[U-Boot] [PATCH 1/2] NAND: add NAND_CMD_PARAM (0xec) definition
This command is used to read the device ONFI parameters page.
Signed-off-by: Florian Fainelli florian@openwrt.org --- include/linux/mtd/nand.h | 1 + 1 files changed, 1 insertions(+), 0 deletions(-)
diff --git a/include/linux/mtd/nand.h b/include/linux/mtd/nand.h index 94ad0c0..7db87e1 100644 --- a/include/linux/mtd/nand.h +++ b/include/linux/mtd/nand.h @@ -84,6 +84,7 @@ extern void nand_wait_ready(struct mtd_info *mtd); #define NAND_CMD_SEQIN 0x80 #define NAND_CMD_RNDIN 0x85 #define NAND_CMD_READID 0x90 +#define NAND_CMD_PARAM 0xec #define NAND_CMD_ERASE2 0xd0 #define NAND_CMD_RESET 0xff
This patch adds support for reading an ONFI page parameter from a NAND device supporting it. If this is the case, struct nand_chip onfi_version member contains the supported ONFI version, 0 otherwise.
This allows NAND drivers past nand_scan_ident to set the best timings for the NAND chip.
Signed-off-by: Florian Fainelli florian@openwrt.org --- drivers/mtd/nand/nand_base.c | 129 ++++++++++++++++++++++++++++++++++------- include/linux/mtd/nand.h | 68 ++++++++++++++++++++++ 2 files changed, 175 insertions(+), 22 deletions(-)
diff --git a/drivers/mtd/nand/nand_base.c b/drivers/mtd/nand/nand_base.c index 21cc5a3..a3a0507 100644 --- a/drivers/mtd/nand/nand_base.c +++ b/drivers/mtd/nand/nand_base.c @@ -2406,15 +2406,94 @@ static void nand_set_defaults(struct nand_chip *chip, int busw) chip->controller = &chip->hwcontrol; }
+static u16 onfi_crc16(u16 crc, u8 const *p, size_t len) +{ + int i; + + while (len--) { + crc ^= *p++ << 8; + for (i = 0; i < 8; i++) + crc = (crc << 1) ^ ((crc & 0x8000) ? 0x8005 : 0); + } + + return crc; +} + +/* + * Check if the NAND chip is ONFI compliant, returns 1 if it is, 0 otherwise + */ +static int nand_flash_detect_onfi(struct mtd_info *mtd, struct nand_chip *chip, + int busw) +{ + struct nand_onfi_params *p = &chip->onfi_params; + int i; + int val; + + /* try ONFI for unknow chip or LP */ + chip->cmdfunc(mtd, NAND_CMD_READID, 0x20, -1); + if (chip->read_byte(mtd) != 'O' || chip->read_byte(mtd) != 'N' || + chip->read_byte(mtd) != 'F' || chip->read_byte(mtd) != 'I') + return 0; + + printk(KERN_INFO "ONFI flash detected\n"); + chip->cmdfunc(mtd, NAND_CMD_PARAM, 0, -1); + for (i = 0; i < 3; i++) { + chip->read_buf(mtd, (uint8_t *)p, sizeof(*p)); + if (onfi_crc16(ONFI_CRC_BASE, (uint8_t *)p, 254) == + le16_to_cpu(p->crc)) { + printk(KERN_INFO "ONFI param page %d valid\n", i); + break; + } + } + + if (i == 3) + return 0; + + /* check version */ + val = le16_to_cpu(p->revision); + if (val == 1 || val > (1 << 4)) { + printk(KERN_INFO "%s: unsupported ONFI version: %d\n", + __func__, val); + return 0; + } + + if (val & (1 << 4)) + chip->onfi_version = 22; + else if (val & (1 << 3)) + chip->onfi_version = 21; + else if (val & (1 << 2)) + chip->onfi_version = 20; + else + chip->onfi_version = 10; + + if (!mtd->name) + mtd->name = p->model; + + mtd->writesize = le32_to_cpu(p->byte_per_page); + mtd->erasesize = le32_to_cpu(p->pages_per_block) * mtd->writesize; + mtd->oobsize = le16_to_cpu(p->spare_bytes_per_page); + chip->chipsize = le32_to_cpu(p->blocks_per_lun) * mtd->erasesize; + busw = 0; + if (le16_to_cpu(p->features) & 1) + busw = NAND_BUSWIDTH_16; + + chip->options &= ~NAND_CHIPOPTIONS_MSK; + chip->options |= (NAND_NO_READRDY | + NAND_NO_AUTOINCR) & NAND_CHIPOPTIONS_MSK; + + return 1; +} + /* * Get the flash and manufacturer id and lookup if the type is supported */ static struct nand_flash_dev *nand_get_flash_type(struct mtd_info *mtd, struct nand_chip *chip, - int busw, int *maf_id) + int busw, + int *maf_id, int *dev_id) { struct nand_flash_dev *type = NULL; - int i, dev_id, maf_idx; + int i, ret, maf_idx; int tmp_id, tmp_manf;
/* Select the device */ @@ -2431,7 +2510,7 @@ static struct nand_flash_dev *nand_get_flash_type(struct mtd_info *mtd,
/* Read manufacturer and device IDs */ *maf_id = chip->read_byte(mtd); - dev_id = chip->read_byte(mtd); + *dev_id = chip->read_byte(mtd);
/* Try again to make sure, as some systems the bus-hold or other * interface concerns can cause random data which looks like a @@ -2446,16 +2525,16 @@ static struct nand_flash_dev *nand_get_flash_type(struct mtd_info *mtd, tmp_manf = chip->read_byte(mtd); tmp_id = chip->read_byte(mtd);
- if (tmp_manf != *maf_id || tmp_id != dev_id) { + if (tmp_manf != *maf_id || tmp_id != *dev_id) { printk(KERN_INFO "%s: second ID read did not match " "%02x,%02x against %02x,%02x\n", __func__, - *maf_id, dev_id, tmp_manf, tmp_id); + *maf_id, *dev_id, tmp_manf, tmp_id); return ERR_PTR(-ENODEV); }
/* Lookup the flash id */ for (i = 0; nand_flash_ids[i].name != NULL; i++) { - if (dev_id == nand_flash_ids[i].id) { + if (*dev_id == nand_flash_ids[i].id) { type = &nand_flash_ids[i]; break; } @@ -2464,10 +2543,10 @@ static struct nand_flash_dev *nand_get_flash_type(struct mtd_info *mtd, if (!type) { /* supress warning if there is no nand */ if (*maf_id != 0x00 && *maf_id != 0xff && - dev_id != 0x00 && dev_id != 0xff) + *dev_id != 0x00 && *dev_id != 0xff) printk(KERN_INFO "%s: unknown NAND device: " "Manufacturer ID: 0x%02x, Chip ID: 0x%02x\n", - __func__, *maf_id, dev_id); + __func__, *maf_id, *dev_id); return ERR_PTR(-ENODEV); }
