[U-Boot] [PATCH v3 00/11] Add BF60x processor support to Blackfin architecture.
ADSP-BF60x is the new generation Blackfin® dual-core processor announced by Analog Devices in late March, 2012. This patch set adds BF60x processor support to Das U-Boot Blackfin architecture.
For more information, see http://blackfin.uclinux.org .
The v3 patches fix the review issues against v1 and v2 from Wolfgang. See the change log in each patches for details.
Bob Liu (5): Blackfin: bf60x: new processor header files Blackfin: bf60x: add dma support Blackfin: bf60x: support big cplb page Blackfin: bf60x: add gpio support Blackfin: bf60x: add hw watchdog support
Scott Jiang (1): Blackfin: spi: add bf6xx spi driver
Sonic Zhang (4): Blackfin: bf60x: Port blackfin core architecture code to boot on bf60x. Blackfin: bf60x: add serial support blackfin: bf609: add board and headers files to support bf609 Blackfin: bf60x: add rsi/sdh support
Steven Miao (1): Blackfin: bf60x: add resume from hibernate
MAINTAINERS | 3 +- arch/blackfin/cpu/cpu.c | 4 +- arch/blackfin/cpu/gpio.c | 36 ++- arch/blackfin/cpu/initcode.c | 385 +++++++++++++++++++- arch/blackfin/cpu/initcode.h | 52 +++ arch/blackfin/cpu/reset.c | 6 + arch/blackfin/cpu/serial.c | 81 +++-- arch/blackfin/cpu/serial.h | 222 +----------- arch/blackfin/cpu/serial1.h | 348 ++++++++++++++++++ arch/blackfin/cpu/serial4.h | 161 ++++++++ arch/blackfin/cpu/start.S | 2 + arch/blackfin/include/asm/blackfin_cdef.h | 3 + arch/blackfin/include/asm/blackfin_def.h | 5 + arch/blackfin/include/asm/blackfin_local.h | 3 + arch/blackfin/include/asm/config-pre.h | 4 + arch/blackfin/include/asm/cplb.h | 31 ++- arch/blackfin/include/asm/dma.h | 81 +++-- arch/blackfin/include/asm/gpio.h | 2 +- arch/blackfin/include/asm/mach-bf533/BF531_def.h | 1 + arch/blackfin/include/asm/mach-bf561/BF561_def.h | 1 + arch/blackfin/include/asm/mach-bf609/BF609_cdef.h | 192 ++++++++++ arch/blackfin/include/asm/mach-bf609/BF609_def.h | 241 ++++++++++++ arch/blackfin/include/asm/mach-bf609/anomaly.h | 97 +++++ arch/blackfin/include/asm/mach-bf609/def_local.h | 5 + arch/blackfin/include/asm/mach-bf609/gpio.h | 151 ++++++++ arch/blackfin/include/asm/mach-bf609/portmux.h | 257 +++++++++++++ arch/blackfin/include/asm/mach-bf609/ports.h | 103 ++++++ arch/blackfin/include/asm/mach-common/bits/cgu.h | 80 ++++ arch/blackfin/include/asm/mach-common/bits/dde.h | 88 +++++ arch/blackfin/include/asm/mach-common/bits/dma.h | 54 +++- arch/blackfin/include/asm/mach-common/bits/mpu.h | 6 +- arch/blackfin/include/asm/mach-common/bits/pll.h | 5 + arch/blackfin/include/asm/mach-common/bits/sdh.h | 38 ++- .../blackfin/include/asm/mach-common/bits/spi6xx.h | 240 ++++++++++++ arch/blackfin/include/asm/mach-common/bits/uart4.h | 66 ++++ arch/blackfin/lib/board.c | 25 ++- arch/blackfin/lib/clocks.c | 112 +++++- arch/blackfin/lib/string.c | 97 +++--- board/bf609-ezkit/Makefile | 55 +++ board/bf609-ezkit/bf609-ezkit.c | 67 ++++ boards.cfg | 1 + common/cmd_reginfo.c | 19 +- drivers/mmc/bfin_sdh.c | 68 +++- drivers/spi/Makefile | 1 + drivers/spi/bfin_spi6xx.c | 308 ++++++++++++++++ include/configs/bf609-ezkit.h | 162 ++++++++ include/configs/bfin_adi_common.h | 12 +- 47 files changed, 3585 insertions(+), 396 deletions(-) create mode 100644 arch/blackfin/cpu/serial1.h create mode 100644 arch/blackfin/cpu/serial4.h create mode 100644 arch/blackfin/include/asm/mach-bf609/BF609_cdef.h create mode 100644 arch/blackfin/include/asm/mach-bf609/BF609_def.h create mode 100644 arch/blackfin/include/asm/mach-bf609/anomaly.h create mode 100644 arch/blackfin/include/asm/mach-bf609/def_local.h create mode 100644 arch/blackfin/include/asm/mach-bf609/gpio.h create mode 100644 arch/blackfin/include/asm/mach-bf609/portmux.h create mode 100644 arch/blackfin/include/asm/mach-bf609/ports.h create mode 100644 arch/blackfin/include/asm/mach-common/bits/cgu.h create mode 100644 arch/blackfin/include/asm/mach-common/bits/dde.h create mode 100644 arch/blackfin/include/asm/mach-common/bits/spi6xx.h create mode 100644 arch/blackfin/include/asm/mach-common/bits/uart4.h create mode 100644 board/bf609-ezkit/Makefile create mode 100644 board/bf609-ezkit/bf609-ezkit.c create mode 100644 drivers/spi/bfin_spi6xx.c create mode 100644 include/configs/bf609-ezkit.h
Add header files for blackfin new processor bf60x.
Fix review issues from Wolfgang: 1) Remove "DO NOT EDIT THIS FILE" comments in anomaly.h 2) Trim the head file to those that are used. 3) Fix all checkpatch issues
Signed-off-by: Bob Liu lliubbo@gmail.com Signed-off-by: Sonic Zhang sonic.zhang@analog.com --- arch/blackfin/include/asm/blackfin_cdef.h | 3 + arch/blackfin/include/asm/blackfin_def.h | 5 + arch/blackfin/include/asm/blackfin_local.h | 3 + arch/blackfin/include/asm/mach-bf609/BF609_cdef.h | 192 +++++++++++++++ arch/blackfin/include/asm/mach-bf609/BF609_def.h | 241 +++++++++++++++++++ arch/blackfin/include/asm/mach-bf609/anomaly.h | 97 ++++++++ arch/blackfin/include/asm/mach-bf609/def_local.h | 5 + arch/blackfin/include/asm/mach-bf609/portmux.h | 257 +++++++++++++++++++++ arch/blackfin/include/asm/mach-bf609/ports.h | 103 ++++++++ arch/blackfin/include/asm/mach-common/bits/cgu.h | 80 +++++++ arch/blackfin/include/asm/mach-common/bits/dde.h | 88 +++++++ arch/blackfin/include/asm/mach-common/bits/mpu.h | 6 +- arch/blackfin/include/asm/mach-common/bits/pll.h | 5 + 13 files changed, 1084 insertions(+), 1 deletions(-) create mode 100644 arch/blackfin/include/asm/mach-bf609/BF609_cdef.h create mode 100644 arch/blackfin/include/asm/mach-bf609/BF609_def.h create mode 100644 arch/blackfin/include/asm/mach-bf609/anomaly.h create mode 100644 arch/blackfin/include/asm/mach-bf609/def_local.h create mode 100644 arch/blackfin/include/asm/mach-bf609/portmux.h create mode 100644 arch/blackfin/include/asm/mach-bf609/ports.h create mode 100644 arch/blackfin/include/asm/mach-common/bits/cgu.h create mode 100644 arch/blackfin/include/asm/mach-common/bits/dde.h
diff --git a/arch/blackfin/include/asm/blackfin_cdef.h b/arch/blackfin/include/asm/blackfin_cdef.h index a19f0f7..8608711 100644 --- a/arch/blackfin/include/asm/blackfin_cdef.h +++ b/arch/blackfin/include/asm/blackfin_cdef.h @@ -84,5 +84,8 @@ #ifdef __ADSPBF561__ # include "mach-bf561/BF561_cdef.h" #endif +#ifdef __ADSPBF609__ +# include "mach-bf609/BF609_cdef.h" +#endif
#endif /* __MACH_CDEF_BLACKFIN__ */ diff --git a/arch/blackfin/include/asm/blackfin_def.h b/arch/blackfin/include/asm/blackfin_def.h index f06d1f1..c96a3ec 100644 --- a/arch/blackfin/include/asm/blackfin_def.h +++ b/arch/blackfin/include/asm/blackfin_def.h @@ -136,5 +136,10 @@ # include "mach-bf561/anomaly.h" # include "mach-bf561/def_local.h" #endif +#ifdef __ADSPBF609__ +# include "mach-bf609/BF609_def.h" +# include "mach-bf609/anomaly.h" +# include "mach-bf609/def_local.h" +#endif
#endif /* __MACH_DEF_BLACKFIN__ */ diff --git a/arch/blackfin/include/asm/blackfin_local.h b/arch/blackfin/include/asm/blackfin_local.h index 49d0c9e..fc46ef4 100644 --- a/arch/blackfin/include/asm/blackfin_local.h +++ b/arch/blackfin/include/asm/blackfin_local.h @@ -61,6 +61,9 @@ extern u_long get_vco(void); extern u_long get_cclk(void); extern u_long get_sclk(void); +extern u_long get_sclk0(void); +extern u_long get_sclk1(void); +extern u_long get_dclk(void);
# define bfin_revid() (bfin_read_CHIPID() >> 28)
diff --git a/arch/blackfin/include/asm/mach-bf609/BF609_cdef.h b/arch/blackfin/include/asm/mach-bf609/BF609_cdef.h new file mode 100644 index 0000000..c590031 --- /dev/null +++ b/arch/blackfin/include/asm/mach-bf609/BF609_cdef.h @@ -0,0 +1,192 @@ +/* DO NOT EDIT THIS FILE + * Automatically generated by generate-cdef-headers.xsl + * DO NOT EDIT THIS FILE + */ + +#ifndef __BFIN_CDEF_ADSP_BF609_proc__ +#define __BFIN_CDEF_ADSP_BF609_proc__ + +#include "../mach-common/ADSP-EDN-core_cdef.h" + +#define bfin_read_CGU_STAT() bfin_read32(CGU_STAT) +#define bfin_read_CGU_CLKOUTSEL() bfin_read32(CGU_CLKOUTSEL) +#define bfin_read_CGU_CTL() bfin_read32(CGU_CTL) +#define bfin_write_CGU_CTL(val) bfin_write32(CGU_CTL, val) +#define bfin_read_CGU_DIV() bfin_read32(CGU_DIV) +#define bfin_write_CGU_DIV(val) bfin_write32(CGU_DIV, val) + +#define bfin_read_RCU0_CTL() bfin_read32(RCU0_CTL) +#define bfin_write_RCU0_CTL(val) bfin_write32(RCU0_CTL, val) + +#define bfin_read_CHIPID() bfin_read32(CHIPID) +#define bfin_write_CHIPID(val) bfin_write32(CHIPID, val) + +#define bfin_read_DMC0_CFG() bfin_read32(DMC0_CFG) +#define bfin_write_DMC0_CFG(val) bfin_write32(DMC0_CFG, val) +#define bfin_read_DMC0_TR0() bfin_read32(DMC0_TR0) +#define bfin_write_DMC0_TR0(val) bfin_write32(DMC0_TR0, val) +#define bfin_read_DMC0_TR1() bfin_read32(DMC0_TR1) +#define bfin_write_DMC0_TR1(val) bfin_write32(DMC0_TR1, val) +#define bfin_read_DMC0_TR2() bfin_read32(DMC0_TR2) +#define bfin_write_DMC0_TR2(val) bfin_write32(DMC0_TR2, val) +#define bfin_read_DMC0_MR() bfin_read32(DMC0_MR) +#define bfin_write_DMC0_MR(val) bfin_write32(DMC0_MR, val) +#define bfin_read_DMC0_EMR1() bfin_read32(DMC0_EMR1) +#define bfin_write_DMC0_EMR1(val) bfin_write32(DMC0_EMR1, val) +#define bfin_read_DMC0_CTL() bfin_read32(DMC0_CTL) +#define bfin_write_DMC0_CTL(val) bfin_write32(DMC0_CTL, val) +#define bfin_read_DMC0_STAT() bfin_read32(DMC0_STAT) +#define bfin_write_DMC0_STAT(val) bfin_write32(DMC0_STAT, val) +#define bfin_read_DMC0_DLLCTL() bfin_read32(DMC0_DLLCTL) +#define bfin_write_DMC0_DLLCTL(val) bfin_write32(DMC0_DLLCTL, val) + +#define bfin_read_SEC_CCTL() bfin_read32(SEC0_CCTL0) +#define bfin_write_SEC_CCTL(val) bfin_write32(SEC0_CCTL0, val) +#define bfin_read_SEC_GCTL() bfin_read32(SEC0_GCTL) +#define bfin_write_SEC_GCTL(val) bfin_write32(SEC0_GCTL, val) + +#define bfin_read_SEC_FCTL() bfin_read32(SEC0_FCTL) +#define bfin_write_SEC_FCTL(val) bfin_write32(SEC0_FCTL, val) +#define bfin_read_SEC_SCTL(sid) bfin_read32((SEC0_SCTL0 + (sid) * 8)) +#define bfin_write_SEC_SCTL(sid, val) bfin_write32((SEC0_SCTL0 \ + + (sid) * 8), val) + +#define bfin_read_SMC_GCTL() bfin_read32(SMC_GCTL) +#define bfin_write_SMC_GCTL(val) bfin_write32(SMC_GCTL, val) +#define bfin_read_SMC_GSTAT() bfin_read32(SMC_GSTAT) +#define bfin_read_SMC_B0CTL() bfin_read32(SMC_B0CTL) +#define bfin_write_SMC_B0CTL(val) bfin_write32(SMC_B0CTL, val) +#define bfin_read_SMC_B0TIM() bfin_read32(SMC_B0TIM) +#define bfin_write_SMC_B0TIM(val) bfin_write32(SMC_B0TIM, val) +#define bfin_read_SMC_B0ETIM() bfin_read32(SMC_B0ETIM) +#define bfin_write_SMC_B0ETIM(val) bfin_write32(SMC_B0ETIM, val) +#define bfin_read_SMC_B1CTL() bfin_read32(SMC_B1CTL) +#define bfin_write_SMC_B1CTL(val) bfin_write32(SMC_B1CTL, val) +#define bfin_read_SMC_B1TIM() bfin_read32(SMC_B1TIM) +#define bfin_write_SMC_B1TIM(val) bfin_write32(SMC_B1TIM, val) +#define bfin_read_SMC_B1ETIM() bfin_read32(SMC_B1ETIM) +#define bfin_write_SMC_B1ETIM(val) bfin_write32(SMC_B1ETIM, val) +#define bfin_read_SMC_B2CTL() bfin_read32(SMC_B2CTL) +#define bfin_write_SMC_B2CTL(val) bfin_write32(SMC_B2CTL, val) +#define bfin_read_SMC_B2TIM() bfin_read32(SMC_B2TIM) +#define bfin_write_SMC_B2TIM(val) bfin_write32(SMC_B2TIM, val) +#define bfin_read_SMC_B2ETIM() bfin_read32(SMC_B2ETIM) +#define bfin_write_SMC_B2ETIM(val) bfin_write32(SMC_B2ETIM, val) +#define bfin_read_SMC_B3CTL() bfin_read32(SMC_B3CTL) +#define bfin_write_SMC_B3CTL(val) bfin_write32(SMC_B3CTL, val) +#define bfin_read_SMC_B3TIM() bfin_read32(SMC_B3TIM) +#define bfin_write_SMC_B3TIM(val) bfin_write32(SMC_B3TIM, val) +#define bfin_read_SMC_B3ETIM() bfin_read32(SMC_B3ETIM) +#define bfin_write_SMC_B3ETIM(val) bfin_write32(SMC_B3ETIM, val) + +#define bfin_read_USB_PLLOSC_CTRL() bfin_read16(USB_PLL_OSC) +#define bfin_write_USB_PLLOSC_CTRL(val) bfin_write16(USB_PLL_OSC, val) +#define bfin_write_USB_VBUS_CTL(val) bfin_write8(USB_VBUS_CTL, val) +#define bfin_read_USB_DMA_INTERRUPT() bfin_read8(USB_DMA_IRQ) +#define bfin_write_USB_DMA_INTERRUPT(val) bfin_write8(USB_DMA_IRQ, val) +#define bfin_write_USB_APHY_CNTRL(val) bfin_write8(USB_PHY_CTL, val) +#define bfin_read_USB_APHY_CNTRL() bfin_read8(USB_PHY_CTL) + +#define bfin_read_DMA10_NEXT_DESC_PTR() bfin_readPTR(DMA10_DSCPTR_NXT) +#define bfin_write_DMA10_NEXT_DESC_PTR(val) bfin_writePTR(DMA10_DSCPTR_NXT, val) +#define bfin_read_DMA10_START_ADDR() bfin_readPTR(DMA10_ADDRSTART) +#define bfin_write_DMA10_START_ADDR(val) bfin_writePTR(DMA10_ADDRSTART, val) +#define bfin_read_DMA10_CONFIG() bfin_read32(DMA10_CFG) +#define bfin_write_DMA10_CONFIG(val) bfin_write32(DMA10_CFG, val) +#define bfin_read_DMA10_X_COUNT() bfin_read32(DMA10_XCNT) +#define bfin_write_DMA10_X_COUNT(val) bfin_write32(DMA10_XCNT, val) +#define bfin_read_DMA10_X_MODIFY() bfin_read32(DMA10_XMOD) +#define bfin_write_DMA10_X_MODIFY(val) bfin_write32(DMA10_XMOD, val) +#define bfin_read_DMA10_Y_COUNT() bfin_read32(DMA10_YCNT) +#define bfin_write_DMA10_Y_COUNT(val) bfin_write32(DMA10_YCNT, val) +#define bfin_read_DMA10_Y_MODIFY() bfin_read32(DMA10_YMOD) +#define bfin_write_DMA10_Y_MODIFY(val) bfin_write32(DMA10_YMOD, val) +#define bfin_read_DMA10_CURR_DESC_PTR() bfin_readPTR(DMA10_DSCPTR_CUR) +#define bfin_write_DMA10_CURR_DESC_PTR(val) bfin_writePTR(DMA10_DSCPTR_CUR, val) +#define bfin_read_DMA10_CURR_ADDR() bfin_readPTR(DMA10_ADDR_CUR) +#define bfin_write_DMA10_CURR_ADDR(val) bfin_writePTR(DMA10_ADDR_CUR, val) +#define bfin_read_DMA10_IRQ_STATUS() bfin_read32(DMA10_STAT) +#define bfin_write_DMA10_IRQ_STATUS(val) bfin_write32(DMA10_STAT, val) +#define bfin_read_DMA10_CURR_X_COUNT() bfin_read32(DMA10_XCNT_CUR) +#define bfin_write_DMA10_CURR_X_COUNT(val) bfin_write32(DMA10_XCNT_CUR, val) +#define bfin_read_DMA10_CURR_Y_COUNT() bfin_read32(DMA10_YCNT_CUR) +#define bfin_write_DMA10_CURR_Y_COUNT(val) bfin_write32(DMA10_YCNT_CUR, val) + +#define bfin_read_WDOG_CNT() bfin_read32(WDOG_CNT) +#define bfin_write_WDOG_CNT(val) bfin_write32(WDOG_CNT, val) +#define bfin_read_WDOG_CTL() bfin_read32(WDOG_CTL) +#define bfin_write_WDOG_CTL(val) bfin_write32(WDOG_CTL, val) +#define bfin_read_WDOG_STAT() bfin_read32(WDOG_STAT) +#define bfin_write_WDOG_STAT(val) bfin_write32(WDOG_STAT, val) +#define bfin_read_SPI_BAUD() bfin_read32(SPI0_CLK) +#define bfin_write_SPI_BAUD(val) bfin_write32(SPI0_CLK, val) + +#define bfin_read_PORTD_FER() bfin_read32(PORTD_FER) +#define bfin_write_PORTD_FER_SET(val) bfin_write32(PORTD_FER_SET, val) +#define bfin_write_PORTD_FER_CLR(val) bfin_write32(PORTD_FER_CLR, val) +#define bfin_read_PORTD_MUX() bfin_read32(PORTD_MUX) +#define bfin_write_PORTD_MUX(val) bfin_write32(PORTD_MUX, val) +#define bfin_read_PORTG_FER() bfin_read32(PORTG_FER) +#define bfin_write_PORTG_FER_SET(val) bfin_write32(PORTG_FER_SET, val) +#define bfin_write_PORTG_FER_CLR(val) bfin_write32(PORTG_FER_CLR, val) +#define bfin_read_PORTG_MUX() bfin_read32(PORTG_MUX) +#define bfin_write_PORTG_MUX(val) bfin_write32(PORTG_MUX, val) + +#define bfin_read_RSI_CLK_CONTROL() bfin_read16(RSI_CLK_CONTROL) +#define bfin_write_RSI_CLK_CONTROL(val) bfin_write16(RSI_CLK_CONTROL, val) +#define bfin_read_RSI_ARGUMENT() bfin_read32(RSI_ARGUMENT) +#define bfin_write_RSI_ARGUMENT(val) bfin_write32(RSI_ARGUMENT, val) +#define bfin_read_RSI_COMMAND() bfin_read16(RSI_COMMAND) +#define bfin_write_RSI_COMMAND(val) bfin_write16(RSI_COMMAND, val) +#define bfin_read_RSI_RESP_CMD() bfin_read16(RSI_RESP_CMD) +#define bfin_write_RSI_RESP_CMD(val) bfin_write16(RSI_RESP_CMD, val) +#define bfin_read_RSI_RESPONSE0() bfin_read32(RSI_RESPONSE0) +#define bfin_write_RSI_RESPONSE0(val) bfin_write32(RSI_RESPONSE0, val) +#define bfin_read_RSI_RESPONSE1() bfin_read32(RSI_RESPONSE1) +#define bfin_write_RSI_RESPONSE1(val) bfin_write32(RSI_RESPONSE1, val) +#define bfin_read_RSI_RESPONSE2() bfin_read32(RSI_RESPONSE2) +#define bfin_write_RSI_RESPONSE2(val) bfin_write32(RSI_RESPONSE2, val) +#define bfin_read_RSI_RESPONSE3() bfin_read32(RSI_RESPONSE3) +#define bfin_write_RSI_RESPONSE3(val) bfin_write32(RSI_RESPONSE3, val) +#define bfin_read_RSI_DATA_TIMER() bfin_read32(RSI_DATA_TIMER) +#define bfin_write_RSI_DATA_TIMER(val) bfin_write32(RSI_DATA_TIMER, val) +#define bfin_read_RSI_DATA_LGTH() bfin_read16(RSI_DATA_LGTH) +#define bfin_write_RSI_DATA_LGTH(val) bfin_write16(RSI_DATA_LGTH, val) +#define bfin_read_RSI_DATA_CONTROL() bfin_read16(RSI_DATA_CONTROL) +#define bfin_write_RSI_DATA_CONTROL(val) bfin_write16(RSI_DATA_CONTROL, val) +#define bfin_read_RSI_DATA_CNT() bfin_read16(RSI_DATA_CNT) +#define bfin_write_RSI_DATA_CNT(val) bfin_write16(RSI_DATA_CNT, val) +#define bfin_read_RSI_STATUS() bfin_read32(RSI_STATUS) +#define bfin_write_RSI_STATUS(val) bfin_write32(RSI_STATUS, val) +#define bfin_read_RSI_STATUSCL() bfin_read16(RSI_STATUSCL) +#define bfin_write_RSI_STATUSCL(val) bfin_write16(RSI_STATUSCL, val) +#define bfin_read_RSI_MASK0() bfin_read32(RSI_MASK0) +#define bfin_write_RSI_MASK0(val) bfin_write32(RSI_MASK0, val) +#define bfin_read_RSI_MASK1() bfin_read32(RSI_MASK1) +#define bfin_write_RSI_MASK1(val) bfin_write32(RSI_MASK1, val) +#define bfin_read_RSI_FIFO_CNT() bfin_read16(RSI_FIFO_CNT) +#define bfin_write_RSI_FIFO_CNT(val) bfin_write16(RSI_FIFO_CNT, val) +#define bfin_read_RSI_CEATA_CONTROL() bfin_read16(RSI_CEATA_CONTROL) +#define bfin_write_RSI_CEATA_CONTROL(val) bfin_write16(RSI_CEATA_CONTROL, val) +#define bfin_read_RSI_BLKSZ() bfin_read16(RSI_BLKSZ) +#define bfin_write_RSI_BLKSZ(val) bfin_write16(RSI_BLKSZ, val) +#define bfin_read_RSI_FIFO() bfin_read32(RSI_FIFO) +#define bfin_write_RSI_FIFO(val) bfin_write32(RSI_FIFO, val) +#define bfin_read_RSI_ESTAT() bfin_read32(RSI_ESTAT) +#define bfin_write_RSI_ESTAT(val) bfin_write32(RSI_ESTAT, val) +#define bfin_read_RSI_EMASK() bfin_read32(RSI_EMASK) +#define bfin_write_RSI_EMASK(val) bfin_write32(RSI_EMASK, val) +#define bfin_read_RSI_CONFIG() bfin_read16(RSI_CONFIG) +#define bfin_write_RSI_CONFIG(val) bfin_write16(RSI_CONFIG, val) +#define bfin_read_RSI_RD_WAIT_EN() bfin_read16(RSI_RD_WAIT_EN) +#define bfin_write_RSI_RD_WAIT_EN(val) bfin_write16(RSI_RD_WAIT_EN, val) +#define bfin_read_RSI_PID0() bfin_read16(RSI_PID0) +#define bfin_write_RSI_PID0(val) bfin_write16(RSI_PID0, val) +#define bfin_read_RSI_PID1() bfin_read16(RSI_PID1) +#define bfin_write_RSI_PID1(val) bfin_write16(RSI_PID1, val) +#define bfin_read_RSI_PID2() bfin_read16(RSI_PID2) +#define bfin_write_RSI_PID2(val) bfin_write16(RSI_PID2, val) +#define bfin_read_RSI_PID3() bfin_read16(RSI_PID3) +#define bfin_write_RSI_PID3(val) bfin_write16(RSI_PID3, val) + +#endif /* __BFIN_CDEF_ADSP_BF609_proc__ */ diff --git a/arch/blackfin/include/asm/mach-bf609/BF609_def.h b/arch/blackfin/include/asm/mach-bf609/BF609_def.h new file mode 100644 index 0000000..0fb0fdf --- /dev/null +++ b/arch/blackfin/include/asm/mach-bf609/BF609_def.h @@ -0,0 +1,241 @@ +/* DO NOT EDIT THIS FILE + * Automatically generated by generate-def-headers.xsl + * DO NOT EDIT THIS FILE + */ + +#ifndef __BFIN_DEF_ADSP_BF609_proc__ +#define __BFIN_DEF_ADSP_BF609_proc__ + +#include "../mach-common/ADSP-EDN-core_def.h" + +#define RSI_CLK_CONTROL 0xFFC00604 /* RSI0 Clock Control Register */ +#define RSI_ARGUMENT 0xFFC00608 /* RSI0 Argument Register */ +#define RSI_COMMAND 0xFFC0060C /* RSI0 Command Register */ +#define RSI_RESP_CMD 0xFFC00610 /* RSI0 Response Command Register */ +#define RSI_RESPONSE0 0xFFC00614 /* RSI0 Response 0 Register */ +#define RSI_RESPONSE1 0xFFC00618 /* RSI0 Response 1 Register */ +#define RSI_RESPONSE2 0xFFC0061C /* RSI0 Response 2 Register */ +#define RSI_RESPONSE3 0xFFC00620 /* RSI0 Response 3 Register */ +#define RSI_DATA_TIMER 0xFFC00624 /* RSI0 Data Timer Register */ +#define RSI_DATA_LGTH 0xFFC00628 /* RSI0 Data Length Register */ +#define RSI_DATA_CONTROL 0xFFC0062C /* RSI0 Data Control Register */ +#define RSI_DATA_CNT 0xFFC00630 /* RSI0 Data Count Register */ +#define RSI_STATUS 0xFFC00634 /* RSI0 Status Register */ +#define RSI_STATUSCL 0xFFC00638 /* RSI0 Status Clear Register */ +#define RSI_IMSK0 0xFFC0063C /* RSI0 Interrupt 0 Mask Register */ +#define RSI_IMSK1 0xFFC00640 /* RSI0 Interrupt 1 Mask Register */ +#define RSI_FIFO_CNT 0xFFC00648 /* RSI0 FIFO Counter Register */ +#define RSI_CEATA_CONTROL 0xFFC0064C /* RSI0 contains bit to dis CCS gen */ +#define RSI_BOOT_TCNTR 0xFFC00650 /* RSI0 Boot Timing Counter Register */ +#define RSI_BACK_TOUT 0xFFC00654 /* RSI0 Boot Ack Timeout Register */ +#define RSI_SLP_WKUP_TOUT 0xFFC00658 /* RSI0 Sleep Wakeup Timeout Register */ +#define RSI_BLKSZ 0xFFC0065C /* RSI0 Block Size Register */ +#define RSI_FIFO 0xFFC00680 /* RSI0 Data FIFO Register */ +#define RSI_ESTAT 0xFFC006C0 /* RSI0 Exception Status Register */ +#define RSI_EMASK 0xFFC006C4 /* RSI0 Exception Mask Register */ +#define RSI_CONFIG 0xFFC006C8 /* RSI0 Configuration Register */ +#define RSI_RD_WAIT_EN 0xFFC006CC /* RSI0 Read Wait Enable Register */ +#define RSI_PID0 0xFFC006D0 /* RSI0 Peripheral Id Register */ +#define RSI_PID1 0xFFC006D4 /* RSI0 Peripheral Id Register */ +#define RSI_PID2 0xFFC006D8 /* RSI0 Peripheral Id Register */ +#define RSI_PID3 0xFFC006DC /* RSI0 Peripheral Id Register */ + +#define TWI0_CLKDIV 0xFFC01E00 /* TWI0 SCL Clock Divider */ +#define TWI1_CLKDIV 0xFFC01F00 /* TWI1 SCL Clock Divider */ + +#define UART0_REVID 0xFFC02000 /* UART0 Revision ID Register */ +#define UART0_CTL 0xFFC02004 /* UART0 Control Register */ +#define UART0_STAT 0xFFC02008 /* UART0 Status Register */ +#define UART0_SCR 0xFFC0200C /* UART0 Scratch Register */ +#define UART0_CLK 0xFFC02010 /* UART0 Clock Rate Register */ +#define UART0_IMSK 0xFFC02014 /* UART0 Interrupt Mask Register */ +#define UART0_IMSK_SET 0xFFC02018 /* UART0 Interrupt Mask Set Register */ +#define UART0_IMSK_CLR 0xFFC0201C /* UART0 Interrupt Mask Clear Register */ +#define UART0_RBR 0xFFC02020 /* UART0 Receive Buffer Register */ +#define UART0_THR 0xFFC02024 /* UART0 Transmit Hold Register */ +#define UART0_TAIP 0xFFC02028 /* UART0 TX Address/Insert Pulse Reg */ +#define UART0_TSR 0xFFC0202C /* UART0 Transmit Shift Register */ +#define UART0_RSR 0xFFC02030 /* UART0 Receive Shift Register */ +#define UART0_TXCNT 0xFFC02034 /* UART0 Transmit Counter Register */ +#define UART0_RXCNT 0xFFC02038 /* UART0 Receive Counter Register */ +#define UART1_REVID 0xFFC02400 /* UART1 Revision ID Register */ +#define UART1_CTL 0xFFC02404 /* UART1 Control Register */ +#define UART1_STAT 0xFFC02408 /* UART1 Status Register */ +#define UART1_SCR 0xFFC0240C /* UART1 Scratch Register */ +#define UART1_CLK 0xFFC02410 /* UART1 Clock Rate Register */ +#define UART1_IMSK 0xFFC02414 /* UART1 Interrupt Mask Register */ +#define UART1_IMSK_SET 0xFFC02418 /* UART1 Interrupt Mask Set Register */ +#define UART1_IMSK_CLR 0xFFC0241C /* UART1 Interrupt Mask Clear Register */ +#define UART1_RBR 0xFFC02420 /* UART1 Receive Buffer Register */ +#define UART1_THR 0xFFC02424 /* UART1 Transmit Hold Register */ +#define UART1_TAIP 0xFFC02428 /* UART1 TX Address/Insert Pulse Reg */ +#define UART1_TSR 0xFFC0242C /* UART1 Transmit Shift Register */ +#define UART1_RSR 0xFFC02430 /* UART1 Receive Shift Register */ +#define UART1_TXCNT 0xFFC02434 /* UART1 Transmit Counter Register */ +#define UART1_RXCNT 0xFFC02438 /* UART1 Receive Counter Register */ + +#define PORTA_FER 0xFFC03000 /* PORTA Port x Function Enable */ +#define PORTA_FER_SET 0xFFC03004 /* PORTA Port x Function Enable Set */ +#define PORTA_FER_CLR 0xFFC03008 /* PORTA Port x Function Enable Clear */ +#define PORTA_MUX 0xFFC03030 /* PORTA Port x Multiplexer Control */ +#define PORTB_FER 0xFFC03080 /* PORTB Port x Function Enable */ +#define PORTB_FER_SET 0xFFC03084 /* PORTB Port x Function Enable Set */ +#define PORTB_FER_CLR 0xFFC03088 /* PORTB Port x Function Enable Clear */ +#define PORTB_MUX 0xFFC030B0 /* PORTB Port x Multiplexer Control */ +#define PORTC_FER 0xFFC03100 /* PORTC Port x Function Enable */ +#define PORTC_FER_SET 0xFFC03104 /* PORTC Port x Function Enable Set */ +#define PORTC_FER_CLR 0xFFC03108 /* PORTC Port x Function Enable Clear */ +#define PORTC_MUX 0xFFC03130 /* PORTC Port x Multiplexer Control */ +#define PORTD_FER 0xFFC03180 /* PORTD Port x Function Enable */ +#define PORTD_FER_SET 0xFFC03184 /* PORTD Port x Function Enable Set */ +#define PORTD_FER_CLR 0xFFC03188 /* PORTD Port x Function Enable Clear */ +#define PORTD_MUX 0xFFC031B0 /* PORTD Port x Multiplexer Control */ +#define PORTE_FER 0xFFC03200 /* PORTE Port x Function Enable */ +#define PORTE_FER_SET 0xFFC03204 /* PORTE Port x Function Enable Set */ +#define PORTE_FER_CLR 0xFFC03208 /* PORTE Port x Function Enable Clear */ +#define PORTE_MUX 0xFFC03230 /* PORTE Port x Multiplexer Control */ +#define PORTF_FER 0xFFC03280 /* PORTF Port x Function Enable */ +#define PORTF_FER_SET 0xFFC03284 /* PORTF Port x Function Enable Set */ +#define PORTF_FER_CLR 0xFFC03288 /* PORTF Port x Function Enable Clear */ +#define PORTF_MUX 0xFFC032B0 /* PORTF Port x Multiplexer Control */ +#define PORTG_FER 0xFFC03300 /* PORTG Port x Function Enable */ +#define PORTG_FER_SET 0xFFC03304 /* PORTG Port x Function Enable Set */ +#define PORTG_FER_CLR 0xFFC03308 /* PORTG Port x Function Enable Clear */ +#define PORTG_MUX 0xFFC03330 /* PORTG Port x Multiplexer Control */ + +#define SMC_GCTL 0xFFC16004 /* SMC Control Register */ +#define SMC_GSTAT 0xFFC16008 /* SMC Status Register */ +#define SMC_B0CTL 0xFFC1600C /* SMC Bank0 Control Register */ +#define SMC_B0TIM 0xFFC16010 /* SMC Bank0 Timing Register */ +#define SMC_B0ETIM 0xFFC16014 /* SMC Bank0 Extended Timing Register */ +#define SMC_B1CTL 0xFFC1601C /* SMC BANK1 Control Register */ +#define SMC_B1TIM 0xFFC16020 /* SMC BANK1 Timing Register */ +#define SMC_B1ETIM 0xFFC16024 /* SMC BANK1 Extended Timing Register */ +#define SMC_B2CTL 0xFFC1602C /* SMC BANK2 Control Register */ +#define SMC_B2TIM 0xFFC16030 /* SMC BANK2 Timing Register */ +#define SMC_B2ETIM 0xFFC16034 /* SMC BANK2 Extended Timing Register */ +#define SMC_B3CTL 0xFFC1603C /* SMC BANK3 Control Register */ +#define SMC_B3TIM 0xFFC16040 /* SMC BANK3 Timing Register */ +#define SMC_B3ETIM 0xFFC16044 /* SMC BANK3 Extended Timing Register */ + +#define WDOG_CTL 0xFFC17000 /* WDOG0 Control Register */ +#define WDOG_CNT 0xFFC17004 /* WDOG0 Count Register */ +#define WDOG_STAT 0xFFC17008 /* WDOG0 Watchdog Timer Status Register */ +#define WDOG1_CTL 0xFFC17800 /* WDOG1 Control Register */ +#define WDOG1_CNT 0xFFC17804 /* WDOG1 Count Register */ +#define WDOG1_STAT 0xFFC17808 /* WDOG1 Watchdog Timer Status Register */ + +#define EMAC0_MACCFG 0xFFC20000 /* EMAC0 MAC Configuration Register */ +#define EMAC1_MACCFG 0xFFC22000 /* EMAC1 MAC Configuration Register */ + +#define DMA10_DSCPTR_NXT 0xFFC05000 /* DMA10 Pointer to Next Initial Desc */ +#define DMA10_ADDRSTART 0xFFC05004 /* DMA10 Start Address of Current Buf */ +#define DMA10_CFG 0xFFC05008 /* DMA10 Configuration Register */ +#define DMA10_XCNT 0xFFC0500C /* DMA10 Inner Loop Count Start Value */ +#define DMA10_XMOD 0xFFC05010 /* DMA10 Inner Loop Address Increment */ +#define DMA10_YCNT 0xFFC05014 /* DMA10 Outer Loop Count Start Value */ +#define DMA10_YMOD 0xFFC05018 /* DMA10 Outer Loop Address Increment */ +#define DMA10_DSCPTR_CUR 0xFFC05024 /* DMA10 Current Descriptor Pointer */ +#define DMA10_DSCPTR_PRV 0xFFC05028 /* DMA10 Previous Initial Desc Pointer */ +#define DMA10_ADDR_CUR 0xFFC0502C /* DMA10 Current Address */ +#define DMA10_STAT 0xFFC05030 /* DMA10 Status Register */ +#define DMA10_XCNT_CUR 0xFFC05034 /* DMA10 Curr Count(1D) or intra-row(2D)*/ +#define DMA10_YCNT_CUR 0xFFC05038 /* DMA10 Curr Row Count (2D only) */ +#define DMA10_BWLCNT 0xFFC05040 /* DMA10 Bandwidth Limit Count */ +#define DMA10_BWLCNT_CUR 0xFFC05044 /* DMA10 Bandwidth Limit Count Current */ +#define DMA10_BWMCNT 0xFFC05048 /* DMA10 Bandwidth Monitor Count */ +#define DMA10_BWMCNT_CUR 0xFFC0504C /* DMA10 Bandwidth Monitor Count Current*/ + +#define MDMA_S0_NEXT_DESC_PTR DMA21_DSCPTR_NXT +#define DMA21_DSCPTR_NXT 0xFFC09000 /* DMA21 Pointer to Next Initial Desc */ +#define MDMA_D0_NEXT_DESC_PTR DMA22_DSCPTR_NXT +#define DMA22_DSCPTR_NXT 0xFFC09080 /* DMA22 Pointer to Next Initial Desc */ + +#define DMC0_ID 0xFFC80000 /* DMC0 Identification Register */ +#define DMC0_CTL 0xFFC80004 /* DMC0 Control Register */ +#define DMC0_STAT 0xFFC80008 /* DMC0 Status Register */ +#define DMC0_EFFCTL 0xFFC8000C /* DMC0 Efficiency Controller */ +#define DMC0_PRIO 0xFFC80010 /* DMC0 Priority ID Register */ +#define DMC0_PRIOMSK 0xFFC80014 /* DMC0 Priority ID Mask */ +#define DMC0_CFG 0xFFC80040 /* DMC0 SDRAM Configuration */ +#define DMC0_TR0 0xFFC80044 /* DMC0 Timing Register 0 */ +#define DMC0_TR1 0xFFC80048 /* DMC0 Timing Register 1 */ +#define DMC0_TR2 0xFFC8004C /* DMC0 Timing Register 2 */ +#define DMC0_MSK 0xFFC8005C /* DMC0 Mode Register Mask */ +#define DMC0_MR 0xFFC80060 /* DMC0 Mode Shadow register */ +#define DMC0_EMR1 0xFFC80064 /* DMC0 EMR1 Shadow Register */ +#define DMC0_EMR2 0xFFC80068 /* DMC0 EMR2 Shadow Register */ +#define DMC0_EMR3 0xFFC8006C /* DMC0 EMR3 Shadow Register */ +#define DMC0_DLLCTL 0xFFC80080 /* DMC0 DLL Control Register */ +#define DMC0_PADCTL 0xFFC800C0 /* DMC0 PAD Control Register 0 */ + +#define RCU0_CTL 0xFFCA6000 /* RCU0 Control Register */ +#define RCU0_STAT 0xFFCA6004 /* RCU0 Status Register */ +#define RCU0_CRCTL 0xFFCA6008 /* RCU0 Core Reset Control Register */ +#define RCU0_CRSTAT 0xFFCA600C /* RCU0 Core Reset Status Register */ +#define RCU0_SIDIS 0xFFCA6010 /* RCU0 Sys Interface Disable Register */ +#define RCU0_SISTAT 0xFFCA6014 /* RCU0 Sys Interface Status Register */ +#define RCU0_SVECT_LCK 0xFFCA6018 /* RCU0 SVECT Lock Register */ +#define RCU0_BCODE 0xFFCA601C /* RCU0 Boot Code Register */ +#define RCU0_SVECT0 0xFFCA6020 /* RCU0 Software Vector Register n */ +#define RCU0_SVECT1 0xFFCA6024 /* RCU0 Software Vector Register n */ + +#define CGU_CTL 0xFFCA8000 /* CGU0 Control Register */ +#define CGU_STAT 0xFFCA8004 /* CGU0 Status Register */ +#define CGU_DIV 0xFFCA8008 /* CGU0 Divisor Register */ +#define CGU_CLKOUTSEL 0xFFCA800C /* CGU0 CLKOUT Select Register */ + +#define DPM0_CTL 0xFFCA9000 /* DPM0 Control Register */ +#define DPM0_STAT 0xFFCA9004 /* DPM0 Status Register */ +#define DPM0_CCBF_DIS 0xFFCA9008 /* DPM0 Core Clock Buffer Disable */ +#define DPM0_CCBF_EN 0xFFCA900C /* DPM0 Core Clock Buffer Enable */ +#define DPM0_CCBF_STAT 0xFFCA9010 /* DPM0 Core Clock Buffer Status */ +#define DPM0_CCBF_STAT_STKY 0xFFCA9014 /* DPM0 Core Clock Buffer Stat Sticky */ +#define DPM0_SCBF_DIS 0xFFCA9018 /* DPM0 System Clock Buffer Disable */ +#define DPM0_WAKE_EN 0xFFCA901C /* DPM0 Wakeup Enable Register */ +#define DPM0_WAKE_POL 0xFFCA9020 /* DPM0 Wakeup Polarity Register */ +#define DPM0_WAKE_STAT 0xFFCA9024 /* DPM0 Wakeup Status Register */ +#define DPM0_HIB_DIS 0xFFCA9028 /* DPM0 Hibernate Disable Register */ +#define DPM0_PGCNTR 0xFFCA902C /* DPM0 Power Good Counter Register */ +#define DPM0_RESTORE0 0xFFCA9030 /* DPM0 Restore Register */ +#define DPM0_RESTORE1 0xFFCA9034 /* DPM0 Restore Register */ +#define DPM0_RESTORE2 0xFFCA9038 /* DPM0 Restore Register */ +#define DPM0_RESTORE3 0xFFCA903C /* DPM0 Restore Register */ +#define DPM0_RESTORE4 0xFFCA9040 /* DPM0 Restore Register */ +#define DPM0_RESTORE5 0xFFCA9044 /* DPM0 Restore Register */ +#define DPM0_RESTORE6 0xFFCA9048 /* DPM0 Restore Register */ +#define DPM0_RESTORE7 0xFFCA904C /* DPM0 Restore Register */ +#define DPM0_RESTORE8 0xFFCA9050 /* DPM0 Restore Register */ +#define DPM0_RESTORE9 0xFFCA9054 /* DPM0 Restore Register */ +#define DPM0_RESTORE10 0xFFCA9058 /* DPM0 Restore Register */ +#define DPM0_RESTORE11 0xFFCA905C /* DPM0 Restore Register */ +#define DPM0_RESTORE12 0xFFCA9060 /* DPM0 Restore Register */ +#define DPM0_RESTORE13 0xFFCA9064 /* DPM0 Restore Register */ +#define DPM0_RESTORE14 0xFFCA9068 /* DPM0 Restore Register */ +#define DPM0_RESTORE15 0xFFCA906C /* DPM0 Restore Register */ + +#define USB_FADDR 0xFFCC1000 /* USB Device Address in Peripheral Mode*/ +#define USB_DMA_IRQ 0xFFCC1200 /* USB Interrupt Register */ +#define USB_VBUS_CTL 0xFFCC1380 /* USB VBus Control */ +#define USB_PHY_CTL 0xFFCC1394 /* USB PHY Control */ +#define USB_PLL_OSC 0xFFCC1398 /* USB PLL and Oscillator Control */ + + +#define CHIPID 0xffc00014 +/* CHIPID Masks */ +#define CHIPID_VERSION 0xF0000000 +#define CHIPID_FAMILY 0x0FFFF000 +#define CHIPID_MANUFACTURE 0x00000FFE + +#define L1_DATA_A_SRAM 0xFF800000 /* 0xFF800000->0xFF803FFF Data Bank A SRAM */ +#define L1_DATA_A_SRAM_SIZE 0x8000 +#define L1_DATA_A_SRAM_END (L1_DATA_A_SRAM + L1_DATA_A_SRAM_SIZE) +#define L1_DATA_B_SRAM 0xFF900000 /* 0xFF900000->0xFF903FFF Data Bank B SRAM */ +#define L1_DATA_B_SRAM_SIZE 0x4000 +#define L1_DATA_B_SRAM_END (L1_DATA_B_SRAM + L1_DATA_B_SRAM_SIZE) + +#define L1_INST_SRAM 0xFFA00000 /* 0xFFA00000->0xFFA07FFF Inst Bank A SRAM */ +#define L1_INST_SRAM_SIZE 0x8000 +#define L1_INST_SRAM_END (L1_INST_SRAM + L1_INST_SRAM_SIZE) + +#endif /* __BFIN_DEF_ADSP_BF609_proc__ */ diff --git a/arch/blackfin/include/asm/mach-bf609/anomaly.h b/arch/blackfin/include/asm/mach-bf609/anomaly.h new file mode 100644 index 0000000..0a70f08 --- /dev/null +++ b/arch/blackfin/include/asm/mach-bf609/anomaly.h @@ -0,0 +1,97 @@ +/* + * Copyright 2004-2012 Analog Devices Inc. + * Licensed under the ADI BSD license. + * https://docs.blackfin.uclinux.org/doku.php?id=adi_bsd + */ + +/* This file should be up to date with: + * - Revision A, 15/06/2012; ADSP-BF609 Blackfin Processor Anomaly List + */ + +#if __SILICON_REVISION__ < 0 +# error will not work on BF609 silicon version +#endif + +#ifndef _MACH_ANOMALY_H_ +#define _MACH_ANOMALY_H_ + +/* TRU_STAT.ADDRERR and TRU_ERRADDR.ADDR May Not Reflect the Correct Status */ +#define ANOMALY_16000003 (1) +/* The EPPI Data Enable (DEN) Signal is Not Functional */ +#define ANOMALY_16000004 (1) +/* Using L1 Instruction Cache with Parity Enabled is Unreliable */ +#define ANOMALY_16000005 (1) +/* SEQSTAT.SYSNMI Clears Upon Entering the NMI ISR */ +#define ANOMALY_16000006 (1) +/* DDR2 Memory Reads May Fail Intermittently */ +#define ANOMALY_16000007 (1) +/* Instruction Memory Stalls Can Cause IFLUSH to Fail */ +#define ANOMALY_16000008 (1) +/* TestSET Instruction Cannot Be Interrupted */ +#define ANOMALY_16000009 (1) +/* IFLUSH Instruction at End of Hardware Loop Causes Infinite Stall */ +#define ANOMALY_16000010 (1) +/* False Hardware Error when RETI Points to Invalid Memory */ +#define ANOMALY_16000011 (1) +/* Speculative Fetches of Indirect-Pointer Inst Can Cause False Hw Errors */ +#define ANOMALY_16000012 (1) +/* False Hardware Errors Caused by Fetches at the Boundary of Reserved Memory */ +#define ANOMALY_16000013 (1) +/* False Hardware Error from an Access in the Shadow of a Conditional Branch */ +#define ANOMALY_16000014 (1) +/* Multi-Issue Inst with dsp32shiftimm in slot1 and P in slot2 Not Supported */ +#define ANOMALY_16000015 (1) +/* Speculative Fetches Can Cause Undesired External FIFO Operations */ +#define ANOMALY_16000017 (1) +/* RSI Boot Cleanup Routine Does Not Clear Registers */ +#define ANOMALY_16000018 (1) +/* SPI Master Boot Device Auto-detection Frequency is Set Incorrectly */ +#define ANOMALY_16000019 (1) +/* rom_SysControl() Fails to Set DDR0_CTL.INIT for Wakeup From Hibernate */ +#define ANOMALY_16000020 (1) +/* rom_SysControl() Fails to Save and Restore DDR0_PHYCTL3 for Hb/Wk Sequence */ +#define ANOMALY_16000021 (1) +/* Boot Code Fails to Enable Parity Fault Detection */ +#define ANOMALY_16000022 (1) +/* USB DMA interrupt status do not show the DMA channel intr in the DMA ISR */ +#define ANOMALY_16000027 (1) +/* Interrupted Core Reads of MMRs May Cause Data Loss */ +#define ANOMALY_16000030 (1) + +/* Anomalies that don't exist on this proc */ +#define ANOMALY_05000158 (0) +#define ANOMALY_05000189 (0) +#define ANOMALY_05000198 (0) +#define ANOMALY_05000219 (0) +#define ANOMALY_05000230 (0) +#define ANOMALY_05000231 (0) +#define ANOMALY_05000244 (0) +#define ANOMALY_05000261 (0) +#define ANOMALY_05000263 (0) +#define ANOMALY_05000273 (0) +#define ANOMALY_05000274 (0) +#define ANOMALY_05000278 (0) +#define ANOMALY_05000281 (0) +#define ANOMALY_05000287 (0) +#define ANOMALY_05000311 (0) +#define ANOMALY_05000312 (0) +#define ANOMALY_05000323 (0) +#define ANOMALY_05000353 (1) +#define ANOMALY_05000363 (0) +#define ANOMALY_05000386 (0) +#define ANOMALY_05000480 (0) +#define ANOMALY_05000481 (1) + +/* Reuse BF5xx anomalies IDs for the same anomaly in BF60x */ +#define ANOMALY_05000491 ANOMALY_16000008 +#define ANOMALY_05000477 ANOMALY_16000009 +#define ANOMALY_05000443 ANOMALY_16000010 +#define ANOMALY_05000461 ANOMALY_16000011 +#define ANOMALY_05000426 ANOMALY_16000012 +#define ANOMALY_05000310 ANOMALY_16000013 +#define ANOMALY_05000245 ANOMALY_16000014 +#define ANOMALY_05000074 ANOMALY_16000015 +#define ANOMALY_05000416 ANOMALY_16000017 + + +#endif diff --git a/arch/blackfin/include/asm/mach-bf609/def_local.h b/arch/blackfin/include/asm/mach-bf609/def_local.h new file mode 100644 index 0000000..d4250e6 --- /dev/null +++ b/arch/blackfin/include/asm/mach-bf609/def_local.h @@ -0,0 +1,5 @@ +#include "gpio.h" +#include "portmux.h" +#include "ports.h" + +#define CONFIG_BF60x 1 /* Linux glue */ diff --git a/arch/blackfin/include/asm/mach-bf609/portmux.h b/arch/blackfin/include/asm/mach-bf609/portmux.h new file mode 100644 index 0000000..757570f --- /dev/null +++ b/arch/blackfin/include/asm/mach-bf609/portmux.h @@ -0,0 +1,257 @@ +/* + * Copyright 2008-2011 Analog Devices Inc. + * + * Licensed under the GPL-2 or later + */ + +#ifndef _MACH_PORTMUX_H_ +#define _MACH_PORTMUX_H_ + +#define MAX_RESOURCES MAX_BLACKFIN_GPIOS + +/* EMAC RMII Port Mux */ +#define P_MII0_MDC (P_DEFINED | P_IDENT(GPIO_PC6) | P_FUNCT(0)) +#define P_MII0_MDIO (P_DEFINED | P_IDENT(GPIO_PC7) | P_FUNCT(0)) +#define P_MII0_ETxD0 (P_DEFINED | P_IDENT(GPIO_PC2) | P_FUNCT(0)) +#define P_MII0_ERxD0 (P_DEFINED | P_IDENT(GPIO_PC0) | P_FUNCT(0)) +#define P_MII0_ETxD1 (P_DEFINED | P_IDENT(GPIO_PC3) | P_FUNCT(0)) +#define P_MII0_ERxD1 (P_DEFINED | P_IDENT(GPIO_PC1) | P_FUNCT(0)) +#define P_MII0_ETxEN (P_DEFINED | P_IDENT(GPIO_PB13) | P_FUNCT(0)) +#define P_MII0_PHYINT (P_DEFINED | P_IDENT(GPIO_PD6) | P_FUNCT(0)) +#define P_MII0_CRS (P_DEFINED | P_IDENT(GPIO_PC5) | P_FUNCT(0)) +#define P_MII0_ERxER (P_DEFINED | P_IDENT(GPIO_PC4) | P_FUNCT(0)) +#define P_MII0_TxCLK (P_DEFINED | P_IDENT(GPIO_PB14) | P_FUNCT(0)) + +#define P_RMII0 {\ + P_MII0_ETxD0, \ + P_MII0_ETxD1, \ + P_MII0_ETxEN, \ + P_MII0_ERxD0, \ + P_MII0_ERxD1, \ + P_MII0_ERxER, \ + P_MII0_TxCLK, \ + P_MII0_PHYINT, \ + P_MII0_CRS, \ + P_MII0_MDC, \ + P_PTP0_PPS, \ + P_PTP1_PPS, \ + P_MII0_MDIO, 0} + +#define P_MII1_MDC (P_DEFINED | P_IDENT(GPIO_PE10) | P_FUNCT(0)) +#define P_MII1_MDIO (P_DEFINED | P_IDENT(GPIO_PE11) | P_FUNCT(0)) +#define P_MII1_ETxD0 (P_DEFINED | P_IDENT(GPIO_PG3) | P_FUNCT(0)) +#define P_MII1_ERxD0 (P_DEFINED | P_IDENT(GPIO_PG0) | P_FUNCT(0)) +#define P_MII1_ETxD1 (P_DEFINED | P_IDENT(GPIO_PG2) | P_FUNCT(0)) +#define P_MII1_ERxD1 (P_DEFINED | P_IDENT(GPIO_PE15) | P_FUNCT(0)) +#define P_MII1_ETxEN (P_DEFINED | P_IDENT(GPIO_PG5) | P_FUNCT(0)) +#define P_MII1_PHYINT (P_DEFINED | P_IDENT(GPIO_PE12) | P_FUNCT(0)) +#define P_MII1_CRS (P_DEFINED | P_IDENT(GPIO_PE13) | P_FUNCT(0)) +#define P_MII1_ERxER (P_DEFINED | P_IDENT(GPIO_PE14) | P_FUNCT(0)) +#define P_MII1_TxCLK (P_DEFINED | P_IDENT(GPIO_PG6) | P_FUNCT(0)) + +#define P_RMII1 {\ + P_MII1_ETxD0, \ + P_MII1_ETxD1, \ + P_MII1_ETxEN, \ + P_MII1_ERxD0, \ + P_MII1_ERxD1, \ + P_MII1_ERxER, \ + P_MII1_TxCLK, \ + P_MII1_PHYINT, \ + P_MII1_CRS, \ + P_MII1_MDC, \ + P_MII1_MDIO, 0} + +/* PPI Port Mux */ +#define P_PPI0_D0 (P_DEFINED | P_IDENT(GPIO_PF0) | P_FUNCT(1)) +#define P_PPI0_D1 (P_DEFINED | P_IDENT(GPIO_PF1) | P_FUNCT(1)) +#define P_PPI0_D2 (P_DEFINED | P_IDENT(GPIO_PF2) | P_FUNCT(1)) +#define P_PPI0_D3 (P_DEFINED | P_IDENT(GPIO_PF3) | P_FUNCT(1)) +#define P_PPI0_D4 (P_DEFINED | P_IDENT(GPIO_PF4) | P_FUNCT(1)) +#define P_PPI0_D5 (P_DEFINED | P_IDENT(GPIO_PF5) | P_FUNCT(1)) +#define P_PPI0_D6 (P_DEFINED | P_IDENT(GPIO_PF6) | P_FUNCT(1)) +#define P_PPI0_D7 (P_DEFINED | P_IDENT(GPIO_PF7) | P_FUNCT(1)) +#define P_PPI0_D8 (P_DEFINED | P_IDENT(GPIO_PF8) | P_FUNCT(1)) +#define P_PPI0_D9 (P_DEFINED | P_IDENT(GPIO_PF9) | P_FUNCT(1)) +#define P_PPI0_D10 (P_DEFINED | P_IDENT(GPIO_PF10) | P_FUNCT(1)) +#define P_PPI0_D11 (P_DEFINED | P_IDENT(GPIO_PF11) | P_FUNCT(1)) +#define P_PPI0_D12 (P_DEFINED | P_IDENT(GPIO_PF12) | P_FUNCT(1)) +#define P_PPI0_D13 (P_DEFINED | P_IDENT(GPIO_PF13) | P_FUNCT(1)) +#define P_PPI0_D14 (P_DEFINED | P_IDENT(GPIO_PF14) | P_FUNCT(1)) +#define P_PPI0_D15 (P_DEFINED | P_IDENT(GPIO_PF15) | P_FUNCT(1)) +#define P_PPI0_D16 (P_DEFINED | P_IDENT(GPIO_PE3) | P_FUNCT(1)) +#define P_PPI0_D17 (P_DEFINED | P_IDENT(GPIO_PE4) | P_FUNCT(1)) +#define P_PPI0_D18 (P_DEFINED | P_IDENT(GPIO_PE0) | P_FUNCT(1)) +#define P_PPI0_D19 (P_DEFINED | P_IDENT(GPIO_PE1) | P_FUNCT(1)) +#define P_PPI0_D20 (P_DEFINED | P_IDENT(GPIO_PD12) | P_FUNCT(1)) +#define P_PPI0_D21 (P_DEFINED | P_IDENT(GPIO_PD15) | P_FUNCT(1)) +#define P_PPI0_D22 (P_DEFINED | P_IDENT(GPIO_PE2) | P_FUNCT(1)) +#define P_PPI0_D23 (P_DEFINED | P_IDENT(GPIO_PE5) | P_FUNCT(1)) +#define P_PPI0_CLK (P_DEFINED | P_IDENT(GPIO_PE9) | P_FUNCT(1)) +#define P_PPI0_FS1 (P_DEFINED | P_IDENT(GPIO_PE8) | P_FUNCT(1)) +#define P_PPI0_FS2 (P_DEFINED | P_IDENT(GPIO_PE7) | P_FUNCT(1)) +#define P_PPI0_FS3 (P_DEFINED | P_IDENT(GPIO_PE6) | P_FUNCT(1)) + +#define P_PPI1_D0 (P_DEFINED | P_IDENT(GPIO_PC0) | P_FUNCT(1)) +#define P_PPI1_D1 (P_DEFINED | P_IDENT(GPIO_PC1) | P_FUNCT(1)) +#define P_PPI1_D2 (P_DEFINED | P_IDENT(GPIO_PC2) | P_FUNCT(1)) +#define P_PPI1_D3 (P_DEFINED | P_IDENT(GPIO_PC3) | P_FUNCT(1)) +#define P_PPI1_D4 (P_DEFINED | P_IDENT(GPIO_PC4) | P_FUNCT(1)) +#define P_PPI1_D5 (P_DEFINED | P_IDENT(GPIO_PC5) | P_FUNCT(1)) +#define P_PPI1_D6 (P_DEFINED | P_IDENT(GPIO_PC6) | P_FUNCT(1)) +#define P_PPI1_D7 (P_DEFINED | P_IDENT(GPIO_PC7) | P_FUNCT(1)) +#define P_PPI1_D8 (P_DEFINED | P_IDENT(GPIO_PC8) | P_FUNCT(1)) +#define P_PPI1_D9 (P_DEFINED | P_IDENT(GPIO_PC9) | P_FUNCT(1)) +#define P_PPI1_D10 (P_DEFINED | P_IDENT(GPIO_PC10) | P_FUNCT(1)) +#define P_PPI1_D11 (P_DEFINED | P_IDENT(GPIO_PC11) | P_FUNCT(1)) +#define P_PPI1_D12 (P_DEFINED | P_IDENT(GPIO_PC12) | P_FUNCT(1)) +#define P_PPI1_D13 (P_DEFINED | P_IDENT(GPIO_PC13) | P_FUNCT(1)) +#define P_PPI1_D14 (P_DEFINED | P_IDENT(GPIO_PC14) | P_FUNCT(1)) +#define P_PPI1_D15 (P_DEFINED | P_IDENT(GPIO_PC15) | P_FUNCT(1)) +#define P_PPI1_D16 (P_DEFINED | P_IDENT(GPIO_PD0) | P_FUNCT(1)) +#define P_PPI1_D17 (P_DEFINED | P_IDENT(GPIO_PD1) | P_FUNCT(1)) +#define P_PPI1_CLK (P_DEFINED | P_IDENT(GPIO_PB14) | P_FUNCT(1)) +#define P_PPI1_FS1 (P_DEFINED | P_IDENT(GPIO_PB13) | P_FUNCT(1)) +#define P_PPI1_FS2 (P_DEFINED | P_IDENT(GPIO_PD6) | P_FUNCT(1)) +#define P_PPI1_FS3 (P_DEFINED | P_IDENT(GPIO_PB15) | P_FUNCT(1)) + +#define P_PPI2_D0 (P_DEFINED | P_IDENT(GPIO_PA0) | P_FUNCT(1)) +#define P_PPI2_D1 (P_DEFINED | P_IDENT(GPIO_PA1) | P_FUNCT(1)) +#define P_PPI2_D2 (P_DEFINED | P_IDENT(GPIO_PA2) | P_FUNCT(1)) +#define P_PPI2_D3 (P_DEFINED | P_IDENT(GPIO_PA3) | P_FUNCT(1)) +#define P_PPI2_D4 (P_DEFINED | P_IDENT(GPIO_PA4) | P_FUNCT(1)) +#define P_PPI2_D5 (P_DEFINED | P_IDENT(GPIO_PA5) | P_FUNCT(1)) +#define P_PPI2_D6 (P_DEFINED | P_IDENT(GPIO_PA6) | P_FUNCT(1)) +#define P_PPI2_D7 (P_DEFINED | P_IDENT(GPIO_PA7) | P_FUNCT(1)) +#define P_PPI2_D8 (P_DEFINED | P_IDENT(GPIO_PA8) | P_FUNCT(1)) +#define P_PPI2_D9 (P_DEFINED | P_IDENT(GPIO_PA9) | P_FUNCT(1)) +#define P_PPI2_D10 (P_DEFINED | P_IDENT(GPIO_PA10) | P_FUNCT(1)) +#define P_PPI2_D11 (P_DEFINED | P_IDENT(GPIO_PA11) | P_FUNCT(1)) +#define P_PPI2_D12 (P_DEFINED | P_IDENT(GPIO_PA12) | P_FUNCT(1)) +#define P_PPI2_D13 (P_DEFINED | P_IDENT(GPIO_PA13) | P_FUNCT(1)) +#define P_PPI2_D14 (P_DEFINED | P_IDENT(GPIO_PA14) | P_FUNCT(1)) +#define P_PPI2_D15 (P_DEFINED | P_IDENT(GPIO_PA15) | P_FUNCT(1)) +#define P_PPI2_D16 (P_DEFINED | P_IDENT(GPIO_PB7) | P_FUNCT(1)) +#define P_PPI2_D17 (P_DEFINED | P_IDENT(GPIO_PB8) | P_FUNCT(1)) +#define P_PPI2_CLK (P_DEFINED | P_IDENT(GPIO_PB0) | P_FUNCT(1)) +#define P_PPI2_FS1 (P_DEFINED | P_IDENT(GPIO_PB1) | P_FUNCT(1)) +#define P_PPI2_FS2 (P_DEFINED | P_IDENT(GPIO_PB2) | P_FUNCT(1)) +#define P_PPI2_FS3 (P_DEFINED | P_IDENT(GPIO_PB3) | P_FUNCT(1)) + +/* SPI Port Mux */ +#define P_SPI0_SS (P_DEFINED | P_IDENT(GPIO_PD11) | P_FUNCT(3)) +#define P_SPI0_SCK (P_DEFINED | P_IDENT(GPIO_PD4) | P_FUNCT(0)) +#define P_SPI0_MISO (P_DEFINED | P_IDENT(GPIO_PD2) | P_FUNCT(0)) +#define P_SPI0_MOSI (P_DEFINED | P_IDENT(GPIO_PD3) | P_FUNCT(0)) +#define P_SPI0_RDY (P_DEFINED | P_IDENT(GPIO_PD10) | P_FUNCT(0)) +#define P_SPI0_D2 (P_DEFINED | P_IDENT(GPIO_PD0) | P_FUNCT(0)) +#define P_SPI0_D3 (P_DEFINED | P_IDENT(GPIO_PD1) | P_FUNCT(0)) + +#define P_SPI0_SSEL1 (P_DEFINED | P_IDENT(GPIO_PD11) | P_FUNCT(0)) +#define P_SPI0_SSEL2 (P_DEFINED | P_IDENT(GPIO_PD1) | P_FUNCT(2)) +#define P_SPI0_SSEL3 (P_DEFINED | P_IDENT(GPIO_PD0) | P_FUNCT(2)) +#define P_SPI0_SSEL4 (P_DEFINED | P_IDENT(GPIO_PC15) | P_FUNCT(0)) +#define P_SPI0_SSEL5 (P_DEFINED | P_IDENT(GPIO_PD9) | P_FUNCT(0)) +#define P_SPI0_SSEL6 (P_DEFINED | P_IDENT(GPIO_PC13) | P_FUNCT(0)) +#define P_SPI0_SSEL7 (P_DEFINED | P_IDENT(GPIO_PC12) | P_FUNCT(0)) + +#define P_SPI1_SS (P_DEFINED | P_IDENT(GPIO_PD12) | P_FUNCT(3)) +#define P_SPI1_SCK (P_DEFINED | P_IDENT(GPIO_PD5) | P_FUNCT(0)) +#define P_SPI1_MISO (P_DEFINED | P_IDENT(GPIO_PD14) | P_FUNCT(0)) +#define P_SPI1_MOSI (P_DEFINED | P_IDENT(GPIO_PD13) | P_FUNCT(0)) +#define P_SPI1_RDY (P_DEFINED | P_IDENT(GPIO_PE2) | P_FUNCT(0)) +#define P_SPI1_D2 (P_DEFINED | P_IDENT(GPIO_PE1) | P_FUNCT(0)) +#define P_SPI1_D3 (P_DEFINED | P_IDENT(GPIO_PE0) | P_FUNCT(0)) + +#define P_SPI1_SSEL1 (P_DEFINED | P_IDENT(GPIO_PD12) | P_FUNCT(0)) +#define P_SPI1_SSEL2 (P_DEFINED | P_IDENT(GPIO_PD15) | P_FUNCT(2)) +#define P_SPI1_SSEL3 (P_DEFINED | P_IDENT(GPIO_PD10) | P_FUNCT(2)) +#define P_SPI1_SSEL4 (P_DEFINED | P_IDENT(GPIO_PD9) | P_FUNCT(2)) +#define P_SPI1_SSEL5 (P_DEFINED | P_IDENT(GPIO_PF8) | P_FUNCT(0)) +#define P_SPI1_SSEL6 (P_DEFINED | P_IDENT(GPIO_PF9) | P_FUNCT(0)) +#define P_SPI1_SSEL7 (P_DEFINED | P_IDENT(GPIO_PC14) | P_FUNCT(0)) + +#define GPIO_DEFAULT_BOOT_SPI_CS +#define P_DEFAULT_BOOT_SPI_CS + +/* UART Port Mux */ +#define P_UART0_TX (P_DEFINED | P_IDENT(GPIO_PD7) | P_FUNCT(1)) +#define P_UART0_RX (P_DEFINED | P_IDENT(GPIO_PD8) | P_FUNCT(1)) +#define P_UART0_RTS (P_DEFINED | P_IDENT(GPIO_PD9) | P_FUNCT(1)) +#define P_UART0_CTS (P_DEFINED | P_IDENT(GPIO_PD10) | P_FUNCT(1)) + +#define P_UART1_TX (P_DEFINED | P_IDENT(GPIO_PG15) | P_FUNCT(0)) +#define P_UART1_RX (P_DEFINED | P_IDENT(GPIO_PG14) | P_FUNCT(0)) +#define P_UART1_RTS (P_DEFINED | P_IDENT(GPIO_PG10) | P_FUNCT(0)) +#define P_UART1_CTS (P_DEFINED | P_IDENT(GPIO_PG13) | P_FUNCT(0)) + +/* Timer */ +#define P_TMRCLK (P_DEFINED | P_IDENT(GPIO_PG13) | P_FUNCT(3)) +#define P_TMR0 (P_DEFINED | P_IDENT(GPIO_PE14) | P_FUNCT(2)) +#define P_TMR1 (P_DEFINED | P_IDENT(GPIO_PG4) | P_FUNCT(1)) +#define P_TMR2 (P_DEFINED | P_IDENT(GPIO_PG1) | P_FUNCT(1)) +#define P_TMR3 (P_DEFINED | P_IDENT(GPIO_PG8) | P_FUNCT(1)) +#define P_TMR4 (P_DEFINED | P_IDENT(GPIO_PG9) | P_FUNCT(1)) +#define P_TMR5 (P_DEFINED | P_IDENT(GPIO_PG7) | P_FUNCT(1)) +#define P_TMR6 (P_DEFINED | P_IDENT(GPIO_PG11) | P_FUNCT(1)) +#define P_TMR7 (P_DEFINED | P_IDENT(GPIO_PG12) | P_FUNCT(1)) + +/* RSI */ +#define P_RSI_DATA0 (P_DEFINED | P_IDENT(GPIO_PG3) | P_FUNCT(2)) +#define P_RSI_DATA1 (P_DEFINED | P_IDENT(GPIO_PG2) | P_FUNCT(2)) +#define P_RSI_DATA2 (P_DEFINED | P_IDENT(GPIO_PG0) | P_FUNCT(2)) +#define P_RSI_DATA3 (P_DEFINED | P_IDENT(GPIO_PE15) | P_FUNCT(2)) +#define P_RSI_DATA4 (P_DEFINED | P_IDENT(GPIO_PE13) | P_FUNCT(2)) +#define P_RSI_DATA5 (P_DEFINED | P_IDENT(GPIO_PE12) | P_FUNCT(2)) +#define P_RSI_DATA6 (P_DEFINED | P_IDENT(GPIO_PE10) | P_FUNCT(2)) +#define P_RSI_DATA7 (P_DEFINED | P_IDENT(GPIO_PE11) | P_FUNCT(2)) +#define P_RSI_CMD (P_DEFINED | P_IDENT(GPIO_PG5) | P_FUNCT(1)) +#define P_RSI_CLK (P_DEFINED | P_IDENT(GPIO_PG6) | P_FUNCT(1)) + +/* PTP */ +#define P_PTP0_PPS (P_DEFINED | P_IDENT(GPIO_PB15) | P_FUNCT(0)) +#define P_PTP0_CLKIN (P_DEFINED | P_IDENT(GPIO_PC13) | P_FUNCT(2)) +#define P_PTP0_AUXIN (P_DEFINED | P_IDENT(GPIO_PC11) | P_FUNCT(2)) + +#define P_PTP1_PPS (P_DEFINED | P_IDENT(GPIO_PC9) | P_FUNCT(0)) +#define P_PTP1_CLKIN (P_DEFINED | P_IDENT(GPIO_PC13) | P_FUNCT(2)) +#define P_PTP1_AUXIN (P_DEFINED | P_IDENT(GPIO_PC11) | P_FUNCT(2)) + +/* SMC Port Mux */ +#define P_A3 (P_DEFINED | P_IDENT(GPIO_PA0) | P_FUNCT(0)) +#define P_A4 (P_DEFINED | P_IDENT(GPIO_PA1) | P_FUNCT(0)) +#define P_A5 (P_DEFINED | P_IDENT(GPIO_PA2) | P_FUNCT(0)) +#define P_A6 (P_DEFINED | P_IDENT(GPIO_PA3) | P_FUNCT(0)) +#define P_A7 (P_DEFINED | P_IDENT(GPIO_PA4) | P_FUNCT(0)) +#define P_A8 (P_DEFINED | P_IDENT(GPIO_PA5) | P_FUNCT(0)) +#define P_A9 (P_DEFINED | P_IDENT(GPIO_PA6) | P_FUNCT(0)) +#define P_A10 (P_DEFINED | P_IDENT(GPIO_PA7) | P_FUNCT(0)) +#define P_A11 (P_DEFINED | P_IDENT(GPIO_PA8) | P_FUNCT(0)) +#define P_A12 (P_DEFINED | P_IDENT(GPIO_PA9) | P_FUNCT(0)) +#define P_A13 (P_DEFINED | P_IDENT(GPIO_PB2) | P_FUNCT(0)) +#define P_A14 (P_DEFINED | P_IDENT(GPIO_PA10) | P_FUNCT(0)) +#define P_A15 (P_DEFINED | P_IDENT(GPIO_PA11) | P_FUNCT(0)) +#define P_A16 (P_DEFINED | P_IDENT(GPIO_PB3) | P_FUNCT(0)) +#define P_A17 (P_DEFINED | P_IDENT(GPIO_PA12) | P_FUNCT(0)) +#define P_A18 (P_DEFINED | P_IDENT(GPIO_PA13) | P_FUNCT(0)) +#define P_A19 (P_DEFINED | P_IDENT(GPIO_PA14) | P_FUNCT(0)) +#define P_A20 (P_DEFINED | P_IDENT(GPIO_PA15) | P_FUNCT(0)) +#define P_A21 (P_DEFINED | P_IDENT(GPIO_PB6) | P_FUNCT(0)) +#define P_A22 (P_DEFINED | P_IDENT(GPIO_PB7) | P_FUNCT(0)) +#define P_A23 (P_DEFINED | P_IDENT(GPIO_PB8) | P_FUNCT(0)) +#define P_A24 (P_DEFINED | P_IDENT(GPIO_PB10) | P_FUNCT(0)) +#define P_A25 (P_DEFINED | P_IDENT(GPIO_PB11) | P_FUNCT(0)) +#define P_NORCK (P_DEFINED | P_IDENT(GPIO_PB0) | P_FUNCT(0)) + +#define P_AMS1 (P_DEFINED | P_IDENT(GPIO_PB1) | P_FUNCT(0)) +#define P_AMS2 (P_DEFINED | P_IDENT(GPIO_PB4) | P_FUNCT(0)) +#define P_AMS3 (P_DEFINED | P_IDENT(GPIO_PB5) | P_FUNCT(0)) + +#define P_ABE0 (P_DEFINED | P_IDENT(GPIO_PB4) | P_FUNCT(1)) +#define P_ABE1 (P_DEFINED | P_IDENT(GPIO_PB5) | P_FUNCT(1)) + +/* CAN */ +#define P_CAN0_TX (P_DEFINED | P_IDENT(GPIO_PG1) | P_FUNCT(2)) +#define P_CAN0_RX (P_DEFINED | P_IDENT(GPIO_PG4) | P_FUNCT(2)) + +#endif /* _MACH_PORTMUX_H_ */ diff --git a/arch/blackfin/include/asm/mach-bf609/ports.h b/arch/blackfin/include/asm/mach-bf609/ports.h new file mode 100644 index 0000000..b361c7b --- /dev/null +++ b/arch/blackfin/include/asm/mach-bf609/ports.h @@ -0,0 +1,103 @@ +/* + * Port Masks + */ + +#ifndef __BFIN_PERIPHERAL_PORT__ +#define __BFIN_PERIPHERAL_PORT__ + +/* PORTx_MUX Masks */ +#define PORT_x_MUX_0_MASK 0x00000003 +#define PORT_x_MUX_1_MASK 0x0000000C +#define PORT_x_MUX_2_MASK 0x00000030 +#define PORT_x_MUX_3_MASK 0x000000C0 +#define PORT_x_MUX_4_MASK 0x00000300 +#define PORT_x_MUX_5_MASK 0x00000C00 +#define PORT_x_MUX_6_MASK 0x00003000 +#define PORT_x_MUX_7_MASK 0x0000C000 +#define PORT_x_MUX_8_MASK 0x00030000 +#define PORT_x_MUX_9_MASK 0x000C0000 +#define PORT_x_MUX_10_MASK 0x00300000 +#define PORT_x_MUX_11_MASK 0x00C00000 +#define PORT_x_MUX_12_MASK 0x03000000 +#define PORT_x_MUX_13_MASK 0x0C000000 +#define PORT_x_MUX_14_MASK 0x30000000 +#define PORT_x_MUX_15_MASK 0xC0000000 + +#define PORT_x_MUX_FUNC_1 (0x0) +#define PORT_x_MUX_FUNC_2 (0x1) +#define PORT_x_MUX_FUNC_3 (0x2) +#define PORT_x_MUX_FUNC_4 (0x3) +#define PORT_x_MUX_0_FUNC_1 (PORT_x_MUX_FUNC_1 << 0) +#define PORT_x_MUX_0_FUNC_2 (PORT_x_MUX_FUNC_2 << 0) +#define PORT_x_MUX_0_FUNC_3 (PORT_x_MUX_FUNC_3 << 0) +#define PORT_x_MUX_0_FUNC_4 (PORT_x_MUX_FUNC_4 << 0) +#define PORT_x_MUX_1_FUNC_1 (PORT_x_MUX_FUNC_1 << 2) +#define PORT_x_MUX_1_FUNC_2 (PORT_x_MUX_FUNC_2 << 2) +#define PORT_x_MUX_1_FUNC_3 (PORT_x_MUX_FUNC_3 << 2) +#define PORT_x_MUX_1_FUNC_4 (PORT_x_MUX_FUNC_4 << 2) +#define PORT_x_MUX_2_FUNC_1 (PORT_x_MUX_FUNC_1 << 4) +#define PORT_x_MUX_2_FUNC_2 (PORT_x_MUX_FUNC_2 << 4) +#define PORT_x_MUX_2_FUNC_3 (PORT_x_MUX_FUNC_3 << 4) +#define PORT_x_MUX_2_FUNC_4 (PORT_x_MUX_FUNC_4 << 4) +#define PORT_x_MUX_3_FUNC_1 (PORT_x_MUX_FUNC_1 << 6) +#define PORT_x_MUX_3_FUNC_2 (PORT_x_MUX_FUNC_2 << 6) +#define PORT_x_MUX_3_FUNC_3 (PORT_x_MUX_FUNC_3 << 6) +#define PORT_x_MUX_3_FUNC_4 (PORT_x_MUX_FUNC_4 << 6) +#define PORT_x_MUX_4_FUNC_1 (PORT_x_MUX_FUNC_1 << 8) +#define PORT_x_MUX_4_FUNC_2 (PORT_x_MUX_FUNC_2 << 8) +#define PORT_x_MUX_4_FUNC_3 (PORT_x_MUX_FUNC_3 << 8) +#define PORT_x_MUX_4_FUNC_4 (PORT_x_MUX_FUNC_4 << 8) +#define PORT_x_MUX_5_FUNC_1 (PORT_x_MUX_FUNC_1 << 10) +#define PORT_x_MUX_5_FUNC_2 (PORT_x_MUX_FUNC_2 << 10) +#define PORT_x_MUX_5_FUNC_3 (PORT_x_MUX_FUNC_3 << 10) +#define PORT_x_MUX_5_FUNC_4 (PORT_x_MUX_FUNC_4 << 10) +#define PORT_x_MUX_6_FUNC_1 (PORT_x_MUX_FUNC_1 << 12) +#define PORT_x_MUX_6_FUNC_2 (PORT_x_MUX_FUNC_2 << 12) +#define PORT_x_MUX_6_FUNC_3 (PORT_x_MUX_FUNC_3 << 12) +#define PORT_x_MUX_6_FUNC_4 (PORT_x_MUX_FUNC_4 << 12) +#define PORT_x_MUX_7_FUNC_1 (PORT_x_MUX_FUNC_1 << 14) +#define PORT_x_MUX_7_FUNC_2 (PORT_x_MUX_FUNC_2 << 14) +#define PORT_x_MUX_7_FUNC_3 (PORT_x_MUX_FUNC_3 << 14) +#define PORT_x_MUX_7_FUNC_4 (PORT_x_MUX_FUNC_4 << 14) +#define PORT_x_MUX_8_FUNC_1 (PORT_x_MUX_FUNC_1 << 16) +#define PORT_x_MUX_8_FUNC_2 (PORT_x_MUX_FUNC_2 << 16) +#define PORT_x_MUX_8_FUNC_3 (PORT_x_MUX_FUNC_3 << 16) +#define PORT_x_MUX_8_FUNC_4 (PORT_x_MUX_FUNC_4 << 16) +#define PORT_x_MUX_9_FUNC_1 (PORT_x_MUX_FUNC_1 << 18) +#define PORT_x_MUX_9_FUNC_2 (PORT_x_MUX_FUNC_2 << 18) +#define PORT_x_MUX_9_FUNC_3 (PORT_x_MUX_FUNC_3 << 18) +#define PORT_x_MUX_9_FUNC_4 (PORT_x_MUX_FUNC_4 << 18) +#define PORT_x_MUX_10_FUNC_1 (PORT_x_MUX_FUNC_1 << 20) +#define PORT_x_MUX_10_FUNC_2 (PORT_x_MUX_FUNC_2 << 20) +#define PORT_x_MUX_10_FUNC_3 (PORT_x_MUX_FUNC_3 << 20) +#define PORT_x_MUX_10_FUNC_4 (PORT_x_MUX_FUNC_4 << 20) +#define PORT_x_MUX_11_FUNC_1 (PORT_x_MUX_FUNC_1 << 22) +#define PORT_x_MUX_11_FUNC_2 (PORT_x_MUX_FUNC_2 << 22) +#define PORT_x_MUX_11_FUNC_3 (PORT_x_MUX_FUNC_3 << 22) +#define PORT_x_MUX_11_FUNC_4 (PORT_x_MUX_FUNC_4 << 22) +#define PORT_x_MUX_12_FUNC_1 (PORT_x_MUX_FUNC_1 << 24) +#define PORT_x_MUX_12_FUNC_2 (PORT_x_MUX_FUNC_2 << 24) +#define PORT_x_MUX_12_FUNC_3 (PORT_x_MUX_FUNC_3 << 24) +#define PORT_x_MUX_12_FUNC_4 (PORT_x_MUX_FUNC_4 << 24) +#define PORT_x_MUX_13_FUNC_1 (PORT_x_MUX_FUNC_1 << 26) +#define PORT_x_MUX_13_FUNC_2 (PORT_x_MUX_FUNC_2 << 26) +#define PORT_x_MUX_13_FUNC_3 (PORT_x_MUX_FUNC_3 << 26) +#define PORT_x_MUX_13_FUNC_4 (PORT_x_MUX_FUNC_4 << 26) +#define PORT_x_MUX_14_FUNC_1 (PORT_x_MUX_FUNC_1 << 28) +#define PORT_x_MUX_14_FUNC_2 (PORT_x_MUX_FUNC_2 << 28) +#define PORT_x_MUX_14_FUNC_3 (PORT_x_MUX_FUNC_3 << 28) +#define PORT_x_MUX_14_FUNC_4 (PORT_x_MUX_FUNC_4 << 28) +#define PORT_x_MUX_15_FUNC_1 (PORT_x_MUX_FUNC_1 << 30) +#define PORT_x_MUX_15_FUNC_2 (PORT_x_MUX_FUNC_2 << 30) +#define PORT_x_MUX_15_FUNC_3 (PORT_x_MUX_FUNC_3 << 30) +#define PORT_x_MUX_15_FUNC_4 (PORT_x_MUX_FUNC_4 << 30) + +#include "../mach-common/bits/ports-a.h" +#include "../mach-common/bits/ports-b.h" +#include "../mach-common/bits/ports-c.h" +#include "../mach-common/bits/ports-d.h" +#include "../mach-common/bits/ports-e.h" +#include "../mach-common/bits/ports-f.h" +#include "../mach-common/bits/ports-g.h" + +#endif diff --git a/arch/blackfin/include/asm/mach-common/bits/cgu.h b/arch/blackfin/include/asm/mach-common/bits/cgu.h new file mode 100644 index 0000000..cdf7349 --- /dev/null +++ b/arch/blackfin/include/asm/mach-common/bits/cgu.h @@ -0,0 +1,80 @@ +/* + * CGU Masks + */ + +#ifndef __BFIN_PERIPHERAL_CGU__ +#define __BFIN_PERIPHERAL_CGU__ + +/* CGU_CTL Masks */ +#define DF (1 << 0) +#define MSEL (0x7f << MSEL_P) +#define WIDLE (1 << WIDLE_P) +#define LOCK (1 << LOCK_P) + +#define DF_P 0 +#define MSEL_P 8 +#define WIDLE_P 30 +#define LOCK_P 31 +#define MSEL_MASK 0x7F00 +#define DF_MASK 0x1 + +/* CGU_STAT Masks */ +#define PLLEN (1 << 0) +#define PLLBP (1 << 1) +#define PLLLK (1 << 2) +#define CLKSALGN (1 << 3) +#define CCBF0EN (1 << 4) +#define CCBF1EN (1 << 5) +#define SCBF0EN (1 << 6) +#define SCBF1EN (1 << 7) +#define DCBFEN (1 << 8) +#define OCBFEN (1 << 9) +#define ADRERR (1 << 16) +#define LWERR (1 << 17) +#define DIVERR (1 << 18) +#define WDFMSERR (1 << 19) +#define WDIVERR (1 << 20) +#define PLLLKERR (1 << 21) + +/* CGU_DIV Masks */ +#define CSEL (0x1f << CSEL_P) +#define S0SEL (3 << S0SEL_P) +#define SYSSEL (0x1f << SYSSEL_P) +#define S1SEL (3 << S1SEL_P) +#define DSEL (0x1f << DSEL_P) +#define OSEL (0x7f << OSEL_P) +#define ALGN (1 << ALGN_P) +#define UPDT (1 << UPDT_P) +#define LOCK (1 << LOCK_P) + +#define CSEL_P 0 +#define S0SEL_P 5 +#define SYSSEL_P 8 +#define S1SEL_P 13 +#define DSEL_P 16 +#define OSEL_P 22 +#define ALGN_P 29 +#define UPDT_P 30 +#define LOCK_P 31 + +/* CGU_CLKOUTSEL Masks */ +#define CLKOUTSEL (0xf << 0) +#define USBCLKSEL (0x3f << 16) +#define LOCK (1 << LOCK_P) + +#define LOCK_P 31 + +#define CLKOUTSEL_CLKIN 0x0 +#define CLKOUTSEL_CCLK 0x1 +#define CLKOUTSEL_SYSCLK 0x2 +#define CLKOUTSEL_SCLK0 0x3 +#define CLKOUTSEL_SCLK1 0x4 +#define CLKOUTSEL_DCLK 0x5 +#define CLKOUTSEL_USB_PLL 0x6 +#define CLKOUTSEL_OUTCLK 0x7 +#define CLKOUTSEL_USB_CLKIN 0x8 +#define CLKOUTSEL_WDOG 0x9 +#define CLKOUTSEL_PMON 0xA +#define CLKOUTSEL_GND 0xB + +#endif diff --git a/arch/blackfin/include/asm/mach-common/bits/dde.h b/arch/blackfin/include/asm/mach-common/bits/dde.h new file mode 100644 index 0000000..f7b0bb9 --- /dev/null +++ b/arch/blackfin/include/asm/mach-common/bits/dde.h @@ -0,0 +1,88 @@ +/* + * Distributed DMA Engine (DDE) Masks + */ + +#ifndef __BFIN_PERIPHERAL_DDE__ +#define __BFIN_PERIPHERAL_DDE__ + +/* DMA_CONFIG Masks */ +#define DMAEN (1 << DMAEN_P) /* DMA Channel Enable */ +#define WNR (1 << WNR_P) /* Channel Direction (W/R*) */ +#define SYNC (1 << SYNC_P) /* Sync Work Unit Transitions */ +#define CADDR (1 << CADDR_P) /* Use Current Address */ +#define PSIZE (7 << PSIZE_P) /* Peripheral Word Size */ +#define PSIZE_1 (0 << PSIZE_P) +#define PSIZE_2 (1 << PSIZE_P) +#define PSIZE_4 (2 << PSIZE_P) +#define PSIZE_8 (3 << PSIZE_P) +#define MSIZE (7 << MSIZE_P) /* Memory Transfer Size */ +#define MSIZE_1 (0 << MSIZE_P) +#define MSIZE_2 (1 << MSIZE_P) +#define MSIZE_4 (2 << MSIZE_P) +#define MSIZE_8 (3 << MSIZE_P) +#define MSIZE_16 (4 << MSIZE_P) +#define MSIZE_32 (5 << MSIZE_P) +#define FLOW (7 << FLOW_P) /* Next Operation */ +#define FLOW_STOP (0 << FLOW_P) /* Stop Mode */ +#define FLOW_AUTO (1 << FLOW_P) /* Autobuffer Mode */ +#define FLOW_DSCL (4 << FLOW_P) /* Descriptor List */ +#define FLOW_DSCA (5 << FLOW_P) /* Descriptor Array */ +#define FLOW_DSDL (6 << FLOW_P) /* Descriptor On Demand List */ +#define FLOW_DSDA (7 << FLOW_P) /* Descriptor On Demand Array */ +#define NDSIZE (7 << NDSIZE_P) /* Next Descriptor Set Size */ +#define NDSIZE_1 (0 << NDSIZE_P) +#define NDSIZE_2 (1 << NDSIZE_P) +#define NDSIZE_3 (2 << NDSIZE_P) +#define NDSIZE_4 (3 << NDSIZE_P) +#define NDSIZE_5 (4 << NDSIZE_P) +#define NDSIZE_6 (5 << NDSIZE_P) +#define NDSIZE_7 (6 << NDSIZE_P) +#define DI_EN_X (1 << INT_P) +#define DI_EN_Y (2 << INT_P) +#define DI_EN_P (3 << INT_P) +#define DI_EN (DI_EN_X) +#define DI_XCOUNT_EN (1 << INT_P) /* xcount expires interrupt */ +#define TRIG (3 << TRIG_P) /* Generate Trigger */ +#define TOVEN (1 << TOVEN_P) +#define DESCIDCPY (1 << DESCIDCPY_P) +#define TWOD (1 << TWOD_P) +#define PDRF (1 << PDRF_P) + +#define DMAEN_P 0 +#define WNR_P 1 +#define SYNC_P 2 +#define CADDR_P 3 +#define PSIZE_P 4 +#define MSIZE_P 8 +#define FLOW_P 12 +#define TWAIT_P 15 +#define NDSIZE_P 16 +#define INT_P 20 +#define TRIG_P 22 +#define TOVEN_P 24 +#define DESCIDCPY_P 25 +#define TWOD_P 26 +#define PDRF_P 28 + +/* DMA_STATUS Masks */ +#define DMA_DONE (1 << DMA_DONE_P) /* Work Unit/Row Done */ +#define DMA_ERR (1 << DMA_ERR_P) /* Error Interrupt */ +#define DMA_PIRQ (1 << DMA_PIRQ_P) /* Peri Intr Request */ +#define DMA_ERRC (7 << DMA_ERRC_P) /* Error Cause */ +#define DMA_RUN (7 << DMA_RUN_P) /* Run Status */ +#define DMA_PBWIDTH (3 << DMA_PBWIDTH_P) /* Peri Bus Width */ +#define DMA_MBWIDTH (3 << DMA_MBWIDTH_P) /* Memory Bus Width */ +#define DMA_FIFOFILL (7 << DMA_FIFOFILL_P) /* FIFO Fill Status */ +#define DMA_TWAIT (1 << DMA_TWAIT_P) /* Trigger Wait Stat */ + +#define DMA_DONE_P 0 +#define DMA_ERR_P 1 +#define DMA_PIRQ_P 2 +#define DMA_ERRC_P 4 +#define DMA_RUN_P 8 +#define DMA_PBWIDTH_P 12 +#define DMA_MBWIDTH_P 14 +#define DMA_FIFOFILL_P 16 +#define DMA_TWAIT_P 20 + +#endif diff --git a/arch/blackfin/include/asm/mach-common/bits/mpu.h b/arch/blackfin/include/asm/mach-common/bits/mpu.h index 39998f8..cfde236 100644 --- a/arch/blackfin/include/asm/mach-common/bits/mpu.h +++ b/arch/blackfin/include/asm/mach-common/bits/mpu.h @@ -70,7 +70,11 @@ #define PAGE_SIZE_4KB 0x00010000 /* 4 KB page size */ #define PAGE_SIZE_1MB 0x00020000 /* 1 MB page size */ #define PAGE_SIZE_4MB 0x00030000 /* 4 MB page size */ -#define PAGE_SIZE_MASK 0x00030000 /* the bits for the page_size field */ +#define PAGE_SIZE_16KB 0x00040000 /* 16 KB page size */ +#define PAGE_SIZE_64KB 0x00050000 /* 64 KB page size */ +#define PAGE_SIZE_16MB 0x00060000 /* 16 MB page size */ +#define PAGE_SIZE_64MB 0x00070000 /* 64 MB page size */ +#define PAGE_SIZE_MASK 0x00070000 /* page_size field mask */ #define PAGE_SIZE_SHIFT 16 #define CPLB_L1SRAM 0x00000020 /* 0=SRAM mapped in L1, 0=SRAM not mapped to L1 */ #define CPLB_PORTPRIO 0x00000200 /* 0=low priority port, 1= high priority port */ diff --git a/arch/blackfin/include/asm/mach-common/bits/pll.h b/arch/blackfin/include/asm/mach-common/bits/pll.h index 9009f26..fe0ba0f 100644 --- a/arch/blackfin/include/asm/mach-common/bits/pll.h +++ b/arch/blackfin/include/asm/mach-common/bits/pll.h @@ -16,6 +16,8 @@ #define MSEL 0x7E00 /* Multiplier Select For CCLK/VCO Factors */ #define SPORT_HYST 0x8000 /* Enable Additional Hysteresis on SPORT Input Pins */
+#define MSEL_P 9 + /* PLL_DIV Masks */ #define SSEL 0x000F /* System Select */ #define CSEL 0x0030 /* Core Select */ @@ -29,6 +31,9 @@ #define CCLK_DIV4 CSEL_DIV4 #define CCLK_DIV8 CSEL_DIV8
+#define SSEL_P 0 +#define CSEL_P 4 + /* PLL_STAT Masks */ #define ACTIVE_PLLENABLED 0x0001 /* Processor In Active Mode With PLL Enabled */ #define FULL_ON 0x0002 /* Processor In Full On Mode */
Set up clocks, DDR controller, Nor flash controller, reboot, serial port. Add new SPI boot modes.
Fix review issue form Wolfgang: 1) Fix all checkpatch issues. 2) Clean up and merge redundant #ifdef's. 3) Spearate declarations and code by a blankline.
