[U-Boot] [PATCH] ARM: rpi: only set usbethaddr on relevant systems
Model A and CM RPis don't have an on-board USB Ethernet device. Hence, there's no point setting $usbethaddr based on the device fuses. Use the model detection code to gate this. Note that the fuses are actually programmed even on those devices though.
Signed-off-by: Stephen Warren swarren@wwwdotorg.org --- This depends on the following patches that I sent earlier: ARM: rpi_b: detect board revision ARM: rpi: rename rpi_b to rpi --- board/raspberrypi/rpi/rpi.c | 17 +++++++++++++++++ 1 file changed, 17 insertions(+)
diff --git a/board/raspberrypi/rpi/rpi.c b/board/raspberrypi/rpi/rpi.c index 51a4fa103061..c7eb257f5b0e 100644 --- a/board/raspberrypi/rpi/rpi.c +++ b/board/raspberrypi/rpi/rpi.c @@ -70,58 +70,72 @@ struct msg_get_clock_rate { static const struct { const char *name; const char *fdtfile; + bool has_onboard_eth; } models[] = { [BCM2835_BOARD_REV_B_I2C0_2] = { "Model B (no P5)", "bcm2835-rpi-b-i2c0.dtb", + true, }, [BCM2835_BOARD_REV_B_I2C0_3] = { "Model B (no P5)", "bcm2835-rpi-b-i2c0.dtb", + true, }, [BCM2835_BOARD_REV_B_I2C1_4] = { "Model B", "bcm2835-rpi-b.dtb", + true, }, [BCM2835_BOARD_REV_B_I2C1_5] = { "Model B", "bcm2835-rpi-b.dtb", + true, }, [BCM2835_BOARD_REV_B_I2C1_6] = { "Model B", "bcm2835-rpi-b.dtb", + true, }, [BCM2835_BOARD_REV_A_7] = { "Model A", "bcm2835-rpi-a.dtb", + false, }, [BCM2835_BOARD_REV_A_8] = { "Model A", "bcm2835-rpi-a.dtb", + false, }, [BCM2835_BOARD_REV_A_9] = { "Model A", "bcm2835-rpi-a.dtb", + false, }, [BCM2835_BOARD_REV_B_REV2_d] = { "Model B rev2", "bcm2835-rpi-b-rev2.dtb", + true, }, [BCM2835_BOARD_REV_B_REV2_e] = { "Model B rev2", "bcm2835-rpi-b-rev2.dtb", + true, }, [BCM2835_BOARD_REV_B_REV2_f] = { "Model B rev2", "bcm2835-rpi-b-rev2.dtb", + true, }, [BCM2835_BOARD_REV_B_PLUS] = { "Model B+", "bcm2835-rpi-b-plus.dtb", + true, }, [BCM2835_BOARD_REV_CM] = { "Compute Module", "bcm2835-rpi-cm.dtb", + false, }, };
@@ -165,6 +179,9 @@ static void set_usbethaddr(void) ALLOC_ALIGN_BUFFER(struct msg_get_mac_address, msg, 1, 16); int ret;
+ if (!models[rpi_board_rev].has_onboard_eth) + return; + if (getenv("usbethaddr")) return;
Stephen Warren
