Re: [PATCH 10/13] ARM: dts: synquacer: Add device trees for DeveloperBox
On Wed, Apr 14, 2021 at 12:30:15AM +0900, Masami Hiramatsu wrote:
Add device trees for 96boards EE DeveloperBox and basement SynQuacer SoC dtsi. These files are imported from EDK2 with cosmetic change and modified for accessing SPI NOR flash.
Signed-off-by: Masami Hiramatsu masami.hiramatsu@linaro.org
arch/arm/dts/DeveloperBox.dts | 146 +++++++++ arch/arm/dts/Makefile | 2 arch/arm/dts/SynQuacer.dtsi | 590 +++++++++++++++++++++++++++++++++++++ arch/arm/dts/SynQuacerCaches.dtsi | 72 +++++
This poses a bit of a naming challenge. I assume, but please correct me if I'm wrong, that you don't intend to push these dts files to the Linux kernel. So that means EDK2 is the primary source of the files, yes? We want to keep them as-is from the upstream project, and note that relevant git hash/tag/etc that matches where we pulled from, to make future syncs easier, in the commit message.
I assume this is not part of the uniphier family, so we should start by naming these as arch/arm/dts/synquacer-... to fit with the general scheme. Perhaps -developerbox, -core and -caches ? And for any changes we do need, they go in a -u-boot.dtsi file and then potentially automatically included (if it fits in the logic we have today for that) or specifically #included otherwise.
Thanks.
Hello Tom,
Thank you for your comment!
2021年4月14日(水) 2:47 Tom Rini trini@konsulko.com:
Yes, those are originally written for the EDK2 and I ported it.
Let me confirm what you mean, is the git hash/tag/etc what the commit I copied from? and note it in commit message or in the devicetree file?
BTW, I made some changes on it for U-Boot drivers. - Enabled OP-TEE node by default (EDK2 checks OP-TEE existance and enables it) - Add SPI node information for accessing SPI-NOR from U-Boot (EDK2 embedded such information inside) Thus the DeveloperBox.dts may not be kept as-is.
OK. BTW, I'm not sure what is the best way to use SYS_CPU and SYS_SOC. This SoC family name is SynQuacer and the SoC itself is SC2A11. In this case, CONFIG_SYS_CPU=synquacer CONFIG_SYS_SOC=sc2a11 or CONFIG_SYS_SOC=synquacer-sc2a11 ?
It seems that (CONFIG_SYS_SOC)-u-boot.dtsi is automatically included, am I correct?
Thank you,
-- Masami Hiramatsu
On Wed, Apr 14, 2021 at 10:06:04AM +0900, Masami Hiramatsu wrote:
Hello Tom,
OK.
Correct.
These kinds of changes can be done in something such as DeveloperBox-u-boot.dtsi. Check out the logic in scripts/Makefile.lib around automatic inclusion of a "-u-boot.dtsi" file.
I think the first example you list is likely the best.
For the full list and how it works, see scripts/Makefile.lib
Hi Tom,
2021年4月15日(木) 2:33 Tom Rini trini@konsulko.com:
OK, I confirmed adding "CONFIG_DEFAULT_DEVICE_TREE-u-boot.dtsi" works.
I found that SYS_CPU is already set to "armv8" and it is used in the build process. So I will not change it.
Thank you,
Masami Hiramatsu