Signed-off-by: Bob Liu lliubbo@gmail.com Signed-off-by: Sonic Zhang sonic.zhang@analog.com --- arch/blackfin/cpu/cpu.c | 4 +- arch/blackfin/cpu/initcode.c | 326 ++++++++++++++++++++++++++++++-- arch/blackfin/cpu/initcode.h | 52 +++++ arch/blackfin/cpu/reset.c | 6 + arch/blackfin/include/asm/config-pre.h | 4 + arch/blackfin/lib/board.c | 6 + arch/blackfin/lib/clocks.c | 112 +++++++++-- common/cmd_reginfo.c | 19 ++- 8 files changed, 487 insertions(+), 42 deletions(-)
diff --git a/arch/blackfin/cpu/cpu.c b/arch/blackfin/cpu/cpu.c index 6a0bcca..b9fdb07 100644 --- a/arch/blackfin/cpu/cpu.c +++ b/arch/blackfin/cpu/cpu.c @@ -68,7 +68,9 @@ void cpu_init_f(ulong bootflag, ulong loaded_from_ldr) /* Reset upon a double exception rather than just hanging. * Do not do bfin_read on SWRST as that will reset status bits. */ +# ifdef SWRST bfin_write_SWRST(DOUBLE_FAULT); +# endif #endif
serial_early_puts("Board init flash\n"); @@ -92,7 +94,7 @@ int irq_init(void) #elif defined(SICA_IMASK0) bfin_write_SICA_IMASK0(0); bfin_write_SICA_IMASK1(0); -#else +#elif defined(SIC_IMASK) bfin_write_SIC_IMASK(0); #endif /* Set up a dummy NMI handler if needed. */ diff --git a/arch/blackfin/cpu/initcode.c b/arch/blackfin/cpu/initcode.c index fb3a101..e304d3e 100644 --- a/arch/blackfin/cpu/initcode.c +++ b/arch/blackfin/cpu/initcode.c @@ -15,20 +15,141 @@ #include <asm/blackfin.h> #include <asm/mach-common/bits/bootrom.h> #include <asm/mach-common/bits/core.h> -#include <asm/mach-common/bits/ebiu.h> -#include <asm/mach-common/bits/pll.h> -#include <asm/mach-common/bits/uart.h>
#define BUG() while (1) { asm volatile("emuexcpt;"); }
#include "serial.h"
+#ifndef __ADSPBF60x__ +#include <asm/mach-common/bits/ebiu.h> +#include <asm/mach-common/bits/pll.h> +#else /* __ADSPBF60x__ */ +#include <asm/mach-common/bits/cgu.h> + +#define CONFIG_BFIN_GET_DCLK_M \ + ((CONFIG_CLKIN_HZ*CONFIG_VCO_MULT)/(CONFIG_DCLK_DIV*1000000)) + +#ifndef CONFIG_DMC_DDRCFG +#if ((CONFIG_BFIN_GET_DCLK_M != 125) && \ + (CONFIG_BFIN_GET_DCLK_M != 133) && \ + (CONFIG_BFIN_GET_DCLK_M != 150) && \ + (CONFIG_BFIN_GET_DCLK_M != 166) && \ + (CONFIG_BFIN_GET_DCLK_M != 200) && \ + (CONFIG_BFIN_GET_DCLK_M != 225) && \ + (CONFIG_BFIN_GET_DCLK_M != 250)) +#error "DDR2 CLK must be in (125, 133, 150, 166, 200, 225, 250)MHz" +#endif +#endif + +/* DMC control bits */ +#define SRREQ 0x8 + +/* DMC status bits */ +#define IDLE 0x1 +#define MEMINITDONE 0x4 +#define SRACK 0x8 +#define PDACK 0x10 +#define DPDACK 0x20 +#define DLLCALDONE 0x2000 +#define PENDREF 0xF0000 +#define PHYRDPHASE 0xF00000 +#define PHYRDPHASE_OFFSET 20 + +/* DMC DLL control bits */ +#define DLLCALRDCNT 0xFF +#define DATACYC_OFFSET 8 + +struct ddr_config { + u32 ddr_clk; + u32 dmc_ddrctl; + u32 dmc_ddrcfg; + u32 dmc_ddrtr0; + u32 dmc_ddrtr1; + u32 dmc_ddrtr2; + u32 dmc_ddrmr; + u32 dmc_ddrmr1; +}; + +static struct ddr_config ddr_config_table[] = { + [0] = { + .ddr_clk = 125, /* 125MHz */ + .dmc_ddrctl = 0x00000904, + .dmc_ddrcfg = 0x00000422, + .dmc_ddrtr0 = 0x20705212, + .dmc_ddrtr1 = 0x201003CF, + .dmc_ddrtr2 = 0x00320107, + .dmc_ddrmr = 0x00000422, + .dmc_ddrmr1 = 0x4, + }, + [1] = { + .ddr_clk = 133, /* 133MHz */ + .dmc_ddrctl = 0x00000904, + .dmc_ddrcfg = 0x00000422, + .dmc_ddrtr0 = 0x20806313, + .dmc_ddrtr1 = 0x2013040D, + .dmc_ddrtr2 = 0x00320108, + .dmc_ddrmr = 0x00000632, + .dmc_ddrmr1 = 0x4, + }, + [2] = { + .ddr_clk = 150, /* 150MHz */ + .dmc_ddrctl = 0x00000904, + .dmc_ddrcfg = 0x00000422, + .dmc_ddrtr0 = 0x20A07323, + .dmc_ddrtr1 = 0x20160492, + .dmc_ddrtr2 = 0x00320209, + .dmc_ddrmr = 0x00000632, + .dmc_ddrmr1 = 0x4, + }, + [3] = { + .ddr_clk = 166, /* 166MHz */ + .dmc_ddrctl = 0x00000904, + .dmc_ddrcfg = 0x00000422, + .dmc_ddrtr0 = 0x20A07323, + .dmc_ddrtr1 = 0x2016050E, + .dmc_ddrtr2 = 0x00320209, + .dmc_ddrmr = 0x00000632, + .dmc_ddrmr1 = 0x4, + }, + [4] = { + .ddr_clk = 200, /* 200MHz */ + .dmc_ddrctl = 0x00000904, + .dmc_ddrcfg = 0x00000422, + .dmc_ddrtr0 = 0x20a07323, + .dmc_ddrtr1 = 0x2016050f, + .dmc_ddrtr2 = 0x00320509, + .dmc_ddrmr = 0x00000632, + .dmc_ddrmr1 = 0x4, + }, + [5] = { + .ddr_clk = 225, /* 225MHz */ + .dmc_ddrctl = 0x00000904, + .dmc_ddrcfg = 0x00000422, + .dmc_ddrtr0 = 0x20E0A424, + .dmc_ddrtr1 = 0x302006DB, + .dmc_ddrtr2 = 0x0032020D, + .dmc_ddrmr = 0x00000842, + .dmc_ddrmr1 = 0x4, + }, + [6] = { + .ddr_clk = 250, /* 250MHz */ + .dmc_ddrctl = 0x00000904, + .dmc_ddrcfg = 0x00000422, + .dmc_ddrtr0 = 0x20E0A424, + .dmc_ddrtr1 = 0x3020079E, + .dmc_ddrtr2 = 0x0032050D, + .dmc_ddrmr = 0x00000842, + .dmc_ddrmr1 = 0x4, + }, +}; +#endif /* __ADSPBF60x__ */ + __attribute__((always_inline)) static inline void serial_init(void) { - uint32_t uart_base = UART_DLL; + uint32_t uart_base = UART_BASE;
-#ifdef __ADSPBF54x__ +#if defined(__ADSPBF54x__) || defined(__ADSPBF60x__) # ifdef BFIN_BOOT_UART_USE_RTS # define BFIN_UART_USE_RTS 1 # else @@ -38,7 +159,12 @@ static inline void serial_init(void) size_t i;
/* force RTS rather than relying on auto RTS */ +#if BFIN_UART_HW_VER < 4 bfin_write16(&pUART->mcr, bfin_read16(&pUART->mcr) | FCPOL); +#else + bfin_write32(&pUART->control, bfin_read32(&pUART->control) | + FCPOL); +#endif
/* Wait for the line to clear up. We cannot rely on UART * registers as none of them reflect the status of the RSR. @@ -68,13 +194,14 @@ static inline void serial_init(void) #endif
if (BFIN_DEBUG_EARLY_SERIAL) { - int ucen = bfin_read16(&pUART->gctl) & UCEN; + int enabled = serial_early_enabled(uart_base); + serial_early_init(uart_base);
/* If the UART is off, that means we need to program * the baud rate ourselves initially. */ - if (ucen != UCEN) + if (!enabled) serial_early_set_baud(uart_base, CONFIG_BAUDRATE); } } @@ -82,12 +209,17 @@ static inline void serial_init(void) __attribute__((always_inline)) static inline void serial_deinit(void) { -#ifdef __ADSPBF54x__ - uint32_t uart_base = UART_DLL; +#if defined(__ADSPBF54x__) || defined(__ADSPBF60x__) + uint32_t uart_base = UART_BASE;
if (BFIN_UART_USE_RTS && CONFIG_BFIN_BOOT_MODE == BFIN_BOOT_UART) { /* clear forced RTS rather than relying on auto RTS */ +#if BFIN_UART_HW_VER < 4 bfin_write16(&pUART->mcr, bfin_read16(&pUART->mcr) & ~FCPOL); +#else + bfin_write32(&pUART->control, bfin_read32(&pUART->control) & + ~FCPOL); +#endif } #endif } @@ -95,7 +227,7 @@ static inline void serial_deinit(void) __attribute__((always_inline)) static inline void serial_putc(char c) { - uint32_t uart_base = UART_DLL; + uint32_t uart_base = UART_BASE;
if (!BFIN_DEBUG_EARLY_SERIAL) return; @@ -103,9 +235,9 @@ static inline void serial_putc(char c) if (c == '\n') serial_putc('\r');
- bfin_write16(&pUART->thr, c); + bfin_write(&pUART->thr, c);
- while (!(bfin_read16(&pUART->lsr) & TEMT)) + while (!(_lsr_read(pUART) & TEMT)) continue; }
@@ -152,6 +284,24 @@ program_nmi_handler(void) # define bfin_write_SPI_BAUD bfin_write_SPI0_BAUD #endif
+#ifdef __ADSPBF60x__ + +#ifndef CONFIG_CGU_CTL_VAL +# define CONFIG_CGU_CTL_VAL ((CONFIG_VCO_MULT << 8) | CONFIG_CLKIN_HALF) +#endif + +#ifndef CONFIG_CGU_DIV_VAL +# define CONFIG_CGU_DIV_VAL \ + ((CONFIG_CCLK_DIV << CSEL_P) | \ + (CONFIG_SCLK0_DIV << S0SEL_P) | \ + (CONFIG_SCLK_DIV << SYSSEL_P) | \ + (CONFIG_SCLK1_DIV << S1SEL_P) | \ + (CONFIG_DCLK_DIV << DSEL_P) | \ + (CONFIG_OCLK_DIV << OSEL_P)) +#endif + +#else /* __ADSPBF60x__ */ + /* PLL_DIV defines */ #ifndef CONFIG_PLL_DIV_VAL # if (CONFIG_CCLK_DIV == 1) @@ -275,6 +425,8 @@ program_nmi_handler(void) # endif #endif
+#endif /* __ADSPBF60x__ */ + __attribute__((always_inline)) static inline void program_early_devices(ADI_BOOT_DATA *bs, uint *sdivB, uint *divB, uint *vcoB) { @@ -283,8 +435,14 @@ program_early_devices(ADI_BOOT_DATA *bs, uint *sdivB, uint *divB, uint *vcoB) /* Save the clock pieces that are used in baud rate calculation */ if (BFIN_DEBUG_EARLY_SERIAL || CONFIG_BFIN_BOOT_MODE == BFIN_BOOT_UART) { serial_putc('b'); +#ifdef __ADSPBF60x__ + *sdivB = bfin_read_CGU_DIV(); + *sdivB = ((*sdivB >> 8) & 0x1f) * ((*sdivB >> 5) & 0x7); + *vcoB = (bfin_read_CGU_CTL() >> 8) & 0x7f; +#else *sdivB = bfin_read_PLL_DIV() & 0xf; *vcoB = (bfin_read_PLL_CTL() >> 9) & 0x3f; +#endif *divB = serial_early_get_div(); serial_putc('c'); } @@ -316,6 +474,7 @@ program_early_devices(ADI_BOOT_DATA *bs, uint *sdivB, uint *divB, uint *vcoB) * boot. Once we switch over to u-boot's SPI flash driver, we'll * increase the speed appropriately. */ +#ifdef SPI_BAUD if (CONFIG_BFIN_BOOT_MODE == BFIN_BOOT_SPI_MASTER) { serial_putc('h'); if (BOOTROM_SUPPORTS_SPI_FAST_READ && CONFIG_SPI_BAUD_INITBLOCK < 4) @@ -323,6 +482,7 @@ program_early_devices(ADI_BOOT_DATA *bs, uint *sdivB, uint *divB, uint *vcoB) bfin_write_SPI_BAUD(CONFIG_SPI_BAUD_INITBLOCK); serial_putc('i'); } +#endif
serial_putc('j'); } @@ -335,6 +495,10 @@ maybe_self_refresh(ADI_BOOT_DATA *bs) if (!CONFIG_MEM_SIZE) return false;
+#ifdef __ADSPBF60x__ + +#else /* __ADSPBF60x__ */ + /* If external memory is enabled, put it into self refresh first. */ #if defined(EBIU_RSTCTL) if (bfin_read_EBIU_RSTCTL() & DDR_SRESET) { @@ -350,6 +514,7 @@ maybe_self_refresh(ADI_BOOT_DATA *bs) } #endif
+#endif /* __ADSPBF60x__ */ serial_putc('c');
return false; @@ -362,6 +527,37 @@ program_clocks(ADI_BOOT_DATA *bs, bool put_into_srfs)
serial_putc('a');
+#ifdef __ADSPBF60x__ + if (bfin_read_DMC0_STAT() & MEMINITDONE) { + bfin_write_DMC0_CTL(bfin_read_DMC0_CTL() | SRREQ); + SSYNC(); + while (!(bfin_read_DMC0_STAT() & SRACK)) + continue; + } + + /* Don't set the same value of MSEL and DF to CGU_CTL */ + if ((bfin_read_CGU_CTL() & (MSEL_MASK | DF_MASK)) + != CONFIG_CGU_CTL_VAL) { + bfin_write_CGU_DIV(CONFIG_CGU_DIV_VAL); + bfin_write_CGU_CTL(CONFIG_CGU_CTL_VAL); + while ((bfin_read_CGU_STAT() & (CLKSALGN | PLLBP)) || + !(bfin_read_CGU_STAT() & PLLLK)) + continue; + } + + bfin_write_CGU_DIV(CONFIG_CGU_DIV_VAL | UPDT); + while (bfin_read_CGU_STAT() & CLKSALGN) + continue; + + if (bfin_read_DMC0_STAT() & MEMINITDONE) { + bfin_write_DMC0_CTL(bfin_read_DMC0_CTL() & ~SRREQ); + SSYNC(); + while (bfin_read_DMC0_STAT() & SRACK) + continue; + } + +#else /* __ADSPBF60x__ */ + vr_ctl = bfin_read_VR_CTL();
serial_putc('b'); @@ -433,7 +629,7 @@ program_clocks(ADI_BOOT_DATA *bs, bool put_into_srfs) #elif defined(SICA_IWR0) bfin_write_SICA_IWR0(1); bfin_write_SICA_IWR1(0); -#else +#elif defined(SIC_IWR) bfin_write_SIC_IWR(1); #endif
@@ -482,13 +678,15 @@ program_clocks(ADI_BOOT_DATA *bs, bool put_into_srfs) #elif defined(SICA_IWR0) bfin_write_SICA_IWR0(-1); bfin_write_SICA_IWR1(-1); -#else +#elif defined(SIC_IWR) bfin_write_SIC_IWR(-1); #endif
serial_putc('n'); }
+#endif /* __ADSPBF60x__ */ + serial_putc('o');
return vr_ctl; @@ -505,16 +703,25 @@ update_serial_clocks(ADI_BOOT_DATA *bs, uint sdivB, uint divB, uint vcoB) * for dividing which means we'd generate a libgcc reference. */ if (CONFIG_BFIN_BOOT_MODE == BFIN_BOOT_UART) { - serial_putc('b'); unsigned int sdivR, vcoR; - sdivR = bfin_read_PLL_DIV() & 0xf; - vcoR = (bfin_read_PLL_CTL() >> 9) & 0x3f; int dividend = sdivB * divB * vcoR; int divisor = vcoB * sdivR; unsigned int quotient; + + serial_putc('b'); + +#ifdef __ADSPBF60x__ + sdivR = bfin_read_CGU_DIV(); + sdivR = ((sdivR >> 8) & 0x1f) * ((sdivR >> 5) & 0x7); + vcoR = (bfin_read_CGU_CTL() >> 8) & 0x7f; +#else + sdivR = bfin_read_PLL_DIV() & 0xf; + vcoR = (bfin_read_PLL_CTL() >> 9) & 0x3f; +#endif + for (quotient = 0; dividend > 0; ++quotient) dividend -= divisor; - serial_early_put_div(UART_DLL, quotient - ANOMALY_05000230); + serial_early_put_div(quotient - ANOMALY_05000230); serial_putc('c'); }
@@ -531,6 +738,84 @@ program_memory_controller(ADI_BOOT_DATA *bs, bool put_into_srfs)
serial_putc('b');
+#ifdef __ADSPBF60x__ + int dlldatacycle; + int dll_ctl; + int i = 0; + + if (CONFIG_BFIN_GET_DCLK_M == 125) + i = 0; + else if (CONFIG_BFIN_GET_DCLK_M == 133) + i = 1; + else if (CONFIG_BFIN_GET_DCLK_M == 150) + i = 2; + else if (CONFIG_BFIN_GET_DCLK_M == 166) + i = 3; + else if (CONFIG_BFIN_GET_DCLK_M == 200) + i = 4; + else if (CONFIG_BFIN_GET_DCLK_M == 225) + i = 5; + else if (CONFIG_BFIN_GET_DCLK_M == 250) + i = 6; + +#if 0 + for (i = 0; i < ARRAY_SIZE(ddr_config_table); i++) + if (CONFIG_BFIN_GET_DCLK_M == ddr_config_table[i].ddr_clk) + break; +#endif + +#ifndef CONFIG_DMC_DDRCFG + bfin_write_DMC0_CFG(ddr_config_table[i].dmc_ddrcfg); +#else + bfin_write_DMC0_CFG(CONFIG_DMC_DDRCFG); +#endif +#ifndef CONFIG_DMC_DDRTR0 + bfin_write_DMC0_TR0(ddr_config_table[i].dmc_ddrtr0); +#else + bfin_write_DMC0_TR0(CONFIG_DMC_DDRTR0); +#endif +#ifndef CONFIG_DMC_DDRTR1 + bfin_write_DMC0_TR1(ddr_config_table[i].dmc_ddrtr1); +#else + bfin_write_DMC0_TR1(CONFIG_DMC_DDRTR1); +#endif +#ifndef CONFIG_DMC_DDRTR2 + bfin_write_DMC0_TR2(ddr_config_table[i].dmc_ddrtr2); +#else + bfin_write_DMC0_TR2(CONFIG_DMC_DDRTR2); +#endif +#ifndef CONFIG_DMC_DDRMR + bfin_write_DMC0_MR(ddr_config_table[i].dmc_ddrmr); +#else + bfin_write_DMC0_MR(CONFIG_DMC_DDRMR); +#endif +#ifndef CONFIG_DMC_DDREMR1 + bfin_write_DMC0_EMR1(ddr_config_table[i].dmc_ddrmr1); +#else + bfin_write_DMC0_EMR1(CONFIG_DMC_DDREMR1); +#endif +#ifndef CONFIG_DMC_DDRCTL + bfin_write_DMC0_CTL(ddr_config_table[i].dmc_ddrctl); +#else + bfin_write_DMC0_CTL(CONFIG_DMC_DDRCTL); +#endif + + SSYNC(); + while (!(bfin_read_DMC0_STAT() & MEMINITDONE)) + continue; + + dlldatacycle = (bfin_read_DMC0_STAT() & PHYRDPHASE) >> + PHYRDPHASE_OFFSET; + dll_ctl = bfin_read_DMC0_DLLCTL(); + dll_ctl &= 0x0ff; + bfin_write_DMC0_DLLCTL(dll_ctl | (dlldatacycle << DATACYC_OFFSET)); + + SSYNC(); + while (!(bfin_read_DMC0_STAT() & DLLCALDONE)) + continue; + serial_putc('!'); +#else /* __ADSPBF60x__ */ + /* Program the external memory controller before we come out of * self-refresh. This only works with our SDRAM controller. */ @@ -583,6 +868,7 @@ program_memory_controller(ADI_BOOT_DATA *bs, bool put_into_srfs) # endif #endif
+#endif /* __ADSPBF60x__ */ serial_putc('e'); }
@@ -606,7 +892,8 @@ check_hibernation(ADI_BOOT_DATA *bs, u16 vr_ctl, bool put_into_srfs) */ if (ANOMALY_05000307 || vr_ctl & 0x8000) { uint32_t *hibernate_magic = 0; - __builtin_bfin_ssync(); /* make sure memory controller is done */ + + SSYNC(); if (hibernate_magic[0] == 0xDEADBEEF) { serial_putc('c'); bfin_write_EVT15(hibernate_magic[1]); @@ -689,3 +976,4 @@ void initcode(ADI_BOOT_DATA *bs)
serial_deinit(); } + diff --git a/arch/blackfin/cpu/initcode.h b/arch/blackfin/cpu/initcode.h index e0aad6d..1fec7f3 100644 --- a/arch/blackfin/cpu/initcode.h +++ b/arch/blackfin/cpu/initcode.h @@ -15,6 +15,8 @@ # define serial_putc(c) #endif
+#ifndef __ADSPBF60x__ + #ifndef CONFIG_EBIU_RSTCTL_VAL # define CONFIG_EBIU_RSTCTL_VAL 0 /* only MDDRENABLE is useful */ #endif @@ -30,6 +32,8 @@ # error invalid EBIU_DDRQUE value: must not set reserved bits #endif
+#endif /* __ADSPBF60x__ */ + __attribute__((always_inline)) static inline void program_async_controller(ADI_BOOT_DATA *bs) { @@ -45,10 +49,13 @@ program_async_controller(ADI_BOOT_DATA *bs)
serial_putc('a');
+#ifdef __ADSPBF60x__ /* Program the async banks controller. */ +#ifdef EBIU_AMGCTL bfin_write_EBIU_AMBCTL0(CONFIG_EBIU_AMBCTL0_VAL); bfin_write_EBIU_AMBCTL1(CONFIG_EBIU_AMBCTL1_VAL); bfin_write_EBIU_AMGCTL(CONFIG_EBIU_AMGCTL_VAL); +#endif
serial_putc('b');
@@ -66,6 +73,51 @@ program_async_controller(ADI_BOOT_DATA *bs) #endif
serial_putc('c'); + +#else /* __ADSPBF60x__ */ + /* Program the static memory controller. */ +# ifdef CONFIG_SMC_GCTL_VAL + bfin_write_SMC_GCTL(CONFIG_SMC_GCTL_VAL); +# endif +# ifdef CONFIG_SMC_B0CTL_VAL + bfin_write_SMC_B0CTL(CONFIG_SMC_B0CTL_VAL); +# endif +# ifdef CONFIG_SMC_B0TIM_VAL + bfin_write_SMC_B0TIM(CONFIG_SMC_B0TIM_VAL); +# endif +# ifdef CONFIG_SMC_B0ETIM_VAL + bfin_write_SMC_B0ETIM(CONFIG_SMC_B0ETIM_VAL); +# endif +# ifdef CONFIG_SMC_B1CTL_VAL + bfin_write_SMC_B1CTL(CONFIG_SMC_B1CTL_VAL); +# endif +# ifdef CONFIG_SMC_B1TIM_VAL + bfin_write_SMC_B1TIM(CONFIG_SMC_B1TIM_VAL); +# endif +# ifdef CONFIG_SMC_B1ETIM_VAL + bfin_write_SMC_B1ETIM(CONFIG_SMC_B1ETIM_VAL); +# endif +# ifdef CONFIG_SMC_B2CTL_VAL + bfin_write_SMC_B2CTL(CONFIG_SMC_B2CTL_VAL); +# endif +# ifdef CONFIG_SMC_B2TIM_VAL + bfin_write_SMC_B2TIM(CONFIG_SMC_B2TIM_VAL); +# endif +# ifdef CONFIG_SMC_B2ETIM_VAL + bfin_write_SMC_B2ETIM(CONFIG_SMC_B2ETIM_VAL); +# endif +# ifdef CONFIG_SMC_B3CTL_VAL + bfin_write_SMC_B3CTL(CONFIG_SMC_B3CTL_VAL); +# endif +# ifdef CONFIG_SMC_B3TIM_VAL + bfin_write_SMC_B3TIM(CONFIG_SMC_B3TIM_VAL); +# endif +# ifdef CONFIG_SMC_B3ETIM_VAL + bfin_write_SMC_B3ETIM(CONFIG_SMC_B3ETIM_VAL); +# endif + +#endif + serial_putc('d'); }
#endif diff --git a/arch/blackfin/cpu/reset.c b/arch/blackfin/cpu/reset.c index ff39035..b6718d3 100644 --- a/arch/blackfin/cpu/reset.c +++ b/arch/blackfin/cpu/reset.c @@ -23,6 +23,7 @@ __attribute__ ((__l1_text__, __noreturn__)) static void bfin_reset(void) { +#ifdef SWRST /* Wait for completion of "system" events such as cache line * line fills so that we avoid infinite stalls later on as * much as possible. This code is in L1, so it won't trigger @@ -66,10 +67,15 @@ static void bfin_reset(void) : "a" (15 * 1) : "LC1", "LB1", "LT1" ); +#endif
while (1) +#if defined(__ADSPBF60x__) + bfin_write_RCU0_CTL(0x1); +#else /* Issue core reset */ asm("raise 1"); +#endif }
/* We need to trampoline ourselves up into L1 since our linker diff --git a/arch/blackfin/include/asm/config-pre.h b/arch/blackfin/include/asm/config-pre.h index be5687c..d0fd537 100644 --- a/arch/blackfin/include/asm/config-pre.h +++ b/arch/blackfin/include/asm/config-pre.h @@ -29,6 +29,8 @@ #define BFIN_BOOT_16HOST_DMA 11 /* boot ldr from 16-bit host dma */ #define BFIN_BOOT_8HOST_DMA 12 /* boot ldr from 8-bit host dma */ #define BFIN_BOOT_NAND 13 /* boot ldr from nand flash */ +#define BFIN_BOOT_RSI_MASTER 14 /* boot ldr from rsi */ +#define BFIN_BOOT_LP_SLAVE 15 /* boot ldr from link port */
#ifndef __ASSEMBLY__ static inline const char *get_bfin_boot_mode(int bfin_boot) @@ -47,6 +49,8 @@ static inline const char *get_bfin_boot_mode(int bfin_boot) case BFIN_BOOT_16HOST_DMA: return "16bit dma"; case BFIN_BOOT_8HOST_DMA: return "8bit dma"; case BFIN_BOOT_NAND: return "nand flash"; + case BFIN_BOOT_RSI_MASTER: return "rsi master"; + case BFIN_BOOT_LP_SLAVE: return "link port slave"; default: return "INVALID"; } } diff --git a/arch/blackfin/lib/board.c b/arch/blackfin/lib/board.c index 9fbbea0..098f685 100644 --- a/arch/blackfin/lib/board.c +++ b/arch/blackfin/lib/board.c @@ -295,7 +295,13 @@ void board_init_f(ulong bootflag)
printf("Clock: VCO: %s MHz, ", strmhz(buf, get_vco())); printf("Core: %s MHz, ", strmhz(buf, get_cclk())); +#if defined(__ADSPBF60x__) + printf("System0: %s MHz, ", strmhz(buf, get_sclk0())); + printf("System1: %s MHz, ", strmhz(buf, get_sclk1())); + printf("Dclk: %s MHz\n", strmhz(buf, get_dclk())); +#else printf("System: %s MHz\n", strmhz(buf, get_sclk())); +#endif
if (CONFIG_MEM_SIZE) { printf("RAM: "); diff --git a/arch/blackfin/lib/clocks.c b/arch/blackfin/lib/clocks.c index 0be395b..d852f5e 100644 --- a/arch/blackfin/lib/clocks.c +++ b/arch/blackfin/lib/clocks.c @@ -9,69 +9,139 @@ #include <common.h> #include <asm/blackfin.h>
+#ifdef PLL_CTL +# include <asm/mach-common/bits/pll.h> +# define pll_is_bypassed() (bfin_read_PLL_STAT() & DF) +#else +# include <asm/mach-common/bits/cgu.h> +# define pll_is_bypassed() (bfin_read_CGU_STAT() & PLLBP) +# define bfin_read_PLL_CTL() bfin_read_CGU_CTL() +# define bfin_read_PLL_DIV() bfin_read_CGU_DIV() +#endif + /* Get the voltage input multiplier */ -static u_long cached_vco_pll_ctl, cached_vco; u_long get_vco(void) { - u_long msel; + static u_long cached_vco_pll_ctl, cached_vco; + + u_long msel, pll_ctl;
- u_long pll_ctl = bfin_read_PLL_CTL(); + pll_ctl = bfin_read_PLL_CTL(); if (pll_ctl == cached_vco_pll_ctl) return cached_vco; else cached_vco_pll_ctl = pll_ctl;
- msel = (pll_ctl >> 9) & 0x3F; + msel = (pll_ctl & MSEL) >> MSEL_P; if (0 == msel) - msel = 64; + msel = (MSEL >> MSEL_P) + 1;
cached_vco = CONFIG_CLKIN_HZ; - cached_vco >>= (1 & pll_ctl); /* DF bit */ + cached_vco >>= (pll_ctl & DF); cached_vco *= msel; return cached_vco; }
/* Get the Core clock */ -static u_long cached_cclk_pll_div, cached_cclk; u_long get_cclk(void) { - u_long csel, ssel; + static u_long cached_cclk_pll_div, cached_cclk; + u_long div, csel, ssel;
- if (bfin_read_PLL_STAT() & 0x1) + if (pll_is_bypassed()) return CONFIG_CLKIN_HZ;
- ssel = bfin_read_PLL_DIV(); - if (ssel == cached_cclk_pll_div) + div = bfin_read_PLL_DIV(); + if (div == cached_cclk_pll_div) return cached_cclk; else - cached_cclk_pll_div = ssel; + cached_cclk_pll_div = div;
- csel = ((ssel >> 4) & 0x03); - ssel &= 0xf; + csel = (div & CSEL) >> CSEL_P; +#ifndef CGU_DIV + ssel = (div & SSEL) >> SSEL_P; if (ssel && ssel < (1 << csel)) /* SCLK > CCLK */ cached_cclk = get_vco() / ssel; else cached_cclk = get_vco() >> csel; +#else + cached_cclk = get_vco() / csel; +#endif return cached_cclk; }
/* Get the System clock */ +#ifdef CGU_DIV + static u_long cached_sclk_pll_div, cached_sclk; +static u_long cached_sclk0, cached_sclk1, cached_dclk; +static u_long _get_sclk(u_long *cache) +{ + u_long div, ssel; + + if (pll_is_bypassed()) + return CONFIG_CLKIN_HZ; + + div = bfin_read_PLL_DIV(); + if (div == cached_sclk_pll_div) + return *cache; + else + cached_sclk_pll_div = div; + + ssel = (div & SYSSEL) >> SYSSEL_P; + cached_sclk = get_vco() / ssel; + + ssel = (div & S0SEL) >> S0SEL_P; + cached_sclk0 = cached_sclk / ssel; + + ssel = (div & S1SEL) >> S1SEL_P; + cached_sclk1 = cached_sclk / ssel; + + ssel = (div & DSEL) >> DSEL_P; + cached_dclk = get_vco() / ssel; + + return *cache; +} + u_long get_sclk(void) { - u_long ssel; + return _get_sclk(&cached_sclk); +} + +u_long get_sclk0(void) +{ + return _get_sclk(&cached_sclk0); +} + +u_long get_sclk1(void) +{ + return _get_sclk(&cached_sclk1); +} + +u_long get_dclk(void) +{ + return _get_sclk(&cached_dclk); +} +#else + +u_long get_sclk(void) +{ + static u_long cached_sclk_pll_div, cached_sclk; + u_long div, ssel;
- ssel = bfin_read_PLL_DIV(); - if (ssel == cached_sclk_pll_div) + div = bfin_read_PLL_DIV(); + if (div == cached_sclk_pll_div) return cached_sclk; else - cached_sclk_pll_div = ssel; - - ssel &= 0xf; + cached_sclk_pll_div = div;
+ ssel = (div & SSEL) >> SSEL_P; cached_sclk = get_vco() / ssel; + return cached_sclk; } + +#endif diff --git a/common/cmd_reginfo.c b/common/cmd_reginfo.c index 08a6563..b591bd3 100644 --- a/common/cmd_reginfo.c +++ b/common/cmd_reginfo.c @@ -191,7 +191,7 @@ static int do_reginfo(cmd_tbl_t *cmdtp, int flag, int argc,
#elif defined(CONFIG_BLACKFIN) puts("\nSystem Configuration registers\n"); - +#ifndef __ADSPBF60x__ puts("\nPLL Registers\n"); printf("\tPLL_DIV: 0x%04x PLL_CTL: 0x%04x\n", bfin_read_PLL_DIV(), bfin_read_PLL_CTL()); @@ -227,7 +227,24 @@ static int do_reginfo(cmd_tbl_t *cmdtp, int flag, int argc, printf("\tEBIU_SDSTAT: 0x%04x EBIU_SDGCTL: 0x%08x\n", bfin_read_EBIU_SDSTAT(), bfin_read_EBIU_SDGCTL()); # endif +#else + puts("\nCGU Registers\n"); + printf("\tCGU_DIV: 0x%08x CGU_CTL: 0x%08x\n", + bfin_read_CGU_DIV(), bfin_read_CGU_CTL()); + printf("\tCGU_STAT: 0x%08x CGU_LOCKCNT: 0x%08x\n", + bfin_read_CGU_STAT(), bfin_read_CGU_CLKOUTSEL());
+ puts("\nSMC DDR Registers\n"); + printf("\tDDR_CFG: 0x%08x DDR_TR0: 0x%08x\n", + bfin_read_DMC0_CFG(), bfin_read_DMC0_TR0()); + printf("\tDDR_TR1: 0x%08x DDR_TR2: 0x%08x\n", + bfin_read_DMC0_TR1(), bfin_read_DMC0_TR2()); + printf("\tDDR_MR: 0x%08x DDR_EMR1: 0x%08x\n", + bfin_read_DMC0_MR(), bfin_read_DMC0_EMR1()); + printf("\tDDR_CTL: 0x%08x DDR_STAT: 0x%08x\n", + bfin_read_DMC0_CTL(), bfin_read_DMC0_STAT()); + printf("\tDDR_DLLCTL:0x%08x\n", bfin_read_DMC0_DLLCTL()); +#endif #endif /* CONFIG_BLACKFIN */
Add serial for bf60x.
