[U-Boot] [PATCH 00/52] Support OF_PLATDATA in TPL, enable RK3368 DRAM init and add RK3368-uQ7
Here's a series that has a lot going on, but I didn't want to split it to allow everyone to understand the motivation between some of the changes to the SPL/TPL framework. The short summary of this is "enablement for DRAM init on the RK3368 with everything else that's necessary to do it using OF_PLATDATA in TPL".
Enabling the RK3368 created a few more challenges that I'd expected: - I needed different stack locations, text addresses and sizes for TPL and SPL - the TPL stage was to use OF_PLATDATA and SPL was to use full OF_CONTROL - with the RK3368 TPL stage, there was a need to extend the back-to-bootrom support for Rockchip to AArch64 - I wanted to start folding some of the Rockchip specific SPL support (i.e. back-to-bootrom) back into the general SPL framework to allow using it as a general boot method
So I ended up separating quite a bit of features between SPL and TPL while keeping things transparent to the few other boards using TPL (at least I hope that things are transparent, as we didn't have any of those in our lab to test on)...
Tested with: RK3368-uQ7, Debian 9, Linux 4.13-rc1.
Just one final remark: the DMC driver for the RK3368 currently covers the configuration we use on the RK3368-uQ7 (i.e. 32bit wide, 2 ranks) and is stress-tested (including 8-way SPEC runs) at all 3 supported speeds. I've built a bit of infrastructure (e.g. the way the memory-schedule is determined) that I hope will be a useful starting-point in unifying the drivers for the various closely related DRAM controllers (e.g. for the RK3288) for Rockchip devices in the future.
Klaus Goger (1): rockchip: board: puma_rk3399: rename ATF firmware
Philipp Tomsich (51): spl: add a 'return to bootrom' boot method spl: configure 'return to bootrom' separately for SPL and TPL rockchip: back-to-bootrom: add 'back-to-bootrom' support for AArch64 rockchip: back-to-bootrom: split BACK_TO_BOOTROM for TPL/SPL rockchip: back-to-bootrom: simplify the #ifdef-check for LIBGENERIC in TPL/SPL spl: dm: Kconfig: use more specific prereqs for SPL_REGMAP and SPL_SYSCON spl: dm: Kconfig: split REGMAP/SYSCON support for TPL from SPL spl: dm: Kconfig: SPL_RAM depends on SPL_DM spl: dm: Kconfig: introduce TPL_RAM (in analogy to SPL_RAM) spl: dm: Kconfig: SPL_CLK depens on SPL_DM spl: dm: Kconfig: split CLK support for SPL and TPL spl: dm: Kconfig: split OF_CONTROL and OF_PLATDATA between SPL and TPL spl: dm: use CONFIG_IS_ENABLED to test for the DM option armv8: remove unused low-level modules from TPL armv8: spl: Support separate stack for TPL spl: allow a separate TEXT_BASE, LDSCRIPT and MAX_SIZE for TPL spl: Kconfig: split SYS_MALLOC_SIMPLE for TPL and SPL lib: spl: differentiate between TPL and SPL for libfdt/of_control/of_platdata spl: consistently use $(SPL_TPL_) to select features for SPL and TPL builds spl: add TPL_DRIVER_MISC_SUPPORT option drivers: spl: consistently use the $(SPL_TPL_) macro rockchip: Makefile: allow selective inclusion of sdram_common.o from TPL/SPL/U-Boot rockchip: rk3368: improve Kconfig text for the RK3368 rockchip: rk3368: mkimage: add support for the RK3368 rockchip: rk3368: pmugrf: add definitions for os_reg[0..3] rockchip: rk3368: define CONFIG_SYS_SDRAM_BASE rockchip: rk3368: spl: define COUNTER_FREQUENCY to 24MHz rockchip: rk3368: spl: add memory layout for TPL and SPL rockchip: rk3368: syscon: MSCH/PMUGRF/GRF support for OF_PLATDATA rockchip: rk3368: grf: use shifted-constants and prefix with RK3368_ rockchip: pinctrl: rk3368: add GMAC (RGMII only) support rockchip: pinctrl: rk3368: add support for configuring the MMC pins rockchip: clk: rk3368: implement bandwidth adjust for PLLs rockchip: clk: rk3368: support OF_PLATDATA for the RK3368 clk driver rockchip: clk: rk3368: do not change CPLL/GPLL before returning to BROM rockchip: clk: rk3368: implement DPLL (DRAM PLL) support rockchip: clk: rk3368: define DMA1_SRST_REQ and DMA2_SRST_REQ rockchip: clk: rk3368: implement MMC/SD clock reparenting rockchip: clk: rk3368: support configuring the DRAM PLL (from TPL) rockchip: clk: rk3368: add support for GMAC (SLCK_MAC) clock rockchip: clk: rk3368: mark 'priv' __maybe_unused in rk3368_clk_set_rate() net: gmac_rockchip: Add support for the RK3368 GMAC rockchip: Makefile: streamline SPL/TPL configuration rockchip: rk3368: add DRAM controller driver with DRAM initialisation rockchip: dts: rk3368: add DMC node in rk3368.dtsi rockchip: rk3368: spl: enable SPL_FRAMEWORK in rk3368_common.h rockchip: rk3368: spl: add TPL support rockchip: rk3368: spl: add SPL support rockchip: rk3368: spl: mark SPL and TPL as supported for ROCKCHIP_RK3368 rockchip: board: lion-rk3368: add support for the RK3368-uQ7 rockchip: board: puma-rk3399: fix warnings in puma_rk3399/fit_spl_atf.its
Makefile | 2 +- arch/arm/cpu/armv8/Makefile | 4 +- arch/arm/dts/Makefile | 1 + arch/arm/dts/rk3368-lion.dts | 209 +++++ arch/arm/dts/rk3368.dtsi | 26 +- arch/arm/include/asm/arch-rockchip/cru_rk3368.h | 15 +- arch/arm/include/asm/arch-rockchip/ddr_rk3368.h | 187 ++++ arch/arm/include/asm/arch-rockchip/grf_rk3368.h | 615 +++++++------ arch/arm/include/asm/spl.h | 1 + arch/arm/lib/crt0_64.S | 4 +- arch/arm/mach-rockchip/Kconfig | 37 +- arch/arm/mach-rockchip/Makefile | 51 +- arch/arm/mach-rockchip/bootrom.c | 4 +- arch/arm/mach-rockchip/rk3188-board-spl.c | 5 +- arch/arm/mach-rockchip/rk3188-board.c | 2 +- arch/arm/mach-rockchip/rk3288-board-spl.c | 4 +- arch/arm/mach-rockchip/rk3288-board.c | 4 +- arch/arm/mach-rockchip/rk3368-board-spl.c | 91 ++ arch/arm/mach-rockchip/rk3368-board-tpl.c | 158 ++++ arch/arm/mach-rockchip/rk3368/Kconfig | 21 + arch/arm/mach-rockchip/rk3368/Makefile | 1 - arch/arm/mach-rockchip/rk3368/sdram_rk3368.c | 60 -- arch/arm/mach-rockchip/rk3368/syscon_rk3368.c | 35 + arch/arm/mach-rockchip/rk3368/u-boot-tpl.lds | 13 + arch/arm/mach-rockchip/rk3399-board-spl.c | 4 +- arch/arm/mach-rockchip/save_boot_param.S | 37 + board/theobroma-systems/lion_rk3368/Kconfig | 15 + board/theobroma-systems/lion_rk3368/MAINTAINERS | 10 + board/theobroma-systems/lion_rk3368/Makefile | 7 + board/theobroma-systems/lion_rk3368/README | 60 ++ .../theobroma-systems/lion_rk3368/fit_spl_atf.its | 51 ++ board/theobroma-systems/lion_rk3368/lion_rk3368.c | 25 + board/theobroma-systems/puma_rk3399/README | 2 +- .../theobroma-systems/puma_rk3399/fit_spl_atf.its | 20 +- common/Makefile | 8 +- common/spl/Kconfig | 39 + common/spl/Makefile | 35 +- common/spl/spl.c | 5 +- common/spl/spl_bootrom.c | 27 + configs/evb-rk3288_defconfig | 2 +- configs/fennec-rk3288_defconfig | 2 +- configs/firefly-rk3288_defconfig | 2 +- configs/lion-rk3368_defconfig | 79 ++ configs/miqi-rk3288_defconfig | 2 +- configs/popmetal-rk3288_defconfig | 2 +- configs/rock2_defconfig | 2 +- configs/rock_defconfig | 2 +- configs/tinker-rk3288_defconfig | 2 +- doc/README.rockchip | 2 +- .../clock/rockchip,rk3368-dmc.txt | 67 ++ drivers/Makefile | 36 +- drivers/clk/Kconfig | 12 +- drivers/clk/Makefile | 2 +- drivers/clk/rockchip/clk_rk3368.c | 222 ++++- drivers/core/Kconfig | 23 +- drivers/core/Makefile | 4 +- drivers/net/gmac_rockchip.c | 54 ++ drivers/pinctrl/rockchip/pinctrl_rk3368.c | 101 ++- drivers/ram/Kconfig | 11 +- drivers/ram/Makefile | 2 + drivers/ram/rockchip/Makefile | 7 + drivers/ram/rockchip/dmc-rk3368.c | 990 +++++++++++++++++++++ dts/Kconfig | 29 + include/configs/lion_rk3368.h | 19 + include/configs/rk3188_common.h | 2 +- include/configs/rk3288_common.h | 2 +- include/configs/rk3368_common.h | 15 + include/configs/rock.h | 2 +- include/configs/rockchip-common.h | 2 +- include/dt-bindings/memory/rk3368-dmc.h | 30 + include/linux/kconfig.h | 13 + include/spl.h | 10 + lib/Makefile | 10 +- scripts/Makefile.spl | 14 +- scripts/config_whitelist.txt | 4 + tools/rkcommon.c | 1 + 76 files changed, 3142 insertions(+), 534 deletions(-) create mode 100644 arch/arm/dts/rk3368-lion.dts create mode 100644 arch/arm/include/asm/arch-rockchip/ddr_rk3368.h create mode 100644 arch/arm/mach-rockchip/rk3368-board-spl.c create mode 100644 arch/arm/mach-rockchip/rk3368-board-tpl.c delete mode 100644 arch/arm/mach-rockchip/rk3368/sdram_rk3368.c create mode 100644 arch/arm/mach-rockchip/rk3368/u-boot-tpl.lds create mode 100644 board/theobroma-systems/lion_rk3368/Kconfig create mode 100644 board/theobroma-systems/lion_rk3368/MAINTAINERS create mode 100644 board/theobroma-systems/lion_rk3368/Makefile create mode 100644 board/theobroma-systems/lion_rk3368/README create mode 100644 board/theobroma-systems/lion_rk3368/fit_spl_atf.its create mode 100644 board/theobroma-systems/lion_rk3368/lion_rk3368.c create mode 100644 common/spl/spl_bootrom.c create mode 100644 configs/lion-rk3368_defconfig create mode 100644 doc/device-tree-bindings/clock/rockchip,rk3368-dmc.txt create mode 100644 drivers/ram/rockchip/Makefile create mode 100644 drivers/ram/rockchip/dmc-rk3368.c create mode 100644 include/configs/lion_rk3368.h create mode 100644 include/dt-bindings/memory/rk3368-dmc.h
Some devices (e.g. the RK3368) have only limited SRAM, but provide support for loading the next boot stage after our SPL performs basic setup (e.g. DRAM).
For target systems like these, we add a boot device BOOTROM that will invoke a board-specific hook to return to the bootrom (if supported).
Signed-off-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com ---
arch/arm/include/asm/spl.h | 1 + common/spl/Kconfig | 11 +++++++++++ common/spl/Makefile | 1 + common/spl/spl_bootrom.c | 27 +++++++++++++++++++++++++++ include/spl.h | 10 ++++++++++ 5 files changed, 50 insertions(+) create mode 100644 common/spl/spl_bootrom.c
diff --git a/arch/arm/include/asm/spl.h b/arch/arm/include/asm/spl.h index 0e67470..df45511 100644 --- a/arch/arm/include/asm/spl.h +++ b/arch/arm/include/asm/spl.h @@ -30,6 +30,7 @@ enum { BOOT_DEVICE_BOARD, BOOT_DEVICE_DFU, BOOT_DEVICE_XIP, + BOOT_DEVICE_BOOTROM, BOOT_DEVICE_NONE }; #endif diff --git a/common/spl/Kconfig b/common/spl/Kconfig index 4de8139..ee767b7 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -25,6 +25,17 @@ config SPL_BOARD_INIT spl_board_init() from board_init_r(). This function should be provided by the board.
+config SPL_BOOTROM_SUPPORT + bool "Support returning to the BOOTROM" + help + Some platforms (e.g. the Rockchip RK3368) provide support in their + ROM for loading the next boot-stage after performing basic setup + from the SPL stage. + + Enable this option, to return to the BOOTROM through the + BOOT_DEVICE_BOOTROM (or fall-through to the next boot device in the + boot device list, if not implemented for a given board) + config SPL_RAW_IMAGE_SUPPORT bool "Support SPL loading and booting of RAW images" default n if (ARCH_MX6 && (SPL_MMC_SUPPORT || SPL_SATA_SUPPORT)) diff --git a/common/spl/Makefile b/common/spl/Makefile index 47a64dd..189b272 100644 --- a/common/spl/Makefile +++ b/common/spl/Makefile @@ -10,6 +10,7 @@
ifdef CONFIG_SPL_BUILD obj-$(CONFIG_SPL_FRAMEWORK) += spl.o +obj-$(CONFIG_SPL_BOOTROM_SUPPORT) += spl_bootrom.o obj-$(CONFIG_SPL_LOAD_FIT) += spl_fit.o obj-$(CONFIG_SPL_NOR_SUPPORT) += spl_nor.o obj-$(CONFIG_SPL_XIP_SUPPORT) += spl_xip.o diff --git a/common/spl/spl_bootrom.c b/common/spl/spl_bootrom.c new file mode 100644 index 0000000..6804246 --- /dev/null +++ b/common/spl/spl_bootrom.c @@ -0,0 +1,27 @@ +/* + * Copyright (C) 2017 Theobroma Systems Design und Consulting GmH + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <spl.h> + +__weak void board_return_to_bootrom(void) +{ +} + +static int spl_return_to_bootrom(struct spl_image_info *spl_image, + struct spl_boot_device *bootdev) +{ + /* + * If the board implements a way to return to its ROM (with + * the expectation that the next stage of will be booted by + * the ROM), it will implement board_return_to_bootrom() and + * should not return from it. + */ + board_return_to_bootrom(); + return false; +} + +SPL_LOAD_IMAGE_METHOD("BOOTROM", 0, BOOT_DEVICE_BOOTROM, spl_return_to_bootrom); diff --git a/include/spl.h b/include/spl.h index ccb1404..b5c2994 100644 --- a/include/spl.h +++ b/include/spl.h @@ -278,4 +278,14 @@ int spl_mmc_load_image(struct spl_image_info *spl_image, struct spl_boot_device *bootdev);
void bl31_entry(void); + +/** + * board_return_to_bootrom - allow for boards to continue with the boot ROM + * + * If a board (e.g. the Rockchip RK3368 boards) provide some + * supporting functionality for SPL in their boot ROM and the SPL + * stage wants to return to the ROM code to continue booting, boards + * can implement 'board_return_to_bootrom'. + */ +void board_return_to_bootrom(void); #endif
On the RK3368, we want our TPL to use the 'return to bootrom' boot method (to have the bootrom load up the SPL stage) and then continue with different boot methods (MMC, SPI, etc.) from SPL.
This adds the config option needed to control the availabily of the 'return to bootrom' boot-method separately for the TPL stage.
common/spl/Kconfig | 11 +++++++++++ 1 file changed, 11 insertions(+)
diff --git a/common/spl/Kconfig b/common/spl/Kconfig index ee767b7..dd94801 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -698,6 +698,17 @@ config TPL
if TPL
+config TPL_BOOTROM_SUPPORT + bool "Support returning to the BOOTROM (from TPL)" + help + Some platforms (e.g. the Rockchip RK3368) provide support in their + ROM for loading the next boot-stage after performing basic setup + from the TPL stage. + + Enable this option, to return to the BOOTROM through the + BOOT_DEVICE_BOOTROM (or fall-through to the next boot device in the + boot device list, if not implemented for a given board) + config TPL_ENV_SUPPORT bool "Support an environment" help
The back-to-bootrom support for Rockchip is equivalent to an (assembly) implementation of setjmp/longjmp (i.e. it saves the stack-pointer, link-register and callee-saved registers). Up until now, this had only been implemented for AArch32 (i.e. ARMv7 or older), which puts the new ARMv8 devices (which boot in AArch64 mode) at a slight disadvantage.
To allow use of the 'back-to-bootrom' feature on new devices (e.g. the RK3368), this commit adds an implementation for AArch64.
arch/arm/mach-rockchip/save_boot_param.S | 37 ++++++++++++++++++++++++++++++++ 1 file changed, 37 insertions(+)
diff --git a/arch/arm/mach-rockchip/save_boot_param.S b/arch/arm/mach-rockchip/save_boot_param.S index 5e6c8db..945a9dd 100644 --- a/arch/arm/mach-rockchip/save_boot_param.S +++ b/arch/arm/mach-rockchip/save_boot_param.S @@ -1,11 +1,47 @@ /* * (C) Copyright 2016 Rockchip Electronics Co., Ltd + * (C) Copyright 2017 Theobroma Systems Design und Consulting GmbH * * SPDX-License-Identifier: GPL-2.0+ */
#include <linux/linkage.h>
+#if defined(CONFIG_ARM64) +.globl SAVE_SP_ADDR +SAVE_SP_ADDR: + .quad 0 + +ENTRY(save_boot_params) + sub sp, sp, #0x100 + stp x29, x30, [sp, #0x50] + stp x27, x28, [sp, #0x40] + stp x25, x26, [sp, #0x30] + stp x23, x24, [sp, #0x20] + stp x21, x22, [sp, #0x10] + stp x19, x20, [sp, #0] + ldr x8, =SAVE_SP_ADDR + mov x9, sp + str x9, [x8] + b save_boot_params_ret /* back to my caller */ +ENDPROC(save_boot_params) + +.globl _back_to_bootrom_s +ENTRY(_back_to_bootrom_s) + ldr x0, =SAVE_SP_ADDR + ldr x0, [x0] + mov sp, x0 + ldp x29, x30, [sp, #0x50] + ldp x27, x28, [sp, #0x40] + ldp x25, x26, [sp, #0x30] + ldp x23, x24, [sp, #0x20] + ldp x21, x22, [sp, #0x10] + ldp x19, x20, [sp] + add sp, sp, #0x100 + mov x0, xzr + ret +ENDPROC(_back_to_bootrom_s) +#else .globl SAVE_SP_ADDR SAVE_SP_ADDR: .word 0 @@ -30,3 +66,4 @@ ENTRY(_back_to_bootrom_s) mov r0, #0 pop {r1-r12, pc} ENDPROC(_back_to_bootrom_s) +#endif
The back-to-bootrom option is rather unfortunately named CONFIG_ROCKCHIP_SPL_BACK_TO_BOOTROM instead of CONFIG_SPL_ROCKCHIP_BACK_TO_BOOTROM
To make is selectable through CONFIG_IS_ENABLED(ROCKCHIP_BACK_TO_BOOTROM), we need to rename it. At the same time, we introduce a TPL_ variant of the option to give us finer-grained control over when it should be used.
This change is motivated by our RK3368 boot process, which returns to the boot ROM only from the TPL stage, but not from the SPL stage.
arch/arm/mach-rockchip/Kconfig | 15 +++++++++++++-- arch/arm/mach-rockchip/rk3188-board-spl.c | 5 ++--- arch/arm/mach-rockchip/rk3188-board.c | 2 +- arch/arm/mach-rockchip/rk3288-board-spl.c | 4 ++-- arch/arm/mach-rockchip/rk3288-board.c | 4 ++-- arch/arm/mach-rockchip/rk3399-board-spl.c | 4 ++-- configs/evb-rk3288_defconfig | 2 +- configs/fennec-rk3288_defconfig | 2 +- configs/firefly-rk3288_defconfig | 2 +- configs/miqi-rk3288_defconfig | 2 +- configs/popmetal-rk3288_defconfig | 2 +- configs/rock2_defconfig | 2 +- configs/rock_defconfig | 2 +- configs/tinker-rk3288_defconfig | 2 +- doc/README.rockchip | 2 +- include/configs/rk3188_common.h | 2 +- include/configs/rk3288_common.h | 2 +- include/configs/rock.h | 2 +- include/configs/rockchip-common.h | 2 +- 19 files changed, 35 insertions(+), 25 deletions(-)
diff --git a/arch/arm/mach-rockchip/Kconfig b/arch/arm/mach-rockchip/Kconfig index bb44c61..523bc11 100644 --- a/arch/arm/mach-rockchip/Kconfig +++ b/arch/arm/mach-rockchip/Kconfig @@ -99,10 +99,21 @@ config ROCKCHIP_RV1108 The Rockchip RV1108 is a ARM-based SoC with a single-core Cortex-A7 and a DSP.
-config ROCKCHIP_SPL_BACK_TO_BROM +config SPL_ROCKCHIP_BACK_TO_BROM bool "SPL returns to bootrom" default y if ROCKCHIP_RK3036 select ROCKCHIP_BROM_HELPER + depends on SPL + help + Rockchip SoCs have ability to load SPL & U-Boot binary. If enabled, + SPL will return to the boot rom, which will then load the U-Boot + binary to keep going on. + +config TPL_ROCKCHIP_BACK_TO_BROM + bool "TPL returns to bootrom" + default y if ROCKCHIP_RK3368 + select ROCKCHIP_BROM_HELPER + depends on TPL help Rockchip SoCs have ability to load SPL & U-Boot binary. If enabled, SPL will return to the boot rom, which will then load the U-Boot @@ -120,7 +131,7 @@ config ROCKCHIP_BROM_HELPER bool
config SPL_MMC_SUPPORT - default y if !ROCKCHIP_SPL_BACK_TO_BROM + default y if !SPL_ROCKCHIP_BACK_TO_BROM
source "arch/arm/mach-rockchip/rk3036/Kconfig" source "arch/arm/mach-rockchip/rk3188/Kconfig" diff --git a/arch/arm/mach-rockchip/rk3188-board-spl.c b/arch/arm/mach-rockchip/rk3188-board-spl.c index c3e174d..d3866bf 100644 --- a/arch/arm/mach-rockchip/rk3188-board-spl.c +++ b/arch/arm/mach-rockchip/rk3188-board-spl.c @@ -167,8 +167,7 @@ void board_init_f(ulong dummy) }
setup_arm_clock(); - -#if defined(CONFIG_ROCKCHIP_SPL_BACK_TO_BROM) && !defined(CONFIG_SPL_BOARD_INIT) +#if CONFIG_IS_ENABLED(ROCKCHIP_BACK_TO_BROM) && !defined(CONFIG_SPL_BOARD_INIT) back_to_bootrom(); #endif } @@ -229,7 +228,7 @@ void spl_board_init(void) }
preloader_console_init(); -#ifdef CONFIG_ROCKCHIP_SPL_BACK_TO_BROM +#if CONFIG_IS_ENABLED(ROCKCHIP_BACK_TO_BROM) back_to_bootrom(); #endif return; diff --git a/arch/arm/mach-rockchip/rk3188-board.c b/arch/arm/mach-rockchip/rk3188-board.c index 3e76100..622e046 100644 --- a/arch/arm/mach-rockchip/rk3188-board.c +++ b/arch/arm/mach-rockchip/rk3188-board.c @@ -39,7 +39,7 @@ int board_late_init(void)
int board_init(void) { -#if defined(CONFIG_ROCKCHIP_SPL_BACK_TO_BROM) +#if CONFIG_IS_ENABLED(ROCKCHIP_BACK_TO_BROM) struct udevice *pinctrl; int ret;
diff --git a/arch/arm/mach-rockchip/rk3288-board-spl.c b/arch/arm/mach-rockchip/rk3288-board-spl.c index 5668fd2..6b7bf85 100644 --- a/arch/arm/mach-rockchip/rk3288-board-spl.c +++ b/arch/arm/mach-rockchip/rk3288-board-spl.c @@ -249,7 +249,7 @@ void board_init_f(ulong dummy) debug("DRAM init failed: %d\n", ret); return; } -#if defined(CONFIG_ROCKCHIP_SPL_BACK_TO_BROM) && !defined(CONFIG_SPL_BOARD_INIT) +#if CONFIG_IS_ENABLED(ROCKCHIP_BACK_TO_BROM) && !defined(CONFIG_SPL_BOARD_INIT) back_to_bootrom(); #endif } @@ -316,7 +316,7 @@ void spl_board_init(void) }
preloader_console_init(); -#ifdef CONFIG_ROCKCHIP_SPL_BACK_TO_BROM +#if CONFIG_IS_ENABLED(ROCKCHIP_BACK_TO_BROM) back_to_bootrom(); #endif return; diff --git a/arch/arm/mach-rockchip/rk3288-board.c b/arch/arm/mach-rockchip/rk3288-board.c index 613967c..272f079 100644 --- a/arch/arm/mach-rockchip/rk3288-board.c +++ b/arch/arm/mach-rockchip/rk3288-board.c @@ -78,7 +78,7 @@ int board_late_init(void) return rk_board_late_init(); }
-#ifndef CONFIG_ROCKCHIP_SPL_BACK_TO_BROM +#if CONFIG_IS_ENABLED(ROCKCHIP_BACK_TO_BROM) static int veyron_init(void) { struct udevice *dev; @@ -115,7 +115,7 @@ static int veyron_init(void)
int board_init(void) { -#ifdef CONFIG_ROCKCHIP_SPL_BACK_TO_BROM +#if CONFIG_IS_ENABLED(ROCKCHIP_BACK_TO_BROM) struct udevice *pinctrl; int ret;
diff --git a/arch/arm/mach-rockchip/rk3399-board-spl.c b/arch/arm/mach-rockchip/rk3399-board-spl.c index e050aff..710f7fe 100644 --- a/arch/arm/mach-rockchip/rk3399-board-spl.c +++ b/arch/arm/mach-rockchip/rk3399-board-spl.c @@ -28,7 +28,7 @@
DECLARE_GLOBAL_DATA_PTR;
-#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_OF_CONTROL) +#if CONFIG_IS_ENABLED(OF_CONTROL) static int spl_node_to_boot_device(int node) { struct udevice *parent; @@ -263,7 +263,7 @@ void spl_board_init(void) }
diff --git a/configs/evb-rk3288_defconfig b/configs/evb-rk3288_defconfig index 0d28311..14345be 100644 --- a/configs/evb-rk3288_defconfig +++ b/configs/evb-rk3288_defconfig @@ -2,7 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_ROCKCHIP_RK3288=y -CONFIG_ROCKCHIP_SPL_BACK_TO_BROM=y +CONFIG_SPL_ROCKCHIP_BACK_TO_BROM=y CONFIG_TARGET_EVB_RK3288=y CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEFAULT_DEVICE_TREE="rk3288-evb" diff --git a/configs/fennec-rk3288_defconfig b/configs/fennec-rk3288_defconfig index 3a51da8..92be959 100644 --- a/configs/fennec-rk3288_defconfig +++ b/configs/fennec-rk3288_defconfig @@ -2,7 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_ROCKCHIP_RK3288=y -CONFIG_ROCKCHIP_SPL_BACK_TO_BROM=y +CONFIG_SPL_ROCKCHIP_BACK_TO_BROM=y CONFIG_TARGET_FENNEC_RK3288=y CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEFAULT_DEVICE_TREE="rk3288-fennec" diff --git a/configs/firefly-rk3288_defconfig b/configs/firefly-rk3288_defconfig index 6f093f4..7df9d09 100644 --- a/configs/firefly-rk3288_defconfig +++ b/configs/firefly-rk3288_defconfig @@ -2,7 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_ROCKCHIP_RK3288=y -CONFIG_ROCKCHIP_SPL_BACK_TO_BROM=y +CONFIG_SPL_ROCKCHIP_BACK_TO_BROM=y CONFIG_TARGET_FIREFLY_RK3288=y CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEFAULT_DEVICE_TREE="rk3288-firefly" diff --git a/configs/miqi-rk3288_defconfig b/configs/miqi-rk3288_defconfig index c6bfa1e..29bdcdb 100644 --- a/configs/miqi-rk3288_defconfig +++ b/configs/miqi-rk3288_defconfig @@ -2,7 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_ROCKCHIP_RK3288=y -CONFIG_ROCKCHIP_SPL_BACK_TO_BROM=y +CONFIG_SPL_ROCKCHIP_BACK_TO_BROM=y CONFIG_TARGET_MIQI_RK3288=y CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEFAULT_DEVICE_TREE="rk3288-miqi" diff --git a/configs/popmetal-rk3288_defconfig b/configs/popmetal-rk3288_defconfig index 6d02675..1392d6f 100644 --- a/configs/popmetal-rk3288_defconfig +++ b/configs/popmetal-rk3288_defconfig @@ -2,7 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_ROCKCHIP_RK3288=y -CONFIG_ROCKCHIP_SPL_BACK_TO_BROM=y +CONFIG_SPL_ROCKCHIP_BACK_TO_BROM=y CONFIG_TARGET_POPMETAL_RK3288=y CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEFAULT_DEVICE_TREE="rk3288-popmetal" diff --git a/configs/rock2_defconfig b/configs/rock2_defconfig index eec0613..831d977 100644 --- a/configs/rock2_defconfig +++ b/configs/rock2_defconfig @@ -2,7 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_ROCKCHIP_RK3288=y -CONFIG_ROCKCHIP_SPL_BACK_TO_BROM=y +CONFIG_SPL_ROCKCHIP_BACK_TO_BROM=y CONFIG_TARGET_ROCK2=y CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEFAULT_DEVICE_TREE="rk3288-rock2-square" diff --git a/configs/rock_defconfig b/configs/rock_defconfig index 5d9b63b..b7fb07f 100644 --- a/configs/rock_defconfig +++ b/configs/rock_defconfig @@ -4,7 +4,7 @@ CONFIG_ARM=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_ROCKCHIP_RK3188=y -CONFIG_ROCKCHIP_SPL_BACK_TO_BROM=y +CONFIG_SPL_ROCKCHIP_BACK_TO_BROM=y CONFIG_TARGET_ROCK=y CONFIG_SPL_STACK_R_ADDR=0x60080000 CONFIG_DEFAULT_DEVICE_TREE="rk3188-radxarock" diff --git a/configs/tinker-rk3288_defconfig b/configs/tinker-rk3288_defconfig index c46bacc..b2124b1 100644 --- a/configs/tinker-rk3288_defconfig +++ b/configs/tinker-rk3288_defconfig @@ -2,7 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_ROCKCHIP_RK3288=y -CONFIG_ROCKCHIP_SPL_BACK_TO_BROM=y +CONFIG_SPL_ROCKCHIP_BACK_TO_BROM=y CONFIG_TARGET_TINKER_RK3288=y CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEFAULT_DEVICE_TREE="rk3288-tinker" diff --git a/doc/README.rockchip b/doc/README.rockchip index dbeb8be..12fec38 100644 --- a/doc/README.rockchip +++ b/doc/README.rockchip @@ -130,7 +130,7 @@ load a second-level bootloader(ie. U-BOOT) as soon as it returns to bootrom. Therefore RK3288 has another loading sequence like RK3036. The option of U-Boot is controlled with this setting in U-Boot:
- #define CONFIG_ROCKCHIP_SPL_BACK_TO_BROM + #define CONFIG_SPL_ROCKCHIP_BACK_TO_BROM
You can create the image via the following operations:
diff --git a/include/configs/rk3188_common.h b/include/configs/rk3188_common.h index 3ee9abd..8a01936 100644 --- a/include/configs/rk3188_common.h +++ b/include/configs/rk3188_common.h @@ -26,7 +26,7 @@
#define CONFIG_SYS_NS16550_MEM32
-#ifdef CONFIG_ROCKCHIP_SPL_BACK_TO_BROM +#ifdef CONFIG_SPL_ROCKCHIP_BACK_TO_BROM /* Bootrom will load u-boot binary to 0x60000000 once return from SPL */ #define CONFIG_SYS_TEXT_BASE 0x60000000 #else diff --git a/include/configs/rk3288_common.h b/include/configs/rk3288_common.h index 488d679..ade6caf 100644 --- a/include/configs/rk3288_common.h +++ b/include/configs/rk3288_common.h @@ -24,7 +24,7 @@ #define CONFIG_SPL_FRAMEWORK #define CONFIG_SYS_NS16550_MEM32
-#ifdef CONFIG_ROCKCHIP_SPL_BACK_TO_BROM +#ifdef CONFIG_SPL_ROCKCHIP_BACK_TO_BROM /* Bootrom will load u-boot binary to 0x0 once return from SPL */ #define CONFIG_SYS_TEXT_BASE 0x00000000 #else diff --git a/include/configs/rock.h b/include/configs/rock.h index de5291c..e76dc73 100644 --- a/include/configs/rock.h +++ b/include/configs/rock.h @@ -13,7 +13,7 @@ #define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0
-#ifdef CONFIG_ROCKCHIP_SPL_BACK_TO_BROM +#ifdef CONFIG_SPL_ROCKCHIP_BACK_TO_BROM /* SPL @ 32k for 34k * u-boot directly after @ 68k for 400k or so * ENV @ 992k diff --git a/include/configs/rockchip-common.h b/include/configs/rockchip-common.h index 715290d..ce5b1a2 100644 --- a/include/configs/rockchip-common.h +++ b/include/configs/rockchip-common.h @@ -41,7 +41,7 @@ #endif
#if !defined(CONFIG_ENV_OFFSET) -#ifdef CONFIG_ROCKCHIP_SPL_BACK_TO_BROM +#ifdef CONFIG_SPL_ROCKCHIP_BACK_TO_BROM /* SPL @ 32k for 34k * u-boot directly after @ 68k for 400k or so * ENV @ 992k
With the finer-grained control over LIBGENERIC_SUPPORT for TPL/SPL (i.e. with the newly introduced distinction between TPL_LIBGENERIC_SUPPORT and SPL_LIBGENERIC_SUPPORT), we can simplify the #ifdef-check to simply use CONFIG_IS_ENABELD.
arch/arm/mach-rockchip/bootrom.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-rockchip/bootrom.c b/arch/arm/mach-rockchip/bootrom.c index da36f92..4d38ed6 100644 --- a/arch/arm/mach-rockchip/bootrom.c +++ b/arch/arm/mach-rockchip/bootrom.c @@ -9,8 +9,8 @@
void back_to_bootrom(void) { -#if defined(CONFIG_SPL_LIBGENERIC_SUPPORT) && !defined(CONFIG_TPL_BUILD) - printf("Returning to boot ROM..."); +#if CONFIG_IS_ENABLED(LIBGENERIC_SUPPORT) + printf("Returning to boot ROM...\n"); #endif _back_to_bootrom_s(); }
SPL_REGMAP and SPL_SYSCON were marked as depending on DM, when a stricter dependency of SPL_DM was possible. This commit makes the prereq more specific.
drivers/core/Kconfig | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/core/Kconfig b/drivers/core/Kconfig index fb5c4e8..01e6d71 100644 --- a/drivers/core/Kconfig +++ b/drivers/core/Kconfig @@ -97,7 +97,7 @@ config REGMAP
config SPL_REGMAP bool "Support register maps in SPL" - depends on DM + depends on SPL_DM help Hardware peripherals tend to have one or more sets of registers which can be accessed to control the hardware. A register map @@ -116,7 +116,7 @@ config SYSCON
config SPL_SYSCON bool "Support system controllers in SPL" - depends on REGMAP + depends on SPL_REGMAP help Many SoCs have a number of system controllers which are dealt with as a group by a single driver. Some common functionality is provided
This change introduces TPL variants of the REGMAP and SYSCON config options (i.e. TPL_REGMAP and TPL_SYSCON in analogy to SPL_REGMAP and SPL_SYSCON) in preparation of a finer-grained feature selection for building feature-rich TPL variants.
drivers/core/Kconfig | 19 +++++++++++++++++++ drivers/core/Makefile | 4 ++-- 2 files changed, 21 insertions(+), 2 deletions(-)
diff --git a/drivers/core/Kconfig b/drivers/core/Kconfig index 01e6d71..6b5796b 100644 --- a/drivers/core/Kconfig +++ b/drivers/core/Kconfig @@ -105,6 +105,16 @@ config SPL_REGMAP support any bus type (I2C, SPI) but so far this only supports direct memory access.
+config TPL_REGMAP + bool "Support register maps in TPL" + depends on TPL_DM + help + Hardware peripherals tend to have one or more sets of registers + which can be accessed to control the hardware. A register map + models this with a simple read/write interface. It can in principle + support any bus type (I2C, SPI) but so far this only supports + direct memory access. + config SYSCON bool "Support system controllers" depends on REGMAP @@ -123,6 +133,15 @@ config SPL_SYSCON by this uclass, including accessing registers via regmap and assigning a unique number to each.
+config TPL_SYSCON + bool "Support system controllers in TPL" + depends on TPL_REGMAP + help + Many SoCs have a number of system controllers which are dealt with + as a group by a single driver. Some common functionality is provided + by this uclass, including accessing registers via regmap and + assigning a unique number to each. + config DEVRES bool "Managed device resources" depends on DM diff --git a/drivers/core/Makefile b/drivers/core/Makefile index 435cf98..dcfb1b0 100644 --- a/drivers/core/Makefile +++ b/drivers/core/Makefile @@ -9,8 +9,8 @@ obj-$(CONFIG_DEVRES) += devres.o obj-$(CONFIG_$(SPL_)DM_DEVICE_REMOVE) += device-remove.o obj-$(CONFIG_$(SPL_)SIMPLE_BUS) += simple-bus.o obj-$(CONFIG_DM) += dump.o -obj-$(CONFIG_$(SPL_)REGMAP) += regmap.o -obj-$(CONFIG_$(SPL_)SYSCON) += syscon-uclass.o +obj-$(CONFIG_$(SPL_TPL_)REGMAP) += regmap.o +obj-$(CONFIG_$(SPL_TPL_)SYSCON) += syscon-uclass.o obj-$(CONFIG_OF_LIVE) += of_access.o of_addr.o ifndef CONFIG_DM_DEV_READ_INLINE obj-$(CONFIG_OF_CONTROL) += read.o
This commit models the dependency from SPL_RAM to SPL_DM in Kconfig.
drivers/ram/Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/ram/Kconfig b/drivers/ram/Kconfig index 61afd7a..e75c23f 100644 --- a/drivers/ram/Kconfig +++ b/drivers/ram/Kconfig @@ -10,7 +10,7 @@ config RAM
config SPL_RAM bool "Enable RAM support in SPL" - depends on RAM + depends on RAM && SPL_DM help The RAM subsystem adds a small amount of overhead to the image. If this is acceptable and you have a need to use RAM drivers in
To allow finer grained selection of features for TPL, we introduce TPL_RAM (in analogy to SPL_RAM).
drivers/ram/Kconfig | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/drivers/ram/Kconfig b/drivers/ram/Kconfig index e75c23f..836be25 100644 --- a/drivers/ram/Kconfig +++ b/drivers/ram/Kconfig @@ -17,6 +17,15 @@ config SPL_RAM SPL, enable this option. It might provide a cleaner interface to setting up RAM (e.g. SDRAM / DDR) within SPL.
+config TPL_RAM + bool "Enable RAM support in SPL" + depends on RAM && TPL_DM + help + The RAM subsystem adds a small amount of overhead to the image. + If this is acceptable and you have a need to use RAM drivers in + TPL, enable this option. It might provide a cleaner interface to + setting up RAM (e.g. SDRAM / DDR) within TPL. + config STM32_SDRAM bool "Enable STM32 SDRAM support" depends on RAM
SPL_CLK should also depend on SPL_DM (and not just on CLK). Add the additional dependency.
drivers/clk/Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/clk/Kconfig b/drivers/clk/Kconfig index 44da716..9c13587 100644 --- a/drivers/clk/Kconfig +++ b/drivers/clk/Kconfig @@ -12,7 +12,7 @@ config CLK
config SPL_CLK bool "Enable clock support in SPL" - depends on CLK + depends on CLK && SPL_DM help The clock subsystem adds a small amount of overhead to the image. If this is acceptable and you have a need to use clock drivers in
Introduce TPL_CLK to allow finer-grained selection of TPL features for feature-rich (i.e. DM-based) TPL stages.
drivers/clk/Kconfig | 10 ++++++++++ drivers/clk/Makefile | 2 +- 2 files changed, 11 insertions(+), 1 deletion(-)
diff --git a/drivers/clk/Kconfig b/drivers/clk/Kconfig index 9c13587..b40bde2 100644 --- a/drivers/clk/Kconfig +++ b/drivers/clk/Kconfig @@ -20,6 +20,16 @@ config SPL_CLK setting up clocks within SPL, and allows the same drivers to be used as U-Boot proper.
