[U-Boot] U-boot memory test results
Hi all,
I want to perform memory test (FLASH) during U-boot and read the results after the operating system (Linux) is booted up. Is it possible? If so, can anyone guide me to do so?
Regards Lakshmi
-- View this message in context: http://u-boot.10912.n7.nabble.com/U-boot-memory-test-results-tp171691.html Sent from the U-Boot mailing list archive at Nabble.com.
Hello aryanlak,
Am 17.01.2014 09:11, schrieb aryanlak:
Hi all,
On which plattform do you want to try this?
You can activate CONFIG_LOGBUFFER in your board config file, and try it, grep for "CONFIG_LOGBUFFER" for examples. The enbw_cmc is a good example for an arm plattform, but you need also adaptions in your Linux kernel, as this is not supported in mainline kernel! See here a try to bring it into mainline
http://lwn.net/Articles/501425/
But this patch does not longer works for newer kernels, as logbuffer handling had changed ... so maybe, you have to do a complete rework ...
bye, Heiko
aryanlak
Heiko Schocher