@@ -2475,6 +2554,11 @@ static struct nand_flash_dev *nand_get_flash_type(struct mtd_info *mtd, mtd->name = type->name;
chip->chipsize = (uint64_t)type->chipsize << 20; + chip->onfi_version = 0; + + ret = nand_flash_detect_onfi(mtd, chip, busw); + if (ret) + goto ident_done;
/* Newer devices have all the information in additional id bytes */ if (!type->pagesize) { @@ -2505,6 +2589,16 @@ static struct nand_flash_dev *nand_get_flash_type(struct mtd_info *mtd, busw = type->options & NAND_BUSWIDTH_16; }
+ /* Get chip options, preserve non chip based options */ + chip->options &= ~NAND_CHIPOPTIONS_MSK; + chip->options |= type->options & NAND_CHIPOPTIONS_MSK; + + /* + * Set chip as a default. Board drivers can override it, if necessary + */ +ident_done: + chip->options |= NAND_NO_AUTOINCR; + /* Try to identify manufacturer */ for (maf_idx = 0; nand_manuf_ids[maf_idx].id != 0x0; maf_idx++) { if (nand_manuf_ids[maf_idx].id == *maf_id) @@ -2518,7 +2612,7 @@ static struct nand_flash_dev *nand_get_flash_type(struct mtd_info *mtd, if (busw != (chip->options & NAND_BUSWIDTH_16)) { printk(KERN_INFO "NAND device: Manufacturer ID:" " 0x%02x, Chip ID: 0x%02x (%s %s)\n", *maf_id, - dev_id, nand_manuf_ids[maf_idx].name, mtd->name); + *dev_id, nand_manuf_ids[maf_idx].name, mtd->name); printk(KERN_WARNING "NAND bus width %d instead %d bit\n", (chip->options & NAND_BUSWIDTH_16) ? 16 : 8, busw ? 16 : 8); @@ -2541,15 +2635,6 @@ static struct nand_flash_dev *nand_get_flash_type(struct mtd_info *mtd, chip->badblockpos = mtd->writesize > 512 ? NAND_LARGE_BADBLOCK_POS : NAND_SMALL_BADBLOCK_POS;
- /* Get chip options, preserve non chip based options */ - chip->options &= ~NAND_CHIPOPTIONS_MSK; - chip->options |= type->options & NAND_CHIPOPTIONS_MSK; - - /* - * Set chip as a default. Board drivers can override it, if necessary - */ - chip->options |= NAND_NO_AUTOINCR; - /* Check if chip is a not a samsung device. Do not clear the * options for chips which are not having an extended id. */ @@ -2567,7 +2652,7 @@ static struct nand_flash_dev *nand_get_flash_type(struct mtd_info *mtd, chip->cmdfunc = nand_command_lp;
MTDDEBUG (MTD_DEBUG_LEVEL0, "NAND device: Manufacturer ID:" - " 0x%02x, Chip ID: 0x%02x (%s %s)\n", *maf_id, dev_id, + " 0x%02x, Chip ID: 0x%02x (%s %s)\n", *maf_id, *dev_id, nand_manuf_ids[maf_idx].name, type->name);
return type; @@ -2585,7 +2670,7 @@ static struct nand_flash_dev *nand_get_flash_type(struct mtd_info *mtd, */ int nand_scan_ident(struct mtd_info *mtd, int maxchips) { - int i, busw, nand_maf_id; + int i, busw, nand_maf_id, nand_dev_id; struct nand_chip *chip = mtd->priv; struct nand_flash_dev *type;
@@ -2595,7 +2680,7 @@ int nand_scan_ident(struct mtd_info *mtd, int maxchips) nand_set_defaults(chip, busw);
/* Read the flash type */ - type = nand_get_flash_type(mtd, chip, busw, &nand_maf_id); + type = nand_get_flash_type(mtd, chip, busw, &nand_maf_id, &nand_dev_id);
if (IS_ERR(type)) { #ifndef CONFIG_SYS_NAND_QUIET_TEST @@ -2614,7 +2699,7 @@ int nand_scan_ident(struct mtd_info *mtd, int maxchips) chip->cmdfunc(mtd, NAND_CMD_READID, 0x00, -1); /* Read manufacturer and device IDs */ if (nand_maf_id != chip->read_byte(mtd) || - type->id != chip->read_byte(mtd)) + nand_dev_id != chip->read_byte(mtd)) break; } #ifdef DEBUG diff --git a/include/linux/mtd/nand.h b/include/linux/mtd/nand.h index 7db87e1..beb35c6 100644 --- a/include/linux/mtd/nand.h +++ b/include/linux/mtd/nand.h @@ -215,6 +215,71 @@ typedef enum { /* Keep gcc happy */ struct nand_chip;
+struct nand_onfi_params { + /* rev info and features block */ + /* 'O' 'N' 'F' 'I' */ + u8 sig[4]; + __le16 revision; + __le16 features; + __le16 opt_cmd; + u8 reserved[22]; + + /* manufacturer information block */ + char manufacturer[12]; + char model[20]; + u8 jedec_id; + __le16 date_code; + u8 reserved2[13]; + + /* memory organization block */ + __le32 byte_per_page; + __le16 spare_bytes_per_page; + __le32 data_bytes_per_ppage; + __le16 spare_bytes_per_ppage; + __le32 pages_per_block; + __le32 blocks_per_lun; + u8 lun_count; + u8 addr_cycles; + u8 bits_per_cell; + __le16 bb_per_lun; + __le16 block_endurance; + u8 guaranteed_good_blocks; + __le16 guaranteed_block_endurance; + u8 programs_per_page; + u8 ppage_attr; + u8 ecc_bits; + u8 interleaved_bits; + u8 interleaved_ops; + u8 reserved3[13]; + + /* electrical parameter block */ + u8 io_pin_capacitance_max; + __le16 async_timing_mode; + __le16 program_cache_timing_mode; + __le16 t_prog; + __le16 t_bers; + __le16 t_r; + __le16 t_ccs; + __le16 src_sync_timing_mode; + __le16 src_ssync_features; + __le16 clk_pin_capacitance_typ; + __le16 io_pin_capacitance_typ; + __le16 input_pin_capacitance_typ; + u8 input_pin_capacitance_max; + u8 driver_strenght_support; + __le16 t_int_r; + __le16 t_ald; + u8 reserved4[7]; + + /* vendor */ + u8 reserved5[90]; + + __le16 crc; +} __attribute__((packed)); + +#define ONFI_CRC_BASE 0x4F4E + + /** * struct nand_hw_control - Control structure for hardware controller (e.g ECC generator) shared among independent devices * @lock: protection lock @@ -405,6 +470,9 @@ struct nand_chip { uint8_t cellinfo; int badblockpos;
+ int onfi_version; + struct nand_onfi_params onfi_params; + int state;
uint8_t *oob_poi;
Wrap changelogs around 72 characters, as git log indents them a bit.
