[U-Boot] [PATCH 1/2] drivers/mtd/spi: Enable 4B opcodes for SPANSION s25fl512s
Signed-off-by: Ashish Kumar Ashish.Kumar@nxp.com --- drivers/mtd/spi/spi-nor-ids.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/mtd/spi/spi-nor-ids.c b/drivers/mtd/spi/spi-nor-ids.c index ec929760ee..a89c1910d9 100644 --- a/drivers/mtd/spi/spi-nor-ids.c +++ b/drivers/mtd/spi/spi-nor-ids.c @@ -177,7 +177,7 @@ const struct flash_info spi_nor_ids[] = { { INFO("s25sl064p", 0x010216, 0x4d00, 64 * 1024, 128, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, { INFO("s25fl256s0", 0x010219, 0x4d00, 256 * 1024, 128, USE_CLSR) }, { INFO("s25fl256s1", 0x010219, 0x4d01, 64 * 1024, 512, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | USE_CLSR) }, - { INFO6("s25fl512s", 0x010220, 0x4d0081, 256 * 1024, 256, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | USE_CLSR) }, + { INFO6("s25fl512s", 0x010220, 0x4d0081, 256 * 1024, 256, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | USE_CLSR | SPI_NOR_4B_OPCODES) }, { INFO("s25fl512s_256k", 0x010220, 0x4d00, 256 * 1024, 256, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | USE_CLSR) }, { INFO("s25fl512s_64k", 0x010220, 0x4d01, 64 * 1024, 1024, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | USE_CLSR) }, { INFO("s25fl512s_512k", 0x010220, 0x4f00, 256 * 1024, 256, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | USE_CLSR) },
Signed-off-by: Ashish Kumar ashish.kumar@nxp.com Signed-off-by: Rajat Srivastava rajat.srivastava@nxp.com --- drivers/spi/fsl_qspi.c | 38 +++++++++++++++++++++++++------------- 1 file changed, 25 insertions(+), 13 deletions(-)
diff --git a/drivers/spi/fsl_qspi.c b/drivers/spi/fsl_qspi.c index 1598c4f698..1d26c6344b 100644 --- a/drivers/spi/fsl_qspi.c +++ b/drivers/spi/fsl_qspi.c @@ -26,7 +26,7 @@ DECLARE_GLOBAL_DATA_PTR; #define TX_BUFFER_SIZE 0x40 #endif
-#define OFFSET_BITS_MASK GENMASK(23, 0) +#define OFFSET_BITS_MASK GENMASK(27, 0)
#define FLASH_STATUS_WEL 0x02
@@ -754,7 +754,8 @@ static void qspi_op_erase(struct fsl_qspi_priv *priv) while (qspi_read32(priv->flags, ®s->sr) & QSPI_SR_BUSY_MASK) ;
- if (priv->cur_seqid == QSPI_CMD_SE) { + if ((priv->cur_seqid == QSPI_CMD_SE_4B) || + (priv->cur_seqid == QSPI_CMD_SE)) { qspi_write32(priv->flags, ®s->ipcr, (SEQID_SE << QSPI_IPCR_SEQID_SHIFT) | 0); } else if (priv->cur_seqid == QSPI_CMD_BE_4K) { @@ -775,31 +776,40 @@ int qspi_xfer(struct fsl_qspi_priv *priv, unsigned int bitlen, u32 txbuf;
WATCHDOG_RESET(); - if (dout) { if (flags & SPI_XFER_BEGIN) { priv->cur_seqid = *(u8 *)dout; - memcpy(&txbuf, dout, 4); + if (FSL_QSPI_FLASH_SIZE > SZ_16M && bytes > 4) + memcpy(&txbuf, dout + 1, 4); + else + memcpy(&txbuf, dout, 4); }
if (flags == SPI_XFER_END) { priv->sf_addr = wr_sfaddr; - qspi_op_write(priv, (u8 *)dout, bytes); - return 0; + if (priv->cur_seqid == QSPI_CMD_PP || + priv->cur_seqid == QSPI_CMD_PP_4B || + priv->cur_seqid == QSPI_CMD_WRAR) { + qspi_op_write(priv, (u8 *)dout, bytes); + return 0; + } }