Fix issues in Wolfgang's feedback: 1) Replace unreable macro in uart structures with normal types. 2) Replace unreable macro in uart peripheral portmux configuration with clear inline function. 3) Fix all checkpatch issues
Signed-off-by: Sonic Zhang sonic.zhang@analog.com Signed-off-by: Bob Liu lliubbo@gmail.com --- arch/blackfin/cpu/serial.c | 81 +++-- arch/blackfin/cpu/serial.h | 222 +------------ arch/blackfin/cpu/serial1.h | 348 ++++++++++++++++++++ arch/blackfin/cpu/serial4.h | 161 +++++++++ arch/blackfin/include/asm/mach-bf533/BF531_def.h | 1 + arch/blackfin/include/asm/mach-bf561/BF561_def.h | 1 + arch/blackfin/include/asm/mach-common/bits/uart4.h | 66 ++++ 7 files changed, 642 insertions(+), 238 deletions(-) create mode 100644 arch/blackfin/cpu/serial1.h create mode 100644 arch/blackfin/cpu/serial4.h create mode 100644 arch/blackfin/include/asm/mach-common/bits/uart4.h
diff --git a/arch/blackfin/cpu/serial.c b/arch/blackfin/cpu/serial.c index 64340ec..9847e9f 100644 --- a/arch/blackfin/cpu/serial.c +++ b/arch/blackfin/cpu/serial.c @@ -43,7 +43,6 @@ #include <serial.h> #include <linux/compiler.h> #include <asm/blackfin.h> -#include <asm/mach-common/bits/uart.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -52,8 +51,8 @@ DECLARE_GLOBAL_DATA_PTR; #include "serial.h"
#ifdef CONFIG_DEBUG_SERIAL -static uint16_t cached_lsr[256]; -static uint16_t cached_rbr[256]; +static uart_lsr_t cached_lsr[256]; +static uart_lsr_t cached_rbr[256]; static size_t cache_count;
/* The LSR is read-to-clear on some parts, so we have to make sure status @@ -61,10 +60,10 @@ static size_t cache_count; * works around anomaly 05000099 at the same time by keeping a cumulative * tally of all the status bits. */ -static uint16_t uart_lsr_save; -static uint16_t uart_lsr_read(uint32_t uart_base) +static uart_lsr_t uart_lsr_save; +static uart_lsr_t uart_lsr_read(uint32_t uart_base) { - uint16_t lsr = bfin_read(&pUART->lsr); + uart_lsr_t lsr = _lsr_read(pUART); uart_lsr_save |= (lsr & (OE|PE|FE|BI)); return lsr | uart_lsr_save; } @@ -72,20 +71,20 @@ static uint16_t uart_lsr_read(uint32_t uart_base) static void uart_lsr_clear(uint32_t uart_base) { uart_lsr_save = 0; - bfin_write(&pUART->lsr, bfin_read(&pUART->lsr) | -1); + _lsr_write(pUART, -1); } #else /* When debugging is disabled, we only care about the DR bit, so if other * bits get set/cleared, we don't really care since we don't read them * anyways (and thus anomaly 05000099 is irrelevant). */ -static inline uint16_t uart_lsr_read(uint32_t uart_base) +static inline uart_lsr_t uart_lsr_read(uint32_t uart_base) { - return bfin_read(&pUART->lsr); + return _lsr_read(pUART); } static void uart_lsr_clear(uint32_t uart_base) { - bfin_write(&pUART->lsr, bfin_read(&pUART->lsr) | -1); + _lsr_write(pUART, -1); } #endif
@@ -127,20 +126,14 @@ static int uart_getc(uint32_t uart_base)
#ifdef CONFIG_DEBUG_SERIAL /* grab & clear the LSR */ - uint16_t uart_lsr_val = uart_lsr_read(uart_base); + uart_lsr_t uart_lsr_val = uart_lsr_read(uart_base);
cached_lsr[cache_count] = uart_lsr_val; cached_rbr[cache_count] = uart_rbr_val; cache_count = (cache_count + 1) % ARRAY_SIZE(cached_lsr);
if (uart_lsr_val & (OE|PE|FE|BI)) { - uint16_t dll, dlh; printf("\n[SERIAL ERROR]\n"); - ACCESS_LATCH(); - dll = bfin_read(&pUART->dll); - dlh = bfin_read(&pUART->dlh); - ACCESS_PORT_IER(); - printf("\tDLL=0x%x DLH=0x%x\n", dll, dlh); do { --cache_count; printf("\t%3zu: RBR=0x%02x LSR=0x%02x\n", cache_count, @@ -160,6 +153,8 @@ static int uart_getc(uint32_t uart_base) # define LOOP(x) #endif
+#if BFIN_UART_HW_VER < 4 + LOOP( static void uart_loop(uint32_t uart_base, int state) { @@ -178,6 +173,28 @@ static void uart_loop(uint32_t uart_base, int state) } )
+#else + +LOOP( +static void uart_loop(uint32_t uart_base, int state) +{ + u32 control; + + /* Drain the TX fifo first so bytes don't come back */ + while (!(uart_lsr_read(uart_base) & TEMT)) + continue; + + control = bfin_read(&pUART->control); + if (state) + control |= LOOP_ENA | MRTS; + else + control &= ~(LOOP_ENA | MRTS); + bfin_write(&pUART->control, control); +} +) + +#endif + #ifdef CONFIG_SYS_BFIN_UART
static void uart_puts(uint32_t uart_base, const char *s) @@ -246,16 +263,16 @@ struct serial_device bfin_serial##n##_device = { \ LOOP(.loop = uart##n##_loop) \ };
-#ifdef UART0_DLL +#ifdef UART0_RBR DECL_BFIN_UART(0) #endif -#ifdef UART1_DLL +#ifdef UART1_RBR DECL_BFIN_UART(1) #endif -#ifdef UART2_DLL +#ifdef UART2_RBR DECL_BFIN_UART(2) #endif -#ifdef UART3_DLL +#ifdef UART3_RBR DECL_BFIN_UART(3) #endif
@@ -274,16 +291,16 @@ __weak struct serial_device *default_serial_console(void)
void bfin_serial_initialize(void) { -#ifdef UART0_DLL +#ifdef UART0_RBR serial_register(&bfin_serial0_device); #endif -#ifdef UART1_DLL +#ifdef UART1_RBR serial_register(&bfin_serial1_device); #endif -#ifdef UART2_DLL +#ifdef UART2_RBR serial_register(&bfin_serial2_device); #endif -#ifdef UART3_DLL +#ifdef UART3_RBR serial_register(&bfin_serial3_device); #endif } @@ -293,7 +310,7 @@ void bfin_serial_initialize(void) /* Symbol for our assembly to call. */ void serial_set_baud(uint32_t baud) { - serial_early_set_baud(UART_DLL, baud); + serial_early_set_baud(UART_BASE, baud); }
/* Symbol for common u-boot code to call. @@ -307,7 +324,7 @@ void serial_setbrg(void) /* Symbol for our assembly to call. */ void serial_initialize(void) { - serial_early_init(UART_DLL); + serial_early_init(UART_BASE); }
/* Symbol for common u-boot code to call. */ @@ -315,23 +332,23 @@ int serial_init(void) { serial_initialize(); serial_setbrg(); - uart_lsr_clear(UART_DLL); + uart_lsr_clear(UART_BASE); return 0; }
int serial_tstc(void) { - return uart_tstc(UART_DLL); + return uart_tstc(UART_BASE); }
int serial_getc(void) { - return uart_getc(UART_DLL); + return uart_getc(UART_BASE); }
void serial_putc(const char c) { - uart_putc(UART_DLL, c); + uart_putc(UART_BASE, c); }
void serial_puts(const char *s) @@ -343,7 +360,7 @@ void serial_puts(const char *s) LOOP( void serial_loop(int state) { - uart_loop(UART_DLL, state); + uart_loop(UART_BASE, state); } )
diff --git a/arch/blackfin/cpu/serial.h b/arch/blackfin/cpu/serial.h index 8a076dd..9200339 100644 --- a/arch/blackfin/cpu/serial.h +++ b/arch/blackfin/cpu/serial.h @@ -3,7 +3,7 @@ * any functions defined here must be always_inline since * initcode cannot have function calls. * - * Copyright (c) 2004-2007 Analog Devices Inc. + * Copyright (c) 2004-2011 Analog Devices Inc. * * Licensed under the GPL-2 or later. */ @@ -12,7 +12,7 @@ #define __BFIN_CPU_SERIAL_H__
#include <asm/blackfin.h> -#include <asm/mach-common/bits/uart.h> +#include <asm/portmux.h>
#ifndef CONFIG_UART_CONSOLE # define CONFIG_UART_CONSOLE 0 @@ -24,88 +24,34 @@ # define BFIN_DEBUG_EARLY_SERIAL 0 #endif
-#ifndef __ASSEMBLY__ - -#include <asm/portmux.h> - -#define LOB(x) ((x) & 0xFF) -#define HIB(x) (((x) >> 8) & 0xFF) - -#if defined(__ADSPBF50x__) || defined(__ADSPBF54x__) +#if defined(__ADSPBF60x__) +# define BFIN_UART_HW_VER 4 +#elif defined(__ADSPBF50x__) || defined(__ADSPBF54x__) # define BFIN_UART_HW_VER 2 #else # define BFIN_UART_HW_VER 1 #endif
-/* - * All Blackfin system MMRs are padded to 32bits even if the register - * itself is only 16bits. So use a helper macro to streamline this. - */ -#define __BFP(m) u16 m; u16 __pad_##m -struct bfin_mmr_serial { -#if BFIN_UART_HW_VER == 2 - __BFP(dll); - __BFP(dlh); - __BFP(gctl); - __BFP(lcr); - __BFP(mcr); - __BFP(lsr); - __BFP(msr); - __BFP(scr); - __BFP(ier_set); - __BFP(ier_clear); - __BFP(thr); - __BFP(rbr); -#else - union { - u16 dll; - u16 thr; - const u16 rbr; - }; - const u16 __spad0; - union { - u16 dlh; - u16 ier; - }; - const u16 __spad1; - const __BFP(iir); - __BFP(lcr); - __BFP(mcr); - __BFP(lsr); - __BFP(msr); - __BFP(scr); - const u32 __spad2; - __BFP(gctl); -#endif -}; -#undef __BFP - #define __PASTE_UART(num, pfx, sfx) pfx##num##_##sfx #define _PASTE_UART(num, pfx, sfx) __PASTE_UART(num, pfx, sfx) -#define MMR_UART(n) _PASTE_UART(n, UART, DLL) #define _P_UART(n, pin) _PASTE_UART(n, P_UART, pin) #define P_UART(pin) _P_UART(CONFIG_UART_CONSOLE, pin)
-#ifndef UART_DLL -# define UART_DLL MMR_UART(CONFIG_UART_CONSOLE) -#else -# define UART0_DLL UART_DLL -# if CONFIG_UART_CONSOLE != 0 -# error CONFIG_UART_CONSOLE must be 0 on parts with only one UART -# endif -#endif #define pUART ((volatile struct bfin_mmr_serial *)uart_base)
-#if BFIN_UART_HW_VER == 2 -# define ACCESS_LATCH() -# define ACCESS_PORT_IER() +#ifndef __ASSEMBLY__ +__attribute__((always_inline)) +static inline void serial_do_portmux(void); +#endif + +#if BFIN_UART_HW_VER < 4 +# include "serial1.h" #else -# define ACCESS_LATCH() \ - bfin_write(&pUART->lcr, bfin_read(&pUART->lcr) | DLAB) -# define ACCESS_PORT_IER() \ - bfin_write(&pUART->lcr, bfin_read(&pUART->lcr) & ~DLAB) +# include "serial4.h" #endif
+#ifndef __ASSEMBLY__ + __attribute__((always_inline)) static inline void serial_do_portmux(void) { @@ -115,143 +61,7 @@ static inline void serial_do_portmux(void) return; }
-#if defined(__ADSPBF50x__) -# define DO_MUX(port, mux_tx, mux_rx, tx, rx) \ - bfin_write_PORT##port##_MUX((bfin_read_PORT##port##_MUX() & ~(PORT_x_MUX_##mux_tx##_MASK | PORT_x_MUX_##mux_rx##_MASK)) | PORT_x_MUX_##mux_tx##_FUNC_1 | PORT_x_MUX_##mux_rx##_FUNC_1); \ - bfin_write_PORT##port##_FER(bfin_read_PORT##port##_FER() | P##port##tx | P##port##rx); - switch (CONFIG_UART_CONSOLE) { - case 0: DO_MUX(G, 7, 7, 12, 13); break; /* Port G; mux 7; PG12 and PG13 */ - case 1: DO_MUX(F, 3, 3, 6, 7); break; /* Port F; mux 3; PF6 and PF7 */ - } - SSYNC(); -#elif defined(__ADSPBF51x__) -# define DO_MUX(port, mux_tx, mux_rx, tx, rx) \ - bfin_write_PORT##port##_MUX((bfin_read_PORT##port##_MUX() & ~(PORT_x_MUX_##mux_tx##_MASK | PORT_x_MUX_##mux_rx##_MASK)) | PORT_x_MUX_##mux_tx##_FUNC_2 | PORT_x_MUX_##mux_rx##_FUNC_2); \ - bfin_write_PORT##port##_FER(bfin_read_PORT##port##_FER() | P##port##tx | P##port##rx); - switch (CONFIG_UART_CONSOLE) { - case 0: DO_MUX(G, 5, 5, 9, 10); break; /* Port G; mux 5; PG9 and PG10 */ - case 1: DO_MUX(F, 2, 3, 14, 15); break; /* Port H; mux 2/3; PH14 and PH15 */ - } - SSYNC(); -#elif defined(__ADSPBF52x__) -# define DO_MUX(port, mux, tx, rx) \ - bfin_write_PORT##port##_MUX((bfin_read_PORT##port##_MUX() & ~PORT_x_MUX_##mux##_MASK) | PORT_x_MUX_##mux##_FUNC_3); \ - bfin_write_PORT##port##_FER(bfin_read_PORT##port##_FER() | P##port##tx | P##port##rx); - switch (CONFIG_UART_CONSOLE) { - case 0: DO_MUX(G, 2, 7, 8); break; /* Port G; mux 2; PG2 and PG8 */ - case 1: DO_MUX(F, 5, 14, 15); break; /* Port F; mux 5; PF14 and PF15 */ - } - SSYNC(); -#elif defined(__ADSPBF537__) || defined(__ADSPBF536__) || defined(__ADSPBF534__) - const uint16_t func[] = { PFDE, PFTE, }; - bfin_write_PORT_MUX(bfin_read_PORT_MUX() & ~func[CONFIG_UART_CONSOLE]); - bfin_write_PORTF_FER(bfin_read_PORTF_FER() | - (1 << P_IDENT(P_UART(RX))) | - (1 << P_IDENT(P_UART(TX)))); - SSYNC(); -#elif defined(__ADSPBF54x__) -# define DO_MUX(port, tx, rx) \ - bfin_write_PORT##port##_MUX((bfin_read_PORT##port##_MUX() & ~(PORT_x_MUX_##tx##_MASK | PORT_x_MUX_##rx##_MASK)) | PORT_x_MUX_##tx##_FUNC_1 | PORT_x_MUX_##rx##_FUNC_1); \ - bfin_write_PORT##port##_FER(bfin_read_PORT##port##_FER() | P##port##tx | P##port##rx); - switch (CONFIG_UART_CONSOLE) { - case 0: DO_MUX(E, 7, 8); break; /* Port E; PE7 and PE8 */ - case 1: DO_MUX(H, 0, 1); break; /* Port H; PH0 and PH1 */ - case 2: DO_MUX(B, 4, 5); break; /* Port B; PB4 and PB5 */ - case 3: DO_MUX(B, 6, 7); break; /* Port B; PB6 and PB7 */ - } - SSYNC(); -#elif defined(__ADSPBF561__) - /* UART pins could be GPIO, but they aren't pin muxed. */ -#else -# if (P_UART(RX) & P_DEFINED) || (P_UART(TX) & P_DEFINED) -# error "missing portmux logic for UART" -# endif -#endif -} - -__attribute__((always_inline)) -static inline int uart_init(uint32_t uart_base) -{ - /* always enable UART -- avoids anomalies 05000309 and 05000350 */ - bfin_write(&pUART->gctl, UCEN); - - /* Set LCR to Word Lengh 8-bit word select */ - bfin_write(&pUART->lcr, WLS_8); - - SSYNC(); - - return 0; -} - -__attribute__((always_inline)) -static inline int serial_early_init(uint32_t uart_base) -{ - /* handle portmux crap on different Blackfins */ - serial_do_portmux(); - - return uart_init(uart_base); -} - -__attribute__((always_inline)) -static inline int serial_early_uninit(uint32_t uart_base) -{ - /* disable the UART by clearing UCEN */ - bfin_write(&pUART->gctl, 0); - - return 0; -} - -__attribute__((always_inline)) -static inline void serial_early_put_div(uint32_t uart_base, uint16_t divisor) -{ - /* Set DLAB in LCR to Access DLL and DLH */ - ACCESS_LATCH(); - SSYNC(); - - /* Program the divisor to get the baud rate we want */ - bfin_write(&pUART->dll, LOB(divisor)); - bfin_write(&pUART->dlh, HIB(divisor)); - SSYNC(); - - /* Clear DLAB in LCR to Access THR RBR IER */ - ACCESS_PORT_IER(); - SSYNC(); -} - -__attribute__((always_inline)) -static inline uint16_t serial_early_get_div(void) -{ - uint32_t uart_base = UART_DLL; - - /* Set DLAB in LCR to Access DLL and DLH */ - ACCESS_LATCH(); - SSYNC(); - - uint8_t dll = bfin_read(&pUART->dll); - uint8_t dlh = bfin_read(&pUART->dlh); - uint16_t divisor = (dlh << 8) | dll; - - /* Clear DLAB in LCR to Access THR RBR IER */ - ACCESS_PORT_IER(); - SSYNC(); - - return divisor; -} - -/* We cannot use get_sclk() early on as it uses caches in external memory */ -#if defined(BFIN_IN_INITCODE) || defined(CONFIG_DEBUG_EARLY_SERIAL) -# define get_sclk() (CONFIG_CLKIN_HZ * CONFIG_VCO_MULT / CONFIG_SCLK_DIV) -#endif - -__attribute__((always_inline)) -static inline void serial_early_set_baud(uint32_t uart_base, uint32_t baud) -{ - /* Translate from baud into divisor in terms of SCLK. The - * weird multiplication is to make sure we over sample just - * a little rather than under sample the incoming signals. - */ - serial_early_put_div(uart_base, - (get_sclk() + (baud * 8)) / (baud * 16) - ANOMALY_05000230); + serial_early_do_portmux(); }
#ifndef BFIN_IN_INITCODE diff --git a/arch/blackfin/cpu/serial1.h b/arch/blackfin/cpu/serial1.h new file mode 100644 index 0000000..a20175b --- /dev/null +++ b/arch/blackfin/cpu/serial1.h @@ -0,0 +1,348 @@ +/* + * serial.h - common serial defines for early debug and serial driver. + * any functions defined here must be always_inline since + * initcode cannot have function calls. + * + * Copyright (c) 2004-2011 Analog Devices Inc. + * + * Licensed under the GPL-2 or later. + */ + +#ifndef __BFIN_CPU_SERIAL1_H__ +#define __BFIN_CPU_SERIAL1_H__ + +#include <asm/mach-common/bits/uart.h> + +#ifndef __ASSEMBLY__ + +#define MMR_UART(n) _PASTE_UART(n, UART, DLL) +#ifdef UART_DLL +# define UART0_DLL UART_DLL +# if CONFIG_UART_CONSOLE != 0 +# error CONFIG_UART_CONSOLE must be 0 on parts with only one UART +# endif +#endif +#define UART_BASE MMR_UART(CONFIG_UART_CONSOLE) + +#define LOB(x) ((x) & 0xFF) +#define HIB(x) (((x) >> 8) & 0xFF) + +/* + * All Blackfin system MMRs are padded to 32bits even if the register + * itself is only 16bits. So use a helper macro to streamline this. + */ +struct bfin_mmr_serial { +#if BFIN_UART_HW_VER == 2 + u16 dll; + u16 __pad_0; + u16 dlh; + u16 __pad_1; + u16 gctl; + u16 __pad_2; + u16 lcr; + u16 __pad_3; + u16 mcr; + u16 __pad_4; + u16 lsr; + u16 __pad_5; + u16 msr; + u16 __pad_6; + u16 scr; + u16 __pad_7; + u16 ier_set; + u16 __pad_8; + u16 ier_clear; + u16 __pad_9; + u16 thr; + u16 __pad_10; + u16 rbr; + u16 __pad_11; +#else + union { + u16 dll; + u16 thr; + const u16 rbr; + }; + const u16 __spad0; + union { + u16 dlh; + u16 ier; + }; + const u16 __spad1; + const u16 iir; + u16 __pad_0; + u16 lcr; + u16 __pad_1; + u16 mcr; + u16 __pad_2; + u16 lsr; + u16 __pad_3; + u16 msr; + u16 __pad_4; + u16 scr; + u16 __pad_5; + const u32 __spad2; + u16 gctl; + u16 __pad_6; +#endif +}; + +#define uart_lsr_t uint32_t +#define _lsr_read(p) bfin_read(&p->lsr) +#define _lsr_write(p, v) bfin_write(&p->lsr, v) + +#if BFIN_UART_HW_VER == 2 +# define ACCESS_LATCH() +# define ACCESS_PORT_IER() +#else +# define ACCESS_LATCH() bfin_write_or(&pUART->lcr, DLAB) +# define ACCESS_PORT_IER() bfin_write_and(&pUART->lcr, ~DLAB) +#endif + +__attribute__((always_inline)) +static inline void serial_early_do_mach_portmux(char port, int mux_mask, + int mux_func, int port_pin) +{ + switch (port) { +#if defined(__ADSPBF54x__) + case 'B': + bfin_write_PORTB_MUX((bfin_read_PORTB_MUX() & + ~mux_mask) | mux_func); + bfin_write_PORTB_FER(bfin_read_PORTB_FER() | port_pin); + break; + case 'E': + bfin_write_PORTE_MUX((bfin_read_PORTE_MUX() & + ~mux_mask) | mux_func); + bfin_write_PORTE_FER(bfin_read_PORTE_FER() | port_pin); + break; +#endif +#if defined(__ADSPBF50x__) || defined(__ADSPBF51x__) || defined(__ADSPBF52x__) + case 'F': + bfin_write_PORTF_MUX((bfin_read_PORTF_MUX() & + ~mux_mask) | mux_func); + bfin_write_PORTF_FER(bfin_read_PORTF_FER() | port_pin); + break; + case 'G': + bfin_write_PORTG_MUX((bfin_read_PORTG_MUX() & + ~mux_mask) | mux_func); + bfin_write_PORTG_FER(bfin_read_PORTG_FER() | port_pin); + break; + case 'H': + bfin_write_PORTH_MUX((bfin_read_PORTH_MUX() & + ~mux_mask) | mux_func); + bfin_write_PORTH_FER(bfin_read_PORTH_FER() | port_pin); + break; +#endif + default: + break; + } +} + +__attribute__((always_inline)) +static inline void serial_early_do_portmux(void) +{ +#if defined(__ADSPBF50x__) + switch (CONFIG_UART_CONSOLE) { + case 0: + serial_early_do_mach_portmux('G', PORT_x_MUX_7_MASK, + PORT_x_MUX_7_FUNC_1, PG12); /* TX: G; mux 7; func 1; PG12 */ + serial_early_do_mach_portmux('G', PORT_x_MUX_7_MASK, + PORT_x_MUX_7_FUNC_1, PG13); /* RX: G; mux 7; func 1; PG13 */ + break; + case 1: + serial_early_do_mach_portmux('F', PORT_x_MUX_3_MASK, + PORT_x_MUX_3_FUNC_1, PF7); /* TX: F; mux 3; func 1; PF6 */ + serial_early_do_mach_portmux('F', PORT_x_MUX_3_MASK, + PORT_x_MUX_3_FUNC_1, PF6); /* RX: F; mux 3; func 1; PF7 */ + break; + } +#elif defined(__ADSPBF51x__) + switch (CONFIG_UART_CONSOLE) { + case 0: + serial_early_do_mach_portmux('G', PORT_x_MUX_5_MASK, + PORT_x_MUX_5_FUNC_2, PG9); /* TX: G; mux 5; func 2; PG9 */ + serial_early_do_mach_portmux('G', PORT_x_MUX_5_MASK, + PORT_x_MUX_5_FUNC_2, PG10); /* RX: G; mux 5; func 2; PG10 */ + break; + case 1: + serial_early_do_mach_portmux('H', PORT_x_MUX_3_MASK, + PORT_x_MUX_3_FUNC_2, PH7); /* TX: H; mux 3; func 2; PH6 */ + serial_early_do_mach_portmux('H', PORT_x_MUX_3_MASK, + PORT_x_MUX_3_FUNC_2, PH6); /* RX: H; mux 3; func 2; PH7 */ + break; + } +#elif defined(__ADSPBF52x__) + switch (CONFIG_UART_CONSOLE) { + case 0: + serial_early_do_mach_portmux('G', PORT_x_MUX_2_MASK, + PORT_x_MUX_2_FUNC_3, PG7); /* TX: G; mux 2; func 3; PG7 */ + serial_early_do_mach_portmux('G', PORT_x_MUX_2_MASK, + PORT_x_MUX_2_FUNC_3, PG8); /* RX: G; mux 2; func 3; PG8 */ + break; + case 1: + serial_early_do_mach_portmux('F', PORT_x_MUX_5_MASK, + PORT_x_MUX_5_FUNC_3, PF14); /* TX: F; mux 5; func 3; PF14 */ + serial_early_do_mach_portmux('F', PORT_x_MUX_5_MASK, + PORT_x_MUX_5_FUNC_3, PF15); /* RX: F; mux 5; func 3; PF15 */ + break; + } +#elif defined(__ADSPBF537__) || defined(__ADSPBF536__) || defined(__ADSPBF534__) + const uint16_t func[] = { PFDE, PFTE, }; + bfin_write_PORT_MUX(bfin_read_PORT_MUX() & ~func[CONFIG_UART_CONSOLE]); + bfin_write_PORTF_FER(bfin_read_PORTF_FER() | + (1 << P_IDENT(P_UART(RX))) | + (1 << P_IDENT(P_UART(TX)))); +#elif defined(__ADSPBF54x__) + switch (CONFIG_UART_CONSOLE) { + case 0: + serial_early_do_mach_portmux('E', PORT_x_MUX_7_MASK, + PORT_x_MUX_7_FUNC_1, PE7); /* TX: E; mux 7; func 1; PE7 */ + serial_early_do_mach_portmux('E', PORT_x_MUX_8_MASK, + PORT_x_MUX_8_FUNC_1, PE8); /* RX: E; mux 8; func 1; PE8 */ + break; + case 1: + serial_early_do_mach_portmux('H', PORT_x_MUX_0_MASK, + PORT_x_MUX_0_FUNC_1, PH0); /* TX: H; mux 0; func 1; PH0 */ + serial_early_do_mach_portmux('H', PORT_x_MUX_1_MASK, + PORT_x_MUX_1_FUNC_1, PH1); /* RX: H; mux 1; func 1; PH1 */ + break; + case 2: + serial_early_do_mach_portmux('B', PORT_x_MUX_4_MASK, + PORT_x_MUX_4_FUNC_1, PB4); /* TX: B; mux 4; func 1; PB4 */ + serial_early_do_mach_portmux('B', PORT_x_MUX_5_MASK, + PORT_x_MUX_5_FUNC_1, PB5); /* RX: B; mux 5; func 1; PB5 */ + break; + case 3: + serial_early_do_mach_portmux('B', PORT_x_MUX_6_MASK, + PORT_x_MUX_6_FUNC_1, PB6); /* TX: B; mux 6; func 1; PB6 */ + serial_early_do_mach_portmux('B', PORT_x_MUX_7_MASK, + PORT_x_MUX_7_FUNC_1, PB7); /* RX: B; mux 7; func 1; PB7 */ + break; + } +#elif defined(__ADSPBF561__) + /* UART pins could be GPIO, but they aren't pin muxed. */ +#else +# if (P_UART(RX) & P_DEFINED) || (P_UART(TX) & P_DEFINED) +# error "missing portmux logic for UART" +# endif +#endif + SSYNC(); +} + +__attribute__((always_inline)) +static inline uint32_t uart_sclk(void) +{ +#if defined(BFIN_IN_INITCODE) || defined(CONFIG_DEBUG_EARLY_SERIAL) + /* We cannot use get_sclk() early on as it uses + * caches in external memory + */ + return CONFIG_CLKIN_HZ * CONFIG_VCO_MULT / CONFIG_SCLK_DIV; +#else + return get_sclk(); +#endif +} + +__attribute__((always_inline)) +static inline int uart_init(uint32_t uart_base) +{ + /* always enable UART -- avoids anomalies 05000309 and 05000350 */ + bfin_write(&pUART->gctl, UCEN); + + /* Set LCR to Word Lengh 8-bit word select */ + bfin_write(&pUART->lcr, WLS_8); + + SSYNC(); + + return 0; +} + +__attribute__((always_inline)) +static inline int serial_early_init(uint32_t uart_base) +{ + /* handle portmux crap on different Blackfins */ + serial_do_portmux(); + + return uart_init(uart_base); +} + +__attribute__((always_inline)) +static inline int serial_early_uninit(uint32_t uart_base) +{ + /* disable the UART by clearing UCEN */ + bfin_write(&pUART->gctl, 0); + + return 0; +} + +__attribute__((always_inline)) +static inline int serial_early_enabled(uint32_t uart_base) +{ + return bfin_read(&pUART->gctl) & UCEN; +} + +__attribute__((always_inline)) +static inline void serial_early_set_baud(uint32_t uart_base, uint32_t baud) +{ + /* Translate from baud into divisor in terms of SCLK. The + * weird multiplication is to make sure we over sample just + * a little rather than under sample the incoming signals. + */ + uint16_t divisor = (uart_sclk() + (baud * 8)) / (baud * 16) - + ANOMALY_05000230; + + /* Set DLAB in LCR to Access DLL and DLH */ + ACCESS_LATCH(); + SSYNC(); + + /* Program the divisor to get the baud rate we want */ + bfin_write(&pUART->dll, LOB(divisor)); + bfin_write(&pUART->dlh, HIB(divisor)); + SSYNC(); + + /* Clear DLAB in LCR to Access THR RBR IER */ + ACCESS_PORT_IER(); + SSYNC(); +} + +__attribute__((always_inline)) +static inline void serial_early_put_div(uint16_t divisor) +{ + uint32_t uart_base = UART_BASE; + + /* Set DLAB in LCR to Access DLL and DLH */ + ACCESS_LATCH(); + SSYNC(); + + /* Program the divisor to get the baud rate we want */ + bfin_write(&pUART->dll, LOB(divisor)); + bfin_write(&pUART->dlh, HIB(divisor)); + SSYNC(); + + /* Clear DLAB in LCR to Access THR RBR IER */ + ACCESS_PORT_IER(); + SSYNC(); +} + +__attribute__((always_inline)) +static inline uint16_t serial_early_get_div(void) +{ + uint32_t uart_base = UART_BASE; + + /* Set DLAB in LCR to Access DLL and DLH */ + ACCESS_LATCH(); + SSYNC(); + + uint8_t dll = bfin_read(&pUART->dll); + uint8_t dlh = bfin_read(&pUART->dlh); + uint16_t divisor = (dlh << 8) | dll; + + /* Clear DLAB in LCR to Access THR RBR IER */ + ACCESS_PORT_IER(); + SSYNC(); + + return divisor; +} + +#endif + +#endif diff --git a/arch/blackfin/cpu/serial4.h b/arch/blackfin/cpu/serial4.h new file mode 100644 index 0000000..33009c3 --- /dev/null +++ b/arch/blackfin/cpu/serial4.h @@ -0,0 +1,161 @@ +/* + * serial.h - common serial defines for early debug and serial driver. + * any functions defined here must be always_inline since + * initcode cannot have function calls. + * + * Copyright (c) 2004-2011 Analog Devices Inc. + * + * Licensed under the GPL-2 or later. + */ + +#ifndef __BFIN_CPU_SERIAL4_H__ +#define __BFIN_CPU_SERIAL4_H__ + +#include <asm/mach-common/bits/uart4.h> + +#ifndef __ASSEMBLY__ + +#define MMR_UART(n) _PASTE_UART(n, UART, REVID) +#define UART_BASE MMR_UART(CONFIG_UART_CONSOLE) + +struct bfin_mmr_serial { + u32 revid; + u32 control; + u32 status; + u32 scr; + u32 clock; + u32 emask; + u32 emaskst; + u32 emaskcl; + u32 rbr; + u32 thr; + u32 taip; + u32 tsr; + u32 rsr; + u32 txdiv_cnt; + u32 rxdiv_cnt; +}; +#define uart_lsr_t uint32_t +#define _lsr_read(p) bfin_read(&p->status) +#define _lsr_write(p, v) bfin_write(&p->status, v) + +__attribute__((always_inline)) +static inline void serial_early_do_mach_portmux(char port, int mux_mask, + int mux_func, int port_pin) +{ + switch (port) { + case 'D': + bfin_write_PORTD_MUX((bfin_read_PORTD_MUX() & + ~mux_mask) | mux_func); + bfin_write_PORTD_FER(bfin_read_PORTD_FER() | port_pin); + break; + case 'G': + bfin_write_PORTG_MUX((bfin_read_PORTG_MUX() & + ~mux_mask) | mux_func); + bfin_write_PORTG_FER(bfin_read_PORTG_FER() | port_pin); + break; + } +} + +__attribute__((always_inline)) +static inline void serial_early_do_portmux(void) +{ +#if defined(__ADSPBF60x__) + switch (CONFIG_UART_CONSOLE) { + case 0: + serial_early_do_mach_portmux('D', PORT_x_MUX_7_MASK, + PORT_x_MUX_7_FUNC_2, PD7); /* TX: D; mux 7; func 2; PD7 */ + serial_early_do_mach_portmux('D', PORT_x_MUX_8_MASK, + PORT_x_MUX_8_FUNC_2, PD8); /* RX: D; mux 8; func 2; PD8 */ + break; + case 1: + serial_early_do_mach_portmux('G', PORT_x_MUX_15_MASK, + PORT_x_MUX_15_FUNC_1, PG15); /* TX: G; mux 15; func 1; PG15 */ + serial_early_do_mach_portmux('G', PORT_x_MUX_14_MASK, + PORT_x_MUX_14_FUNC_1, PG14); /* RX: G; mux 14; func 1; PG14 */ + break; + } +#else +# if (P_UART(RX) & P_DEFINED) || (P_UART(TX) & P_DEFINED) +# error "missing portmux logic for UART" +# endif +#endif + SSYNC(); +} + +__attribute__((always_inline)) +static inline uint32_t uart_sclk(void) +{ +#if defined(BFIN_IN_INITCODE) || defined(CONFIG_DEBUG_EARLY_SERIAL) + /* We cannot use get_sclk() early on as it uses caches in + * external memory + */ + return CONFIG_CLKIN_HZ * CONFIG_VCO_MULT / CONFIG_SCLK_DIV / + CONFIG_SCLK0_DIV; +#else + return get_sclk0(); +#endif +} + +__attribute__((always_inline)) +static inline int uart_init(uint32_t uart_base) +{ + /* always enable UART to 8-bit mode */ + bfin_write(&pUART->control, UEN | UMOD_UART | WLS_8); + + SSYNC(); + + return 0; +} + +__attribute__((always_inline)) +static inline int serial_early_init(uint32_t uart_base) +{ + /* handle portmux crap on different Blackfins */ + serial_do_portmux(); + + return uart_init(uart_base); +} + +__attribute__((always_inline)) +static inline int serial_early_uninit(uint32_t uart_base) +{ + /* disable the UART by clearing UEN */ + bfin_write(&pUART->control, 0); + + return 0; +} + +__attribute__((always_inline)) +static inline int serial_early_enabled(uint32_t uart_base) +{ + return bfin_read(&pUART->control) & UEN; +} + +__attribute__((always_inline)) +static inline void serial_early_set_baud(uint32_t uart_base, uint32_t baud) +{ + uint32_t divisor = uart_sclk() / (baud * 16); + + /* Program the divisor to get the baud rate we want */ + bfin_write(&pUART->clock, divisor); + SSYNC(); +} + +__attribute__((always_inline)) +static inline void serial_early_put_div(uint32_t divisor) +{ + uint32_t uart_base = UART_BASE; + bfin_write(&pUART->clock, divisor); +} + +__attribute__((always_inline)) +static inline uint32_t serial_early_get_div(void) +{ + uint32_t uart_base = UART_BASE; + return bfin_read(&pUART->clock); +} + +#endif + +#endif diff --git a/arch/blackfin/include/asm/mach-bf533/BF531_def.h b/arch/blackfin/include/asm/mach-bf533/BF531_def.h index 3b61aaf..2bcd2d8 100644 --- a/arch/blackfin/include/asm/mach-bf533/BF531_def.h +++ b/arch/blackfin/include/asm/mach-bf533/BF531_def.h @@ -149,6 +149,7 @@ #define UART_LSR 0xFFC00414 #define UART_SCR 0xFFC0041C #define UART_RBR 0xFFC00400 /* Receive Buffer */ +#define UART0_RBR UART_RBR #define UART_GCTL 0xFFC00424 #define SPT0_TX_CONFIG0 0xFFC00800 #define SPT0_TX_CONFIG1 0xFFC00804 diff --git a/arch/blackfin/include/asm/mach-bf561/BF561_def.h b/arch/blackfin/include/asm/mach-bf561/BF561_def.h index 46925f8..a7ff5a3 100644 --- a/arch/blackfin/include/asm/mach-bf561/BF561_def.h +++ b/arch/blackfin/include/asm/mach-bf561/BF561_def.h @@ -690,6 +690,7 @@ #define PPI1_FRAME 0xFFC01310 #define UART_THR 0xFFC00400 #define UART_RBR 0xFFC00400 +#define UART0_RBR UART_RBR #define UART_DLL 0xFFC00400 #define UART_DLH 0xFFC00404 #define UART_IER 0xFFC00404 diff --git a/arch/blackfin/include/asm/mach-common/bits/uart4.h b/arch/blackfin/include/asm/mach-common/bits/uart4.h new file mode 100644 index 0000000..37808de --- /dev/null +++ b/arch/blackfin/include/asm/mach-common/bits/uart4.h @@ -0,0 +1,66 @@ +/* + * UART4 Masks + */ + +#ifndef __BFIN_PERIPHERAL_UART4__ +#define __BFIN_PERIPHERAL_UART4__ + +/* UART_CONTROL */ +#define UEN (1 << 0) +#define LOOP_ENA (1 << 1) +#define UMOD (3 << 4) +#define UMOD_UART (0 << 4) +#define UMOD_MDB (1 << 4) +#define UMOD_IRDA (1 << 4) +#define WLS (3 << 8) +#define WLS_5 (0 << 8) +#define WLS_6 (1 << 8) +#define WLS_7 (2 << 8) +#define WLS_8 (3 << 8) +#define STB (1 << 12) +#define STBH (1 << 13) +#define PEN (1 << 14) +#define EPS (1 << 15) +#define STP (1 << 16) +#define FPE (1 << 17) +#define FFE (1 << 18) +#define SB (1 << 19) +#define FCPOL (1 << 22) +#define RPOLC (1 << 23) +#define TPOLC (1 << 24) +#define MRTS (1 << 25) +#define XOFF (1 << 26) +#define ARTS (1 << 27) +#define ACTS (1 << 28) +#define RFIT (1 << 29) +#define RFRT (1 << 30) + +/* UART_STATUS */ +#define DR (1 << 0) +#define OE (1 << 1) +#define PE (1 << 2) +#define FE (1 << 3) +#define BI (1 << 4) +#define THRE (1 << 5) +#define TEMT (1 << 7) +#define TFI (1 << 8) +#define ASTKY (1 << 9) +#define ADDR (1 << 10) +#define RO (1 << 11) +#define SCTS (1 << 12) +#define CTS (1 << 16) +#define RFCS (1 << 17) + +/* UART_EMASK */ +#define ERBFI (1 << 0) +#define ETBEI (1 << 1) +#define ELSI (1 << 2) +#define EDSSI (1 << 3) +#define EDTPTI (1 << 4) +#define ETFI (1 << 5) +#define ERFCI (1 << 6) +#define EAWI (1 << 7) +#define ERXS (1 << 8) +#define ETXS (1 << 9) + +#endif
Add dma support for bf60x.
