[U-Boot] [PATCH] lsxl: support power switch
This patch restores the Linkstation's original behaviour when powering off. Once the (soft) power switch is turned off, linux will reboot and the bootloader turns off HDD and USB power. Then it loops as long as the switch is in the off position, before continuing the boot process again.
Additionally, this patch fixes the board function set_led(LED_OFF).
Signed-off-by: Michael Walle michael@walle.cc Cc: Prafulla Wadaskar prafulla@marvell.com --- board/buffalo/lsxl/lsxl.c | 22 +++++++++++++++++++++- 1 files changed, 21 insertions(+), 1 deletions(-)
diff --git a/board/buffalo/lsxl/lsxl.c b/board/buffalo/lsxl/lsxl.c index fe15511..b3f31d6 100644 --- a/board/buffalo/lsxl/lsxl.c +++ b/board/buffalo/lsxl/lsxl.c @@ -158,7 +158,7 @@ static void set_led(int state) { switch (state) { case LED_OFF: - __set_led(0, 0, 0, 0, 0, 0); + __set_led(0, 0, 0, 1, 1, 1); break; case LED_ALARM_ON: __set_led(0, 0, 0, 0, 1, 1); @@ -192,6 +192,25 @@ int board_init(void) }
#ifdef CONFIG_MISC_INIT_R +static void check_power_switch(void) +{ + if (kw_gpio_get_value(GPIO_POWER_SWITCH)) { + /* turn off HDD and USB power */ + kw_gpio_set_value(GPIO_HDD_POWER, 0); + kw_gpio_set_value(GPIO_USB_VBUS, 0); + set_led(LED_OFF); + + /* loop until released */ + while (kw_gpio_get_value(GPIO_POWER_SWITCH)) + ; + + /* turn power on again */ + kw_gpio_set_value(GPIO_HDD_POWER, 1); + kw_gpio_set_value(GPIO_USB_VBUS, 1); + set_led(LED_POWER_BLINKING); + } +} + void check_enetaddr(void) { uchar enetaddr[6]; @@ -261,6 +280,7 @@ static void check_push_button(void)
int misc_init_r(void) { + check_power_switch(); check_enetaddr(); check_push_button();
-----Original Message----- From: Michael Walle [mailto:michael@walle.cc] Sent: 31 July 2012 02:17 To: u-boot@lists.denx.de Cc: Michael Walle; Prafulla Wadaskar Subject: [PATCH] lsxl: support power switch
break; case LED_ALARM_ON: __set_led(0, 0, 0, 0, 1, 1);__set_led(0, 0, 0, 1, 1, 1);
- if (kw_gpio_get_value(GPIO_POWER_SWITCH)) {
set_led(LED_OFF);
Please avoid infinite loop, may you introduce timeout?
- check_power_switch(); check_enetaddr(); check_push_button();
Ack for rest of the code.
Regards... Prafulla . . .
set_led(LED_OFF);
actually, thats the use case, to loop indefinitely ;) See the commit message. The GPIO is a switch not a button. As long as it is switched to "Power Off" uboot should loop.
Thanks for the review.
-----Original Message----- From: Michael Walle [mailto:michael@walle.cc] Sent: 31 July 2012 16:22 To: Prafulla Wadaskar Cc: Michael Walle; u-boot@lists.denx.de Subject: RE: [PATCH] lsxl: support power switch
powering
the
the
set_led(LED_OFF);
Okay got it. Ack for this patch.
Am Dienstag 31 Juli 2012, 13:12:19 schrieb Prafulla Wadaskar:
powering
the
the
switch (state) {
case LED_OFF:
break;
set_led(LED_OFF);
ok thanks, can you apply it to your repository?
-----Original Message----- From: Michael Walle [mailto:michael@walle.cc] Sent: 01 August 2012 01:58 To: Prafulla Wadaskar Cc: u-boot@lists.denx.de Subject: Re: [PATCH] lsxl: support power switch
powering
and
the
as
the
again.
set_led(LED_OFF).
switch (state) {
case LED_OFF:
break;
set_led(LED_OFF);
commit
switched
Sure..
-----Original Message----- From: Prafulla Wadaskar Sent: 01 August 2012 12:58 To: 'Michael Walle' Cc: u-boot@lists.denx.de Subject: RE: [PATCH] lsxl: support power switch
powering
and
the
as
the
again.
set_led(LED_OFF).
switch (state) {
case LED_OFF:
break;
set_led(LED_OFF);
commit
switched
Sure..
Applied to u-boot-marvell.git master branch
Michael Walle
Prafulla Wadaskar