- if (priv->cur_seqid == QSPI_CMD_FAST_READ || - priv->cur_seqid == QSPI_CMD_RDAR) { + if ((priv->cur_seqid == QSPI_CMD_FAST_READ) || + (priv->cur_seqid == QSPI_CMD_FAST_READ_4B) || + (priv->cur_seqid == QSPI_CMD_RDAR)) { priv->sf_addr = swab32(txbuf) & OFFSET_BITS_MASK; } else if ((priv->cur_seqid == QSPI_CMD_SE) || - (priv->cur_seqid == QSPI_CMD_BE_4K)) { + priv->cur_seqid == QSPI_CMD_SE_4B || + priv->cur_seqid == QSPI_CMD_BE_4K) { priv->sf_addr = swab32(txbuf) & OFFSET_BITS_MASK; qspi_op_erase(priv); } else if (priv->cur_seqid == QSPI_CMD_PP || + priv->cur_seqid == QSPI_CMD_PP_4B || priv->cur_seqid == QSPI_CMD_WRAR) { wr_sfaddr = swab32(txbuf) & OFFSET_BITS_MASK; } else if ((priv->cur_seqid == QSPI_CMD_BRWR) || - (priv->cur_seqid == QSPI_CMD_WREAR)) { + (priv->cur_seqid == QSPI_CMD_WREAR)) { #ifdef CONFIG_SPI_FLASH_BAR wr_sfaddr = 0; #endif @@ -807,7 +817,8 @@ int qspi_xfer(struct fsl_qspi_priv *priv, unsigned int bitlen, }
if (din) { - if (priv->cur_seqid == QSPI_CMD_FAST_READ) { + if ((priv->cur_seqid == QSPI_CMD_FAST_READ) || + (priv->cur_seqid == QSPI_CMD_FAST_READ_4B)) { #ifdef CONFIG_SYS_FSL_QSPI_AHB qspi_ahb_read(priv, din, bytes); #else @@ -815,10 +826,11 @@ int qspi_xfer(struct fsl_qspi_priv *priv, unsigned int bitlen, #endif } else if (priv->cur_seqid == QSPI_CMD_RDAR) { qspi_op_read(priv, din, bytes); - } else if (priv->cur_seqid == QSPI_CMD_RDID) + } else if (priv->cur_seqid == QSPI_CMD_RDID) { qspi_op_rdid(priv, din, bytes); - else if (priv->cur_seqid == QSPI_CMD_RDSR) + } else if (priv->cur_seqid == QSPI_CMD_RDSR) { qspi_op_rdsr(priv, din, bytes); + } #ifdef CONFIG_SPI_FLASH_BAR else if ((priv->cur_seqid == QSPI_CMD_BRRD) || (priv->cur_seqid == QSPI_CMD_RDEAR)) {
Commit message is missing. But from $patch subject, I infer that $patch is adding new feature and not actually fixing something broken? If so, you should move the driver over to use spi-mem APIs instead of adding more features and hard coding more flash specific commands in the driver. This makes driver duplicate more of spi-nor core code. I discourage adding new features w/o moving driver over to spi-mem. IMHO, converting the driver would not be a huge effort. And I believe its already done in kernel.
Regards Vignesh
- if ((priv->cur_seqid == QSPI_CMD_SE_4B) ||
qspi_write32(priv->flags, ®s->ipcr, (SEQID_SE << QSPI_IPCR_SEQID_SHIFT) | 0); } else if (priv->cur_seqid == QSPI_CMD_BE_4K) {(priv->cur_seqid == QSPI_CMD_SE)) {
WATCHDOG_RESET();
else
} else if ((priv->cur_seqid == QSPI_CMD_SE) ||(priv->cur_seqid == QSPI_CMD_RDAR)) { priv->sf_addr = swab32(txbuf) & OFFSET_BITS_MASK;
} else if (priv->cur_seqid == QSPI_CMD_PP ||priv->cur_seqid == QSPI_CMD_BE_4K) { priv->sf_addr = swab32(txbuf) & OFFSET_BITS_MASK; qspi_op_erase(priv);
} else if ((priv->cur_seqid == QSPI_CMD_BRWR) ||priv->cur_seqid == QSPI_CMD_PP_4B || priv->cur_seqid == QSPI_CMD_WRAR) { wr_sfaddr = swab32(txbuf) & OFFSET_BITS_MASK;
if (din) {
-----Original Message----- From: Vignesh Raghavendra vigneshr@ti.com Sent: Wednesday, April 24, 2019 10:17 PM To: Rajat Srivastava rajat.srivastava@nxp.com; u-boot@lists.denx.de; jagan@openedev.com Cc: Ashish Kumar ashish.kumar@nxp.com Subject: [EXT] Re: [PATCH 2/2] fsl_qspi: Improve QSPI driver to incorporate 4 byte commands
Caution: EXT Email
I'll add proper commit message in the next patch version.
