Please pull u-boot-marvell/master
Hi Tom,
please pull this first batch of mostly Marvell related patches:
---------------------------------------------------------------- - turris: Misc updates (Pali) - mvebu: handle non-zero base address for RAM (Chris) - mvebu: add support for Methode eDPU (Robert) - mvebu: a3720: Set BOOT_TARGET_DEVICES list to enabled peripherals (Pali) - tlv_eeprom: Add missing CRC32 dependency (Pali) - treewide: Fix Marek's name and change my e-mail address (Marek) - mvebu: eDPU/uDPU: Misc updates (Robert) - mvebu: Avoid reading MVEBU_REG_PCIE_DEVID register too many times (Pali) ----------------------------------------------------------------
Here the Azure build, without any issues:
https://dev.azure.com/sr0718/u-boot/_build/results?buildId=209&view=resu...
Thanks, Stefan
The following changes since commit 88d931a71052fc8fb7b48126ae09aa875745d5ec:
Merge tag 'for-v2022.10' of https://source.denx.de/u-boot/custodians/u-boot-ubi (2022-07-20 07:38:49 -0400)
git@source.denx.de:u-boot/custodians/u-boot-marvell.git
for you to fetch changes up to ca85b5a146ebfd6da81f4b79e4b51eb9c5d6f60b:
arm: mvebu: turris_omnia: Set ETHPRIME to DT alias (2022-07-21 10:14:04 +0200)
---------------------------------------------------------------- Chris Packham (1): arm64: mvebu: handle non-zero base address for RAM
Marek Behún (2): board: turris: Fix MAINTAINERS and add Pali treewide: Fix Marek's name and change my e-mail address
Pali Rohár (7): board: turris: Find atsha device by atsha driver arm: mvebu: a3720: Set BOOT_TARGET_DEVICES list to enabled peripherals arm: mvebu: a3720: Add NVMe to BOOT_TARGET_DEVICES list arch: mvebu: Disable by default unused peripherals in SPL tlv_eeprom: Add missing CRC32 dependency arm: mvebu: Avoid reading MVEBU_REG_PCIE_DEVID register too many times arm: mvebu: turris_omnia: Set ETHPRIME to DT alias
Robert Marko (5): arm: mvebu: dts: sync DTS arm: mvebu: add support for Methode eDPU MAINTAINERS: add myself as Methode maintainer mvebu: eDPU: disable SCSI support mvebu: uDPU: disable non-present peripherals
.mailmap | 2 + MAINTAINERS | 20 +-- arch/arm/dts/Makefile | 1 + arch/arm/dts/armada-3720-eDPU-u-boot.dtsi | 45 +++++++ arch/arm/dts/armada-3720-eDPU.dts | 14 ++ arch/arm/dts/armada-3720-uDPU.dts | 155 +--------------------- arch/arm/dts/armada-3720-uDPU.dtsi | 160 +++++++++++++++++++++++ arch/arm/dts/armada-385-turris-omnia-u-boot.dtsi | 2 +- arch/arm/dts/armada-385-turris-omnia.dts | 6 + arch/arm/mach-mvebu/arm64-common.c | 7 +- arch/arm/mach-mvebu/armada3700/cpu.c | 2 +- arch/arm/mach-mvebu/armada3700/mbox.c | 2 +- arch/arm/mach-mvebu/cpu.c | 67 ++++------ arch/arm/mach-mvebu/dram.c | 18 +-- arch/arm/mach-mvebu/include/mach/cpu.h | 9 -- arch/arm/mach-mvebu/include/mach/mbox.h | 2 +- board/CZ.NIC/turris_atsha_otp.c | 7 +- board/CZ.NIC/turris_mox/MAINTAINERS | 6 +- board/CZ.NIC/turris_mox/Makefile | 2 +- board/CZ.NIC/turris_mox/mox_sp.c | 2 +- board/CZ.NIC/turris_mox/mox_sp.h | 2 +- board/CZ.NIC/turris_mox/turris_mox.c | 2 +- board/CZ.NIC/turris_omnia/MAINTAINERS | 7 +- board/CZ.NIC/turris_omnia/Makefile | 2 +- board/CZ.NIC/turris_omnia/turris_omnia.c | 2 +- board/Marvell/mvebu_armada-37xx/MAINTAINERS | 5 - cmd/Kconfig | 2 + cmd/btrfs.c | 2 +- common/spl/Kconfig | 2 + configs/eDPU_defconfig | 99 ++++++++++++++ configs/turris_omnia_defconfig | 2 +- configs/uDPU_defconfig | 7 +- disk/Kconfig | 2 + doc/kwboot.1 | 2 +- drivers/clk/mvebu/armada-37xx-periph.c | 2 +- drivers/clk/mvebu/armada-37xx-tbg.c | 2 +- drivers/misc/atsha204a-i2c.c | 2 +- drivers/mmc/Kconfig | 1 + drivers/rtc/armada38x.c | 2 +- drivers/usb/Kconfig | 1 + drivers/watchdog/armada-37xx-wdt.c | 2 +- drivers/watchdog/orion_wdt.c | 2 +- fs/btrfs/Makefile | 2 +- fs/btrfs/btrfs.c | 2 +- fs/btrfs/btrfs.h | 2 +- fs/btrfs/compression.c | 2 +- fs/btrfs/conv-funcs.h | 2 +- fs/btrfs/ctree.c | 2 +- fs/btrfs/ctree.h | 2 +- fs/btrfs/dev.c | 2 +- fs/btrfs/dir-item.c | 2 +- fs/btrfs/extent-io.c | 2 +- fs/btrfs/inode.c | 2 +- fs/btrfs/subvolume.c | 2 +- fs/fs_internal.c | 2 +- include/atsha204a-i2c.h | 2 +- include/btrfs.h | 2 +- include/configs/mvebu_armada-37xx.h | 49 ++++++- include/configs/turris_mox.h | 2 +- include/configs/turris_omnia.h | 2 +- include/fs_internal.h | 2 +- include/u-boot/variadic-macro.h | 2 +- scripts/gen_ll_addressable_symbols.sh | 2 +- tools/kwboot.c | 2 +- tools/termios_linux.h | 2 +- 65 files changed, 481 insertions(+), 293 deletions(-) create mode 100644 arch/arm/dts/armada-3720-eDPU-u-boot.dtsi create mode 100644 arch/arm/dts/armada-3720-eDPU.dts create mode 100644 arch/arm/dts/armada-3720-uDPU.dtsi create mode 100644 configs/eDPU_defconfig
Stefan Roese
