[U-Boot] [PATCH 1/3] Fix IO port selection issue on MPC8544DS and MPC8572DS boards
The IO port selection is not correct on MPC8572DS and MPC8544DS board. This patch fixes this issue. For MPC8572 Port cfg_io_ports PCIE1 0x2, 0x3, 0x7, 0xb, 0xc, 0xf PCIE2 0x3, 0x7 PCIE3 0x7
For MPC8544 Port cfg_io_ports PCIE1 0x2, 0x3, 0x4, 0x5, 0x6, 0x7 PCIE2 0x4, 0x5, 0x6, 0x7 PCIE3 0x6, 0x7 Signed-off-by: Roy Zang tie-fei.zang@freescale.com --- board/freescale/mpc8544ds/mpc8544ds.c | 2 +- board/freescale/mpc8572ds/mpc8572ds.c | 8 +++++--- 2 files changed, 6 insertions(+), 4 deletions(-)
diff --git a/board/freescale/mpc8544ds/mpc8544ds.c b/board/freescale/mpc8544ds/mpc8544ds.c index 08ce817..a02a932 100644 --- a/board/freescale/mpc8544ds/mpc8544ds.c +++ b/board/freescale/mpc8544ds/mpc8544ds.c @@ -121,7 +121,7 @@ pci_init_board(void) volatile ccsr_fsl_pci_t *pci = (ccsr_fsl_pci_t *) CONFIG_SYS_PCIE3_ADDR; struct pci_controller *hose = &pcie3_hose; int pcie_ep = (host_agent == 1); - int pcie_configured = io_sel >= 1; + int pcie_configured = io_sel >= 6; struct pci_region *r = hose->regions;
if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE)){ diff --git a/board/freescale/mpc8572ds/mpc8572ds.c b/board/freescale/mpc8572ds/mpc8572ds.c index 79be628..11c30b2 100644 --- a/board/freescale/mpc8572ds/mpc8572ds.c +++ b/board/freescale/mpc8572ds/mpc8572ds.c @@ -166,7 +166,7 @@ void pci_init_board(void) struct pci_controller *hose = &pcie3_hose; int pcie_ep = (host_agent == 0) || (host_agent == 3) || (host_agent == 5) || (host_agent == 6); - int pcie_configured = io_sel >= 1; + int pcie_configured = (io_sel == 0x7); struct pci_region *r = hose->regions; u32 temp32;
@@ -234,7 +234,7 @@ void pci_init_board(void) struct pci_controller *hose = &pcie2_hose; int pcie_ep = (host_agent == 2) || (host_agent == 4) || (host_agent == 6) || (host_agent == 0); - int pcie_configured = io_sel & 4; + int pcie_configured = (io_sel == 0x3) || (io_sel == 0x7); struct pci_region *r = hose->regions;
if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE)){ @@ -287,7 +287,9 @@ void pci_init_board(void) struct pci_controller *hose = &pcie1_hose; int pcie_ep = (host_agent <= 1) || (host_agent == 4) || (host_agent == 5); - int pcie_configured = io_sel & 6; + int pcie_configured = (io_sel == 0x2) || (io_sel == 0x3) || + (io_sel == 0x7) || (io_sel == 0xb) || + (io_sel == 0xc) || (io_sel == 0xf); struct pci_region *r = hose->regions;
Roy Zang
