[PATCH v2 0/1] Add driver support for the IMX General Purpose Timer (GPT) available
Giulio Benetti (3): timer: imx-gpt: Add timer support for i.MX SoCs family
Jesse Taube (1): timer: imx-gpt: Add timer support for i.MX SoCs family
drivers/timer/Kconfig | 7 ++ drivers/timer/Makefile | 1 + drivers/timer/imx-gpt-timer.c | 132 ++++++++++++++++++++++++++++++++++ 3 files changed, 140 insertions(+) create mode 100644 drivers/timer/imx-gpt-timer.c
--- V1->V2: * Fixed indentation * Fixed capitals * Made timer work on only 24MHz clock ---
This timer driver is using GPT Timer (General Purpose Timer) available on almost all i.MX SoCs family. Since this driver is only meant to provide u-boot's timer and counter, and most of the i.MX* SoCs use a 24Mhz crystal, let's only deal with that specific source.
Signed-off-by: Giulio Benetti giulio.benetti@benettiengineering.com Signed-off-by: Jesse Taube mr.bossman075@gmail.com
--- drivers/timer/Kconfig | 7 ++ drivers/timer/Makefile | 1 + drivers/timer/imx-gpt-timer.c | 132 ++++++++++++++++++++++++++++++++++ 3 files changed, 140 insertions(+) create mode 100644 drivers/timer/imx-gpt-timer.c
diff --git a/drivers/timer/Kconfig b/drivers/timer/Kconfig index 80743a2551..ee81dfa776 100644 --- a/drivers/timer/Kconfig +++ b/drivers/timer/Kconfig @@ -227,4 +227,11 @@ config MCHP_PIT64B_TIMER Select this to enable support for Microchip 64-bit periodic interval timer.
+config IMX_GPT_TIMER + bool "NXP i.MX GPT timer support" + depends on TIMER + help + Select this to enable support for the timer found on + NXP i.MX devices. + endmenu diff --git a/drivers/timer/Makefile b/drivers/timer/Makefile index eb5c48cc6c..e214ba7268 100644 --- a/drivers/timer/Makefile +++ b/drivers/timer/Makefile @@ -25,3 +25,4 @@ obj-$(CONFIG_STM32_TIMER) += stm32_timer.o obj-$(CONFIG_X86_TSC_TIMER) += tsc_timer.o obj-$(CONFIG_MTK_TIMER) += mtk_timer.o obj-$(CONFIG_MCHP_PIT64B_TIMER) += mchp-pit64b-timer.o +obj-$(CONFIG_IMX_GPT_TIMER) += imx-gpt-timer.o diff --git a/drivers/timer/imx-gpt-timer.c b/drivers/timer/imx-gpt-timer.c new file mode 100644 index 0000000000..58c37db300 --- /dev/null +++ b/drivers/timer/imx-gpt-timer.c @@ -0,0 +1,132 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2020 + * Author(s): Giulio Benetti giulio.benetti@benettiengineering.com + */ + +#include <common.h> +#include <clk.h> +#include <dm.h> +#include <fdtdec.h> +#include <timer.h> +#include <dm/device_compat.h> + +#include <asm/io.h> + +#define GPT_CR_SWR 0x00008000 +#define GPT_CR_CLKSRC 0x000001C0 +#define GPT_CR_EN_24M 0x00004000 +#define GPT_CR_EN 0x00000001 +#define GPT_PR_PRESCALER 0x00000FFF +#define GPT_PR_PRESCALER24M 0x0000F000 + +#define NO_CLOCK (0) +#define IPG_CLK (1 << 6) +#define IPG_CLK_HF (2 << 6) +#define IPG_EXT (3 << 6) +#define IPG_CLK_32K (4 << 6) +#define IPG_CLK_24M (5 << 6) + +struct imx_gpt_timer_regs { + u32 cr; + u32 pr; + u32 sr; + u32 ir; + u32 ocr1; + u32 ocr2; + u32 ocr3; + u32 icr1; + u32 icr2; + u32 cnt; +}; + +struct imx_gpt_timer_priv { + struct imx_gpt_timer_regs *base; +}; + +static u64 imx_gpt_timer_get_count(struct udevice *dev) +{ + struct imx_gpt_timer_priv *priv = dev_get_priv(dev); + struct imx_gpt_timer_regs *regs = priv->base; + + return readl(®s->cnt); +} + +static int imx_gpt_timer_probe(struct udevice *dev) +{ + struct timer_dev_priv *uc_priv = dev_get_uclass_priv(dev); + struct imx_gpt_timer_priv *priv = dev_get_priv(dev); + struct imx_gpt_timer_regs *regs; + struct clk clk; + fdt_addr_t addr; + u32 prescaler; + u32 rate; + int ret; + + addr = dev_read_addr(dev); + if (addr == FDT_ADDR_T_NONE) + return -EINVAL; + + priv->base = (struct imx_gpt_timer_regs *)addr; + + ret = clk_get_by_index(dev, 0, &clk); + if (ret < 0) + return ret; + + ret = clk_enable(&clk); + if (ret) { + dev_err(dev, "Failed to enable clock\n"); + return ret; + } + + regs = priv->base; + + /* Reset the timer */ + setbits_le32(®s->cr, GPT_CR_SWR); + + /* Wait for timer to finish reset */ + while (readl(®s->cr) & GPT_CR_SWR) + ; + + /* Get timer clock rate */ + rate = clk_get_rate(&clk); + if ((int)rate <= 0) { + dev_err(dev, "Could not get clock rate...\n"); + return -EINVAL; + } + /* Only support 24MHz clock */ + if (rate != 24000000UL) { + dev_err(dev, "Clock rate other than 24MHz not supported...\n"); + return -EINVAL; + } + /* We set timer prescaler to obtain a 1MHz timer counter frequency */ + prescaler = (rate / CONFIG_SYS_HZ_CLOCK) - 1; + writel(GPT_PR_PRESCALER & prescaler, ®s->pr); + /* Set timer frequency to 1MHz */ + uc_priv->clock_rate = CONFIG_SYS_HZ_CLOCK; + + clrbits_le32(®s->cr, GPT_CR_CLKSRC); + setbits_le32(®s->cr, IPG_CLK); + /* Start timer */ + setbits_le32(®s->cr, GPT_CR_EN); + + return 0; +} + +static const struct timer_ops imx_gpt_timer_ops = { + .get_count = imx_gpt_timer_get_count, +}; + +static const struct udevice_id imx_gpt_timer_ids[] = { + { .compatible = "fsl,imxrt-gpt" }, + {} +}; + +U_BOOT_DRIVER(imx_gpt_timer) = { + .name = "imx_gpt_timer", + .id = UCLASS_TIMER, + .of_match = imx_gpt_timer_ids, + .priv_auto = sizeof(struct imx_gpt_timer_priv), + .probe = imx_gpt_timer_probe, + .ops = &imx_gpt_timer_ops, +};
We have a problem with columns on commit log, they shouldn't be longer than 72 cols, so please check the editor you're using for commit log writing and set 72 cols costrains. I use nano and you only need to set in .gitconfig under [core]: editor = nano -b -r 72
This way nano automatically put a CR.
- bool "NXP i.MX GPT timer support"
- depends on TIMER
- help
NXP i.MX devices.
- endmenu
- Copyright (C) 2020
- Author(s): Giulio Benetti giulio.benetti@benettiengineering.com
Here ^^^ and
here you still have different tab numbers. Enable in your editor the option to show whitespaces and tabs, that way everything it easier.
- u32 cr;
- u32 pr;
- u32 sr;
- u32 ir;
- u32 ocr1;
- u32 ocr2;
- u32 ocr3;
- u32 icr1;
- u32 icr2;
- u32 cnt;
- struct imx_gpt_timer_regs *base;
- struct imx_gpt_timer_priv *priv = dev_get_priv(dev);
- struct imx_gpt_timer_regs *regs = priv->base;
- return readl(®s->cnt);
- struct timer_dev_priv *uc_priv = dev_get_uclass_priv(dev);
- struct imx_gpt_timer_regs *regs;
- struct clk clk;
- fdt_addr_t addr;
- u32 prescaler;
- u32 rate;
- int ret;
- addr = dev_read_addr(dev);
- if (addr == FDT_ADDR_T_NONE)
return -EINVAL;
- priv->base = (struct imx_gpt_timer_regs *)addr;
- ret = clk_get_by_index(dev, 0, &clk);
- if (ret < 0)
return ret;
- ret = clk_enable(&clk);
- if (ret) {
return ret;
- regs = priv->base;
- /* Reset the timer */
- setbits_le32(®s->cr, GPT_CR_SWR);
- /* Wait for timer to finish reset */
- while (readl(®s->cr) & GPT_CR_SWR)
- /* Get timer clock rate */
- rate = clk_get_rate(&clk);
clk_get_rate() has a wrong description in include/clk.h saying: "@return clock rate in Hz, or -ve error code."
