[U-Boot] [PATCH 1/2] fdt: introduce fdt_create_phandle()
The ePAPR specification says that phandle properties should be called "phandle", and not "linux,phandle". To facilitate the migration from "linux,phandle" to "phandle", introduce function fdt_create_phandle(), which creates a phandle in a given node. For now, we create both the "phandle" and "linux,phandle" properties. A later version of this function will remove support for "linux,phandle".
Signed-off-by: Timur Tabi timur@freescale.com --- common/fdt_support.c | 40 ++++++++++++++++++++++++++++++++++++++++ include/fdt_support.h | 1 + 2 files changed, 41 insertions(+), 0 deletions(-)
diff --git a/common/fdt_support.c b/common/fdt_support.c index 85715ff..dd9deaf 100644 --- a/common/fdt_support.c +++ b/common/fdt_support.c @@ -1201,6 +1201,46 @@ int fdt_alloc_phandle(void *blob) return phandle + 1; }
+/* + * fdt_create_phandle: Create a phandle property for the given node + * + * @fdt: ptr to device tree + * @nodeoffset: node to update + * @phandle: phandle value to set (must be unique) +*/ +int fdt_create_phandle(void *fdt, int nodeoffset, uint32_t phandle) +{ + int ret; + +#ifdef DEBUG + int off = fdt_node_offset_by_phandle(fdt, phandle); + + if ((off >= 0) && (off != nodeoffset)) { + char buf[64]; + + fdt_get_path(fdt, nodeoffset, buf, sizeof(buf)); + printf("Trying to update node %s with phandle %u ", + buf, phandle); + + fdt_get_path(fdt, off, buf, sizeof(buf)); + printf("that already exists in node %s.\n", buf); + return -FDT_ERR_BADPHANDLE; + } +#endif + + ret = fdt_setprop_cell(fdt, nodeoffset, "phandle", phandle); + if (ret < 0) + return ret; + + /* + * For now, also set the deprecated "linux,phandle" property, so that we + * don't break older kernels. + */ + ret = fdt_setprop_cell(fdt, nodeoffset, "linux,phandle", phandle); + + return ret; +} + #if defined(CONFIG_VIDEO) int fdt_add_edid(void *blob, const char *compat, unsigned char *edid_buf) { diff --git a/include/fdt_support.h b/include/fdt_support.h index ce6817b..366062f 100644 --- a/include/fdt_support.h +++ b/include/fdt_support.h @@ -88,6 +88,7 @@ u64 fdt_translate_address(void *blob, int node_offset, const u32 *in_addr); int fdt_node_offset_by_compat_reg(void *blob, const char *compat, phys_addr_t compat_off); int fdt_alloc_phandle(void *blob); +int fdt_create_phandle(void *fdt, int nodeoffset, uint32_t phandle); int fdt_add_edid(void *blob, const char *compat, unsigned char *buf);
#endif /* ifdef CONFIG_OF_LIBFDT */
The ePAPR specification says that phandle properties should be called "phandle", and not "linux,phandle". To facilitate the migration from "linux,phandle" to "phandle", we update fdt_qportal() to use the new function, fdt_create_phandle(). This function abstracts the creation of phandle properties.
Signed-off-by: Timur Tabi timur@freescale.com --- arch/powerpc/cpu/mpc85xx/portals.c | 5 +++-- 1 files changed, 3 insertions(+), 2 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/portals.c b/arch/powerpc/cpu/mpc85xx/portals.c index c014163..4325f45 100644 --- a/arch/powerpc/cpu/mpc85xx/portals.c +++ b/arch/powerpc/cpu/mpc85xx/portals.c @@ -151,8 +151,9 @@ static int fdt_qportal(void *blob, int off, int id, char *name, dev_handle = fdt_get_phandle(blob, dev_off); if (dev_handle <= 0) { dev_handle = fdt_alloc_phandle(blob); - fdt_setprop_cell(blob, dev_off, - "linux,phandle", dev_handle); + ret = fdt_create_phandle(blob, dev_off, dev_handle); + if (ret < 0) + return ret; }
ret = fdt_setprop(blob, childoff, "dev-handle",
Dear Timur Tabi,
Line too long.
Jerry,
Any comments on this?
- k
- fdt_create_phandle: Create a phandle property for the given node
- @fdt: ptr to device tree
- @nodeoffset: node to update
- @phandle: phandle value to set (must be unique)
- int ret;
+#ifdef DEBUG
- int off = fdt_node_offset_by_phandle(fdt, phandle);
- if ((off >= 0) && (off != nodeoffset)) {
char buf[64];
buf, phandle);
- ret = fdt_setprop_cell(fdt, nodeoffset, "phandle", phandle);
- if (ret < 0)
return ret;
- ret = fdt_setprop_cell(fdt, nodeoffset, "linux,phandle", phandle);
- return ret;
1.7.3.4
Signed-off-by: Timur Tabitimur@freescale.com
Jerry,
- k
I put it in my todo list on patchworks. What I have queued are two patches from upstream 0329-Support-ePAPR-compliant-phandle-properties.patch 0344-libfdt-Implement-property-iteration-functions.patch and...
[U-Boot,v2] Add uboot "fdt_high" enviroment variable 2011-07-09 David A. Long gvb New [U-Boot,2/2,v3] powerpc/85xx: add support the ePAPR "phandle" property 2011-05-10 Timur Tabi gvb New [U-Boot,1/2] fdt: introduce fdt_create_phandle() 2011-05-10 Timur Tabi gvb New [U-Boot,1/2] fdt: add prototype for fdt_increase_size() 2011-05-03 Timur Tabi gvb New [U-Boot,1/2,v2] fdt: introduce fdt_verify_alias_address() and fdt_get_base_address() 2011-05-03 Timur Tabi gvb New
Hollor if I'm missing something.
Thanks, gvb
Jerry,
- k
I'd add:
http://patchwork.ozlabs.org/patch/103598/
at least for a review/ack.
- k
Applied to u-boot-fdt.
Thanks, gvb
participants (5)
Gerald Van Baren
Jerry Van Baren
Kumar Gala
Timur Tabi