+config TPL_CLK + bool "Enable clock support in TPL" + depends on CLK && TPL_DM + help + The clock subsystem adds a small amount of overhead to the image. + If this is acceptable and you have a need to use clock drivers in + SPL, enable this option. It might provide a cleaner interface to + setting up clocks within TPL, and allows the same drivers to be + used as U-Boot proper. + config CLK_BCM6345 bool "Clock controller driver for BCM6345" depends on CLK && ARCH_BMIPS diff --git a/drivers/clk/Makefile b/drivers/clk/Makefile index 2746a80..844bc4e 100644 --- a/drivers/clk/Makefile +++ b/drivers/clk/Makefile @@ -5,7 +5,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-obj-$(CONFIG_CLK) += clk-uclass.o clk_fixed_rate.o +obj-$(CONFIG_$(SPL_TPL_)CLK) += clk-uclass.o clk_fixed_rate.o obj-$(CONFIG_ARCH_ROCKCHIP) += rockchip/ obj-$(CONFIG_SANDBOX) += clk_sandbox.o obj-$(CONFIG_SANDBOX) += clk_sandbox_test.o
For the RK3368, we want to use OF_PLATDATA in TPL, but full OF_CONTROL in SPL: this requires the introduction of a new family of configuration options to decouple SPL_OF_CONTROL and SPL_OF_PLATDATA from TPL.
Consequently, Makefile.spl needs to be adjusted to test for these configuration items through the $(SPL_TPL_) macro instead of hard-coding the SPL variant.
Makefile | 2 +- dts/Kconfig | 29 +++++++++++++++++++++++++++++ scripts/Makefile.spl | 4 ++-- 3 files changed, 32 insertions(+), 3 deletions(-)
diff --git a/Makefile b/Makefile index 119ad49..d5cdf2a 100644 --- a/Makefile +++ b/Makefile @@ -1378,7 +1378,7 @@ u-boot.lds: $(LDSCRIPT) prepare FORCE spl/u-boot-spl.bin: spl/u-boot-spl @: spl/u-boot-spl: tools prepare \ - $(if $(CONFIG_OF_SEPARATE)$(CONFIG_SPL_OF_PLATDATA),dts/dt.dtb) + $(if $(CONFIG_OF_SEPARATE)$(CONFIG_$(SPL_TPL_)OF_PLATDATA),dts/dt.dtb) $(Q)$(MAKE) obj=spl -f $(srctree)/scripts/Makefile.spl all
spl/sunxi-spl.bin: spl/u-boot-spl diff --git a/dts/Kconfig b/dts/Kconfig index b3009af..bbadc32 100644 --- a/dts/Kconfig +++ b/dts/Kconfig @@ -32,6 +32,14 @@ config SPL_OF_CONTROL which is not enough to support device tree. Enable this option to allow such boards to be supported by U-Boot SPL.
+config TPL_OF_CONTROL + bool "Enable run-time configuration via Device Tree in TPL" + depends on TPL && OF_CONTROL + help + Some boards use device tree in U-Boot but only have 4KB of SRAM + which is not enough to support device tree. Enable this option to + allow such boards to be supported by U-Boot TPL. + config OF_LIVE bool "Enable use of a live tree" depends on OF_CONTROL @@ -135,4 +143,25 @@ config SPL_OF_PLATDATA declarations for each node. See README.platdata for more information.
+config TPL_OF_PLATDATA + bool "Generate platform data for use in TPL" + depends on TPL_OF_CONTROL + help + For very constrained SPL environments the overhead of decoding + device tree nodes and converting their contents into platform data + is too large. This overhead includes libfdt code as well as the + device tree contents itself. The latter is fairly compact, but the + former can add 3KB or more to a Thumb 2 Image. + + This option enables generation of platform data from the device + tree as C code. This code creates devices using U_BOOT_DEVICE() + declarations. The benefit is that it allows driver code to access + the platform data directly in C structures, avoidin the libfdt + overhead. + + This option works by generating C structure declarations for each + compatible string, then adding platform data and U_BOOT_DEVICE + declarations for each node. See README.platdata for more + information. + endmenu diff --git a/scripts/Makefile.spl b/scripts/Makefile.spl index ac3c2c7..3e35cd6 100644 --- a/scripts/Makefile.spl +++ b/scripts/Makefile.spl @@ -98,7 +98,7 @@ endif
u-boot-spl-init := $(head-y) u-boot-spl-main := $(libs-y) -ifdef CONFIG_SPL_OF_PLATDATA +ifdef CONFIG_$(SPL_TPL_)OF_PLATDATA u-boot-spl-platdata := $(obj)/dts/dt-platdata.o endif
@@ -202,7 +202,7 @@ cmd_cat = cat $(filter-out $(PHONY), $^) > $@ quiet_cmd_copy = COPY $@ cmd_copy = cp $< $@
-ifeq ($(CONFIG_SPL_OF_CONTROL)$(CONFIG_OF_SEPARATE)$(CONFIG_SPL_OF_PLATDATA),yy) +ifeq ($(CONFIG_$(SPL_TPL_)OF_CONTROL)$(CONFIG_OF_SEPARATE)$(CONFIG_$(SPL_TPL_)OF_PLATDATA),yy) $(obj)/$(SPL_BIN)-dtb.bin: $(obj)/$(SPL_BIN)-nodtb.bin \ $(if $(CONFIG_SPL_SEPARATE_BSS),,$(obj)/$(SPL_BIN)-pad.bin) \ $(obj)/$(SPL_BIN).dtb FORCE
Even though there's now a TPL_DM configuration option, the spl logic still checks for SPL_DM and thus does not pick up the proper config option.
This introduces the use of CONFIG_IS_ENABLED(DM) in spl.c to always pick up the desired configuration option instead of having a hard-coded check for the SPL variant.
common/spl/spl.c | 5 +++-- include/linux/kconfig.h | 13 +++++++++++++ 2 files changed, 16 insertions(+), 2 deletions(-)
diff --git a/common/spl/spl.c b/common/spl/spl.c index db55d26..233e4fe 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -6,6 +6,7 @@ * * SPDX-License-Identifier: GPL-2.0+ */ + #include <common.h> #include <dm.h> #include <spl.h> @@ -243,7 +244,7 @@ static int spl_common_init(bool setup_malloc) return ret; } } - if (IS_ENABLED(CONFIG_SPL_DM)) { + if (CONFIG_IS_ENABLED(DM)) { bootstage_start(BOOTSTATE_ID_ACCUM_DM_SPL, "dm_spl"); /* With CONFIG_SPL_OF_PLATDATA, bring in all devices */ ret = dm_init_and_scan(!CONFIG_IS_ENABLED(OF_PLATDATA)); @@ -425,7 +426,7 @@ void board_init_r(gd_t *dummy1, ulong dummy2) gd->malloc_ptr / 1024); #endif
- if (IS_ENABLED(CONFIG_SPL_ATF_SUPPORT)) { + if (CONFIG_IS_ENABLED(ATF_SUPPORT)) { debug("loaded - jumping to U-Boot via ATF BL31.\n"); bl31_entry(); } diff --git a/include/linux/kconfig.h b/include/linux/kconfig.h index 486fb94..fbfc718 100644 --- a/include/linux/kconfig.h +++ b/include/linux/kconfig.h @@ -51,12 +51,25 @@ #define _IS_SPL 1 #endif
+#ifdef CONFIG_TPL_BUILD +#define _IS_TPL 1 +#endif + +#if defined(CONFIG_TPL_BUILD) +#define config_val(cfg) _config_val(_IS_TPL, cfg) +#define _config_val(x, cfg) __config_val(x, cfg) +#define __config_val(x, cfg) ___config_val(__ARG_PLACEHOLDER_##x, cfg) +#define ___config_val(arg1_or_junk, cfg) \ + ____config_val(arg1_or_junk CONFIG_TPL_##cfg, CONFIG_##cfg) +#define ____config_val(__ignored, val, ...) val +#else #define config_val(cfg) _config_val(_IS_SPL, cfg) #define _config_val(x, cfg) __config_val(x, cfg) #define __config_val(x, cfg) ___config_val(__ARG_PLACEHOLDER_##x, cfg) #define ___config_val(arg1_or_junk, cfg) \ ____config_val(arg1_or_junk CONFIG_SPL_##cfg, CONFIG_##cfg) #define ____config_val(__ignored, val, ...) val +#endif
/* * CONFIG_VAL(FOO) evaluates to the value of
TPL builds today don't need to call into firmware or set up the MMU (if this changes, it should be controlled through a config option whether to include this or not), but include the needed support code for this anyway.
Even for a feature-rich TPL (including DM support as for the RK3368), this equates to a size difference of approx. 10% in TPL binary size: - without this change: text data bss dec hex filename 23635 3112 24 26771 6893 tpl/u-boot-tpl - with this change: text data bss dec hex filename 21583 3112 24 24719 608f tpl/u-boot-tpl
arch/arm/cpu/armv8/Makefile | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/arch/arm/cpu/armv8/Makefile b/arch/arm/cpu/armv8/Makefile index c447085..e831471 100644 --- a/arch/arm/cpu/armv8/Makefile +++ b/arch/arm/cpu/armv8/Makefile @@ -9,12 +9,14 @@ extra-y := start.o
obj-y += cpu.o obj-y += generic_timer.o +ifndef CONFIG_TPL_BUILD obj-y += cache_v8.o -obj-y += exceptions.o obj-y += cache.o obj-y += tlb.o obj-y += transition.o obj-y += fwcall.o +endif +obj-y += exceptions.o obj-y += cpu-dt.o obj-$(CONFIG_ARM_SMCCC) += smccc-call.o
To allow a TPL and SPL to run from different addresses/memories, we need to split setup of the TPL and SPL stacks. To do so, we introduce CONFIG_TPL_STACK (not listed in Kconfig) which can be used to override the initial stack pointer for TPL.
To provide backward compatibility for existing boards, this is added as an optional configuration item and the normal search order (i.e. SPL_STACK, then SYS_STACK) apply if not defined.
arch/arm/lib/crt0_64.S | 4 +++- scripts/config_whitelist.txt | 1 + 2 files changed, 4 insertions(+), 1 deletion(-)
diff --git a/arch/arm/lib/crt0_64.S b/arch/arm/lib/crt0_64.S index 57e728f..177b5bf 100644 --- a/arch/arm/lib/crt0_64.S +++ b/arch/arm/lib/crt0_64.S @@ -69,7 +69,9 @@ ENTRY(_main) /* * Set up initial C runtime environment and call board_init_f(0). */ -#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_STACK) +#if defined(CONFIG_TPL_BUILD) && defined(CONFIG_TPL_STACK) + ldr x0, =(CONFIG_TPL_STACK) +#elif defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_STACK) ldr x0, =(CONFIG_SPL_STACK) #else ldr x0, =(CONFIG_SYS_INIT_SP_ADDR) diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 1ab6101..34aadc5 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -4997,6 +4997,7 @@ CONFIG_TI_SPI_MMAP CONFIG_TMU_TIMER CONFIG_TPL_DRIVERS_MISC_SUPPORT CONFIG_TPL_PAD_TO +CONFIG_TPL_STACK CONFIG_TPM_TIS_BASE_ADDRESS CONFIG_TPS6586X_POWER CONFIG_TQM834X
For the bringup of the RK3368, we need to support TPL and SPL running from different addresses... which requires both stages to use a distinct TEXT_BASE.
This commit adds support for having a separate LDSCRIPT for TPL (which is expected to make use of the TPL_MAX_SIZE define) and for having a the option of defining TPL_TEXT_BASE and having the TPL stage linked against this address.
Note that the handling of the TEXT_BASE is designed to not interfere with the previous assumption that SPL_TEXT_BASE should be used for TPL as well, unless TPL_TEXT_BASE is defined. For this reason, the test in Makefile.spl uses the following (seemingly redundant checks): 1. looks for $(SPL_TPL_)TEXT_BASE 2. looks for SPL_TEXT_BASE (even when building in TPL)
scripts/Makefile.spl | 10 ++++++++-- scripts/config_whitelist.txt | 3 +++ 2 files changed, 11 insertions(+), 2 deletions(-)
diff --git a/scripts/Makefile.spl b/scripts/Makefile.spl index 3e35cd6..4a9a58f 100644 --- a/scripts/Makefile.spl +++ b/scripts/Makefile.spl @@ -103,9 +103,9 @@ u-boot-spl-platdata := $(obj)/dts/dt-platdata.o endif
# Linker Script -ifdef CONFIG_SPL_LDSCRIPT +ifdef CONFIG_$(SPL_TPL_)LDSCRIPT # need to strip off double quotes -LDSCRIPT := $(addprefix $(srctree)/,$(CONFIG_SPL_LDSCRIPT:"%"=%)) +LDSCRIPT := $(addprefix $(srctree)/,$(CONFIG_$(SPL_TPL_)LDSCRIPT:"%"=%)) endif
ifeq ($(wildcard $(LDSCRIPT)),) @@ -293,9 +293,15 @@ LDFLAGS_$(SPL_BIN) += -T u-boot-spl.lds $(LDFLAGS_FINAL) # Avoid 'Not enough room for program headers' error on binutils 2.28 onwards. LDFLAGS_$(SPL_BIN) += $(call ld-option, --no-dynamic-linker)
+# First try the best-match (i.e. SPL_TEXT_BASE for SPL, TPL_TEXT_BASE for TPL) +ifneq ($(CONFIG_$(SPL_TPL_)TEXT_BASE),) +LDFLAGS_$(SPL_BIN) += -Ttext $(CONFIG_$(SPL_TPL_)TEXT_BASE) +else +# And then fall back to just testing for SPL_TEXT_BASE, even if in TPL mode ifneq ($(CONFIG_SPL_TEXT_BASE),) LDFLAGS_$(SPL_BIN) += -Ttext $(CONFIG_SPL_TEXT_BASE) endif +endif
MKIMAGEFLAGS_$(SPL_BIN).sfp = -T socfpgaimage $(obj)/$(SPL_BIN).sfp: $(obj)/$(SPL_BIN).bin FORCE diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 34aadc5..d8d00f5 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -4996,8 +4996,11 @@ CONFIG_TI_KSNAV CONFIG_TI_SPI_MMAP CONFIG_TMU_TIMER CONFIG_TPL_DRIVERS_MISC_SUPPORT +CONFIG_TPL_LDSCRIPT +CONFIG_TPL_MAX_SIZE CONFIG_TPL_PAD_TO CONFIG_TPL_STACK +CONFIG_TPL_TEXT_BASE CONFIG_TPM_TIS_BASE_ADDRESS CONFIG_TPS6586X_POWER CONFIG_TQM834X
As include/malloc.h already checks for SYS_MALLOC_SIMPLE using the CONFIG_IS_ENABLED macro, we need to move to having separate entries as we switch to fully separate configuration for SPL and TPL.
common/spl/Kconfig | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/common/spl/Kconfig b/common/spl/Kconfig index dd94801..f49b958 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -62,6 +62,15 @@ config SPL_SYS_MALLOC_SIMPLE this will make the SPL binary smaller at the cost of more heap usage as the *_simple malloc functions do not re-use free-ed mem.
+config TPL_SYS_MALLOC_SIMPLE + bool + prompt "Only use malloc_simple functions in the TPL" + help + Say Y here to only use the *_simple malloc functions from + malloc_simple.c, rather then using the versions from dlmalloc.c; + this will make the TPL binary smaller at the cost of more heap + usage as the *_simple malloc functions do not re-use free-ed mem. + config SPL_STACK_R bool "Enable SDRAM location for SPL stack" help
This splits the compilation of code modules for TPL and SPL for OF_CONTROL (and related) features between TPL and SPL. The typical use-case of this is a TPL stage that uses OF_PLATDATA at TPL and provides full OF_CONTROL at SPL (e.g. on the RK3368).
lib/Makefile | 10 +++++----- 1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/lib/Makefile b/lib/Makefile index eacc7d6..2eef1eb 100644 --- a/lib/Makefile +++ b/lib/Makefile @@ -49,11 +49,11 @@ obj-$(CONFIG_RSA) += rsa/ obj-$(CONFIG_SHA1) += sha1.o obj-$(CONFIG_SHA256) += sha256.o
-obj-$(CONFIG_SPL_SAVEENV) += qsort.o -obj-$(CONFIG_$(SPL_)OF_LIBFDT) += libfdt/ -ifneq ($(CONFIG_SPL_BUILD)$(CONFIG_SPL_OF_PLATDATA),yy) -obj-$(CONFIG_$(SPL_)OF_CONTROL) += fdtdec_common.o -obj-$(CONFIG_$(SPL_)OF_CONTROL) += fdtdec.o +obj-$(CONFIG_$(SPL_TPL_)SAVEENV) += qsort.o +obj-$(CONFIG_$(SPL_TPL_)OF_LIBFDT) += libfdt/ +ifneq ($(CONFIG_$(SPL_TPL_)BUILD)$(CONFIG_$(SPL_TPL_)OF_PLATDATA),yy) +obj-$(CONFIG_$(SPL_TPL_)OF_CONTROL) += fdtdec_common.o +obj-$(CONFIG_$(SPL_TPL_)OF_CONTROL) += fdtdec.o endif
To allow for a finer-grained control of features for TPL and SPL builds all modules/boot-methods/etc. need to be consistently selected based on the $(SPL_TPL_) macros.
This allows splitting the associated config-options in Kconfig: we don't split the Kconfig options here and now, as this should happen on an as-needed basis, whenever someone needs a feature/boot-method/etc. in their TPL.
common/Makefile | 8 ++++---- common/spl/Makefile | 36 ++++++++++++++++++------------------ 2 files changed, 22 insertions(+), 22 deletions(-)
diff --git a/common/Makefile b/common/Makefile index 539cf98..14345de 100644 --- a/common/Makefile +++ b/common/Makefile @@ -53,7 +53,7 @@ obj-$(CONFIG_ENV_IS_IN_UBI) += env_ubi.o obj-$(CONFIG_ENV_IS_NOWHERE) += env_nowhere.o
obj-$(CONFIG_CMD_BEDBUG) += bedbug.o -obj-$(CONFIG_$(SPL_)OF_LIBFDT) += fdt_support.o +obj-$(CONFIG_$(SPL_TPL_)OF_LIBFDT) += fdt_support.o
obj-$(CONFIG_MII) += miiphyutil.o obj-$(CONFIG_CMD_MII) += miiphyutil.o @@ -148,9 +148,9 @@ obj-y += malloc_simple.o endif obj-y += image.o obj-$(CONFIG_ANDROID_BOOT_IMAGE) += image-android.o -obj-$(CONFIG_$(SPL_)OF_LIBFDT) += image-fdt.o -obj-$(CONFIG_$(SPL_)FIT) += image-fit.o -obj-$(CONFIG_$(SPL_)FIT_SIGNATURE) += image-sig.o +obj-$(CONFIG_$(SPL_TPL_)OF_LIBFDT) += image-fdt.o +obj-$(CONFIG_$(SPL_TPL_)FIT) += image-fit.o +obj-$(CONFIG_$(SPL_TPL_)FIT_SIGNATURE) += image-sig.o obj-$(CONFIG_IO_TRACE) += iotrace.o obj-y += memsize.o obj-y += stdio.o diff --git a/common/spl/Makefile b/common/spl/Makefile index 189b272..112b3e6 100644 --- a/common/spl/Makefile +++ b/common/spl/Makefile @@ -10,24 +10,24 @@
ifdef CONFIG_SPL_BUILD obj-$(CONFIG_SPL_FRAMEWORK) += spl.o -obj-$(CONFIG_SPL_BOOTROM_SUPPORT) += spl_bootrom.o -obj-$(CONFIG_SPL_LOAD_FIT) += spl_fit.o -obj-$(CONFIG_SPL_NOR_SUPPORT) += spl_nor.o -obj-$(CONFIG_SPL_XIP_SUPPORT) += spl_xip.o -obj-$(CONFIG_SPL_YMODEM_SUPPORT) += spl_ymodem.o +obj-$(CONFIG_$(SPL_TPL_)BOOTROM_SUPPORT) += spl_bootrom.o +obj-$(CONFIG_$(SPL_TPL_)LOAD_FIT) += spl_fit.o +obj-$(CONFIG_$(SPL_TPL_)SPL_NOR_SUPPORT) += spl_nor.o +obj-$(CONFIG_$(SPL_TPL_)SPL_XIP_SUPPORT) += spl_xip.o +obj-$(CONFIG_$(SPL_TPL_)SPL_YMODEM_SUPPORT) += spl_ymodem.o ifndef CONFIG_SPL_UBI -obj-$(CONFIG_SPL_NAND_SUPPORT) += spl_nand.o -obj-$(CONFIG_SPL_ONENAND_SUPPORT) += spl_onenand.o +obj-$(CONFIG_$(SPL_TPL_)NAND_SUPPORT) += spl_nand.o +obj-$(CONFIG_$(SPL_TPL_)ONENAND_SUPPORT) += spl_onenand.o endif -obj-$(CONFIG_SPL_UBI) += spl_ubi.o -obj-$(CONFIG_SPL_NET_SUPPORT) += spl_net.o -obj-$(CONFIG_SPL_MMC_SUPPORT) += spl_mmc.o -obj-$(CONFIG_SPL_ATF_SUPPORT) += spl_atf.o -obj-$(CONFIG_SPL_USB_SUPPORT) += spl_usb.o -obj-$(CONFIG_SPL_FAT_SUPPORT) += spl_fat.o -obj-$(CONFIG_SPL_EXT_SUPPORT) += spl_ext.o -obj-$(CONFIG_SPL_SATA_SUPPORT) += spl_sata.o -obj-$(CONFIG_SPL_DFU_SUPPORT) += spl_dfu.o -obj-$(CONFIG_SPL_SPI_LOAD) += spl_spi.o -obj-$(CONFIG_SPL_RAM_SUPPORT) += spl_ram.o +obj-$(CONFIG_$(SPL_TPL_)UBI) += spl_ubi.o +obj-$(CONFIG_$(SPL_TPL_)NET_SUPPORT) += spl_net.o +obj-$(CONFIG_$(SPL_TPL_)MMC_SUPPORT) += spl_mmc.o +obj-$(CONFIG_$(SPL_TPL_)ATF_SUPPORT) += spl_atf.o +obj-$(CONFIG_$(SPL_TPL_)USB_SUPPORT) += spl_usb.o +obj-$(CONFIG_$(SPL_TPL_)FAT_SUPPORT) += spl_fat.o +obj-$(CONFIG_$(SPL_TPL_)EXT_SUPPORT) += spl_ext.o +obj-$(CONFIG_$(SPL_TPL_)SATA_SUPPORT) += spl_sata.o +obj-$(CONFIG_$(SPL_TPL_)DFU_SUPPORT) += spl_dfu.o +obj-$(CONFIG_$(SPL_TPL_)SPI_LOAD) += spl_spi.o +obj-$(CONFIG_$(SPL_TPL_)RAM_SUPPORT) += spl_ram.o endif
This adds the TPL_DRIVER_MISC_SUPPORT option to allow activation of DRIVER_MISC_SUPPORT for devices that need it in the TPL stage.
common/spl/Kconfig | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/common/spl/Kconfig b/common/spl/Kconfig index f49b958..def8107 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -718,6 +718,14 @@ config TPL_BOOTROM_SUPPORT BOOT_DEVICE_BOOTROM (or fall-through to the next boot device in the boot device list, if not implemented for a given board)
+config TPL_DRIVERS_MISC_SUPPORT + bool "Support misc drivers in TPL" + help + Enable miscellaneous drivers in TPL. These drivers perform various + tasks that don't fall nicely into other categories, Enable this + option to build the drivers in drivers/misc as part of an TPL + build, for those that support building in TPL (not all drivers do). + config TPL_ENV_SUPPORT bool "Support an environment" help
To simplify drivers/Makefile a bit when using TPL/SPL, we consistently use the $(SPL_TPL_) macro to test for drivers that have separate configuration symbols for the full U-boot, SPL and TPL stages. Instead of explicitly repeating them in two separate if-guarded sections of the Makefile, we can now simply list these options once.
drivers/Makefile | 36 ++++++++++++++++-------------------- 1 file changed, 16 insertions(+), 20 deletions(-)
diff --git a/drivers/Makefile b/drivers/Makefile index 058bccb..2bd769f 100644 --- a/drivers/Makefile +++ b/drivers/Makefile @@ -2,33 +2,34 @@ # SPDX-License-Identifier: GPL-2.0+ #
-obj-$(CONFIG_$(SPL_TPL_)DM) += core/ -obj-$(CONFIG_$(SPL_)CLK) += clk/ -obj-$(CONFIG_$(SPL_)LED) += led/ -obj-$(CONFIG_$(SPL_)PHY) += phy/ -obj-$(CONFIG_$(SPL_)PINCTRL) += pinctrl/ -obj-$(CONFIG_$(SPL_)RAM) += ram/ +obj-$(CONFIG_$(SPL_TPL_)CLK) += clk/ +obj-$(CONFIG_$(SPL_TPL_)DM) += core/ +obj-$(CONFIG_$(SPL_TPL_)DRIVERS_MISC_SUPPORT) += misc/ sysreset/ firmware/ +obj-$(CONFIG_$(SPL_TPL_)I2C_SUPPORT) += i2c/ +obj-$(CONFIG_$(SPL_TPL_)LED) += led/ +obj-$(CONFIG_$(SPL_TPL_)MMC_SUPPORT) += mmc/ +obj-$(CONFIG_$(SPL_TPL_)NAND_SUPPORT) += mtd/nand/ +obj-$(CONFIG_$(SPL_TPL_)PHY) += phy/ +obj-$(CONFIG_$(SPL_TPL_)PINCTRL) += pinctrl/ +obj-$(CONFIG_$(SPL_TPL_)RAM) += ram/ +obj-$(CONFIG_$(SPL_TPL_)SERIAL_SUPPORT) += serial/ +obj-$(CONFIG_$(SPL_TPL_)SPI_FLASH_SUPPORT) += mtd/spi/ +obj-$(CONFIG_$(SPL_TPL_)SPI_SUPPORT) += spi/
+ifndef CONFIG_TPL_BUILD ifdef CONFIG_SPL_BUILD
obj-$(CONFIG_SPL_CPU_SUPPORT) += cpu/ obj-$(CONFIG_SPL_CRYPTO_SUPPORT) += crypto/ -obj-$(CONFIG_SPL_I2C_SUPPORT) += i2c/ obj-$(CONFIG_SPL_GPIO_SUPPORT) += gpio/ -obj-$(CONFIG_SPL_MMC_SUPPORT) += mmc/ obj-$(CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT) += ddr/fsl/ obj-$(CONFIG_ARMADA_38X) += ddr/marvell/a38x/ obj-$(CONFIG_ARMADA_XP) += ddr/marvell/axp/ obj-$(CONFIG_ALTERA_SDRAM) += ddr/altera/ -obj-$(CONFIG_SPL_SERIAL_SUPPORT) += serial/ -obj-$(CONFIG_SPL_SPI_SUPPORT) += spi/ obj-$(CONFIG_SPL_POWER_SUPPORT) += power/ power/pmic/ obj-$(CONFIG_SPL_POWER_SUPPORT) += power/regulator/ -obj-$(CONFIG_SPL_DRIVERS_MISC_SUPPORT) += misc/ sysreset/ firmware/ obj-$(CONFIG_SPL_MTD_SUPPORT) += mtd/ -obj-$(CONFIG_SPL_NAND_SUPPORT) += mtd/nand/ obj-$(CONFIG_SPL_ONENAND_SUPPORT) += mtd/onenand/ -obj-$(CONFIG_SPL_SPI_FLASH_SUPPORT) += mtd/spi/ obj-$(CONFIG_SPL_UBI) += mtd/ubispl/ obj-$(CONFIG_SPL_DMA_SUPPORT) += dma/ obj-$(CONFIG_SPL_ETH_SUPPORT) += net/ @@ -48,18 +49,13 @@ obj-$(CONFIG_OMAP_USB_PHY) += usb/phy/ obj-$(CONFIG_SPL_SATA_SUPPORT) += block/ obj-$(CONFIG_SPL_USB_HOST_SUPPORT) += block/ obj-$(CONFIG_SPL_MMC_SUPPORT) += block/ + +endif endif
-obj-$(CONFIG_TPL_I2C_SUPPORT) += i2c/ -obj-$(CONFIG_TPL_DRIVERS_MISC_SUPPORT) += misc/ sysreset/ firmware/ -obj-$(CONFIG_TPL_MMC_SUPPORT) += mmc/ obj-$(CONFIG_TPL_MPC8XXX_INIT_DDR_SUPPORT) += ddr/fsl/ -obj-$(CONFIG_TPL_NAND_SUPPORT) += mtd/nand/ -obj-$(CONFIG_TPL_SERIAL_SUPPORT) += serial/ -obj-$(CONFIG_TPL_SPI_FLASH_SUPPORT) += mtd/spi/ -obj-$(CONFIG_TPL_SPI_SUPPORT) += spi/
endif
The utility functions in sdram_common.c will be useful both for some SPL implementations (and if unused, the linked will discard these anyway) and for the full U-Boot stage.
This changes selects sdram_common.o through the $(SPL_TPL_) macro to allow better control of its inclusion through the CONFIG_ROM, CONFIG_SPL_RAM or CONFIG_TPL_RAM options.
arch/arm/mach-rockchip/Makefile | 4 +--- 1 file changed, 1 insertion(+), 3 deletions(-)
diff --git a/arch/arm/mach-rockchip/Makefile b/arch/arm/mach-rockchip/Makefile index cb8d3ef..8a3cb9f 100644 --- a/arch/arm/mach-rockchip/Makefile +++ b/arch/arm/mach-rockchip/Makefile @@ -5,6 +5,7 @@ #
obj-$(CONFIG_ROCKCHIP_BROM_HELPER) += bootrom.o +obj-$(CONFIG_$(SPL_TPL_)RAM) += sdram_common.o
ifdef CONFIG_TPL_BUILD obj-$(CONFIG_ROCKCHIP_RK3188) += rk3188-board-tpl.o @@ -21,9 +22,6 @@ obj-$(CONFIG_ROCKCHIP_RK3188) += rk3188-board.o obj-$(CONFIG_ROCKCHIP_RK322X) += rk322x-board.o obj-$(CONFIG_ROCKCHIP_RK3288) += rk3288-board.o obj-$(CONFIG_ROCKCHIP_RK3036) += rk3036-board.o -ifdef CONFIG_RAM -obj-y += sdram_common.o -endif endif ifndef CONFIG_ARM64 obj-y += rk_timer.o
The RK3368 option in Kconfig referred to the RK3328 (copy-and-paste) and had a few typos and unnecessarily used UTF-8 characters. While fixing this, I also reformatted and further clarified the text (e.g. made the grouping into a a big and little cluster of 4 cores each explicit).
arch/arm/mach-rockchip/Kconfig | 15 +++++++++------ 1 file changed, 9 insertions(+), 6 deletions(-)
diff --git a/arch/arm/mach-rockchip/Kconfig b/arch/arm/mach-rockchip/Kconfig index 523bc11..2ad4943 100644 --- a/arch/arm/mach-rockchip/Kconfig +++ b/arch/arm/mach-rockchip/Kconfig @@ -69,12 +69,15 @@ config ROCKCHIP_RK3368 select ARM64 select SYS_NS16550 help - The Rockchip RK3328 is a ARM-based SoC with a octa-core Cortex-A53. - including NEON and GPU, 512KB L2 cache for big cluster and 256 KB - L2 cache for little cluser, PowerVR G6110 based graphics, one video - output processor supporting LVDS、HDMI、eDP, several DDR3 options - and video codec support. Peripherals include Gigabit Ethernet, - USB2 host and OTG, SDIO, I2S, UARTs, SPI, I2C and PWMs. + The Rockchip RK3368 is a ARM-based SoC with a octa-core (organised + into a big and little cluster with 4 cores each) Cortex-A53 including + AdvSIMD, 512KB L2 cache (for the big cluster) and 256 KB L2 cache + (for the little cluster), PowerVR G6110 based graphics, one video + output processor supporting LVDS/HDMI/eDP, several DDR3 options and + video codec support. + + On-chip peripherals include Gigabit Ethernet, USB2 host and OTG, SDIO, + I2S, UARTs, SPI, I2C and PWMs.
config ROCKCHIP_RK3399 bool "Support Rockchip RK3399"
This commit adds support for RK3368 SoC in mkimage.
tools/rkcommon.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/tools/rkcommon.c b/tools/rkcommon.c index 25b0340..04e8272 100644 --- a/tools/rkcommon.c +++ b/tools/rkcommon.c @@ -77,6 +77,7 @@ static struct spl_info spl_infos[] = { { "rk322x", "RK32", 0x8000 - 0x1000, false, false }, { "rk3288", "RK32", 0x8000, false, false }, { "rk3328", "RK32", 0x8000 - 0x1000, false, false }, + { "rk3368", "RK33", 0x8000 - 0x1000, false, true }, { "rk3399", "RK33", 0x30000 - 0x2000, false, true }, { "rv1108", "RK11", 0x1800, false, false}, };
On the RK3368 we use a TPL-stage similar to Rockchip's DDR init (i.e. it initialises DRAM, leaves some info for the next stage and returns to the BootROM). To allow compatibility with Rockchip's DDR init code, we use the same register os_reg2 in pmugrf for passing this info (i.e. DRAM size and configuration) between stages.
This change adds the definitions for os_reg[0] through os_reg[3] to the pmugrf structure for the RK3368.
arch/arm/include/asm/arch-rockchip/grf_rk3368.h | 5 +++-- 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/arch/arm/include/asm/arch-rockchip/grf_rk3368.h b/arch/arm/include/asm/arch-rockchip/grf_rk3368.h index 93c4e7d..a438f5d 100644 --- a/arch/arm/include/asm/arch-rockchip/grf_rk3368.h +++ b/arch/arm/include/asm/arch-rockchip/grf_rk3368.h @@ -92,10 +92,11 @@ struct rk3368_pmu_grf { u32 gpio0d_drv; u32 gpio0l_sr; u32 gpio0h_sr; - u32 reserved[(0x200 - 0x34) / 4 - 1]; + u32 reserved[0x72]; u32 os_reg[4]; }; -check_member(rk3368_pmu_grf, os_reg[3], 0x20c); +check_member(rk3368_pmu_grf, gpio0h_sr, 0x34); +check_member(rk3368_pmu_grf, os_reg[0], 0x200);
/*GRF_GPIO0C_IOMUX*/ enum {
With the new common SDRAM code for Rockchip, we need to define CONFIG_SYS_SDRAM_BASE to correctly indicate the start of the physical address range mapping onto DRAM.
include/configs/rk3368_common.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/include/configs/rk3368_common.h b/include/configs/rk3368_common.h index b0c858c..488f8c5 100644 --- a/include/configs/rk3368_common.h +++ b/include/configs/rk3368_common.h @@ -15,6 +15,7 @@ #define CONFIG_SYS_SDRAM_BASE 0 #define SDRAM_MAX_SIZE 0xff000000 #define CONFIG_NR_DRAM_BANKS 1 +#define CONFIG_SYS_SDRAM_BASE 0 #define CONFIG_SYS_MAXARGS 16 #define CONFIG_BAUDRATE 115200 #define CONFIG_SYS_MALLOC_LEN (32 << 20)
Am Dienstag, 18. Juli 2017, 22:36:06 CEST schrieb Philipp Tomsich:
^^ isn't that already defined here?
The BootROM of the RK3368 Boot ROM does not initialise cntfrq_el0. This change defines COUNTER_FREQUENCY, which is used by the AArch64 init code in arch/arm/cpu/armv8/start.S to set up cntfrq_el0.
If the counter-frequency is not correctly set up, the calculation of delays using the ARMv8 generic timer can not work correctly.
include/configs/rk3368_common.h | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/include/configs/rk3368_common.h b/include/configs/rk3368_common.h index 488f8c5..7ab3b46 100644 --- a/include/configs/rk3368_common.h +++ b/include/configs/rk3368_common.h @@ -22,6 +22,8 @@ #define CONFIG_SYS_CBSIZE 1024 #define CONFIG_SKIP_LOWLEVEL_INIT
+#define COUNTER_FREQUENCY 24000000 + #define CONFIG_SYS_NS16550_MEM32
#define CONFIG_SYS_TEXT_BASE 0x00200000
For the RK3368, we use a multi-stage boot-process consisting of the following: 1. TPL: initalises DRAM, returns to boot-ROM (which then loads the next stage and transfers control to it) 2. SPL: a full-features SPL stage including OF_CONTROL and FIT image loading, which fetches the ATF, DTB and full U-Boot and then transfers control to the ATF (using the BL31 parameter block to indicate the location of BL33/U-Boot) 3. ATF: sets up the secure world and exits to BL33 (i.e. a full U-Boot) in the normal world 4. full U-Boot
TPL/SPL and the full U-Boot are built from this tree and need to run from distinct text addresses and with distinct initial stack pointer addresses.
This commit sets up the configuration to run: - TPL from the SRAM at 0xff8c0000 (note that the first 0x1000 are reserved for use by the boot-ROM and contain the SP when the TPL is entered) - SPL from DRAM at 0x0 - U-Boot from DRAM at 0x200000
include/configs/rk3368_common.h | 11 +++++++++++ 1 file changed, 11 insertions(+)
diff --git a/include/configs/rk3368_common.h b/include/configs/rk3368_common.h index 7ab3b46..8ffc293 100644 --- a/include/configs/rk3368_common.h +++ b/include/configs/rk3368_common.h @@ -30,6 +30,17 @@ #define CONFIG_SYS_INIT_SP_ADDR 0x00300000 #define CONFIG_SYS_LOAD_ADDR 0x00280000
+#define CONFIG_SPL_TEXT_BASE 0x00000000 +#define CONFIG_SPL_MAX_SIZE 0x40000 +#define CONFIG_SPL_BSS_START_ADDR 0x400000 +#define CONFIG_SPL_BSS_MAX_SIZE 0x20000 + +#define CONFIG_TPL_LDSCRIPT \ + "arch/arm/mach-rockchip/rk3368/u-boot-tpl.lds" +#define CONFIG_TPL_TEXT_BASE 0xff8c1000 +#define CONFIG_TPL_MAX_SIZE 0x7000 +#define CONFIG_TPL_STACK 0xff8cffff + #define CONFIG_BOUNCE_BUFFER
#ifndef CONFIG_SPL_BUILD
The RK3368 has both a limited SPL size (just 0x7000 bytes) and the added challenge of booting in AArch64, which increases the code size for SPL (particularily when using the LP64 programming model). For this reason we expect the RK3368 to always use OF_PLATDATA for its SPL stage.
This change adds support for the MSCH, PMUGRF and GRF register regions in syscon, which are necessary for initialising the RK3368's DRAM controller.
arch/arm/mach-rockchip/rk3368/syscon_rk3368.c | 35 +++++++++++++++++++++++++++ 1 file changed, 35 insertions(+)
diff --git a/arch/arm/mach-rockchip/rk3368/syscon_rk3368.c b/arch/arm/mach-rockchip/rk3368/syscon_rk3368.c index 03e97eb..90a993e 100644 --- a/arch/arm/mach-rockchip/rk3368/syscon_rk3368.c +++ b/arch/arm/mach-rockchip/rk3368/syscon_rk3368.c @@ -1,6 +1,8 @@ /* * (C) Copyright 2017 Rockchip Electronics Co., Ltd * Author: Andy Yan andy.yan@rock-chips.com + * (C) Copyright 2017 Theobroma Systems Design und Consulting GmbH + * * SPDX-License-Identifier: GPL-2.0+ */
@@ -14,6 +16,8 @@ static const struct udevice_id rk3368_syscon_ids[] = { .data = ROCKCHIP_SYSCON_GRF }, { .compatible = "rockchip,rk3368-pmugrf", .data = ROCKCHIP_SYSCON_PMUGRF }, + { .compatible = "rockchip,rk3368-msch", + .data = ROCKCHIP_SYSCON_MSCH }, { } };
@@ -22,3 +26,34 @@ U_BOOT_DRIVER(syscon_rk3368) = { .id = UCLASS_SYSCON, .of_match = rk3368_syscon_ids, }; + +#if CONFIG_IS_ENABLED(OF_PLATDATA) +static int rk3368_syscon_bind_of_platdata(struct udevice *dev) +{ + dev->driver_data = dev->driver->of_match->data; + debug("syscon: %s %d\n", dev->name, (uint)dev->driver_data); + + return 0; +} + +U_BOOT_DRIVER(rockchip_rk3368_grf) = { + .name = "rockchip_rk3368_grf", + .id = UCLASS_SYSCON, + .of_match = rk3368_syscon_ids, + .bind = rk3368_syscon_bind_of_platdata, +}; + +U_BOOT_DRIVER(rockchip_rk3368_pmugrf) = { + .name = "rockchip_rk3368_pmugrf", + .id = UCLASS_SYSCON, + .of_match = rk3368_syscon_ids + 1, + .bind = rk3368_syscon_bind_of_platdata, +}; + +U_BOOT_DRIVER(rockchip_rk3368_msch) = { + .name = "rockchip_rk3368_msch", + .id = UCLASS_SYSCON, + .of_match = rk3368_syscon_ids + 2, + .bind = rk3368_syscon_bind_of_platdata, +}; +#endif
Hi Philipp:
According to your previous patch, maybe you mean TPL here?
- (C) Copyright 2017 Rockchip Electronics Co., Ltd
- Author: Andy Yan andy.yan@rock-chips.com
- (C) Copyright 2017 Theobroma Systems Design und Consulting GmbH
- { .compatible = "rockchip,rk3368-msch",
{ } };.data = ROCKCHIP_SYSCON_MSCH },
- dev->driver_data = dev->driver->of_match->data;
- debug("syscon: %s %d\n", dev->name, (uint)dev->driver_data);
- .name = "rockchip_rk3368_grf",
- .id = UCLASS_SYSCON,
- .of_match = rk3368_syscon_ids,
- .bind = rk3368_syscon_bind_of_platdata,
- .name = "rockchip_rk3368_pmugrf",
- .of_match = rk3368_syscon_ids + 1,
- .name = "rockchip_rk3368_msch",
- .of_match = rk3368_syscon_ids + 2,
+}; +#endif
The RK3368 GRF header was still defines with a shifted-mask but with non-shifted function selectors for the IOMUX defines. As the RK3368 support is still fresh enough to allow a quick rename, we do this now before having more code use this.