Fix review issues from Wolfgang: 1) Fix all checkpatch issues. 2) Remove unrelated dma structure change to separate patch. 3) The DMA config MMR on BF60x is 32 bits while it is 16 bits on BF5xx. The different type of config MMR is correct. 4) Replace unreable macro in dma structures with normal types.
Signed-off-by: Bob Liu lliubbo@gmail.com Signed-off-by: Sonic Zhang sonic.zhang@analog.com --- arch/blackfin/include/asm/dma.h | 81 ++++++++++++------ arch/blackfin/include/asm/mach-common/bits/dma.h | 54 +++++++++++- arch/blackfin/lib/string.c | 97 ++++++++++++---------- 3 files changed, 156 insertions(+), 76 deletions(-)
diff --git a/arch/blackfin/include/asm/dma.h b/arch/blackfin/include/asm/dma.h index 21ff1cf..ef1db6e 100644 --- a/arch/blackfin/include/asm/dma.h +++ b/arch/blackfin/include/asm/dma.h @@ -8,7 +8,12 @@ #ifndef _BLACKFIN_DMA_H_ #define _BLACKFIN_DMA_H_
+#include <linux/types.h> +#ifdef __ADSPBF60x__ +#include <asm/mach-common/bits/dde.h> +#else #include <asm/mach-common/bits/dma.h> +#endif
struct dmasg_large { void *next_desc_addr; @@ -30,46 +35,70 @@ struct dmasg { } __attribute__((packed));
struct dma_register { +#ifdef __ADSPBF60x__ + void *next_desc_ptr; /* DMA Next Descriptor Pointer register */ + u32 start_addr; /* DMA Start address register */ + u32 config; /* DMA Configuration register */ + + u32 x_count; /* DMA x_count register */ + s32 x_modify; /* DMA x_modify register */ + u32 y_count; /* DMA y_count register */ + s32 y_modify; /* DMA y_modify register */ + u32 __pad0[2]; + + void *curr_desc_ptr; /* DMA Curr Descriptor Pointer register */ + void *prev_desc_ptr; /* DMA Prev Descriptor Pointer register */ + void *curr_addr; /* DMA Current Address Pointer register */ + u32 status; /* DMA irq status register */ + u32 curr_x_count; /* DMA Current x-count register */ + u32 curr_y_count; /* DMA Current y-count register */ + u32 __pad1[2]; + + u32 bw_limit; /* DMA Bandwidth Limit Count */ + u32 curr_bw_limit; /* DMA curr Bandwidth Limit Count */ + u32 bw_monitor; /* DMA Bandwidth Monitor Count */ + u32 curr_bw_monitor; /* DMA curr Bandwidth Monitor Count */ +#else void *next_desc_ptr; /* DMA Next Descriptor Pointer register */ - unsigned long start_addr; /* DMA Start address register */ + u32 start_addr; /* DMA Start address register */
- unsigned short cfg; /* DMA Configuration register */ - unsigned short dummy1; /* DMA Configuration register */ + u16 config; /* DMA Configuration register */ + u16 dummy1; /* DMA Configuration register */
- unsigned long reserved; + u32 reserved;
- unsigned short x_count; /* DMA x_count register */ - unsigned short dummy2; + u16 x_count; /* DMA x_count register */ + u16 dummy2;
- short x_modify; /* DMA x_modify register */ - unsigned short dummy3; + s16 x_modify; /* DMA x_modify register */ + u16 dummy3;
- unsigned short y_count; /* DMA y_count register */ - unsigned short dummy4; + u16 y_count; /* DMA y_count register */ + u16 dummy4;
- short y_modify; /* DMA y_modify register */ - unsigned short dummy5; + s16 y_modify; /* DMA y_modify register */ + u16 dummy5;
- void *curr_desc_ptr; /* DMA Current Descriptor Pointer - register */ - unsigned long curr_addr_ptr; /* DMA Current Address Pointer - register */ - unsigned short irq_status; /* DMA irq status register */ - unsigned short dummy6; + void *curr_desc_ptr; /* DMA Current Descriptor Pointer register */
- unsigned short peripheral_map; /* DMA peripheral map register */ - unsigned short dummy7; + u32 curr_addr_ptr; /* DMA Current Address Pointer register */
- unsigned short curr_x_count; /* DMA Current x-count register */ - unsigned short dummy8; + u16 status; /* DMA irq status register */ + u16 dummy6;
- unsigned long reserved2; + u16 peripheral_map; /* DMA peripheral map register */ + u16 dummy7;
- unsigned short curr_y_count; /* DMA Current y-count register */ - unsigned short dummy9; + u16 curr_x_count; /* DMA Current x-count register */ + u16 dummy8;
- unsigned long reserved3; + u32 reserved2;
+ u16 curr_y_count; /* DMA Current y-count register */ + u16 dummy9; + + u32 reserved3; +#endif };
#endif diff --git a/arch/blackfin/include/asm/mach-common/bits/dma.h b/arch/blackfin/include/asm/mach-common/bits/dma.h index 136313e..ac426ad 100644 --- a/arch/blackfin/include/asm/mach-common/bits/dma.h +++ b/arch/blackfin/include/asm/mach-common/bits/dma.h @@ -9,14 +9,54 @@ #define DMAEN 0x0001 /* DMA Channel Enable */ #define WNR 0x0002 /* Channel Direction (W/R*) */ #define WDSIZE_8 0x0000 /* Transfer Word Size = 8 */ + +#ifdef CONFIG_BF60x + +#define PSIZE_8 0x00000000 /* Transfer Word Size = 16 */ +#define PSIZE_16 0x00000010 /* Transfer Word Size = 16 */ +#define PSIZE_32 0x00000020 /* Transfer Word Size = 32 */ +#define PSIZE_64 0x00000030 /* Transfer Word Size = 32 */ +#define WDSIZE_16 0x00000100 /* Transfer Word Size = 16 */ +#define WDSIZE_32 0x00000200 /* Transfer Word Size = 32 */ +#define WDSIZE_64 0x00000300 /* Transfer Word Size = 32 */ +#define WDSIZE_128 0x00000400 /* Transfer Word Size = 32 */ +#define WDSIZE_256 0x00000500 /* Transfer Word Size = 32 */ +#define DMA2D 0x04000000 /* DMA Mode (2D/1D*) */ +#define RESTART 0x00000004 /* DMA Buffer Clear SYNC */ +#define DI_EN_X 0x00100000 /* Data Int Enable in X count */ +#define DI_EN_Y 0x00200000 /* Data Int Enable in Y count */ +#define DI_EN_P 0x00300000 /* Data Int Enable in Peri */ +#define DI_EN DI_EN_X /* Data Int Enable */ +#define NDSIZE_0 0x00000000 /* Next Desc Size = 0 */ +#define NDSIZE_1 0x00010000 /* Next Desc Size = 1 */ +#define NDSIZE_2 0x00020000 /* Next Desc Size = 2 */ +#define NDSIZE_3 0x00030000 /* Next Desc Size = 3 */ +#define NDSIZE_4 0x00040000 /* Next Desc Size = 4 */ +#define NDSIZE_5 0x00050000 /* Next Desc Size = 5 */ +#define NDSIZE_6 0x00060000 /* Next Desc Size = 6 */ +#define NDSIZE 0x00070000 /* Next Desc Size */ +#define NDSIZE_OFFSET 16 /* Next Desc Size Offset */ +#define DMAFLOW_LIST 0x00004000 /* Desc List Mode */ +#define DMAFLOW_ARRAY 0x00005000 /* Desc Array Mode */ +#define DMAFLOW_LIST_DEMAND 0x00006000 /* Desc Demand List Mode */ +#define DMAFLOW_ARRAY_DEMAND 0x00007000 /* Desc Demand Array Mode */ +#define DMA_RUN_DFETCH 0x00000100 /* DMA Channel Run (DFETCH) */ +#define DMA_RUN 0x00000200 /* DMA Channel Run */ +#define DMA_RUN_WAIT_TRIG 0x00000300 /* DMA Channel Run (WAIT TRIG)*/ +#define DMA_RUN_WAIT_ACK 0x00000400 /* DMA Channel Run (WAIT ACK) */ + +#else + #define WDSIZE_16 0x0004 /* Transfer Word Size = 16 */ #define WDSIZE_32 0x0008 /* Transfer Word Size = 32 */ +#define PSIZE_16 WDSIZE_16 +#define PSIZE_32 WDSIZE_32 #define DMA2D 0x0010 /* DMA Mode (2D/1D*) */ #define RESTART 0x0020 /* DMA Buffer Clear */ #define DI_SEL 0x0040 /* Data Interrupt Timing Select */ #define DI_EN 0x0080 /* Data Interrupt Enable */ #define NDSIZE 0x0F00 /* Next Descriptor bitmask */ -#define NDSIZE_0 0x0000 /* Next Descriptor Size = 0 (Stop/Autobuffer) */ +#define NDSIZE_0 0x0000 /* Next Descriptor Size = 0 */ #define NDSIZE_1 0x0100 /* Next Descriptor Size = 1 */ #define NDSIZE_2 0x0200 /* Next Descriptor Size = 2 */ #define NDSIZE_3 0x0300 /* Next Descriptor Size = 3 */ @@ -26,14 +66,13 @@ #define NDSIZE_7 0x0700 /* Next Descriptor Size = 7 */ #define NDSIZE_8 0x0800 /* Next Descriptor Size = 8 */ #define NDSIZE_9 0x0900 /* Next Descriptor Size = 9 */ -#define FLOW_STOP 0x0000 /* Stop Mode */ -#define FLOW_AUTO 0x1000 /* Autobuffer Mode */ #define FLOW_ARRAY 0x4000 /* Descriptor Array Mode */ #define FLOW_SMALL 0x6000 /* Small Model Descriptor List Mode */ #define FLOW_LARGE 0x7000 /* Large Model Descriptor List Mode */
#define DMAEN_P 0 /* Channel Enable */ #define WNR_P 1 /* Channel Direction (W/R*) */ +#define WDSIZE_P 2 /* Transfer Word Size */ #define DMA2D_P 4 /* 2D/1D* Mode */ #define RESTART_P 5 /* Restart */ #define DI_SEL_P 6 /* Data Interrupt Select */ @@ -45,14 +84,19 @@ #define DFETCH 0x0004 /* DMA Descriptor Fetch Indicator */ #define DMA_RUN 0x0008 /* DMA Channel Running Indicator */
+#endif +#define DMAFLOW 0x7000 /* Flow Control */ +#define FLOW_STOP 0x0000 /* Stop Mode */ +#define FLOW_AUTO 0x1000 /* Autobuffer Mode */ + #define DMA_DONE_P 0 /* DMA Done Indicator */ #define DMA_ERR_P 1 /* DMA Error Indicator */ #define DFETCH_P 2 /* Descriptor Fetch Indicator */ #define DMA_RUN_P 3 /* DMA Running Indicator */
/* DMAx_PERIPHERAL_MAP, MDMA_yy_PERIPHERAL_MAP Masks */ -#define CTYPE 0x0040 /* DMA Channel Type Indicator (Memory/Peripheral*) */ -#define CTYPE_P 6 /* DMA Channel Type Indicator BIT POSITION */ +#define CTYPE 0x0040 /* DMA Channel Type (Mem/Peri) */ +#define CTYPE_P 6 /* DMA Channel Type BIT POSITION */ #define PMAP 0xF000 /* Peripheral Mapped To This Channel */
#endif diff --git a/arch/blackfin/lib/string.c b/arch/blackfin/lib/string.c index e344d3b..44d8c6d 100644 --- a/arch/blackfin/lib/string.c +++ b/arch/blackfin/lib/string.c @@ -29,7 +29,7 @@ #include <config.h> #include <asm/blackfin.h> #include <asm/io.h> -#include <asm/mach-common/bits/dma.h> +#include <asm/dma.h>
char *strcpy(char *dest, const char *src) { @@ -117,81 +117,88 @@ int strncmp(const char *cs, const char *ct, size_t count) return __res1; }
-#ifdef bfin_write_MDMA1_D0_IRQ_STATUS -# define bfin_write_MDMA_D0_IRQ_STATUS bfin_write_MDMA1_D0_IRQ_STATUS -# define bfin_write_MDMA_D0_START_ADDR bfin_write_MDMA1_D0_START_ADDR -# define bfin_write_MDMA_D0_X_COUNT bfin_write_MDMA1_D0_X_COUNT -# define bfin_write_MDMA_D0_X_MODIFY bfin_write_MDMA1_D0_X_MODIFY -# define bfin_write_MDMA_D0_CONFIG bfin_write_MDMA1_D0_CONFIG -# define bfin_write_MDMA_S0_START_ADDR bfin_write_MDMA1_S0_START_ADDR -# define bfin_write_MDMA_S0_X_COUNT bfin_write_MDMA1_S0_X_COUNT -# define bfin_write_MDMA_S0_X_MODIFY bfin_write_MDMA1_S0_X_MODIFY -# define bfin_write_MDMA_S0_CONFIG bfin_write_MDMA1_S0_CONFIG -# define bfin_write_MDMA_D0_IRQ_STATUS bfin_write_MDMA1_D0_IRQ_STATUS -# define bfin_read_MDMA_D0_IRQ_STATUS bfin_read_MDMA1_D0_IRQ_STATUS +#ifdef MDMA1_D0_NEXT_DESC_PTR +# define MDMA_D0_NEXT_DESC_PTR MDMA1_D0_NEXT_DESC_PTR +# define MDMA_S0_NEXT_DESC_PTR MDMA1_S0_NEXT_DESC_PTR #endif + +static void dma_calc_size(unsigned long ldst, unsigned long lsrc, size_t count, + unsigned long *dshift, unsigned long *bpos) +{ + unsigned long limit; + +#ifdef MSIZE + limit = 6; + *dshift = MSIZE_P; +#else + limit = 3; + *dshift = WDSIZE_P; +#endif + + *bpos = min(limit, ffs(ldst | lsrc | count)) - 1; +} + /* This version misbehaves for count values of 0 and 2^16+. * Perhaps we should detect that ? Nowhere do we actually * use dma memcpy for those types of lengths though ... */ void dma_memcpy_nocache(void *dst, const void *src, size_t count) { - uint16_t wdsize, mod; + struct dma_register *mdma_d0 = (void *)MDMA_D0_NEXT_DESC_PTR; + struct dma_register *mdma_s0 = (void *)MDMA_S0_NEXT_DESC_PTR; + unsigned long ldst = (unsigned long)dst; + unsigned long lsrc = (unsigned long)src; + unsigned long dshift, bpos; + uint32_t dsize, mod;
/* Disable DMA in case it's still running (older u-boot's did not * always turn them off). Do it before the if statement below so * we can be cheap and not do a SSYNC() due to the forced abort. */ - bfin_write_MDMA_D0_CONFIG(0); - bfin_write_MDMA_S0_CONFIG(0); - bfin_write_MDMA_D0_IRQ_STATUS(DMA_RUN | DMA_DONE | DMA_ERR); + bfin_write(&mdma_d0->config, 0); + bfin_write(&mdma_s0->config, 0); + bfin_write(&mdma_d0->status, DMA_RUN | DMA_DONE | DMA_ERR);
/* Scratchpad cannot be a DMA source or destination */ - if (((unsigned long)src >= L1_SRAM_SCRATCH && - (unsigned long)src < L1_SRAM_SCRATCH_END) || - ((unsigned long)dst >= L1_SRAM_SCRATCH && - (unsigned long)dst < L1_SRAM_SCRATCH_END)) + if ((lsrc >= L1_SRAM_SCRATCH && lsrc < L1_SRAM_SCRATCH_END) || + (ldst >= L1_SRAM_SCRATCH && ldst < L1_SRAM_SCRATCH_END)) hang();
- if (((unsigned long)dst | (unsigned long)src | count) & 0x1) { - wdsize = WDSIZE_8; - mod = 1; - } else if (((unsigned long)dst | (unsigned long)src | count) & 0x2) { - wdsize = WDSIZE_16; - count >>= 1; - mod = 2; - } else { - wdsize = WDSIZE_32; - count >>= 2; - mod = 4; - } + dma_calc_size(ldst, lsrc, count, &dshift, &bpos); + dsize = bpos << dshift; + count >>= bpos; + mod = 1 << bpos; + +#ifdef PSIZE + dsize |= min(3, bpos) << PSIZE_P; +#endif
/* Copy sram functions from sdram to sram */ /* Setup destination start address */ - bfin_write_MDMA_D0_START_ADDR(dst); + bfin_write(&mdma_d0->start_addr, ldst); /* Setup destination xcount */ - bfin_write_MDMA_D0_X_COUNT(count); + bfin_write(&mdma_d0->x_count, count); /* Setup destination xmodify */ - bfin_write_MDMA_D0_X_MODIFY(mod); + bfin_write(&mdma_d0->x_modify, mod);
/* Setup Source start address */ - bfin_write_MDMA_S0_START_ADDR(src); + bfin_write(&mdma_s0->start_addr, lsrc); /* Setup Source xcount */ - bfin_write_MDMA_S0_X_COUNT(count); + bfin_write(&mdma_s0->x_count, count); /* Setup Source xmodify */ - bfin_write_MDMA_S0_X_MODIFY(mod); + bfin_write(&mdma_s0->x_modify, mod);
/* Enable source DMA */ - bfin_write_MDMA_S0_CONFIG(wdsize | DMAEN); - bfin_write_MDMA_D0_CONFIG(wdsize | DMAEN | WNR | DI_EN); + bfin_write(&mdma_s0->config, dsize | DMAEN); + bfin_write(&mdma_d0->config, dsize | DMAEN | WNR | DI_EN); SSYNC();
- while (!(bfin_read_MDMA_D0_IRQ_STATUS() & DMA_DONE)) + while (!(bfin_read(&mdma_d0->status) & DMA_DONE)) continue;
- bfin_write_MDMA_D0_IRQ_STATUS(DMA_RUN | DMA_DONE | DMA_ERR); - bfin_write_MDMA_D0_CONFIG(0); - bfin_write_MDMA_S0_CONFIG(0); + bfin_write(&mdma_d0->status, DMA_RUN | DMA_DONE | DMA_ERR); + bfin_write(&mdma_d0->config, 0); + bfin_write(&mdma_s0->config, 0); } /* We should do a dcache invalidate on the destination after the dma, but since * we lack such hardware capability, we'll flush/invalidate the destination
Bf60x support 16K, 64K, 16M and 64M cplb pages, this patch add support for them. So that bf609-ezkit can use it's 128M memory.
Fix review issues from Wolfgang: 1) Fix all checkpatch issues. 2) Replace run-time variable with additional macros when adding 4M byte CPLB entries.
Signed-off-by: Bob Liu lliubbo@gmail.com Signed-off-by: Sonic Zhang sonic.zhang@analog.com --- arch/blackfin/include/asm/cplb.h | 31 +++++++++++++++++++++++++++---- arch/blackfin/lib/board.c | 19 +++++++++++++++++-- 2 files changed, 44 insertions(+), 6 deletions(-)
diff --git a/arch/blackfin/include/asm/cplb.h b/arch/blackfin/include/asm/cplb.h index cc21e93..420380d 100644 --- a/arch/blackfin/include/asm/cplb.h +++ b/arch/blackfin/include/asm/cplb.h @@ -46,8 +46,13 @@ #define CPLB_IDOCACHE CPLB_INOCACHE | CPLB_L1_CHBL
/* Data Attibutes*/ - -#define SDRAM_IGENERIC (PAGE_SIZE_4MB | CPLB_L1_CHBL | CPLB_USER_RD | CPLB_VALID) +#if defined(__ADSPBF60x__) +#define SDRAM_IGENERIC (PAGE_SIZE_16MB | CPLB_L1_CHBL | \ + CPLB_USER_RD | CPLB_VALID) +#else +#define SDRAM_IGENERIC (PAGE_SIZE_4MB | CPLB_L1_CHBL | \ + CPLB_USER_RD | CPLB_VALID) +#endif #define SDRAM_IKERNEL (PAGE_SIZE_4MB | CPLB_L1_CHBL | CPLB_USER_RD | CPLB_VALID | CPLB_LOCK) #define L1_IMEMORY (PAGE_SIZE_1MB | CPLB_USER_RD | CPLB_VALID | CPLB_LOCK) #define SDRAM_INON_CHBL (PAGE_SIZE_4MB | CPLB_USER_RD | CPLB_VALID) @@ -59,14 +64,32 @@ #endif
#ifdef CONFIG_DCACHE_WB /*Write Back Policy */ -#define SDRAM_DGENERIC (PAGE_SIZE_4MB | CPLB_L1_CHBL | CPLB_DIRTY | CPLB_SUPV_WR | CPLB_USER_WR | CPLB_USER_RD | CPLB_VALID | ANOMALY_05000158_WORKAROUND) +#if defined(__ADSPBF60x__) +#define SDRAM_DGENERIC (PAGE_SIZE_16MB | CPLB_L1_CHBL | CPLB_DIRTY | \ + CPLB_SUPV_WR | CPLB_USER_WR | CPLB_USER_RD | \ + CPLB_VALID | ANOMALY_05000158_WORKAROUND) +#else +#define SDRAM_DGENERIC (PAGE_SIZE_4MB | CPLB_L1_CHBL | CPLB_DIRTY | \ + CPLB_SUPV_WR | CPLB_USER_WR | CPLB_USER_RD | \ + CPLB_VALID | ANOMALY_05000158_WORKAROUND) +#endif #define SDRAM_DNON_CHBL (PAGE_SIZE_4MB | CPLB_DIRTY | CPLB_SUPV_WR | CPLB_USER_RD | CPLB_USER_WR | CPLB_VALID | ANOMALY_05000158_WORKAROUND) #define SDRAM_DKERNEL (PAGE_SIZE_4MB | CPLB_L1_CHBL | CPLB_USER_RD | CPLB_USER_WR | CPLB_DIRTY | CPLB_SUPV_WR | CPLB_VALID | CPLB_LOCK | ANOMALY_05000158_WORKAROUND) #define L1_DMEMORY (PAGE_SIZE_4MB | CPLB_SUPV_WR | CPLB_USER_WR | CPLB_USER_RD | CPLB_VALID | ANOMALY_05000158_WORKAROUND) #define SDRAM_EBIU (PAGE_SIZE_4MB | CPLB_DIRTY | CPLB_USER_RD | CPLB_USER_WR | CPLB_SUPV_WR | CPLB_VALID | ANOMALY_05000158_WORKAROUND)
#else /*Write Through */ -#define SDRAM_DGENERIC (PAGE_SIZE_4MB | CPLB_L1_CHBL | CPLB_WT | CPLB_L1_AOW | CPLB_SUPV_WR | CPLB_USER_RD | CPLB_USER_WR | CPLB_VALID | ANOMALY_05000158_WORKAROUND) +#if defined(__ADSPBF60x__) +#define SDRAM_DGENERIC (PAGE_SIZE_16MB | CPLB_L1_CHBL | CPLB_WT | \ + CPLB_L1_AOW | CPLB_SUPV_WR | CPLB_USER_RD | \ + CPLB_USER_WR | CPLB_VALID | \ + ANOMALY_05000158_WORKAROUND) +#else +#define SDRAM_DGENERIC (PAGE_SIZE_4MB | CPLB_L1_CHBL | CPLB_WT | \ + CPLB_L1_AOW | CPLB_SUPV_WR | CPLB_USER_RD | \ + CPLB_USER_WR | CPLB_VALID | \ + ANOMALY_05000158_WORKAROUND) +#endif #define SDRAM_DNON_CHBL (PAGE_SIZE_4MB | CPLB_WT | CPLB_L1_AOW | CPLB_SUPV_WR | CPLB_USER_WR | CPLB_USER_RD | CPLB_VALID | ANOMALY_05000158_WORKAROUND) #define SDRAM_DKERNEL (PAGE_SIZE_4MB | CPLB_L1_CHBL | CPLB_WT | CPLB_L1_AOW | CPLB_USER_RD | CPLB_SUPV_WR | CPLB_USER_WR | CPLB_VALID | CPLB_LOCK | ANOMALY_05000158_WORKAROUND) #define L1_DMEMORY (PAGE_SIZE_4MB | CPLB_SUPV_WR | CPLB_USER_WR | CPLB_VALID | ANOMALY_05000158_WORKAROUND) diff --git a/arch/blackfin/lib/board.c b/arch/blackfin/lib/board.c index 098f685..288dc82 100644 --- a/arch/blackfin/lib/board.c +++ b/arch/blackfin/lib/board.c @@ -96,6 +96,13 @@ static void display_global_data(void)
#define CPLB_PAGE_SIZE (4 * 1024 * 1024) #define CPLB_PAGE_MASK (~(CPLB_PAGE_SIZE - 1)) +#if defined(__ADSPBF60x__) +#define CPLB_EX_PAGE_SIZE (16 * 1024 * 1024) +#define CPLB_EX_PAGE_MASK (~(CPLB_EX_PAGE_SIZE - 1)) +#else +#define CPLB_EX_PAGE_SIZE CPLB_PAGE_SIZE +#define CPLB_EX_PAGE_MASK CPLB_PAGE_MASK +#endif void init_cplbtables(void) { volatile uint32_t *ICPLB_ADDR, *ICPLB_DATA; @@ -127,6 +134,11 @@ void init_cplbtables(void) icplb_add(0xFFA00000, L1_IMEMORY); dcplb_add(0xFF800000, L1_DMEMORY); ++i; +#if defined(__ADSPBF60x__) + icplb_add(0x0, 0x0); + dcplb_add(CONFIG_SYS_FLASH_BASE, SDRAM_EBIU); + ++i; +#endif
if (CONFIG_MEM_SIZE) { uint32_t mbase = CONFIG_SYS_MONITOR_BASE; @@ -150,9 +162,11 @@ void init_cplbtables(void) } }
+#ifndef __ADSPBF60x__ icplb_add(0x20000000, SDRAM_INON_CHBL); dcplb_add(0x20000000, SDRAM_EBIU); ++i; +#endif
/* Add entries for the rest of external RAM up to the bootrom */ extern_memory = 0; @@ -167,10 +181,11 @@ void init_cplbtables(void) ++i; #endif
- while (i < 16 && extern_memory < (CONFIG_SYS_MONITOR_BASE & CPLB_PAGE_MASK)) { + while (i < 16 && extern_memory < + (CONFIG_SYS_MONITOR_BASE & CPLB_EX_PAGE_MASK)) { icplb_add(extern_memory, SDRAM_IGENERIC); dcplb_add(extern_memory, SDRAM_DGENERIC); - extern_memory += CPLB_PAGE_SIZE; + extern_memory += CPLB_EX_PAGE_SIZE; ++i; } while (i < 16) {
Signed-off-by: Bob Liu lliubbo@gmail.com Signed-off-by: Sonic Zhang sonic.zhang@analog.com --- arch/blackfin/cpu/gpio.c | 36 +++++-- arch/blackfin/include/asm/gpio.h | 2 +- arch/blackfin/include/asm/mach-bf609/gpio.h | 151 +++++++++++++++++++++++++++ 3 files changed, 181 insertions(+), 8 deletions(-) create mode 100644 arch/blackfin/include/asm/mach-bf609/gpio.h
diff --git a/arch/blackfin/cpu/gpio.c b/arch/blackfin/cpu/gpio.c index 5674d42..f684be5 100644 --- a/arch/blackfin/cpu/gpio.c +++ b/arch/blackfin/cpu/gpio.c @@ -66,6 +66,14 @@ static struct gpio_port_t * const gpio_array[] = { (struct gpio_port_t *)PORTH_FER, (struct gpio_port_t *)PORTI_FER, (struct gpio_port_t *)PORTJ_FER, +#elif defined(CONFIG_BF60x) + (struct gpio_port_t *)PORTA_FER, + (struct gpio_port_t *)PORTB_FER, + (struct gpio_port_t *)PORTC_FER, + (struct gpio_port_t *)PORTD_FER, + (struct gpio_port_t *)PORTE_FER, + (struct gpio_port_t *)PORTF_FER, + (struct gpio_port_t *)PORTG_FER, #else # error no gpio arrays defined #endif @@ -216,6 +224,12 @@ static void port_setup(unsigned gpio, unsigned short usage) else gpio_array[gpio_bank(gpio)]->port_fer |= gpio_bit(gpio); SSYNC(); +#elif defined(CONFIG_BF60x) + if (usage == GPIO_USAGE) + gpio_array[gpio_bank(gpio)]->port_fer_clear = gpio_bit(gpio); + else + gpio_array[gpio_bank(gpio)]->port_fer_set = gpio_bit(gpio); + SSYNC(); #endif }
@@ -290,7 +304,7 @@ static void portmux_setup(unsigned short per) } } } -#elif defined(CONFIG_BF54x) +#elif defined(CONFIG_BF54x) || defined(CONFIG_BF60x) inline void portmux_setup(unsigned short per) { u32 pmux; @@ -330,7 +344,7 @@ inline void portmux_setup(unsigned short per) # define portmux_setup(...) do { } while (0) #endif
-#ifndef CONFIG_BF54x +#if !defined(CONFIG_BF54x) && !defined(CONFIG_BF60x) /*********************************************************** * * FUNCTIONS: Blackfin General Purpose Ports Access Functions @@ -534,7 +548,7 @@ int peripheral_request(unsigned short per, const char *label) * be requested and used by several drivers */
-#ifdef CONFIG_BF54x +#if defined(CONFIG_BF54x) || defined(CONFIG_BF60x) if (!((per & P_MAYSHARE) && get_portmux(per) == P_FUNCT2MUX(per))) { #else if (!(per & P_MAYSHARE)) { @@ -651,7 +665,7 @@ int bfin_gpio_request(unsigned gpio, const char *label) gpio, get_label(gpio)); return -EBUSY; } -#ifndef CONFIG_BF54x +#if !defined(CONFIG_BF54x) && !defined(CONFIG_BF60x) else { /* Reset POLAR setting when acquiring a gpio for the first time */ set_gpio_polar(gpio, 0); } @@ -732,12 +746,16 @@ void bfin_special_gpio_free(unsigned gpio)
static inline void __bfin_gpio_direction_input(unsigned gpio) { -#ifdef CONFIG_BF54x +#if defined(CONFIG_BF54x) || defined(CONFIG_BF60x) gpio_array[gpio_bank(gpio)]->dir_clear = gpio_bit(gpio); #else gpio_array[gpio_bank(gpio)]->dir &= ~gpio_bit(gpio); #endif +#if defined(CONFIG_BF60x) + gpio_array[gpio_bank(gpio)]->inen_set = gpio_bit(gpio); +#else gpio_array[gpio_bank(gpio)]->inen |= gpio_bit(gpio); +#endif }
int bfin_gpio_direction_input(unsigned gpio) @@ -785,9 +803,13 @@ int bfin_gpio_direction_output(unsigned gpio, int value)
local_irq_save(flags);
+#if defined(CONFIG_BF60x) + gpio_array[gpio_bank(gpio)]->inen_clear = gpio_bit(gpio); +#else gpio_array[gpio_bank(gpio)]->inen &= ~gpio_bit(gpio); +#endif gpio_set_value(gpio, value); -#ifdef CONFIG_BF54x +#if defined(CONFIG_BF54x) || defined(CONFIG_BF60x) gpio_array[gpio_bank(gpio)]->dir_set = gpio_bit(gpio); #else gpio_array[gpio_bank(gpio)]->dir |= gpio_bit(gpio); @@ -801,7 +823,7 @@ int bfin_gpio_direction_output(unsigned gpio, int value)
int bfin_gpio_get_value(unsigned gpio) { -#ifdef CONFIG_BF54x +#if defined(CONFIG_BF54x) || defined(CONFIG_BF60x) return (1 & (gpio_array[gpio_bank(gpio)]->data >> gpio_sub_n(gpio))); #else unsigned long flags; diff --git a/arch/blackfin/include/asm/gpio.h b/arch/blackfin/include/asm/gpio.h index 224688f..05131b5 100644 --- a/arch/blackfin/include/asm/gpio.h +++ b/arch/blackfin/include/asm/gpio.h @@ -68,7 +68,7 @@
-#ifndef CONFIG_BF54x +#if !defined(CONFIG_BF54x) && !defined(CONFIG_BF60x) void set_gpio_dir(unsigned, unsigned short); void set_gpio_inen(unsigned, unsigned short); void set_gpio_polar(unsigned, unsigned short); diff --git a/arch/blackfin/include/asm/mach-bf609/gpio.h b/arch/blackfin/include/asm/mach-bf609/gpio.h new file mode 100644 index 0000000..e297bcc --- /dev/null +++ b/arch/blackfin/include/asm/mach-bf609/gpio.h @@ -0,0 +1,151 @@ +/* + * Copyright (C) 2008 Analog Devices Inc. + * Licensed under the GPL-2 or later. + */ + +#ifndef _MACH_GPIO_H_ +#define _MACH_GPIO_H_ + +#define MAX_BLACKFIN_GPIOS 112 + +#define GPIO_PA0 0 +#define GPIO_PA1 1 +#define GPIO_PA2 2 +#define GPIO_PA3 3 +#define GPIO_PA4 4 +#define GPIO_PA5 5 +#define GPIO_PA6 6 +#define GPIO_PA7 7 +#define GPIO_PA8 8 +#define GPIO_PA9 9 +#define GPIO_PA10 10 +#define GPIO_PA11 11 +#define GPIO_PA12 12 +#define GPIO_PA13 13 +#define GPIO_PA14 14 +#define GPIO_PA15 15 +#define GPIO_PB0 16 +#define GPIO_PB1 17 +#define GPIO_PB2 18 +#define GPIO_PB3 19 +#define GPIO_PB4 20 +#define GPIO_PB5 21 +#define GPIO_PB6 22 +#define GPIO_PB7 23 +#define GPIO_PB8 24 +#define GPIO_PB9 25 +#define GPIO_PB10 26 +#define GPIO_PB11 27 +#define GPIO_PB12 28 +#define GPIO_PB13 29 +#define GPIO_PB14 30 +#define GPIO_PB15 31 +#define GPIO_PC0 32 +#define GPIO_PC1 33 +#define GPIO_PC2 34 +#define GPIO_PC3 35 +#define GPIO_PC4 36 +#define GPIO_PC5 37 +#define GPIO_PC6 38 +#define GPIO_PC7 39 +#define GPIO_PC8 40 +#define GPIO_PC9 41 +#define GPIO_PC10 42 +#define GPIO_PC11 43 +#define GPIO_PC12 44 +#define GPIO_PC13 45 +#define GPIO_PC14 46 +#define GPIO_PC15 47 +#define GPIO_PD0 48 +#define GPIO_PD1 49 +#define GPIO_PD2 50 +#define GPIO_PD3 51 +#define GPIO_PD4 52 +#define GPIO_PD5 53 +#define GPIO_PD6 54 +#define GPIO_PD7 55 +#define GPIO_PD8 56 +#define GPIO_PD9 57 +#define GPIO_PD10 58 +#define GPIO_PD11 59 +#define GPIO_PD12 60 +#define GPIO_PD13 61 +#define GPIO_PD14 62 +#define GPIO_PD15 63 +#define GPIO_PE0 64 +#define GPIO_PE1 65 +#define GPIO_PE2 66 +#define GPIO_PE3 67 +#define GPIO_PE4 68 +#define GPIO_PE5 69 +#define GPIO_PE6 70 +#define GPIO_PE7 71 +#define GPIO_PE8 72 +#define GPIO_PE9 73 +#define GPIO_PE10 74 +#define GPIO_PE11 75 +#define GPIO_PE12 76 +#define GPIO_PE13 77 +#define GPIO_PE14 78 +#define GPIO_PE15 79 +#define GPIO_PF0 80 +#define GPIO_PF1 81 +#define GPIO_PF2 82 +#define GPIO_PF3 83 +#define GPIO_PF4 84 +#define GPIO_PF5 85 +#define GPIO_PF6 86 +#define GPIO_PF7 87 +#define GPIO_PF8 88 +#define GPIO_PF9 89 +#define GPIO_PF10 90 +#define GPIO_PF11 91 +#define GPIO_PF12 92 +#define GPIO_PF13 93 +#define GPIO_PF14 94 +#define GPIO_PF15 95 +#define GPIO_PG0 96 +#define GPIO_PG1 97 +#define GPIO_PG2 98 +#define GPIO_PG3 99 +#define GPIO_PG4 100 +#define GPIO_PG5 101 +#define GPIO_PG6 102 +#define GPIO_PG7 103 +#define GPIO_PG8 104 +#define GPIO_PG9 105 +#define GPIO_PG10 106 +#define GPIO_PG11 107 +#define GPIO_PG12 108 +#define GPIO_PG13 109 +#define GPIO_PG14 110 +#define GPIO_PG15 111 + +#ifndef __ASSEMBLY__ + +struct gpio_port_t { + unsigned long port_fer; + unsigned long port_fer_set; + unsigned long port_fer_clear; + unsigned long data; + unsigned long data_set; + unsigned long data_clear; + unsigned long dir; + unsigned long dir_set; + unsigned long dir_clear; + unsigned long inen; + unsigned long inen_set; + unsigned long inen_clear; + unsigned long port_mux; + unsigned long toggle; + unsigned long polar; + unsigned long polar_set; + unsigned long polar_clear; + unsigned long lock; + unsigned long spare; + unsigned long revid; +}; + +#endif + +#endif /* _MACH_GPIO_H_ */
Board and config header files for bf609-ezkit support.
