[U-Boot] [PATCH 1/3] mpc83xx: Add support for MPC83xx PCI-E controllers
This patch adds support for MPC83xx PCI-E controllers in Root Complex mode.
The patch is based on Tony Li and Dave Liu work[1].
Though unlike the original patch, by default we don't register PCI-E buses for use in U-Boot, we only configure the controllers for future use in other OSes (Linux). This is done because we don't have enough of spare BATs to map all the PCI-E regions.
To actually use PCI-E in U-Boot, users should explicitly define CONFIG_83XX_GENERIC_PCIE_REGISTER_HOSES symbol in the board file. And only then U-Boot will able to access PCI-E, but at the cost of disabled address translation.
[1] http://lists.denx.de/pipermail/u-boot/2008-January/027630.html
Signed-off-by: Tony Li tony.li@freescale.com Signed-off-by: Anton Vorontsov avorontsov@ru.mvista.com --- cpu/mpc83xx/Makefile | 1 + cpu/mpc83xx/pcie.c | 314 +++++++++++++++++++++++++++++++++++++++++ cpu/mpc83xx/speed.c | 4 +- include/asm-ppc/global_data.h | 2 +- include/asm-ppc/immap_83xx.h | 119 +++++++++++++++- include/mpc83xx.h | 67 +++++++-- include/pci.h | 4 + 7 files changed, 488 insertions(+), 23 deletions(-) create mode 100644 cpu/mpc83xx/pcie.c
diff --git a/cpu/mpc83xx/Makefile b/cpu/mpc83xx/Makefile index fcb6a52..dd35e6b 100644 --- a/cpu/mpc83xx/Makefile +++ b/cpu/mpc83xx/Makefile @@ -39,6 +39,7 @@ COBJS-y += ecc.o COBJS-$(CONFIG_QE) += qe_io.o COBJS-$(CONFIG_FSL_SERDES) += serdes.o COBJS-$(CONFIG_83XX_GENERIC_PCI) += pci.o +COBJS-$(CONFIG_83XX_GENERIC_PCIE) += pcie.o COBJS-$(CONFIG_OF_LIBFDT) += fdt.o
COBJS := $(COBJS-y) diff --git a/cpu/mpc83xx/pcie.c b/cpu/mpc83xx/pcie.c new file mode 100644 index 0000000..02150ba --- /dev/null +++ b/cpu/mpc83xx/pcie.c @@ -0,0 +1,314 @@ +/* + * Copyright (C) 2007-2009 Freescale Semiconductor, Inc. + * Copyright (C) 2008-2009 MontaVista Software, Inc. + * + * Authors: Tony Li tony.li@freescale.com + * Anton Vorontsov avorontsov@ru.mvista.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <pci.h> +#include <mpc83xx.h> +#include <asm/io.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define PCIE_MAX_BUSES 2 + +#ifdef CONFIG_83XX_GENERIC_PCIE_REGISTER_HOSES + +static int mpc83xx_pcie_remap_cfg(struct pci_controller *hose, pci_dev_t dev) +{ + int bus = PCI_BUS(dev) - hose->first_busno; + immap_t *immr = (immap_t *)CONFIG_SYS_IMMR; + pex83xx_t *pex = &immr->pciexp[bus]; + struct pex_outbound_window *out_win = &pex->bridge.pex_outbound_win[0]; + u8 devfn = PCI_DEV(dev) << 3 | PCI_FUNC(dev); + u32 dev_base = bus << 24 | devfn << 16; + + if (hose->indirect_type == INDIRECT_TYPE_NO_PCIE_LINK) + return -1; + /* + * Workaround for the HW bug: for Type 0 configure transactions the + * PCI-E controller does not check the device number bits and just + * assumes that the device number bits are 0. + */ + if (devfn & 0xf8) + return -1; + + out_le32(&out_win->tarl, dev_base); + return 0; +} + +#define cfg_read(val, addr, type, op) \ + do { *val = op((type)(addr)); } while (0) +#define cfg_write(val, addr, type, op) \ + do { op((type *)(addr), (val)); } while (0) + +#define