[U-Boot] [PATCH] igep00x0: Use BCH8 ECC
Used NAND chips requires at least 4-bit error correction, so use BCH8 as it is what kernel uses.
Signed-off-by: Ladislav Michl ladis@linux-mips.org
--- omap3_igep00x0.h | 18 +++++++++++++----- 1 file changed, 13 insertions(+), 5 deletions(-)
diff --git a/include/configs/omap3_igep00x0.h b/include/configs/omap3_igep00x0.h index 4409103..cf2bc3e 100644 --- a/include/configs/omap3_igep00x0.h +++ b/include/configs/omap3_igep00x0.h @@ -160,12 +160,20 @@ #define CONFIG_SYS_NAND_PAGE_SIZE 2048 #define CONFIG_SYS_NAND_OOBSIZE 64 #define CONFIG_SYS_NAND_BLOCK_SIZE (128*1024) -#define CONFIG_SYS_NAND_BAD_BLOCK_POS 0 -#define CONFIG_SYS_NAND_ECCPOS {2, 3, 4, 5, 6, 7, 8, 9,\ - 10, 11, 12, 13} +#define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS +#define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ + 10, 11, 12, 13, 14, 15, 16, 17, \ + 18, 19, 20, 21, 22, 23, 24, 25, \ + 26, 27, 28, 29, 30, 31, 32, 33, \ + 34, 35, 36, 37, 38, 39, 40, 41, \ + 42, 43, 44, 45, 46, 47, 48, 49, \ + 50, 51, 52, 53, 54, 55, 56, 57, } #define CONFIG_SYS_NAND_ECCSIZE 512 -#define CONFIG_SYS_NAND_ECCBYTES 3 -#define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_HAM1_CODE_HW +#define CONFIG_SYS_NAND_ECCBYTES 14 +#define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_BCH8_CODE_HW_DETECTION_SW +#define CONFIG_NAND_OMAP_GPMC +#define CONFIG_BCH + #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x80000 /* NAND: SPL falcon mode configs */ #ifdef CONFIG_SPL_OS_BOOT
Hello Ladislav,
Thanks for the patch. It looks good to me.
Acked-by: Javier Martinez Canillas javier@osg.samsung.com
Best regards, Javier
Signed-off-by: Ladislav Michl ladis@linux-mips.org Acked-by: Javier Martinez Canillas javier@osg.samsung.com
Ladislav Michl
