[U-Boot] Please pull u-boot-sunxi master
Hi Tom,
Please pull u-boot-sunxi/master into master for various small bugfixes, improvements and one new board.
The following changes since commit 0e6b7a28243175ae0874d53b6e6e4eff8548d71f:
Merge git://git.denx.de/u-boot-samsung (2015-05-18 09:15:15 -0400)
http://git.denx.de/u-boot-sunxi.git
for you to fetch changes up to 8a65f69c9cef09aebc20aca98a4ddbf2b4829995:
sunxi: Cache line size definition (2015-05-19 18:46:44 +0200)
---------------------------------------------------------------- Hans de Goede (6): sunxi: Set SYS_MALLOC_CLEAR_ON_INIT to n console: Fix pre-console flushing via cfb_console being very slow sunxi: Fix dram initialization not working on some a33 devices sunxi: Make DRAM_ODT_EN Kconfig setting a bool sunxi: video: Fix lvds panel support for sun6i+ sunxi: Add ga10h v1.1 defconfig
Laurent Itti (1): sunxi: add support for UART2 on A23/A33
Paul Kocialkowski (3): sunxi: Pass serial number through ATAG sunxi: VBUS detection function fixup in g_dnl_board_usb_cable_connected sunxi: Cache line size definition
README | 3 ++ arch/arm/cpu/armv7/sunxi/board.c | 4 +++ arch/arm/cpu/armv7/sunxi/dram_sun4i.c | 4 +-- arch/arm/cpu/armv7/sunxi/dram_sun8i_a23.c | 19 ++++++----- arch/arm/cpu/armv7/sunxi/dram_sun8i_a33.c | 6 ++-- arch/arm/include/asm/arch-sunxi/clock_sun6i.h | 3 ++ arch/arm/include/asm/arch-sunxi/display.h | 12 +++++++ arch/arm/include/asm/arch-sunxi/dram_sun4i.h | 3 +- arch/arm/include/asm/arch-sunxi/dram_sun8i_a23.h | 1 + arch/arm/include/asm/arch-sunxi/gpio.h | 1 + board/sunxi/Kconfig | 28 ++++++++++++----- board/sunxi/MAINTAINERS | 1 + board/sunxi/board.c | 22 ++++++++++++- board/sunxi/dram_sun4i_auto.c | 3 +- board/sunxi/dram_sun5i_auto.c | 3 +- common/console.c | 40 +++++++++++++----------- configs/ga10h_v1_1_defconfig | 29 +++++++++++++++++ drivers/video/sunxi_display.c | 18 ++++++++++- include/configs/sunxi-common.h | 8 ++++- 19 files changed, 161 insertions(+), 47 deletions(-) create mode 100644 configs/ga10h_v1_1_defconfig
Regards,
Hans
On Tue, May 19, 2015 at 10:23:54PM +0200, Hans de Goede wrote:
Hi Tom,
Hans de Goede
