[U-Boot-Users] [PATCH] xsengine: Fix no partition type specified, use DOS as default
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com
diff --git a/board/xsengine/flash.c b/board/xsengine/flash.c index 2b9afc7..a188e24 100644 --- a/board/xsengine/flash.c +++ b/board/xsengine/flash.c @@ -46,11 +46,11 @@ unsigned long flash_init (void) for (i = 0; i < CFG_MAX_FLASH_BANKS; i++) { switch (i) { case 0: - flash_get_size ((long *) PHYS_FLASH_1, &flash_info[i]); + flash_get_size ((vu_long *) PHYS_FLASH_1, &flash_info[i]); flash_get_offsets (PHYS_FLASH_1, &flash_info[i]); break; case 1: - flash_get_size ((long *) PHYS_FLASH_2, &flash_info[i]); + flash_get_size ((vu_long *) PHYS_FLASH_2, &flash_info[i]); flash_get_offsets (PHYS_FLASH_2, &flash_info[i]); break; default: diff --git a/include/configs/xsengine.h b/include/configs/xsengine.h index 5733933..766617e 100644 --- a/include/configs/xsengine.h +++ b/include/configs/xsengine.h @@ -32,6 +32,7 @@ #define CONFIG_PXA250 1 /* This is an PXA250 CPU */ #define CONFIG_XSENGINE 1 #define CONFIG_MMC 1 +#define CONFIG_DOS_PARTITION 1 #define BOARD_POST_INIT 1 #undef CONFIG_USE_IRQ /* we don't need IRQ/FIQ stuff */ #define CFG_HZ 3686400 /* incrementer freq: 3.6864 MHz */
In message 1192768425-12791-1-git-send-email-plagnioj@jcrosoft.com you wrote:
case 1:flash_get_size ((vu_long *) PHYS_FLASH_1, &flash_info[i]); flash_get_offsets (PHYS_FLASH_1, &flash_info[i]); break;
Ummm... you did not mention this change in your Subject.
That's not good. It would be better to split this into 2 independent commits.