This ^^^ is wrong. If you dig into drivers/clk/clk-uclass.c and look for clk_get_rate(), you will see that it returns 0 on error and > 0 if succesfull.
I've just sent a patch for this: https://patchwork.ozlabs.org/project/uboot/patch/20210210173722.4823-1-giuli...
- if ((int)rate <= 0) {
This ^^^^ is a cast trying to solve the problem above but it's not correct. clk_get_rate() returns ulong, not int, so modify "int rate" into "ulong rate".
return -EINVAL;
- /* Only support 24MHz clock */
Extend to /* Only support 24MHz crystal clock */ otherwise it seems that every 24Mhz clock is accepted and it's not that way.
I don't know a sure way to be bounded to crystal clock, suggestions are welcome.
- if (rate != 24000000UL) {
return -EINVAL;
- /* We set timer prescaler to obtain a 1MHz timer counter frequency */
- prescaler = (rate / CONFIG_SYS_HZ_CLOCK) - 1;
Here you should check against maximum value of PRESCALER(0xFFF), if prescaler is > 0xFFF then you have to return with error.
- writel(GPT_PR_PRESCALER & prescaler, ®s->pr);
- /* Set timer frequency to 1MHz */
- uc_priv->clock_rate = CONFIG_SYS_HZ_CLOCK;
- clrbits_le32(®s->cr, GPT_CR_CLKSRC);
- setbits_le32(®s->cr, IPG_CLK);
Here IPG_CLK should be IPG_CLK_24M as discussed previously.
Best regards
diff --git a/drivers/timer/Kconfig b/drivers/timer/Kconfig index 80743a2551..ee81dfa776 100644 --- a/drivers/timer/Kconfig +++ b/drivers/timer/Kconfig @@ -227,4 +227,11 @@ config MCHP_PIT64B_TIMER Select this to enable support for Microchip 64-bit periodic interval timer. +config IMX_GPT_TIMER
- depends on TIMER
- help
NXP i.MX devices.
- endmenu
Here ^^^ and
- u32 cr;
- u32 pr;
- u32 sr;
- u32 ir;
- u32 ocr1;
- u32 ocr2;
- u32 ocr3;
- u32 icr1;
- u32 icr2;
- u32 cnt;
- struct clk clk;
- fdt_addr_t addr;
- u32 prescaler;
- u32 rate;
- int ret;
return -EINVAL;
- if (ret < 0)
return ret;
- if (ret) {
return ret;
return -EINVAL;
Why is it necessary? What are the constraints which require only using the 24MHz reference?
--Sean
return -EINVAL;
frequency */
Best regards
- depends on TIMER
- help
NXP i.MX devices.
- endmenu
Here ^^^ and
- u32 cr;
- u32 pr;
- u32 sr;
- u32 ir;
- u32 ocr1;
- u32 ocr2;
- u32 ocr3;
- u32 icr1;
- u32 icr2;
- u32 cnt;
- struct clk clk;
- fdt_addr_t addr;
- u32 prescaler;
- u32 rate;
- int ret;
return -EINVAL;
- if (ret < 0)
return ret;
- if (ret) {
return ret;
return -EINVAL;
To tell the truth there are no constraints, the reason is that I'm trying to keep this driver compatible and reusable by imx6* and imx7* since they setup the timer this way: https://gitlab.denx.de/u-boot/u-boot/-/blob/master/arch/arm/mach-imx/timer.c...
But if this timer needs to support any kind of clock source then let's modify it, but it gets more complicated and I think it could be done if needed.
Hi Jesse, Sean,
On 2/10/21 9:13 PM, Giulio Benetti wrote: [SNIP]
return -EINVAL;
This is the Linux way to make it work even if clock source is not 24Mhz: https://github.com/torvalds/linux/blob/master/drivers/clocksource/timer-imx-...
It checks if clock source is 24Mhz and set CLKSRC(named V2_TPRER_PRE24M) to IPG_CLK_24M(named MXC_TPRER). Otherwise it uses peripheral clock and that's all.
At this point it's easier than I thought.
Jesse, can you please add that handling imitating Linux driver?
Best regards
There's something strange here, patchset is malformed since above there are 4 patches listed while subject speaks about only 1 patch 0/1.
So please, try to fix it while sending to yourself with git send-mail --to "you", otherwise you spam ML.
V1->V2:
- Fixed indentation
- Fixed capitals
- Made timer work on only 24MHz clock
This is the right way.
Best regards
Giulio Benetti
Jesse Taube
Sean Anderson