Fix review issues from Wolfgang: 1) Fix all checkpatch issues except for cpu name bf609-0.0. It is used as the link flags and is not an error. 2) Remove the values for variables in bf609 config headers whose values are useless.
Signed-off-by: Bob Liu lliubbo@gmail.com Signed-off-by: Sonic Zhang sonic.zhang@analog.com --- MAINTAINERS | 3 +- board/bf609-ezkit/Makefile | 55 +++++++++++++ board/bf609-ezkit/bf609-ezkit.c | 67 +++++++++++++++ boards.cfg | 1 + include/configs/bf609-ezkit.h | 161 +++++++++++++++++++++++++++++++++++++ include/configs/bfin_adi_common.h | 12 ++-- 6 files changed, 292 insertions(+), 7 deletions(-) create mode 100644 board/bf609-ezkit/Makefile create mode 100644 board/bf609-ezkit/bf609-ezkit.c create mode 100644 include/configs/bf609-ezkit.h
diff --git a/MAINTAINERS b/MAINTAINERS index 28c052d..76368cf 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -1214,7 +1214,7 @@ Yoshihiro Shimoda yoshihiro.shimoda.uh@renesas.com # Board CPU # #########################################################################
-Mike Frysinger vapier@gentoo.org +Sonic Zhang sonic.adi@gmail.com Blackfin Team u-boot-devel@blackfin.uclinux.org
BF506F-EZKIT BF506 @@ -1231,6 +1231,7 @@ Blackfin Team u-boot-devel@blackfin.uclinux.org BF538F-EZKIT BF538 BF548-EZKIT BF548 BF561-EZKIT BF561 + BF609-EZKIT BF609
M.Hasewinkel (MHA) info@ssv-embedded.de
diff --git a/board/bf609-ezkit/Makefile b/board/bf609-ezkit/Makefile new file mode 100644 index 0000000..0bb8fe6 --- /dev/null +++ b/board/bf609-ezkit/Makefile @@ -0,0 +1,55 @@ +# +# U-boot - Makefile +# +# Copyright (c) 2005-2008 Analog Device Inc. +# +# (C) Copyright 2000-2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +COBJS-y := $(BOARD).o +COBJS-$(CONFIG_BFIN_SOFT_SWITCH) += soft_switch.o + +SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS-y)) +SOBJS := $(addprefix $(obj),$(SOBJS-y)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(call cmd_link_o_target, $(OBJS) $(SOBJS)) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak $(obj).depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/bf609-ezkit/bf609-ezkit.c b/board/bf609-ezkit/bf609-ezkit.c new file mode 100644 index 0000000..0388226 --- /dev/null +++ b/board/bf609-ezkit/bf609-ezkit.c @@ -0,0 +1,67 @@ +/* + * U-boot - main board file + * + * Copyright (c) 2008-2011 Analog Devices Inc. + * + * Licensed under the GPL-2 or later. + */ + +#include <common.h> +#include <netdev.h> +#include <asm/blackfin.h> +#include <asm/io.h> +#include <asm/portmux.h> +#include "soft_switch.h" + +int checkboard(void) +{ + printf("Board: ADI BF609 EZ-Kit board\n"); + printf(" Support: http://blackfin.uclinux.org/%5Cn"); + return 0; +} + +int board_early_init_f(void) +{ + static const unsigned short pins[] = { + P_A3, P_A4, P_A5, P_A6, P_A7, P_A8, P_A9, P_A10, P_A11, P_A12, + P_A13, P_A14, P_A15, P_A16, P_A17, P_A18, P_A19, P_A20, P_A21, + P_A22, P_A23, P_A24, P_A25, P_NORCK, 0, + }; + peripheral_request_list(pins, "smc0"); + + return 0; +} + +#ifdef CONFIG_DESIGNWARE_ETH +int board_eth_init(bd_t *bis) +{ + int ret = 0; + + if (CONFIG_DW_PORTS & 1) { + static const unsigned short pins[] = P_RMII0; + if (!peripheral_request_list(pins, "emac0")) + ret += designware_initialize(0, EMAC0_MACCFG, 1, 0); + } + if (CONFIG_DW_PORTS & 2) { + static const unsigned short pins[] = P_RMII1; + if (!peripheral_request_list(pins, "emac1")) + ret += designware_initialize(1, EMAC1_MACCFG, 1, 0); + } + + return ret; +} +#endif + +#ifdef CONFIG_BFIN_SDH +int board_mmc_init(bd_t *bis) +{ + return bfin_mmc_init(bis); +} +#endif + +/* miscellaneous platform dependent initialisations */ +int misc_init_r(void) +{ + printf("other init\n"); + return setup_board_switches(); +} diff --git a/boards.cfg b/boards.cfg index e4b0d44..11060c4 100644 --- a/boards.cfg +++ b/boards.cfg @@ -356,6 +356,7 @@ bf538f-ezkit blackfin blackfin bf548-ezkit blackfin blackfin bf561-acvilon blackfin blackfin bf561-ezkit blackfin blackfin +bf609-ezkit blackfin blackfin blackstamp blackfin blackfin blackvme blackfin blackfin br4 blackfin blackfin diff --git a/include/configs/bf609-ezkit.h b/include/configs/bf609-ezkit.h new file mode 100644 index 0000000..6dffab8 --- /dev/null +++ b/include/configs/bf609-ezkit.h @@ -0,0 +1,161 @@ +/* + * U-boot - Configuration file for BF609 EZ-Kit board + */ + +#ifndef __CONFIG_BF609_EZKIT_H__ +#define __CONFIG_BF609_EZKIT_H__ + +#include <asm/config-pre.h> + +/* + * Processor Settings + */ +#define CONFIG_BFIN_CPU bf609-0.0 +#define CONFIG_BFIN_BOOT_MODE BFIN_BOOT_PARA + + +/* For ez-board version 1.0, else undef this */ +#define CONFIG_BFIN_BOARD_VERSION_1_0 + +/* + * Clock Settings + * CCLK = (CLKIN * VCO_MULT) / CCLK_DIV + * SCLK = (CLKIN * VCO_MULT) / SYSCLK_DIV + * SCLK0 = SCLK / SCLK0_DIV + * SCLK1 = SCLK / SCLK1_DIV + */ +/* CONFIG_CLKIN_HZ is any value in Hz */ +#define CONFIG_CLKIN_HZ (25000000) +/* CLKIN_HALF controls the DF bit in PLL_CTL 0 = CLKIN */ +/* 1 = CLKIN / 2 */ +#define CONFIG_CLKIN_HALF (0) + +/* VCO_MULT controls the MSEL (multiplier) bits in PLL_CTL */ +/* Values can range from 0-127 (where 0 means 128) */ +#define CONFIG_VCO_MULT (20) + +/* CCLK_DIV controls the core clock divider */ +/* Values can range from 0-31 (where 0 means 32) */ +#define CONFIG_CCLK_DIV (1) +/* SCLK_DIV controls the system clock divider */ +/* Values can range from 0-31 (where 0 means 32) */ +#define CONFIG_SCLK_DIV (4) +/* Values can range from 0-7 (where 0 means 8) */ +#define CONFIG_SCLK0_DIV (1) +#define CONFIG_SCLK1_DIV (1) +/* DCLK_DIV controls the DDR clock divider */ +/* Values can range from 0-31 (where 0 means 32) */ +#define CONFIG_DCLK_DIV (2) +/* OCLK_DIV controls the output clock divider */ +/* Values can range from 0-127 (where 0 means 128) */ +#define CONFIG_OCLK_DIV (16) + +/* + * Memory Settings + */ +#define CONFIG_MEM_SIZE 128 + +#define CONFIG_SMC_GCTL_VAL 0x00000010 +#define CONFIG_SMC_B0CTL_VAL 0x01007011 +#define CONFIG_SMC_B0TIM_VAL 0x08170977 +#define CONFIG_SMC_B0ETIM_VAL 0x00092231 + +#define CONFIG_SYS_MONITOR_LEN (768 * 1024) +#define CONFIG_SYS_MALLOC_LEN (512 * 1024) + +/* + * Network Settings + */ +#define ADI_CMDS_NETWORK +#define CONFIG_NETCONSOLE +#define CONFIG_NET_MULTI +#define CONFIG_HOSTNAME "bf609-ezkit" +#define CONFIG_DESIGNWARE_ETH +#define CONFIG_DW_PORTS 1 +#define CONFIG_DW_AUTONEG +#define CONFIG_DW_ALTDESCRIPTOR +#define CONFIG_CMD_NET +#define CONFIG_CMD_MII +#define CONFIG_MII + +/* i2c Settings */ +#define CONFIG_BFIN_TWI_I2C +#define CONFIG_HARD_I2C + +/* + * Flash Settings + */ +#undef CONFIG_CMD_IMLS +#undef CONFIG_CMD_JFFS2 +#define CONFIG_SYS_FLASH_CFI_WIDTH 2 +#define CONFIG_FLASH_CFI_DRIVER +#define CONFIG_SYS_FLASH_BASE 0xb0000000 +#define CONFIG_SYS_FLASH_CFI +#define CONFIG_SYS_FLASH_PROTECTION +#define CONFIG_SYS_MAX_FLASH_BANKS 1 +#define CONFIG_SYS_MAX_FLASH_SECT 131 +#define CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS + +/* + * SPI Settings + */ +#define CONFIG_BFIN_SPI6XX +#define CONFIG_ENV_SPI_MAX_HZ 25000000 +#define CONFIG_SF_DEFAULT_SPEED 25000000 +#define CONFIG_SPI_FLASH +#define CONFIG_SPI_FLASH_ALL + +/* + * Env Storage Settings + */ +#if (CONFIG_BFIN_BOOT_MODE == BFIN_BOOT_SPI_MASTER) +#define CONFIG_ENV_IS_IN_SPI_FLASH +#define CONFIG_ENV_OFFSET 0x10000 +#define CONFIG_ENV_SIZE 0x2000 +#define CONFIG_ENV_SECT_SIZE 0x10000 +#define CONFIG_ENV_IS_EMBEDDED_IN_LDR +#elif (CONFIG_BFIN_BOOT_MODE == BFIN_BOOT_NAND) +#define CONFIG_ENV_IS_IN_NAND +#define CONFIG_ENV_OFFSET 0x60000 +#define CONFIG_ENV_SIZE 0x20000 +#else +#define CONFIG_ENV_IS_IN_FLASH +#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + CONFIG_ENV_OFFSET) +#define CONFIG_ENV_OFFSET 0x8000 +#define CONFIG_ENV_SIZE 0x8000 +#define CONFIG_ENV_SECT_SIZE 0x8000 +#define CONFIG_ENV_IS_EMBEDDED_IN_LDR +#endif + +#define FLASHBOOT_ENV_SETTINGS "flashboot=bootm 0xB0100000\0" + +/* + * SDH Settings + */ +#define CONFIG_GENERIC_MMC +#define CONFIG_MMC +#define CONFIG_BFIN_SDH + +/* + * Misc Settings + */ +#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_UART_CONSOLE 0 + +#define CONFIG_CMD_MEMORY + +#define CONFIG_SYS_MEMTEST_END (CONFIG_STACKBASE - 20*1024*1024 + 4) +#define CONFIG_BFIN_SOFT_SWITCH + +#if 0 +#define CONFIG_UART_MEM 1024 +#undef CONFIG_UART_CONSOLE +#undef CONFIG_JTAG_CONSOLE +#undef CONFIG_UART_CONSOLE_IS_JTAG +#endif + +/* + * Pull in common ADI header for remaining command/environment setup + */ +#include <configs/bfin_adi_common.h> +#endif diff --git a/include/configs/bfin_adi_common.h b/include/configs/bfin_adi_common.h index ccdec0d..ada03f0 100644 --- a/include/configs/bfin_adi_common.h +++ b/include/configs/bfin_adi_common.h @@ -10,7 +10,7 @@ */ #ifndef _CONFIG_CMD_DEFAULT_H # include <config_cmd_default.h> -# if ADI_CMDS_NETWORK +# ifdef ADI_CMDS_NETWORK # define CONFIG_CMD_DHCP # define CONFIG_BOOTP_SUBNETMASK # define CONFIG_BOOTP_GATEWAY @@ -58,7 +58,7 @@ # endif # ifdef CONFIG_RTC_BFIN # define CONFIG_CMD_DATE -# if ADI_CMDS_NETWORK +# ifdef ADI_CMDS_NETWORK # define CONFIG_CMD_SNTP # endif # endif @@ -193,10 +193,10 @@ "nand erase 0 0x40000;" \ "nand write $(loadaddr) 0 0x40000" # else -# define UBOOT_ENV_UPDATE \ - "protect off 0x20000000 +$(filesize);" \ - "erase 0x20000000 +$(filesize);" \ - "cp.b $(loadaddr) 0x20000000 $(filesize)" +# define UBOOT_ENV_UPDATE \ + "protect off " MK_STR(CONFIG_SYS_FLASH_BASE) " +$(filesize);" \ + "erase " MK_STR(CONFIG_SYS_FLASH_BASE) " +$(filesize);" \ + "cp.b $(loadaddr)" MK_STR(CONFIG_SYS_FLASH_BASE) " $(filesize)" # endif # ifdef CONFIG_NETCONSOLE # define NETCONSOLE_ENV \
Add rsi/sdh support for bf60x.
Fix review issues from Wolfgang: 1) Fix all checkpatch issues. 2) Does't change funtion sdh_setup_data() to return void. It returns 0 at the end of this function. But, it may return UNUSABLE_ERR(-17) at the beginning if the data flags match MMC_DATA_WRITE.
Signed-off-by: Sonic Zhang sonic.zhang@analog.com Signed-off-by: Bob Liu lliubbo@gmail.com --- arch/blackfin/include/asm/mach-common/bits/sdh.h | 38 +++++++++++- drivers/mmc/bfin_sdh.c | 68 ++++++++++++++++----- 2 files changed, 88 insertions(+), 18 deletions(-)
diff --git a/arch/blackfin/include/asm/mach-common/bits/sdh.h b/arch/blackfin/include/asm/mach-common/bits/sdh.h index 8c5dd33..1c60d4b 100644 --- a/arch/blackfin/include/asm/mach-common/bits/sdh.h +++ b/arch/blackfin/include/asm/mach-common/bits/sdh.h @@ -12,18 +12,35 @@ #define CMD_INT_E 0x100 /* Command Interrupt */ #define CMD_PEND_E 0x200 /* Command Pending */ #define CMD_E 0x400 /* Command Enable */ +#ifdef RSI_BLKSZ +#define CMD_CRC_CHECK_D 0x800 /* CRC Check is disabled */ +#define CMD_DATA0_BUSY 0x1000 /* Check Busy State on DATA0 */ +#endif
/* Bit masks for SDH_PWR_CTL */ +#ifndef RSI_BLKSZ #define PWR_ON 0x3 /* Power On */ #define SD_CMD_OD 0x40 /* Open Drain Output */ #define ROD_CTL 0x80 /* Rod Control */ +#endif
/* Bit masks for SDH_CLK_CTL */ #define CLKDIV 0xff /* MC_CLK Divisor */ #define CLK_E 0x100 /* MC_CLK Bus Clock Enable */ #define PWR_SV_E 0x200 /* Power Save Enable */ #define CLKDIV_BYPASS 0x400 /* Bypass Divisor */ -#define WIDE_BUS 0x800 /* Wide Bus Mode Enable */ +#define BUS_MODE_MASK 0x1800 /* Bus Mode Mask */ +#define STD_BUS_1 0x000 /* Standard Bus 1 bit mode */ +#define WIDE_BUS_4 0x800 /* Wide Bus 4 bit mode */ +#define BYTE_BUS_8 0x1000 /* Byte Bus 8 bit mode */ +#ifdef RSI_BLKSZ +#define CARD_TYPE_MASK 0xe000 /* Card type mask */ +#define CARD_TYPE_OFFSET 13 /* Card type offset */ +#define CARD_TYPE_SDIO 0 +#define CARD_TYPE_eMMC 1 +#define CARD_TYPE_SD 2 +#define CARD_TYPE_CEATA 3 +#endif
/* Bit masks for SDH_RESP_CMD */ #define RESP_CMD 0x3f /* Response Command */ @@ -33,7 +50,13 @@ #define DTX_DIR 0x2 /* Data Transfer Direction */ #define DTX_MODE 0x4 /* Data Transfer Mode */ #define DTX_DMA_E 0x8 /* Data Transfer DMA Enable */ +#ifndef RSI_BLKSZ #define DTX_BLK_LGTH 0xf0 /* Data Transfer Block Length */ +#else + +/* Bit masks for SDH_BLK_SIZE */ +#define DTX_BLK_LGTH 0x1fff /* Data Transfer Block Length */ +#endif
/* Bit masks for SDH_STATUS */ #define CMD_CRC_FAIL 0x1 /* CMD CRC Fail */ @@ -102,10 +125,13 @@ /* Bit masks for SDH_E_STATUS */ #define SDIO_INT_DET 0x2 /* SDIO Int Detected */ #define SD_CARD_DET 0x10 /* SD Card Detect */ +#define SD_CARD_BUSYMODE 0x80000000 /* Card is in Busy mode */ +#define SD_CARD_SLPMODE 0x40000000 /* Card in Sleep Mode */ +#define SD_CARD_READY 0x00020000 /* Card Ready */
/* Bit masks for SDH_E_MASK */ #define SDIO_MSK 0x2 /* Mask SDIO Int Detected */ -#define SCD_MSK 0x40 /* Mask Card Detect */ +#define SCD_MSK 0x10 /* Mask Card Detect */
/* Bit masks for SDH_CFG */ #define CLKS_EN 0x1 /* Clocks Enable */ @@ -114,7 +140,15 @@ #define SD_RST 0x10 /* SDMMC Reset */ #define PUP_SDDAT 0x20 /* Pull-up SD_DAT */ #define PUP_SDDAT3 0x40 /* Pull-up SD_DAT3 */ +#ifndef RSI_BLKSZ #define PD_SDDAT3 0x80 /* Pull-down SD_DAT3 */ +#else +#define PWR_ON 0x600 /* Power On */ +#define SD_CMD_OD 0x800 /* Open Drain Output */ +#define BOOT_EN 0x1000 /* Boot Enable */ +#define BOOT_MODE 0x2000 /* Alternate Boot Mode */ +#define BOOT_ACK_EN 0x4000 /* Boot ACK is expected */ +#endif
/* Bit masks for SDH_RD_WAIT_EN */ #define RWR 0x1 /* Read Wait Request */ diff --git a/drivers/mmc/bfin_sdh.c b/drivers/mmc/bfin_sdh.c index 8d59d46..f22429a 100644 --- a/drivers/mmc/bfin_sdh.c +++ b/drivers/mmc/bfin_sdh.c @@ -19,9 +19,7 @@ #include <asm/mach-common/bits/sdh.h> #include <asm/mach-common/bits/dma.h>
-#if defined(__ADSPBF50x__) || defined(__ADSPBF51x__) -# define bfin_read_SDH_PWR_CTL bfin_read_RSI_PWR_CONTROL -# define bfin_write_SDH_PWR_CTL bfin_write_RSI_PWR_CONTROL +#if defined(__ADSPBF50x__) || defined(__ADSPBF51x__) || defined(__ADSPBF60x__) # define bfin_read_SDH_CLK_CTL bfin_read_RSI_CLK_CONTROL # define bfin_write_SDH_CLK_CTL bfin_write_RSI_CLK_CONTROL # define bfin_write_SDH_ARGUMENT bfin_write_RSI_ARGUMENT @@ -38,10 +36,21 @@ # define bfin_write_SDH_STATUS_CLR bfin_write_RSI_STATUSCL # define bfin_read_SDH_CFG bfin_read_RSI_CONFIG # define bfin_write_SDH_CFG bfin_write_RSI_CONFIG +# if defined(__ADSPBF60x__) +# define bfin_read_SDH_BLK_SIZE bfin_read_RSI_BLKSZ +# define bfin_write_SDH_BLK_SIZE bfin_write_RSI_BLKSZ +# define bfin_write_DMA_START_ADDR bfin_write_DMA10_START_ADDR +# define bfin_write_DMA_X_COUNT bfin_write_DMA10_X_COUNT +# define bfin_write_DMA_X_MODIFY bfin_write_DMA10_X_MODIFY +# define bfin_write_DMA_CONFIG bfin_write_DMA10_CONFIG +# else +# define bfin_read_SDH_PWR_CTL bfin_read_RSI_PWR_CONTROL +# define bfin_write_SDH_PWR_CTL bfin_write_RSI_PWR_CONTROL # define bfin_write_DMA_START_ADDR bfin_write_DMA4_START_ADDR # define bfin_write_DMA_X_COUNT bfin_write_DMA4_X_COUNT # define bfin_write_DMA_X_MODIFY bfin_write_DMA4_X_MODIFY # define bfin_write_DMA_CONFIG bfin_write_DMA4_CONFIG +# endif # define PORTMUX_PINS \ { P_RSI_DATA0, P_RSI_DATA1, P_RSI_DATA2, P_RSI_DATA3, P_RSI_CMD, P_RSI_CLK, 0 } #elif defined(__ADSPBF54x__) @@ -70,6 +79,9 @@ sdh_send_cmd(struct mmc *mmc, struct mmc_cmd *mmc_cmd) sdh_cmd |= CMD_RSP; if (flags & MMC_RSP_136) sdh_cmd |= CMD_L_RSP; +#ifdef RSI_BLKSZ + sdh_cmd |= CMD_DATA0_BUSY; +#endif
bfin_write_SDH_ARGUMENT(arg); bfin_write_SDH_COMMAND(sdh_cmd); @@ -104,6 +116,12 @@ sdh_send_cmd(struct mmc *mmc, struct mmc_cmd *mmc_cmd)
bfin_write_SDH_STATUS_CLR(CMD_SENT_STAT | CMD_RESP_END_STAT | CMD_TIMEOUT_STAT | CMD_CRC_FAIL_STAT); +#ifdef RSI_BLKSZ + /* wait till card ready */ + while (!(bfin_read_RSI_ESTAT() & SD_CARD_READY)) + ; + bfin_write_RSI_ESTAT(SD_CARD_READY); +#endif
return ret; } @@ -113,16 +131,19 @@ static int sdh_setup_data(struct mmc *mmc, struct mmc_data *data) { u16 data_ctl = 0; u16 dma_cfg = 0; - int ret = 0; unsigned long data_size = data->blocksize * data->blocks;
/* Don't support write yet. */ if (data->flags & MMC_DATA_WRITE) return UNUSABLE_ERR; +#ifndef RSI_BLKSZ data_ctl |= ((ffs(data_size) - 1) << 4); +#else + bfin_write_SDH_BLK_SIZE(data_size); +#endif data_ctl |= DTX_DIR; bfin_write_SDH_DATA_CTL(data_ctl); - dma_cfg = WDSIZE_32 | RESTART | WNR | DMAEN; + dma_cfg = WDSIZE_32 | PSIZE_32 | RESTART | WNR | DMAEN;
bfin_write_SDH_DATA_TIMER(-1);
@@ -137,7 +158,7 @@ static int sdh_setup_data(struct mmc *mmc, struct mmc_data *data) /* kick off transfer */ bfin_write_SDH_DATA_CTL(bfin_read_SDH_DATA_CTL() | DTX_DMA_E | DTX_E);
- return ret; + return 0; }
@@ -147,13 +168,23 @@ static int bfin_sdh_request(struct mmc *mmc, struct mmc_cmd *cmd, u32 status; int ret = 0;
+ if (data) { + ret = sdh_setup_data(mmc, data); + if (ret) + return ret; + } + ret = sdh_send_cmd(mmc, cmd); if (ret) { + bfin_write_SDH_COMMAND(0); + bfin_write_DMA_CONFIG(0); + bfin_write_SDH_DATA_CTL(0); + SSYNC(); printf("sending CMD%d failed\n", cmd->cmdidx); return ret; } + if (data) { - ret = sdh_setup_data(mmc, data); do { udelay(1); status = bfin_read_SDH_STATUS(); @@ -208,10 +239,12 @@ static void bfin_sdh_set_ios(struct mmc *mmc)
if (mmc->bus_width == 4) { cfg = bfin_read_SDH_CFG(); - cfg &= ~0x80; - cfg |= 0x40; +#ifndef RSI_BLKSZ + cfg &= ~PD_SDDAT3; +#endif + cfg |= PUP_SDDAT3; bfin_write_SDH_CFG(cfg); - clk_ctl |= WIDE_BUS; + clk_ctl |= WIDE_BUS_4; } bfin_write_SDH_CLK_CTL(clk_ctl); sdh_set_clk(mmc->clock); @@ -220,20 +253,23 @@ static void bfin_sdh_set_ios(struct mmc *mmc) static int bfin_sdh_init(struct mmc *mmc) { const unsigned short pins[] = PORTMUX_PINS; - u16 pwr_ctl = 0; + int ret;
/* Initialize sdh controller */ - peripheral_request_list(pins, "bfin_sdh"); + ret = peripheral_request_list(pins, "bfin_sdh"); + if (ret < 0) + return ret; #if defined(__ADSPBF54x__) bfin_write_DMAC1_PERIMUX(bfin_read_DMAC1_PERIMUX() | 0x1); #endif bfin_write_SDH_CFG(bfin_read_SDH_CFG() | CLKS_EN); /* Disable card detect pin */ bfin_write_SDH_CFG((bfin_read_SDH_CFG() & 0x1F) | 0x60); - - pwr_ctl |= ROD_CTL; - pwr_ctl |= PWR_ON; - bfin_write_SDH_PWR_CTL(pwr_ctl); +#ifndef RSI_BLKSZ + bfin_write_SDH_PWR_CTL(PWR_ON | ROD_CTL); +#else + bfin_write_SDH_CFG(bfin_read_SDH_CFG() | PWR_ON); +#endif return 0; }
Spi driver for bf60x is different from old one, so implement a new driver for it.
Fix all checkpatch issues memtioned by Wolfgang.
