[U-Boot] [PATCH 1/4] video: omap3_dss: add setup for LCD
Signed-off-by: Stefano Babic sbabic@denx.de --- arch/arm/include/asm/arch-omap3/dss.h | 23 ++++++++++++++++--- drivers/video/omap3_dss.c | 40 ++++++++++++++++++++++++++++++++- 2 files changed, 59 insertions(+), 4 deletions(-)
diff --git a/arch/arm/include/asm/arch-omap3/dss.h b/arch/arm/include/asm/arch-omap3/dss.h index 4c56e5e..911cc9a 100644 --- a/arch/arm/include/asm/arch-omap3/dss.h +++ b/arch/arm/include/asm/arch-omap3/dss.h @@ -60,6 +60,17 @@ struct dispc_regs { u32 global_alpha; /* 0x74 */ u32 size_dig; /* 0x78 */ u32 size_lcd; /* 0x7C */ + u32 gfx_base[2]; + u32 gfx_position; /* 0x88 */ + u32 gfx_size; /* 0x8C */ + u32 reserved_3[4]; /* 0x90 */ + u32 gfx_attributes; /* 0xA0 */ + u32 gfx_fifo_threshold; /* 0xA4 */ + u32 gfx_fifo_size_status; /* 0xA8 */ + u32 gfx_row_inc; /* 0xAC */ + u32 gfx_pixel_inc; /* 0xB0 */ + u32 gfx_window_skip; /* 0xB4 */ + u32 gfx_table_ba; /* 0xB8 */ };
/* VENC Registers */ @@ -120,6 +131,7 @@ struct venc_regs {
/* Few Register Offsets */ #define FRAME_MODE_SHIFT 1 +#define FUNC_GATED_SHIFT 9 #define TFTSTN_SHIFT 3 #define DATALINES_SHIFT 8
@@ -132,13 +144,16 @@ struct venc_regs { #define GP_OUT1 (1 << 16)
#define DISPC_ENABLE (LCD_ENABLE | \ - DIG_ENABLE | \ GO_LCD | \ - GO_DIG | \ GP_OUT0| \ GP_OUT1)
-/* Configure VENC DSS Params */ +#define DISPC_PCK_FREE_ENABLE (1 << 27) + +/* Register DSS_CONTROL */ +#define DISPC_CLK_SWITCH (1 << 0) +#define DSI_CLK_SWITCH (1 << 1) +#define VENC_CLOCK_MODE (1 << 2) #define VENC_CLK_ENABLE (1 << 3) #define DAC_DEMEN (1 << 4) #define DAC_POWERDN (1 << 5) @@ -148,6 +163,7 @@ struct venc_regs { DAC_DEMEN | \ DAC_POWERDN | \ VENC_OUT_SEL) + /* * Panel Configuration */ @@ -170,5 +186,6 @@ void omap3_dss_venc_config(const struct venc_regs *venc_cfg, u32 height, u32 width); void omap3_dss_panel_config(const struct panel_config *panel_cfg); void omap3_dss_enable(void); +void omap3_dss_setfb(void *addr);
#endif /* DSS_H */ diff --git a/drivers/video/omap3_dss.c b/drivers/video/omap3_dss.c index b322cc3..6e5849a 100644 --- a/drivers/video/omap3_dss.c +++ b/drivers/video/omap3_dss.c @@ -28,6 +28,8 @@ #include <common.h> #include <asm/io.h> #include <asm/arch/dss.h> +#include <asm/arch/clocks.h> +#include <asm/arch/clocks_omap3.h>
/* * Configure VENC for a given Mode (NTSC / PAL) @@ -105,16 +107,43 @@ void omap3_dss_venc_config(const struct venc_regs *venc_cfg, void omap3_dss_panel_config(const struct panel_config *panel_cfg) { struct dispc_regs *dispc = (struct dispc_regs *) OMAP3_DISPC_BASE; + struct dss_regs *dss = (struct dss_regs *) OMAP3_DSS_BASE;
writel(panel_cfg->timing_h, &dispc->timing_h); writel(panel_cfg->timing_v, &dispc->timing_v); writel(panel_cfg->pol_freq, &dispc->pol_freq); writel(panel_cfg->divisor, &dispc->divisor); writel(panel_cfg->lcd_size, &dispc->size_lcd); - writel((panel_cfg->load_mode << FRAME_MODE_SHIFT), &dispc->config); + writel((panel_cfg->load_mode << FRAME_MODE_SHIFT) | + (1 << FUNC_GATED_SHIFT), + &dispc->config); writel(((panel_cfg->panel_type << TFTSTN_SHIFT) | (panel_cfg->data_lines << DATALINES_SHIFT)), &dispc->control); writel(panel_cfg->panel_color, &dispc->default_color0); + + writel(panel_cfg->lcd_size, &dispc->gfx_size); + writel(0x91, &dispc->gfx_attributes); + writel(0x01, &dispc->gfx_row_inc); + writel(0x01, &dispc->gfx_pixel_inc); + writel(0x00, &dispc->gfx_window_skip); + + writel(VENC_CLK_ENABLE | DAC_DEMEN, + &dss->control); + +} + +void omap3_dss_clock_enable(int enable) +{ + struct prcm *prcm_base = (struct prcm *)PRCM_BASE; + + if (enable) { + setbits_le32(&prcm_base->fclken_dss, FCK_DSS_ON); + setbits_le32(&prcm_base->iclken_dss, ICK_DSS_ON); + } else { + clrbits_le32(&prcm_base->fclken_dss, FCK_DSS_ON); + clrbits_le32(&prcm_base->iclken_dss, ICK_DSS_ON); + } + }
/* @@ -129,3 +158,12 @@ void omap3_dss_enable(void) l |= DISPC_ENABLE; writel(l, &dispc->control); } + +void omap3_dss_setfb(void *addr) +{ + struct dispc_regs *dispc = (struct dispc_regs *) OMAP3_DISPC_BASE; + + writel((u32)addr, &dispc->gfx_base[0]); + writel((u32)addr, &dispc->gfx_base[1]); + +}
Signed-off-by: Stefano Babic sbabic@denx.de --- arch/arm/include/asm/arch-omap3/clocks.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/include/asm/arch-omap3/clocks.h b/arch/arm/include/asm/arch-omap3/clocks.h index bed0002..ab7b703 100644 --- a/arch/arm/include/asm/arch-omap3/clocks.h +++ b/arch/arm/include/asm/arch-omap3/clocks.h @@ -36,7 +36,7 @@ #define ICK_CORE2_ON 0x0000001f #define FCK_WKUP_ON 0x000000e9 #define ICK_WKUP_ON 0x0000003f -#define FCK_DSS_ON 0x00000005 +#define FCK_DSS_ON 0x00000007 #define ICK_DSS_ON 0x00000001 #define FCK_CAM_ON 0x00000001 #define ICK_CAM_ON 0x00000001
Signed-off-by: Stefano Babic sbabic@denx.de --- board/technexion/twister/twister.c | 49 ++++++++++++++++++++++++++++++++++++ include/configs/twister.h | 10 ++++++++ 2 files changed, 59 insertions(+)
diff --git a/board/technexion/twister/twister.c b/board/technexion/twister/twister.c index b927586..c1281b9 100644 --- a/board/technexion/twister/twister.c +++ b/board/technexion/twister/twister.c @@ -25,12 +25,15 @@
#include <common.h> #include <netdev.h> +#include <malloc.h> +#include <video_fb.h> #include <asm/io.h> #include <asm/arch/mem.h> #include <asm/arch/mux.h> #include <asm/arch/sys_proto.h> #include <asm/omap_gpio.h> #include <asm/arch/mmc_host_def.h> +#include <asm/arch/dss.h> #include <i2c.h> #include <asm/gpio.h> #ifdef CONFIG_USB_EHCI @@ -39,8 +42,23 @@ #endif #include "twister.h"
+#define XRES 480 +#define YRES 272 + DECLARE_GLOBAL_DATA_PTR;
+static GraphicDevice panel; +static const struct panel_config lcd_cfg = { + .timing_h = 0x01101d1b, /* Horizontal timing */ + .timing_v = 0x01400b02, /* Vertical timing */ + .pol_freq = 0x00023000, /* Pol Freq */ + .divisor = 0x0001000d, /* 33Mhz Pixel Clock */ + .lcd_size = ((YRES - 1) << 16 | (XRES - 1)), + .panel_type = 0x01, /* TFT */ + .data_lines = 0x03, /* 24 Bit RGB */ + .load_mode = 0x02 /* Frame Mode */ +}; + /* Timing definitions for Ethernet Controller */ static const u32 gpmc_smc911[] = { NET_GPMC_CONFIG1, @@ -135,6 +153,37 @@ int board_mmc_init(bd_t *bis) { return omap_mmc_init(0); } + +void *video_hw_init(void) +{ + + void *fb; + u32 size; + + size = XRES * YRES * lcd_cfg.data_lines; + fb = malloc(size); + if (!fb) { + printf("Frame buffer not allocated\n"); + return NULL; + } + + panel.winSizeX = XRES; + panel.winSizeY = YRES; + panel.plnSizeX = XRES; + panel.plnSizeY = YRES; + + panel.frameAdrs = (u32)fb; + panel.memSize = size; + + panel.gdfBytesPP = 2; + panel.gdfIndex = GDF_16BIT_565RGB; + + omap3_dss_panel_config(&lcd_cfg); + omap3_dss_enable(); + omap3_dss_setfb(fb); + + return (void *)&panel; +} #endif
#ifdef CONFIG_SPL_OS_BOOT diff --git a/include/configs/twister.h b/include/configs/twister.h index a852481..fb96f30 100644 --- a/include/configs/twister.h +++ b/include/configs/twister.h @@ -48,6 +48,16 @@ #define CONFIG_SMC911X_BASE 0x2C000000 #define CONFIG_SMC911X_NO_EEPROM
+#define CONFIG_VIDEO +#define CONFIG_CFB_CONSOLE +#define CONFIG_VGA_AS_SINGLE_DEVICE +#define CONFIG_SPLASH_SCREEN +#define CONFIG_VIDEO_LOGO +#define CONFIG_VIDEO_BMP_RLE8 +#define CONFIG_CMD_BMP +#define CONFIG_VIDEO_OMAP3 /* DSS Support */ +#define CONFIG_SYS_CONSOLE_IS_IN_ENV + #define CONFIG_EXTRA_ENV_SETTINGS CONFIG_TAM3517_SETTINGS \ "bootcmd=run nandboot\0"
[snip]
- .timing_h = 0x01101d1b, /* Horizontal timing */
- .timing_v = 0x01400b02, /* Vertical timing */
- .pol_freq = 0x00023000, /* Pol Freq */
- .divisor = 0x0001000d, /* 33Mhz Pixel Clock */
- .lcd_size = ((YRES - 1) << 16 | (XRES - 1)),
- .panel_type = 0x01, /* TFT */
- .data_lines = 0x03, /* 24 Bit RGB */
- .load_mode = 0x02 /* Frame Mode */
You need #if defined(CONFIG_VIDEO) && !defined(CONFIG_SPL_BUILD) type testing here[1] that the mt_ventoux board patch has. Shall I or will you v2? And I'll sanity test this on omap3_beagle tomorrow, but I suspect it's fine :)
[1]: twister.c:50: warning: 'panel' defined but not used
Hi Tom,
[snip]
I discussed with Anatolji about the patches and they need to be rebased and reworked - a v2 is necessary !
Stefano
Signed-off-by: Stefano Babic sbabic@denx.de --- board/teejet/mt_ventoux/mt_ventoux.c | 63 ++++++++++++++++++++++++++++++++++ board/teejet/mt_ventoux/mt_ventoux.h | 2 +- include/configs/mt_ventoux.h | 17 +++++++++ 3 files changed, 81 insertions(+), 1 deletion(-)
diff --git a/board/teejet/mt_ventoux/mt_ventoux.c b/board/teejet/mt_ventoux/mt_ventoux.c index c5eb42c..ecf91f7 100644 --- a/board/teejet/mt_ventoux/mt_ventoux.c +++ b/board/teejet/mt_ventoux/mt_ventoux.c @@ -21,13 +21,16 @@
#include <common.h> #include <netdev.h> +#include <malloc.h> #include <fpga.h> +#include <video_fb.h> #include <asm/io.h> #include <asm/arch/mem.h> #include <asm/arch/mux.h> #include <asm/arch/sys_proto.h> #include <asm/omap_gpio.h> #include <asm/arch/mmc_host_def.h> +#include <asm/arch/dss.h> #include <i2c.h> #include <spartan3.h> #include <asm/gpio.h> @@ -50,6 +53,28 @@ DECLARE_GLOBAL_DATA_PTR; #define FPGA_INIT 119 #define FPGA_DONE 154