Tested on what I assume is a non-ONFI chip, no breakage.
Please wrap this in a CONFIG option, so that we don't increase the image size of boards that don't need to support this.
- int i;
- while (len--) {
crc ^= *p++ << 8;
- return crc;
- Check if the NAND chip is ONFI compliant, returns 1 if it is, 0 otherwise
int busw)
Keep lines under 80 columns.
- /* try ONFI for unknow chip or LP */
"unknown".
- chip->cmdfunc(mtd, NAND_CMD_READID, 0x20, -1);
- if (chip->read_byte(mtd) != 'O' || chip->read_byte(mtd) != 'N' ||
I'm not sure how this comment matches the code -- it looks like it's checking for an explicit ONFI ID. I don't see anything about unknown chips or large pages.
- /* check version */
- val = le16_to_cpu(p->revision);
- if (val == 1 || val > (1 << 4)) {
__func__, val);
Ideally I'd like to see continuation lines lined up nicely with the start of arguments on the previous line, but at least don't tab it all the way over to the right edge of the screen.
- chip->onfi_version = 0;
- ret = nand_flash_detect_onfi(mtd, chip, busw);
- if (ret)
goto ident_done;
Move the non-ONFI code out into its own function, instead of using goto.
- __le32 blocks_per_lun;
- u8 lun_count;
- u8 addr_cycles;
- u8 bits_per_cell;
- __le16 bb_per_lun;
- __le16 block_endurance;
- u8 guaranteed_good_blocks;
- __le16 guaranteed_block_endurance;
[snip]
Sigh. Someone on the standards body needs to learn about alignment.
-Scott
Makes sense, I will do this
- int i;
- while (len--) {
crc ^= *p++ << 8;
- return crc;
"unknown".
It does not actually, I did not think about checking it when porting this from Linux.
__func__, val);
- if (ret)
goto ident_done;
- u8 lun_count;
- u8 addr_cycles;
- u8 bits_per_cell;
[snip]
-Scott
Signed-off-by: Florian Fainelli florian@openwrt.org --- Changes since v1: - ifdef out ONFI detection code around CONFIG_SYS_NAND_ONFI_DETECTION - removed bogus comment - fixed busw variable usage - move non-ONFI detection code to its own function - fixed stylistic issues spotted by Scott
diff --git a/drivers/mtd/nand/nand_base.c b/drivers/mtd/nand/nand_base.c index 5239c1f..7f9d69a 100644 --- a/drivers/mtd/nand/nand_base.c +++ b/drivers/mtd/nand/nand_base.c @@ -2409,15 +2409,141 @@ static void nand_set_defaults(struct nand_chip *chip, int busw) chip->controller = &chip->hwcontrol; }
+#ifdef CONFIG_SYS_NAND_ONFI_DETECTION +static u16 onfi_crc16(u16 crc, u8 const *p, size_t len) +{ + int i; + + while (len--) { + crc ^= *p++ << 8; + for (i = 0; i < 8; i++) + crc = (crc << 1) ^ ((crc & 0x8000) ? 0x8005 : 0); + } + + return crc; +} + +/* + * Check if the NAND chip is ONFI compliant, returns 1 if it is, 0 otherwise + */ +static int nand_flash_detect_onfi(struct mtd_info *mtd, + struct nand_chip *chip, + int *busw) +{ + struct nand_onfi_params *p = &chip->onfi_params; + int i; + int val; + + chip->cmdfunc(mtd, NAND_CMD_READID, 0x20, -1); + if (chip->read_byte(mtd) != 'O' || chip->read_byte(mtd) != 'N' || + chip->read_byte(mtd) != 'F' || chip->read_byte(mtd) != 'I') + return 0; + + printk(KERN_INFO "ONFI flash detected\n"); + chip->cmdfunc(mtd, NAND_CMD_PARAM, 0, -1); + for (i = 0; i < 3; i++) { + chip->read_buf(mtd, (uint8_t *)p, sizeof(*p)); + if (onfi_crc16(ONFI_CRC_BASE, (uint8_t *)p, 254) == + le16_to_cpu(p->crc)) { + printk(KERN_INFO "ONFI param page %d valid\n", i); + break; + } + } + + if (i == 3) + return 0; + + /* check version */ + val = le16_to_cpu(p->revision); + if (val == 1 || val > (1 << 4)) { + printk(KERN_INFO "%s: unsupported ONFI version: %d\n", __func__, val); + return 0; + } + + if (val & (1 << 4)) + chip->onfi_version = 22; + else if (val & (1 << 3)) + chip->onfi_version = 21; + else if (val & (1 << 2)) + chip->onfi_version = 20; + else + chip->onfi_version = 10; + + if (!mtd->name) + mtd->name = p->model; + + mtd->writesize = le32_to_cpu(p->byte_per_page); + mtd->erasesize = le32_to_cpu(p->pages_per_block) * mtd->writesize; + mtd->oobsize = le16_to_cpu(p->spare_bytes_per_page); + chip->chipsize = le32_to_cpu(p->blocks_per_lun) * mtd->erasesize; + *busw = 0; + if (le16_to_cpu(p->features) & 1) + *busw = NAND_BUSWIDTH_16; + + chip->options &= ~NAND_CHIPOPTIONS_MSK; + chip->options |= (NAND_NO_READRDY | + NAND_NO_AUTOINCR) & NAND_CHIPOPTIONS_MSK; + + return 1; +} +#else +static inline int nand_flash_detect_onfi(struct mtd_info *mtd, + struct nand_chip *chip, + int *busw) +{ + return 0; +} +#endif + +static void nand_flash_detect_non_onfi(struct mtd_info *mtd, + struct nand_chip *chip, + const struct nand_flash_dev *type, + int *busw) +{ + /* Newer devices have all the information in additional id bytes */ + if (!type->pagesize) { + int extid; + /* The 3rd id byte holds MLC / multichip data */ + chip->cellinfo = chip->read_byte(mtd); + /* The 4th id byte is the important one */ + extid = chip->read_byte(mtd); + /* Calc pagesize */ + mtd->writesize = 1024 << (extid & 0x3); + extid >>= 2; + /* Calc oobsize */ + mtd->oobsize = (8 << (extid & 0x01)) * (mtd->writesize >> 9); + extid >>= 2; + /* Calc blocksize. Blocksize is multiples of 64KiB */ + mtd->erasesize = (64 * 1024) << (extid & 0x03); + extid >>= 2; + /* Get buswidth information */ + *busw = (extid & 0x01) ? NAND_BUSWIDTH_16 : 0; + + } else { + /* + * Old devices have chip data hardcoded in the device id table + */ + mtd->erasesize = type->erasesize; + mtd->writesize = type->pagesize; + mtd->oobsize = mtd->writesize / 32; + *busw = type->options & NAND_BUSWIDTH_16; + } + + /* Get chip options, preserve non chip based options */ + chip->options &= ~NAND_CHIPOPTIONS_MSK; + chip->options |= type->options & NAND_CHIPOPTIONS_MSK; +} + /* * Get the flash and manufacturer id and lookup if the type is supported */ static const struct nand_flash_dev *nand_get_flash_type(struct mtd_info *mtd, struct nand_chip *chip, - int busw, int *maf_id) + int busw, + int *maf_id, int *dev_id) { const struct nand_flash_dev *type = NULL; - int i, dev_id, maf_idx; + int i, ret, maf_idx; int tmp_id, tmp_manf;
