[U-Boot] [PATCH] usb: gadget: composite: Correct recovery path for register
In case when usb_composite_register() failed once (for whatever reason), it will fail further even if all conditions are correct. Example:
=> fastboot 2 Invalid Controller Index couldn't find an available UDC g_dnl_register: failed!, error: -19 exit not allowed from main input shell.
=> fastboot 0 g_dnl_register: failed!, error: -22 exit not allowed from main input shell.
Despite that 0 is correct index for USB controller, "fastboot 0" command will fail, because "composite" structure wasn't cleared properly on previous fail (on "fastboot 2" command).
This patch fixes that erroneous behavior, allowing us to use composite even after previous failure.
Signed-off-by: Sam Protsenko semen.protsenko@linaro.org --- drivers/usb/gadget/composite.c | 8 +++++++- 1 file changed, 7 insertions(+), 1 deletion(-)
diff --git a/drivers/usb/gadget/composite.c b/drivers/usb/gadget/composite.c index 60f9272..d0ee784 100644 --- a/drivers/usb/gadget/composite.c +++ b/drivers/usb/gadget/composite.c @@ -1077,6 +1077,8 @@ static struct usb_gadget_driver composite_driver = { */ int usb_composite_register(struct usb_composite_driver *driver) { + int res; + if (!driver || !driver->dev || !driver->bind || composite) return -EINVAL;
@@ -1084,7 +1086,11 @@ int usb_composite_register(struct usb_composite_driver *driver) driver->name = "composite"; composite = driver;
- return usb_gadget_register_driver(&composite_driver); + res = usb_gadget_register_driver(&composite_driver); + if (res != 0) + composite = NULL; + + return res; }
+ Praneeth Bajjuri + Tom Rini + Rob Herring
On Tue, Feb 16, 2016 at 7:59 PM, Semen Protsenko semen.protsenko@linaro.org wrote:
=> fastboot 2 Invalid Controller Index couldn't find an available UDC g_dnl_register: failed!, error: -19 exit not allowed from main input shell. => fastboot 0 g_dnl_register: failed!, error: -22 exit not allowed from main input shell.
int res;
if (res != 0)
composite = NULL;
return res;
2.7.0
On Fri, Feb 19, 2016 at 9:34 PM, Sam Protsenko semen.protsenko@linaro.org wrote:
- Praneeth Bajjuri
- Tom Rini
- Rob Herring
int res;
if (res != 0)
composite = NULL;
return res;
2.7.0
bump
- Praneeth Bajjuri
- Tom Rini
- Rob Herring
int res;
if (res != 0)
composite = NULL;
return res;
2.7.0
bump
Looks fine. Lukasz, shall I pick this myself ?
btw if this isn't applied in a week, please ping me and I will pick it nonetheless.
Hi Marek,
- Praneeth Bajjuri
- Tom Rini
- Rob Herring
int res;
if (res != 0)
composite = NULL;
return res;
2.7.0
bump
I will add this to my tree. And test it afterwards.
I will send new PR with some other patches.
On 02/29/2016 11:11 AM, Lukasz Majewski wrote:
Hi Marek,
- Praneeth Bajjuri
- Tom Rini
- Rob Herring
int res;
if (res != 0)
composite = NULL;
return res;
2.7.0
bump
Roger, thanks!
Hi Marek,
Hi Marek,
- Praneeth Bajjuri
- Tom Rini
- Rob Herring
int res;
if (res != 0)
composite = NULL;
return res;
2.7.0
bump
This patch seems correct - no regression found.
Tested-by: Lukasz Majewski "l.majewski@samsung.com" Acked-by: Lukasz Majewski "l.majewski@samsung.com"
Patches which I thought that you didn't pull are already in u-boot-usb tree, so there is no point to prepare PR for this single patch.
Hence, Marek, please apply it directly to -usb tree.
Roger, thanks!
On 03/01/2016 01:42 PM, Lukasz Majewski wrote:
Hi Marek,
Hi Marek,
- Praneeth Bajjuri
- Tom Rini
- Rob Herring
On Tue, Feb 16, 2016 at 7:59 PM, Semen Protsenko semen.protsenko@linaro.org wrote: > From: Sam Protsenko semen.protsenko@linaro.org > > In case when usb_composite_register() failed once (for whatever > reason), it will fail further even if all conditions are > correct. Example: > > => fastboot 2 > Invalid Controller Index > couldn't find an available UDC > g_dnl_register: failed!, error: -19 > exit not allowed from main input shell. > > => fastboot 0 > g_dnl_register: failed!, error: -22 > exit not allowed from main input shell. > > Despite that 0 is correct index for USB controller, "fastboot 0" > command will fail, because "composite" structure wasn't cleared > properly on previous fail (on "fastboot 2" command). > > This patch fixes that erroneous behavior, allowing us to use > composite even after previous failure. > > Signed-off-by: Sam Protsenko semen.protsenko@linaro.org > --- > drivers/usb/gadget/composite.c | 8 +++++++- > 1 file changed, 7 insertions(+), 1 deletion(-) > > diff --git a/drivers/usb/gadget/composite.c > b/drivers/usb/gadget/composite.c index 60f9272..d0ee784 100644 > --- a/drivers/usb/gadget/composite.c > +++ b/drivers/usb/gadget/composite.c > @@ -1077,6 +1077,8 @@ static struct usb_gadget_driver > composite_driver = { */ > int usb_composite_register(struct usb_composite_driver *driver) > { > + int res; > + > if (!driver || !driver->dev || !driver->bind || > composite) return -EINVAL; > > @@ -1084,7 +1086,11 @@ int usb_composite_register(struct > usb_composite_driver *driver) driver->name = "composite"; > composite = driver; > > - return usb_gadget_register_driver(&composite_driver); > + res = usb_gadget_register_driver(&composite_driver); > + if (res != 0) > + composite = NULL; > + > + return res; > } > > /** > -- > 2.7.0 >
bump
Applied, thanks!
Lukasz Majewski
Sam Protsenko
Semen Protsenko