+#define LCD_PWR 138 +#define LCD_PON_PIN 139 +#define XRES 480 +#define YRES 272 + +static const struct panel_config lcd_cfg = { + + .timing_h = ((4 /* hpb */ - 1) << 20) | + ((8 /*hfp */- 1) << 8) | + (41 /* hsw */ - 1), /* Horizontal timing */ + .timing_v = (2 /*vbp */ << 24) | + (4 /* vfp */ << 8) | + (10 - 1), /* Vertical timing */ + .pol_freq = 0x00000000, /* Pol Freq */ + .divisor = 0x0001000d, /* 33Mhz Pixel Clock */ + .lcd_size = ((YRES - 1) << 16 | (XRES - 1)), + .panel_type = 0x01, /* TFT */ + .data_lines = 0x03, /* 24 Bit RGB */ + .load_mode = 0x02, /* Frame Mode */ + .panel_color = 0, +}; + /* Timing definitions for FPGA */ static const u32 gpmc_fpga[] = { FPGA_GPMC_CONFIG1, @@ -231,3 +256,41 @@ int board_mmc_init(bd_t *bis) return omap_mmc_init(0); } #endif + +#if defined(CONFIG_VIDEO) && !defined(CONFIG_SPL_BUILD) +static GraphicDevice panel; + +void *video_hw_init(void) +{ + + void *fb; + u32 size; + + panel.gdfBytesPP = 4; + panel.gdfIndex = GDF_32BIT_X888RGB; + size = XRES * YRES * panel.gdfBytesPP * 2 + 1024; + + fb = (void *)0x80500000; + + printf("Frame buffer address 0x%p\n", fb); + + gpio_request(LCD_PWR, "LCD Power"); + gpio_request(LCD_PON_PIN, "LCD Pon"); + gpio_direction_output(LCD_PWR, 0); + gpio_direction_output(LCD_PON_PIN, 1); + + panel.winSizeX = XRES; + panel.winSizeY = YRES; + panel.plnSizeX = XRES; + panel.plnSizeY = YRES; + + panel.frameAdrs = (u32)fb; + panel.memSize = size; + + omap3_dss_panel_config(&lcd_cfg); + omap3_dss_setfb(fb); + omap3_dss_enable(); + + return (void *)&panel; +} +#endif diff --git a/board/teejet/mt_ventoux/mt_ventoux.h b/board/teejet/mt_ventoux/mt_ventoux.h index 9b2e43e..90331f4 100644 --- a/board/teejet/mt_ventoux/mt_ventoux.h +++ b/board/teejet/mt_ventoux/mt_ventoux.h @@ -221,7 +221,7 @@ const omap3_sysinfo sysinfo = { MUX_VAL(CP(MMC2_DAT5), (IDIS | PTU | EN | M4)) \ MUX_VAL(CP(MMC2_DAT6), (IDIS | PTU | EN | M4)) \ /* GPIO_138: LCD_ENVD */\ - MUX_VAL(CP(MMC2_DAT7), (IDIS | PTU | EN | M4)) \ + MUX_VAL(CP(MMC2_DAT7), (IDIS | PTD | EN | M4)) \ /* GPIO_139: LCD_PON */\ /* McBSP */\ MUX_VAL(CP(MCBSP_CLKS), (IEN | PTU | DIS | M0)) \ diff --git a/include/configs/mt_ventoux.h b/include/configs/mt_ventoux.h index 5db6d57..8ea0dc2 100644 --- a/include/configs/mt_ventoux.h +++ b/include/configs/mt_ventoux.h @@ -2,6 +2,9 @@ * Copyright (C) 2011 * Stefano Babic, DENX Software Engineering, sbabic@denx.de. * + * + * Configuration settings for the Teejet mt_ventoux board. + * * Copyright (C) 2009 TechNexion Ltd. * * This program is free software; you can redistribute it and/or modify @@ -24,6 +27,10 @@
#include "tam3517-common.h"
+#undef CONFIG_SYS_MALLOC_LEN +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (128 << 10) + \ + 6 * 1024 * 1024) + #define MACH_TYPE_AM3517_MT_VENTOUX 3832 #define CONFIG_MACH_TYPE MACH_TYPE_AM3517_MT_VENTOUX
@@ -62,6 +69,16 @@ #define CONFIG_FPGA_DELAY() udelay(1) #define CONFIG_SYS_FPGA_PROG_FEEDBACK
+#define CONFIG_VIDEO +#define CONFIG_CFB_CONSOLE +#define CONFIG_VGA_AS_SINGLE_DEVICE +#define CONFIG_SPLASH_SCREEN +/* #define CONFIG_VIDEO_LOGO */ +#define CONFIG_VIDEO_BMP_RLE8 +#define CONFIG_CMD_BMP +#define CONFIG_VIDEO_OMAP3 /* DSS Support */ +#define CONFIG_SYS_CONSOLE_IS_IN_ENV + #define CONFIG_EXTRA_ENV_SETTINGS CONFIG_TAM3517_SETTINGS \ "bootcmd=run net_nfs\0"
Stefano Babic