As some of the downstream drivers (e.g. the Designware GMAC wrapper) may need to include the grf-header of multiple devices, we rename the various defines for the RK3368 by prefixing them with the device name. This avoids future trouble during driver integration.
arch/arm/include/asm/arch-rockchip/grf_rk3368.h | 617 +++++++++++++----------- drivers/pinctrl/rockchip/pinctrl_rk3368.c | 17 +- 2 files changed, 334 insertions(+), 300 deletions(-)
diff --git a/arch/arm/include/asm/arch-rockchip/grf_rk3368.h b/arch/arm/include/asm/arch-rockchip/grf_rk3368.h index a438f5d..a97dc1e 100644 --- a/arch/arm/include/asm/arch-rockchip/grf_rk3368.h +++ b/arch/arm/include/asm/arch-rockchip/grf_rk3368.h @@ -1,4 +1,6 @@ -/* (C) Copyright 2016 Rockchip Electronics Co., Ltd +/* + * (C) Copyright 2016 Rockchip Electronics Co., Ltd + * (C) Copyright 2017 Theobroma Systems Design und Consulting GmbH * * SPDX-License-Identifier: GPL-2.0+ */ @@ -100,315 +102,318 @@ check_member(rk3368_pmu_grf, os_reg[0], 0x200);
/*GRF_GPIO0C_IOMUX*/ enum { - GPIO0C7_SHIFT = 14, - GPIO0C7_MASK = 3 << GPIO0C7_SHIFT, - GPIO0C7_GPIO = 0, - GPIO0C7_LCDC_D19, - GPIO0C7_TRACE_D9, - GPIO0C7_UART1_RTSN, - - GPIO0C6_SHIFT = 12, - GPIO0C6_MASK = 3 << GPIO0C6_SHIFT, - GPIO0C6_GPIO = 0, - GPIO0C6_LCDC_D18, - GPIO0C6_TRACE_D8, - GPIO0C6_UART1_CTSN, - - GPIO0C5_SHIFT = 10, - GPIO0C5_MASK = 3 << GPIO0C5_SHIFT, - GPIO0C5_GPIO = 0, - GPIO0C5_LCDC_D17, - GPIO0C5_TRACE_D7, - GPIO0C5_UART1_SOUT, - - GPIO0C4_SHIFT = 8, - GPIO0C4_MASK = 3 << GPIO0C4_SHIFT, - GPIO0C4_GPIO = 0, - GPIO0C4_LCDC_D16, - GPIO0C4_TRACE_D6, - GPIO0C4_UART1_SIN, - - GPIO0C3_SHIFT = 6, - GPIO0C3_MASK = 3 << GPIO0C3_SHIFT, - GPIO0C3_GPIO = 0, - GPIO0C3_LCDC_D15, - GPIO0C3_TRACE_D5, - GPIO0C3_MCU_JTAG_TDO, - - GPIO0C2_SHIFT = 4, - GPIO0C2_MASK = 3 << GPIO0C2_SHIFT, - GPIO0C2_GPIO = 0, - GPIO0C2_LCDC_D14, - GPIO0C2_TRACE_D4, - GPIO0C2_MCU_JTAG_TDI, - - GPIO0C1_SHIFT = 2, - GPIO0C1_MASK = 3 << GPIO0C1_SHIFT, - GPIO0C1_GPIO = 0, - GPIO0C1_LCDC_D13, - GPIO0C1_TRACE_D3, - GPIO0C1_MCU_JTAG_TRTSN, - - GPIO0C0_SHIFT = 0, - GPIO0C0_MASK = 3 << GPIO0C0_SHIFT, - GPIO0C0_GPIO = 0, - GPIO0C0_LCDC_D12, - GPIO0C0_TRACE_D2, - GPIO0C0_MCU_JTAG_TDO, + RK3368_GPIO0C7_MASK = GENMASK(15, 14), + RK3368_GPIO0C7_GPIO = 0, + RK3368_GPIO0C7_LCDC_D19 = (1 << 14), + RK3368_GPIO0C7_TRACE_D9 = (2 << 14), + RK3368_GPIO0C7_UART1_RTSN = (3 << 14), + + RK3368_GPIO0C6_MASK = GENMASK(13, 12), + RK3368_GPIO0C6_GPIO = 0, + RK3368_GPIO0C6_LCDC_D18 = (1 << 12), + RK3368_GPIO0C6_TRACE_D8 = (2 << 12), + RK3368_GPIO0C6_UART1_CTSN = (3 << 12), + + RK3368_GPIO0C5_MASK = GENMASK(11, 10), + RK3368_GPIO0C5_GPIO = 0, + RK3368_GPIO0C5_LCDC_D17 = (1 << 10), + RK3368_GPIO0C5_TRACE_D7 = (2 << 10), + RK3368_GPIO0C5_UART1_SOUT = (3 << 10), + + RK3368_GPIO0C4_MASK = GENMASK(9, 8), + RK3368_GPIO0C4_GPIO = 0, + RK3368_GPIO0C4_LCDC_D16 = (1 << 8), + RK3368_GPIO0C4_TRACE_D6 = (2 << 8), + RK3368_GPIO0C4_UART1_SIN = (3 << 8), + + RK3368_GPIO0C3_MASK = GENMASK(7, 6), + RK3368_GPIO0C3_GPIO = 0, + RK3368_GPIO0C3_LCDC_D15 = (1 << 6), + RK3368_GPIO0C3_TRACE_D5 = (2 << 6), + RK3368_GPIO0C3_MCU_JTAG_TDO = (3 << 6), + + RK3368_GPIO0C2_MASK = GENMASK(5, 4), + RK3368_GPIO0C2_GPIO = 0, + RK3368_GPIO0C2_LCDC_D14 = (1 << 4), + RK3368_GPIO0C2_TRACE_D4 = (2 << 4), + RK3368_GPIO0C2_MCU_JTAG_TDI = (3 << 4), + + RK3368_GPIO0C1_MASK = GENMASK(3, 2), + RK3368_GPIO0C1_GPIO = 0, + RK3368_GPIO0C1_LCDC_D13 = (1 << 2), + RK3368_GPIO0C1_TRACE_D3 = (2 << 2), + RK3368_GPIO0C1_MCU_JTAG_TRTSN = (3 << 2), + + RK3368_GPIO0C0_MASK = GENMASK(1, 0), + RK3368_GPIO0C0_GPIO = 0, + RK3368_GPIO0C0_LCDC_D12 = (1 << 0), + RK3368_GPIO0C0_TRACE_D2 = (2 << 0), + RK3368_GPIO0C0_MCU_JTAG_TDO = (3 << 0), };
/*GRF_GPIO0D_IOMUX*/ enum { - GPIO0D7_SHIFT = 14, - GPIO0D7_MASK = 3 << GPIO0D7_SHIFT, - GPIO0D7_GPIO = 0, - GPIO0D7_LCDC_DCLK, - GPIO0D7_TRACE_CTL, - GPIO0D7_PMU_DEBUG5, - - GPIO0D6_SHIFT = 12, - GPIO0D6_MASK = 3 << GPIO0D6_SHIFT, - GPIO0D6_GPIO = 0, - GPIO0D6_LCDC_DEN, - GPIO0D6_TRACE_CLK, - GPIO0D6_PMU_DEBUG4, - - GPIO0D5_SHIFT = 10, - GPIO0D5_MASK = 3 << GPIO0D5_SHIFT, - GPIO0D5_GPIO = 0, - GPIO0D5_LCDC_VSYNC, - GPIO0D5_TRACE_D15, - GPIO0D5_PMU_DEBUG3, - - GPIO0D4_SHIFT = 8, - GPIO0D4_MASK = 3 << GPIO0D4_SHIFT, - GPIO0D4_GPIO = 0, - GPIO0D4_LCDC_HSYNC, - GPIO0D4_TRACE_D14, - GPIO0D4_PMU_DEBUG2, - - GPIO0D3_SHIFT = 6, - GPIO0D3_MASK = 3 << GPIO0D3_SHIFT, - GPIO0D3_GPIO = 0, - GPIO0D3_LCDC_D23, - GPIO0D3_TRACE_D13, - GPIO0D3_UART4_SIN, - - GPIO0D2_SHIFT = 4, - GPIO0D2_MASK = 3 << GPIO0D2_SHIFT, - GPIO0D2_GPIO = 0, - GPIO0D2_LCDC_D22, - GPIO0D2_TRACE_D12, - GPIO0D2_UART4_SOUT, - - GPIO0D1_SHIFT = 2, - GPIO0D1_MASK = 3 << GPIO0D1_SHIFT, - GPIO0D1_GPIO = 0, - GPIO0D1_LCDC_D21, - GPIO0D1_TRACE_D11, - GPIO0D1_UART4_RTSN, - - GPIO0D0_SHIFT = 0, - GPIO0D0_MASK = 3 << GPIO0D0_SHIFT, - GPIO0D0_GPIO = 0, - GPIO0D0_LCDC_D20, - GPIO0D0_TRACE_D10, - GPIO0D0_UART4_CTSN, + RK3368_GPIO0D7_MASK = GENMASK(15, 14), + RK3368_GPIO0D7_GPIO = 0, + RK3368_GPIO0D7_LCDC_DCLK = (1 << 14), + RK3368_GPIO0D7_TRACE_CTL = (2 << 14), + RK3368_GPIO0D7_PMU_DEBUG5 = (3 << 14), + + RK3368_GPIO0D6_MASK = GENMASK(13, 12), + RK3368_GPIO0D6_GPIO = 0, + RK3368_GPIO0D6_LCDC_DEN = (1 << 12), + RK3368_GPIO0D6_TRACE_CLK = (2 << 12), + RK3368_GPIO0D6_PMU_DEBUG4 = (3 << 12), + + RK3368_GPIO0D5_MASK = GENMASK(11, 10), + RK3368_GPIO0D5_GPIO = 0, + GPIO0D5_LCDC_VSYNC = (1 << 10), + RK3368_GPIO0D5_TRACE_D15 = (2 << 10), + RK3368_GPIO0D5_PMU_DEBUG3 = (3 << 10), + + RK3368_GPIO0D4_MASK = GENMASK(9, 8), + RK3368_GPIO0D4_GPIO = 0, + RK3368_GPIO0D4_LCDC_HSYNC = (1 << 8), + RK3368_GPIO0D4_TRACE_D14 = (2 << 8), + RK3368_GPIO0D4_PMU_DEBUG2 = (3 << 8), + + RK3368_GPIO0D3_MASK = GENMASK(7, 6), + RK3368_GPIO0D3_GPIO = 0, + RK3368_GPIO0D3_LCDC_D23 = (1 << 6), + RK3368_GPIO0D3_TRACE_D13 = (2 << 6), + RK3368_GPIO0D3_UART4_SIN = (3 << 6), + + RK3368_GPIO0D2_MASK = GENMASK(5, 4), + RK3368_GPIO0D2_GPIO = 0, + RK3368_GPIO0D2_LCDC_D22 = (1 << 4), + RK3368_GPIO0D2_TRACE_D12 = (2 << 4), + RK3368_GPIO0D2_UART4_SOUT = (3 << 4), + + RK3368_GPIO0D1_MASK = GENMASK(3, 2), + RK3368_GPIO0D1_GPIO = 0, + RK3368_GPIO0D1_LCDC_D21 = (1 << 2), + RK3368_GPIO0D1_TRACE_D11 = (2 << 2), + RK3368_GPIO0D1_UART4_RTSN = (3 << 2), + + RK3368_GPIO0D0_MASK = GENMASK(1, 0), + RK3368_GPIO0D0_GPIO = 0, + RK3368_GPIO0D0_LCDC_D20 = (1 << 0), + RK3368_GPIO0D0_TRACE_D10 = (2 << 0), + RK3368_GPIO0D0_UART4_CTSN = (3 << 0), };
/*GRF_GPIO2A_IOMUX*/ enum { - GPIO2A7_SHIFT = 14, - GPIO2A7_MASK = 3 << GPIO2A7_SHIFT, - GPIO2A7_GPIO = 0, - GPIO2A7_SDMMC0_D2, - GPIO2A7_JTAG_TCK, - - GPIO2A6_SHIFT = 12, - GPIO2A6_MASK = 3 << GPIO2A6_SHIFT, - GPIO2A6_GPIO = 0, - GPIO2A6_SDMMC0_D1, - GPIO2A6_UART2_SIN, - - GPIO2A5_SHIFT = 10, - GPIO2A5_MASK = 3 << GPIO2A5_SHIFT, - GPIO2A5_GPIO = 0, - GPIO2A5_SDMMC0_D0, - GPIO2A5_UART2_SOUT, - - GPIO2A4_SHIFT = 8, - GPIO2A4_MASK = 3 << GPIO2A4_SHIFT, - GPIO2A4_GPIO = 0, - GPIO2A4_FLASH_DQS, - GPIO2A4_EMMC_CLKO, - - GPIO2A3_SHIFT = 6, - GPIO2A3_MASK = 3 << GPIO2A3_SHIFT, - GPIO2A3_GPIO = 0, - GPIO2A3_FLASH_CSN3, - GPIO2A3_EMMC_RSTNO, - - GPIO2A2_SHIFT = 4, - GPIO2A2_MASK = 3 << GPIO2A2_SHIFT, - GPIO2A2_GPIO = 0, - GPIO2A2_FLASH_CSN2, - - GPIO2A1_SHIFT = 2, - GPIO2A1_MASK = 3 << GPIO2A1_SHIFT, - GPIO2A1_GPIO = 0, - GPIO2A1_FLASH_CSN1, - - GPIO2A0_SHIFT = 0, - GPIO2A0_MASK = 3 << GPIO2A0_SHIFT, - GPIO2A0_GPIO = 0, - GPIO2A0_FLASH_CSN0, + RK3368_GPIO2A7_MASK = GENMASK(15, 14), + RK3368_GPIO2A7_GPIO = 0, + RK3368_GPIO2A7_SDMMC0_D2 = (1 << 14), + RK3368_GPIO2A7_JTAG_TCK = (2 << 14), + + RK3368_GPIO2A6_MASK = GENMASK(13, 12), + RK3368_GPIO2A6_GPIO = 0, + RK3368_GPIO2A6_SDMMC0_D1 = (1 << 12), + RK3368_GPIO2A6_UART2_SIN = (2 << 12), + + RK3368_GPIO2A5_MASK = GENMASK(11, 10), + RK3368_GPIO2A5_GPIO = 0, + RK3368_GPIO2A5_SDMMC0_D0 = (1 << 10), + RK3368_GPIO2A5_UART2_SOUT = (2 << 10), + + RK3368_GPIO2A4_MASK = GENMASK(9, 8), + RK3368_GPIO2A4_RK3368_GPIO = 0, + RK3368_GPIO2A4_FLASH_DQS = (1 << 8), + RK3368_GPIO2A4_EMMC_CLKOUT = (2 << 8), + + RK3368_GPIO2A3_MASK = GENMASK(7, 6), + RK3368_GPIO2A3_GPIO = 0, + RK3368_GPIO2A3_FLASH_CSN3 = (1 << 6), + RK3368_GPIO2A3_EMMC_RSTNOUT = (2 << 6), + + RK3368_GPIO2A2_MASK = GENMASK(5, 4), + RK3368_GPIO2A2_GPIO = 0, + RK3368_GPIO2A2_FLASH_CSN2 = (1 << 4), + + RK3368_GPIO2A1_MASK = GENMASK(3, 2), + RK3368_GPIO2A1_GPIO = 0, + RK3368_GPIO2A1_FLASH_CSN1 = (1 << 2), + + RK3368_GPIO2A0_MASK = GENMASK(1, 0), + RK3368_GPIO2A0_GPIO = 0, + RK3368_GPIO2A0_FLASH_CSN0 = (1 << 0), };
-/*GRF_GPIO2D_IOMUX*/ +/*GRF_RK3368_GPIO2D_IOMUX*/ enum { - GPIO2D7_SHIFT = 14, - GPIO2D7_MASK = 3 << GPIO2D7_SHIFT, - GPIO2D7_GPIO = 0, - GPIO2D7_SDIO0_D3, - - GPIO2D6_SHIFT = 12, - GPIO2D6_MASK = 3 << GPIO2D6_SHIFT, - GPIO2D6_GPIO = 0, - GPIO2D6_SDIO0_D2, - - GPIO2D5_SHIFT = 10, - GPIO2D5_MASK = 3 << GPIO2D5_SHIFT, - GPIO2D5_GPIO = 0, - GPIO2D5_SDIO0_D1, - - GPIO2D4_SHIFT = 8, - GPIO2D4_MASK = 3 << GPIO2D4_SHIFT, - GPIO2D4_GPIO = 0, - GPIO2D4_SDIO0_D0, - - GPIO2D3_SHIFT = 6, - GPIO2D3_MASK = 3 << GPIO2D3_SHIFT, - GPIO2D3_GPIO = 0, - GPIO2D3_UART0_RTS0, - - GPIO2D2_SHIFT = 4, - GPIO2D2_MASK = 3 << GPIO2D2_SHIFT, - GPIO2D2_GPIO = 0, - GPIO2D2_UART0_CTS0, - - GPIO2D1_SHIFT = 2, - GPIO2D1_MASK = 3 << GPIO2D1_SHIFT, - GPIO2D1_GPIO = 0, - GPIO2D1_UART0_SOUT, - - GPIO2D0_SHIFT = 0, - GPIO2D0_MASK = 3 << GPIO2D0_SHIFT, - GPIO2D0_GPIO = 0, - GPIO2D0_UART0_SIN, + RK3368_GPIO2D7_MASK = GENMASK(15, 14), + RK3368_GPIO2D7_GPIO = 0, + RK3368_GPIO2D7_SDIO0_D3 = (1 << 14), + + RK3368_GPIO2D6_MASK = GENMASK(13, 12), + RK3368_GPIO2D6_GPIO = 0, + RK3368_GPIO2D6_SDIO0_D2 = (1 << 12), + + RK3368_GPIO2D5_MASK = GENMASK(11, 10), + RK3368_GPIO2D5_GPIO = 0, + RK3368_GPIO2D5_SDIO0_D1 = (1 << 10), + + RK3368_GPIO2D4_MASK = GENMASK(9, 8), + RK3368_GPIO2D4_GPIO = 0, + RK3368_GPIO2D4_SDIO0_D0 = (1 << 8), + + RK3368_GPIO2D3_MASK = GENMASK(7, 6), + RK3368_GPIO2D3_GPIO = 0, + RK3368_GPIO2D3_UART0_RTS0 = (1 << 6), + + RK3368_GPIO2D2_MASK = GENMASK(5, 4), + RK3368_GPIO2D2_GPIO = 0, + RK3368_GPIO2D2_UART0_CTS0 = (1 << 4), + + RK3368_GPIO2D1_MASK = GENMASK(3, 2), + RK3368_GPIO2D1_GPIO = 0, + RK3368_GPIO2D1_UART0_SOUT = (1 << 2), + + RK3368_GPIO2D0_MASK = GENMASK(1, 0), + RK3368_GPIO2D0_GPIO = 0, + RK3368_GPIO2D0_UART0_SIN = (1 << 0), +}; + +/* GRF_GPIO1C_IOMUX */ +enum { + RK3368_GPIO1C7_MASK = GENMASK(15, 14), + RK3368_GPIO1C7_GPIO = 0, + RK3368_GPIO1C7_EMMC_DATA5 = (2 << 14), + + RK3368_GPIO1C6_MASK = GENMASK(13, 12), + RK3368_GPIO1C6_GPIO = 0, + RK3368_GPIO1C6_EMMC_DATA4 = (2 << 12), + + RK3368_GPIO1C5_MASK = GENMASK(11, 10), + RK3368_GPIO1C5_GPIO = 0, + RK3368_GPIO1C5_EMMC_DATA3 = (2 << 10), + + RK3368_GPIO1C4_MASK = GENMASK(9, 8), + RK3368_GPIO1C4_GPIO = 0, + RK3368_GPIO1C4_EMMC_DATA2 = (2 << 8), + + RK3368_GPIO1C3_MASK = GENMASK(7, 6), + RK3368_GPIO1C3_GPIO = 0, + RK3368_GPIO1C3_EMMC_DATA1 = (2 << 6), + + RK3368_GPIO1C2_MASK = GENMASK(5, 4), + RK3368_GPIO1C2_GPIO = 0, + RK3368_GPIO1C2_EMMC_DATA0 = (2 << 4), +}; + +/* GRF_GPIO1D_IOMUX*/ +enum { + RK3368_GPIO1D3_MASK = GENMASK(7, 6), + RK3368_GPIO1D3_GPIO = 0, + RK3368_GPIO1D3_EMMC_PWREN = (2 << 6), + + RK3368_GPIO1D2_MASK = GENMASK(5, 4), + RK3368_GPIO1D2_GPIO = 0, + RK3368_GPIO1D2_EMMC_CMD = (2 << 4), + + RK3368_GPIO1D1_MASK = GENMASK(3, 2), + RK3368_GPIO1D1_GPIO = 0, + RK3368_GPIO1D1_EMMC_DATA7 = (2 << 2), + + RK3368_GPIO1D0_MASK = GENMASK(1, 0), + RK3368_GPIO1D0_GPIO = 0, + RK3368_GPIO1D0_EMMC_DATA6 = (2 << 0), +}; + + +/*GRF_GPIO3B_IOMUX*/ +enum { + RK3368_GPIO3B7_MASK = GENMASK(15, 14), + RK3368_GPIO3B7_GPIO = 0, + RK3368_GPIO3B7_MAC_RXD0 = (1 << 14), + + RK3368_GPIO3B6_MASK = GENMASK(13, 12), + RK3368_GPIO3B6_GPIO = 0, + RK3368_GPIO3B6_MAC_TXD3 = (1 << 12), + + RK3368_GPIO3B5_MASK = GENMASK(11, 10), + RK3368_GPIO3B5_GPIO = 0, + RK3368_GPIO3B5_MAC_TXEN = (1 << 10), + + RK3368_GPIO3B4_MASK = GENMASK(9, 8), + RK3368_GPIO3B4_GPIO = 0, + RK3368_GPIO3B4_MAC_COL = (1 << 8), + + RK3368_GPIO3B3_MASK = GENMASK(7, 6), + RK3368_GPIO3B3_GPIO = 0, + RK3368_GPIO3B3_MAC_CRS = (1 << 6), + + RK3368_GPIO3B2_MASK = GENMASK(5, 4), + RK3368_GPIO3B2_GPIO = 0, + RK3368_GPIO3B2_MAC_TXD2 = (1 << 4), + + RK3368_GPIO3B1_MASK = GENMASK(3, 2), + RK3368_GPIO3B1_GPIO = 0, + RK3368_GPIO3B1_MAC_TXD1 = (1 << 2), + + RK3368_GPIO3B0_MASK = GENMASK(1, 0), + RK3368_GPIO3B0_GPIO = 0, + RK3368_GPIO3B0_MAC_TXD0 = (1 << 0), + RK3368_GPIO3B0_PWM0 = (2 << 0), };
/*GRF_GPIO3C_IOMUX*/ enum { - GPIO3C7_SHIFT = 14, - GPIO3C7_MASK = 3 << GPIO3C7_SHIFT, - GPIO3C7_GPIO = 0, - GPIO3C7_EDPHDMI_CECINOUT, - GPIO3C7_ISP_FLASHTRIGIN, - - GPIO3C6_SHIFT = 12, - GPIO3C6_MASK = 3 << GPIO3C6_SHIFT, - GPIO3C6_GPIO = 0, - GPIO3C6_MAC_CLK, - GPIO3C6_ISP_SHUTTERTRIG, - - GPIO3C5_SHIFT = 10, - GPIO3C5_MASK = 3 << GPIO3C5_SHIFT, - GPIO3C5_GPIO = 0, - GPIO3C5_MAC_RXER, - GPIO3C5_ISP_PRELIGHTTRIG, - - GPIO3C4_SHIFT = 8, - GPIO3C4_MASK = 3 << GPIO3C4_SHIFT, - GPIO3C4_GPIO = 0, - GPIO3C4_MAC_RXDV, - GPIO3C4_ISP_FLASHTRIGOUT, - - GPIO3C3_SHIFT = 6, - GPIO3C3_MASK = 3 << GPIO3C3_SHIFT, - GPIO3C3_GPIO = 0, - GPIO3C3_MAC_RXDV, - GPIO3C3_EMMC_RSTNO, - - GPIO3C2_SHIFT = 4, - GPIO3C2_MASK = 3 << GPIO3C2_SHIFT, - GPIO3C2_MAC_MDC = 0, - GPIO3C2_ISP_SHUTTEREN, - - GPIO3C1_SHIFT = 2, - GPIO3C1_MASK = 3 << GPIO3C1_SHIFT, - GPIO3C1_GPIO = 0, - GPIO3C1_MAC_RXD2, - GPIO3C1_UART3_RTSN, - - GPIO3C0_SHIFT = 0, - GPIO3C0_MASK = 3 << GPIO3C0_SHIFT, - GPIO3C0_GPIO = 0, - GPIO3C0_MAC_RXD1, - GPIO3C0_UART3_CTSN, - GPIO3C0_GPS_RFCLK, + RK3368_GPIO3C6_MASK = GENMASK(13, 12), + RK3368_GPIO3C6_GPIO = 0, + RK3368_GPIO3C6_MAC_CLK = (1 << 12), + + RK3368_GPIO3C5_MASK = GENMASK(11, 10), + RK3368_GPIO3C5_GPIO = 0, + RK3368_GPIO3C5_MAC_RXEN = (1 << 10), + + RK3368_GPIO3C4_MASK = GENMASK(9, 8), + RK3368_GPIO3C4_GPIO = 0, + RK3368_GPIO3C4_MAC_RXDV = (1 << 8), + + RK3368_GPIO3C3_MASK = GENMASK(7, 6), + RK3368_GPIO3C3_GPIO = 0, + RK3368_GPIO3C3_MAC_MDC = (1 << 6), + + RK3368_GPIO3C2_MASK = GENMASK(5, 4), + RK3368_GPIO3C2_GPIO = 0, + RK3368_GPIO3C2_MAC_RXD3 = (1 << 4), + + RK3368_GPIO3C1_MASK = GENMASK(3, 2), + RK3368_GPIO3C1_GPIO = 0, + RK3368_GPIO3C1_MAC_RXD2 = (1 << 2), + + RK3368_GPIO3C0_MASK = GENMASK(1, 0), + RK3368_GPIO3C0_GPIO = 0, + RK3368_GPIO3C0_MAC_RXD1 = (1 << 0), };
/*GRF_GPIO3D_IOMUX*/ enum { - GPIO3D7_SHIFT = 14, - GPIO3D7_MASK = 3 << GPIO3D7_SHIFT, - GPIO3D7_GPIO = 0, - GPIO3D7_SC_VCC18V, - GPIO3D7_I2C2_SDA, - GPIO3D7_GPUJTAG_TCK, - - GPIO3D6_SHIFT = 12, - GPIO3D6_MASK = 3 << GPIO3D6_SHIFT, - GPIO3D6_GPIO = 0, - GPIO3D6_IR_TX, - GPIO3D6_UART3_SOUT, - GPIO3D6_PWM3, - - GPIO3D5_SHIFT = 10, - GPIO3D5_MASK = 3 << GPIO3D5_SHIFT, - GPIO3D5_GPIO = 0, - GPIO3D5_IR_RX, - GPIO3D5_UART3_SIN, - - GPIO3D4_SHIFT = 8, - GPIO3D4_MASK = 3 << GPIO3D4_SHIFT, - GPIO3D4_GPIO = 0, - GPIO3D4_MAC_TXCLKOUT, - GPIO3D4_SPI1_CSN1, - - GPIO3D3_SHIFT = 6, - GPIO3D3_MASK = 3 << GPIO3D3_SHIFT, - GPIO3D3_GPIO = 0, - GPIO3D3_HDMII2C_SCL, - GPIO3D3_I2C5_SCL, - - GPIO3D2_SHIFT = 4, - GPIO3D2_MASK = 3 << GPIO3D2_SHIFT, - GPIO3D2_GPIO = 0, - GPIO3D2_HDMII2C_SDA, - GPIO3D2_I2C5_SDA, - - GPIO3D1_SHIFT = 2, - GPIO3D1_MASK = 3 << GPIO3D1_SHIFT, - GPIO3D1_GPIO = 0, - GPIO3D1_MAC_RXCLKIN, - GPIO3D1_I2C4_SCL, - - GPIO3D0_SHIFT = 0, - GPIO3D0_MASK = 3 << GPIO3D0_SHIFT, - GPIO3D0_GPIO = 0, - GPIO3D0_MAC_MDIO, - GPIO3D0_I2C4_SDA, + RK3368_GPIO3D4_MASK = GENMASK(9, 8), + RK3368_GPIO3D4_GPIO = 0, + RK3368_GPIO3D4_MAC_TXCLK = (1 << 8), + + RK3368_GPIO3D1_MASK = GENMASK(3, 2), + RK3368_GPIO3D1_GPIO = 0, + RK3368_GPIO3D1_MAC_RXCLK = (1 << 2), + + RK3368_GPIO3D0_MASK = GENMASK(1, 0), + RK3368_GPIO3D0_GPIO = 0, + RK3368_GPIO3D0_MAC_MDIO = (1 << 0), +}; + +/* GRF_SOC_CON0 */ +enum { + NOC_RSP_ERR_STALL = BIT(9), + MOBILE_DDR_SEL = BIT(4), + DDR0_16BIT_EN = BIT(3), + MSCH0_MAINDDR3_DDR3 = BIT(2), + MSCH0_MAINPARTIALPOP = BIT(1), + UPCTL_C_ACTIVE = BIT(0), };
/*GRF_SOC_CON11/12/13*/ @@ -440,4 +445,34 @@ enum { MCU_CODE_BASE_BIT31_BIT28_SHIFT = 0, MCU_CODE_BASE_BIT31_BIT28_MASK = GENMASK(3, 0), }; + +/*GRF_SOC_CON15*/ +enum { + RK3368_GMAC_PHY_INTF_SEL_RGMII = 1 << 9, + RK3368_GMAC_PHY_INTF_SEL_MASK = GENMASK(11, 9), + RK3368_RMII_MODE_MASK = BIT(6), + RK3368_RMII_MODE = BIT(6), + RK3368_GMAC_CLK_SEL_2_5M = 2 << 4, + RK3368_GMAC_CLK_SEL_25M = 3 << 4, + RK3368_GMAC_CLK_SEL_125M = 0 << 4, + RK3368_GMAC_CLK_SEL_MASK = GENMASK(5, 4), +}; + +/* GRF_SOC_CON16 */ +enum { + RK3368_RXCLK_DLY_ENA_GMAC_MASK = BIT(15), + RK3368_RXCLK_DLY_ENA_GMAC_DISABLE = 0, + RK3368_RXCLK_DLY_ENA_GMAC_ENABLE = BIT(15), + + RK3368_TXCLK_DLY_ENA_GMAC_MASK = BIT(7), + RK3368_TXCLK_DLY_ENA_GMAC_DISABLE = 0, + RK3368_TXCLK_DLY_ENA_GMAC_ENABLE = BIT(7), + + RK3368_CLK_RX_DL_CFG_GMAC_SHIFT = 8, + RK3368_CLK_RX_DL_CFG_GMAC_MASK = GENMASK(14, 8), + + RK3368_CLK_TX_DL_CFG_GMAC_SHIFT = 0, + RK3368_CLK_TX_DL_CFG_GMAC_MASK = GENMASK(6, 0), +}; + #endif diff --git a/drivers/pinctrl/rockchip/pinctrl_rk3368.c b/drivers/pinctrl/rockchip/pinctrl_rk3368.c index bdf0758..b77c5ab 100644 --- a/drivers/pinctrl/rockchip/pinctrl_rk3368.c +++ b/drivers/pinctrl/rockchip/pinctrl_rk3368.c @@ -30,9 +30,9 @@ static void pinctrl_rk3368_uart_config(struct rk3368_pinctrl_priv *priv, switch (uart_id) { case PERIPH_ID_UART2: rk_clrsetreg(&grf->gpio2a_iomux, - GPIO2A6_MASK | GPIO2A5_MASK, - GPIO2A6_UART2_SIN << GPIO2A6_SHIFT | - GPIO2A5_UART2_SOUT << GPIO2A5_SHIFT); + RK3368_GPIO2A6_MASK | RK3368_GPIO2A5_MASK, + RK3368_GPIO2A6_UART2_SIN | + RK3368_GPIO2A5_UART2_SOUT); break; case PERIPH_ID_UART0: break; @@ -42,12 +42,11 @@ static void pinctrl_rk3368_uart_config(struct rk3368_pinctrl_priv *priv, break; case PERIPH_ID_UART4: rk_clrsetreg(&pmugrf->gpio0d_iomux, - GPIO0D0_MASK | GPIO0D1_MASK | - GPIO0D2_MASK | GPIO0D3_MASK, - GPIO0D0_GPIO << GPIO0D0_SHIFT | - GPIO0D1_GPIO << GPIO0D1_SHIFT | - GPIO0D2_UART4_SOUT << GPIO0D2_SHIFT | - GPIO0D3_UART4_SIN << GPIO0D3_SHIFT); + RK3368_GPIO0D0_MASK | RK3368_GPIO0D1_MASK | + RK3368_GPIO0D2_MASK | RK3368_GPIO0D3_MASK, + RK3368_GPIO0D0_GPIO | RK3368_GPIO0D1_GPIO | + RK3368_GPIO0D2_UART4_SOUT | + RK3368_GPIO0D3_UART4_SIN); break; default: debug("uart id = %d iomux error!\n", uart_id);
Hi Philipp:
Is that really necessary to add such a prefix for all the register definition, just to fit the GMAC dirver? Maybe the gmac driver can define the platform specific macro in its own code like dwmac-rk in the kernel. Then we can keep the register header file a little tidy.
Signed-off-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
- (C) Copyright 2016 Rockchip Electronics Co., Ltd
- GPIO0C7_GPIO = 0,
- GPIO0C7_LCDC_D19,
- GPIO0C7_TRACE_D9,
- GPIO0C6_GPIO = 0,
- GPIO0C6_LCDC_D18,
- GPIO0C6_TRACE_D8,
- GPIO0C5_GPIO = 0,
- GPIO0C5_LCDC_D17,
- GPIO0C5_TRACE_D7,
- GPIO0C4_GPIO = 0,
- GPIO0C4_LCDC_D16,
- GPIO0C4_TRACE_D6,
- GPIO0C3_GPIO = 0,
- GPIO0C3_LCDC_D15,
- GPIO0C3_TRACE_D5,
- GPIO0C2_GPIO = 0,
- GPIO0C2_LCDC_D14,
- GPIO0C2_TRACE_D4,
- GPIO0C1_GPIO = 0,
- GPIO0C1_LCDC_D13,
- GPIO0C1_TRACE_D3,
- GPIO0C0_GPIO = 0,
- GPIO0C0_LCDC_D12,
- GPIO0C0_TRACE_D2,
- GPIO0D7_GPIO = 0,
- GPIO0D6_GPIO = 0,
- GPIO0D6_LCDC_DEN,
- GPIO0D5_GPIO = 0,
- GPIO0D4_GPIO = 0,
- GPIO0D3_GPIO = 0,
- GPIO0D3_LCDC_D23,
- GPIO0D2_GPIO = 0,
- GPIO0D2_LCDC_D22,
- GPIO0D1_GPIO = 0,
- GPIO0D1_LCDC_D21,
- GPIO0D0_GPIO = 0,
- GPIO0D0_LCDC_D20,
- GPIO2A7_GPIO = 0,
- GPIO2A7_JTAG_TCK,
- GPIO2A6_GPIO = 0,
- GPIO2A5_GPIO = 0,
- GPIO2A4_GPIO = 0,
- GPIO2A3_GPIO = 0,
- GPIO2A2_GPIO = 0,
- GPIO2A1_GPIO = 0,
- GPIO2A0_GPIO = 0,
- RK3368_GPIO2A7_MASK = GENMASK(15, 14),
- RK3368_GPIO2A7_GPIO = 0,
- RK3368_GPIO2A7_SDMMC0_D2 = (1 << 14),
- RK3368_GPIO2A7_JTAG_TCK = (2 << 14),
- RK3368_GPIO2A6_MASK = GENMASK(13, 12),
- RK3368_GPIO2A6_GPIO = 0,
- RK3368_GPIO2A6_SDMMC0_D1 = (1 << 12),
- RK3368_GPIO2A6_UART2_SIN = (2 << 12),
- RK3368_GPIO2A5_MASK = GENMASK(11, 10),
- RK3368_GPIO2A5_GPIO = 0,
- RK3368_GPIO2A5_SDMMC0_D0 = (1 << 10),
- RK3368_GPIO2A5_UART2_SOUT = (2 << 10),
- RK3368_GPIO2A4_MASK = GENMASK(9, 8),
- RK3368_GPIO2A4_RK3368_GPIO = 0,
- RK3368_GPIO2A4_FLASH_DQS = (1 << 8),
- RK3368_GPIO2A4_EMMC_CLKOUT = (2 << 8),
- RK3368_GPIO2A3_MASK = GENMASK(7, 6),
- RK3368_GPIO2A3_GPIO = 0,
- RK3368_GPIO2A3_FLASH_CSN3 = (1 << 6),
- RK3368_GPIO2A3_EMMC_RSTNOUT = (2 << 6),
- RK3368_GPIO2A2_MASK = GENMASK(5, 4),
- RK3368_GPIO2A2_GPIO = 0,
- RK3368_GPIO2A2_FLASH_CSN2 = (1 << 4),
- RK3368_GPIO2A1_MASK = GENMASK(3, 2),
- RK3368_GPIO2A1_GPIO = 0,
- RK3368_GPIO2A1_FLASH_CSN1 = (1 << 2),
- RK3368_GPIO2A0_MASK = GENMASK(1, 0),
- RK3368_GPIO2A0_GPIO = 0,
- RK3368_GPIO2A0_FLASH_CSN0 = (1 << 0), };
- GPIO2D7_GPIO = 0,
- GPIO2D7_SDIO0_D3,
- GPIO2D6_GPIO = 0,
- GPIO2D6_SDIO0_D2,
- GPIO2D5_GPIO = 0,
- GPIO2D5_SDIO0_D1,
- GPIO2D4_GPIO = 0,
- GPIO2D4_SDIO0_D0,
- GPIO2D3_GPIO = 0,
- GPIO2D2_GPIO = 0,
- GPIO2D1_GPIO = 0,
- GPIO2D0_GPIO = 0,
- RK3368_GPIO2D7_MASK = GENMASK(15, 14),
- RK3368_GPIO2D7_GPIO = 0,
- RK3368_GPIO2D7_SDIO0_D3 = (1 << 14),
- RK3368_GPIO2D6_MASK = GENMASK(13, 12),
- RK3368_GPIO2D6_GPIO = 0,
- RK3368_GPIO2D6_SDIO0_D2 = (1 << 12),
- RK3368_GPIO2D5_MASK = GENMASK(11, 10),
- RK3368_GPIO2D5_GPIO = 0,
- RK3368_GPIO2D5_SDIO0_D1 = (1 << 10),
- RK3368_GPIO2D4_MASK = GENMASK(9, 8),
- RK3368_GPIO2D4_GPIO = 0,
- RK3368_GPIO2D4_SDIO0_D0 = (1 << 8),
- RK3368_GPIO2D3_MASK = GENMASK(7, 6),
- RK3368_GPIO2D3_GPIO = 0,
- RK3368_GPIO2D3_UART0_RTS0 = (1 << 6),
- RK3368_GPIO2D2_MASK = GENMASK(5, 4),
- RK3368_GPIO2D2_GPIO = 0,
- RK3368_GPIO2D2_UART0_CTS0 = (1 << 4),
- RK3368_GPIO2D1_MASK = GENMASK(3, 2),
- RK3368_GPIO2D1_GPIO = 0,
- RK3368_GPIO2D1_UART0_SOUT = (1 << 2),
- RK3368_GPIO2D0_MASK = GENMASK(1, 0),
- RK3368_GPIO2D0_GPIO = 0,
- RK3368_GPIO2D0_UART0_SIN = (1 << 0),
- RK3368_GPIO1C7_MASK = GENMASK(15, 14),
- RK3368_GPIO1C7_GPIO = 0,
- RK3368_GPIO1C7_EMMC_DATA5 = (2 << 14),
- RK3368_GPIO1C6_MASK = GENMASK(13, 12),
- RK3368_GPIO1C6_GPIO = 0,
- RK3368_GPIO1C6_EMMC_DATA4 = (2 << 12),
- RK3368_GPIO1C5_MASK = GENMASK(11, 10),
- RK3368_GPIO1C5_GPIO = 0,
- RK3368_GPIO1C5_EMMC_DATA3 = (2 << 10),
- RK3368_GPIO1C4_MASK = GENMASK(9, 8),
- RK3368_GPIO1C4_GPIO = 0,
- RK3368_GPIO1C4_EMMC_DATA2 = (2 << 8),
- RK3368_GPIO1C3_MASK = GENMASK(7, 6),
- RK3368_GPIO1C3_GPIO = 0,
- RK3368_GPIO1C3_EMMC_DATA1 = (2 << 6),
- RK3368_GPIO1C2_MASK = GENMASK(5, 4),
- RK3368_GPIO1C2_GPIO = 0,
- RK3368_GPIO1C2_EMMC_DATA0 = (2 << 4),
- RK3368_GPIO1D3_MASK = GENMASK(7, 6),
- RK3368_GPIO1D3_GPIO = 0,
- RK3368_GPIO1D3_EMMC_PWREN = (2 << 6),
- RK3368_GPIO1D2_MASK = GENMASK(5, 4),
- RK3368_GPIO1D2_GPIO = 0,
- RK3368_GPIO1D2_EMMC_CMD = (2 << 4),
- RK3368_GPIO1D1_MASK = GENMASK(3, 2),
- RK3368_GPIO1D1_GPIO = 0,
- RK3368_GPIO1D1_EMMC_DATA7 = (2 << 2),
- RK3368_GPIO1D0_MASK = GENMASK(1, 0),
- RK3368_GPIO1D0_GPIO = 0,
- RK3368_GPIO1D0_EMMC_DATA6 = (2 << 0),
- GPIO3C7_GPIO = 0,
- GPIO3C6_GPIO = 0,
- GPIO3C6_MAC_CLK,
- GPIO3C5_GPIO = 0,
- GPIO3C5_MAC_RXER,
- GPIO3C4_GPIO = 0,
- GPIO3C4_MAC_RXDV,
- GPIO3C3_GPIO = 0,
- GPIO3C3_MAC_RXDV,
- GPIO3C1_GPIO = 0,
- GPIO3C1_MAC_RXD2,
- GPIO3C0_GPIO = 0,
- GPIO3C0_MAC_RXD1,
- GPIO3D7_GPIO = 0,
- GPIO3D7_I2C2_SDA,
- GPIO3D6_GPIO = 0,
- GPIO3D6_IR_TX,
- GPIO3D6_PWM3,
- GPIO3D5_GPIO = 0,
- GPIO3D5_IR_RX,
- GPIO3D4_GPIO = 0,
- GPIO3D3_GPIO = 0,
- GPIO3D3_I2C5_SCL,
- GPIO3D2_GPIO = 0,
- GPIO3D2_I2C5_SDA,
- GPIO3D1_GPIO = 0,
- GPIO3D1_I2C4_SCL,
- GPIO3D0_GPIO = 0,
- GPIO3D0_MAC_MDIO,
- GPIO3D0_I2C4_SDA,
- RK3368_GPIO3D4_MASK = GENMASK(9, 8),
- RK3368_GPIO3D4_GPIO = 0,
- RK3368_GPIO3D4_MAC_TXCLK = (1 << 8),
- RK3368_GPIO3D1_MASK = GENMASK(3, 2),
- RK3368_GPIO3D1_GPIO = 0,
- RK3368_GPIO3D1_MAC_RXCLK = (1 << 2),
- RK3368_GPIO3D0_MASK = GENMASK(1, 0),
- RK3368_GPIO3D0_GPIO = 0,
- RK3368_GPIO3D0_MAC_MDIO = (1 << 0),
- RK3368_GMAC_PHY_INTF_SEL_RGMII = 1 << 9,
- RK3368_GMAC_PHY_INTF_SEL_MASK = GENMASK(11, 9),
- RK3368_RMII_MODE_MASK = BIT(6),
- RK3368_RMII_MODE = BIT(6),
- RK3368_GMAC_CLK_SEL_2_5M = 2 << 4,
- RK3368_GMAC_CLK_SEL_25M = 3 << 4,
- RK3368_GMAC_CLK_SEL_125M = 0 << 4,
- RK3368_GMAC_CLK_SEL_MASK = GENMASK(5, 4),
- RK3368_RXCLK_DLY_ENA_GMAC_MASK = BIT(15),
- RK3368_RXCLK_DLY_ENA_GMAC_DISABLE = 0,
- RK3368_RXCLK_DLY_ENA_GMAC_ENABLE = BIT(15),
- RK3368_TXCLK_DLY_ENA_GMAC_MASK = BIT(7),
- RK3368_TXCLK_DLY_ENA_GMAC_DISABLE = 0,
- RK3368_TXCLK_DLY_ENA_GMAC_ENABLE = BIT(7),
- RK3368_CLK_RX_DL_CFG_GMAC_SHIFT = 8,
- RK3368_CLK_RX_DL_CFG_GMAC_MASK = GENMASK(14, 8),
- RK3368_CLK_TX_DL_CFG_GMAC_SHIFT = 0,
- RK3368_CLK_TX_DL_CFG_GMAC_MASK = GENMASK(6, 0),
- #endif
break; case PERIPH_ID_UART0: break;RK3368_GPIO2A5_UART2_SOUT);
break; default: debug("uart id = %d iomux error!\n", uart_id);RK3368_GPIO0D3_UART4_SIN);
On 21 Jul 2017, at 05:50, Andy Yan andy.yan@rock-chips.com wrote:
Hi Philipp:
The problem is not the GMAC driver (although it was the motivation for doing this change), but rather how easy it is to pick up the wrong grf-file and refer to the wrong definitions/values… the conflicts are not through the GMAC-specifc defines but rather through things like the IOMUX masks or (before I moved this to the DDR-driver) things like the defines to enable DRAM in GRF.
