[PATCH] bootstd: Make BOOTSTD_FULL depend on BOOTSTD
Move BOOTSTD_FULL down in the file so that it can be enabled only when BOOTSTD is enabled. This prevents a build error if BOOTSTD is disabled but BOOTSTD_FULL is enabled.
boot/Kconfig | 26 +++++++++++++------------- 1 file changed, 13 insertions(+), 13 deletions(-)
diff --git a/boot/Kconfig b/boot/Kconfig index 5f491625c82..47952bbba23 100644 --- a/boot/Kconfig +++ b/boot/Kconfig @@ -371,19 +371,6 @@ config BOOTSTD U-Boot) - bootflow - a description of how to boot (owned by the distro)
-config BOOTSTD_FULL - bool "Enhanced features for standard boot" - default y if SANDBOX - help - This enables various useful features for standard boot, which are not - essential for operation: - - - bootdev, bootmeth commands - - extra features in the bootflow command - - support for selecting the ordering of bootmeths ("bootmeth order") - - support for selecting the ordering of bootdevs using the devicetree - as well as the "boot_targets" environment variable - config SPL_BOOTSTD bool "Standard boot support in VPL" depends on SPL && SPL_DM && SPL_OF_CONTROL && SPL_BLK @@ -406,6 +393,19 @@ config VPL_BOOTSTD
if BOOTSTD
+config BOOTSTD_FULL + bool "Enhanced features for standard boot" + default y if SANDBOX + help + This enables various useful features for standard boot, which are not + essential for operation: + + - bootdev, bootmeth commands + - extra features in the bootflow command + - support for selecting the ordering of bootmeths ("bootmeth order") + - support for selecting the ordering of bootdevs using the devicetree + as well as the "boot_targets" environment variable + config BOOTSTD_DEFAULTS bool "Select some common defaults for standard boot" depends on BOOTSTD
help
if BOOTSTD
help
config BOOTSTD_DEFAULTS bool "Select some common defaults for standard boot" depends on BOOTSTD -- 2.39.2.637.g21b0678d19-goog
Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org
Ilias Apalodimas
