Re: [PATCH] pico-imx7d: Remove board_phy_config()
4 Nov
2023
4 Nov
'23
11:45 a.m.
Other pico SoMs still has board_phy_config() also, you should remove it from them, too.pico-imx8mq: https://github.com/u-boot/u-boot/blob/master/board/technexion/pico-imx8mq/pi...
4 Nov
4 Nov
12:54 p.m.
New subject: [PATCH] pico-imx7d: Remove board_phy_config()
On Sat, Nov 4, 2023 at 7:45 AM Szőke Kálmán Benjamin egyszeregy@freemail.hu wrote:
board_phy_config() could probably be removed from these boards too.
To be sure, someone has to test it. If there is a problem with the devicetree description, simply removing board_phy_config() may cause an Ethernet regression.
If you have access to these boards, feel free to test and submit patches.
555
1 comments
2 participants
Fabio Estevam