Until we find a way to consistently structure things in such a way that (a) common constructs can be shared (e.g. the masks in the IOMUX) (b) specific definitions (e.g. the pin-out for a specific device) is not visible outside of its driver I prefer the names to explicitly refer to each device.
That said, the longer-term plan (especially with a larger number of devices being supported) needs to include a consistent rework of how (and where) we manage all these definitions from the grf-header files.
@@ -100,315 +102,318 @@ check_member(rk3368_pmu_grf, os_reg[0], 0x200); /*GRF_GPIO0C_IOMUX*/ enum {
- GPIO0C7_GPIO = 0,
- GPIO0C7_LCDC_D19,
- GPIO0C7_TRACE_D9,
- GPIO0C6_GPIO = 0,
- GPIO0C6_LCDC_D18,
- GPIO0C6_TRACE_D8,
- GPIO0C5_GPIO = 0,
- GPIO0C5_LCDC_D17,
- GPIO0C5_TRACE_D7,
- GPIO0C4_GPIO = 0,
- GPIO0C4_LCDC_D16,
- GPIO0C4_TRACE_D6,
- GPIO0C3_GPIO = 0,
- GPIO0C3_LCDC_D15,
- GPIO0C3_TRACE_D5,
- GPIO0C2_GPIO = 0,
- GPIO0C2_LCDC_D14,
- GPIO0C2_TRACE_D4,
- GPIO0C1_GPIO = 0,
- GPIO0C1_LCDC_D13,
- GPIO0C1_TRACE_D3,
- GPIO0C0_GPIO = 0,
- GPIO0C0_LCDC_D12,
- GPIO0C0_TRACE_D2,
- RK3368_GPIO0C7_MASK = GENMASK(15, 14),
- RK3368_GPIO0C7_GPIO = 0,
- RK3368_GPIO0C7_LCDC_D19 = (1 << 14),
- RK3368_GPIO0C7_TRACE_D9 = (2 << 14),
- RK3368_GPIO0C7_UART1_RTSN = (3 << 14),
- RK3368_GPIO0C6_MASK = GENMASK(13, 12),
- RK3368_GPIO0C6_GPIO = 0,
- RK3368_GPIO0C6_LCDC_D18 = (1 << 12),
- RK3368_GPIO0C6_TRACE_D8 = (2 << 12),
- RK3368_GPIO0C6_UART1_CTSN = (3 << 12),
- RK3368_GPIO0C5_MASK = GENMASK(11, 10),
- RK3368_GPIO0C5_GPIO = 0,
- RK3368_GPIO0C5_LCDC_D17 = (1 << 10),
- RK3368_GPIO0C5_TRACE_D7 = (2 << 10),
- RK3368_GPIO0C5_UART1_SOUT = (3 << 10),
- RK3368_GPIO0C4_MASK = GENMASK(9, 8),
- RK3368_GPIO0C4_GPIO = 0,
- RK3368_GPIO0C4_LCDC_D16 = (1 << 8),
- RK3368_GPIO0C4_TRACE_D6 = (2 << 8),
- RK3368_GPIO0C4_UART1_SIN = (3 << 8),
- RK3368_GPIO0C3_MASK = GENMASK(7, 6),
- RK3368_GPIO0C3_GPIO = 0,
- RK3368_GPIO0C3_LCDC_D15 = (1 << 6),
- RK3368_GPIO0C3_TRACE_D5 = (2 << 6),
- RK3368_GPIO0C3_MCU_JTAG_TDO = (3 << 6),
- RK3368_GPIO0C2_MASK = GENMASK(5, 4),
- RK3368_GPIO0C2_GPIO = 0,
- RK3368_GPIO0C2_LCDC_D14 = (1 << 4),
- RK3368_GPIO0C2_TRACE_D4 = (2 << 4),
- RK3368_GPIO0C2_MCU_JTAG_TDI = (3 << 4),
- RK3368_GPIO0C1_MASK = GENMASK(3, 2),
- RK3368_GPIO0C1_GPIO = 0,
- RK3368_GPIO0C1_LCDC_D13 = (1 << 2),
- RK3368_GPIO0C1_TRACE_D3 = (2 << 2),
- RK3368_GPIO0C1_MCU_JTAG_TRTSN = (3 << 2),
- RK3368_GPIO0C0_MASK = GENMASK(1, 0),
- RK3368_GPIO0C0_GPIO = 0,
- RK3368_GPIO0C0_LCDC_D12 = (1 << 0),
- RK3368_GPIO0C0_TRACE_D2 = (2 << 0),
- RK3368_GPIO0C0_MCU_JTAG_TDO = (3 << 0),
}; /*GRF_GPIO0D_IOMUX*/ enum {
- GPIO0D7_GPIO = 0,
- GPIO0D6_GPIO = 0,
- GPIO0D6_LCDC_DEN,
- GPIO0D5_GPIO = 0,
- GPIO0D4_GPIO = 0,
- GPIO0D3_GPIO = 0,
- GPIO0D3_LCDC_D23,
- GPIO0D2_GPIO = 0,
- GPIO0D2_LCDC_D22,
- GPIO0D1_GPIO = 0,
- GPIO0D1_LCDC_D21,
- GPIO0D0_GPIO = 0,
- GPIO0D0_LCDC_D20,
- RK3368_GPIO0D7_MASK = GENMASK(15, 14),
- RK3368_GPIO0D7_GPIO = 0,
- RK3368_GPIO0D7_LCDC_DCLK = (1 << 14),
- RK3368_GPIO0D7_TRACE_CTL = (2 << 14),
- RK3368_GPIO0D7_PMU_DEBUG5 = (3 << 14),
- RK3368_GPIO0D6_MASK = GENMASK(13, 12),
- RK3368_GPIO0D6_GPIO = 0,
- RK3368_GPIO0D6_LCDC_DEN = (1 << 12),
- RK3368_GPIO0D6_TRACE_CLK = (2 << 12),
- RK3368_GPIO0D6_PMU_DEBUG4 = (3 << 12),
- RK3368_GPIO0D5_MASK = GENMASK(11, 10),
- RK3368_GPIO0D5_GPIO = 0,
- GPIO0D5_LCDC_VSYNC = (1 << 10),
- RK3368_GPIO0D5_TRACE_D15 = (2 << 10),
- RK3368_GPIO0D5_PMU_DEBUG3 = (3 << 10),
- RK3368_GPIO0D4_MASK = GENMASK(9, 8),
- RK3368_GPIO0D4_GPIO = 0,
- RK3368_GPIO0D4_LCDC_HSYNC = (1 << 8),
- RK3368_GPIO0D4_TRACE_D14 = (2 << 8),
- RK3368_GPIO0D4_PMU_DEBUG2 = (3 << 8),
- RK3368_GPIO0D3_MASK = GENMASK(7, 6),
- RK3368_GPIO0D3_GPIO = 0,
- RK3368_GPIO0D3_LCDC_D23 = (1 << 6),
- RK3368_GPIO0D3_TRACE_D13 = (2 << 6),
- RK3368_GPIO0D3_UART4_SIN = (3 << 6),
- RK3368_GPIO0D2_MASK = GENMASK(5, 4),
- RK3368_GPIO0D2_GPIO = 0,
- RK3368_GPIO0D2_LCDC_D22 = (1 << 4),
- RK3368_GPIO0D2_TRACE_D12 = (2 << 4),
- RK3368_GPIO0D2_UART4_SOUT = (3 << 4),
- RK3368_GPIO0D1_MASK = GENMASK(3, 2),
- RK3368_GPIO0D1_GPIO = 0,
- RK3368_GPIO0D1_LCDC_D21 = (1 << 2),
- RK3368_GPIO0D1_TRACE_D11 = (2 << 2),
- RK3368_GPIO0D1_UART4_RTSN = (3 << 2),
- RK3368_GPIO0D0_MASK = GENMASK(1, 0),
- RK3368_GPIO0D0_GPIO = 0,
- RK3368_GPIO0D0_LCDC_D20 = (1 << 0),
- RK3368_GPIO0D0_TRACE_D10 = (2 << 0),
- RK3368_GPIO0D0_UART4_CTSN = (3 << 0),
}; /*GRF_GPIO2A_IOMUX*/ enum {
- GPIO2A7_GPIO = 0,
- GPIO2A7_JTAG_TCK,
- GPIO2A6_GPIO = 0,
- GPIO2A5_GPIO = 0,
- GPIO2A4_GPIO = 0,
- GPIO2A3_GPIO = 0,
- GPIO2A2_GPIO = 0,
- GPIO2A1_GPIO = 0,
- GPIO2A0_GPIO = 0,
}; -/*GRF_GPIO2D_IOMUX*/ +/*GRF_RK3368_GPIO2D_IOMUX*/ enum {
- GPIO2D7_GPIO = 0,
- GPIO2D7_SDIO0_D3,
- GPIO2D6_GPIO = 0,
- GPIO2D6_SDIO0_D2,
- GPIO2D5_GPIO = 0,
- GPIO2D5_SDIO0_D1,
- GPIO2D4_GPIO = 0,
- GPIO2D4_SDIO0_D0,
- GPIO2D3_GPIO = 0,
- GPIO2D2_GPIO = 0,
- GPIO2D1_GPIO = 0,
- GPIO2D0_GPIO = 0,
- RK3368_GPIO3B7_MASK = GENMASK(15, 14),
- RK3368_GPIO3B7_GPIO = 0,
- RK3368_GPIO3B7_MAC_RXD0 = (1 << 14),
- RK3368_GPIO3B6_MASK = GENMASK(13, 12),
- RK3368_GPIO3B6_GPIO = 0,
- RK3368_GPIO3B6_MAC_TXD3 = (1 << 12),
- RK3368_GPIO3B5_MASK = GENMASK(11, 10),
- RK3368_GPIO3B5_GPIO = 0,
- RK3368_GPIO3B5_MAC_TXEN = (1 << 10),
- RK3368_GPIO3B4_MASK = GENMASK(9, 8),
- RK3368_GPIO3B4_GPIO = 0,
- RK3368_GPIO3B4_MAC_COL = (1 << 8),
- RK3368_GPIO3B3_MASK = GENMASK(7, 6),
- RK3368_GPIO3B3_GPIO = 0,
- RK3368_GPIO3B3_MAC_CRS = (1 << 6),
- RK3368_GPIO3B2_MASK = GENMASK(5, 4),
- RK3368_GPIO3B2_GPIO = 0,
- RK3368_GPIO3B2_MAC_TXD2 = (1 << 4),
- RK3368_GPIO3B1_MASK = GENMASK(3, 2),
- RK3368_GPIO3B1_GPIO = 0,
- RK3368_GPIO3B1_MAC_TXD1 = (1 << 2),
- RK3368_GPIO3B0_MASK = GENMASK(1, 0),
- RK3368_GPIO3B0_GPIO = 0,
- RK3368_GPIO3B0_MAC_TXD0 = (1 << 0),
- RK3368_GPIO3B0_PWM0 = (2 << 0),
}; /*GRF_GPIO3C_IOMUX*/ enum {
- GPIO3C7_GPIO = 0,
- GPIO3C6_GPIO = 0,
- GPIO3C6_MAC_CLK,
- GPIO3C5_GPIO = 0,
- GPIO3C5_MAC_RXER,
- GPIO3C4_GPIO = 0,
- GPIO3C4_MAC_RXDV,
- GPIO3C3_GPIO = 0,
- GPIO3C3_MAC_RXDV,
- GPIO3C1_GPIO = 0,
- GPIO3C1_MAC_RXD2,
- GPIO3C0_GPIO = 0,
- GPIO3C0_MAC_RXD1,
- RK3368_GPIO3C6_MASK = GENMASK(13, 12),
- RK3368_GPIO3C6_GPIO = 0,
- RK3368_GPIO3C6_MAC_CLK = (1 << 12),
- RK3368_GPIO3C5_MASK = GENMASK(11, 10),
- RK3368_GPIO3C5_GPIO = 0,
- RK3368_GPIO3C5_MAC_RXEN = (1 << 10),
- RK3368_GPIO3C4_MASK = GENMASK(9, 8),
- RK3368_GPIO3C4_GPIO = 0,
- RK3368_GPIO3C4_MAC_RXDV = (1 << 8),
- RK3368_GPIO3C3_MASK = GENMASK(7, 6),
- RK3368_GPIO3C3_GPIO = 0,
- RK3368_GPIO3C3_MAC_MDC = (1 << 6),
- RK3368_GPIO3C2_MASK = GENMASK(5, 4),
- RK3368_GPIO3C2_GPIO = 0,
- RK3368_GPIO3C2_MAC_RXD3 = (1 << 4),
- RK3368_GPIO3C1_MASK = GENMASK(3, 2),
- RK3368_GPIO3C1_GPIO = 0,
- RK3368_GPIO3C1_MAC_RXD2 = (1 << 2),
- RK3368_GPIO3C0_MASK = GENMASK(1, 0),
- RK3368_GPIO3C0_GPIO = 0,
- RK3368_GPIO3C0_MAC_RXD1 = (1 << 0),
}; /*GRF_GPIO3D_IOMUX*/ enum {
- GPIO3D7_GPIO = 0,
- GPIO3D7_I2C2_SDA,
- GPIO3D6_GPIO = 0,
- GPIO3D6_IR_TX,
- GPIO3D6_PWM3,
- GPIO3D5_GPIO = 0,
- GPIO3D5_IR_RX,
- GPIO3D4_GPIO = 0,
- GPIO3D3_GPIO = 0,
- GPIO3D3_I2C5_SCL,
- GPIO3D2_GPIO = 0,
- GPIO3D2_I2C5_SDA,
- GPIO3D1_GPIO = 0,
- GPIO3D1_I2C4_SCL,
- GPIO3D0_GPIO = 0,
- GPIO3D0_MAC_MDIO,
- GPIO3D0_I2C4_SDA,
- NOC_RSP_ERR_STALL = BIT(9),
- MOBILE_DDR_SEL = BIT(4),
- DDR0_16BIT_EN = BIT(3),
- MSCH0_MAINDDR3_DDR3 = BIT(2),
- MSCH0_MAINPARTIALPOP = BIT(1),
- UPCTL_C_ACTIVE = BIT(0),
}; /*GRF_SOC_CON11/12/13*/ @@ -440,4 +445,34 @@ enum { MCU_CODE_BASE_BIT31_BIT28_SHIFT = 0, MCU_CODE_BASE_BIT31_BIT28_MASK = GENMASK(3, 0), };
Hi Philipp:
Hi Philipp:
It's true that many devices use GRF, we also face this condition in the kernel land.And all the drivers in kernel handle this device specific definition in the driver itself(by of_device_id->data or MACRO). And there is also no need to use the grf constructs, the common syscon api will provide you the grf base address. I think this keeps things simple, we don't need to rely on too much of the grf or cru header, maybe some day we can remove the header file, just as clean as the kernel. On the other hand, add such a prefix of rk3368 breaks the consistency with other rockchip devices.
- GPIO0C7_GPIO = 0,
- GPIO0C7_LCDC_D19,
- GPIO0C7_TRACE_D9,
- GPIO0C6_GPIO = 0,
- GPIO0C6_LCDC_D18,
- GPIO0C6_TRACE_D8,
- GPIO0C5_GPIO = 0,
- GPIO0C5_LCDC_D17,
- GPIO0C5_TRACE_D7,
- GPIO0C4_GPIO = 0,
- GPIO0C4_LCDC_D16,
- GPIO0C4_TRACE_D6,
- GPIO0C3_GPIO = 0,
- GPIO0C3_LCDC_D15,
- GPIO0C3_TRACE_D5,
- GPIO0C2_GPIO = 0,
- GPIO0C2_LCDC_D14,
- GPIO0C2_TRACE_D4,
- GPIO0C1_GPIO = 0,
- GPIO0C1_LCDC_D13,
- GPIO0C1_TRACE_D3,
- GPIO0C0_GPIO = 0,
- GPIO0C0_LCDC_D12,
- GPIO0C0_TRACE_D2,
- RK3368_GPIO0C0_MCU_JTAG_TDO = (3 << 0), }; /*GRF_GPIO0D_IOMUX*/ enum {
- GPIO0D7_GPIO = 0,
- GPIO0D6_GPIO = 0,
- GPIO0D6_LCDC_DEN,
- GPIO0D5_GPIO = 0,
- GPIO0D4_GPIO = 0,
- GPIO0D3_GPIO = 0,
- GPIO0D3_LCDC_D23,
- GPIO0D2_GPIO = 0,
- GPIO0D2_LCDC_D22,
- GPIO0D1_GPIO = 0,
- GPIO0D1_LCDC_D21,
- GPIO0D0_GPIO = 0,
- GPIO0D0_LCDC_D20,
- RK3368_GPIO0D0_UART4_CTSN = (3 << 0), }; /*GRF_GPIO2A_IOMUX*/ enum {
- GPIO2A7_GPIO = 0,
- GPIO2A7_JTAG_TCK,
- GPIO2A6_GPIO = 0,
- GPIO2A5_GPIO = 0,
- GPIO2A4_GPIO = 0,
- GPIO2A3_GPIO = 0,
- GPIO2A2_GPIO = 0,
- GPIO2A1_GPIO = 0,
- GPIO2A0_GPIO = 0,
- RK3368_GPIO2A0_FLASH_CSN0 = (1 << 0), }; -/*GRF_GPIO2D_IOMUX*/
- GPIO2D7_GPIO = 0,
- GPIO2D7_SDIO0_D3,
- GPIO2D6_GPIO = 0,
- GPIO2D6_SDIO0_D2,
- GPIO2D5_GPIO = 0,
- GPIO2D5_SDIO0_D1,
- GPIO2D4_GPIO = 0,
- GPIO2D4_SDIO0_D0,
- GPIO2D3_GPIO = 0,
- GPIO2D2_GPIO = 0,
- GPIO2D1_GPIO = 0,
- GPIO2D0_GPIO = 0,
- RK3368_GPIO3B0_PWM0 = (2 << 0), }; /*GRF_GPIO3C_IOMUX*/ enum {
- GPIO3C7_GPIO = 0,
- GPIO3C6_GPIO = 0,
- GPIO3C6_MAC_CLK,
- GPIO3C5_GPIO = 0,
- GPIO3C5_MAC_RXER,
- GPIO3C4_GPIO = 0,
- GPIO3C4_MAC_RXDV,
- GPIO3C3_GPIO = 0,
- GPIO3C3_MAC_RXDV,
- GPIO3C1_GPIO = 0,
- GPIO3C1_MAC_RXD2,
- GPIO3C0_GPIO = 0,
- GPIO3C0_MAC_RXD1,
- RK3368_GPIO3C0_MAC_RXD1 = (1 << 0), }; /*GRF_GPIO3D_IOMUX*/ enum {
- GPIO3D7_GPIO = 0,
- GPIO3D7_I2C2_SDA,
- GPIO3D6_GPIO = 0,
- GPIO3D6_IR_TX,
- GPIO3D6_PWM3,
- GPIO3D5_GPIO = 0,
- GPIO3D5_IR_RX,
- GPIO3D4_GPIO = 0,
- GPIO3D3_GPIO = 0,
- GPIO3D3_I2C5_SCL,
- GPIO3D2_GPIO = 0,
- GPIO3D2_I2C5_SDA,
- GPIO3D1_GPIO = 0,
- GPIO3D1_I2C4_SCL,
- GPIO3D0_GPIO = 0,
- GPIO3D0_MAC_MDIO,
- GPIO3D0_I2C4_SDA,
- UPCTL_C_ACTIVE = BIT(0), }; /*GRF_SOC_CON11/12/13*/
- #endif
On 24 Jul 2017, at 10:34, Andy Yan andy.yan@rock-chips.com wrote:
Hi Philipp:
Hi Philipp:
Until we find a way to consistently structure things in such a way that (a) common constructs can be shared (e.g. the masks in the IOMUX) (b) specific definitions (e.g. the pin-out for a specific device) is not visible outside of its driver I prefer the names to explicitly refer to each device. That said, the longer-term plan (especially with a larger number of devices being supported) needs to include a consistent rework of how (and where) we manage all these definitions from the grf-header files.
The problem is not the base-address of GRF, but rather the need to pull in the register structure (so we can refer to individual registers by name instead of by hard-coded offset): as we pull this in today, the definitions for the various IOMUX entries will also be pulled in, which will cause duplicate definitions.
I do agree that we need to clean this up across all the boards and drivers supported today. As of today, I can not resolve this on a RK3368-only basis, as I’d need to clean up the RK3288 at the same time (and don’t want to do this in a RK3368-focused series that already has way too much going on).
Let’s try to clean this up for the next (i.e. the one after this) merge window. Once we have bit-definitions out of the grf-header, I’ll remove the RK3368_ prefixes...
- GPIO0C7_GPIO = 0,
- GPIO0C7_LCDC_D19,
- GPIO0C7_TRACE_D9,
- GPIO0C6_GPIO = 0,
- GPIO0C6_LCDC_D18,
- GPIO0C6_TRACE_D8,
- GPIO0C5_GPIO = 0,
- GPIO0C5_LCDC_D17,
- GPIO0C5_TRACE_D7,
- GPIO0C4_GPIO = 0,
- GPIO0C4_LCDC_D16,
- GPIO0C4_TRACE_D6,
- GPIO0C3_GPIO = 0,
- GPIO0C3_LCDC_D15,
- GPIO0C3_TRACE_D5,
- GPIO0C2_GPIO = 0,
- GPIO0C2_LCDC_D14,
- GPIO0C2_TRACE_D4,
- GPIO0C1_GPIO = 0,
- GPIO0C1_LCDC_D13,
- GPIO0C1_TRACE_D3,
- GPIO0C0_GPIO = 0,
- GPIO0C0_LCDC_D12,
- GPIO0C0_TRACE_D2,
- GPIO0D7_GPIO = 0,
- GPIO0D6_GPIO = 0,
- GPIO0D6_LCDC_DEN,
- GPIO0D5_GPIO = 0,
- GPIO0D4_GPIO = 0,
- GPIO0D3_GPIO = 0,
- GPIO0D3_LCDC_D23,
- GPIO0D2_GPIO = 0,
- GPIO0D2_LCDC_D22,
- GPIO0D1_GPIO = 0,
- GPIO0D1_LCDC_D21,
- GPIO0D0_GPIO = 0,
- GPIO0D0_LCDC_D20,
- GPIO2A7_GPIO = 0,
- GPIO2A7_JTAG_TCK,
- GPIO2A6_GPIO = 0,
- GPIO2A5_GPIO = 0,
- GPIO2A4_GPIO = 0,
- GPIO2A3_GPIO = 0,
- GPIO2A2_GPIO = 0,
- GPIO2A1_GPIO = 0,
- GPIO2A0_GPIO = 0,
- GPIO2D7_GPIO = 0,
- GPIO2D7_SDIO0_D3,
- GPIO2D6_GPIO = 0,
- GPIO2D6_SDIO0_D2,
- GPIO2D5_GPIO = 0,
- GPIO2D5_SDIO0_D1,
- GPIO2D4_GPIO = 0,
- GPIO2D4_SDIO0_D0,
- GPIO2D3_GPIO = 0,
- GPIO2D2_GPIO = 0,
- GPIO2D1_GPIO = 0,
- GPIO2D0_GPIO = 0,
- GPIO3C7_GPIO = 0,
- GPIO3C6_GPIO = 0,
- GPIO3C6_MAC_CLK,
- GPIO3C5_GPIO = 0,
- GPIO3C5_MAC_RXER,
- GPIO3C4_GPIO = 0,
- GPIO3C4_MAC_RXDV,
- GPIO3C3_GPIO = 0,
- GPIO3C3_MAC_RXDV,
- GPIO3C1_GPIO = 0,
- GPIO3C1_MAC_RXD2,
- GPIO3C0_GPIO = 0,
- GPIO3C0_MAC_RXD1,
- GPIO3D7_GPIO = 0,
- GPIO3D7_I2C2_SDA,
- GPIO3D6_GPIO = 0,
- GPIO3D6_IR_TX,
- GPIO3D6_PWM3,
- GPIO3D5_GPIO = 0,
- GPIO3D5_IR_RX,
- GPIO3D4_GPIO = 0,
- GPIO3D3_GPIO = 0,
- GPIO3D3_I2C5_SCL,
- GPIO3D2_GPIO = 0,
- GPIO3D2_I2C5_SDA,
- GPIO3D1_GPIO = 0,
- GPIO3D1_I2C4_SCL,
- GPIO3D0_GPIO = 0,
- GPIO3D0_MAC_MDIO,
- GPIO3D0_I2C4_SDA,
Hi Philipp,
Hi Philipp:
Hi Philipp:
I really don't like the idea of add the prefix, which end with longer MACRO but no other improve. I think the GRF is used mostly for the IOMUX, in this case the better solution is port the kernel rockchip-pinctrl driver in uboot, which not rely on the dtsi instead of header file.
If we do this, we can remove most of the GRF header definition for IOMUX, I can ask David Wu to do this, but maybe few weeks later.
Thanks, - Kever
- GPIO0C7_GPIO = 0,
- GPIO0C7_LCDC_D19,
- GPIO0C7_TRACE_D9,
- GPIO0C6_GPIO = 0,
- GPIO0C6_LCDC_D18,
- GPIO0C6_TRACE_D8,
- GPIO0C5_GPIO = 0,
- GPIO0C5_LCDC_D17,
- GPIO0C5_TRACE_D7,
- GPIO0C4_GPIO = 0,
- GPIO0C4_LCDC_D16,
- GPIO0C4_TRACE_D6,
- GPIO0C3_GPIO = 0,
- GPIO0C3_LCDC_D15,
- GPIO0C3_TRACE_D5,
- GPIO0C2_GPIO = 0,
- GPIO0C2_LCDC_D14,
- GPIO0C2_TRACE_D4,
- GPIO0C1_GPIO = 0,
- GPIO0C1_LCDC_D13,
- GPIO0C1_TRACE_D3,
- GPIO0C0_GPIO = 0,
- GPIO0C0_LCDC_D12,
- GPIO0C0_TRACE_D2,
- GPIO0D7_GPIO = 0,
- GPIO0D6_GPIO = 0,
- GPIO0D6_LCDC_DEN,
- GPIO0D5_GPIO = 0,
- GPIO0D4_GPIO = 0,
- GPIO0D3_GPIO = 0,
- GPIO0D3_LCDC_D23,
- GPIO0D2_GPIO = 0,
- GPIO0D2_LCDC_D22,
- GPIO0D1_GPIO = 0,
- GPIO0D1_LCDC_D21,
- GPIO0D0_GPIO = 0,
- GPIO0D0_LCDC_D20,
- GPIO2A7_GPIO = 0,
- GPIO2A7_JTAG_TCK,
- GPIO2A6_GPIO = 0,
- GPIO2A5_GPIO = 0,
- GPIO2A4_GPIO = 0,
- GPIO2A3_GPIO = 0,
- GPIO2A2_GPIO = 0,
- GPIO2A1_GPIO = 0,
- GPIO2A0_GPIO = 0,
- GPIO2D7_GPIO = 0,
- GPIO2D7_SDIO0_D3,
- GPIO2D6_GPIO = 0,
- GPIO2D6_SDIO0_D2,
- GPIO2D5_GPIO = 0,
- GPIO2D5_SDIO0_D1,
- GPIO2D4_GPIO = 0,
- GPIO2D4_SDIO0_D0,
- GPIO2D3_GPIO = 0,
- GPIO2D2_GPIO = 0,
- GPIO2D1_GPIO = 0,
- GPIO2D0_GPIO = 0,
- GPIO3C7_GPIO = 0,
- GPIO3C6_GPIO = 0,
- GPIO3C6_MAC_CLK,
- GPIO3C5_GPIO = 0,
- GPIO3C5_MAC_RXER,
- GPIO3C4_GPIO = 0,
- GPIO3C4_MAC_RXDV,
- GPIO3C3_GPIO = 0,
- GPIO3C3_MAC_RXDV,
- GPIO3C1_GPIO = 0,
- GPIO3C1_MAC_RXD2,
- GPIO3C0_GPIO = 0,
- GPIO3C0_MAC_RXD1,
- GPIO3D7_GPIO = 0,
- GPIO3D7_I2C2_SDA,
- GPIO3D6_GPIO = 0,
- GPIO3D6_IR_TX,
- GPIO3D6_PWM3,
- GPIO3D5_GPIO = 0,
- GPIO3D5_IR_RX,
- GPIO3D4_GPIO = 0,
- GPIO3D3_GPIO = 0,
- GPIO3D3_I2C5_SCL,
- GPIO3D2_GPIO = 0,
- GPIO3D2_I2C5_SDA,
- GPIO3D1_GPIO = 0,
- GPIO3D1_I2C4_SCL,
- GPIO3D0_GPIO = 0,
- GPIO3D0_MAC_MDIO,
- GPIO3D0_I2C4_SDA,
- #endif
On 24 Jul 2017, at 14:45, Kever Yang kever.yang@rock-chips.com wrote:
Hi Philipp,
Hi Philipp:
Hi Philipp:
As indicated earlier: this is a temporary solution (although we have a local saying that "nothing is more permanent than a temporary solution”) and should remain limited to the RK3368 until we can clean this up across all boards.
Pulling this into the pinctrl drivers is an excellent choice. Please watch out for board_debug_uart_init(…), which also directly accesses the IOMUX constants and will need to be restructured together with pinctrl drivers.
Thanks! —Philipp.
Thanks,
- Kever
- GPIO0C7_GPIO = 0,
- GPIO0C7_LCDC_D19,
- GPIO0C7_TRACE_D9,
- GPIO0C6_GPIO = 0,
- GPIO0C6_LCDC_D18,
- GPIO0C6_TRACE_D8,
- GPIO0C5_GPIO = 0,
- GPIO0C5_LCDC_D17,
- GPIO0C5_TRACE_D7,
- GPIO0C4_GPIO = 0,
- GPIO0C4_LCDC_D16,
- GPIO0C4_TRACE_D6,
- GPIO0C3_GPIO = 0,
- GPIO0C3_LCDC_D15,
- GPIO0C3_TRACE_D5,
- GPIO0C2_GPIO = 0,
- GPIO0C2_LCDC_D14,
- GPIO0C2_TRACE_D4,
- GPIO0C1_GPIO = 0,
- GPIO0C1_LCDC_D13,
- GPIO0C1_TRACE_D3,
- GPIO0C0_GPIO = 0,
- GPIO0C0_LCDC_D12,
- GPIO0C0_TRACE_D2,
- GPIO0D7_GPIO = 0,
- GPIO0D6_GPIO = 0,
- GPIO0D6_LCDC_DEN,
- GPIO0D5_GPIO = 0,
- GPIO0D4_GPIO = 0,
- GPIO0D3_GPIO = 0,
- GPIO0D3_LCDC_D23,
- GPIO0D2_GPIO = 0,
- GPIO0D2_LCDC_D22,
- GPIO0D1_GPIO = 0,
- GPIO0D1_LCDC_D21,
- GPIO0D0_GPIO = 0,
- GPIO0D0_LCDC_D20,
- GPIO2A7_GPIO = 0,
- GPIO2A7_JTAG_TCK,
- GPIO2A6_GPIO = 0,
- GPIO2A5_GPIO = 0,
- GPIO2A4_GPIO = 0,
- GPIO2A3_GPIO = 0,
- GPIO2A2_GPIO = 0,
- GPIO2A1_GPIO = 0,
- GPIO2A0_GPIO = 0,
- GPIO2D7_GPIO = 0,
- GPIO2D7_SDIO0_D3,
- GPIO2D6_GPIO = 0,
- GPIO2D6_SDIO0_D2,
- GPIO2D5_GPIO = 0,
- GPIO2D5_SDIO0_D1,
- GPIO2D4_GPIO = 0,
- GPIO2D4_SDIO0_D0,
- GPIO2D3_GPIO = 0,
- GPIO2D2_GPIO = 0,
- GPIO2D1_GPIO = 0,
- GPIO2D0_GPIO = 0,
- GPIO3C7_GPIO = 0,
- GPIO3C6_GPIO = 0,
- GPIO3C6_MAC_CLK,
- GPIO3C5_GPIO = 0,
- GPIO3C5_MAC_RXER,
- GPIO3C4_GPIO = 0,
- GPIO3C4_MAC_RXDV,
- GPIO3C3_GPIO = 0,
- GPIO3C3_MAC_RXDV,
- GPIO3C1_GPIO = 0,
- GPIO3C1_MAC_RXD2,
- GPIO3C0_GPIO = 0,
- GPIO3C0_MAC_RXD1,
- GPIO3D7_GPIO = 0,
- GPIO3D7_I2C2_SDA,
- GPIO3D6_GPIO = 0,
- GPIO3D6_IR_TX,
- GPIO3D6_PWM3,
- GPIO3D5_GPIO = 0,
- GPIO3D5_IR_RX,
- GPIO3D4_GPIO = 0,
- GPIO3D3_GPIO = 0,
- GPIO3D3_I2C5_SCL,
- GPIO3D2_GPIO = 0,
- GPIO3D2_I2C5_SDA,
- GPIO3D1_GPIO = 0,
- GPIO3D1_I2C4_SCL,
- GPIO3D0_GPIO = 0,
- GPIO3D0_MAC_MDIO,
- GPIO3D0_I2C4_SDA,
Hi Philipp,
On 24 July 2017 at 07:10, Dr. Philipp Tomsich philipp.tomsich@theobroma-systems.com wrote:
Hi Philipp,
Hi Philipp:
Hi Philipp:
On 2017年07月19日 04:36, Philipp Tomsich wrote: > The RK3368 GRF header was still defines with a shifted-mask but with > non-shifted function selectors for the IOMUX defines. As the RK3368 > support is still fresh enough to allow a quick rename, we do this now > before having more code use this. > > As some of the downstream drivers (e.g. the Designware GMAC wrapper) > may need to include the grf-header of multiple devices, we rename the > various defines for the RK3368 by prefixing them with the device name. > This avoids future trouble during driver integration. Is that really necessary to add such a prefix for all the register definition, just to fit the GMAC dirver? Maybe the gmac driver can define the platform specific macro in its own code like dwmac-rk in the kernel. Then we can keep the register header file a little tidy.
Can we drop the prefix for now? I do worry about the precedent this sets. If this is needed anywhere then it suggests to me that we have not split up the drivers correctly. We should not be including two different GRF headers into the same file. E.g. there should be different pinctrl drivers for each SoC.
Thanks! —Philipp.
Thanks,
- Kever
> Signed-off-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com > --- >
On 24 Jul 2017, at 18:43, Simon Glass sjg@chromium.org wrote:
Hi Philipp,
Hi Philipp,
Hi Philipp:
> On 21 Jul 2017, at 05:50, Andy Yan andy.yan@rock-chips.com wrote: > > Hi Philipp: > > > On 2017年07月19日 04:36, Philipp Tomsich wrote: >> The RK3368 GRF header was still defines with a shifted-mask but with >> non-shifted function selectors for the IOMUX defines. As the RK3368 >> support is still fresh enough to allow a quick rename, we do this now >> before having more code use this. >> >> As some of the downstream drivers (e.g. the Designware GMAC wrapper) >> may need to include the grf-header of multiple devices, we rename the >> various defines for the RK3368 by prefixing them with the device name. >> This avoids future trouble during driver integration. > Is that really necessary to add such a prefix for all the register definition, just to fit the GMAC dirver? > Maybe the gmac driver can define the platform specific macro in its own code like dwmac-rk in the kernel. Then we can keep the register header file a little tidy. The problem is not the GMAC driver (although it was the motivation for doing this change), but rather how easy it is to pick up the wrong grf-file and refer to the wrong definitions/values… the conflicts are not through the GMAC-specifc defines but rather through things like the IOMUX masks or (before I moved this to the DDR-driver) things like the defines to enable DRAM in GRF.
If we drop it, we can’t get RK3368-support merged into the GMAC driver for now. Splitting the Rockchip-wrapper of the GMAC-driver doesn’t appear like a workable solution either, as this would create a new file for each chip-variant in drivers/net.
I’ll just pull the RK3368 GMAC (driver) support for now and split it off this series.
Thanks! —Philipp.
