[U-Boot] Can't see NFS packages with wireshark
Hi!
I have: Board: Artila M501 board with AT91RM9200 U-Boot: 1.1.2 Kernel: 2.6.14-M5 (I know that U-Boot and Kernel are quite old, but I think for my learning purposes it is OK... Will try to update later.)
My problem: I'm trying to run root-fs over nfs... I know that my nfs-server is OK, because I can mount from another linux-pc. But I'm not able to mount nfs from my target-system. And I can't see any package from my target on wireshark which is running on the nfs-server -> So it seems that my target doesn't send any packet to the server or it get lost on my net....
Can you see any problem with my configuration? See configuration and bootlog below:
Configuration:
*************************** baudrate=115200 ethaddr=00:13:48:00:77:b5 rootpath=/opt/arm lel=1 initrd=0x20800000,8192000 ramdisk_size=15360 root=/dev/ram0 rw loader=tftp 21000000 m501_64M.alf mtdparts=phys_mapped_flash:128k(loader)ro,128k(reserved)ro,1408k(linux)ro,2560(ramdisk)ro,-(userdisk)
filesize=3A3 netmask=255.255.255.0 kernel=tftp 21000000 M501K;erase 10040000 1019ffff;cp.b 21000000 10040000 $(filesize) skernel=loadb 21000000;erase 10040000 1019ffff;cp.b 21000000 10040000 $(filesize) ramdisk=tftp 21000000 M501R;erase 101a0000 1041ffff;cp.b 21000000 101a0000 $(filesize) sramdisk=loadb 21000000;erase 101a0000 1041ffff;cp.b 21000000 101a0000 $(filesize) ipaddr=192.168.2.196 bootdelay=1 bargs=setenv bootargs mem=64M console=$(console),115200 initrd=0x20800000,8192000 ramdisk_size=15360 root=/dev/ram0 rw mtdparts=phys_mapped_flash:128k(loader)ro,128k(env)ro,1408k(linux)ro,2560k(ramdisk)ro,-(userdisk)
serverip=192.168.2.40 gateway=192.168.2.1 console=ttyS0 bootargs=mem=64M root=/dev/nfs rw nfsroot=192.168.2.40:/opt/arm ip=192.168.2.196:192.168.2.40:192.168.2.1:255.255.255.0:kleiner_michi::off console=ttyS0,115200 bootcmd=bootm 10040000 stdin=serial stdout=serial stderr=serial ***************************
log: *************************** Starting M501............. Starting kernel ...
Uncompressing Linux............................................................................................... done, booting the kernel. Linux version 2.6.14-M5 (Alan@ace-yang) (gcc version 3.3.2) #837 Tue Aug 14 14:14:03 CST 2007 CPU: ARM920Tid(wb) [41129200] revision 0 (ARMv4T) Machine: Artila M501 SOM Memory policy: ECC disabled, Data cache writeback Clocks: CPU 179 MHz, master 59 MHz, main 18.432 MHz CPU0: D VIVT write-back cache CPU0: I cache: 16384 bytes, associativity 64, 32 byte lines, 8 sets CPU0: D cache: 16384 bytes, associativity 64, 32 byte lines, 8 sets Built 1 zonelists Kernel command line: mem=64M root=/dev/nfs rw nfsroot=192.168.2.40:/opt/arm ip=192.168.2.196:192.168.2.40:192.168.2.1:255.255.255.0:kleiner_michi::off console=ttyS0,115200 AT91: 128 gpio irqs in 4 banks PID hash table entries: 512 (order: 9, 8192 bytes) Console: colour dummy device 80x30 Dentry cache hash table entries: 16384 (order: 4, 65536 bytes) Inode-cache hash table entries: 8192 (order: 3, 32768 bytes) Memory: 64MB = 64MB total Memory: 61824KB available (2389K code, 523K data, 104K init) Mount-cache hash table entries: 512 CPU: Testing write buffer coherency: ok NET: Registered protocol family 16 SCSI subsystem initialized usbcore: registered new driver usbfs usbcore: registered new driver hub NetWinder Floating Point Emulator V0.97 (extended precision) JFFS2 version 2.2. (NAND) (C) 2001-2003 Red Hat, Inc. Initializing Cryptographic API Matrix500 RTC driver. Matrix500 GPIO Driver Loaded. AT91 SPI driver loaded AT91 Watchdog Timer enabled (5 seconds) ttyS0 at MMIO 0xfefff200 (irq = 1) is a AT91_SERIAL ttyS1 at MMIO 0xfefc0000 (irq = 6) is a