/* Select the device */ @@ -2434,7 +2560,7 @@ static const struct nand_flash_dev *nand_get_flash_type(struct mtd_info *mtd,
/* Try again to make sure, as some systems the bus-hold or other * interface concerns can cause random data which looks like a @@ -2449,16 +2575,16 @@ static const struct nand_flash_dev *nand_get_flash_type(struct mtd_info *mtd, tmp_manf = chip->read_byte(mtd); tmp_id = chip->read_byte(mtd);
/* Lookup the flash id */ for (i = 0; nand_flash_ids[i].name != NULL; i++) { - if (dev_id == nand_flash_ids[i].id) { + if (*dev_id == nand_flash_ids[i].id) { type = &nand_flash_ids[i]; break; } @@ -2467,10 +2593,10 @@ static const struct nand_flash_dev *nand_get_flash_type(struct mtd_info *mtd, if (!type) { /* supress warning if there is no nand */ if (*maf_id != 0x00 && *maf_id != 0xff && - dev_id != 0x00 && dev_id != 0xff) + *dev_id != 0x00 && *dev_id != 0xff) printk(KERN_INFO "%s: unknown NAND device: " "Manufacturer ID: 0x%02x, Chip ID: 0x%02x\n", - __func__, *maf_id, dev_id); + __func__, *maf_id, *dev_id); return ERR_PTR(-ENODEV); }
@@ -2478,35 +2604,20 @@ static const struct nand_flash_dev *nand_get_flash_type(struct mtd_info *mtd, mtd->name = type->name;
- /* Newer devices have all the information in additional id bytes */ - if (!type->pagesize) { - int extid; - /* The 3rd id byte holds MLC / multichip data */ - chip->cellinfo = chip->read_byte(mtd); - /* The 4th id byte is the important one */ - extid = chip->read_byte(mtd); - /* Calc pagesize */ - mtd->writesize = 1024 << (extid & 0x3); - extid >>= 2; - /* Calc oobsize */ - mtd->oobsize = (8 << (extid & 0x01)) * (mtd->writesize >> 9); - extid >>= 2; - /* Calc blocksize. Blocksize is multiples of 64KiB */ - mtd->erasesize = (64 * 1024) << (extid & 0x03); - extid >>= 2; - /* Get buswidth information */ - busw = (extid & 0x01) ? NAND_BUSWIDTH_16 : 0; + ret = nand_flash_detect_onfi(mtd, chip, &busw); + if (!ret) + nand_flash_detect_non_onfi(mtd, chip, type, &busw);
- } else { - /* - * Old devices have chip data hardcoded in the device id table - */ - mtd->erasesize = type->erasesize; - mtd->writesize = type->pagesize; - mtd->oobsize = mtd->writesize / 32; - busw = type->options & NAND_BUSWIDTH_16; - } + /* Get chip options, preserve non chip based options */ + chip->options &= ~NAND_CHIPOPTIONS_MSK; + chip->options |= type->options & NAND_CHIPOPTIONS_MSK; + + /* + * Set chip as a default. Board drivers can override it, if necessary + */ + chip->options |= NAND_NO_AUTOINCR;
/* Try to identify manufacturer */ for (maf_idx = 0; nand_manuf_ids[maf_idx].id != 0x0; maf_idx++) { @@ -2521,7 +2632,7 @@ static const struct nand_flash_dev *nand_get_flash_type(struct mtd_info *mtd, if (busw != (chip->options & NAND_BUSWIDTH_16)) { printk(KERN_INFO "NAND device: Manufacturer ID:" " 0x%02x, Chip ID: 0x%02x (%s %s)\n", *maf_id, - dev_id, nand_manuf_ids[maf_idx].name, mtd->name); + *dev_id, nand_manuf_ids[maf_idx].name, mtd->name); printk(KERN_WARNING "NAND bus width %d instead %d bit\n", (chip->options & NAND_BUSWIDTH_16) ? 16 : 8, busw ? 16 : 8); @@ -2544,15 +2655,6 @@ static const struct nand_flash_dev *nand_get_flash_type(struct mtd_info *mtd, chip->badblockpos = mtd->writesize > 512 ? NAND_LARGE_BADBLOCK_POS : NAND_SMALL_BADBLOCK_POS;
- /* Get chip options, preserve non chip based options */ - chip->options &= ~NAND_CHIPOPTIONS_MSK; - chip->options |= type->options & NAND_CHIPOPTIONS_MSK; - - /* - * Set chip as a default. Board drivers can override it, if necessary - */ - chip->options |= NAND_NO_AUTOINCR; - /* Check if chip is a not a samsung device. Do not clear the * options for chips which are not having an extended id. */ @@ -2570,7 +2672,7 @@ static const struct nand_flash_dev *nand_get_flash_type(struct mtd_info *mtd, chip->cmdfunc = nand_command_lp;
return type; @@ -2588,7 +2690,7 @@ static const struct nand_flash_dev *nand_get_flash_type(struct mtd_info *mtd, */ int nand_scan_ident(struct mtd_info *mtd, int maxchips) { - int i, busw, nand_maf_id; + int i, busw, nand_maf_id, nand_dev_id; struct nand_chip *chip = mtd->priv; const struct nand_flash_dev *type;
@@ -2598,7 +2700,7 @@ int nand_scan_ident(struct mtd_info *mtd, int maxchips) nand_set_defaults(chip, busw);
