[U-Boot] [PATCH] ARM: mvebu: switch db-88f6820-amc to DM for i2c
Move existing configuration from header file to defconfig or dts as appropriate.
Signed-off-by: Chris Packham judge.packham@gmail.com ---
arch/arm/dts/armada-385-amc.dts | 3 +++ configs/db-88f6820-amc_defconfig | 2 ++ include/configs/db-88f6820-amc.h | 7 ------- 3 files changed, 5 insertions(+), 7 deletions(-)
diff --git a/arch/arm/dts/armada-385-amc.dts b/arch/arm/dts/armada-385-amc.dts index a5a8a7f186db..4649c910c7b0 100644 --- a/arch/arm/dts/armada-385-amc.dts +++ b/arch/arm/dts/armada-385-amc.dts @@ -54,6 +54,7 @@ aliases { ethernet0 = ð0; ethernet1 = ð1; + i2c0 = &i2c0; spi1 = &spi1; };
@@ -68,6 +69,8 @@
internal-regs { i2c@11000 { + clock-frequency = <100000>; + u-boot,i2c-slave-addr = <0x0>; pinctrl-names = "default"; pinctrl-0 = <&i2c0_pins>; status = "okay"; diff --git a/configs/db-88f6820-amc_defconfig b/configs/db-88f6820-amc_defconfig index e90526a40226..63fc4db6c882 100644 --- a/configs/db-88f6820-amc_defconfig +++ b/configs/db-88f6820-amc_defconfig @@ -36,6 +36,8 @@ CONFIG_EFI_PARTITION=y # CONFIG_PARTITION_UUIDS is not set # CONFIG_SPL_PARTITION_UUIDS is not set CONFIG_SPL_OF_TRANSLATE=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_MVTWSI=y # CONFIG_MMC is not set CONFIG_NAND_PXA3XX=y CONFIG_SPI_FLASH=y diff --git a/include/configs/db-88f6820-amc.h b/include/configs/db-88f6820-amc.h index ba5c0901b1af..1cdefa054967 100644 --- a/include/configs/db-88f6820-amc.h +++ b/include/configs/db-88f6820-amc.h @@ -27,13 +27,6 @@ #define CONFIG_CMD_ENV #define CONFIG_CMD_PCI
-/* I2C */ -#define CONFIG_SYS_I2C -#define CONFIG_SYS_I2C_MVTWSI -#define CONFIG_I2C_MVTWSI_BASE0 MVEBU_TWSI_BASE -#define CONFIG_SYS_I2C_SLAVE 0x0 -#define CONFIG_SYS_I2C_SPEED 100000 - /* SPI NOR flash default params, used by sf commands */ #define CONFIG_SF_DEFAULT_BUS 1 #define CONFIG_SF_DEFAULT_SPEED 1000000
Thanks, Stefan
Applied to u-boot-marvell/master.
Thanks, Stefan
Chris Packham
Stefan Roese