Signed-off-by: Scott Jiang scott.jiang.linux@gmail.com Signed-off-by: Sonic Zhang sonic.zhang@analog.com Signed-off-by: Bob Liu lliubbo@gmail.com --- .../blackfin/include/asm/mach-common/bits/spi6xx.h | 240 +++++++++++++++ drivers/spi/Makefile | 1 + drivers/spi/bfin_spi6xx.c | 308 ++++++++++++++++++++ 3 files changed, 549 insertions(+), 0 deletions(-) create mode 100644 arch/blackfin/include/asm/mach-common/bits/spi6xx.h create mode 100644 drivers/spi/bfin_spi6xx.c
diff --git a/arch/blackfin/include/asm/mach-common/bits/spi6xx.h b/arch/blackfin/include/asm/mach-common/bits/spi6xx.h new file mode 100644 index 0000000..3368712 --- /dev/null +++ b/arch/blackfin/include/asm/mach-common/bits/spi6xx.h @@ -0,0 +1,240 @@ +/* + * Analog Devices bfin_spi3 controller driver + * + * Copyright (c) 2011 Analog Devices Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +#ifndef _SPI_CHANNEL_H_ +#define _SPI_CHANNEL_H_ + +#include <linux/types.h> + +/* SPI_CONTROL */ +#define SPI_CTL_EN 0x00000001 /* Enable */ +#define SPI_CTL_MSTR 0x00000002 /* Master/Slave */ +#define SPI_CTL_PSSE 0x00000004 /* controls modf error in master mode */ +#define SPI_CTL_ODM 0x00000008 /* Open Drain Mode */ +#define SPI_CTL_CPHA 0x00000010 /* Clock Phase */ +#define SPI_CTL_CPOL 0x00000020 /* Clock Polarity */ +#define SPI_CTL_ASSEL 0x00000040 /* Slave Select Pin Control */ +#define SPI_CTL_SELST 0x00000080 /* Slave Select Polarity in transfers */ +#define SPI_CTL_EMISO 0x00000100 /*Enable MISO */ +#define SPI_CTL_SIZE 0x00000600 /*Word Transfer Size */ +#define SPI_CTL_SIZE08 0x00000000 /*SIZE: 8 bits */ +#define SPI_CTL_SIZE16 0x00000200 /*SIZE: 16 bits */ +#define SPI_CTL_SIZE32 0x00000400 /*SIZE: 32 bits */ +#define SPI_CTL_LSBF 0x00001000 /*LSB First */ +#define SPI_CTL_FCEN 0x00002000 /*Flow-Control Enable */ +#define SPI_CTL_FCCH 0x00004000 /*Flow-Control Channel Selection */ +#define SPI_CTL_FCPL 0x00008000 /*Flow-Control Polarity */ +#define SPI_CTL_FCWM 0x00030000 /*Flow-Control Water-Mark */ +#define SPI_CTL_FIFO0 0x00000000 /*FCWM: Tx empty or Rx Full */ +#define SPI_CTL_FIFO1 0x00010000 /*FCWM: Tx empty or Rx full (>=75%) */ +#define SPI_CTL_FIFO2 0x00020000 /*FCWM: Tx empty or Rx full (>=50%) */ +#define SPI_CTL_FMODE 0x00040000 /*Fast-mode Enable */ +#define SPI_CTL_MIOM 0x00300000 /*Multiple I/O Mode */ +#define SPI_CTL_MIO_DIS 0x00000000 /*MIOM: Disable */ +#define SPI_CTL_MIO_DUAL 0x00100000 /*MIOM: Enable DIOM (Dual I/O Mode) */ +#define SPI_CTL_MIO_QUAD 0x00200000 /*MIOM: Enable QUAD (Quad SPI Mode) */ +#define SPI_CTL_SOSI 0x00400000 /*Start on MOSI */ +/* SPI_RX_CONTROL */ +#define SPI_RXCTL_REN 0x00000001 /*Receive Channel Enable */ +#define SPI_RXCTL_RTI 0x00000004 /*Receive Transfer Initiate */ +#define SPI_RXCTL_RWCEN 0x00000008 /*Receive Word Counter Enable */ +#define SPI_RXCTL_RDR 0x00000070 /*Receive Data Request */ +#define SPI_RXCTL_RDR_DIS 0x00000000 /*RDR: Disabled */ +#define SPI_RXCTL_RDR_NE 0x00000010 /*RDR: RFIFO not empty */ +#define SPI_RXCTL_RDR_25 0x00000020 /*RDR: RFIFO 25% full */ +#define SPI_RXCTL_RDR_50 0x00000030 /*RDR: RFIFO 50% full */ +#define SPI_RXCTL_RDR_75 0x00000040 /*RDR: RFIFO 75% full */ +#define SPI_RXCTL_RDR_FULL 0x00000050 /*RDR: RFIFO full */ +#define SPI_RXCTL_RDO 0x00000100 /*Receive Data Over-Run */ +#define SPI_RXCTL_RRWM 0x00003000 /*FIFO Regular Water-Mark */ +#define SPI_RXCTL_RWM_0 0x00000000 /*RRWM: RFIFO Empty */ +#define SPI_RXCTL_RWM_25 0x00001000 /*RRWM: RFIFO 25% full */ +#define SPI_RXCTL_RWM_50 0x00002000 /*RRWM: RFIFO 50% full */ +#define SPI_RXCTL_RWM_75 0x00003000 /*RRWM: RFIFO 75% full */ +#define SPI_RXCTL_RUWM 0x00070000 /*FIFO Urgent Water-Mark */ +#define SPI_RXCTL_UWM_DIS 0x00000000 /*RUWM: Disabled */ +#define SPI_RXCTL_UWM_25 0x00010000 /*RUWM: RFIFO 25% full */ +#define SPI_RXCTL_UWM_50 0x00020000 /*RUWM: RFIFO 50% full */ +#define SPI_RXCTL_UWM_75 0x00030000 /*RUWM: RFIFO 75% full */ +#define SPI_RXCTL_UWM_FULL 0x00040000 /*RUWM: RFIFO full */ +/* SPI_TX_CONTROL */ +#define SPI_TXCTL_TEN 0x00000001 /*Transmit Channel Enable */ +#define SPI_TXCTL_TTI 0x00000004 /*Transmit Transfer Initiate */ +#define SPI_TXCTL_TWCEN 0x00000008 /*Transmit Word Counter Enable */ +#define SPI_TXCTL_TDR 0x00000070 /*Transmit Data Request */ +#define SPI_TXCTL_TDR_DIS 0x00000000 /*TDR: Disabled */ +#define SPI_TXCTL_TDR_NF 0x00000010 /*TDR: TFIFO not full */ +#define SPI_TXCTL_TDR_25 0x00000020 /*TDR: TFIFO 25% empty */ +#define SPI_TXCTL_TDR_50 0x00000030 /*TDR: TFIFO 50% empty */ +#define SPI_TXCTL_TDR_75 0x00000040 /*TDR: TFIFO 75% empty */ +#define SPI_TXCTL_TDR_EMPTY 0x00000050 /*TDR: TFIFO empty */ +#define SPI_TXCTL_TDU 0x00000100 /*Transmit Data Under-Run */ +#define SPI_TXCTL_TRWM 0x00003000 /*FIFO Regular Water-Mark */ +#define SPI_TXCTL_RWM_FULL 0x00000000 /*TRWM: TFIFO full */ +#define SPI_TXCTL_RWM_25 0x00001000 /*TRWM: TFIFO 25% empty */ +#define SPI_TXCTL_RWM_50 0x00002000 /*TRWM: TFIFO 50% empty */ +#define SPI_TXCTL_RWM_75 0x00003000 /*TRWM: TFIFO 75% empty */ +#define SPI_TXCTL_TUWM 0x00070000 /*FIFO Urgent Water-Mark */ +#define SPI_TXCTL_UWM_DIS 0x00000000 /*TUWM: Disabled */ +#define SPI_TXCTL_UWM_25 0x00010000 /*TUWM: TFIFO 25% empty */ +#define SPI_TXCTL_UWM_50 0x00020000 /*TUWM: TFIFO 50% empty */ +#define SPI_TXCTL_UWM_75 0x00030000 /*TUWM: TFIFO 75% empty */ +#define SPI_TXCTL_UWM_EMPTY 0x00040000 /*TUWM: TFIFO empty */ +/* SPI_CLOCK */ +#define SPI_CLK_BAUD 0x0000FFFF /*Baud Rate */ +/* SPI_DELAY */ +#define SPI_DLY_STOP 0x000000FF /*Transfer delay time */ +#define SPI_DLY_LEADX 0x00000100 /*Extended (1 SCK) LEAD Control */ +#define SPI_DLY_LAGX 0x00000200 /*Extended (1 SCK) LAG control */ +/* SPI_SSEL */ +#define SPI_SLVSEL_SSE1 0x00000002 /*SPISSEL1 Enable */ +#define SPI_SLVSEL_SSE2 0x00000004 /*SPISSEL2 Enable */ +#define SPI_SLVSEL_SSE3 0x00000008 /*SPISSEL3 Enable */ +#define SPI_SLVSEL_SSE4 0x00000010 /*SPISSEL4 Enable */ +#define SPI_SLVSEL_SSE5 0x00000020 /*SPISSEL5 Enable */ +#define SPI_SLVSEL_SSE6 0x00000040 /*SPISSEL6 Enable */ +#define SPI_SLVSEL_SSE7 0x00000080 /*SPISSEL7 Enable */ +#define SPI_SLVSEL_SSEL1 0x00000200 /*SPISSEL1 Value */ +#define SPI_SLVSEL_SSEL2 0x00000400 /*SPISSEL2 Value */ +#define SPI_SLVSEL_SSEL3 0x00000800 /*SPISSEL3 Value */ +#define SPI_SLVSEL_SSEL4 0x00001000 /*SPISSEL4 Value */ +#define SPI_SLVSEL_SSEL5 0x00002000 /*SPISSEL5 Value */ +#define SPI_SLVSEL_SSEL6 0x00004000 /*SPISSEL6 Value */ +#define SPI_SLVSEL_SSEL7 0x00008000 /*SPISSEL7 Value */ +/* SPI_RWC */ +#define SPI_RWC_VALUE 0x0000FFFF /*Received Word-Count */ +/* SPI_RWCR */ +#define SPI_RWCR_VALUE 0x0000FFFF /*Received Word-Count Reload */ +/* SPI_TWC */ +#define SPI_TWC_VALUE 0x0000FFFF /*Transmitted Word-Count */ +/* SPI_TWCR */ +#define SPI_TWCR_VALUE 0x0000FFFF /*Transmitted Word-Count Reload */ +/* SPI_IMASK */ +#define SPI_IMSK_RUWM 0x00000002 /*Receive Water-Mark Interrupt Mask */ +#define SPI_IMSK_TUWM 0x00000004 /*Transmit Water-Mark Interrupt Mask */ +#define SPI_IMSK_ROM 0x00000010 /*Receive Over-Run Interrupt Mask */ +#define SPI_IMSK_TUM 0x00000020 /*Transmit Under-Run Interrupt Mask */ +#define SPI_IMSK_TCM 0x00000040 /*Transmit Collision Interrupt Mask */ +#define SPI_IMSK_MFM 0x00000080 /*Mode Fault Interrupt Mask */ +#define SPI_IMSK_RSM 0x00000100 /*Receive Start Interrupt Mask */ +#define SPI_IMSK_TSM 0x00000200 /*Transmit Start Interrupt Mask */ +#define SPI_IMSK_RFM 0x00000400 /*Receive Finish Interrupt Mask */ +#define SPI_IMSK_TFM 0x00000800 /*Transmit Finish Interrupt Mask */ +/* SPI_IMASKCL */ +#define SPI_IMSK_CLR_RUW 0x00000002 /*Receive Water-Mark Interrupt Mask */ +#define SPI_IMSK_CLR_TUWM 0x00000004 /*Transmit Water-Mark Interrupt Mask */ +#define SPI_IMSK_CLR_ROM 0x00000010 /*Receive Over-Run Interrupt Mask */ +#define SPI_IMSK_CLR_TUM 0x00000020 /*Transmit Under-Run Interrupt Mask */ +#define SPI_IMSK_CLR_TCM 0x00000040 /*Transmit Collision Interrupt Mask */ +#define SPI_IMSK_CLR_MFM 0x00000080 /*Mode Fault Interrupt Mask */ +#define SPI_IMSK_CLR_RSM 0x00000100 /*Receive Start Interrupt Mask */ +#define SPI_IMSK_CLR_TSM 0x00000200 /*Transmit Start Interrupt Mask */ +#define SPI_IMSK_CLR_RFM 0x00000400 /*Receive Finish Interrupt Mask */ +#define SPI_IMSK_CLR_TFM 0x00000800 /*Transmit Finish Interrupt Mask */ +/* SPI_IMASKST */ +#define SPI_IMSK_SET_RUWM 0x00000002 /*Receive Water-Mark Interrupt Mask */ +#define SPI_IMSK_SET_TUWM 0x00000004 /*Transmit Water-Mark Interrupt Mask */ +#define SPI_IMSK_SET_ROM 0x00000010 /*Receive Over-Run Interrupt Mask */ +#define SPI_IMSK_SET_TUM 0x00000020 /*Transmit Under-Run Interrupt Mask */ +#define SPI_IMSK_SET_TCM 0x00000040 /*Transmit Collision Interrupt Mask */ +#define SPI_IMSK_SET_MFM 0x00000080 /*Mode Fault Interrupt Mask */ +#define SPI_IMSK_SET_RSM 0x00000100 /*Receive Start Interrupt Mask */ +#define SPI_IMSK_SET_TSM 0x00000200 /*Transmit Start Interrupt Mask */ +#define SPI_IMSK_SET_RFM 0x00000400 /*Receive Finish Interrupt Mask */ +#define SPI_IMSK_SET_TFM 0x00000800 /*Transmit Finish Interrupt Mask */ +/* SPI_STATUS */ +#define SPI_STAT_SPIF 0x00000001 /*SPI Finished */ +#define SPI_STAT_RUWM 0x00000002 /*Receive Water-Mark Breached */ +#define SPI_STAT_TUWM 0x00000004 /*Transmit Water-Mark Breached */ +#define SPI_STAT_ROE 0x00000010 /*Receive Over-Run Indication */ +#define SPI_STAT_TUE 0x00000020 /*Transmit Under-Run Indication */ +#define SPI_STAT_TCE 0x00000040 /*Transmit Collision Indication */ +#define SPI_STAT_MODF 0x00000080 /*Mode Fault Indication */ +#define SPI_STAT_RS 0x00000100 /*Receive Start Indication */ +#define SPI_STAT_TS 0x00000200 /*Transmit Start Indication */ +#define SPI_STAT_RF 0x00000400 /*Receive Finish Indication */ +#define SPI_STAT_TF 0x00000800 /*Transmit Finish Indication */ +#define SPI_STAT_RFS 0x00007000 /*SPI_RFIFO status */ +#define SPI_STAT_RFIFO_EMPTY 0x00000000 /*RFS: RFIFO Empty */ +#define SPI_STAT_RFIFO_25 0x00001000 /*RFS: RFIFO 25% Full */ +#define SPI_STAT_RFIFO_50 0x00002000 /*RFS: RFIFO 50% Full */ +#define SPI_STAT_RFIFO_75 0x00003000 /*RFS: RFIFO 75% Full */ +#define SPI_STAT_RFIFO_FULL 0x00004000 /*RFS: RFIFO Full */ +#define SPI_STAT_TFS 0x00070000 /*SPI_TFIFO status */ +#define SPI_STAT_TFIFO_FULL 0x00000000 /*TFS: TFIFO full */ +#define SPI_STAT_TFIFO_25 0x00010000 /*TFS: TFIFO 25% empty */ +#define SPI_STAT_TFIFO_50 0x00020000 /*TFS: TFIFO 50% empty */ +#define SPI_STAT_TFIFO_75 0x00030000 /*TFS: TFIFO 75% empty */ +#define SPI_STAT_TFIFO_EMPTY 0x00040000 /*TFS: TFIFO empty */ +#define SPI_STAT_FCS 0x00100000 /*Flow-Control Stall Indication */ +#define SPI_STAT_RFE 0x00400000 /*SPI_RFIFO Empty */ +#define SPI_STAT_TFF 0x00800000 /*SPI_TFIFO Full */ +/* SPI_ILAT */ +#define SPI_ILAT_RUWMI 0x00000002 /*Receive Water Mark Interrupt */ +#define SPI_ILAT_TUWMI 0x00000004 /*Transmit Water Mark Interrupt */ +#define SPI_ILAT_ROI 0x00000010 /*Receive Over-Run Indication */ +#define SPI_ILAT_TUI 0x00000020 /*Transmit Under-Run Indication */ +#define SPI_ILAT_TCI 0x00000040 /*Transmit Collision Indication */ +#define SPI_ILAT_MFI 0x00000080 /*Mode Fault Indication */ +#define SPI_ILAT_RSI 0x00000100 /*Receive Start Indication */ +#define SPI_ILAT_TSI 0x00000200 /*Transmit Start Indication */ +#define SPI_ILAT_RFI 0x00000400 /*Receive Finish Indication */ +#define SPI_ILAT_TFI 0x00000800 /*Transmit Finish Indication */ +/* SPI_ILATCL */ +#define SPI_ILAT_CLR_RUWMI 0x00000002 /*Receive Water Mark Interrupt */ +#define SPI_ILAT_CLR_TUWMI 0x00000004 /*Transmit Water Mark Interrupt */ +#define SPI_ILAT_CLR_ROI 0x00000010 /*Receive Over-Run Indication */ +#define SPI_ILAT_CLR_TUI 0x00000020 /*Transmit Under-Run Indication */ +#define SPI_ILAT_CLR_TCI 0x00000040 /*Transmit Collision Indication */ +#define SPI_ILAT_CLR_MFI 0x00000080 /*Mode Fault Indication */ +#define SPI_ILAT_CLR_RSI 0x00000100 /*Receive Start Indication */ +#define SPI_ILAT_CLR_TSI 0x00000200 /*Transmit Start Indication */ +#define SPI_ILAT_CLR_RFI 0x00000400 /*Receive Finish Indication */ +#define SPI_ILAT_CLR_TFI 0x00000800 /*Transmit Finish Indication */ + +/* + * bfin spi3 registers layout + */ +struct bfin_spi_regs { + u32 revid; + u32 control; + u32 rx_control; + u32 tx_control; + u32 clock; + u32 delay; + u32 ssel; + u32 rwc; + u32 rwcr; + u32 twc; + u32 twcr; + u32 reserved0; + u32 emask; + u32 emaskcl; + u32 emaskst; + u32 reserved1; + u32 status; + u32 elat; + u32 elatcl; + u32 reserved2; + u32 rfifo; + u32 reserved3; + u32 tfifo; +}; + +#endif /* _SPI_CHANNEL_H_ */ diff --git a/drivers/spi/Makefile b/drivers/spi/Makefile index 824d357..42aa1a7 100644 --- a/drivers/spi/Makefile +++ b/drivers/spi/Makefile @@ -31,6 +31,7 @@ COBJS-$(CONFIG_ARMADA100_SPI) += armada100_spi.o COBJS-$(CONFIG_ATMEL_DATAFLASH_SPI) += atmel_dataflash_spi.o COBJS-$(CONFIG_ATMEL_SPI) += atmel_spi.o COBJS-$(CONFIG_BFIN_SPI) += bfin_spi.o +COBJS-$(CONFIG_BFIN_SPI6XX) += bfin_spi6xx.o COBJS-$(CONFIG_CF_SPI) += cf_spi.o COBJS-$(CONFIG_CF_QSPI) += cf_qspi.o COBJS-$(CONFIG_DAVINCI_SPI) += davinci_spi.o diff --git a/drivers/spi/bfin_spi6xx.c b/drivers/spi/bfin_spi6xx.c new file mode 100644 index 0000000..fde3447 --- /dev/null +++ b/drivers/spi/bfin_spi6xx.c @@ -0,0 +1,308 @@ +/* + * Analog Devices SPI3 controller driver + * + * Copyright (c) 2011 Analog Devices Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +#include <common.h> +#include <malloc.h> +#include <spi.h> + +#include <asm/blackfin.h> +#include <asm/gpio.h> +#include <asm/portmux.h> +#include <asm/mach-common/bits/spi6xx.h> + +struct bfin_spi_slave { + struct spi_slave slave; + u32 control, clock; + struct bfin_spi_regs *regs; + int cs_pol; +}; + +#define to_bfin_spi_slave(s) container_of(s, struct bfin_spi_slave, slave) + +#define gpio_cs(cs) ((cs) - MAX_CTRL_CS) +#ifdef CONFIG_BFIN_SPI_GPIO_CS +# define is_gpio_cs(cs) ((cs) > MAX_CTRL_CS) +#else +# define is_gpio_cs(cs) 0 +#endif + +int spi_cs_is_valid(unsigned int bus, unsigned int cs) +{ + if (is_gpio_cs(cs)) + return gpio_is_valid(gpio_cs(cs)); + else + return (cs >= 1 && cs <= MAX_CTRL_CS); +} + +void spi_cs_activate(struct spi_slave *slave) +{ + struct bfin_spi_slave *bss = to_bfin_spi_slave(slave); + + if (is_gpio_cs(slave->cs)) { + unsigned int cs = gpio_cs(slave->cs); + gpio_set_value(cs, bss->cs_pol); + } else { + u32 ssel; + ssel = bfin_read32(&bss->regs->ssel); + ssel |= 1 << slave->cs; + if (bss->cs_pol) + ssel |= (1 << 8) << slave->cs; + else + ssel &= ~((1 << 8) << slave->cs); + bfin_write32(&bss->regs->ssel, ssel); + } + + SSYNC(); +} + +void spi_cs_deactivate(struct spi_slave *slave) +{ + struct bfin_spi_slave *bss = to_bfin_spi_slave(slave); + + if (is_gpio_cs(slave->cs)) { + unsigned int cs = gpio_cs(slave->cs); + gpio_set_value(cs, !bss->cs_pol); + } else { + u32 ssel; + ssel = bfin_read32(&bss->regs->ssel); + if (bss->cs_pol) + ssel &= ~((1 << 8) << slave->cs); + else + ssel |= (1 << 8) << slave->cs; + /* deassert cs */ + bfin_write32(&bss->regs->ssel, ssel); + SSYNC(); + /* disable cs */ + ssel &= ~(1 << slave->cs); + bfin_write32(&bss->regs->ssel, ssel); + } + + SSYNC(); +} + +void spi_init() +{ +} + +#define SPI_PINS(n) \ + { 0, P_SPI##n##_SCK, P_SPI##n##_MISO, P_SPI##n##_MOSI, 0 } +static unsigned short pins[][5] = { +#ifdef SPI0_REGBASE + [0] = SPI_PINS(0), +#endif +#ifdef SPI1_REGBASE + [1] = SPI_PINS(1), +#endif +#ifdef SPI2_REGBASE + [2] = SPI_PINS(2), +#endif +}; + +#define SPI_CS_PINS(n) \ + { \ + P_SPI##n##_SSEL1, P_SPI##n##_SSEL2, P_SPI##n##_SSEL3, \ + P_SPI##n##_SSEL4, P_SPI##n##_SSEL5, P_SPI##n##_SSEL6, \ + P_SPI##n##_SSEL7, \ + } +static const unsigned short cs_pins[][7] = { +#ifdef SPI0_REGBASE + [0] = SPI_CS_PINS(0), +#endif +#ifdef SPI1_REGBASE + [1] = SPI_CS_PINS(1), +#endif +#ifdef SPI2_REGBASE + [2] = SPI_CS_PINS(2), +#endif +}; + +void spi_set_speed(struct spi_slave *slave, uint hz) +{ + struct bfin_spi_slave *bss = to_bfin_spi_slave(slave); + ulong sclk; + u32 clock; + + sclk = get_sclk1(); + clock = sclk / hz; + if (clock) + clock--; + bss->clock = clock; +} + +struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, + unsigned int max_hz, unsigned int mode) +{ + struct bfin_spi_slave *bss; + u32 reg_base; + + if (!spi_cs_is_valid(bus, cs)) + return NULL; + + if (bus >= ARRAY_SIZE(pins) || pins[bus] == NULL) { + debug("%s: invalid bus %u\n", __func__, bus); + return NULL; + } + switch (bus) { +#ifdef SPI0_REGBASE + case 0: + reg_base = SPI0_REGBASE; + break; +#endif +#ifdef SPI1_REGBASE + case 1: + reg_base = SPI1_REGBASE; + break; +#endif +#ifdef SPI2_REGBASE + case 2: + reg_base = SPI2_REGBASE; + break; +#endif + default: + return NULL; + } + + bss = malloc(sizeof(*bss)); + if (!bss) + return NULL; + + bss->slave.bus = bus; + bss->slave.cs = cs; + bss->regs = (struct bfin_spi_regs *)reg_base; + bss->control = SPI_CTL_EN | SPI_CTL_MSTR; + if (mode & SPI_CPHA) + bss->control |= SPI_CTL_CPHA; + if (mode & SPI_CPOL) + bss->control |= SPI_CTL_CPOL; + if (mode & SPI_LSB_FIRST) + bss->control |= SPI_CTL_LSBF; + bss->control &= ~SPI_CTL_ASSEL; + bss->cs_pol = mode & SPI_CS_HIGH ? 1 : 0; + spi_set_speed(&bss->slave, max_hz); + + return &bss->slave; +} + +void spi_free_slave(struct spi_slave *slave) +{ + struct bfin_spi_slave *bss = to_bfin_spi_slave(slave); + free(bss); +} + +int spi_claim_bus(struct spi_slave *slave) +{ + struct bfin_spi_slave *bss = to_bfin_spi_slave(slave); + + debug("%s: bus:%i cs:%i\n", __func__, slave->bus, slave->cs); + + if (is_gpio_cs(slave->cs)) { + unsigned int cs = gpio_cs(slave->cs); + gpio_request(cs, "bfin-spi"); + gpio_direction_output(cs, !bss->cs_pol); + pins[slave->bus][0] = P_DONTCARE; + } else + pins[slave->bus][0] = cs_pins[slave->bus][slave->cs - 1]; + peripheral_request_list(pins[slave->bus], "bfin-spi"); + + bfin_write32(&bss->regs->control, bss->control); + bfin_write32(&bss->regs->clock, bss->clock); + bfin_write32(&bss->regs->delay, 0x0); + bfin_write32(&bss->regs->rx_control, SPI_RXCTL_REN); + bfin_write32(&bss->regs->tx_control, SPI_TXCTL_TEN | SPI_TXCTL_TTI); + SSYNC(); + + return 0; +} + +void spi_release_bus(struct spi_slave *slave) +{ + struct bfin_spi_slave *bss = to_bfin_spi_slave(slave); + + debug("%s: bus:%i cs:%i\n", __func__, slave->bus, slave->cs); + + peripheral_free_list(pins[slave->bus]); + if (is_gpio_cs(slave->cs)) + gpio_free(gpio_cs(slave->cs)); + + bfin_write32(&bss->regs->rx_control, 0x0); + bfin_write32(&bss->regs->tx_control, 0x0); + bfin_write32(&bss->regs->control, 0x0); + SSYNC(); +} + +#ifndef CONFIG_BFIN_SPI_IDLE_VAL +# define CONFIG_BFIN_SPI_IDLE_VAL 0xff +#endif + +static int spi_pio_xfer(struct bfin_spi_slave *bss, const u8 *tx, u8 *rx, + uint bytes) +{ + /* discard invalid rx data and empty rfifo */ + while (!(bfin_read32(&bss->regs->status) & SPI_STAT_RFE)) + bfin_read32(&bss->regs->rfifo); + + while (bytes--) { + u8 value = (tx ? *tx++ : CONFIG_BFIN_SPI_IDLE_VAL); + debug("%s: tx:%x ", __func__, value); + bfin_write32(&bss->regs->tfifo, value); + SSYNC(); + while (bfin_read32(&bss->regs->status) & SPI_STAT_RFE) + if (ctrlc()) + return -1; + value = bfin_read32(&bss->regs->rfifo); + if (rx) + *rx++ = value; + debug("rx:%x\n", value); + } + + return 0; +} + +int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *dout, + void *din, unsigned long flags) +{ + struct bfin_spi_slave *bss = to_bfin_spi_slave(slave); + const u8 *tx = dout; + u8 *rx = din; + uint bytes = bitlen / 8; + int ret = 0; + + debug("%s: bus:%i cs:%i bitlen:%i bytes:%i flags:%lx\n", __func__, + slave->bus, slave->cs, bitlen, bytes, flags); + + if (bitlen == 0) + goto done; + + /* we can only do 8 bit transfers */ + if (bitlen % 8) { + flags |= SPI_XFER_END; + goto done; + } + + if (flags & SPI_XFER_BEGIN) + spi_cs_activate(slave); + + ret = spi_pio_xfer(bss, tx, rx, bytes); + + done: + if (flags & SPI_XFER_END) + spi_cs_deactivate(slave); + + return ret; +}
Signed-off-by: Bob Liu lliubbo@gmail.com Signed-off-by: Sonic Zhang sonic.zhang@analog.com --- arch/blackfin/cpu/initcode.c | 13 +++++++++++++ arch/blackfin/cpu/start.S | 2 ++ include/configs/bf609-ezkit.h | 1 + 3 files changed, 16 insertions(+), 0 deletions(-)
diff --git a/arch/blackfin/cpu/initcode.c b/arch/blackfin/cpu/initcode.c index e304d3e..374fe6d 100644 --- a/arch/blackfin/cpu/initcode.c +++ b/arch/blackfin/cpu/initcode.c @@ -461,8 +461,21 @@ program_early_devices(ADI_BOOT_DATA *bs, uint *sdivB, uint *divB, uint *vcoB) */ if (CONFIG_BFIN_BOOT_MODE != BFIN_BOOT_BYPASS) { serial_putc('e'); +#ifdef __ADSPBF60x__ + bfin_write_SEC_GCTL(0x2); + SSYNC(); + bfin_write_SEC_FCTL(0xc1); + bfin_write_SEC_SCTL(2, bfin_read_SEC_SCTL(2) | 0x6); + + bfin_write_SEC_CCTL(0x2); + SSYNC(); + bfin_write_SEC_GCTL(0x1); + bfin_write_SEC_CCTL(0x1); +#endif bfin_write_WDOG_CNT(MSEC_TO_SCLK(CONFIG_HW_WATCHDOG_TIMEOUT_INITCODE)); +#if CONFIG_BFIN_BOOT_MODE != BFIN_BOOT_UART bfin_write_WDOG_CTL(0); +#endif serial_putc('f'); } #endif diff --git a/arch/blackfin/cpu/start.S b/arch/blackfin/cpu/start.S index 90b4d1a..7155fc8 100644 --- a/arch/blackfin/cpu/start.S +++ b/arch/blackfin/cpu/start.S @@ -65,6 +65,7 @@ ENTRY(_start) p5.h = HI(COREMMR_BASE);
#ifdef CONFIG_HW_WATCHDOG +#ifndef __ADSPBF60x__ # ifndef CONFIG_HW_WATCHDOG_TIMEOUT_START # define CONFIG_HW_WATCHDOG_TIMEOUT_START 5000 # endif @@ -78,6 +79,7 @@ ENTRY(_start) /* fire up the watchdog - R0.L above needs to be 0x0000 */ W[p4 + (WDOG_CTL - SYSMMR_BASE)] = r0; #endif +#endif
/* Turn on the serial for debugging the init process */ serial_early_init diff --git a/include/configs/bf609-ezkit.h b/include/configs/bf609-ezkit.h index 6dffab8..02149fa 100644 --- a/include/configs/bf609-ezkit.h +++ b/include/configs/bf609-ezkit.h @@ -63,6 +63,7 @@ #define CONFIG_SYS_MONITOR_LEN (768 * 1024) #define CONFIG_SYS_MALLOC_LEN (512 * 1024)
+#define CONFIG_HW_WATCHDOG /* * Network Settings */
Add Bf60x resume from hibernate support
Signed-off-by: Steven Miao realmz6@gmail.com Signed-off-by: Sonic Zhang sonic.zhang@analog.com Signed-off-by: Bob Liu lliubbo@gmail.com --- arch/blackfin/cpu/initcode.c | 46 ++++++++++++++++++++++++++++++++++++++++++ 1 files changed, 46 insertions(+), 0 deletions(-)
diff --git a/arch/blackfin/cpu/initcode.c b/arch/blackfin/cpu/initcode.c index 374fe6d..bfd64a2 100644 --- a/arch/blackfin/cpu/initcode.c +++ b/arch/blackfin/cpu/initcode.c @@ -509,6 +509,11 @@ maybe_self_refresh(ADI_BOOT_DATA *bs) return false;
#ifdef __ADSPBF60x__ + /* resume from hibernate, return false let ddr initialize */ + if ((bfin_read32(DPM0_STAT) & 0xF0) == 0x50) { + serial_putc('b'); + return false; + }
#else /* __ADSPBF60x__ */
@@ -827,6 +832,7 @@ program_memory_controller(ADI_BOOT_DATA *bs, bool put_into_srfs) while (!(bfin_read_DMC0_STAT() & DLLCALDONE)) continue; serial_putc('!'); + #else /* __ADSPBF60x__ */
/* Program the external memory controller before we come out of @@ -894,7 +900,46 @@ check_hibernation(ADI_BOOT_DATA *bs, u16 vr_ctl, bool put_into_srfs) return;
serial_putc('b'); +#ifdef __ADSPBF60x__ + if (bfin_read32(DPM0_RESTORE0) != 0) { + uint32_t reg = bfin_read_DMC0_CTL(); + reg &= ~0x8; + bfin_write_DMC0_CTL(reg); + + while ((bfin_read_DMC0_STAT() & 0x8)) + continue; + while (!(bfin_read_DMC0_STAT() & 0x1)) + continue;
+ serial_putc('z'); + uint32_t *hibernate_magic = bfin_read32(DPM0_RESTORE4); + SSYNC(); /* make sure memory controller is done */ + if (hibernate_magic[0] == 0xDEADBEEF) { + serial_putc('c'); + SSYNC(); + bfin_write_EVT15(hibernate_magic[1]); + bfin_write_IMASK(EVT_IVG15); + __asm__ __volatile__ ( + /* load reti early to avoid anomaly 281 */ + "reti = %2;" + /* clear hibernate magic */ + "[%0] = %1;" + /* load stack pointer */ + "SP = [%0 + 8];" + /* lower ourselves from reset ivg to ivg15 */ + "raise 15;" + "nop;nop;nop;" + "rti;" + : + : "p"(hibernate_magic), + "d"(0x2000 /* jump.s 0 */), + "d"(0xffa00000) + ); + } + + + } +#else /* Are we coming out of hibernate (suspend to memory) ? * The memory layout is: * 0x0: hibernate magic for anomaly 307 (0xDEADBEEF) @@ -927,6 +972,7 @@ check_hibernation(ADI_BOOT_DATA *bs, u16 vr_ctl, bool put_into_srfs) } serial_putc('d'); } +#endif
serial_putc('e'); }
Sonic Zhang