PCIE_OP(rw, size, type, op) \ +static int pcie_##rw##_config_##size(struct pci_controller *hose, \ + pci_dev_t dev, int offset, \ + type val) \ +{ \ + int ret; \ + \ + ret = mpc83xx_pcie_remap_cfg(hose, dev); \ + if (ret) \ + return ret; \ + cfg_##rw(val, (void *)hose->cfg_addr + offset, type, op); \ + return 0; \ +} + +PCIE_OP(read, byte, u8 *, in_8) +PCIE_OP(read, word, u16 *, in_le16) +PCIE_OP(read, dword, u32 *, in_le32) +PCIE_OP(write, byte, u8, out_8) +PCIE_OP(write, word, u16, out_le16) +PCIE_OP(write, dword, u32, out_le32) + +static void mpc83xx_pcie_register_hose(int bus, struct pci_region *reg, + u8 link) +{ + extern void disable_addr_trans(void); /* start.S */ + static struct pci_controller pcie_hose[PCIE_MAX_BUSES]; + static int max_bus; + struct pci_controller *hose = &pcie_hose[bus]; + int i; + + /* + * There are no spare BATs to remap all PCI-E windows for U-Boot, so + * disable translations. In general, this is not great solution, and + * that's why we don't register PCI-E hoses by default. + */ + disable_addr_trans(); + + for (i = 0; i < 2; i++, reg++) { + if (reg->size == 0) + break; + + hose->regions[i] = *reg; + hose->region_count++; + } + + i = hose->region_count++; + hose->regions[i].bus_start = 0; + hose->regions[i].phys_start = 0; + hose->regions[i].size = gd->ram_size; + hose->regions[i].flags = PCI_REGION_MEM | PCI_REGION_MEMORY; + + i = hose->region_count++; + hose->regions[i].bus_start = CONFIG_SYS_IMMR; + hose->regions[i].phys_start = CONFIG_SYS_IMMR; + hose->regions[i].size = 0x100000; + hose->regions[i].flags = PCI_REGION_MEM | PCI_REGION_MEMORY; + + hose->first_busno = max_bus; + hose->last_busno = 0xff; + + if (bus == 0) + hose->cfg_addr = (unsigned int *)CONFIG_SYS_PCIE1_CFG_BASE; + else + hose->cfg_addr = (unsigned int *)CONFIG_SYS_PCIE2_CFG_BASE; + + pci_set_ops(hose, + pcie_read_config_byte, + pcie_read_config_word, + pcie_read_config_dword, + pcie_write_config_byte, + pcie_write_config_word, + pcie_write_config_dword); + + if (!link) + hose->indirect_type = INDIRECT_TYPE_NO_PCIE_LINK; + + pci_register_hose(hose); + +#ifdef CONFIG_PCI_SCAN_SHOW + printf("PCI: Bus Dev VenId DevId Class Int\n"); +#endif + /* + * Hose scan. + */ + hose->last_busno = pci_hose_scan(hose); + max_bus = hose->last_busno + 1; +} + +#else + +static void mpc83xx_pcie_register_hose(int bus, struct pci_region *reg, + u8 link) {} + +#endif /* CONFIG_83XX_GENERIC_PCIE_REGISTER_HOSES */ + +static void mpc83xx_pcie_init_bus(int bus, struct pci_region *reg) +{ + immap_t *immr = (immap_t *)CONFIG_SYS_IMMR; + pex83xx_t *pex = &immr->pciexp[bus]; + struct pex_outbound_window *out_win; + struct pex_inbound_window *in_win; + void *hose_cfg_base; + unsigned int ram_sz; + unsigned int barl; + unsigned int tar; + u16 reg16; + int i; + + /* Enable pex csb bridge inbound & outbound transactions */ + out_le32(&pex->bridge.pex_csb_ctrl, + in_le32(&pex->bridge.pex_csb_ctrl) | PEX_CSB_CTRL_OBPIOE | + PEX_CSB_CTRL_IBPIOE); + + /* Enable bridge outbound */ + out_le32(&pex->bridge.pex_csb_obctrl, PEX_CSB_OBCTRL_PIOE | + PEX_CSB_OBCTRL_MEMWE | PEX_CSB_OBCTRL_IOWE | + PEX_CSB_OBCTRL_CFGWE); + + out_win = &pex->bridge.pex_outbound_win[0]; + if (bus) { + out_le32(&out_win->ar, PEX_OWAR_EN | PEX_OWAR_TYPE_CFG | + CONFIG_SYS_PCIE2_CFG_SIZE); + out_le32(&out_win->bar, CONFIG_SYS_PCIE2_CFG_BASE); + } else { + out_le32(&out_win->ar, PEX_OWAR_EN | PEX_OWAR_TYPE_CFG | + CONFIG_SYS_PCIE1_CFG_SIZE); + out_le32(&out_win->bar, CONFIG_SYS_PCIE1_CFG_BASE); + } + out_le32(&out_win->tarl, 0); + out_le32(&out_win->tarh, 0); + + for (i = 0; i < 2; i++, reg++) { + u32 ar; + + if (reg->size == 0) + break; + + out_win = &pex->bridge.pex_outbound_win[i + 1]; + out_le32(&out_win->bar, reg->phys_start); + out_le32(&out_win->tarl, reg->bus_start); + out_le32(&out_win->tarh, 0); + ar = PEX_OWAR_EN | (reg->size & PEX_OWAR_SIZE); + if (reg->flags & PCI_REGION_IO) + ar |= PEX_OWAR_TYPE_IO; + else + ar |= PEX_OWAR_TYPE_MEM; + out_le32(&out_win->ar, ar); + } + + out_le32(&pex->bridge.pex_csb_ibctrl, PEX_CSB_IBCTRL_PIOE); + + ram_sz = gd->ram_size; + barl = 0; + tar = 0; + i = 0; + while (ram_sz > 0) { + in_win = &pex->bridge.pex_inbound_win[i]; + out_le32(&in_win->barl, barl); + out_le32(&in_win->barh, 0x0); + out_le32(&in_win->tar, tar); + if (ram_sz >= 0x10000000) { + /* The maxium windows size is 256M */ + out_le32(&in_win->ar, PEX_IWAR_EN | PEX_IWAR_NSOV | + PEX_IWAR_TYPE_PF | 0x0FFFF000); + barl += 0x10000000; + tar += 0x10000000; + ram_sz -= 0x10000000; + } else { + /* The UM is not clear here. + * So, round up to even Mb boundary */ + + ram_sz = ram_sz >> (20 + + ((ram_sz & 0xFFFFF) ? 1 : 0)); + if (!(ram_sz % 2)) + ram_sz -= 1; + out_le32(&in_win->ar, PEX_IWAR_EN | PEX_IWAR_NSOV | + PEX_IWAR_TYPE_PF | (ram_sz << 20) | 0xFF000); + ram_sz = 0; + } + i++; + } + + in_win = &pex->bridge.pex_inbound_win[i]; + out_le32(&in_win->barl, CONFIG_SYS_IMMR); + out_le32(&in_win->barh, 0); + out_le32(&in_win->tar, CONFIG_SYS_IMMR); + out_le32(&in_win->ar, PEX_IWAR_EN | + PEX_IWAR_TYPE_NO_PF | PEX_IWAR_SIZE_1M); + + /* Enable the host virtual INTX interrupts */ + out_le32(&pex->bridge.pex_int_axi_misc_enb, + in_le32(&pex->bridge.pex_int_axi_misc_enb) | 0x1E0); + + /* Hose configure header is memory-mapped */ + hose_cfg_base = (void *)pex; + + get_clocks(); + /* Configure the PCIE controller core clock ratio */ + out_le32(hose_cfg_base + PEX_GCLK_RATIO, + (((bus ? gd->pciexp2_clk : gd->pciexp1_clk) / 1000000) * 16) + / 333); + udelay(1000000); + + /* Do Type 1 bridge configuration */ + out_8(hose_cfg_base + PCI_PRIMARY_BUS, 0); + out_8(hose_cfg_base + PCI_SECONDARY_BUS, 1); + out_8(hose_cfg_base + PCI_SUBORDINATE_BUS, 255); + + /* + * Write to Command register + */ + reg16 = in_le16(hose_cfg_base + PCI_COMMAND); + reg16 |= PCI_COMMAND_MASTER | PCI_COMMAND_MEMORY | PCI_COMMAND_IO | + PCI_COMMAND_SERR | PCI_COMMAND_PARITY; + out_le16(hose_cfg_base + PCI_COMMAND, reg16); + + /* + * Clear non-reserved bits in status register. + */ + out_le16(hose_cfg_base + PCI_STATUS, 0xffff); + out_8(hose_cfg_base + PCI_LATENCY_TIMER, 0x80); + out_8(hose_cfg_base + PCI_CACHE_LINE_SIZE, 0x08); + + printf("PCIE%d: ", bus); + + reg16 = in_le16(hose_cfg_base + PCI_LTSSM); + if (reg16 >= PCI_LTSSM_L0) + printf("link\n"); + else + printf("No link\n"); + + mpc83xx_pcie_register_hose(bus, reg, reg16 >= PCI_LTSSM_L0); +} + +/* + * The caller must have already set SCCR, SERDES and the PCIE_LAW BARs + * must have been set to cover all of the requested regions. + */ +void mpc83xx_pcie_init(int num_buses, struct pci_region **reg, int warmboot) +{ + int i; + + /* + * Release PCI RST Output signal. + * Power on to RST high must be at least 100 ms as per PCI spec. + * On warm boots only 1 ms is required. + */ + udelay(warmboot ? 1000 : 100000); + + for (i = 0; i < num_buses; i++) + mpc83xx_pcie_init_bus(i, reg[i]); +} diff --git a/cpu/mpc83xx/speed.c b/cpu/mpc83xx/speed.c index bf9bf36..4230099 100644 --- a/cpu/mpc83xx/speed.c +++ b/cpu/mpc83xx/speed.c @@ -132,7 +132,7 @@ int get_clocks(void) u32 qe_clk; u32 brg_clk; #endif -#if defined(CONFIG_MPC837X) +#if defined(CONFIG_MPC837X) || defined(CONFIG_MPC831X) u32 pciexp1_clk; u32 pciexp2_clk; #endif @@ -328,7 +328,7 @@ int get_clocks(void) i2c2_clk = csb_clk; /* i2c-2 clk is equal to csb clk */ #endif
-#if defined(CONFIG_MPC837X) +#if defined(CONFIG_MPC837X) || defined(CONFIG_MPC831X) switch ((sccr & SCCR_PCIEXP1CM) >> SCCR_PCIEXP1CM_SHIFT) { case 0: pciexp1_clk = 0; diff --git a/include/asm-ppc/global_data.h b/include/asm-ppc/global_data.h index 2bb50b4..e5a3b2c 100644 --- a/include/asm-ppc/global_data.h +++ b/include/asm-ppc/global_data.h @@ -75,7 +75,7 @@ typedef struct global_data { u32 lbiu_clk; u32 lclk_clk; u32 pci_clk; -#if defined(CONFIG_MPC837X) +#if defined(CONFIG_MPC837X) || defined(CONFIG_MPC831X) u32 pciexp1_clk; u32 pciexp2_clk; #endif diff --git a/include/asm-ppc/immap_83xx.h b/include/asm-ppc/immap_83xx.h index df24a6e..77c09db 100644 --- a/include/asm-ppc/immap_83xx.h +++ b/include/asm-ppc/immap_83xx.h @@ -52,23 +52,28 @@ typedef struct sysconf83xx { law83xx_t lblaw[4]; /* LBIU local access window */ u8 res2[0x20]; law83xx_t pcilaw[2]; /* PCI local access window */ - u8 res3[0x30]; + u8 res3[0x10]; + law83xx_t pcielaw[2]; /* PCI Express local access window */ + u8 res4[0x10]; law83xx_t ddrlaw[2]; /* DDR local access window */ - u8 res4[0x50]; + u8 res5[0x50]; u32 sgprl; /* System General Purpose Register Low */ u32 sgprh; /* System General Purpose Register High */ u32 spridr; /* System Part and Revision ID Register */ - u8 res5[0x04]; + u8 res6[0x04]; u32 spcr; /* System Priority Configuration Register */ u32 sicrl; /* System I/O Configuration Register Low */ u32 sicrh; /* System I/O Configuration Register High */ - u8 res6[0x04]; + u8 res7[0x04]; u32 sidcr0; /* System I/O Delay Configuration Register 0 */ u32 sidcr1; /* System I/O Delay Configuration Register 1 */ u32 ddrcdr; /* DDR Control Driver Register */ u32 ddrdsr; /* DDR Debug Status Register */ u32 obir; /* Output Buffer Impedance Register */ - u8 res7[0xCC]; + u8 res8[0xC]; + u32 pecr1; /* PCI Express control register 1 */ + u32 pecr2; /* PCI Express control register 2 */ + u8 res9[0xB8]; } sysconf83xx_t;