if (IS_ERR(type)) { #ifndef CONFIG_SYS_NAND_QUIET_TEST @@ -2617,7 +2719,7 @@ int nand_scan_ident(struct mtd_info *mtd, int maxchips) chip->cmdfunc(mtd, NAND_CMD_READID, 0x00, -1); /* Read manufacturer and device IDs */ if (nand_maf_id != chip->read_byte(mtd) || - type->id != chip->read_byte(mtd)) + nand_dev_id != chip->read_byte(mtd)) break; } #ifdef DEBUG diff --git a/include/linux/mtd/nand.h b/include/linux/mtd/nand.h index 1128f5a..f19909c 100644 --- a/include/linux/mtd/nand.h +++ b/include/linux/mtd/nand.h @@ -215,6 +215,71 @@ typedef enum { /* Keep gcc happy */ struct nand_chip;
+struct nand_onfi_params { + /* rev info and features block */ + /* 'O' 'N' 'F' 'I' */ + u8 sig[4]; + __le16 revision; + __le16 features; + __le16 opt_cmd; + u8 reserved[22]; + + /* manufacturer information block */ + char manufacturer[12]; + char model[20]; + u8 jedec_id; + __le16 date_code; + u8 reserved2[13]; + + /* memory organization block */ + __le32 byte_per_page; + __le16 spare_bytes_per_page; + __le32 data_bytes_per_ppage; + __le16 spare_bytes_per_ppage; + __le32 pages_per_block; + __le32 blocks_per_lun; + u8 lun_count; + u8 addr_cycles; + u8 bits_per_cell; + __le16 bb_per_lun; + __le16 block_endurance; + u8 guaranteed_good_blocks; + __le16 guaranteed_block_endurance; + u8 programs_per_page; + u8 ppage_attr; + u8 ecc_bits; + u8 interleaved_bits; + u8 interleaved_ops; + u8 reserved3[13]; + + /* electrical parameter block */ + u8 io_pin_capacitance_max; + __le16 async_timing_mode; + __le16 program_cache_timing_mode; + __le16 t_prog; + __le16 t_bers; + __le16 t_r; + __le16 t_ccs; + __le16 src_sync_timing_mode; + __le16 src_ssync_features; + __le16 clk_pin_capacitance_typ; + __le16 io_pin_capacitance_typ; + __le16 input_pin_capacitance_typ; + u8 input_pin_capacitance_max; + u8 driver_strenght_support; + __le16 t_int_r; + __le16 t_ald; + u8 reserved4[7]; + + /* vendor */ + u8 reserved5[90]; + + __le16 crc; +} __attribute__((packed)); + +#define ONFI_CRC_BASE 0x4F4E + + /** * struct nand_hw_control - Control structure for hardware controller (e.g ECC generator) shared among independent devices * @lock: protection lock @@ -404,6 +469,10 @@ struct nand_chip { int subpagesize; uint8_t cellinfo; int badblockpos; + int onfi_version; +#ifdef CONFIG_SYS_NAND_ONFI_DETECTION + struct nand_onfi_params onfi_params; +#endif
int state;
Hello Scott,
Forgot to mention that this patch is against your 'next' branch. -- Florian
On Tue, Dec 28, 2010 at 01:21:06AM +0100, Florian Fainelli wrote:
/* check version */
Line length.
NAND_NO_AUTOINCR is not included in NAND_CHIPOPTIONS_MSK, so including it here has no effect.
if (!ret)
} else {
Won't this duplicate/overwrite what was done in nand_flash_detect_*()?
__le16 t_int_r;
__le16 t_ald;
u8 reserved4[7];
/* vendor */
u8 reserved5[90];
__le16 crc;
Extra space before __le16.
-Scott
Signed-off-by: Florian Fainelli florian@openwrt.org --- Patch against your 'next' branch
Changes since v2: - reduce lenght of some lines down to 80 columns - change chip->options consistently wrt to ONFI detected or not - removed extra spaces
diff --git a/drivers/mtd/nand/nand_base.c b/drivers/mtd/nand/nand_base.c index 5239c1f..7becb99 100644 --- a/drivers/mtd/nand/nand_base.c +++ b/drivers/mtd/nand/nand_base.c @@ -2409,15 +2409,137 @@ static void nand_set_defaults(struct nand_chip *chip, int busw) chip->controller = &chip->hwcontrol; }
+#ifdef CONFIG_SYS_NAND_ONFI_DETECTION +static u16 onfi_crc16(u16 crc, u8 const *p, size_t len) +{ + int i; + + while (len--) { + crc ^= *p++ << 8; + for (i = 0; i < 8; i++) + crc = (crc << 1) ^ ((crc & 0x8000) ? 0x8005 : 0); + } + + return crc; +} + +/* + * Check if the NAND chip is ONFI compliant, returns 1 if it is, 0 otherwise + */ +static int nand_flash_detect_onfi(struct mtd_info *mtd, + struct nand_chip *chip, + int *busw) +{ + struct nand_onfi_params *p = &chip->onfi_params; + int i; + int val; + + chip->cmdfunc(mtd, NAND_CMD_READID, 0x20, -1); + if (chip->read_byte(mtd) != 'O' || chip->read_byte(mtd) != 'N' || + chip->read_byte(mtd) != 'F' || chip->read_byte(mtd) != 'I') + return 0; + + printk(KERN_INFO "ONFI flash detected\n"); + chip->cmdfunc(mtd, NAND_CMD_PARAM, 0, -1); + for (i = 0; i < 3; i++) { + chip->read_buf(mtd, (uint8_t *)p, sizeof(*p)); + if (onfi_crc16(ONFI_CRC_BASE, (uint8_t *)p, 254) == + le16_to_cpu(p->crc)) { + printk(KERN_INFO "ONFI param page %d valid\n", i); + break; + } + } + + if (i == 3) + return 0; + + /* check version */ + val = le16_to_cpu(p->revision); + if (val == 1 || val > (1 << 4)) { + printk(KERN_INFO "%s: unsupported ONFI " + "version: %d\n", __func__, val); + return 0; + } + + if (val & (1 << 4)) + chip->onfi_version = 22; + else if (val & (1 << 3)) + chip->onfi_version = 21; + else if (val & (1 << 2)) + chip->onfi_version = 20; + else + chip->onfi_version = 10; + + if (!mtd->name) + mtd->name = p->model; + + mtd->writesize = le32_to_cpu(p->byte_per_page); + mtd->erasesize = le32_to_cpu(p->pages_per_block) * mtd->writesize; + mtd->oobsize = le16_to_cpu(p->spare_bytes_per_page); + chip->chipsize = le32_to_cpu(p->blocks_per_lun) * mtd->erasesize; + *busw = 0; + if (le16_to_cpu(p->features) & 1) + *busw = NAND_BUSWIDTH_16; + + chip->options &= ~NAND_CHIPOPTIONS_MSK; + chip->options |= NAND_NO_READRDY & NAND_CHIPOPTIONS_MSK; + + return 1; +} +#else +static inline int nand_flash_detect_onfi(struct mtd_info *mtd, + struct