AT91_SERIAL ttyS2 at MMIO 0xfefc4000 (irq = 7) is a AT91_SERIAL ttyS3 at MMIO 0xfefc8000 (irq = 8) is a AT91_SERIAL ttyS4 at MMIO 0xfefcc000 (irq = 9) is a AT91_SERIAL io scheduler noop registered io scheduler anticipatory registered RAMDISK driver initialized: 16 RAM disks of 8192K size 1024 blocksize PPP generic driver version 2.4.2 PPP BSD Compression module registered NET: Registered protocol family 24 eth0: Link now 100-FullDuplex eth0: AT91 ethernet at 0xfefbc000 int=24 100-FullDuplex (00:13:48:00:77:b5) eth0: Davicom 9161AE PHY (Copper) physmap flash device: 1000000 at 10000000 phys_mapped_flash: Found 1 x16 devices at 0x0 in 16-bit bank Intel/Sharp Extended Query Table at 0x010A Using buffer write method cfi_cmdset_0001: Erase suspend on write enabled RedBoot partition parsing not available block2mtd: version $Revision: 1.28 $ at91rm9200-ohci at91rm9200-ohci: AT91RM9200 OHCI at91rm9200-ohci at91rm9200-ohci: new USB bus registered, assigned bus number 1 at91rm9200-ohci at91rm9200-ohci: irq 23, io mem 0x00300000 usb usb1: Product: AT91RM9200 OHCI usb usb1: Manufacturer: Linux 2.6.14-M5 ohci_hcd usb usb1: SerialNumber: at91rm9200 hub 1-0:1.0: USB hub found hub 1-0:1.0: 2 ports detected usbcore: registered new driver cdc_acm drivers/usb/class/cdc-acm.c: v0.23:USB Abstract Control Model driver for USB modems and ISDN adapters usbcore: registered new driver usblp drivers/usb/class/usblp.c: v0.13: USB Printer Device Class driver Initializing USB Mass Storage driver... usbcore: registered new driver usb-storage USB Mass Storage support registered. rtusb init ====> usbcore: registered new driver rt73 usbcore: registered new driver usbserial drivers/usb/serial/usb-serial.c: USB Serial support registered for Generic usbcore: registered new driver usbserial_generic drivers/usb/serial/usb-serial.c: USB Serial Driver core v2.0 drivers/usb/serial/usb-serial.c: USB Serial support registered for FTDI USB Serial Device usbcore: registered new driver ftdi_sio drivers/usb/serial/ftdi_sio.c: v1.4.3:USB FTDI Serial Converters Driver drivers/usb/serial/usb-serial.c: USB Serial support registered for PL-2303 usbcore: registered new driver pl2303 drivers/usb/serial/pl2303.c: Prolific PL2303 USB to serial adaptor driver v0.12 mice: PS/2 mouse device common for all mice i2c /dev entries driver Found AT91 i2c RTC found. AT91RM9200 MCI initialized NET: Registered protocol family 2 IP route cache hash table entries: 1024 (order: 0, 4096 bytes) TCP established hash table entries: 4096 (order: 2, 16384 bytes) TCP bind hash table entries: 4096 (order: 2, 16384 bytes) TCP: Hash tables configured (established 4096 bind 4096) TCP reno registered ip_conntrack version 2.3 (512 buckets, 4096 max) - 240 bytes per conntrack ctnetlink v0.90: registering with nfnetlink. ip_tables: (C) 2000-2002 Netfilter core team ipt_recent v0.3.1: Stephen Frost sfrost@snowman.net. http://snowman.net/projects/ipt_recent/ arp_tables: (C) 2002 David S. Miller TCP bic registered Netfilter messages via NETLINK v0.30. NET: Registered protocol family 1 NET: Registered protocol family 17 eth0: Link now 100-FullDuplex IP-Config: Complete: device=eth0, addr=192.168.2.196, mask=255.255.255.0, gw=192.168.2.1, host=kleiner_michi, domain=, nis-domain=(none), bootserver=192.168.2.40, rootserver=192.168.2.40, rootpath= VFS: Cannot open root device "nfs" or unknown-block(0,255) Please append a correct "root=" boot option Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,255) ***************************
Regards! Michael
Dear Michael Schmid,
Do you have support for NFS (CONFIG_NFS_FS) and root filesystem over NFS (CONFIG_ROOT_NFS) enabled in your Linux kenrel configuration?
Michael Schmid