/* @@ -503,8 +508,110 @@ typedef struct security83xx { /* * PCI Express */ +struct pex_inbound_window { + u32 ar; + u32 tar; + u32 barl; + u32 barh; +}; + +struct pex_outbound_window { + u32 ar; + u32 bar; + u32 tarl; + u32 tarh; +}; + +struct pex_csb_bridge { + u32 pex_csb_ver; + u32 pex_csb_cab; + u32 pex_csb_ctrl; + u8 res0[8]; + u32 pex_dms_dstmr; + u8 res1[4]; + u32 pex_cbs_stat; + u8 res2[0x20]; + u32 pex_csb_obctrl; + u32 pex_csb_obstat; + u8 res3[0x98]; + u32 pex_csb_ibctrl; + u32 pex_csb_ibstat; + u8 res4[0xb8]; + u32 pex_wdma_ctrl; + u32 pex_wdma_addr; + u32 pex_wdma_stat; + u8 res5[0x94]; + u32 pex_rdma_ctrl; + u32 pex_rdma_addr; + u32 pex_rdma_stat; + u8 res6[0xd4]; + u32 pex_ombcr; + u32 pex_ombdr; + u8 res7[0x38]; + u32 pex_imbcr; + u32 pex_imbdr; + u8 res8[0x38]; + u32 pex_int_enb; + u32 pex_int_stat; + u32 pex_int_apio_vec1; + u32 pex_int_apio_vec2; + u8 res9[0x10]; + u32 pex_int_ppio_vec1; + u32 pex_int_ppio_vec2; + u32 pex_int_wdma_vec1; + u32 pex_int_wdma_vec2; + u32 pex_int_rdma_vec1; + u32 pex_int_rdma_vec2; + u32 pex_int_misc_vec; + u8 res10[4]; + u32 pex_int_axi_pio_enb; + u32 pex_int_axi_wdma_enb; + u32 pex_int_axi_rdma_enb; + u32 pex_int_axi_misc_enb; + u32 pex_int_axi_pio_stat; + u32 pex_int_axi_wdma_stat; + u32 pex_int_axi_rdma_stat; + u32 pex_int_axi_misc_stat; + u8 res11[0xa0]; + struct pex_outbound_window pex_outbound_win[4]; + u8 res12[0x100]; + u32 pex_epiwtar0; + u32 pex_epiwtar1; + u32 pex_epiwtar2; + u32 pex_epiwtar3; + u8 res13[0x70]; + struct pex_inbound_window pex_inbound_win[4]; +}; + typedef struct pex83xx { - u8 fixme[0x1000]; + u8 pex_cfg_header[0x404]; + u32 pex_ltssm_stat; + u8 res0[0x30]; + u32 pex_ack_replay_timeout; + u8 res1[4]; + u32 pex_gclk_ratio; + u8 res2[0xc]; + u32 pex_pm_timer; + u32 pex_pme_timeout; + u8 res3[4]; + u32 pex_aspm_req_timer; + u8 res4[0x18]; + u32 pex_ssvid_update; + u8 res5[0x34]; + u32 pex_cfg_ready; + u8 res6[0x24]; + u32 pex_bar_sizel; + u8 res7[4]; + u32 pex_bar_sel; + u8 res8[0x20]; + u32 pex_bar_pf; + u8 res9[0x88]; + u32 pex_pme_to_ack_tor; + u8 res10[0xc]; + u32 pex_ss_intr_mask; + u8 res11[0x25c]; + struct pex_csb_bridge bridge; + u8 res12[0x160]; } pex83xx_t;
/* diff --git a/include/mpc83xx.h b/include/mpc83xx.h index 43553f5..db571fe 100644 --- a/include/mpc83xx.h +++ b/include/mpc83xx.h @@ -751,9 +751,6 @@ #define SCCR_USBDRCM_2 0x00800000 #define SCCR_USBDRCM_3 0x00c00000
-#define SCCR_PCIEXP1CM 0x00300000 -#define SCCR_PCIEXP2CM 0x000c0000 - #define SCCR_SATA1CM 0x00003000 #define SCCR_SATA1CM_SHIFT 12 #define SCCR_SATACM 0x00003c00 @@ -800,6 +797,17 @@ #define SCCR_USBDRCM_2 0x00800000 #define SCCR_USBDRCM_3 0x00c00000
+/* All of the four SATA controllers must have the same clock ratio */ +#define SCCR_SATA1CM 0x000000c0 +#define SCCR_SATA1CM_SHIFT 6 +#define SCCR_SATACM 0x000000ff +#define SCCR_SATACM_SHIFT 0 +#define SCCR_SATACM_0 0x00000000 +#define SCCR_SATACM_1 0x00000055 +#define SCCR_SATACM_2 0x000000aa +#define SCCR_SATACM_3 0x000000ff +#endif + #define SCCR_PCIEXP1CM 0x00300000 #define SCCR_PCIEXP1CM_SHIFT 20 #define SCCR_PCIEXP1CM_0 0x00000000 @@ -814,17 +822,6 @@ #define SCCR_PCIEXP2CM_2 0x00080000 #define SCCR_PCIEXP2CM_3 0x000c0000