Thanks,
- Kever
>> Signed-off-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com >> --- >>
Hi Philipp,
On 24 July 2017 at 10:49, Dr. Philipp Tomsich philipp.tomsich@theobroma-systems.com wrote:
Hi Philipp,
Hi Philipp,
Hi Philipp:
On 2017年07月21日 16:34, Dr. Philipp Tomsich wrote: >> On 21 Jul 2017, at 05:50, Andy Yan andy.yan@rock-chips.com wrote: >> >> Hi Philipp: >> >> >> On 2017年07月19日 04:36, Philipp Tomsich wrote: >>> The RK3368 GRF header was still defines with a shifted-mask but with >>> non-shifted function selectors for the IOMUX defines. As the RK3368 >>> support is still fresh enough to allow a quick rename, we do this now >>> before having more code use this. >>> >>> As some of the downstream drivers (e.g. the Designware GMAC wrapper) >>> may need to include the grf-header of multiple devices, we rename the >>> various defines for the RK3368 by prefixing them with the device name. >>> This avoids future trouble during driver integration. >> Is that really necessary to add such a prefix for all the register definition, just to fit the GMAC dirver? >> Maybe the gmac driver can define the platform specific macro in its own code like dwmac-rk in the kernel. Then we can keep the register header file a little tidy. > The problem is not the GMAC driver (although it was the motivation for doing > this change), but rather how easy it is to pick up the wrong grf-file and refer > to the wrong definitions/values… the conflicts are not through the GMAC-specifc > defines but rather through things like the IOMUX masks or (before I moved > this to the DDR-driver) things like the defines to enable DRAM in GRF. > > Until we find a way to consistently structure things in such a way that > (a) common constructs can be shared (e.g. the masks in the IOMUX) > (b) specific definitions (e.g. the pin-out for a specific device) is not visible outside of its driver > I prefer the names to explicitly refer to each device. > That said, the longer-term plan (especially with a larger number of devices > being supported) needs to include a consistent rework of how (and where) > we manage all these definitions from the grf-header files. It's true that many devices use GRF, we also face this condition in the kernel land.And all the drivers in kernel handle this device specific definition in the driver itself(by of_device_id->data or MACRO). And there is also no need to use the grf constructs, the common syscon api will provide you the grf base address. I think this keeps things simple, we don't need to rely on too much of the grf or cru header, maybe some day we can remove the header file, just as clean as the kernel.
My view of GRF is that we should try to have a driver for the various operations that each thing needs (e.g. using the ioctl model). Imagine a world where we have a U-Boot that supports running on all available Rockchip SoCs and can boot on any board. In that case we probably want a GRF driver with operations that can be implemented by each SoC.
I have not sketched this out or tried it though. It needs more thought / prototyping.
I am concerned about #ifdefs in the code and including private SoC-specific RK header files in generic Rockchip drivers. To me that is the wrong approach.
Thanks! —Philipp.
Thanks,
- Kever
>>> Signed-off-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com >>> --- >>>
On 24 Jul 2017, at 19:17, Simon Glass sjg@chromium.org wrote:
Hi Philipp,
Hi Philipp,
Hi Philipp,
> On 24 Jul 2017, at 10:34, Andy Yan andy.yan@rock-chips.com wrote: > > Hi Philipp: > > > On 2017年07月21日 16:34, Dr. Philipp Tomsich wrote: >>> On 21 Jul 2017, at 05:50, Andy Yan andy.yan@rock-chips.com wrote: >>> >>> Hi Philipp: >>> >>> >>> On 2017年07月19日 04:36, Philipp Tomsich wrote: >>>> The RK3368 GRF header was still defines with a shifted-mask but with >>>> non-shifted function selectors for the IOMUX defines. As the RK3368 >>>> support is still fresh enough to allow a quick rename, we do this now >>>> before having more code use this. >>>> >>>> As some of the downstream drivers (e.g. the Designware GMAC wrapper) >>>> may need to include the grf-header of multiple devices, we rename the >>>> various defines for the RK3368 by prefixing them with the device name. >>>> This avoids future trouble during driver integration. >>> Is that really necessary to add such a prefix for all the register definition, just to fit the GMAC dirver? >>> Maybe the gmac driver can define the platform specific macro in its own code like dwmac-rk in the kernel. Then we can keep the register header file a little tidy. >> The problem is not the GMAC driver (although it was the motivation for doing >> this change), but rather how easy it is to pick up the wrong grf-file and refer >> to the wrong definitions/values… the conflicts are not through the GMAC-specifc >> defines but rather through things like the IOMUX masks or (before I moved >> this to the DDR-driver) things like the defines to enable DRAM in GRF. >> >> Until we find a way to consistently structure things in such a way that >> (a) common constructs can be shared (e.g. the masks in the IOMUX) >> (b) specific definitions (e.g. the pin-out for a specific device) is not visible outside of its driver >> I prefer the names to explicitly refer to each device. >> That said, the longer-term plan (especially with a larger number of devices >> being supported) needs to include a consistent rework of how (and where) >> we manage all these definitions from the grf-header files. > It's true that many devices use GRF, we also face this condition in the kernel land.And all the drivers in kernel handle this device specific definition in the driver itself(by of_device_id->data or MACRO). And there is also no need to use the grf constructs, the common syscon api will provide you the grf base address. I think this keeps things simple, we don't need to rely on too much of the grf or cru header, maybe some day we can remove the header file, just as clean as the kernel. The problem is not the base-address of GRF, but rather the need to pull in the register structure (so we can refer to individual registers by name instead of by hard-coded offset): as we pull this in today, the definitions for the various IOMUX entries will also be pulled in, which will cause duplicate definitions.
This echoes some of my ideas, especially the litmus-test of considering an universal U-Boot for all Rockchip devices.
I currently don’t see us winning much by moving the inclusion to new drivers (as these would then need to include the RK header files). The direction that I am taking this avoids any chip-specific #ifdef as well, as the device-model offers plenty better solutions.
In fact, I had sketched out a misc-device that would provide the required functionality for the GMAC driver last week and this would have resolved my issue at hand. Yet, this seems a bit overkill, as it would add a number of misc-devices w/o gaining any simplification (i.e. each misc-device would then include the grf-header for one of the chips).
Either way, there’s one detail that I haven’t been able to fully flesh out yet: the TPL/SPL stages use the GRF directly to set up the debug uart pin-mux. I haven’t had time to see if there’s space to pull pinctrl in to resolve this specific case—either way, it shows that there may be cases where we need to access the GRF w/o the device-model support…
My hope is that the few remaining cases of needing the GRF bits before the device-model is ready are sufficiently few to accept duplicating the bit-definitions (e.g. I’d be willing to live with this, if it’s only the debug-uart).
—Philipp.
To add GMAC (Gigabit Ethernet) support (limited to RGMII only at this point), we need support for additional pin-configuration. This commit adds the pinctrl support for GMAC in RGMII mode: * adds a PERIPH_ID_GMAC and the mapping from IRQ number to PERIPH_ID * configures the RGMII pins
Signed-off-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com ---
drivers/pinctrl/rockchip/pinctrl_rk3368.c | 36 +++++++++++++++++++++++++++++++ 1 file changed, 36 insertions(+)
diff --git a/drivers/pinctrl/rockchip/pinctrl_rk3368.c b/drivers/pinctrl/rockchip/pinctrl_rk3368.c index b77c5ab..aecd11d 100644 --- a/drivers/pinctrl/rockchip/pinctrl_rk3368.c +++ b/drivers/pinctrl/rockchip/pinctrl_rk3368.c @@ -54,6 +54,33 @@ static void pinctrl_rk3368_uart_config(struct rk3368_pinctrl_priv *priv, } }
+#if CONFIG_IS_ENABLED(GMAC_ROCKCHIP) +static void pinctrl_rk3368_gmac_config(struct rk3368_grf *grf, int gmac_id) +{ + rk_clrsetreg(&grf->gpio3b_iomux, + RK3368_GPIO3B0_MASK | RK3368_GPIO3B1_MASK | + RK3368_GPIO3B2_MASK | RK3368_GPIO3B5_MASK | + RK3368_GPIO3B6_MASK | RK3368_GPIO3B7_MASK, + RK3368_GPIO3B0_MAC_TXD0 | RK3368_GPIO3B1_MAC_TXD1 | + RK3368_GPIO3B2_MAC_TXD2 | RK3368_GPIO3B5_MAC_TXEN | + RK3368_GPIO3B6_MAC_TXD3 | RK3368_GPIO3B7_MAC_RXD0); + rk_clrsetreg(&grf->gpio3c_iomux, + RK3368_GPIO3C0_MASK | RK3368_GPIO3C1_MASK | + RK3368_GPIO3C2_MASK | RK3368_GPIO3C3_MASK | + RK3368_GPIO3C4_MASK | RK3368_GPIO3C5_MASK | + RK3368_GPIO3C6_MASK, + RK3368_GPIO3C0_MAC_RXD1 | RK3368_GPIO3C1_MAC_RXD2 | + RK3368_GPIO3C2_MAC_RXD3 | RK3368_GPIO3C3_MAC_MDC | + RK3368_GPIO3C4_MAC_RXDV | RK3368_GPIO3C5_MAC_RXEN | + RK3368_GPIO3C6_MAC_CLK); + rk_clrsetreg(&grf->gpio3d_iomux, + RK3368_GPIO3D0_MASK | RK3368_GPIO3D1_MASK | + RK3368_GPIO3D4_MASK, + RK3368_GPIO3D0_MAC_MDIO | RK3368_GPIO3D1_MAC_RXCLK | + RK3368_GPIO3D4_MAC_TXCLK); +} +#endif + static int rk3368_pinctrl_request(struct udevice *dev, int func, int flags) { struct rk3368_pinctrl_priv *priv = dev_get_priv(dev); @@ -67,6 +94,11 @@ static int rk3368_pinctrl_request(struct udevice *dev, int func, int flags) case PERIPH_ID_UART4: pinctrl_rk3368_uart_config(priv, func); break; +#if CONFIG_IS_ENABLED(GMAC_ROCKCHIP) + case PERIPH_ID_GMAC: + pinctrl_rk3368_gmac_config(priv->grf, func); + break; +#endif default: return -EINVAL; } @@ -96,6 +128,10 @@ static int rk3368_pinctrl_get_periph_id(struct udevice *dev, return PERIPH_ID_UART1; case 55: return PERIPH_ID_UART0; +#if CONFIG_IS_ENABLED(GMAC_ROCKCHIP) + case 27: + return PERIPH_ID_GMAC; +#endif }
return -ENOENT;
The RK3368 has two SD/MMC controllers that can be used from U-Boot both during SPL and for booting an OS from the full bootloader stage. While both are configured to (mostly) sensible settings from the BROM, additional configuration for the MMC controller is needed to configure it to 8bit mode.
This adds pinctrl support for the MMC controller.
drivers/pinctrl/rockchip/pinctrl_rk3368.c | 48 +++++++++++++++++++++++++++++++ 1 file changed, 48 insertions(+)
diff --git a/drivers/pinctrl/rockchip/pinctrl_rk3368.c b/drivers/pinctrl/rockchip/pinctrl_rk3368.c index aecd11d..23950d0 100644 --- a/drivers/pinctrl/rockchip/pinctrl_rk3368.c +++ b/drivers/pinctrl/rockchip/pinctrl_rk3368.c @@ -81,6 +81,46 @@ static void pinctrl_rk3368_gmac_config(struct rk3368_grf *grf, int gmac_id) } #endif
+static void pinctrl_rk3368_sdmmc_config(struct rk3368_grf *grf, int mmc_id) +{ + switch (mmc_id) { + case PERIPH_ID_EMMC: + debug("mmc id = %d setting registers!\n", mmc_id); + rk_clrsetreg(&grf->gpio1c_iomux, + RK3368_GPIO1C2_MASK | RK3368_GPIO1C3_MASK | + RK3368_GPIO1C4_MASK | RK3368_GPIO1C5_MASK | + RK3368_GPIO1C6_MASK | RK3368_GPIO1C7_MASK, + RK3368_GPIO1C2_EMMC_DATA0 | + RK3368_GPIO1C3_EMMC_DATA1 | + RK3368_GPIO1C4_EMMC_DATA2 | + RK3368_GPIO1C5_EMMC_DATA3 | + RK3368_GPIO1C6_EMMC_DATA4 | + RK3368_GPIO1C7_EMMC_DATA5); + rk_clrsetreg(&grf->gpio1d_iomux, + RK3368_GPIO1D0_MASK | RK3368_GPIO1D1_MASK | + RK3368_GPIO1D2_MASK | RK3368_GPIO1D3_MASK, + RK3368_GPIO1D0_EMMC_DATA6 | + RK3368_GPIO1D1_EMMC_DATA7 | + RK3368_GPIO1D2_EMMC_CMD | + RK3368_GPIO1D3_EMMC_PWREN); + rk_clrsetreg(&grf->gpio2a_iomux, + RK3368_GPIO2A3_MASK | RK3368_GPIO2A4_MASK, + RK3368_GPIO2A3_EMMC_RSTNOUT | + RK3368_GPIO2A4_EMMC_CLKOUT); + break; + case PERIPH_ID_SDCARD: + /* + * We assume that the BROM has already set this up + * correctly for us and that there's nothing to do + * here. + */ + break; + default: + debug("mmc id = %d iomux error!\n", mmc_id); + break; + } +} + static int rk3368_pinctrl_request(struct udevice *dev, int func, int flags) { struct rk3368_pinctrl_priv *priv = dev_get_priv(dev); @@ -94,6 +134,10 @@ static int rk3368_pinctrl_request(struct udevice *dev, int func, int flags) case PERIPH_ID_UART4: pinctrl_rk3368_uart_config(priv, func); break; + case PERIPH_ID_EMMC: + case PERIPH_ID_SDCARD: + pinctrl_rk3368_sdmmc_config(priv->grf, func); + break; #if CONFIG_IS_ENABLED(GMAC_ROCKCHIP) case PERIPH_ID_GMAC: pinctrl_rk3368_gmac_config(priv->grf, func); @@ -128,6 +172,10 @@ static int rk3368_pinctrl_get_periph_id(struct udevice *dev, return PERIPH_ID_UART1; case 55: return PERIPH_ID_UART0; + case 35: + return PERIPH_ID_EMMC; + case 32: + return PERIPH_ID_SDCARD; #if CONFIG_IS_ENABLED(GMAC_ROCKCHIP) case 27: return PERIPH_ID_GMAC;
The RK3368 TRM recommends to configure the bandwith adjustment (CON2) for PLLs to NF/2. This implements this for all reconfigurations of PLLs and removes the 'has_bwadj' flag (as the RK3368 always has the bandwidth-adjustment feature according to its manual).
drivers/clk/rockchip/clk_rk3368.c | 17 ++++++++++++----- 1 file changed, 12 insertions(+), 5 deletions(-)
diff --git a/drivers/clk/rockchip/clk_rk3368.c b/drivers/clk/rockchip/clk_rk3368.c index e1d9aeb..d8f06d5 100644 --- a/drivers/clk/rockchip/clk_rk3368.c +++ b/drivers/clk/rockchip/clk_rk3368.c @@ -1,6 +1,7 @@ /* * (C) Copyright 2017 Rockchip Electronics Co., Ltd * Author: Andy Yan andy.yan@rock-chips.com + * (C) Copyright 2017 Theobroma Systems Design und Consulting GmbH * SPDX-License-Identifier: GPL-2.0 */
@@ -74,7 +75,7 @@ static uint32_t rkclk_pll_get_rate(struct rk3368_cru *cru, }
static int rkclk_set_pll(struct rk3368_cru *cru, enum rk3368_pll_id pll_id, - const struct pll_div *div, bool has_bwadj) + const struct pll_div *div) { struct rk3368_pll *pll = &cru->pll[pll_id]; /* All PLLs have same VCO and output frequency range restrictions*/ @@ -92,6 +93,12 @@ static int rkclk_set_pll(struct rk3368_cru *cru, enum rk3368_pll_id pll_id, ((div->nr - 1) << PLL_NR_SHIFT) | ((div->no - 1) << PLL_OD_SHIFT)); writel((div->nf - 1) << PLL_NF_SHIFT, &pll->con1); + /* + * BWADJ should be set to NF / 2 to ensure the nominal bandwidth. + * Compare the RK3368 TRM, section "3.6.4 PLL Bandwidth Adjustment". + */ + clrsetbits_le32(&pll->con2, PLL_BWADJ_MASK, (div->nf >> 1) - 1); + udelay(10);
/* return from reset */ @@ -111,10 +118,10 @@ static void rkclk_init(struct rk3368_cru *cru) { u32 apllb, aplll, dpll, cpll, gpll;
- rkclk_set_pll(cru, APLLB, &apll_b_init_cfg, false); - rkclk_set_pll(cru, APLLL, &apll_l_init_cfg, false); - rkclk_set_pll(cru, GPLL, &gpll_init_cfg, false); - rkclk_set_pll(cru, CPLL, &cpll_init_cfg, false); + rkclk_set_pll(cru, APLLB, &apll_b_init_cfg); + rkclk_set_pll(cru, APLLL, &apll_l_init_cfg); + rkclk_set_pll(cru, GPLL, &gpll_init_cfg); + rkclk_set_pll(cru, CPLL, &cpll_init_cfg);
apllb = rkclk_pll_get_rate(cru, APLLB); aplll = rkclk_pll_get_rate(cru, APLLL);
With the RK3368's limited TPL size, we'll want to use OF_PLATFDATA for the SPL stage. This implements support for OF_PLATDATA in the clock driver for the RK3368.
drivers/clk/rockchip/clk_rk3368.c | 17 +++++++++++++++++ 1 file changed, 17 insertions(+)
diff --git a/drivers/clk/rockchip/clk_rk3368.c b/drivers/clk/rockchip/clk_rk3368.c index d8f06d5..809ad19 100644 --- a/drivers/clk/rockchip/clk_rk3368.c +++ b/drivers/clk/rockchip/clk_rk3368.c @@ -8,7 +8,9 @@ #include <common.h> #include <clk-uclass.h> #include <dm.h> +#include <dt-structs.h> #include <errno.h> +#include <mapmem.h> #include <syscon.h> #include <asm/arch/clock.h> #include <asm/arch/cru_rk3368.h> @@ -19,6 +21,12 @@
DECLARE_GLOBAL_DATA_PTR;
+#if CONFIG_IS_ENABLED(OF_PLATDATA) +struct rk3368_clk_plat { + struct dtd_rockchip_rk3368_cru dtd; +}; +#endif + struct pll_div { u32 nr; u32 nf; @@ -254,7 +262,11 @@ static struct clk_ops rk3368_clk_ops = { static int rk3368_clk_probe(struct udevice *dev) { struct rk3368_clk_priv *priv = dev_get_priv(dev); +#if CONFIG_IS_ENABLED(OF_PLATDATA) + struct rk3368_clk_plat *plat = dev_get_platdata(dev);
+ priv->cru = map_sysmem(plat->dtd.reg[1], plat->dtd.reg[3]); +#endif rkclk_init(priv->cru);
return 0; @@ -262,9 +274,11 @@ static int rk3368_clk_probe(struct udevice *dev)
static int rk3368_clk_ofdata_to_platdata(struct udevice *dev) { +#if !CONFIG_IS_ENABLED(OF_PLATDATA) struct rk3368_clk_priv *priv = dev_get_priv(dev);
priv->cru = (struct rk3368_cru *)devfdt_get_addr(dev); +#endif
return 0; } @@ -291,6 +305,9 @@ U_BOOT_DRIVER(rockchip_rk3368_cru) = { .id = UCLASS_CLK, .of_match = rk3368_clk_ids, .priv_auto_alloc_size = sizeof(struct rk3368_clk_priv), +#if CONFIG_IS_ENABLED(OF_PLATDATA) + .platdata_auto_alloc_size = sizeof(struct rk3368_clk_plat), +#endif .ofdata_to_platdata = rk3368_clk_ofdata_to_platdata, .ops = &rk3368_clk_ops, .bind = rk3368_clk_bind,
Hi Philipp:
TPL or SPL?
- struct dtd_rockchip_rk3368_cru dtd;
+}; +#endif
- struct pll_div { u32 nr; u32 nf;
- .platdata_auto_alloc_size = sizeof(struct rk3368_clk_plat),
On 21 Jul 2017, at 08:36, Andy Yan andy.yan@rock-chips.com wrote:
Hi Philipp:
TPL or SPL?
Thanks for catching this.
In fact it was first done for SPL and later reused for TPL (when I split the CONFIG_IS_ENABLED for TPL and SPL). There may be more of such confused uses of TPL/SPL lurking in my commit messages...
diff --git a/drivers/clk/rockchip/clk_rk3368.c b/drivers/clk/rockchip/clk_rk3368.c index d8f06d5..809ad19 100644 --- a/drivers/clk/rockchip/clk_rk3368.c +++ b/drivers/clk/rockchip/clk_rk3368.c @@ -8,7 +8,9 @@ #include <common.h> #include <clk-uclass.h> #include <dm.h> +#include <dt-structs.h> #include <errno.h> +#include <mapmem.h> #include <syscon.h> #include <asm/arch/clock.h> #include <asm/arch/cru_rk3368.h> @@ -19,6 +21,12 @@ DECLARE_GLOBAL_DATA_PTR; +#if CONFIG_IS_ENABLED(OF_PLATDATA) +struct rk3368_clk_plat {
+}; +#endif
- struct rk3368_clk_plat *plat = dev_get_platdata(dev);
- priv->cru = map_sysmem(plat->dtd.reg[1], plat->dtd.reg[3]);
+#endif rkclk_init(priv->cru); return 0; @@ -262,9 +274,11 @@ static int rk3368_clk_probe(struct udevice *dev) static int rk3368_clk_ofdata_to_platdata(struct udevice *dev) { +#if !CONFIG_IS_ENABLED(OF_PLATDATA) struct rk3368_clk_priv *priv = dev_get_priv(dev); priv->cru = (struct rk3368_cru *)devfdt_get_addr(dev); +#endif return 0; } @@ -291,6 +305,9 @@ U_BOOT_DRIVER(rockchip_rk3368_cru) = { .id = UCLASS_CLK, .of_match = rk3368_clk_ids, .priv_auto_alloc_size = sizeof(struct rk3368_clk_priv), +#if CONFIG_IS_ENABLED(OF_PLATDATA)
The RK3368 has a somewhat temperamental BootROM (which I learned the hard way) when it comes to reconfiguring the CPLL and GPLL (in fact, experiments show that changing the GPLL broke things for me, while changing the CPLL seems to be more benign). These should not be modified by the SPL stage, if we intend to return to the BootROM for chain booting the next stage.
This commit changes the clock initialisation to not change CPLL/GPLL before returning to the BootROM (i.e. in TPL). As it's safe to change these settings if we no longer intend to return to U-Boot, we'll run the full PLL setup a little later (i.e. in SPL).
drivers/clk/rockchip/clk_rk3368.c | 18 +++++++++++++++++- 1 file changed, 17 insertions(+), 1 deletion(-)
diff --git a/drivers/clk/rockchip/clk_rk3368.c b/drivers/clk/rockchip/clk_rk3368.c index 809ad19..d05be72 100644 --- a/drivers/clk/rockchip/clk_rk3368.c +++ b/drivers/clk/rockchip/clk_rk3368.c @@ -50,10 +50,14 @@ struct pll_div { (_nr * _no) == hz, #hz "Hz cannot be hit with PLL " \ "divisors on line " __stringify(__LINE__));
+#if IS_ENABLED(CONFIG_SPL_BUILD) || IS_ENABLED(CONFIG_TPL_BUILD) static const struct pll_div apll_l_init_cfg = PLL_DIVISORS(APLL_L_HZ, 12, 2); static const struct pll_div apll_b_init_cfg = PLL_DIVISORS(APLL_B_HZ, 1, 2); +#if !defined(CONFIG_TPL_BUILD) static const struct pll_div gpll_init_cfg = PLL_DIVISORS(GPLL_HZ, 1, 2); static const struct pll_div cpll_init_cfg = PLL_DIVISORS(CPLL_HZ, 1, 6); +#endif +#endif
/* Get pll rate by id */ static uint32_t rkclk_pll_get_rate(struct rk3368_cru *cru, @@ -82,6 +86,7 @@ static uint32_t rkclk_pll_get_rate(struct rk3368_cru *cru, } }
+#if IS_ENABLED(CONFIG_SPL_BUILD) || IS_ENABLED(CONFIG_TPL_BUILD) static int rkclk_set_pll(struct rk3368_cru *cru, enum rk3368_pll_id pll_id, const struct pll_div *div) { @@ -121,15 +126,23 @@ static int rkclk_set_pll(struct rk3368_cru *cru, enum rk3368_pll_id pll_id,
return 0; } +#endif
+#if IS_ENABLED(CONFIG_SPL_BUILD) || IS_ENABLED(CONFIG_TPL_BUILD) static void rkclk_init(struct rk3368_cru *cru) { u32 apllb, aplll, dpll, cpll, gpll;
rkclk_set_pll(cru, APLLB, &apll_b_init_cfg); rkclk_set_pll(cru, APLLL, &apll_l_init_cfg); +#if !defined(CONFIG_TPL_BUILD) + /* + * If we plan to return to the boot ROM, we can't increase the + * GPLL rate from the SPL stage. + */ rkclk_set_pll(cru, GPLL, &gpll_init_cfg); rkclk_set_pll(cru, CPLL, &cpll_init_cfg); +#endif
apllb = rkclk_pll_get_rate(cru, APLLB); aplll = rkclk_pll_get_rate(cru, APLLL); @@ -140,6 +153,7 @@ static void rkclk_init(struct rk3368_cru *cru) debug("%s apllb(%d) apll(%d) dpll(%d) cpll(%d) gpll(%d)\n", __func__, apllb, aplll, dpll, cpll, gpll); } +#endif
static ulong rk3368_mmc_get_clk(struct rk3368_cru *cru, uint clk_id) { @@ -261,13 +275,15 @@ static struct clk_ops rk3368_clk_ops = {
static int rk3368_clk_probe(struct udevice *dev) { - struct rk3368_clk_priv *priv = dev_get_priv(dev); + struct rk3368_clk_priv __maybe_unused *priv = dev_get_priv(dev); #if CONFIG_IS_ENABLED(OF_PLATDATA) struct rk3368_clk_plat *plat = dev_get_platdata(dev);
priv->cru = map_sysmem(plat->dtd.reg[1], plat->dtd.reg[3]); #endif +#if IS_ENABLED(CONFIG_SPL_BUILD) || IS_ENABLED(CONFIG_TPL_BUILD) rkclk_init(priv->cru); +#endif
return 0; }
To implement a TPL stage (incl. its DRAM controller setup) for the RK3368, we'll want to configure the DPLL (DRAM PLL).
This commit implements setting the DPLL (CLK_DDR) and provides PLL configuration details for the common DRAM operating speeds found on RK3368 boards.
drivers/clk/rockchip/clk_rk3368.c | 35 +++++++++++++++++++++++++++++++++++ 1 file changed, 35 insertions(+)
diff --git a/drivers/clk/rockchip/clk_rk3368.c b/drivers/clk/rockchip/clk_rk3368.c index d05be72..33d2946 100644 --- a/drivers/clk/rockchip/clk_rk3368.c +++ b/drivers/clk/rockchip/clk_rk3368.c @@ -250,6 +250,37 @@ static ulong rk3368_clk_get_rate(struct clk *clk) return rate; }
+static ulong rk3368_ddr_set_clk(struct rk3368_cru *cru, ulong set_rate) +{ + const struct pll_div *dpll_cfg = NULL; + const ulong MHz = 1000000; + + /* Fout = ((Fin /NR) * NF )/ NO */ + static const struct pll_div dpll_1200 = + PLL_DIVISORS(1200 * MHz, 1, 1); + static const struct pll_div dpll_1332 = + PLL_DIVISORS(1332 * MHz, 2, 1); + static const struct pll_div dpll_1600 = + PLL_DIVISORS(1600 * MHz, 3, 2); + + switch (set_rate) { + case 1200*MHz: + dpll_cfg = &dpll_1200; + break; + case 1332*MHz: + dpll_cfg = &dpll_1332; + break; + case 1600*MHz: + dpll_cfg = &dpll_1600; + break; + default: + error("Unsupported SDRAM frequency!,%ld\n", set_rate); + } + rkclk_set_pll(cru, DPLL, dpll_cfg); + + return set_rate; +} + static ulong rk3368_clk_set_rate(struct clk *clk, ulong rate) { struct rk3368_clk_priv *priv = dev_get_priv(clk->dev); @@ -257,6 +288,10 @@ static ulong rk3368_clk_set_rate(struct clk *clk, ulong rate)
debug("%s id:%ld rate:%ld\n", __func__, clk->id, rate); switch (clk->id) { + case CLK_DDR: + ret = rk3368_ddr_set_clk(priv->cru, rate); + break; + case SCLK_SDMMC: case SCLK_EMMC: ret = rk3368_mmc_set_clk(priv->cru, clk->id, rate);
On he RK3368, we need to temporarily disable security on the DMA engines during TPL and SPL to allow the MMC host to DMA into DRAM. To do so, we need to reset the two DMA engines, which in turn requires the DMA1_SRST_REQ and DMA2_SRST_REQ constants to refer to the appropriate bits in the CRU.
As the ATF correctly initialises security (and only leaves EL3 after doing so), this can not pose a security issue.
arch/arm/include/asm/arch-rockchip/cru_rk3368.h | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/arm/include/asm/arch-rockchip/cru_rk3368.h b/arch/arm/include/asm/arch-rockchip/cru_rk3368.h index 24a9cc0..bf09e2f 100644 --- a/arch/arm/include/asm/arch-rockchip/cru_rk3368.h +++ b/arch/arm/include/asm/arch-rockchip/cru_rk3368.h @@ -102,6 +102,10 @@ enum { /* SOFTRST1_CON */ MCU_PO_SRST_MASK = BIT(13), MCU_SYS_SRST_MASK = BIT(12), + DMA1_SRST_REQ = BIT(2), + + /* SOFTRST4_CON */ + DMA2_SRST_REQ = BIT(0),
/* GLB_RST_CON */ PMU_GLB_SRST_CTRL_SHIFT = 2,
The original clock support for MMC/SD cards on the RK3368 suffered from a tendency to select a divider less-or-equal to the the one giving the requested clock-rate: this can lead to higher-than-expected (or rather: higher than supported) clock rates for the MMC/SD communiction.
This change rewrites the MMC/SD clock generation to: * always generate a clock less-than-or-equal to the requested clock * support reparenting among the CPLL, GPLL and OSC24M parents to generate the highest clock that does not exceed the requested rate
In addition to this, the Linux DTS uses HCLK_MMC/HCLK_SDMMC instead of SCLK_MMC/SCLK_SDMMC: to match this (and to ensure that clock setup always works), we adjust the driver appropriately.
This includes the changes from: - rockchip: clk: rk3368: convert MMC_PLL_SEL_* definitions to shifted-value form
arch/arm/include/asm/arch-rockchip/cru_rk3368.h | 8 +- drivers/clk/rockchip/clk_rk3368.c | 119 ++++++++++++++++++------ 2 files changed, 95 insertions(+), 32 deletions(-)
diff --git a/arch/arm/include/asm/arch-rockchip/cru_rk3368.h b/arch/arm/include/asm/arch-rockchip/cru_rk3368.h index bf09e2f..21f11e0 100644 --- a/arch/arm/include/asm/arch-rockchip/cru_rk3368.h +++ b/arch/arm/include/asm/arch-rockchip/cru_rk3368.h @@ -92,10 +92,10 @@ enum { /* CLKSEL51_CON */ MMC_PLL_SEL_SHIFT = 8, MMC_PLL_SEL_MASK = GENMASK(9, 8), - MMC_PLL_SEL_CPLL = 0, - MMC_PLL_SEL_GPLL, - MMC_PLL_SEL_USBPHY_480M, - MMC_PLL_SEL_24M, + MMC_PLL_SEL_CPLL = (0 << MMC_PLL_SEL_SHIFT), + MMC_PLL_SEL_GPLL = (1 << MMC_PLL_SEL_SHIFT), + MMC_PLL_SEL_USBPHY_480M = (2 << MMC_PLL_SEL_SHIFT), + MMC_PLL_SEL_24M = (3 << MMC_PLL_SEL_SHIFT), MMC_CLK_DIV_SHIFT = 0, MMC_CLK_DIV_MASK = GENMASK(6, 0),
diff --git a/drivers/clk/rockchip/clk_rk3368.c b/drivers/clk/rockchip/clk_rk3368.c index 33d2946..1327116 100644 --- a/drivers/clk/rockchip/clk_rk3368.c +++ b/drivers/clk/rockchip/clk_rk3368.c @@ -59,6 +59,8 @@ static const struct pll_div cpll_init_cfg = PLL_DIVISORS(CPLL_HZ, 1, 6); #endif #endif
+static ulong rk3368_clk_get_rate(struct clk *clk); + /* Get pll rate by id */ static uint32_t rkclk_pll_get_rate(struct rk3368_cru *cru, enum rk3368_pll_id pll_id) @@ -155,16 +157,17 @@ static void rkclk_init(struct rk3368_cru *cru) } #endif
+#if !IS_ENABLED(CONFIG_SPL_BUILD) || CONFIG_IS_ENABLED(MMC_SUPPORT) static ulong rk3368_mmc_get_clk(struct rk3368_cru *cru, uint clk_id) { u32 div, con, con_id, rate; u32 pll_rate;
switch (clk_id) { - case SCLK_SDMMC: + case HCLK_SDMMC: con_id = 50; break; - case SCLK_EMMC: + case HCLK_EMMC: con_id = 51; break; case SCLK_SDIO0: @@ -175,7 +178,7 @@ static ulong rk3368_mmc_get_clk(struct rk3368_cru *cru, uint clk_id) }
con = readl(&cru->clksel_con[con_id]); - switch ((con & MMC_PLL_SEL_MASK) >> MMC_PLL_SEL_SHIFT) { + switch (con & MMC_PLL_SEL_MASK) { case MMC_PLL_SEL_GPLL: pll_rate = rkclk_pll_get_rate(cru, GPLL); break; @@ -183,6 +186,8 @@ static ulong rk3368_mmc_get_clk(struct rk3368_cru *cru, uint clk_id) pll_rate = OSC_HZ; break; case MMC_PLL_SEL_CPLL: + pll_rate = rkclk_pll_get_rate(cru, CPLL); + break; case MMC_PLL_SEL_USBPHY_480M: default: return -EINVAL; @@ -190,23 +195,76 @@ static ulong rk3368_mmc_get_clk(struct rk3368_cru *cru, uint clk_id) div = (con & MMC_CLK_DIV_MASK) >> MMC_CLK_DIV_SHIFT; rate = DIV_TO_RATE(pll_rate, div);
+ debug("%s: raw rate %d (post-divide by 2)\n", __func__, rate); return rate >> 1; }
-static ulong rk3368_mmc_set_clk(struct rk3368_cru *cru, - ulong clk_id, ulong rate) +static ulong rk3368_mmc_find_best_rate_and_parent(struct clk *clk, + ulong rate, + u32 *best_mux, + u32 *best_div) +{ + int i; + ulong best_rate = 0; + const ulong MHz = 1000000; + const struct { + u32 mux; + ulong rate; + } parents[] = { + { .mux = MMC_PLL_SEL_CPLL, .rate = CPLL_HZ }, + { .mux = MMC_PLL_SEL_GPLL, .rate = GPLL_HZ }, + { .mux = MMC_PLL_SEL_24M, .rate = 24 * MHz } + }; + + debug("%s: target rate %ld\n", __func__, rate); + for (i = 0; i < ARRAY_SIZE(parents); ++i) { + /* + * Find the largest rate no larger than the target-rate for + * the current parent. + */ + ulong parent_rate = parents[i].rate; + u32 div = DIV_ROUND_UP(parent_rate, rate); + u32 adj_div = div; + ulong new_rate = parent_rate / adj_div; + + debug("%s: rate %ld, parent-mux %d, parent-rate %ld, div %d\n", + __func__, rate, parents[i].mux, parents[i].rate, div); + + /* Skip, if not representable */ + if ((div - 1) > MMC_CLK_DIV_MASK) + continue; + + /* Skip, if we already have a better (or equal) solution */ + if (new_rate <= best_rate) + continue; + + /* This is our new best rate. */ + best_rate = new_rate; + *best_mux = parents[i].mux; + *best_div = div - 1; + } + + debug("%s: best_mux = %x, best_div = %d, best_rate = %ld\n", + __func__, *best_mux, *best_div, best_rate); + + return best_rate; +} + +static ulong rk3368_mmc_set_clk(struct clk *clk, ulong rate) { - u32 div; - u32 con_id; - u32 gpll_rate = rkclk_pll_get_rate(cru, GPLL); + struct rk3368_clk_priv *priv = dev_get_priv(clk->dev); + struct rk3368_cru *cru = priv->cru; + ulong clk_id = clk->id; + u32 con_id, mux = 0, div = 0;
- div = RATE_TO_DIV(gpll_rate, rate << 1); + /* Find the best parent and rate */ + rk3368_mmc_find_best_rate_and_parent(clk, rate << 1, &mux, &div);
switch (clk_id) { - case SCLK_SDMMC: + case HCLK_SDMMC: con_id = 50; break; - case SCLK_EMMC: + case HCLK_EMMC: con_id = 51; break; case SCLK_SDIO0: @@ -216,33 +274,33 @@ static ulong rk3368_mmc_set_clk(struct rk3368_cru *cru, return -EINVAL; }
- if (div > 0x3f) { - div = RATE_TO_DIV(OSC_HZ, rate); - rk_clrsetreg(&cru->clksel_con[con_id], - MMC_PLL_SEL_MASK | MMC_CLK_DIV_MASK, - (MMC_PLL_SEL_24M << MMC_PLL_SEL_SHIFT) | - (div << MMC_CLK_DIV_SHIFT)); - } else { - rk_clrsetreg(&cru->clksel_con[con_id], - MMC_PLL_SEL_MASK | MMC_CLK_DIV_MASK, - (MMC_PLL_SEL_GPLL << MMC_PLL_SEL_SHIFT) | - div << MMC_CLK_DIV_SHIFT); - } + rk_clrsetreg(&cru->clksel_con[con_id], + MMC_PLL_SEL_MASK | MMC_CLK_DIV_MASK, + mux | div);
return rk3368_mmc_get_clk(cru, clk_id); } +#endif
static ulong rk3368_clk_get_rate(struct clk *clk) { struct rk3368_clk_priv *priv = dev_get_priv(clk->dev); ulong rate = 0;
- debug("%s id:%ld\n", __func__, clk->id); + debug("%s: id %ld\n", __func__, clk->id); switch (clk->id) { + case PLL_CPLL: + rate = rkclk_pll_get_rate(priv->cru, CPLL); + break; + case PLL_GPLL: + rate = rkclk_pll_get_rate(priv->cru, GPLL); + break; +#if !IS_ENABLED(CONFIG_SPL_BUILD) || CONFIG_IS_ENABLED(MMC_SUPPORT) case HCLK_SDMMC: case HCLK_EMMC: rate = rk3368_mmc_get_clk(priv->cru, clk->id); break; +#endif default: return -ENOENT; } @@ -291,10 +349,15 @@ static ulong rk3368_clk_set_rate(struct clk *clk, ulong rate) case CLK_DDR: ret = rk3368_ddr_set_clk(priv->cru, rate); break; - - case SCLK_SDMMC: - case SCLK_EMMC: - ret = rk3368_mmc_set_clk(priv->cru, clk->id, rate); +#if !IS_ENABLED(CONFIG_SPL_BUILD) || CONFIG_IS_ENABLED(MMC_SUPPORT) + case HCLK_SDMMC: + case HCLK_EMMC: + ret = rk3368_mmc_set_clk(clk, rate); + break; +#endif + case SCLK_MAC: + /* nothing to do, as this is an external clock */ + ret = rate; break; default: return -ENOENT;
As part of the DRAM initialisation process (running as part of the TPL stage) on the RK3368, we need to set up the DRAM PLL.
This implements support for configuring the PLL to for 1200, 1332 or 1600 MHz (i.e. for DDR3-1200, DDR3-1333, DDR3-1600 operating modes).
drivers/clk/rockchip/clk_rk3368.c | 13 +++++++------ 1 file changed, 7 insertions(+), 6 deletions(-)
diff --git a/drivers/clk/rockchip/clk_rk3368.c b/drivers/clk/rockchip/clk_rk3368.c index 1327116..1bed4e2 100644 --- a/drivers/clk/rockchip/clk_rk3368.c +++ b/drivers/clk/rockchip/clk_rk3368.c @@ -308,18 +308,16 @@ static ulong rk3368_clk_get_rate(struct clk *clk) return rate; }
+#if IS_ENABLED(CONFIG_TPL_BUILD) static ulong rk3368_ddr_set_clk(struct rk3368_cru *cru, ulong set_rate) { const struct pll_div *dpll_cfg = NULL; const ulong MHz = 1000000;
/* Fout = ((Fin /NR) * NF )/ NO */ - static const struct pll_div dpll_1200 = - PLL_DIVISORS(1200 * MHz, 1, 1); - static const struct pll_div dpll_1332 = - PLL_DIVISORS(1332 * MHz, 2, 1); - static const struct pll_div dpll_1600 = - PLL_DIVISORS(1600 * MHz, 3, 2); + static const struct pll_div dpll_1200 = PLL_DIVISORS(1200 * MHz, 1, 1); + static const struct pll_div dpll_1332 = PLL_DIVISORS(1332 * MHz, 2, 1); + static const struct pll_div dpll_1600 = PLL_DIVISORS(1600 * MHz, 3, 2);
switch (set_rate) { case 1200*MHz: @@ -338,6 +336,7 @@ static ulong rk3368_ddr_set_clk(struct rk3368_cru *cru, ulong set_rate)
return set_rate; } +#endif
static ulong rk3368_clk_set_rate(struct clk *clk, ulong rate) { @@ -346,9 +345,11 @@ static ulong rk3368_clk_set_rate(struct clk *clk, ulong rate)
debug("%s id:%ld rate:%ld\n", __func__, clk->id, rate); switch (clk->id) { +#if IS_ENABLED(CONFIG_TPL_BUILD) case CLK_DDR: ret = rk3368_ddr_set_clk(priv->cru, rate); break; +#endif #if !IS_ENABLED(CONFIG_SPL_BUILD) || CONFIG_IS_ENABLED(MMC_SUPPORT) case HCLK_SDMMC: case HCLK_EMMC:
To enable the GMAC on the RK3368, we need to set up the clocking appropriately to generate a tx_clk for the MAC.