nand_chip *chip, + int *busw) +{ + return 0; +} +#endif + +static void nand_flash_detect_non_onfi(struct mtd_info *mtd, + struct nand_chip *chip, + const struct nand_flash_dev *type, + int *busw) +{ + /* Newer devices have all the information in additional id bytes */ + if (!type->pagesize) { + int extid; + /* The 3rd id byte holds MLC / multichip data */ + chip->cellinfo = chip->read_byte(mtd); + /* The 4th id byte is the important one */ + extid = chip->read_byte(mtd); + /* Calc pagesize */ + mtd->writesize = 1024 << (extid & 0x3); + extid >>= 2; + /* Calc oobsize */ + mtd->oobsize = (8 << (extid & 0x01)) * (mtd->writesize >> 9); + extid >>= 2; + /* Calc blocksize. Blocksize is multiples of 64KiB */ + mtd->erasesize = (64 * 1024) << (extid & 0x03); + extid >>= 2; + /* Get buswidth information */ + *busw = (extid & 0x01) ? NAND_BUSWIDTH_16 : 0; + + } else { + /* + * Old devices have chip data hardcoded in the device id table + */ + mtd->erasesize = type->erasesize; + mtd->writesize = type->pagesize; + mtd->oobsize = mtd->writesize / 32; + *busw = type->options & NAND_BUSWIDTH_16; + } +} + /* * Get the flash and manufacturer id and lookup if the type is supported */ static const struct nand_flash_dev *nand_get_flash_type(struct mtd_info *mtd, struct nand_chip *chip, - int busw, int *maf_id) + int busw, + int *maf_id, int *dev_id) { const struct nand_flash_dev *type = NULL; - int i, dev_id, maf_idx; + int i, ret, maf_idx; int tmp_id, tmp_manf;
/* Select the device */ @@ -2434,7 +2556,7 @@ static const struct nand_flash_dev *nand_get_flash_type(struct mtd_info *mtd,
/* Try again to make sure, as some systems the bus-hold or other * interface concerns can cause random data which looks like a @@ -2449,16 +2571,16 @@ static const struct nand_flash_dev *nand_get_flash_type(struct mtd_info *mtd, tmp_manf = chip->read_byte(mtd); tmp_id = chip->read_byte(mtd);
/* Lookup the flash id */ for (i = 0; nand_flash_ids[i].name != NULL; i++) { - if (dev_id == nand_flash_ids[i].id) { + if (*dev_id == nand_flash_ids[i].id) { type = &nand_flash_ids[i]; break; } @@ -2467,10 +2589,10 @@ static const struct nand_flash_dev *nand_get_flash_type(struct mtd_info *mtd, if (!type) { /* supress warning if there is no nand */ if (*maf_id != 0x00 && *maf_id != 0xff && - dev_id != 0x00 && dev_id != 0xff) + *dev_id != 0x00 && *dev_id != 0xff) printk(KERN_INFO "%s: unknown NAND device: " "Manufacturer ID: 0x%02x, Chip ID: 0x%02x\n", - __func__, *maf_id, dev_id); + __func__, *maf_id, *dev_id); return ERR_PTR(-ENODEV); }
@@ -2478,35 +2600,20 @@ static const struct nand_flash_dev *nand_get_flash_type(struct mtd_info *mtd, mtd->name = type->name;
/* Try to identify manufacturer */ for (maf_idx = 0; nand_manuf_ids[maf_idx].id != 0x0; maf_idx++) { @@ -2521,7 +2628,7 @@ static const struct nand_flash_dev *nand_get_flash_type(struct mtd_info *mtd, if (busw != (chip->options & NAND_BUSWIDTH_16)) { printk(KERN_INFO "NAND device: Manufacturer ID:" " 0x%02x, Chip ID: 0x%02x (%s %s)\n", *maf_id, - dev_id, nand_manuf_ids[maf_idx].name, mtd->name); + *dev_id, nand_manuf_ids[maf_idx].name, mtd->name); printk(KERN_WARNING "NAND bus width %d instead %d bit\n", (chip->options & NAND_BUSWIDTH_16) ? 16 : 8, busw ? 16 : 8); @@ -2544,15 +2651,6 @@ static const struct nand_flash_dev *nand_get_flash_type(struct mtd_info *mtd, chip->badblockpos = mtd->writesize > 512 ? NAND_LARGE_BADBLOCK_POS : NAND_SMALL_BADBLOCK_POS;
- /* Get chip options, preserve non chip based options */ - chip->options &= ~NAND_CHIPOPTIONS_MSK; - chip->options |= type->options & NAND_CHIPOPTIONS_MSK; - - /* - * Set chip as a default. Board drivers can override it, if necessary - */ - chip->options |= NAND_NO_AUTOINCR; - /* Check if chip is a not a samsung device. Do not clear the * options for chips which are not having an extended id. */ @@ -2570,7 +2668,7 @@ static const struct nand_flash_dev *nand_get_flash_type(struct mtd_info *mtd, chip->cmdfunc = nand_command_lp;
return type; @@ -2588,7 +2686,7 @@ static const struct nand_flash_dev *nand_get_flash_type(struct mtd_info *mtd, */ int nand_scan_ident(struct mtd_info *mtd, int maxchips) { - int i, busw, nand_maf_id; + int i, busw, nand_maf_id, nand_dev_id; struct nand_chip *chip = mtd->priv; const struct nand_flash_dev *type;
@@ -2598,7 +2696,7 @@ int nand_scan_ident(struct mtd_info *mtd, int maxchips) nand_set_defaults(chip, busw);
if (IS_ERR(type)) { #ifndef CONFIG_SYS_NAND_QUIET_TEST @@ -2617,7 +2715,7 @@ int nand_scan_ident(struct mtd_info *mtd, int maxchips) chip->cmdfunc(mtd, NAND_CMD_READID, 0x00, -1); /* Read manufacturer and device IDs */ if (nand_maf_id != chip->read_byte(mtd) || - type->id != chip->read_byte(mtd)) + nand_dev_id != chip->read_byte(mtd)) break; } #ifdef DEBUG diff --git a/include/linux/mtd/nand.h b/include/linux/mtd/nand.h index 1128f5a..4b77094 100644 --- a/include/linux/mtd/nand.h +++ b/include/linux/mtd/nand.h @@ -215,6 +215,71 @@ typedef enum { /* Keep gcc happy */ struct nand_chip;
int state;
-- 1.7.1
On Mon, 14 Feb 2011 16:48:01 +0100 Florian Fainelli florian@openwrt.org wrote:
The 'next' branch is old, since I haven't pushed anything to it yet this cycle. Base it on Wolfgang's 'next'.