Earlier the framework was designed to work for only 3-byte opcodes but our controller supports flashes of size greater than 16 MB. As a workaround, FSL QSPI driver used to explicitly send 4-byte opcodes for 3-byte opcodes sent by framework to the flash. Also there used to exist a temporary patch for framework which never got accepted In upstream. Now the new framework supports 4-byte opcodes and FSL QSPI driver needs correction. I am not introducing any new feature. I am just fixing the driver to suit the current framework.
Please let me know your feedback.
Regards Rajat
Regards Vignesh
WATCHDOG_RESET();
else
memcpy(&txbuf, dout, 4); } if (flags == SPI_XFER_END) { priv->sf_addr = wr_sfaddr;
bitlen,
} if (din) {
Caution: EXT Email
With SPL_FLASH_BAR set fsl_qspi driver should never see 4 byte opcodes and should work like it did before. I guess you are disabling SPI_FLASH_BAR?
Please add all details to the commit message and I recommend you to move the driver over to spi-mem as soon as possible. Else you would have to keep handling new opcodes in your driver as and when spi-nor-core changes.
Regards Vignesh
Regards Rajat
Regards Vignesh
WATCHDOG_RESET();
else
bitlen,
} if (din) {
Caution: EXT Email
Regards Vignesh
Regards Rajat
I started moving the driver to spi-mem, by porting the kernel driver over to U-Boot. I still have some Kconfig dependency problem for the LS2081 platform (CONFIG_SPI_MEM is not enabled implicitly), that needs to be solved, otherwise it should be more or less ready.
For anyone who wants to check/test the current state, look here: [1]
Regards, Frieder
[1]: https://github.com/fschrempf/u-boot/commits/fsl_qspi_spimem_port
Caution: EXT Email
Regards Vignesh
Regards Rajat
I am not familiar with ls2081 defconfig, but it seems like CONFIG_SPI_FLASH is not enabled in ls2081ardb_defconfig due to which SPI_MEM does not be selected. Jagan had a patch to make DM_SPI_FLASH enable SPI_FLASH[2] to fix such configs.
That's great!
Regards, Frieder
-----Original Message----- From: U-Boot u-boot-bounces@lists.denx.de On Behalf Of Schrempf Frieder Sent: Tuesday, April 30, 2019 1:14 PM To: Vignesh Raghavendra vigneshr@ti.com; Rajat Srivastava rajat.srivastava@nxp.com; u-boot@lists.denx.de; jagan@openedev.com Subject: [EXT] Re: [U-Boot] [PATCH 2/2] fsl_qspi: Improve QSPI driver to incorporate 4 byte commands
Caution: EXT Email
Caution: EXT Email
upstream.
changes.
Regards Vignesh
Regards Rajat
the driver.
done in kernel.
I started moving the driver to spi-mem, by porting the kernel driver over to U- Boot. I still have some Kconfig dependency problem for the LS2081 platform (CONFIG_SPI_MEM is not enabled implicitly), that needs to be solved, otherwise it should be more or less ready.
Hi Frieder,
What is the change, it seems it is moving the driver from Linux as it is to uboot ? I am not sure how stable is the current Linux driver, since it is not yet tested by FSL/NXP system test team. Last time I tested the current Linux driver(QSPI) it was functional in only 1-1-1 mode. Moving to u-boot may not be good idea at this point of time.
How do you plan to cater CONFIG_SPI_BAR change in uboot now. Some old board still uses flash that supports CONFIG_SPI_BAR.
Me and Rajat have recently posted patches to fix current u-boot driver to be functional with new frame work pushed by Vignesh, and it serves all the current supported board with and without CONFIG_SPI_BAR.
May be spi-nxp-fspi.c can be a good starting point, but then again I not sure how booting from serial-nand will be taken care in that case.
Regards Ashish
Regards, Frieder
com%2Ffschrempf%2Fu- boot%2Fcommits%2Ffsl_qspi_spimem_port&data=02%7C01%7CAshish.K umar%40nxp.com%7C459c6d89b8b748c928ca08d6cd3fa6cd%7C686ea1d3bc 2b4c6fa92cd99c5c301635%7C0%7C0%7C636922070665346047&sdata =8HplTAZYeEaBrXZd38h4hgT7hLRixjobx%2ByCjL%2FjJjc%3D&reserved=0 _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.de nx.de%2Flistinfo%2Fu- boot&data=02%7C01%7CAshish.Kumar%40nxp.com%7C459c6d89b8b74 8c928ca08d6cd3fa6cd%7C686ea1d3bc2b4c6fa92cd99c5c301635%7C0%7C0 %7C636922070665346047&sdata=sk6GB%2BMeEKjqR5BR5K9PX6yYayC nyDUG69LTWl05xlM%3D&reserved=0
Hi Ashish,
Caution: EXT Email
Caution: EXT Email
upstream.
changes.