This adds an implementation that implements the use of the <&ext_gmac> clock (i.e. an external 125MHz clock for RGMII provided by the PHY). This is the clock setup used by the boards currently supported by U-Boot (i.e. Geekbox, Sheep and RK3368-uQ7).
This includes the change from commit - rockchip: clk: rk3368: define GMAC_MUX_SEL_EXTCLK
arch/arm/include/asm/arch-rockchip/cru_rk3368.h | 3 +++ drivers/clk/rockchip/clk_rk3368.c | 19 +++++++++++++++++-- 2 files changed, 20 insertions(+), 2 deletions(-)
diff --git a/arch/arm/include/asm/arch-rockchip/cru_rk3368.h b/arch/arm/include/asm/arch-rockchip/cru_rk3368.h index 21f11e0..2b1197f 100644 --- a/arch/arm/include/asm/arch-rockchip/cru_rk3368.h +++ b/arch/arm/include/asm/arch-rockchip/cru_rk3368.h @@ -89,6 +89,9 @@ enum { MCU_CLK_DIV_SHIFT = 0, MCU_CLK_DIV_MASK = GENMASK(4, 0),
+ /* CLKSEL43_CON */ + GMAC_MUX_SEL_EXTCLK = BIT(8), + /* CLKSEL51_CON */ MMC_PLL_SEL_SHIFT = 8, MMC_PLL_SEL_MASK = GENMASK(9, 8), diff --git a/drivers/clk/rockchip/clk_rk3368.c b/drivers/clk/rockchip/clk_rk3368.c index 1bed4e2..2b6c8da 100644 --- a/drivers/clk/rockchip/clk_rk3368.c +++ b/drivers/clk/rockchip/clk_rk3368.c @@ -338,6 +338,19 @@ static ulong rk3368_ddr_set_clk(struct rk3368_cru *cru, ulong set_rate) } #endif
+#if CONFIG_IS_ENABLED(GMAC_ROCKCHIP) +static ulong rk3368_gmac_set_clk(struct rk3368_cru *cru, + ulong clk_id, ulong set_rate) +{ + /* + * This models the 'assigned-clock-parents = <&ext_gmac>' from + * the DTS and switches to the 'ext_gmac' clock parent. + */ + rk_setreg(&cru->clksel_con[43], GMAC_MUX_SEL_EXTCLK); + return set_rate; +} +#endif + static ulong rk3368_clk_set_rate(struct clk *clk, ulong rate) { struct rk3368_clk_priv *priv = dev_get_priv(clk->dev); @@ -356,10 +369,12 @@ static ulong rk3368_clk_set_rate(struct clk *clk, ulong rate) ret = rk3368_mmc_set_clk(clk, rate); break; #endif +#if CONFIG_IS_ENABLED(GMAC_ROCKCHIP) case SCLK_MAC: - /* nothing to do, as this is an external clock */ - ret = rate; + /* select the external clock */ + ret = rk3368_gmac_set_clk(priv->cru, clk->id, rate); break; +#endif default: return -ENOENT; }
With the clock support in rk3368_clk_set_rate() conditionalized on various feature definitions, 'priv' can remain unused (e.g. in the SPL build when only MMC is enabled).
drivers/clk/rockchip/clk_rk3368.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/clk/rockchip/clk_rk3368.c b/drivers/clk/rockchip/clk_rk3368.c index 2b6c8da..d3f6c29 100644 --- a/drivers/clk/rockchip/clk_rk3368.c +++ b/drivers/clk/rockchip/clk_rk3368.c @@ -353,7 +353,7 @@ static ulong rk3368_gmac_set_clk(struct rk3368_cru *cru,
static ulong rk3368_clk_set_rate(struct clk *clk, ulong rate) { - struct rk3368_clk_priv *priv = dev_get_priv(clk->dev); + __maybe_unused struct rk3368_clk_priv *priv = dev_get_priv(clk->dev); ulong ret = 0;
The GMAC in the RK3368 once again is identical to the incarnation in the RK3288 and the RK3399, except for where some of the configuration and control registers are located in the GRF.
This adds the RK3368-specific logic necessary to reuse this driver.
drivers/net/gmac_rockchip.c | 54 +++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 54 insertions(+)
diff --git a/drivers/net/gmac_rockchip.c b/drivers/net/gmac_rockchip.c index c9f9e83..2e4a812 100644 --- a/drivers/net/gmac_rockchip.c +++ b/drivers/net/gmac_rockchip.c @@ -16,6 +16,7 @@ #include <asm/arch/clock.h> #include <asm/arch/hardware.h> #include <asm/arch/grf_rk3288.h> +#include <asm/arch/grf_rk3368.h> #include <asm/arch/grf_rk3399.h> #include <dm/pinctrl.h> #include <dt-bindings/clock/rk3288-cru.h> @@ -83,6 +84,32 @@ static int rk3288_gmac_fix_mac_speed(struct dw_eth_dev *priv) return 0; }
+static int rk3368_gmac_fix_mac_speed(struct dw_eth_dev *priv) +{ + struct rk3368_grf *grf; + int clk; + + switch (priv->phydev->speed) { + case 10: + clk = RK3368_GMAC_CLK_SEL_2_5M; + break; + case 100: + clk = RK3368_GMAC_CLK_SEL_25M; + break; + case 1000: + clk = RK3368_GMAC_CLK_SEL_125M; + break; + default: + debug("Unknown phy speed: %d\n", priv->phydev->speed); + return -EINVAL; + } + + grf = syscon_get_first_range(ROCKCHIP_SYSCON_GRF); + rk_clrsetreg(&grf->soc_con15, RK3368_GMAC_CLK_SEL_MASK, clk); + + return 0; +} + static int rk3399_gmac_fix_mac_speed(struct dw_eth_dev *priv) { struct rk3399_grf_regs *grf; @@ -129,6 +156,26 @@ static void rk3288_gmac_set_to_rgmii(struct gmac_rockchip_platdata *pdata) pdata->tx_delay << RK3288_CLK_TX_DL_CFG_GMAC_SHIFT); }
+static void rk3368_gmac_set_to_rgmii(struct gmac_rockchip_platdata *pdata) +{ + struct rk3368_grf *grf; + + grf = syscon_get_first_range(ROCKCHIP_SYSCON_GRF); + rk_clrsetreg(&grf->soc_con15, + RK3368_RMII_MODE_MASK | RK3368_GMAC_PHY_INTF_SEL_MASK, + RK3368_GMAC_PHY_INTF_SEL_RGMII); + + rk_clrsetreg(&grf->soc_con16, + RK3368_RXCLK_DLY_ENA_GMAC_MASK | + RK3368_TXCLK_DLY_ENA_GMAC_MASK | + RK3368_CLK_RX_DL_CFG_GMAC_MASK | + RK3368_CLK_TX_DL_CFG_GMAC_MASK, + RK3368_RXCLK_DLY_ENA_GMAC_ENABLE | + RK3368_TXCLK_DLY_ENA_GMAC_ENABLE | + pdata->rx_delay << RK3368_CLK_RX_DL_CFG_GMAC_SHIFT | + pdata->tx_delay << RK3368_CLK_TX_DL_CFG_GMAC_SHIFT); +} + static void rk3399_gmac_set_to_rgmii(struct gmac_rockchip_platdata *pdata) { struct rk3399_grf_regs *grf; @@ -208,6 +255,11 @@ const struct rk_gmac_ops rk3288_gmac_ops = { .set_to_rgmii = rk3288_gmac_set_to_rgmii, };
+const struct rk_gmac_ops rk3368_gmac_ops = { + .fix_mac_speed = rk3368_gmac_fix_mac_speed, + .set_to_rgmii = rk3368_gmac_set_to_rgmii, +}; + const struct rk_gmac_ops rk3399_gmac_ops = { .fix_mac_speed = rk3399_gmac_fix_mac_speed, .set_to_rgmii = rk3399_gmac_set_to_rgmii, @@ -216,6 +268,8 @@ const struct rk_gmac_ops rk3399_gmac_ops = { static const struct udevice_id rockchip_gmac_ids[] = { { .compatible = "rockchip,rk3288-gmac", .data = (ulong)&rk3288_gmac_ops }, + { .compatible = "rockchip,rk3368-gmac", + .data = (ulong)&rk3368_gmac_ops }, { .compatible = "rockchip,rk3399-gmac", .data = (ulong)&rk3399_gmac_ops }, { }
Handling TPL and SPL in the Makefile for mach-rockchip was based on nested if checks and/or if-else-if paths. This can be simplified and made more readable by using $(SPL_TPL_) and by introducing intermediate variables for the aggregation of SPL and TPL features.
arch/arm/mach-rockchip/Makefile | 46 +++++++++++++++++++++++++---------------- 1 file changed, 28 insertions(+), 18 deletions(-)
diff --git a/arch/arm/mach-rockchip/Makefile b/arch/arm/mach-rockchip/Makefile index 8a3cb9f..633c91e 100644 --- a/arch/arm/mach-rockchip/Makefile +++ b/arch/arm/mach-rockchip/Makefile @@ -4,37 +4,47 @@ # SPDX-License-Identifier: GPL-2.0+ #
-obj-$(CONFIG_ROCKCHIP_BROM_HELPER) += bootrom.o -obj-$(CONFIG_$(SPL_TPL_)RAM) += sdram_common.o +# We don't want the bootrom-helper present in a full U-Boot build, as +# this may have entered from ATF with the stack-pointer pointing to +# inaccessible/protected memory (and the bootrom-helper assumes that +# the stack-pointer is valid before switching to the U-Boot stack). +obj-spl-$(CONFIG_ROCKCHIP_BROM_HELPER) += bootrom.o save_boot_param.o +obj-tpl-$(CONFIG_ROCKCHIP_BROM_HELPER) += bootrom.o save_boot_param.o + +obj-tpl-$(CONFIG_ROCKCHIP_RK3188) += rk3188-board-tpl.o + +obj-spl-$(CONFIG_ROCKCHIP_RK3036) += rk3036-board-spl.o +obj-spl-$(CONFIG_ROCKCHIP_RK3188) += rk3188-board-spl.o +obj-spl-$(CONFIG_ROCKCHIP_RK322X) += rk322x-board-spl.o +obj-spl-$(CONFIG_ROCKCHIP_RK3288) += rk3288-board-spl.o +obj-spl-$(CONFIG_ROCKCHIP_RK3368) += rk3368-board-spl.o +obj-spl-$(CONFIG_ROCKCHIP_RK3399) += rk3399-board-spl.o
-ifdef CONFIG_TPL_BUILD -obj-$(CONFIG_ROCKCHIP_RK3188) += rk3188-board-tpl.o -obj-$(CONFIG_ROCKCHIP_BROM_HELPER) += save_boot_param.o -else ifdef CONFIG_SPL_BUILD -obj-$(CONFIG_ROCKCHIP_RK3036) += rk3036-board-spl.o -obj-$(CONFIG_ROCKCHIP_RK3188) += rk3188-board-spl.o -obj-$(CONFIG_ROCKCHIP_RK322X) += rk322x-board-spl.o -obj-$(CONFIG_ROCKCHIP_RK3288) += rk3288-board-spl.o -obj-$(CONFIG_ROCKCHIP_RK3399) += rk3399-board-spl.o -obj-$(CONFIG_ROCKCHIP_BROM_HELPER) += save_boot_param.o -else +ifeq ($(CONFIG_SPL_BUILD)$(CONFIG_TPL_BUILD),) obj-$(CONFIG_ROCKCHIP_RK3188) += rk3188-board.o obj-$(CONFIG_ROCKCHIP_RK322X) += rk322x-board.o obj-$(CONFIG_ROCKCHIP_RK3288) += rk3288-board.o obj-$(CONFIG_ROCKCHIP_RK3036) += rk3036-board.o endif + +obj-$(CONFIG_$(SPL_TPL_)RAM) += sdram_common.o + ifndef CONFIG_ARM64 obj-y += rk_timer.o endif -obj-$(CONFIG_ROCKCHIP_RK3036) += rk3036/ - -ifndef CONFIG_TPL_BUILD -obj-$(CONFIG_ROCKCHIP_RK3188) += rk3188/ -endif
+obj-$(CONFIG_ROCKCHIP_RK3036) += rk3036/ +obj-tpl-$(CONFIG_ROCKCHIP_RK3188) += rk3188/ obj-$(CONFIG_ROCKCHIP_RK322X) += rk322x/ obj-$(CONFIG_ROCKCHIP_RK3288) += rk3288/ obj-$(CONFIG_ROCKCHIP_RK3328) += rk3328/ obj-$(CONFIG_ROCKCHIP_RK3368) += rk3368/ obj-$(CONFIG_ROCKCHIP_RK3399) += rk3399/ obj-$(CONFIG_ROCKCHIP_RV1108) += rv1108/ + +# Clear out SPL objects, in case this is a TPL build +obj-spl-$(CONFIG_TPL_BUILD) = + +# Now add SPL/TPL objects back into the main build +obj-$(CONFIG_SPL_BUILD) += $(obj-spl-y) +obj-$(CONFIG_TPL_BUILD) += $(obj-tpl-y)
This adds a DRAM controller driver for the RK3368 and places it in drivers/ddr/rockchip (where the other DM-enabled DRAM controller drivers for rockchip devices should also be moved eventually).
At this stage, only the following feature-set is supported: - DDR3 - 32-bit configuration (i.e. fully populated) - dual-rank (i.e. no auto-detection of ranks) - DDR3-1600K speed-bin
This driver expects to run from a TPL stage that will later return to the RK3368 BROM. It communicates with later stages through the os_reg2 in the pmugrf (i.e. using the same mechanism as Rockchip's DDR init code).
Unlike other DMC drivers for RK32xx and RK33xx parts, the required timings are calculated within the driver based on a target frequency and a DDR3 speed-bin (only the DDR3-1600K speed-bin is support at this time).
The RK3368 also has the DDRC0_CON0 (DDR ch. 0, control-register 0) register for controlling the operation of its (single-channel) DRAM controller in the GRF block. This provides for selecting DDR3, mobile DDR modes, and control low-power operation. As part of this change, DDRC0_CON0 is also added to the GRF structure definition (at offset 0x600).
arch/arm/include/asm/arch-rockchip/ddr_rk3368.h | 187 ++++ arch/arm/include/asm/arch-rockchip/grf_rk3368.h | 13 +- arch/arm/mach-rockchip/rk3368/Makefile | 1 - arch/arm/mach-rockchip/rk3368/sdram_rk3368.c | 60 -- .../clock/rockchip,rk3368-dmc.txt | 67 ++ drivers/ram/Makefile | 2 + drivers/ram/rockchip/Makefile | 7 + drivers/ram/rockchip/dmc-rk3368.c | 990 +++++++++++++++++++++ include/dt-bindings/memory/rk3368-dmc.h | 30 + 9 files changed, 1286 insertions(+), 71 deletions(-) create mode 100644 arch/arm/include/asm/arch-rockchip/ddr_rk3368.h delete mode 100644 arch/arm/mach-rockchip/rk3368/sdram_rk3368.c create mode 100644 doc/device-tree-bindings/clock/rockchip,rk3368-dmc.txt create mode 100644 drivers/ram/rockchip/Makefile create mode 100644 drivers/ram/rockchip/dmc-rk3368.c create mode 100644 include/dt-bindings/memory/rk3368-dmc.h
diff --git a/arch/arm/include/asm/arch-rockchip/ddr_rk3368.h b/arch/arm/include/asm/arch-rockchip/ddr_rk3368.h new file mode 100644 index 0000000..4e2b233 --- /dev/null +++ b/arch/arm/include/asm/arch-rockchip/ddr_rk3368.h @@ -0,0 +1,187 @@ +/* + * (C) Copyright 2017 Theobroma Systems Design und Consulting GmbH + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#ifndef __ASM_ARCH_DDR_RK3368_H__ +#define __ASM_ARCH_DDR_RK3368_H__ + +/* + * The RK3368 DDR PCTL differs from the incarnation in the RK3288 only + * in a few details. Most notably, it has an additional field to track + * tREFI in controller cycles (i.e. trefi_mem_ddr3). + */ +struct rk3368_ddr_pctl { + u32 scfg; + u32 sctl; + u32 stat; + u32 intrstat; + u32 reserved0[12]; + u32 mcmd; + u32 powctl; + u32 powstat; + u32 cmdtstat; + u32 cmdtstaten; + u32 reserved1[3]; + u32 mrrcfg0; + u32 mrrstat0; + u32 mrrstat1; + u32 reserved2[4]; + u32 mcfg1; + u32 mcfg; + u32 ppcfg; + u32 mstat; + u32 lpddr2zqcfg; + u32 reserved3; + u32 dtupdes; + u32 dtuna; + u32 dtune; + u32 dtuprd0; + u32 dtuprd1; + u32 dtuprd2; + u32 dtuprd3; + u32 dtuawdt; + u32 reserved4[3]; + u32 togcnt1u; + u32 tinit; + u32 trsth; + u32 togcnt100n; + u32 trefi; + u32 tmrd; + u32 trfc; + u32 trp; + u32 trtw; + u32 tal; + u32 tcl; + u32 tcwl; + u32 tras; + u32 trc; + u32 trcd; + u32 trrd; + u32 trtp; + u32 twr; + u32 twtr; + u32 texsr; + u32 txp; + u32 txpdll; + u32 tzqcs; + u32 tzqcsi; + u32 tdqs; + u32 tcksre; + u32 tcksrx; + u32 tcke; + u32 tmod; + u32 trstl; + u32 tzqcl; + u32 tmrr; + u32 tckesr; + u32 tdpd; + u32 trefi_mem_ddr3; + u32 reserved5[45]; + u32 dtuwactl; + u32 dturactl; + u32 dtucfg; + u32 dtuectl; + u32 dtuwd0; + u32 dtuwd1; + u32 dtuwd2; + u32 dtuwd3; + u32 dtuwdm; + u32 dturd0; + u32 dturd1; + u32 dturd2; + u32 dturd3; + u32 dtulfsrwd; + u32 dtulfsrrd; + u32 dtueaf; + u32 dfitctrldelay; + u32 dfiodtcfg; + u32 dfiodtcfg1; + u32 dfiodtrankmap; + u32 dfitphywrdata; + u32 dfitphywrlat; + u32 reserved7[2]; + u32 dfitrddataen; + u32 dfitphyrdlat; + u32 reserved8[2]; + u32 dfitphyupdtype0; + u32 dfitphyupdtype1; + u32 dfitphyupdtype2; + u32 dfitphyupdtype3; + u32 dfitctrlupdmin; + u32 dfitctrlupdmax; + u32 dfitctrlupddly; + u32 reserved9; + u32 dfiupdcfg; + u32 dfitrefmski; + u32 dfitctrlupdi; + u32 reserved10[4]; + u32 dfitrcfg0; + u32 dfitrstat0; + u32 dfitrwrlvlen; + u32 dfitrrdlvlen; + u32 dfitrrdlvlgateen; + u32 dfiststat0; + u32 dfistcfg0; + u32 dfistcfg1; + u32 reserved11; + u32 dfitdramclken; + u32 dfitdramclkdis; + u32 dfistcfg2; + u32 dfistparclr; + u32 dfistparlog; + u32 reserved12[3]; + u32 dfilpcfg0; + u32 reserved13[3]; + u32 dfitrwrlvlresp0; + u32 dfitrwrlvlresp1; + u32 dfitrwrlvlresp2; + u32 dfitrrdlvlresp0; + u32 dfitrrdlvlresp1; + u32 dfitrrdlvlresp2; + u32 dfitrwrlvldelay0; + u32 dfitrwrlvldelay1; + u32 dfitrwrlvldelay2; + u32 dfitrrdlvldelay0; + u32 dfitrrdlvldelay1; + u32 dfitrrdlvldelay2; + u32 dfitrrdlvlgatedelay0; + u32 dfitrrdlvlgatedelay1; + u32 dfitrrdlvlgatedelay2; + u32 dfitrcmd; + u32 reserved14[46]; + u32 ipvr; + u32 iptr; +}; +check_member(rk3368_ddr_pctl, iptr, 0x03fc); + +struct rk3368_ddrphy { + u32 reg[0x100]; +}; +check_member(rk3368_ddrphy, reg[0xff], 0x03fc); + +struct rk3368_msch { + u32 coreid; + u32 revisionid; + u32 ddrconf; + u32 ddrtiming; + u32 ddrmode; + u32 readlatency; + u32 reserved1[8]; + u32 activate; + u32 devtodev; +}; +check_member(rk3368_msch, devtodev, 0x003c); + +/* GRF_SOC_CON0 */ +enum { + NOC_RSP_ERR_STALL = BIT(9), + MOBILE_DDR_SEL = BIT(4), + DDR0_16BIT_EN = BIT(3), + MSCH0_MAINDDR3_DDR3 = BIT(2), + MSCH0_MAINPARTIALPOP = BIT(1), + UPCTL_C_ACTIVE = BIT(0), +}; + +#endif diff --git a/arch/arm/include/asm/arch-rockchip/grf_rk3368.h b/arch/arm/include/asm/arch-rockchip/grf_rk3368.h index a97dc1e..f91a5fb 100644 --- a/arch/arm/include/asm/arch-rockchip/grf_rk3368.h +++ b/arch/arm/include/asm/arch-rockchip/grf_rk3368.h @@ -76,8 +76,11 @@ struct rk3368_grf { u32 soc_con15; u32 soc_con16; u32 soc_con17; + u32 reserved5[0x6e]; + u32 ddrc0_con0; }; check_member(rk3368_grf, soc_con17, 0x444); +check_member(rk3368_grf, ddrc0_con0, 0x600);
struct rk3368_pmu_grf { u32 gpio0a_iomux; @@ -406,16 +409,6 @@ enum { RK3368_GPIO3D0_MAC_MDIO = (1 << 0), };
-/* GRF_SOC_CON0 */ -enum { - NOC_RSP_ERR_STALL = BIT(9), - MOBILE_DDR_SEL = BIT(4), - DDR0_16BIT_EN = BIT(3), - MSCH0_MAINDDR3_DDR3 = BIT(2), - MSCH0_MAINPARTIALPOP = BIT(1), - UPCTL_C_ACTIVE = BIT(0), -}; - /*GRF_SOC_CON11/12/13*/ enum { MCU_SRAM_BASE_BIT27_BIT12_SHIFT = 0, diff --git a/arch/arm/mach-rockchip/rk3368/Makefile b/arch/arm/mach-rockchip/rk3368/Makefile index 0390716..46798c2 100644 --- a/arch/arm/mach-rockchip/rk3368/Makefile +++ b/arch/arm/mach-rockchip/rk3368/Makefile @@ -5,5 +5,4 @@ # obj-y += clk_rk3368.o obj-y += rk3368.o -obj-y += sdram_rk3368.o obj-y += syscon_rk3368.o diff --git a/arch/arm/mach-rockchip/rk3368/sdram_rk3368.c b/arch/arm/mach-rockchip/rk3368/sdram_rk3368.c deleted file mode 100644 index d0d0900..0000000 --- a/arch/arm/mach-rockchip/rk3368/sdram_rk3368.c +++ /dev/null @@ -1,60 +0,0 @@ -/* - * (C) Copyright 2016 Rockchip Electronics Co., Ltd. - * - * SPDX-License-Identifier: GPL-2.0 - */ - -#include <common.h> -#include <dm.h> -#include <ram.h> -#include <syscon.h> -#include <asm/arch/clock.h> -#include <asm/arch/grf_rk3368.h> -#include <asm/arch/sdram_common.h> - -DECLARE_GLOBAL_DATA_PTR; -struct dram_info { - struct ram_info info; - struct rk3368_pmu_grf *pmugrf; -}; - -static int rk3368_dmc_probe(struct udevice *dev) -{ - struct dram_info *priv = dev_get_priv(dev); - - priv->pmugrf = syscon_get_first_range(ROCKCHIP_SYSCON_PMUGRF); - debug("%s: grf=%p\n", __func__, priv->pmugrf); - priv->info.base = CONFIG_SYS_SDRAM_BASE; - priv->info.size = rockchip_sdram_size( - (phys_addr_t)&priv->pmugrf->os_reg[2]); - - return 0; -} - -static int rk3368_dmc_get_info(struct udevice *dev, struct ram_info *info) -{ - struct dram_info *priv = dev_get_priv(dev); - - *info = priv->info; - - return 0; -} - -static struct ram_ops rk3368_dmc_ops = { - .get_info = rk3368_dmc_get_info, -}; - - -static const struct udevice_id rk3368_dmc_ids[] = { - { .compatible = "rockchip,rk3368-dmc" }, - { } -}; - -U_BOOT_DRIVER(dmc_rk3368) = { - .name = "rockchip_rk3368_dmc", - .id = UCLASS_RAM, - .of_match = rk3368_dmc_ids, - .ops = &rk3368_dmc_ops, - .probe = rk3368_dmc_probe, - .priv_auto_alloc_size = sizeof(struct dram_info), -}; diff --git a/doc/device-tree-bindings/clock/rockchip,rk3368-dmc.txt b/doc/device-tree-bindings/clock/rockchip,rk3368-dmc.txt new file mode 100644 index 0000000..8e7357d --- /dev/null +++ b/doc/device-tree-bindings/clock/rockchip,rk3368-dmc.txt @@ -0,0 +1,67 @@ +RK3368 dynamic memory controller driver +======================================= + +The RK3368 DMC (dynamic memory controller) driver supports setup/initialisation +during TPL using configuration data from the DTS (i.e. OF_PLATDATA), based on +the following key configuration data: + (a) a target-frequency (i.e. operating point) for the memory operation + (b) a speed-bin (as defined in JESD-79) for the DDR3 used in hardware + (c) a memory-schedule (i.e. mapping from physical addresses to the address + pins of the memory bus) + +Required properties +------------------- + +- compatible: "rockchip,rk3368-dmc" +- reg + protocol controller (PCTL) address and PHY controller (DDRPHY) address +- rockchip,ddr-speed-bin + the DDR3 device's speed-bin (as specified according to JESD-79) + DDR3_800D (5-5-5) + DDR3_800E (6-6-6) + DDR3_1066E (6-6-6) + DDR3_1066F (7-7-7) + DDR3_1066G (8-8-8) + DDR3_1333F (7-7-7) + DDR3_1333G (8-8-8) + DDR3_1333H (9-9-9) + DDR3_1333J (10-10-10) + DDR3_1600G (8-8-8) + DDR3_1600H (9-9-9) + DDR3_1600J (10-10-10) + DDR3_1600K (11-11-11) + DDR3_1866J (10-10-10) + DDR3_1866K (11-11-11) + DDR3_1866L (12-12-12) + DDR3_1866M (13-13-13) + DDR3_2133K (11-11-11) + DDR3_2133L (12-12-12) + DDR3_2133M (13-13-13) + DDR3_2133N (14-14-14) +- rockchip,ddr-frequency: + target DDR clock frequency in Hz (not all frequencies may be supported, + as there's some cooperation from the clock-driver required) +- rockchip,memory-schedule: + controls the decoding of physical addresses to DRAM addressing (i.e. how + the physical address maps onto the address pins/chip-select of the device) + DMC_MSCH_CBDR: column -> bank -> device -> row + DMC_MSCH_CBRD: column -> band -> row -> device + DMC_MSCH_CRBD: column -> row -> band -> device + +Example (for DDR3-1600K and 800MHz) +----------------------------------- + + #include <dt-bindings/memory/rk3368-dmc.h> + + dmc: dmc@ff610000 { + u-boot,dm-pre-reloc; + compatible = "rockchip,rk3368-dmc"; + reg = <0 0xff610000 0 0x400 + 0 0xff620000 0 0x400>; + }; + + &dmc { + rockchip,ddr-speed-bin = <DDR3_1600K>; + rockchip,ddr-frequency = <800000000>; + rockchip,memory-schedule = <DMC_MSCH_CBRD>; + }; diff --git a/drivers/ram/Makefile b/drivers/ram/Makefile index c409c48..51ae6be 100644 --- a/drivers/ram/Makefile +++ b/drivers/ram/Makefile @@ -8,3 +8,5 @@ obj-$(CONFIG_RAM) += ram-uclass.o obj-$(CONFIG_SANDBOX) += sandbox_ram.o obj-$(CONFIG_STM32_SDRAM) += stm32_sdram.o obj-$(CONFIG_ARCH_BMIPS) += bmips_ram.o + +obj-$(CONFIG_ARCH_ROCKCHIP) += rockchip/ diff --git a/drivers/ram/rockchip/Makefile b/drivers/ram/rockchip/Makefile new file mode 100644 index 0000000..b09d03c --- /dev/null +++ b/drivers/ram/rockchip/Makefile @@ -0,0 +1,7 @@ +# +# Copyright (c) 2017 Theobroma Systems Design und Consulting GmbH +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-$(CONFIG_ROCKCHIP_RK3368) = dmc-rk3368.o diff --git a/drivers/ram/rockchip/dmc-rk3368.c b/drivers/ram/rockchip/dmc-rk3368.c new file mode 100644 index 0000000..fea96a5 --- /dev/null +++ b/drivers/ram/rockchip/dmc-rk3368.c @@ -0,0 +1,990 @@ +/* + * (C) Copyright 2017 Theobroma Systems Design und Consulting GmbH + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <common.h> +#include <clk.h> +#include <dm.h> +#include <dt-bindings/memory/rk3368-dmc.h> +#include <dt-structs.h> +#include <ram.h> +#include <regmap.h> +#include <syscon.h> +#include <asm/io.h> +#include <asm/arch/clock.h> +#include <asm/arch/cru_rk3368.h> +#include <asm/arch/grf_rk3368.h> +#include <asm/arch/ddr_rk3368.h> +#include <asm/arch/sdram.h> +#include <asm/arch/sdram_common.h> + +DECLARE_GLOBAL_DATA_PTR; + +struct dram_info { + struct ram_info info; + struct clk ddr_clk; + struct rk3368_cru *cru; + struct rk3368_grf *grf; + struct rk3368_ddr_pctl *pctl; + struct rk3368_ddrphy *phy; + struct rk3368_pmu_grf *pmugrf; + struct rk3368_msch *msch; +}; + +struct rk3368_sdram_params { +#if CONFIG_IS_ENABLED(OF_PLATDATA) + struct dtd_rockchip_rk3368_dmc of_plat; +#endif + struct rk3288_sdram_pctl_timing pctl_timing; + u32 trefi_mem_ddr3; + struct rk3288_sdram_channel chan; + struct regmap *map; + u32 ddr_freq; + u32 memory_schedule; + u32 ddr_speed_bin; + u32 tfaw_mult; +}; + +/* PTCL bits */ +enum { + /* PCTL_DFISTCFG0 */ + DFI_INIT_START = BIT(0), + DFI_DATA_BYTE_DISABLE_EN = BIT(2), + + /* PCTL_DFISTCFG1 */ + DFI_DRAM_CLK_SR_EN = BIT(0), + DFI_DRAM_CLK_DPD_EN = BIT(1), + ODT_LEN_BL8_W_SHIFT = 16, + + /* PCTL_DFISTCFG2 */ + DFI_PARITY_INTR_EN = BIT(0), + DFI_PARITY_EN = BIT(1), + + /* PCTL_DFILPCFG0 */ + TLP_RESP_TIME_SHIFT = 16, + LP_SR_EN = BIT(8), + LP_PD_EN = BIT(0), + + /* PCTL_DFIODTCFG */ + RANK0_ODT_WRITE_SEL = BIT(3), + RANK1_ODT_WRITE_SEL = BIT(11), + + /* PCTL_SCFG */ + HW_LOW_POWER_EN = BIT(0), + + /* PCTL_MCMD */ + START_CMD = BIT(31), + MCMD_RANK0 = BIT(20), + MCMD_RANK1 = BIT(21), + DESELECT_CMD = 0, + PREA_CMD, + REF_CMD, + MRS_CMD, + ZQCS_CMD, + ZQCL_CMD, + RSTL_CMD, + MRR_CMD = 8, + DPDE_CMD, + + /* PCTL_POWCTL */ + POWER_UP_START = BIT(0), + + /* PCTL_POWSTAT */ + POWER_UP_DONE = BIT(0), + + /* PCTL_SCTL */ + INIT_STATE = 0, + CFG_STATE, + GO_STATE, + SLEEP_STATE, + WAKEUP_STATE, + + /* PCTL_STAT */ + LP_TRIG_SHIFT = 4, + LP_TRIG_MASK = 7, + PCTL_STAT_MSK = 7, + INIT_MEM = 0, + CONFIG, + CONFIG_REQ, + ACCESS, + ACCESS_REQ, + LOW_POWER, + LOW_POWER_ENTRY_REQ, + LOW_POWER_EXIT_REQ, + + /* PCTL_MCFG */ + DDR2_DDR3_BL_8 = BIT(0), + DDR3_EN = BIT(5), + TFAW_TRRD_MULT4 = (0 << 18), + TFAW_TRRD_MULT5 = (1 << 18), + TFAW_TRRD_MULT6 = (2 << 18), +}; + +#define DDR3_MR0_WR(n) \ + ((n <= 8) ? ((n - 4) << 9) : (((n >> 1) & 0x7) << 9)) +#define DDR3_MR0_CL(n) \ + ((((n - 4) & 0x7) << 4) | (((n - 4) & 0x8) >> 2)) +#define DDR3_MR0_BL8 \ + (0 << 0) +#define DDR3_MR0_DLL_RESET \ + (1 << 8) +#define DDR3_MR1_RTT120OHM \ + ((0 << 9) | (1 << 6) | (0 << 2)) +#define DDR3_MR2_TWL(n) \ + (((n - 5) & 0x7) << 3) + + +#ifdef CONFIG_TPL_BUILD + +static void ddr_set_noc_spr_err_stall(struct rk3368_grf *grf, bool enable) +{ + if (enable) + rk_setreg(&grf->ddrc0_con0, NOC_RSP_ERR_STALL); + else + rk_clrreg(&grf->ddrc0_con0, NOC_RSP_ERR_STALL); +} + +static void ddr_set_ddr3_mode(struct rk3368_grf *grf, bool ddr3_mode) +{ + if (ddr3_mode) + rk_setreg(&grf->ddrc0_con0, MSCH0_MAINDDR3_DDR3); + else + rk_clrreg(&grf->ddrc0_con0, MSCH0_MAINDDR3_DDR3); +} + +static void ddrphy_config(struct rk3368_ddrphy *phy, + u32 tcl, u32 tal, u32 tcwl) +{ + int i; + + /* Set to DDR3 mode */ + clrsetbits_le32(&phy->reg[1], 0x3, 0x0); + + /* DDRPHY_REGB: CL, AL */ + clrsetbits_le32(&phy->reg[0xb], 0xff, tcl << 4 | tal); + /* DDRPHY_REGC: CWL */ + clrsetbits_le32(&phy->reg[0xc], 0x0f, tcwl); + + /* Update drive-strength */ + writel(0xcc, &phy->reg[0x11]); + writel(0xaa, &phy->reg[0x16]); + /* + * Update NRCOMP/PRCOMP for all 4 channels (for details of all + * affected registers refer to the documentation of DDRPHY_REG20 + * and DDRPHY_REG21 in the RK3368 TRM. + */ + for (i = 0; i < 4; ++i) { + writel(0xcc, &phy->reg[0x20 + i * 0x10]); + writel(0x44, &phy->reg[0x21 + i * 0x10]); + } + + /* Enable write-leveling calibration bypass */ + setbits_le32(&phy->reg[2], BIT(3)); +} + +static void copy_to_reg(u32 *dest, const u32 *src, u32 n) +{ + int i; + + for (i = 0; i < n / sizeof(u32); i++) + writel(*src++, dest++); +} + +static void send_command(struct rk3368_ddr_pctl *pctl, u32 rank, u32 cmd) +{ + u32 mcmd = START_CMD | cmd | rank; + + debug("%s: writing %x to MCMD\n", __func__, mcmd); + writel(mcmd, &pctl->mcmd); + while (readl(&pctl->mcmd) & START_CMD) + /* spin */; +} + +static void send_mrs(struct rk3368_ddr_pctl *pctl, + u32 rank, u32 mr_num, u32 mr_data) +{ + u32 mcmd = START_CMD | MRS_CMD | rank | (mr_num << 17) | (mr_data << 4); + + debug("%s: writing %x to MCMD\n", __func__, mcmd); + writel(mcmd, &pctl->mcmd); + while (readl(&pctl->mcmd) & START_CMD) + /* spin */; +} + +static int memory_init(struct rk3368_ddr_pctl *pctl, + struct rk3368_sdram_params *params) +{ + u32 mr[4]; + const ulong timeout_ms = 500; + ulong tmp; + + /* + * Power up DRAM by DDR_PCTL_POWCTL[0] register of PCTL and + * wait power up DRAM finish with DDR_PCTL_POWSTAT[0] register + * of PCTL. + */ + writel(POWER_UP_START, &pctl->powctl); + + tmp = get_timer(0); + do { + if (get_timer(tmp) > timeout_ms) { + error("%s: POWER_UP_START did not complete in %ld ms\n", + __func__, timeout_ms); + return -ETIME; + } + } while (!