-/* All of the four SATA controllers must have the same clock ratio */ -#define SCCR_SATA1CM 0x000000c0 -#define SCCR_SATA1CM_SHIFT 6 -#define SCCR_SATACM 0x000000ff -#define SCCR_SATACM_SHIFT 0 -#define SCCR_SATACM_0 0x00000000 -#define SCCR_SATACM_1 0x00000055 -#define SCCR_SATACM_2 0x000000aa -#define SCCR_SATACM_3 0x000000ff -#endif - /* CSn_BDNS - Chip Select memory Bounds Register */ #define CSBNDS_SA 0x00FF0000 @@ -1170,9 +1167,51 @@ #define DDRCDR_M_ODR 0x00000002 #define DDRCDR_Q_DRN 0x00000001
+/* PCIE Bridge Register + */ +#define PEX_CSB_CTRL_OBPIOE 0x00000001 +#define PEX_CSB_CTRL_IBPIOE 0x00000002 +#define PEX_CSB_CTRL_WDMAE 0x00000004 +#define PEX_CSB_CTRL_RDMAE 0x00000008 + +#define PEX_CSB_OBCTRL_PIOE 0x00000001 +#define PEX_CSB_OBCTRL_MEMWE 0x00000002 +#define PEX_CSB_OBCTRL_IOWE 0x00000004 +#define PEX_CSB_OBCTRL_CFGWE 0x00000008 + +#define PEX_CSB_IBCTRL_PIOE 0x00000001 + +#define PEX_OWAR_EN 0x00000001 +#define PEX_OWAR_TYPE_CFG 0x00000000 +#define PEX_OWAR_TYPE_IO 0x00000002 +#define PEX_OWAR_TYPE_MEM 0x00000004 +#define PEX_OWAR_RLXO 0x00000008 +#define PEX_OWAR_NANP 0x00000010 +#define PEX_OWAR_SIZE 0xFFFFF000 + +#define PEX_IWAR_EN 0x00000001 +#define PEX_IWAR_TYPE_INT 0x00000000 +#define PEX_IWAR_TYPE_PF 0x00000004 +#define PEX_IWAR_TYPE_NO_PF 0x00000006 +#define PEX_IWAR_NSOV 0x00000008 +#define PEX_IWAR_NSNP 0x00000010 +#define PEX_IWAR_SIZE 0xFFFFF000 +#define PEX_IWAR_SIZE_1M 0x000FF000 +#define PEX_IWAR_SIZE_2M 0x001FF000 +#define PEX_IWAR_SIZE_4M 0x003FF000 +#define PEX_IWAR_SIZE_8M 0x007FF000 +#define PEX_IWAR_SIZE_16M 0x00FFF000 +#define PEX_IWAR_SIZE_32M 0x01FFF000 +#define PEX_IWAR_SIZE_64M 0x03FFF000 +#define PEX_IWAR_SIZE_128M 0x07FFF000 +#define PEX_IWAR_SIZE_256M 0x0FFFF000 + +#define PEX_GCLK_RATIO 0x440 + #ifndef __ASSEMBLY__ struct pci_region; void mpc83xx_pci_init(int num_buses, struct pci_region **reg, int warmboot); +void mpc83xx_pcie_init(int num_buses, struct pci_region **reg, int warmboot); #endif
#endif /* __MPC83XX_H__ */ diff --git a/include/pci.h b/include/pci.h index eebe8a8..072273b 100644 --- a/include/pci.h +++ b/include/pci.h @@ -382,6 +382,8 @@ extern void pci_cfgfunc_config_device(struct pci_controller* hose, pci_dev_t dev
#define MAX_PCI_REGIONS 7
+#define INDIRECT_TYPE_NO_PCIE_LINK 1 + /* * Structure of a PCI controller (host bridge) */ @@ -394,6 +396,8 @@ struct pci_controller { volatile unsigned int *cfg_addr; volatile unsigned char *cfg_data;
+ int indirect_type; + struct pci_region regions[MAX_PCI_REGIONS]; int region_count;
Acked-by: Dave Liu daveliu@freescale.com
applied to u-boot-mpc83xx next.
Thanks all,
Kim
u8 link)
- extern void disable_addr_trans(void); /* start.S */
- static struct pci_controller pcie_hose[PCIE_MAX_BUSES];
If PCIe use the hose which is different from PCI hose, after u-boot booting, the command 'pci' only find the PCI controller and device, but not find the PCIe controller and PCIe devices.
u8 link)
Please post the patch as reference.
Thanks
Anton Vorontsov
Huang Changming
Kim Phillips
Liu Dave