Regards Vignesh
Regards Rajat
the driver.
done in kernel.
Hi Frieder,
Yes, it's moving the current Linux driver to U-Boot with some small compatibility changes and simplifications.
The current mainline Linux driver is a SPI controller driver using the SPI MEM API and it replaced the old SPI NOR driver in Linux 5.1. If nothing went wrong in the upstreaming process, the driver should be just as good as the old one, while bringing all the advantages of the new SPI MEM interface. The driver does support 1-1-1 mode, just like all other modes supported by the QSPI controller.
While upstreaming to the kernel, the driver was tested by Han Xu and Yogesh Gaur.
The new driver is not a SPI NOR driver, so it does not care about CONFIG_SPI_BAR. It just handels SPI MEM operations created by the upper layer.
Please have a look at the SPI MEM and SPI NAND APIs to understand why porting the Linux driver is the right thing to do instead of patching the old driver. By supporting the SPI MEM API, the driver will implicitly allow to interface SPI NAND chips.
Thanks, Frieder
-----Original Message----- From: Schrempf Frieder frieder.schrempf@kontron.de Sent: Thursday, May 2, 2019 12:38 PM To: Ashish Kumar ashish.kumar@nxp.com; Vignesh Raghavendra vigneshr@ti.com; Rajat Srivastava rajat.srivastava@nxp.com; u- boot@lists.denx.de; jagan@openedev.com Subject: Re: [EXT] Re: [U-Boot] [PATCH 2/2] fsl_qspi: Improve QSPI driver to incorporate 4 byte commands
Caution: EXT Email
Hi Ashish,
jagan@openedev.com
Caution: EXT Email
Caution: EXT Email
On 24-Apr-19 6:10 PM, Rajat Srivastava wrote: > Signed-off-by: Ashish Kumar ashish.kumar@nxp.com > Signed-off-by: Rajat Srivastava rajat.srivastava@nxp.com
upstream.
SPI_FLASH_BAR?
changes.
Regards Vignesh
Regards Rajat
the driver.
done in kernel.
Hi Frieder,
uboot ?
Hi Frieder,
I had a discussion Han Xu, He was also able to find some defects with current linux QSPI driver on i.mx7 platform.
I had also tried testing this with QUAD/DUAL on LS1088 and It was not functional. "s25fl512s", INFO(0x010220, 0x4d00, 256 * 1024, 256, SPI_NOR_DUAL_READ |SPI_NOR_QUAD_READ | USE_CLSR| SPI_NOR_4B_OPCODES),
I will be debugging further and update with findings in sometime.
Regards Ashish
Thanks, Frieder
Hi.
- { INFO6("s25fl512s", 0x010220, 0x4d0081, 256 * 1024, 256, SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | USE_CLSR | SPI_NOR_4B_OPCODES) },
You should not be needing this change to enable 4 Byte opcodes. From spi-nor-core.c:
if (nor->addr_width) { /* already configured from SFDP */ } else if (info->addr_width) { nor->addr_width = info->addr_width; } else if (mtd->size > SZ_16M) { #ifndef CONFIG_SPI_FLASH_BAR /* enable 4-byte addressing if the device exceeds 16MiB */ nor->addr_width = 4; if (JEDEC_MFR(info) == SNOR_MFR_SPANSION || info->flags & SPI_NOR_4B_OPCODES) spi_nor_set_4byte_opcodes(nor, info); #else /* Configure the BAR - discover bank cmds and read current bank */ nor->addr_width = 3; ret = read_bar(nor, info); if (ret < 0) return ret; #endif } [...]
So as long as SPI_FLASH_BAR is not set, 4 Byte opcodes are used by default with Spansion flashes >16M size. If that's not the case, then we need to root cause the actual bug instead of adding SPI_NOR_4B_OPCODES to s25fl512s
Regards Vignesh
-----Original Message----- From: Vignesh Raghavendra vigneshr@ti.com Sent: Wednesday, April 24, 2019 10:08 PM To: Rajat Srivastava rajat.srivastava@nxp.com; u-boot@lists.denx.de; jagan@openedev.com Cc: Ashish Kumar ashish.kumar@nxp.com Subject: [EXT] Re: [PATCH 1/2] drivers/mtd/spi: Enable 4B opcodes for SPANSION s25fl512s
Caution: EXT Email
Hi.
- SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | USE_CLSR |
- SPI_NOR_4B_OPCODES) },
#endif } [...]
You are right. I've tested without using SPI_NOR_4B_OPCODES flag and it is working now. Deprecating this patch now.
Regards Rajat
Ashish Kumar
Rajat Srivastava
Schrempf Frieder
Vignesh Raghavendra