(readl(&pctl->powstat) & POWER_UP_DONE)); + + /* Configure MR0 through MR3 */ + mr[0] = DDR3_MR0_WR(params->pctl_timing.twr) | + DDR3_MR0_CL(params->pctl_timing.tcl) | + DDR3_MR0_DLL_RESET; + mr[1] = DDR3_MR1_RTT120OHM; + mr[2] = DDR3_MR2_TWL(params->pctl_timing.tcwl); + mr[3] = 0; + + /* + * Also see RK3368 Technical Reference Manual: + * "16.6.2 Initialization (DDR3 Initialization Sequence)" + */ + send_command(pctl, MCMD_RANK0 | MCMD_RANK1, DESELECT_CMD); + udelay(1); + send_command(pctl, MCMD_RANK0 | MCMD_RANK1, PREA_CMD); + send_mrs(pctl, MCMD_RANK0 | MCMD_RANK1, 2, mr[2]); + send_mrs(pctl, MCMD_RANK0 | MCMD_RANK1, 3, mr[3]); + send_mrs(pctl, MCMD_RANK0 | MCMD_RANK1, 1, mr[1]); + send_mrs(pctl, MCMD_RANK0 | MCMD_RANK1, 0, mr[0]); + send_command(pctl, MCMD_RANK0 | MCMD_RANK1, ZQCL_CMD); + + return 0; +} + +static void move_to_config_state(struct rk3368_ddr_pctl *pctl) +{ + /* + * Also see RK3368 Technical Reference Manual: + * "16.6.1 State transition of PCTL (Moving to Config State)" + */ + u32 state = readl(&pctl->stat) & PCTL_STAT_MSK; + + switch (state) { + case LOW_POWER: + writel(WAKEUP_STATE, &pctl->sctl); + while ((readl(&pctl->stat) & PCTL_STAT_MSK) != ACCESS) + /* spin */; + + /* fall-through */ + case ACCESS: + case INIT_MEM: + writel(CFG_STATE, &pctl->sctl); + while ((readl(&pctl->stat) & PCTL_STAT_MSK) != CONFIG) + /* spin */; + break; + + case CONFIG: + return; + + default: + break; + } +} + +static void move_to_access_state(struct rk3368_ddr_pctl *pctl) +{ + /* + * Also see RK3368 Technical Reference Manual: + * "16.6.1 State transition of PCTL (Moving to Access State)" + */ + u32 state = readl(&pctl->stat) & PCTL_STAT_MSK; + + switch (state) { + case LOW_POWER: + if (((readl(&pctl->stat) >> LP_TRIG_SHIFT) & + LP_TRIG_MASK) == 1) + return; + + writel(WAKEUP_STATE, &pctl->sctl); + while ((readl(&pctl->stat) & PCTL_STAT_MSK) != ACCESS) + /* spin */; + + /* fall-through */ + case INIT_MEM: + writel(CFG_STATE, &pctl->sctl); + while ((readl(&pctl->stat) & PCTL_STAT_MSK) != CONFIG) + /* spin */; + + /* fall-through */ + case CONFIG: + writel(GO_STATE, &pctl->sctl); + while ((readl(&pctl->stat) & PCTL_STAT_MSK) == CONFIG) + /* spin */; + break; + + case ACCESS: + return; + + default: + break; + } +} + +static void ddrctl_reset(struct rk3368_cru *cru) +{ + const u32 ctl_reset = BIT(3) | BIT(2); + const u32 phy_reset = BIT(1) | BIT(0); + + rk_setreg(&cru->softrst_con[10], ctl_reset | phy_reset); + udelay(1); + rk_clrreg(&cru->softrst_con[10], ctl_reset | phy_reset); +} + +static void ddrphy_reset(struct rk3368_ddrphy *ddrphy) +{ + clrbits_le32(&ddrphy->reg[0], BIT(3) | BIT(2)); + udelay(1); + setbits_le32(&ddrphy->reg[0], BIT(3) | BIT(2)); +} + +static void ddrphy_config_delays(struct rk3368_ddrphy *ddrphy, u32 freq) +{ + u32 dqs_dll_delay; + + setbits_le32(&ddrphy->reg[0x13], BIT(4)); + clrbits_le32(&ddrphy->reg[0x14], BIT(3)); + + setbits_le32(&ddrphy->reg[0x26], BIT(4)); + clrbits_le32(&ddrphy->reg[0x27], BIT(3)); + + setbits_le32(&ddrphy->reg[0x36], BIT(4)); + clrbits_le32(&ddrphy->reg[0x37], BIT(3)); + + setbits_le32(&ddrphy->reg[0x46], BIT(4)); + clrbits_le32(&ddrphy->reg[0x47], BIT(3)); + + setbits_le32(&ddrphy->reg[0x56], BIT(4)); + clrbits_le32(&ddrphy->reg[0x57], BIT(3)); + + if (freq <= 400000000) + setbits_le32(&ddrphy->reg[0xa4], 0x1f); + else + clrbits_le32(&ddrphy->reg[0xa4], 0x1f); + + if (freq < 681000000) + dqs_dll_delay = 3; /* 67.5 degree delay */ + else + dqs_dll_delay = 2; /* 45 degree delay */ + + writel(dqs_dll_delay, &ddrphy->reg[0x28]); + writel(dqs_dll_delay, &ddrphy->reg[0x38]); + writel(dqs_dll_delay, &ddrphy->reg[0x48]); + writel(dqs_dll_delay, &ddrphy->reg[0x58]); +} + +static int dfi_cfg(struct rk3368_ddr_pctl *pctl) +{ + const ulong timeout_ms = 200; + ulong tmp; + + writel(DFI_DATA_BYTE_DISABLE_EN, &pctl->dfistcfg0); + + writel(DFI_DRAM_CLK_SR_EN | DFI_DRAM_CLK_DPD_EN, + &pctl->dfistcfg1); + writel(DFI_PARITY_INTR_EN | DFI_PARITY_EN, &pctl->dfistcfg2); + writel(7 << TLP_RESP_TIME_SHIFT | LP_SR_EN | LP_PD_EN, + &pctl->dfilpcfg0); + + writel(1, &pctl->dfitphyupdtype0); + + writel(0x1f, &pctl->dfitphyrdlat); + writel(0, &pctl->dfitphywrdata); + writel(0, &pctl->dfiupdcfg); /* phyupd and ctrlupd disabled */ + + setbits_le32(&pctl->dfistcfg0, DFI_INIT_START); + + tmp = get_timer(0); + do { + if (get_timer(tmp) > timeout_ms) { + error("%s: DFI init did not complete within %ld ms\n", + __func__, timeout_ms); + return -ETIME; + } + } while ((readl(&pctl->dfiststat0) & 1) == 0); + + return 0; +} + +static inline u32 ps_to_tCK(const u32 ps, const ulong freq) +{ + const ulong MHz = 1000000; + return DIV_ROUND_UP(ps * freq, 1000000 * MHz); +} + +static inline u32 ns_to_tCK(const u32 ns, const ulong freq) +{ + return ps_to_tCK(ns * 1000, freq); +} + +static inline u32 tCK_to_ps(const ulong tCK, const ulong freq) +{ + const ulong MHz = 1000000; + return DIV_ROUND_UP(tCK * 1000000 * MHz, freq); +} + +static int pctl_calc_timings(struct rk3368_sdram_params *params, + ulong freq) +{ + struct rk3288_sdram_pctl_timing *pctl_timing = ¶ms->pctl_timing; + const ulong MHz = 1000000; + u32 tccd; + u32 tfaw_as_ps; + + if (params->ddr_speed_bin != DDR3_1600K) { + error("%s: unimplemented DDR3 speed bin %d\n", + __func__, params->ddr_speed_bin); + return -1; + } + + /* PCTL is clocked at 1/2 the DRAM clock; err on the side of caution */ + pctl_timing->togcnt1u = DIV_ROUND_UP(freq, 2 * MHz); + pctl_timing->togcnt100n = DIV_ROUND_UP(freq / 10, 2 * MHz); + + pctl_timing->tinit = 200; /* 200 usec */ + pctl_timing->trsth = 500; /* 500 usec */ + pctl_timing->trefi = 78; /* 7.8usec = 78 * 100ns */ + params->trefi_mem_ddr3 = ns_to_tCK(pctl_timing->trefi * 100, freq); + + if (freq <= (400 * MHz)) { + pctl_timing->tcl = 6; + pctl_timing->tcwl = 10; + } else if (freq <= (533 * MHz)) { + pctl_timing->tcl = 8; + pctl_timing->tcwl = 6; + } else if (freq <= (666 * MHz)) { + pctl_timing->tcl = 10; + pctl_timing->tcwl = 7; + } else { + pctl_timing->tcl = 11; + pctl_timing->tcwl = 8; + } + + pctl_timing->tmrd = 4; /* 4 tCK (all speed bins) */ + pctl_timing->trfc = ns_to_tCK(350, freq); /* tRFC: 350 (max) @ 8GBit */ + pctl_timing->trp = max(4u, ps_to_tCK(13750, freq)); + /* + * JESD-79: + * READ to WRITE Command Delay = RL + tCCD / 2 + 2tCK - WL + */ + tccd = 4; + pctl_timing->trtw = pctl_timing->tcl + tccd/2 + 2 - pctl_timing->tcwl; + pctl_timing->tal = 0; + pctl_timing->tras = ps_to_tCK(35000, freq); + pctl_timing->trc = ps_to_tCK(48750, freq); + pctl_timing->trcd = ps_to_tCK(13750, freq); + pctl_timing->trrd = max(4u, ps_to_tCK(7500, freq)); + pctl_timing->trtp = max(4u, ps_to_tCK(7500, freq)); + pctl_timing->twr = ps_to_tCK(15000, freq); + /* The DDR3 mode-register does only support even values for tWR > 8. */ + if (pctl_timing->twr > 8) + pctl_timing->twr = (pctl_timing->twr + 1) & ~1; + pctl_timing->twtr = max(4u, ps_to_tCK(7500, freq)); + pctl_timing->texsr = 512; /* tEXSR(max) is tDLLLK */ + pctl_timing->txp = max(3u, ps_to_tCK(6000, freq)); + pctl_timing->txpdll = max(10u, ps_to_tCK(24000, freq)); + pctl_timing->tzqcs = max(64u, ps_to_tCK(80000, freq)); + pctl_timing->tzqcsi = 10000; /* as used by Rockchip */ + pctl_timing->tdqs = 1; /* fixed for DDR3 */ + pctl_timing->tcksre = max(5u, ps_to_tCK(10000, freq)); + pctl_timing->tcksrx = max(5u, ps_to_tCK(10000, freq)); + pctl_timing->tcke = max(3u, ps_to_tCK(5000, freq)); + pctl_timing->tmod = max(12u, ps_to_tCK(15000, freq)); + pctl_timing->trstl = ns_to_tCK(100, freq); + pctl_timing->tzqcl = max(256u, ps_to_tCK(320000, freq)); /* tZQoper */ + pctl_timing->tmrr = 0; + pctl_timing->tckesr = pctl_timing->tcke + 1; /* JESD-79: tCKE + 1tCK */ + pctl_timing->tdpd = 0; /* RK3368 TRM: "allowed values for DDR3: 0" */ + + + /* + * The controller can represent tFAW as 4x, 5x or 6x tRRD only. + * We want to use the smallest multiplier that satisfies the tFAW + * requirements of the given speed-bin. If necessary, we stretch out + * tRRD to allow us to operate on a 6x multiplier for tFAW. + */ + tfaw_as_ps = 40000; /* 40ns: tFAW for DDR3-1600K, 2KB page-size */ + if (tCK_to_ps(pctl_timing->trrd * 6, freq) < tfaw_as_ps) { + /* If tFAW is > 6 x tRRD, we need to stretch tRRD */ + pctl_timing->trrd = ps_to_tCK(DIV_ROUND_UP(40000, 6), freq); + params->tfaw_mult = TFAW_TRRD_MULT6; + } else if (tCK_to_ps(pctl_timing->trrd * 5, freq) < tfaw_as_ps) { + params->tfaw_mult = TFAW_TRRD_MULT6; + } else if (tCK_to_ps(pctl_timing->trrd * 4, freq) < tfaw_as_ps) { + params->tfaw_mult = TFAW_TRRD_MULT5; + } else { + params->tfaw_mult = TFAW_TRRD_MULT4; + } + + return 0; +} + +static void pctl_cfg(struct rk3368_ddr_pctl *pctl, + struct rk3368_sdram_params *params, + struct rk3368_grf *grf) +{ + /* Configure PCTL timing registers */ + params->pctl_timing.trefi |= BIT(31); /* see PCTL_TREFI */ + copy_to_reg(&pctl->togcnt1u, ¶ms->pctl_timing.togcnt1u, + sizeof(params->pctl_timing)); + writel(params->trefi_mem_ddr3, &pctl->trefi_mem_ddr3); + + /* Set up ODT write selector and ODT write length */ + writel((RANK0_ODT_WRITE_SEL | RANK1_ODT_WRITE_SEL), &pctl->dfiodtcfg); + writel(7 << ODT_LEN_BL8_W_SHIFT, &pctl->dfiodtcfg1); + + /* Set up the CL/CWL-dependent timings of DFI */ + writel((params->pctl_timing.tcl - 1) / 2 - 1, &pctl->dfitrddataen); + writel((params->pctl_timing.tcwl - 1) / 2 - 1, &pctl->dfitphywrlat); + + /* DDR3 */ + writel(params->tfaw_mult | DDR3_EN | DDR2_DDR3_BL_8, &pctl->mcfg); + writel(0x001c0004, &grf->ddrc0_con0); + + setbits_le32(&pctl->scfg, HW_LOW_POWER_EN); +} + +static int ddrphy_data_training(struct rk3368_ddr_pctl *pctl, + struct rk3368_ddrphy *ddrphy) +{ + const u32 trefi = readl(&pctl->trefi); + const ulong timeout_ms = 500; + ulong tmp; + + /* disable auto-refresh */ + writel(0 | BIT(31), &pctl->trefi); + + clrsetbits_le32(&ddrphy->reg[2], 0x33, 0x20); + clrsetbits_le32(&ddrphy->reg[2], 0x33, 0x21); + + tmp = get_timer(0); + do { + if (get_timer(tmp) > timeout_ms) { + error("%s: did not complete within %ld ms\n", + __func__, timeout_ms); + return -ETIME; + } + } while ((readl(&ddrphy->reg[0xff]) & 0xf) != 0xf); + + send_command(pctl, MCMD_RANK0 | MCMD_RANK1, PREA_CMD); + clrsetbits_le32(&ddrphy->reg[2], 0x33, 0x20); + /* resume auto-refresh */ + writel(trefi | BIT(31), &pctl->trefi); + + return 0; +} + +static int sdram_col_row_detect(struct udevice *dev) +{ + struct dram_info *priv = dev_get_priv(dev); + struct rk3368_sdram_params *params = dev_get_platdata(dev); + struct rk3368_ddr_pctl *pctl = priv->pctl; + struct rk3368_msch *msch = priv->msch; + const u32 test_pattern = 0x5aa5f00f; + int row, col; + uintptr_t addr; + + move_to_config_state(pctl); + writel(6, &msch->ddrconf); + move_to_access_state(pctl); + + /* Detect col */ + for (col = 11; col >= 9; col--) { + writel(0, CONFIG_SYS_SDRAM_BASE); + addr = CONFIG_SYS_SDRAM_BASE + + (1 << (col + params->chan.bw - 1)); + writel(test_pattern, addr); + if ((readl(addr) == test_pattern) && + (readl(CONFIG_SYS_SDRAM_BASE) == 0)) + break; + } + + if (col == 8) { + error("%s: col detect error\n", __func__); + return -EINVAL; + } + + move_to_config_state(pctl); + writel(15, &msch->ddrconf); + move_to_access_state(pctl); + + /* Detect row*/ + for (row = 16; row >= 12; row--) { + writel(0, CONFIG_SYS_SDRAM_BASE); + addr = CONFIG_SYS_SDRAM_BASE + (1 << (row + 15 - 1)); + writel(test_pattern, addr); + if ((readl(addr) == test_pattern) && + (readl(CONFIG_SYS_SDRAM_BASE) == 0)) + break; + } + + if (row == 11) { + error("%s: row detect error\n", __func__); + return -EINVAL; + } + + /* Record results */ + debug("%s: col %d, row %d\n", __func__, col, row); + params->chan.col = col; + params->chan.cs0_row = row; + params->chan.cs1_row = row; + params->chan.row_3_4 = 0; + + return 0; +} + +static int msch_niu_config(struct rk3368_msch *msch, + struct rk3368_sdram_params *params) +{ + int i; + const u8 cols = params->chan.col - ((params->chan.bw == 2) ? 0 : 1); + const u8 rows = params->chan.cs0_row; + + /* + * The DDR address-translation table always assumes a 32bit + * bus and the comparison below takes care of adjusting for + * a 16bit bus (i.e. one column-address is consumed). + */ + const struct { + u8 rows; + u8 columns; + u8 type; + } ddrconf_table[] = { + /* + * C-B-R-D patterns are first. For these we require an + * exact match for the columns and rows (as there's + * one entry per possible configuration). + */ + [0] = { .rows = 13, .columns = 10, .type = DMC_MSCH_CBRD }, + [1] = { .rows = 14, .columns = 10, .type = DMC_MSCH_CBRD }, + [2] = { .rows = 15, .columns = 10, .type = DMC_MSCH_CBRD }, + [3] = { .rows = 16, .columns = 10, .type = DMC_MSCH_CBRD }, + [4] = { .rows = 14, .columns = 11, .type = DMC_MSCH_CBRD }, + [5] = { .rows = 15, .columns = 11, .type = DMC_MSCH_CBRD }, + [6] = { .rows = 16, .columns = 11, .type = DMC_MSCH_CBRD }, + [7] = { .rows = 13, .columns = 9, .type = DMC_MSCH_CBRD }, + [8] = { .rows = 14, .columns = 9, .type = DMC_MSCH_CBRD }, + [9] = { .rows = 15, .columns = 9, .type = DMC_MSCH_CBRD }, + [10] = { .rows = 16, .columns = 9, .type = DMC_MSCH_CBRD }, + /* + * 11 through 13 are C-R-B-D patterns. These are + * matched for an exact number of columns and to + * ensure that the hardware uses at least as many rows + * as the pattern requires (i.e. we make sure that + * there's no gaps up until we hit the device/chip-select; + * however, these patterns can accept up to 16 rows, + * as the row-address continues right after the CS + * switching) + */ + [11] = { .rows = 15, .columns = 10, .type = DMC_MSCH_CRBD }, + [12] = { .rows = 14, .columns = 11, .type = DMC_MSCH_CRBD }, + [13] = { .rows = 13, .columns = 10, .type = DMC_MSCH_CRBD }, + /* + * 14 and 15 are catch-all variants using a C-B-D-R + * scheme (i.e. alternating the chip-select every time + * C-B overflows) and stuffing the remaining C-bits + * into the top. Matching needs to make sure that the + * number of columns is either an exact match (i.e. we + * can use less the the maximum number of rows) -or- + * that the columns exceed what is given in this table + * and the rows are an exact match (in which case the + * remaining C-bits will be stuffed onto the top after + * the device/chip-select switches). + */ + [14] = { .rows = 16, .columns = 10, .type = DMC_MSCH_CBDR }, + [15] = { .rows = 16, .columns = 9, .type = DMC_MSCH_CBDR }, + }; + + /* + * For C-B-R-D, we need an exact match (i.e. both for the number of + * columns and rows), while for C-B-D-R, only the the number of + * columns needs to match. + */ + for (i = 0; i < ARRAY_SIZE(ddrconf_table); i++) { + bool match = false; + + /* If this entry if for a different matcher, then skip it */ + if (ddrconf_table[i].type != params->memory_schedule) + continue; + + /* + * Match according to the rules (exact/inexact/at-least) + * documented in the ddrconf_table above. + */ + switch (params->memory_schedule) { + case DMC_MSCH_CBRD: + match = (ddrconf_table[i].columns == cols) && + (ddrconf_table[i].rows == rows); + break; + + case DMC_MSCH_CRBD: + match = (ddrconf_table[i].columns == cols) && + (ddrconf_table[i].rows <= rows); + break; + + case DMC_MSCH_CBDR: + match = (ddrconf_table[i].columns == cols) || + ((ddrconf_table[i].columns <= cols) && + (ddrconf_table[i].rows == rows)); + break; + + default: + break; + } + + if (match) { + debug("%s: setting ddrconf 0x%x\n", __func__, i); + writel(i, &msch->ddrconf); + return 0; + } + } + + error("%s: ddrconf (NIU config) not found\n", __func__); + return -EINVAL; +} + +static void dram_all_config(struct udevice *dev) +{ + struct dram_info *priv = dev_get_priv(dev); + struct rk3368_pmu_grf *pmugrf = priv->pmugrf; + struct rk3368_sdram_params *params = dev_get_platdata(dev); + const struct rk3288_sdram_channel *info = ¶ms->chan; + u32 sys_reg = 0; + const int chan = 0; + + sys_reg |= DDR3 << SYS_REG_DDRTYPE_SHIFT; + sys_reg |= 0 << SYS_REG_NUM_CH_SHIFT; + + sys_reg |= info->row_3_4 << SYS_REG_ROW_3_4_SHIFT(chan); + sys_reg |= 1 << SYS_REG_CHINFO_SHIFT(chan); + sys_reg |= (info->rank - 1) << SYS_REG_RANK_SHIFT(chan); + sys_reg |= (info->col - 9) << SYS_REG_COL_SHIFT(chan); + sys_reg |= info->bk == 3 ? 0 : 1 << SYS_REG_BK_SHIFT(chan); + sys_reg |= (info->cs0_row - 13) << SYS_REG_CS0_ROW_SHIFT(chan); + sys_reg |= (info->cs1_row - 13) << SYS_REG_CS1_ROW_SHIFT(chan); + sys_reg |= (2 >> info->bw) << SYS_REG_BW_SHIFT(chan); + sys_reg |= (2 >> info->dbw) << SYS_REG_DBW_SHIFT(chan); + + writel(sys_reg, &pmugrf->os_reg[2]); +} + +static int setup_sdram(struct udevice *dev) +{ + struct dram_info *priv = dev_get_priv(dev); + struct rk3368_sdram_params *params = dev_get_platdata(dev); + + struct rk3368_ddr_pctl *pctl = priv->pctl; + struct rk3368_ddrphy *ddrphy = priv->phy; + struct rk3368_cru *cru = priv->cru; + struct rk3368_grf *grf = priv->grf; + struct rk3368_msch *msch = priv->msch; + + int ret; + + /* The input clock (i.e. DPLL) needs to be 2x the DRAM frequency */ + ret = clk_set_rate(&priv->ddr_clk, 2 * params->ddr_freq); + if (ret < 0) { + debug("%s: could not set DDR clock: %d\n", __func__, ret); + return ret; + } + + /* Update the read-latency for the RK3368 */ + writel(0x32, &msch->readlatency); + + /* Initialise the DDR PCTL and DDR PHY */ + ddrctl_reset(cru); + ddrphy_reset(ddrphy); + ddrphy_config_delays(ddrphy, params->ddr_freq); + dfi_cfg(pctl); + /* Configure relative system information of grf_ddrc0_con0 register */ + ddr_set_ddr3_mode(grf, true); + ddr_set_noc_spr_err_stall(grf, true); + /* Calculate timings */ + pctl_calc_timings(params, params->ddr_freq); + /* Initialise the device timings in protocol controller */ + pctl_cfg(pctl, params, grf); + /* Configure AL, CL ... information of PHY registers */ + ddrphy_config(ddrphy, + params->pctl_timing.tcl, + params->pctl_timing.tal, + params->pctl_timing.tcwl); + + /* Initialize DRAM and configure with mode-register values */ + ret = memory_init(pctl, params); + if (ret) + goto error; + + move_to_config_state(pctl); + /* Perform data-training */ + ddrphy_data_training(pctl, ddrphy); + move_to_access_state(pctl); + + /* TODO(prt): could detect rank in training... */ + params->chan.rank = 2; + /* TODO(prt): bus width is not auto-detected (yet)... */ + params->chan.bw = 2; /* 32bit wide bus */ + params->chan.dbw = params->chan.dbw; /* 32bit wide bus */ + + /* DDR3 is always 8 bank */ + params->chan.bk = 3; + /* Detect col and row number */ + ret = sdram_col_row_detect(dev); + if (ret) + goto error; + + /* Configure NIU DDR configuration */ + ret = msch_niu_config(msch, params); + if (ret) + goto error; + + /* set up OS_REG to communicate w/ next stage and OS */ + dram_all_config(dev); + + return 0; + +error: + printf("DRAM init failed!\n"); + hang(); +} +#endif + +static int rk3368_dmc_ofdata_to_platdata(struct udevice *dev) +{ + int ret = 0; + +#if !CONFIG_IS_ENABLED(OF_PLATDATA) + struct rk3368_sdram_params *plat = dev_get_platdata(dev); + + ret = regmap_init_mem(dev, &plat->map); + if (ret) + return ret; +#endif + + return ret; +} + +#if CONFIG_IS_ENABLED(OF_PLATDATA) +static int conv_of_platdata(struct udevice *dev) +{ + struct rk3368_sdram_params *plat = dev_get_platdata(dev); + struct dtd_rockchip_rk3368_dmc *of_plat = &plat->of_plat; + int ret; + + plat->ddr_freq = of_plat->rockchip_ddr_frequency; + plat->ddr_speed_bin = of_plat->rockchip_ddr_speed_bin; + plat->memory_schedule = of_plat->rockchip_memory_schedule; + + ret = regmap_init_mem_platdata(dev, of_plat->reg, + ARRAY_SIZE(of_plat->reg) / 2, + &plat->map); + if (ret) + return ret; + + return 0; +} +#endif + +static int rk3368_dmc_probe(struct udevice *dev) +{ +#ifdef CONFIG_TPL_BUILD + struct rk3368_sdram_params *plat = dev_get_platdata(dev); + struct rk3368_ddr_pctl *pctl; + struct rk3368_ddrphy *ddrphy; + struct rk3368_cru *cru; + struct rk3368_grf *grf; + struct rk3368_msch *msch; + int ret; + struct udevice *dev_clk; +#endif + struct dram_info *priv = dev_get_priv(dev); + +#if CONFIG_IS_ENABLED(OF_PLATDATA) + ret = conv_of_platdata(dev); + if (ret) + return ret; +#endif + + priv->pmugrf = syscon_get_first_range(ROCKCHIP_SYSCON_PMUGRF); + debug("%s: pmugrf=%p\n", __func__, priv->pmugrf); + +#ifdef CONFIG_TPL_BUILD + pctl = regmap_get_range(plat->map, 0); + ddrphy = regmap_get_range(plat->map, 1); + msch = syscon_get_first_range(ROCKCHIP_SYSCON_MSCH); + grf = syscon_get_first_range(ROCKCHIP_SYSCON_GRF); + + priv->pctl = pctl; + priv->phy = ddrphy; + priv->msch = msch; + priv->grf = grf; + + ret = rockchip_get_clk(&dev_clk); + if (ret) + return ret; + priv->ddr_clk.id = CLK_DDR; + ret = clk_request(dev_clk, &priv->ddr_clk); + if (ret) + return ret; + + cru = rockchip_get_cru(); + priv->cru = cru; + if (IS_ERR(priv->cru)) + return PTR_ERR(priv->cru); + + ret = setup_sdram(dev); + if (ret) + return ret; +#endif + + priv->info.base = 0; + priv->info.size = + rockchip_sdram_size((phys_addr_t)&priv->pmugrf->os_reg[2]); + + /* + * we use the 0x00000000~0xfdffffff space since 0xff000000~0xffffffff + * is SoC register space (i.e. reserved), and 0xfe000000~0xfeffffff is + * inaccessible for some IP controller. + */ + priv->info.size = min(priv->info.size, (size_t)0xfe000000); + + return 0; +} + +static int rk3368_dmc_get_info(struct udevice *dev, struct ram_info *info) +{ + struct dram_info *priv = dev_get_priv(dev); + + *info = priv->info; + return 0; +} + +static struct ram_ops rk3368_dmc_ops = { + .get_info = rk3368_dmc_get_info, +}; + + +static const struct udevice_id rk3368_dmc_ids[] = { + { .compatible = "rockchip,rk3368-dmc" }, + { } +}; + +U_BOOT_DRIVER(dmc_rk3368) = { + .name = "rockchip_rk3368_dmc", + .id = UCLASS_RAM, + .of_match = rk3368_dmc_ids, + .ops = &rk3368_dmc_ops, + .probe = rk3368_dmc_probe, + .priv_auto_alloc_size = sizeof(struct dram_info), + .ofdata_to_platdata = rk3368_dmc_ofdata_to_platdata, + .probe = rk3368_dmc_probe, + .priv_auto_alloc_size = sizeof(struct dram_info), + .platdata_auto_alloc_size = sizeof(struct rk3368_sdram_params), +}; diff --git a/include/dt-bindings/memory/rk3368-dmc.h b/include/dt-bindings/memory/rk3368-dmc.h new file mode 100644 index 0000000..b06ffde --- /dev/null +++ b/include/dt-bindings/memory/rk3368-dmc.h @@ -0,0 +1,30 @@ +#ifndef DT_BINDINGS_RK3368_DMC_H +#define DT_BINDINGS_RK3368_DMC_H + +#define DMC_MSCH_CBDR 0x0 +#define DMC_MSCH_CBRD 0x1 +#define DMC_MSCH_CRBD 0x2 + +#define DDR3_800D 0 +#define DDR3_800E 1 +#define DDR3_1066E 2 +#define DDR3_1066F 3 +#define DDR3_1066G 4 +#define DDR3_1333F 5 +#define DDR3_1333G 6 +#define DDR3_1333H 7 +#define DDR3_1333J 8 +#define DDR3_1600G 9 +#define DDR3_1600H 10 +#define DDR3_1600J 11 +#define DDR3_1600K 12 +#define DDR3_1866J 13 +#define DDR3_1866K 14 +#define DDR3_1866L 15 +#define DDR3_1866M 16 +#define DDR3_2133K 17 +#define DDR3_2133L 18 +#define DDR3_2133M 19 +#define DDR3_2133N 20 + +#endif
For full SPL support, including DRAM initialisation, we need a few nodes from the DTS: this commit adds the DMC (DRAM controller) node, the service_msch (memory scheduler) node and marks GRF, PMUGRF and CRU as 'u-boot,dm-pre-reloc'. In addition to this, we also include the dt-binding for the DMC to allow DTS files including this DTSI to refer to the symbolic constants for the DDR3 bin and for the memory-schedule.
Note that the DMC contains both the memory regions for the (Designware) protocol controller as well as the DDR PHY.
Signed-off-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com ---
arch/arm/dts/rk3368.dtsi | 26 ++++++++++++++++++++------ 1 file changed, 20 insertions(+), 6 deletions(-)
diff --git a/arch/arm/dts/rk3368.dtsi b/arch/arm/dts/rk3368.dtsi index 9daf765..8dd6549 100644 --- a/arch/arm/dts/rk3368.dtsi +++ b/arch/arm/dts/rk3368.dtsi @@ -46,6 +46,7 @@ #include <dt-bindings/interrupt-controller/arm-gic.h> #include <dt-bindings/pinctrl/rockchip.h> #include <dt-bindings/thermal/thermal.h> +#include <dt-bindings/memory/rk3368-dmc.h>
/ { compatible = "rockchip,rk3368"; @@ -227,6 +228,23 @@ #clock-cells = <0>; };
+ dmc: dmc@ff610000 { + u-boot,dm-pre-reloc; + compatible = "rockchip,rk3368-dmc", "syscon"; + rockchip,cru = <&cru>; + rockchip,grf = <&grf>; + rockchip,msch = <&service_msch>; + reg = <0 0xff610000 0 0x400 + 0 0xff620000 0 0x400>; + }; + + service_msch: syscon@ffac0000 { + u-boot,dm-pre-reloc; + compatible = "rockchip,rk3368-msch", "syscon"; + reg = <0x0 0xffac0000 0x0 0x2000>; + status = "okay"; + }; + sdmmc: dwmmc@ff0c0000 { compatible = "rockchip,rk3368-dw-mshc", "rockchip,rk3288-dw-mshc"; reg = <0x0 0xff0c0000 0x0 0x4000>; @@ -546,12 +564,6 @@ status = "disabled"; };
- dmc: dmc@ff610000 { - u-boot,dm-pre-reloc; - compatible = "rockchip,rk3368-dmc", "syscon"; - reg = <0x0 0xff610000 0x0 0x1000>; - }; - i2c0: i2c@ff650000 { compatible = "rockchip,rk3368-i2c", "rockchip,rk3288-i2c"; reg = <0x0 0xff650000 0x0 0x1000>; @@ -653,6 +665,7 @@ };
cru: clock-controller@ff760000 { + u-boot,dm-pre-reloc; compatible = "rockchip,rk3368-cru"; reg = <0x0 0xff760000 0x0 0x1000>; rockchip,grf = <&grf>; @@ -661,6 +674,7 @@ };
grf: syscon@ff770000 { + u-boot,dm-pre-reloc; compatible = "rockchip,rk3368-grf", "syscon"; reg = <0x0 0xff770000 0x0 0x1000>; };
Hi Philipp:
- service_msch: syscon@ffac0000 {
status = "okay";
- sdmmc: dwmmc@ff0c0000 { compatible = "rockchip,rk3368-dw-mshc", "rockchip,rk3288-dw-mshc"; reg = <0x0 0xff0c0000 0x0 0x4000>;
As U-BOOT has introduced xxx-u-boot.dtsi for the U-BOOT-spceific dt information. I think it's better to put this u-boot needed things in rk3368-u-boot.dtsi. It will make things easier when we need to sync the dts with upstream kernel.
compatible = "rockchip,rk3368-grf", "syscon"; reg = <0x0 0xff770000 0x0 0x1000>; };u-boot,dm-pre-reloc;
To build TPL and SPL stages for the RK3368, we will also need to enable the SPL_FRAMEWORK.
include/configs/rk3368_common.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/include/configs/rk3368_common.h b/include/configs/rk3368_common.h index 8ffc293..2a3876e 100644 --- a/include/configs/rk3368_common.h +++ b/include/configs/rk3368_common.h @@ -24,6 +24,7 @@
#define COUNTER_FREQUENCY 24000000
+#define CONFIG_SPL_FRAMEWORK #define CONFIG_SYS_NS16550_MEM32
#define CONFIG_SYS_TEXT_BASE 0x00200000
This adds the TPL support for the RK3368, including the u-boot-tpl.lds.
arch/arm/mach-rockchip/Makefile | 1 + arch/arm/mach-rockchip/rk3368-board-tpl.c | 158 +++++++++++++++++++++++++++ arch/arm/mach-rockchip/rk3368/u-boot-tpl.lds | 13 +++ 3 files changed, 172 insertions(+) create mode 100644 arch/arm/mach-rockchip/rk3368-board-tpl.c create mode 100644 arch/arm/mach-rockchip/rk3368/u-boot-tpl.lds
diff --git a/arch/arm/mach-rockchip/Makefile b/arch/arm/mach-rockchip/Makefile index 633c91e..960f40f 100644 --- a/arch/arm/mach-rockchip/Makefile +++ b/arch/arm/mach-rockchip/Makefile @@ -12,6 +12,7 @@ obj-spl-$(CONFIG_ROCKCHIP_BROM_HELPER) += bootrom.o save_boot_param.o obj-tpl-$(CONFIG_ROCKCHIP_BROM_HELPER) += bootrom.o save_boot_param.o
obj-tpl-$(CONFIG_ROCKCHIP_RK3188) += rk3188-board-tpl.o +obj-tpl-$(CONFIG_ROCKCHIP_RK3368) += rk3368-board-tpl.o
obj-spl-$(CONFIG_ROCKCHIP_RK3036) += rk3036-board-spl.o obj-spl-$(CONFIG_ROCKCHIP_RK3188) += rk3188-board-spl.o diff --git a/arch/arm/mach-rockchip/rk3368-board-tpl.c b/arch/arm/mach-rockchip/rk3368-board-tpl.c new file mode 100644 index 0000000..376b478 --- /dev/null +++ b/arch/arm/mach-rockchip/rk3368-board-tpl.c @@ -0,0 +1,158 @@ +/* + * (C) Copyright 2017 Theobroma Systems Design und Consulting GmbH + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#define DEBUG + +#include <common.h> +#include <debug_uart.h> +#include <dm.h> +#include <ram.h> +#include <spl.h> +#include <asm/io.h> +#include <asm/arch/bootrom.h> +#include <asm/arch/cru_rk3368.h> +#include <asm/arch/grf_rk3368.h> +#include <asm/arch/hardware.h> +#include <asm/arch/timer.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* + * The ARMv8 generic timer uses the STIMER1 as its clock-source. + * Set up the STIMER1 to free-running (i.e. auto-reload) to start + * the generic timer counting (if we don't do this, udelay will not + * work and block indefinitively). + */ +static void secure_timer_init(void) +{ + struct rk_timer * const stimer1 = + (struct rk_timer * const)0xff830020; + const u32 TIMER_EN = BIT(0); + + writel(~0u, &stimer1->timer_load_count0); + writel(~0u, &stimer1->timer_load_count1); + writel(TIMER_EN, &stimer1->timer_ctrl_reg); +} + +/* + * The SPL (and also the full U-Boot stage on the RK3368) will run in + * secure mode (i.e. EL3) and an ATF will eventually be booted before + * starting up the operating system... so we can initialize the SGRF + * here and rely on the ATF installing the final (secure) policy + * later. + */ +static inline uintptr_t sgrf_soc_con_addr(unsigned no) +{ + const uintptr_t SGRF_BASE = 0xff740000; + + return SGRF_BASE + sizeof(u32) * no; +} + +static inline uintptr_t sgrf_busdmac_addr(unsigned no) +{ + const uintptr_t SGRF_BUSDMAC_BASE = 0xff740100; + + return SGRF_BUSDMAC_BASE + sizeof(u32) * no; +} + +static void sgrf_init(void) +{ + struct rk3368_cru * const cru = + (struct rk3368_cru * const)0xff760000; + const u16 SGRF_SOC_CON_SEC = GENMASK(15, 0); + const u16 SGRF_BUSDMAC_CON0_SEC = BIT(2); + const u16 SGRF_BUSDMAC_CON1_SEC = GENMASK(15, 12); + + /* Set all configurable IP to 'non secure'-mode */ + rk_setreg(sgrf_soc_con_addr(5), SGRF_SOC_CON_SEC); + rk_setreg(sgrf_soc_con_addr(6), SGRF_SOC_CON_SEC); + rk_setreg(sgrf_soc_con_addr(7), SGRF_SOC_CON_SEC); + + /* + * From rockchip-uboot/arch/arm/cpu/armv8/rk33xx/cpu.c + * Original comment: "ddr space set no secure mode" + */ + rk_clrreg(sgrf_soc_con_addr(8), SGRF_SOC_CON_SEC); + rk_clrreg(sgrf_soc_con_addr(9), SGRF_SOC_CON_SEC); + rk_clrreg(sgrf_soc_con_addr(10), SGRF_SOC_CON_SEC); + + /* Set 'secure dma' to 'non secure'-mode */ + rk_setreg(sgrf_busdmac_addr(0), SGRF_BUSDMAC_CON0_SEC); + rk_setreg(sgrf_busdmac_addr(1), SGRF_BUSDMAC_CON1_SEC); + + dsb(); /* barrier */ + + rk_setreg(&cru->softrst_con[1], DMA1_SRST_REQ); + rk_setreg(&cru->softrst_con[4], DMA2_SRST_REQ); + + dsb(); /* barrier */ + udelay(10); + + rk_clrreg(&cru->softrst_con[1], DMA1_SRST_REQ); + rk_clrreg(&cru->softrst_con[4], DMA2_SRST_REQ); +} + +void board_debug_uart_init(void) +{ + struct rk3368_grf * const grf = + (struct rk3368_grf * const)0xff770000; + +#if defined(CONFIG_DEBUG_UART_BASE) && (CONFIG_DEBUG_UART_BASE == 0xff180000) + /* Enable early UART0 on the RK3368 */ + rk_clrsetreg(&grf->gpio2d_iomux, + RK3368_GPIO2D0_MASK, RK3368_GPIO2D0_UART0_SIN); + rk_clrsetreg(&grf->gpio2d_iomux, + RK3368_GPIO2D1_MASK, RK3368_GPIO2D1_UART0_SOUT); +#endif +} + +void board_init_f(ulong dummy) +{ + struct udevice *dev; + int ret; + +#define EARLY_UART +#ifdef EARLY_UART + /* + * Debug UART can be used from here if required: + * + * debug_uart_init(); + * printch('a'); + * printhex8(0x1234); + * printascii("string"); + */ + debug_uart_init(); + printascii("U-Boot TPL board init\n"); +#endif + + ret = spl_early_init(); + if (ret) { + debug("spl_early_init() failed: %d\n", ret); + hang(); + } + + /* Make sure the ARMv8 generic timer counts */ + secure_timer_init(); + /* Reset security, so we can use DMA in the MMC drivers */ + sgrf_init(); + + ret = uclass_get_device(UCLASS_RAM, 0, &dev); + if (ret) { + debug("DRAM init failed: %d\n", ret); + return; + } +} + +void board_return_to_bootrom(void) +{ + back_to_bootrom(); +} + +u32 spl_boot_device(void) +{ + return BOOT_DEVICE_BOOTROM; +} + diff --git a/arch/arm/mach-rockchip/rk3368/u-boot-tpl.lds b/arch/arm/mach-rockchip/rk3368/u-boot-tpl.lds new file mode 100644 index 0000000..cc59844 --- /dev/null +++ b/arch/arm/mach-rockchip/rk3368/u-boot-tpl.lds @@ -0,0 +1,13 @@ +/* + * (C) Copyright 2017 Theobroma Systems Design und Consulting GmbH + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#undef CONFIG_SPL_TEXT_BASE +#define CONFIG_SPL_TEXT_BASE CONFIG_TPL_TEXT_BASE + +#undef CONFIG_SPL_MAX_SIZE +#define CONFIG_SPL_MAX_SIZE CONFIG_TPL_MAX_SIZE + +#include "../../cpu/armv8/u-boot-spl.lds"
Adds SPL support for the RK3368 (assuming that our TPL stage has initialised DRAM and set up the memory firewall).
This includes an implementation of board_debug_uart_init().
arch/arm/mach-rockchip/rk3368-board-spl.c | 91 +++++++++++++++++++++++++++++++ 1 file changed, 91 insertions(+) create mode 100644 arch/arm/mach-rockchip/rk3368-board-spl.c
diff --git a/arch/arm/mach-rockchip/rk3368-board-spl.c b/arch/arm/mach-rockchip/rk3368-board-spl.c new file mode 100644 index 0000000..eefe3bf --- /dev/null +++ b/arch/arm/mach-rockchip/rk3368-board-spl.c @@ -0,0 +1,91 @@ +/* + * (C) Copyright 2017 Theobroma Systems Design und Consulting GmbH + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <debug_uart.h> +#include <dm.h> +#include <ram.h> +#include <spl.h> +#include <asm/io.h> +#include <asm/arch/bootrom.h> +#include <asm/arch/cru_rk3368.h> +#include <asm/arch/grf_rk3368.h> +#include <asm/arch/hardware.h> +#include <asm/arch/timer.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* + * The ARMv8 generic timer uses the STIMER1 as its clock-source. + * Set up the STIMER1 to free-running (i.e. auto-reload) to start + * the generic timer counting (if we don't do this, udelay will not + * work and block indefinitively). + */ +static void secure_timer_init(void) +{ + struct rk_timer * const stimer1 = + (struct rk_timer * const)0xff830020; + const u32 TIMER_EN = BIT(0); + + writel(~0u, &stimer1->timer_load_count0); + writel(~0u, &stimer1->timer_load_count1); + writel(TIMER_EN, &stimer1->timer_ctrl_reg); +} + +void board_debug_uart_init(void) +{ + struct rk3368_grf * const grf = + (struct rk3368_grf * const)0xff770000; + +#if defined(CONFIG_DEBUG_UART_BASE) && (CONFIG_DEBUG_UART_BASE == 0xff180000) + /* Enable early UART0 on the RK3368 */ + rk_clrsetreg(&grf->gpio2d_iomux, + RK3368_GPIO2D0_MASK, RK3368_GPIO2D0_UART0_SIN); + rk_clrsetreg(&grf->gpio2d_iomux, + RK3368_GPIO2D1_MASK, RK3368_GPIO2D1_UART0_SOUT); +#endif +} + +void board_init_f(ulong dummy) +{ + struct udevice *dev; + int ret; + + ret = spl_early_init(); + if (ret) { + debug("spl_early_init() failed: %d\n", ret); + hang(); + } + + /* Make sure the ARMv8 generic timer counts */ + secure_timer_init(); + + ret = uclass_get_device(UCLASS_RAM, 0, &dev); + if (ret) { + debug("DRAM init failed: %d\n", ret); + return; + } +} + +u32 spl_boot_mode(const u32 boot_device) +{ + return MMCSD_MODE_RAW; +} + +u32 spl_boot_device(void) +{ + return BOOT_DEVICE_MMC1; +} + +#ifdef CONFIG_SPL_LOAD_FIT +int board_fit_config_name_match(const char *name) +{ + /* Just empty function now - can't decide what to choose */ + debug("%s: %s\n", __func__, name); + + return 0; +} +#endif
With SPL and TPL support for the RK3368 in place, mark SPL and TPL as supported from Kconfig for the RK3368. As this is primarily tested on the RK3368-uQ7, we'll leave it to board's individual defconfig to enable.