Changes since v1:
Changes since v2:
- int i;
- while (len--) {
crc ^= *p++ << 8;
- return crc;
Is this different from what's in lib/crc16.c (other than appearing to have made a different speed/size tradeoff)?
Is this ONFI-specific, or standard for crc16?
int *busw)
[snip]
- chip->options |= NAND_NO_READRDY & NAND_CHIPOPTIONS_MSK;
Won't this get overwritten by this later?
-Scott
Dear Scott Wood,
I don't have a "next" yet. I will create it when -rc2 is out.
Hello Scott,
(sorry for the lag in answering)
Changes since v1:
Changes since v2:
- int i;
- while (len--) {
crc ^= *p++ << 8;
- return crc;
Yes it is a different version of the CRC16 function.
int *busw)
[snip]
It will, thanks for spotting. -- Florian
Signed-off-by: Florian Fainelli florian@openwrt.org --- Patch against your 'master' branch
Changes since v3: - removed chip->options modification in nand_flash_detect_onfi because it is overwritten in nand_flash_detect() later
diff --git a/drivers/mtd/nand/nand_base.c b/drivers/mtd/nand/nand_base.c index 70c0593..9034945 100644 --- a/drivers/mtd/nand/nand_base.c +++ b/drivers/mtd/nand/nand_base.c @@ -2409,15 +2409,134 @@ static void nand_set_defaults(struct nand_chip *chip, int busw) chip->controller = &chip->hwcontrol; }
+#ifdef CONFIG_SYS_NAND_ONFI_DETECTION +static u16 onfi_crc16(u16 crc, u8 const *p, size_t len) +{ + int i; + + while (len--) { + crc ^= *p++ << 8; + for (i = 0; i < 8; i++) + crc = (crc << 1) ^ ((crc & 0x8000) ? 0x8005 : 0); + } + + return crc; +} + +/* + * Check if the NAND chip is ONFI compliant, returns 1 if it is, 0 otherwise + */ +static int nand_flash_detect_onfi(struct mtd_info *mtd, + struct nand_chip *chip, + int *busw) +{ + struct nand_onfi_params *p = &chip->onfi_params; + int i; + int val; + + chip->cmdfunc(mtd, NAND_CMD_READID, 0x20, -1); + if (chip->read_byte(mtd) != 'O' || chip->read_byte(mtd) != 'N' || + chip->read_byte(mtd) != 'F' || chip->read_byte(mtd) != 'I') + return 0; + + printk(KERN_INFO "ONFI flash detected\n"); + chip->cmdfunc(mtd, NAND_CMD_PARAM, 0, -1); + for (i = 0; i < 3; i++) { + chip->read_buf(mtd, (uint8_t *)p, sizeof(*p)); + if (onfi_crc16(ONFI_CRC_BASE, (uint8_t *)p, 254) == + le16_to_cpu(p->crc)) { + printk(KERN_INFO "ONFI param page %d valid\n", i); + break; + } + } + + if (i == 3) + return 0; + + /* check version */ + val = le16_to_cpu(p->revision); + if (val == 1 || val > (1 << 4)) { + printk(KERN_INFO "%s: unsupported ONFI " + "version: %d\n", __func__, val); + return 0; + } + + if (val & (1 << 4)) + chip->onfi_version = 22; + else if (val & (1 << 3)) + chip->onfi_version = 21; + else if (val & (1 << 2)) + chip->onfi_version = 20; + else + chip->onfi_version = 10; + + if (!mtd->name) + mtd->name = p->model; + + mtd->writesize = le32_to_cpu(p->byte_per_page); + mtd->erasesize = le32_to_cpu(p->pages_per_block) * mtd->writesize; + mtd->oobsize = le16_to_cpu(p->spare_bytes_per_page); + chip->chipsize = le32_to_cpu(p->blocks_per_lun) * mtd->erasesize; + *busw = 0; + if (le16_to_cpu(p->features) & 1) + *busw = NAND_BUSWIDTH_16; + + return 1; +} +#else +static inline int nand_flash_detect_onfi(struct mtd_info *mtd, + struct nand_chip *chip, + int *busw) +{ + return 0; +} +#endif + +static void nand_flash_detect_non_onfi(struct mtd_info *mtd, + struct nand_chip *chip, + const struct nand_flash_dev *type, + int *busw) +{ + /* Newer devices have all the information in additional id bytes */ + if (!type->pagesize) { + int extid; + /* The 3rd id byte holds MLC / multichip data */ + chip->cellinfo = chip->read_byte(mtd); + /* The 4th id byte is the important one */ + extid = chip->read_byte(mtd); + /* Calc pagesize */ + mtd->writesize = 1024 << (extid & 0x3); + extid >>= 2; + /* Calc oobsize */ + mtd->oobsize = (8 << (extid & 0x01)) * (mtd->writesize >> 9); + extid >>= 2; + /* Calc blocksize. Blocksize is multiples of 64KiB */ + mtd->erasesize = (64 * 1024) << (extid & 0x03); + extid >>= 2; + /* Get buswidth information */ + *busw = (extid & 0x01) ? NAND_BUSWIDTH_16 : 0; + + } else { + /* + * Old devices have chip data hardcoded in the device id table + */ + mtd->erasesize = type->erasesize; + mtd->writesize = type->pagesize; + mtd->oobsize = mtd->writesize / 32; + *busw = type->options & NAND_BUSWIDTH_16; + } +} + /* * Get the flash and manufacturer id and lookup if the type is supported */ static const struct nand_flash_dev *nand_get_flash_type(struct mtd_info *mtd, struct nand_chip *chip, - int busw, int *maf_id, + int busw, + int *maf_id, int *dev_id, const struct nand_flash_dev *type) { - int dev_id, maf_idx; + int ret, maf_idx; int tmp_id, tmp_manf;
/* Select the device */ @@ -2434,7 +2553,7 @@ static const struct nand_flash_dev *nand_get_flash_type(struct mtd_info *mtd,
/* Try again to make sure, as some systems the bus-hold or other * interface concerns can cause random data which looks like a @@ -2449,10 +2568,10 @@ static const struct nand_flash_dev *nand_get_flash_type(struct mtd_info *mtd, tmp_manf = chip->read_byte(mtd); tmp_id = chip->read_byte(mtd);
