[U-Boot] [PATCH] MX31: QONG: drop config.mk
Remove obsolete config.mk from QONG board.
Signed-off-by: Stefano Babic sbabic@denx.de --- board/davedenx/qong/config.mk | 3 --- include/configs/qong.h | 4 +++- 2 files changed, 3 insertions(+), 4 deletions(-) delete mode 100644 board/davedenx/qong/config.mk
diff --git a/board/davedenx/qong/config.mk b/board/davedenx/qong/config.mk deleted file mode 100644 index ea1c1b0..0000000 --- a/board/davedenx/qong/config.mk +++ /dev/null @@ -1,3 +0,0 @@ -CONFIG_SYS_TEXT_BASE = 0xa0000000 - -# PLATFORM_CPPFLAGS += -DDEBUG diff --git a/include/configs/qong.h b/include/configs/qong.h index 405c438..78b3701 100644 --- a/include/configs/qong.h +++ b/include/configs/qong.h @@ -24,7 +24,7 @@
#include <asm/arch/imx-regs.h>
- /* High Level Configuration Options */ +/* High Level Configuration Options */ #define CONFIG_ARM1136 1 /* This is an arm1136 CPU core */ #define CONFIG_MX31 1 /* in a mx31 */ #define CONFIG_QONG 1 @@ -34,6 +34,8 @@ #define CONFIG_DISPLAY_CPUINFO #define CONFIG_DISPLAY_BOARDINFO
+#define CONFIG_SYS_TEXT_BASE 0xa0000000 + #define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ #define CONFIG_SETUP_MEMORY_TAGS 1 #define CONFIG_INITRD_TAG 1
Stefano Babic