Also enable DEBUG_UART_BOARD_INIT for the RK3368, so we get output during the early boot-up, as we turn on TPL and SPL.
arch/arm/mach-rockchip/Kconfig | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/arch/arm/mach-rockchip/Kconfig b/arch/arm/mach-rockchip/Kconfig index 2ad4943..fd08897 100644 --- a/arch/arm/mach-rockchip/Kconfig +++ b/arch/arm/mach-rockchip/Kconfig @@ -67,6 +67,13 @@ config ROCKCHIP_RK3328 config ROCKCHIP_RK3368 bool "Support Rockchip RK3368" select ARM64 + select SUPPORT_SPL + select SUPPORT_TPL + select SPL_SEPARATE_BSS + select SPL_SERIAL_SUPPORT + select TPL_SERIAL_SUPPORT + select ENABLE_ARM_SOC_BOOT0_HOOK + select DEBUG_UART_BOARD_INIT select SYS_NS16550 help The Rockchip RK3368 is a ARM-based SoC with a octa-core (organised
The RK3368-uQ7 (codenamed 'Lion') is a micro-Qseven (40mm x 70mm, MXM-230 edge connector compatible with the Qseven specification) form-factor system-on-module based on the octo-core Rockchip RK3368. It is designed, supported and manufactured by Theobroma Systems.
It provides the following features: - 8x Cortex-A53 (in 2 clusters of 4 cores each) - (on-module) up to 4GB of DDR3 memory - (on-module) SPI-NOR flash - (on-module) eMMC - Gigabit Ethernet (with an on-module KSZ9031 PHY) - USB - HDMI - MIPI-DSI/single-channel LVDS (muxed on the 'LVDS-A' pin-group) - various 'slow' interfaces (e.g. UART, SPI, I2C, I2S, ...)
arch/arm/dts/Makefile | 1 + arch/arm/dts/rk3368-lion.dts | 209 +++++++++++++++++++++ arch/arm/mach-rockchip/rk3368/Kconfig | 21 +++ board/theobroma-systems/lion_rk3368/Kconfig | 15 ++ board/theobroma-systems/lion_rk3368/MAINTAINERS | 10 + board/theobroma-systems/lion_rk3368/Makefile | 7 + board/theobroma-systems/lion_rk3368/README | 60 ++++++ .../theobroma-systems/lion_rk3368/fit_spl_atf.its | 51 +++++ board/theobroma-systems/lion_rk3368/lion_rk3368.c | 25 +++ configs/lion-rk3368_defconfig | 79 ++++++++ include/configs/lion_rk3368.h | 19 ++ 11 files changed, 497 insertions(+) create mode 100644 arch/arm/dts/rk3368-lion.dts create mode 100644 board/theobroma-systems/lion_rk3368/Kconfig create mode 100644 board/theobroma-systems/lion_rk3368/MAINTAINERS create mode 100644 board/theobroma-systems/lion_rk3368/Makefile create mode 100644 board/theobroma-systems/lion_rk3368/README create mode 100644 board/theobroma-systems/lion_rk3368/fit_spl_atf.its create mode 100644 board/theobroma-systems/lion_rk3368/lion_rk3368.c create mode 100644 configs/lion-rk3368_defconfig create mode 100644 include/configs/lion_rk3368.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index fd28290..5a22bb1 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -42,6 +42,7 @@ dtb-$(CONFIG_ARCH_ROCKCHIP) += \ rk3288-veyron-mickey.dtb \ rk3288-veyron-minnie.dtb \ rk3328-evb.dtb \ + rk3368-lion.dtb \ rk3368-sheep.dtb \ rk3368-geekbox.dtb \ rk3368-px5-evb.dtb \ diff --git a/arch/arm/dts/rk3368-lion.dts b/arch/arm/dts/rk3368-lion.dts new file mode 100644 index 0000000..be5e3c9 --- /dev/null +++ b/arch/arm/dts/rk3368-lion.dts @@ -0,0 +1,209 @@ +/* + * (C) Copyright 2017 Theobroma Systems Design und Consulting GmbH + * + * SPDX-License-Identifier: GPL-2.0+ X11 + */ + +/dts-v1/; +#include "rk3368.dtsi" +#include <dt-bindings/input/input.h> + +/ { + model = "Theobroma Systems RK3368-uQ7 SoM"; + compatible = "tsd,rk3368-uq7", "tsd,lion", "rockchip,rk3368"; + + config { + u-boot,spl-payload-offset = <0x40000>; /* @ 256KB */ + u-boot,mmc-env-offset = <0x4000>; /* @ 16KB */ + }; + + chosen { + stdout-path = "serial0:115200n8"; + u-boot,spl-boot-order = &emmc, &sdmmc; + }; + + aliases { + mmc0 = &emmc; + mmc1 = &sdmmc; + }; + + memory@0 { + device_type = "memory"; + reg = <0x0 0x0 0x0 0x80000000>; + }; + + ext_gmac: gmac-clk { + compatible = "fixed-clock"; + clock-frequency = <125000000>; + clock-output-names = "ext_gmac"; + #clock-cells = <0>; + }; + + vcc_sys: vcc-sys-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc_sys"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + regulator-boot-on; + }; +}; + +&dmc { +/* + * possible settings for rockchip,memory-schedule + * DMC_MSCH_CBDR column -> bank -> device -> row + * DMC_MSCH_CBRD column -> bank -> row -> device + * DMC_MSCH_CRBD column -> row -> bank -> device + */ + rockchip,memory-schedule = <DMC_MSCH_CBDR>; + rockchip,ddr-frequency = <800000000>; + rockchip,ddr-speed-bin = <DDR3_1600K>; + + status = "okay"; +}; + +&uart0 { + status = "okay"; +}; + +&emmc { + u-boot,dm-pre-reloc; + status = "okay"; + bus-width = <8>; + cap-mmc-highspeed; + clock-frequency = <150000000>; + disable-wp; + keep-power-in-suspend; + non-removable; + num-slots = <1>; + vmmc-supply = <&vcc33_io>; + vqmmc-supply = <&vcc18_io>; + pinctrl-names = "default"; + pinctrl-0 = <&emmc_clk>, <&emmc_cmd>, <&emmc_bus8>; +}; + +&sdmmc { + u-boot,dm-pre-reloc; + status = "okay"; +}; + +&gmac { + status = "okay"; + phy-supply = <&vcc33_io>; + phy-mode = "rgmii"; + clock_in_out = "input"; + snps,reset-gpio = <&gpio3 11 GPIO_ACTIVE_LOW>; + snps,reset-active-low; + snps,reset-delays-us = <2 10000 50000>; + assigned-clocks = <&cru SCLK_MAC>; + assigned-clock-parents = <&ext_gmac>; + pinctrl-names = "default"; + pinctrl-0 = <&rgmii_pins>; + tx_delay = <0x10>; + rx_delay = <0x10>; +}; + +&i2c0 { + status = "okay"; + + rk808: pmic@1b { + compatible = "rockchip,rk808"; + reg = <0x1b>; + interrupt-parent = <&gpio0>; + interrupts = <5 IRQ_TYPE_LEVEL_LOW>; + rockchip,system-power-controller; + vcc1-supply = <&vcc_sys>; + vcc2-supply = <&vcc_sys>; + vcc3-supply = <&vcc_sys>; + vcc4-supply = <&vcc_sys>; + vcc6-supply = <&vcc_sys>; + vcc7-supply = <&vcc_sys>; + vcc8-supply = <&vcc_sys>; + vcc9-supply = <&vcc_sys>; + vcc10-supply = <&vcc_sys>; + vcc11-supply = <&vcc_sys>; + vcc12-supply = <&vcc_sys>; + clock-output-names = "xin32k", "rk808-clkout2"; + #clock-cells = <1>; + + regulators { + vdd_cpu: DCDC_REG1 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1500000>; + regulator-name = "vdd_cpu"; + }; + + vdd_log: DCDC_REG2 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <700000>; + regulator-max-microvolt = <1500000>; + regulator-name = "vdd_log"; + }; + + vcc_ddr: DCDC_REG3 { + regulator-always-on; + regulator-boot-on; + regulator-name = "vcc_ddr"; + }; + + vcc33_io: DCDC_REG4 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc33_io"; + }; + + vcc33_video: LDO_REG2 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc33_video"; + }; + + vdd10_pll: LDO_REG3 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1000000>; + regulator-name = "vdd10_pll"; + }; + + vcc18_io: LDO_REG4 { + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcc18_io"; + }; + + vdd10_video: LDO_REG6 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1000000>; + regulator-name = "vdd10_video"; + }; + + vcc18_video: LDO_REG8 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcc18_video"; + }; + }; + }; +}; + +&pinctrl { +}; + +&uart0 { + status = "okay"; +}; + diff --git a/arch/arm/mach-rockchip/rk3368/Kconfig b/arch/arm/mach-rockchip/rk3368/Kconfig index 6d32068..f8189f1 100644 --- a/arch/arm/mach-rockchip/rk3368/Kconfig +++ b/arch/arm/mach-rockchip/rk3368/Kconfig @@ -3,6 +3,26 @@ if ROCKCHIP_RK3368 choice prompt "RK3368 board"
+config TARGET_LION_RK3368 + bool "Theobroma Systems RK3368-uQ7 (Lion) module" + help + The RK3368-uQ7 is a micro-Qseven form-factor (40mm x 70mm, + MXM-230 connector) system-on-module designed by Theobroma + Systems for industrial applications. + + It provides the following features: + - 8x Cortex-A53 (in 2 clusters of 4 cores each) + - (on-module) up to 4GB of DDR3 memory + - (on-module) SPI-NOR flash + - (on-module) eMMC + - Gigabit Ethernet (with an on-module KSZ9031 PHY) + - USB + - HDMI + - MIPI-DSI/single-channel LVDS (muxed on the 'LVDS-A' pin-group) + - various 'slow' interfaces (e.g. UART, SPI, I2C, I2S, ...) + - on-module STM32 providing CAN, RTC and fan-control + - (optional on-module) EAL4+-certified security module + config TARGET_SHEEP bool "Sheep board" help @@ -25,6 +45,7 @@ endchoice config SYS_SOC default "rockchip"
+source "board/theobroma-systems/lion_rk3368/Kconfig" source "board/rockchip/sheep_rk3368/Kconfig" source "board/geekbuying/geekbox/Kconfig" source "board/rockchip/evb_px5/Kconfig" diff --git a/board/theobroma-systems/lion_rk3368/Kconfig b/board/theobroma-systems/lion_rk3368/Kconfig new file mode 100644 index 0000000..d7aa487 --- /dev/null +++ b/board/theobroma-systems/lion_rk3368/Kconfig @@ -0,0 +1,15 @@ +if TARGET_LION_RK3368 + +config SYS_BOARD + default "lion_rk3368" + +config SYS_VENDOR + default "theobroma-systems" + +config SYS_CONFIG_NAME + default "lion_rk3368" + +config BOARD_SPECIFIC_OPTIONS # dummy + def_bool y + +endif diff --git a/board/theobroma-systems/lion_rk3368/MAINTAINERS b/board/theobroma-systems/lion_rk3368/MAINTAINERS new file mode 100644 index 0000000..857f784 --- /dev/null +++ b/board/theobroma-systems/lion_rk3368/MAINTAINERS @@ -0,0 +1,10 @@ +LION-RK3368 (RK3368-uQ7 system-on-module) +M: Philipp Tomsich philipp.tomsich@theobroma-systems.com +M: Klaus Goger klaus.goger@theobroma-systems.com +S: Maintained +F: board/theobroma-systems/lion_rk3368 +F: include/configs/lion_rk3368.h +F: arch/arm/dts/rk3368-lion.dts +F: configs/lion-rk3368_defconfig +W: https://www.theobroma-systems.com/rk3368-uq7/tech-specs +T: git git://git.theobroma-systems.com/lion-u-boot.git diff --git a/board/theobroma-systems/lion_rk3368/Makefile b/board/theobroma-systems/lion_rk3368/Makefile new file mode 100644 index 0000000..f13a20b --- /dev/null +++ b/board/theobroma-systems/lion_rk3368/Makefile @@ -0,0 +1,7 @@ +# +# Copyright (c) 2017 Theobroma Systems Design und Consulting GmbH +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += lion_rk3368.o diff --git a/board/theobroma-systems/lion_rk3368/README b/board/theobroma-systems/lion_rk3368/README new file mode 100644 index 0000000..47304fc --- /dev/null +++ b/board/theobroma-systems/lion_rk3368/README @@ -0,0 +1,60 @@ +Here is the step-by-step to boot to U-Boot on RK3368-uQ7 + +Get the Source and build ATF +============================ + + > git clone git://git.theobroma-systems.com/arm-trusted-firmware.git + > cd arm-trusted-firmware + > make CROSS_COMPILE=aarch64-linux-gnu- PLAT=rk3368 bl31 + > cp build/rk3368/release/bl31.bin ../u-boot/bl31-rk3368.bin + +Configure U-Boot +================ + + > cd ../u-boot + > make lion-rk3368_defconfig + +Build the TPL/SPL stage +======================= + + > make CROSS_COMPILE=aarch64-unknown-elf- ARCH=arm + > tools/mkimage -n rk3368 -T rksd -d tpl/u-boot-tpl.bin spl-3368.img + > cat spl/u-boot-spl-dtb.bin >> spl-3368.img + +Build the full U-Boot and a FIT image including the ATF +======================================================= + + > make CROSS_COMPILE=aarch64-unknown-elf- ARCH=arm u-boot.itb + +Write to a SD-card +================== + + > dd if=spl-3368.img of=/dev/sdb seek=64 + > dd if=u-boot.itb of=/dev/sdb seek=512 + + +If everything went according to plan, you should see the following +output on UART0: + +<debug_uart> U-Boot TPL board init +Trying to boot from BOOTROM +Returning to boot ROM... +Trying to boot from MMC1 +NOTICE: BL31: v1.3(release):v1.2-1320-gbf43a443 +NOTICE: BL31: Built : 18:04:47, Jul 5 2017 + + +U-Boot 2017.07-00158-g2395e99858 (Jul 18 2017 - 21:03:31 +0200) + +Model: Theobroma Systems RK3368-uQ7 SoM +DRAM: 2 GiB +MMC: dwmmc@ff0c0000: 1, dwmmc@ff0f0000: 0 +Using default environment + +In: serial@ff180000 +Out: serial@ff180000 +Err: serial@ff180000 +Net: +Warning: ethernet@ff290000 (eth0) using random MAC address - d2:69:35:7e:d0:1e +eth0: ethernet@ff290000 +Hit any key to stop autoboot: 2 diff --git a/board/theobroma-systems/lion_rk3368/fit_spl_atf.its b/board/theobroma-systems/lion_rk3368/fit_spl_atf.its new file mode 100644 index 0000000..e7d98b9 --- /dev/null +++ b/board/theobroma-systems/lion_rk3368/fit_spl_atf.its @@ -0,0 +1,51 @@ +/* + * Copyright (C) 2017 Theobroma Systems Design und Consulting GmbH + * + * Minimal dts for a SPL FIT image payload. + * + * SPDX-License-Identifier: GPL-2.0+ X11 + */ + +/dts-v1/; + +/ { + description = "FIT image with U-Boot proper, ATF bl31, DTB"; + #address-cells = <1>; + + images { + uboot { + description = "U-Boot (64-bit)"; + data = /incbin/("../../../u-boot-nodtb.bin"); + type = "standalone"; + arch = "arm64"; + compression = "none"; + load = <0x00200000>; + }; + atf { + description = "ARM Trusted Firmware"; + data = /incbin/("../../../bl31-rk3368.bin"); + type = "firmware"; + arch = "arm64"; + compression = "none"; + load = <0x00010000>; + entry = <0x00010000>; + }; + + fdt { + description = "RK3368-uQ7 (Lion) flat device-tree"; + data = /incbin/("../../../u-boot.dtb"); + type = "flat_dt"; + compression = "none"; + }; + }; + + configurations { + default = "conf"; + conf { + description = "Theobroma Systems RK3368-uQ7 (Puma) SoM"; + firmware = "uboot"; + loadables = "atf"; + fdt = "fdt"; + }; + }; +}; diff --git a/board/theobroma-systems/lion_rk3368/lion_rk3368.c b/board/theobroma-systems/lion_rk3368/lion_rk3368.c new file mode 100644 index 0000000..73b1488 --- /dev/null +++ b/board/theobroma-systems/lion_rk3368/lion_rk3368.c @@ -0,0 +1,25 @@ +/* + * Copyright (c) 2017 Theobroma Systems Design und Consulting GmbH + * + * SPDX-License-Identifier: GPL-2.0+ + */ +#include <common.h> +#include <dm.h> +#include <ram.h> +#include <asm/io.h> +#include <asm/arch/clock.h> +#include <asm/arch/grf_rk3368.h> +#include <asm/arch/timer.h> +#include <syscon.h> + +DECLARE_GLOBAL_DATA_PTR; + +int mach_cpu_init(void) +{ + return 0; +} + +int board_init(void) +{ + return 0; +} diff --git a/configs/lion-rk3368_defconfig b/configs/lion-rk3368_defconfig new file mode 100644 index 0000000..203e4f8 --- /dev/null +++ b/configs/lion-rk3368_defconfig @@ -0,0 +1,79 @@ +CONFIG_ARM=y +CONFIG_ARCH_ROCKCHIP=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_ROCKCHIP_RK3368=y +CONFIG_ROCKCHIP_SPL_RESERVE_IRAM=0x0 +CONFIG_TPL_LIBCOMMON_SUPPORT=y +CONFIG_TPL_LIBGENERIC_SUPPORT=y +CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_SPL_STACK_R_ADDR=0x600000 +CONFIG_DEFAULT_DEVICE_TREE="rk3368-lion" +CONFIG_SMBIOS_PRODUCT_NAME="sheep_rk3368" +CONFIG_DEBUG_UART=y +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_SPL_FIT_SOURCE="board/theobroma-systems/lion_rk3368/fit_spl_atf.its" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_ARCH_EARLY_INIT_R=y +CONFIG_SPL=y +CONFIG_SPL_BOOTROM_SUPPORT=y +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +# CONFIG_SPL_LEGACY_IMAGE_SUPPORT is not set +CONFIG_TPL_SYS_MALLOC_SIMPLE=y +CONFIG_SPL_STACK_R=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x200 +CONFIG_SPL_ATF_SUPPORT=y +CONFIG_SPL_ATF_TEXT_BASE=0x10000 +CONFIG_TPL=y +CONFIG_TPL_BOOTROM_SUPPORT=y +CONFIG_TPL_DRIVERS_MISC_SUPPORT=y +CONFIG_FASTBOOT=y +CONFIG_ANDROID_BOOT_IMAGE=y +# CONFIG_CMD_IMLS is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_REGULATOR=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_TPL_OF_CONTROL=y +CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names interrupt-parent" +CONFIG_TPL_OF_PLATDATA=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_TPL_DM=y +CONFIG_REGMAP=y +CONFIG_SPL_REGMAP=y +CONFIG_TPL_REGMAP=y +CONFIG_SYSCON=y +CONFIG_SPL_SYSCON=y +CONFIG_TPL_SYSCON=y +CONFIG_CLK=y +CONFIG_SPL_CLK=y +CONFIG_TPL_CLK=y +CONFIG_ROCKCHIP_GPIO=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_PHY_MICREL=y +CONFIG_PHY_MICREL_KSZ9031=y +CONFIG_DM_ETH=y +CONFIG_ETH_DESIGNWARE=y +CONFIG_RGMII=y +CONFIG_GMAC_ROCKCHIP=y +CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y +CONFIG_PINCTRL_ROCKCHIP_RK3368=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_RAM=y +CONFIG_SPL_RAM=y +CONFIG_TPL_RAM=y +CONFIG_DEBUG_UART_BASE=0xFF180000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_DEBUG_UART_ANNOUNCE=y +CONFIG_DEBUG_UART_SKIP_INIT=y +CONFIG_SYSRESET=y +CONFIG_USE_TINY_PRINTF=y +CONFIG_SPL_TINY_MEMSET=y +CONFIG_ERRNO_STR=y +CONFIG_SMBIOS_MANUFACTURER="rockchip" diff --git a/include/configs/lion_rk3368.h b/include/configs/lion_rk3368.h new file mode 100644 index 0000000..1f25b31 --- /dev/null +++ b/include/configs/lion_rk3368.h @@ -0,0 +1,19 @@ +/* + * Copyright (c) 2017 Theobroma Systems Design und Consulting GmbH + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __CONFIGS_LION_RK3368_H +#define __CONFIGS_LION_RK3368_H + +#include <configs/rk3368_common.h> + +#define CONFIG_SYS_MMC_ENV_DEV 0 +#define KERNEL_LOAD_ADDR 0x280000 +#define DTB_LOAD_ADDR 0x5600000 +#define INITRD_LOAD_ADDR 0x5bf0000 +#define CONFIG_ENV_IS_NOWHERE +#define CONFIG_ENV_SIZE 0x2000 + +#endif
The ITS file generated warnings due to @<num> designations in the naming which cause DTC to complain as follows: Warning (unit_address_vs_reg): Node /images/uboot@1 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /images/atf@1 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /images/pmu@1 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /images/fdt@1 has a unit name, but no reg property Warning (unit_address_vs_reg): Node /configurations/conf@1 has a unit name, but no reg property
This removes the @<num> part from the names, as we only have a single image for each payload aspect (and only a single configuration) anyway.
board/theobroma-systems/puma_rk3399/fit_spl_atf.its | 18 +++++++++--------- 1 file changed, 9 insertions(+), 9 deletions(-)
diff --git a/board/theobroma-systems/puma_rk3399/fit_spl_atf.its b/board/theobroma-systems/puma_rk3399/fit_spl_atf.its index f93c251..0519fad 100644 --- a/board/theobroma-systems/puma_rk3399/fit_spl_atf.its +++ b/board/theobroma-systems/puma_rk3399/fit_spl_atf.its @@ -13,7 +13,7 @@ #address-cells = <1>;
images { - uboot@1 { + uboot { description = "U-Boot (64-bit)"; data = /incbin/("../../../u-boot-nodtb.bin"); type = "standalone"; @@ -21,7 +21,7 @@ compression = "none"; load = <0x00200000>; }; - atf@1 { + atf { description = "ARM Trusted Firmware"; data = /incbin/("../../../bl31.bin"); type = "firmware"; @@ -30,14 +30,14 @@ load = <0x00001000>; entry = <0x00001000>; }; - pmu@1 { + pmu { description = "Cortex-M0 firmware"; data = /incbin/("../../../rk3399m0.bin"); type = "pmu-firmware"; compression = "none"; load = <0xff8c0000>; }; - fdt@1 { + fdt { description = "RK3399-Q7 (Puma) flat device-tree"; data = /incbin/("../../../u-boot.dtb"); type = "flat_dt"; @@ -46,12 +46,12 @@ };
configurations { - default = "conf@1"; - conf@1 { + default = "conf"; + conf { description = "Theobroma Systems RK3399-Q7 (Puma) SoM"; - firmware = "uboot@1"; - loadables = "atf@1"; - fdt = "fdt@1"; + firmware = "uboot"; + loadables = "atf"; + fdt = "fdt"; }; }; };
From: Klaus Goger klaus.goger@theobroma-systems.com
Prefix the bl31 firmware needed to build uboot.itb so it can coexist in the build area with ATFs from other boards (i.e. lion_rk3368).
Signed-off-by: Klaus Goger klaus.goger@theobroma-systems.com Signed-off-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com ---
board/theobroma-systems/puma_rk3399/README | 2 +- board/theobroma-systems/puma_rk3399/fit_spl_atf.its | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/board/theobroma-systems/puma_rk3399/README b/board/theobroma-systems/puma_rk3399/README index 250e345..214281a 100644 --- a/board/theobroma-systems/puma_rk3399/README +++ b/board/theobroma-systems/puma_rk3399/README @@ -37,7 +37,7 @@ Compile the ATF
cd arm-trusted-firmware make CROSS_COMPILE=aarch64-linux-gnu- PLAT=rk3399 bl31
- > cp build/rk3399/release/bl31.bin ../u-boot + > cp build/rk3399/release/bl31.bin ../u-boot/bl31-rk3399.bin
Compile the M0 firmware ======================= diff --git a/board/theobroma-systems/puma_rk3399/fit_spl_atf.its b/board/theobroma-systems/puma_rk3399/fit_spl_atf.its index 0519fad..520f846 100644 --- a/board/theobroma-systems/puma_rk3399/fit_spl_atf.its +++ b/board/theobroma-systems/puma_rk3399/fit_spl_atf.its @@ -23,7 +23,7 @@ }; atf { description = "ARM Trusted Firmware"; - data = /incbin/("../../../bl31.bin"); + data = /incbin/("../../../bl31-rk3399.bin"); type = "firmware"; arch = "arm64"; compression = "none";
Hi:
On 2017年07月19日 04:35, Philipp Tomsich wrote:
Here's a series that has a lot going on, but I didn't want to split it to allow everyone to understand the motivation between some of the changes to the SPL/TPL framework. The short summary of this is "enablement for DRAM init on the RK3368 with everything else that's necessary to do it using OF_PLATDATA in TPL".
Enabling the RK3368 created a few more challenges that I'd expected:
- I needed different stack locations, text addresses and sizes for TPL and SPL
- the TPL stage was to use OF_PLATDATA and SPL was to use full OF_CONTROL
- with the RK3368 TPL stage, there was a need to extend the back-to-bootrom support for Rockchip to AArch64
- I wanted to start folding some of the Rockchip specific SPL support (i.e. back-to-bootrom) back into the general SPL framework to allow using it as a general boot method
I have a confusion here: according to the README.TPL, TPL is Third Program Loader, which loaded by the SPL. So I think it should run after the SPL. But from RK3188 and RK3368 TPL implementation , they all run before SPL.Maybe it is my misunderstanding, hope to get some guidance.:-)
So I ended up separating quite a bit of features between SPL and TPL while keeping things transparent to the few other boards using TPL (at least I hope that things are transparent, as we didn't have any of those in our lab to test on)...
Tested with: RK3368-uQ7, Debian 9, Linux 4.13-rc1.
Just one final remark: the DMC driver for the RK3368 currently covers the configuration we use on the RK3368-uQ7 (i.e. 32bit wide, 2 ranks) and is stress-tested (including 8-way SPEC runs) at all 3 supported speeds. I've built a bit of infrastructure (e.g. the way the memory-schedule is determined) that I hope will be a useful starting-point in unifying the drivers for the various closely related DRAM controllers (e.g. for the RK3288) for Rockchip devices in the future.
Klaus Goger (1): rockchip: board: puma_rk3399: rename ATF firmware
Philipp Tomsich (51): spl: add a 'return to bootrom' boot method spl: configure 'return to bootrom' separately for SPL and TPL rockchip: back-to-bootrom: add 'back-to-bootrom' support for AArch64 rockchip: back-to-bootrom: split BACK_TO_BOOTROM for TPL/SPL rockchip: back-to-bootrom: simplify the #ifdef-check for LIBGENERIC in TPL/SPL spl: dm: Kconfig: use more specific prereqs for SPL_REGMAP and SPL_SYSCON spl: dm: Kconfig: split REGMAP/SYSCON support for TPL from SPL spl: dm: Kconfig: SPL_RAM depends on SPL_DM spl: dm: Kconfig: introduce TPL_RAM (in analogy to SPL_RAM) spl: dm: Kconfig: SPL_CLK depens on SPL_DM spl: dm: Kconfig: split CLK support for SPL and TPL spl: dm: Kconfig: split OF_CONTROL and OF_PLATDATA between SPL and TPL spl: dm: use CONFIG_IS_ENABLED to test for the DM option armv8: remove unused low-level modules from TPL armv8: spl: Support separate stack for TPL spl: allow a separate TEXT_BASE, LDSCRIPT and MAX_SIZE for TPL spl: Kconfig: split SYS_MALLOC_SIMPLE for TPL and SPL lib: spl: differentiate between TPL and SPL for libfdt/of_control/of_platdata spl: consistently use $(SPL_TPL_) to select features for SPL and TPL builds spl: add TPL_DRIVER_MISC_SUPPORT option drivers: spl: consistently use the $(SPL_TPL_) macro rockchip: Makefile: allow selective inclusion of sdram_common.o from TPL/SPL/U-Boot rockchip: rk3368: improve Kconfig text for the RK3368 rockchip: rk3368: mkimage: add support for the RK3368 rockchip: rk3368: pmugrf: add definitions for os_reg[0..3] rockchip: rk3368: define CONFIG_SYS_SDRAM_BASE rockchip: rk3368: spl: define COUNTER_FREQUENCY to 24MHz rockchip: rk3368: spl: add memory layout for TPL and SPL rockchip: rk3368: syscon: MSCH/PMUGRF/GRF support for OF_PLATDATA rockchip: rk3368: grf: use shifted-constants and prefix with RK3368_ rockchip: pinctrl: rk3368: add GMAC (RGMII only) support rockchip: pinctrl: rk3368: add support for configuring the MMC pins rockchip: clk: rk3368: implement bandwidth adjust for PLLs rockchip: clk: rk3368: support OF_PLATDATA for the RK3368 clk driver rockchip: clk: rk3368: do not change CPLL/GPLL before returning to BROM rockchip: clk: rk3368: implement DPLL (DRAM PLL) support rockchip: clk: rk3368: define DMA1_SRST_REQ and DMA2_SRST_REQ rockchip: clk: rk3368: implement MMC/SD clock reparenting rockchip: clk: rk3368: support configuring the DRAM PLL (from TPL) rockchip: clk: rk3368: add support for GMAC (SLCK_MAC) clock rockchip: clk: rk3368: mark 'priv' __maybe_unused in rk3368_clk_set_rate() net: gmac_rockchip: Add support for the RK3368 GMAC rockchip: Makefile: streamline SPL/TPL configuration rockchip: rk3368: add DRAM controller driver with DRAM initialisation rockchip: dts: rk3368: add DMC node in rk3368.dtsi rockchip: rk3368: spl: enable SPL_FRAMEWORK in rk3368_common.h rockchip: rk3368: spl: add TPL support rockchip: rk3368: spl: add SPL support rockchip: rk3368: spl: mark SPL and TPL as supported for ROCKCHIP_RK3368 rockchip: board: lion-rk3368: add support for the RK3368-uQ7 rockchip: board: puma-rk3399: fix warnings in puma_rk3399/fit_spl_atf.its
Makefile | 2 +- arch/arm/cpu/armv8/Makefile | 4 +- arch/arm/dts/Makefile | 1 + arch/arm/dts/rk3368-lion.dts | 209 +++++ arch/arm/dts/rk3368.dtsi | 26 +- arch/arm/include/asm/arch-rockchip/cru_rk3368.h | 15 +- arch/arm/include/asm/arch-rockchip/ddr_rk3368.h | 187 ++++ arch/arm/include/asm/arch-rockchip/grf_rk3368.h | 615 +++++++------ arch/arm/include/asm/spl.h | 1 + arch/arm/lib/crt0_64.S | 4 +- arch/arm/mach-rockchip/Kconfig | 37 +- arch/arm/mach-rockchip/Makefile | 51 +- arch/arm/mach-rockchip/bootrom.c | 4 +- arch/arm/mach-rockchip/rk3188-board-spl.c | 5 +- arch/arm/mach-rockchip/rk3188-board.c | 2 +- arch/arm/mach-rockchip/rk3288-board-spl.c | 4 +- arch/arm/mach-rockchip/rk3288-board.c | 4 +- arch/arm/mach-rockchip/rk3368-board-spl.c | 91 ++ arch/arm/mach-rockchip/rk3368-board-tpl.c | 158 ++++ arch/arm/mach-rockchip/rk3368/Kconfig | 21 + arch/arm/mach-rockchip/rk3368/Makefile | 1 - arch/arm/mach-rockchip/rk3368/sdram_rk3368.c | 60 -- arch/arm/mach-rockchip/rk3368/syscon_rk3368.c | 35 + arch/arm/mach-rockchip/rk3368/u-boot-tpl.lds | 13 + arch/arm/mach-rockchip/rk3399-board-spl.c | 4 +- arch/arm/mach-rockchip/save_boot_param.S | 37 + board/theobroma-systems/lion_rk3368/Kconfig | 15 + board/theobroma-systems/lion_rk3368/MAINTAINERS | 10 + board/theobroma-systems/lion_rk3368/Makefile | 7 + board/theobroma-systems/lion_rk3368/README | 60 ++ .../theobroma-systems/lion_rk3368/fit_spl_atf.its | 51 ++ board/theobroma-systems/lion_rk3368/lion_rk3368.c | 25 + board/theobroma-systems/puma_rk3399/README | 2 +- .../theobroma-systems/puma_rk3399/fit_spl_atf.its | 20 +- common/Makefile | 8 +- common/spl/Kconfig | 39 + common/spl/Makefile | 35 +- common/spl/spl.c | 5 +- common/spl/spl_bootrom.c | 27 + configs/evb-rk3288_defconfig | 2 +- configs/fennec-rk3288_defconfig | 2 +- configs/firefly-rk3288_defconfig | 2 +- configs/lion-rk3368_defconfig | 79 ++ configs/miqi-rk3288_defconfig | 2 +- configs/popmetal-rk3288_defconfig | 2 +- configs/rock2_defconfig | 2 +- configs/rock_defconfig | 2 +- configs/tinker-rk3288_defconfig | 2 +- doc/README.rockchip | 2 +- .../clock/rockchip,rk3368-dmc.txt | 67 ++ drivers/Makefile | 36 +- drivers/clk/Kconfig | 12 +- drivers/clk/Makefile | 2 +- drivers/clk/rockchip/clk_rk3368.c | 222 ++++- drivers/core/Kconfig | 23 +- drivers/core/Makefile | 4 +- drivers/net/gmac_rockchip.c | 54 ++ drivers/pinctrl/rockchip/pinctrl_rk3368.c | 101 ++- drivers/ram/Kconfig | 11 +- drivers/ram/Makefile | 2 + drivers/ram/rockchip/Makefile | 7 + drivers/ram/rockchip/dmc-rk3368.c | 990 +++++++++++++++++++++ dts/Kconfig | 29 + include/configs/lion_rk3368.h | 19 + include/configs/rk3188_common.h | 2 +- include/configs/rk3288_common.h | 2 +- include/configs/rk3368_common.h | 15 + include/configs/rock.h | 2 +- include/configs/rockchip-common.h | 2 +- include/dt-bindings/memory/rk3368-dmc.h | 30 + include/linux/kconfig.h | 13 + include/spl.h | 10 + lib/Makefile | 10 +- scripts/Makefile.spl | 14 +- scripts/config_whitelist.txt | 4 + tools/rkcommon.c | 1 + 76 files changed, 3142 insertions(+), 534 deletions(-) create mode 100644 arch/arm/dts/rk3368-lion.dts create mode 100644 arch/arm/include/asm/arch-rockchip/ddr_rk3368.h create mode 100644 arch/arm/mach-rockchip/rk3368-board-spl.c create mode 100644 arch/arm/mach-rockchip/rk3368-board-tpl.c delete mode 100644 arch/arm/mach-rockchip/rk3368/sdram_rk3368.c create mode 100644 arch/arm/mach-rockchip/rk3368/u-boot-tpl.lds create mode 100644 board/theobroma-systems/lion_rk3368/Kconfig create mode 100644 board/theobroma-systems/lion_rk3368/MAINTAINERS create mode 100644 board/theobroma-systems/lion_rk3368/Makefile create mode 100644 board/theobroma-systems/lion_rk3368/README create mode 100644 board/theobroma-systems/lion_rk3368/fit_spl_atf.its create mode 100644 board/theobroma-systems/lion_rk3368/lion_rk3368.c create mode 100644 common/spl/spl_bootrom.c create mode 100644 configs/lion-rk3368_defconfig create mode 100644 doc/device-tree-bindings/clock/rockchip,rk3368-dmc.txt create mode 100644 drivers/ram/rockchip/Makefile create mode 100644 drivers/ram/rockchip/dmc-rk3368.c create mode 100644 include/configs/lion_rk3368.h create mode 100644 include/dt-bindings/memory/rk3368-dmc.h
On 21 Jul 2017, at 04:33, Andy Yan andy.yan@rock-chips.com wrote:
Hi:
I think you are right and most Rockchip boards have been using this the wrong way around.
With the fine-grained configurability that I created for the RK3368, it will be easy enough to switch this around on the RK3368. However, this will then also be done for the other RK3xxx devices to restore consistency.
I would prefer to first add the RK3368 support with the “backwards TPL/SPL” (i.e. TPL before SPL) to remain consistent with current mach-rockchip usage of the TPL/SPL terminology. Once this is merged, we can then switch this around for each board individually.
Hi Philipp:
Hi:
Only RK3188 uses TPL now.
Am Montag, 24. Juli 2017, 16:38:52 CEST schrieb Andy Yan:
Hi Philipp:
Hi:
TPL and SPL
OF_CONTROL
back-to-bootrom
I have a confusion here: according to the README.TPL, TPL is Third Program Loader, which loaded by the SPL. So I think it should run after the SPL. But from RK3188 and RK3368 TPL implementation , they all run before SPL.Maybe it is my misunderstanding, hope to get some guidance.:-)>
Actually at first I also had the ordering of SPL -> TPL -> uboot for rk3188 but after discussions with Simon and Tom Rini, the opinion was that TPL stands for "tiny" program loader and should run before the full SPL.
So I switched that stuff around on rk3188.
Heiko
I would prefer to first add the RK3368 support with the “backwards TPL/SPL” (i.e. TPL before SPL) to remain consistent with current mach-rockchip usage of the TPL/SPL terminology. Once this is merged, we can then switch this around for each board individually.>
TPL/SPL
SPL_SYSCON
builds
TPL/SPL/U-Boot
BROM
ROCKCHIP_RK3368
Hi Philipp:
Hi:
TPL and SPL
OF_CONTROL
back-to-bootrom
Thanks for the background.
A documentation-fix will be much easier than changing the order across all our Rockchip board … and I’ll include it in the next version of this series.
Heiko
TPL/SPL
SPL_SYSCON
builds
TPL/SPL/U-Boot
BROM
ROCKCHIP_RK3368
Hi Philipp:
Hi:
TPL and SPL
OF_CONTROL
back-to-bootrom
Has something changed since:
http://www.denx.de/wiki/pub/U-Boot/MiniSummitELCE2013/tpl-presentation.pdf
I've always thought that we do have SPL -> TPL -> u-boot -> Linux
If there was a change, then:
1. The TPL name is a bit misleading (considering the above presentation/status)
2. IMHO the code running before SPL (to do some _real_ early init) should be named more descriptive like PreSPL.
Heiko
TPL/SPL
SPL_SYSCON
builds
TPL/SPL/U-Boot
BROM
ROCKCHIP_RK3368
Hi Łukasz,
Am Montag, 24. Juli 2017, 11:23:05 CEST schrieb Łukasz Majewski:
Hi Philipp:
Hi:
TPL and SPL
OF_CONTROL
back-to-bootrom
support
- The TPL name is a bit misleading (considering the above
- IMHO the code running before SPL (to do some _real_ early init)
I've gone back and looked up the previous discussion. It was part of a thread where we only included Tom later on to clarify spl/tpl usage, so there is no list-reference, but I guess I can just quote the part:
----------------- 8< ------------------- Am Donnerstag, 26. Januar 2017, 12:57:40 CEST schrieben Tom Rini:
On Thu, Jan 26, 2017 at 07:23:25AM -0700, Simon Glass wrote:
+Tom for question below.
Hi Heiko,
On 17 December 2016 at 15:51, Heiko Stübner heiko@sntech.de wrote:
Am Samstag, 17. Dezember 2016, 09:57:51 schrieb Simon Glass:
I cannot see the .S code in that tree. If it is a few instructions then it is fine. But if it is a lot of code I question why it cannot be written mostly in C?
The .S was just my question to Kever how he envisioned this "preloader" being implemented. Right now all my parts are fully C-based.
Using TPL seems OK to me. But from my understanding TPL runs before SPL. So the sequence should be: TPL -> SPL -> U-Boot. This makes some sense because SPL is a more full-featured loader, and TPL is just a mini-loader to get the SPL running.
hmm, I think SPL -> TPL -> U-Boot would be the correct order :-) Based on the TPL being the "tertiary program loader" where the SPL only is the "secondary program loader" and based on the slides from 2013 in [0].>
That seems wrong to me. A secondary load loads the primary loader, which surely means that the tertiary should load the secondary, i.e.
I think it should be: 2 loads 1 (SPL loads U-Boot) 3 loads 2 which loads 1 (TPL loads SPL which loads U-Boot)
The alternative is: 2 loads 3 which loads 1
which seems really odd.
Note that PowerPC appears to use TPL->SPL->U-Boot when I last looked at it. Of course I could be wrong.
Yes, naming is hard. TPL (which is maybe better thought of as Tiny not Tertiary) loads SPL loads U-Boot.
Heiko
participants (8)
Andy Yan
Dr. Philipp Tomsich
Heiko Stuebner
Heiko Stübner
Kever Yang
Philipp Tomsich
Łukasz Majewski