@@ -2466,10 +2585,10 @@ static const struct nand_flash_dev *nand_get_flash_type(struct mtd_info *mtd, if (!type->name) { /* supress warning if there is no nand */ if (*maf_id != 0x00 && *maf_id != 0xff && - dev_id != 0x00 && dev_id != 0xff) + *dev_id != 0x00 && *dev_id != 0xff) printk(KERN_INFO "%s: unknown NAND device: " "Manufacturer ID: 0x%02x, Chip ID: 0x%02x\n", - __func__, *maf_id, dev_id); + __func__, *maf_id, *dev_id); return ERR_PTR(-ENODEV); }
@@ -2477,35 +2596,20 @@ static const struct nand_flash_dev *nand_get_flash_type(struct mtd_info *mtd, mtd->name = type->name;
/* Try to identify manufacturer */ for (maf_idx = 0; nand_manuf_ids[maf_idx].id != 0x0; maf_idx++) { @@ -2520,7 +2624,7 @@ static const struct nand_flash_dev *nand_get_flash_type(struct mtd_info *mtd, if (busw != (chip->options & NAND_BUSWIDTH_16)) { printk(KERN_INFO "NAND device: Manufacturer ID:" " 0x%02x, Chip ID: 0x%02x (%s %s)\n", *maf_id, - dev_id, nand_manuf_ids[maf_idx].name, mtd->name); + *dev_id, nand_manuf_ids[maf_idx].name, mtd->name); printk(KERN_WARNING "NAND bus width %d instead %d bit\n", (chip->options & NAND_BUSWIDTH_16) ? 16 : 8, busw ? 16 : 8); @@ -2543,15 +2647,6 @@ static const struct nand_flash_dev *nand_get_flash_type(struct mtd_info *mtd, chip->badblockpos = mtd->writesize > 512 ? NAND_LARGE_BADBLOCK_POS : NAND_SMALL_BADBLOCK_POS;
- /* Get chip options, preserve non chip based options */ - chip->options &= ~NAND_CHIPOPTIONS_MSK; - chip->options |= type->options & NAND_CHIPOPTIONS_MSK; - - /* - * Set chip as a default. Board drivers can override it, if necessary - */ - chip->options |= NAND_NO_AUTOINCR; - /* Check if chip is a not a samsung device. Do not clear the * options for chips which are not having an extended id. */ @@ -2569,7 +2664,7 @@ static const struct nand_flash_dev *nand_get_flash_type(struct mtd_info *mtd, chip->cmdfunc = nand_command_lp;
return type; @@ -2589,7 +2684,7 @@ static const struct nand_flash_dev *nand_get_flash_type(struct mtd_info *mtd, int nand_scan_ident(struct mtd_info *mtd, int maxchips, const struct nand_flash_dev *table) { - int i, busw, nand_maf_id; + int i, busw, nand_maf_id, nand_dev_id; struct nand_chip *chip = mtd->priv; const struct nand_flash_dev *type;
@@ -2599,7 +2694,7 @@ int nand_scan_ident(struct mtd_info *mtd, int maxchips, nand_set_defaults(chip, busw);
/* Read the flash type */ - type = nand_get_flash_type(mtd, chip, busw, &nand_maf_id, table); + type = nand_get_flash_type(mtd, chip, busw, &nand_maf_id, &nand_dev_id, table);
if (IS_ERR(type)) { #ifndef CONFIG_SYS_NAND_QUIET_TEST @@ -2618,7 +2713,7 @@ int nand_scan_ident(struct mtd_info *mtd, int maxchips, chip->cmdfunc(mtd, NAND_CMD_READID, 0x00, -1); /* Read manufacturer and device IDs */ if (nand_maf_id != chip->read_byte(mtd) || - type->id != chip->read_byte(mtd)) + nand_dev_id != chip->read_byte(mtd)) break; } #ifdef DEBUG diff --git a/include/linux/mtd/nand.h b/include/linux/mtd/nand.h index d299929..987a2ec 100644 --- a/include/linux/mtd/nand.h +++ b/include/linux/mtd/nand.h @@ -217,6 +217,71 @@ typedef enum { /* Keep gcc happy */ struct nand_chip;
+struct nand_onfi_params { + /* rev info and features block */ + /* 'O' 'N' 'F' 'I' */ + u8 sig[4]; + __le16 revision; + __le16 features; + __le16 opt_cmd; + u8 reserved[22]; + + /* manufacturer information block */ + char manufacturer[12]; + char model[20]; + u8 jedec_id; + __le16 date_code; + u8 reserved2[13]; + + /* memory organization block */ + __le32 byte_per_page; + __le16 spare_bytes_per_page; + __le32 data_bytes_per_ppage; + __le16 spare_bytes_per_ppage; + __le32 pages_per_block; + __le32 blocks_per_lun; + u8 lun_count; + u8 addr_cycles; + u8 bits_per_cell; + __le16 bb_per_lun; + __le16 block_endurance; + u8 guaranteed_good_blocks; + __le16 guaranteed_block_endurance; + u8 programs_per_page; + u8 ppage_attr; + u8 ecc_bits; + u8 interleaved_bits; + u8 interleaved_ops; + u8 reserved3[13]; + + /* electrical parameter block */ + u8 io_pin_capacitance_max; + __le16 async_timing_mode; + __le16 program_cache_timing_mode; + __le16 t_prog; + __le16 t_bers; + __le16 t_r; + __le16 t_ccs; + __le16 src_sync_timing_mode; + __le16 src_ssync_features; + __le16 clk_pin_capacitance_typ; + __le16 io_pin_capacitance_typ; + __le16 input_pin_capacitance_typ; + u8 input_pin_capacitance_max; + u8 driver_strenght_support; + __le16 t_int_r; + __le16 t_ald; + u8 reserved4[7]; + + /* vendor */ + u8 reserved5[90]; + + __le16 crc; +} __attribute__((packed)); + +#define ONFI_CRC_BASE 0x4F4E + + /** * struct nand_hw_control - Control structure for hardware controller (e.g ECC generator) shared among independent devices * @lock: protection lock @@ -406,6 +471,10 @@ struct nand_chip { int subpagesize; uint8_t cellinfo; int badblockpos; + int onfi_version; +#ifdef CONFIG_SYS_NAND_ONFI_DETECTION + struct nand_onfi_params onfi_params; +#endif
int state;
-- 1.7.1
Applied to u-boot-nand-flash next with this change:
diff --git a/drivers/mtd/nand/nand_base.c b/drivers/mtd/nand/nand_base.c index 0d7c819..fa286a8 100644 --- a/drivers/mtd/nand/nand_base.c +++ b/drivers/mtd/nand/nand_base.c @@ -2585,7 +2585,7 @@ static const struct nand_flash_dev *nand_get_flash_type(st type = nand_flash_ids;
for (; type->name != NULL; type++) - if (dev_id == type->id) + if (*dev_id == type->id) break;
-Scott
My bad, thanks for fixing this and committing the patch! -- Florian
-Scott
Florian Fainelli
Scott Wood
