[U-Boot] [PATCH 1/3] [OneNAND] Flex-OneNAND driver support
This patch adds support for Flex-OneNAND devices.
Signed-off-by: Rohit Hagargundgi h.rohit@samsung.com Signed-off-by: Amul Kumar Saha amul.saha@samsung.com --- drivers/mtd/onenand/onenand_base.c | 733 +++++++++++++++++++++++++++++++----- drivers/mtd/onenand/onenand_bbt.c | 14 drivers/mtd/onenand/onenand_uboot.c | 4 include/linux/mtd/onenand.h | 16 include/linux/mtd/onenand_regs.h | 18 include/onenand_uboot.h | 10 6 files changed, 695 insertions(+), 100 deletions(-)
diff --git a/drivers/mtd/onenand/onenand_base.c b/drivers/mtd/onenand/onenand_base.c index 368fa6e..ff84c2d 100644 --- a/drivers/mtd/onenand/onenand_base.c +++ b/drivers/mtd/onenand/onenand_base.c @@ -37,6 +37,27 @@ static inline void *memcpy_16(void *dst, const void *src, unsigned int len) }
/** + * onenand_oob_128 - oob info for Flex-Onenand with 4KB page + * For now, we expose only 64 out of 80 ecc bytes + */ +static struct nand_ecclayout onenand_oob_128 = { + .eccbytes = 64, + .eccpos = { + 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, + 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, + 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, + 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, + 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, + 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, + 102, 103, 104, 105 + }, + .oobfree = { + {2, 4}, {18, 4}, {34, 4}, {50, 4}, + {66, 4}, {82, 4}, {98, 4}, {114, 4} + } +}; + +/** * onenand_oob_64 - oob info for large (2KB) page */ static struct nand_ecclayout onenand_oob_64 = { @@ -74,6 +95,14 @@ static const unsigned char ffchars[] = { 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* 48 */ 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* 64 */ + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* 80 */ + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* 96 */ + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* 112 */ + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* 128 */ };
/** @@ -180,6 +209,84 @@ static int onenand_buffer_address(int dataram1, int sectors, int count) }
/** + * flexonenand_block - Return block number for flash address + * @param this - OneNAND device structure + * @param addr - Address for which block number is needed + */ +static unsigned int flexonenand_block(struct onenand_chip *this, loff_t addr) +{ + unsigned int boundary, blk, die = 0; + + if (ONENAND_IS_DDP(this) && addr >= this->diesize[0]) { + die = 1; + addr -= this->diesize[0]; + } + + boundary = this->boundary[die]; + + blk = addr >> (this->erase_shift - 1); + if (blk > boundary) + blk = (blk + boundary + 1) >> 1; + + blk += die ? this->density_mask : 0; + return blk; +} + +inline unsigned int onenand_block(struct onenand_chip *this, loff_t addr) +{ + if (!FLEXONENAND(this)) + return addr >> this->erase_shift; + return flexonenand_block(this, addr); +} + +/** + * flexonenand_addr - Return address of the block + * @this: OneNAND device structure + * @block: Block number on Flex-OneNAND + * + * Return address of the block + */ +static loff_t flexonenand_addr(struct onenand_chip *this, int block) +{ + loff_t ofs = 0; + int die = 0, boundary; + + if (ONENAND_IS_DDP(this) && block >= this->density_mask) { + block -= this->density_mask; + die = 1; + ofs = this->diesize[0]; + } + + boundary = this->boundary[die]; + ofs += block << (this->erase_shift - 1); + if (block > (boundary + 1)) + ofs += (block - boundary - 1) << (this->erase_shift - 1); + return ofs; +} + +inline loff_t onenand_addr(struct onenand_chip *this, int block) +{ + if (!FLEXONENAND(this)) + return block << this->erase_shift; + return flexonenand_addr(this, block); +} + +/** + * flexonenand_region - [Flex-OneNAND] Return erase region of addr + * @param mtd MTD device structure + * @param addr address whose erase region needs to be identified + */ +int flexonenand_region(struct mtd_info *mtd, loff_t addr) +{ + int i; + + for (i = 0; i < mtd->numeraseregions; i++) + if (addr < mtd->eraseregions[i].offset) + break; + return i - 1; +} + +/** * onenand_get_density - [DEFAULT] Get OneNAND density * @param dev_id OneNAND device ID * @@ -205,10 +312,11 @@ static int onenand_command(struct mtd_info *mtd, int cmd, loff_t addr, size_t len) { struct onenand_chip *this = mtd->priv; - int value, readcmd = 0; + int value; int block, page; + /* Now we use page size operation */ - int sectors = 4, count = 4; + int sectors = 0, count = 0;
/* Address translation */ switch (cmd) { @@ -220,15 +328,28 @@ static int onenand_command(struct mtd_info *mtd, int cmd, loff_t addr, page = -1; break;
+ case FLEXONENAND_CMD_PI_ACCESS: + /* addr contains die index */ + block = addr * this->density_mask; + page = -1; + break; + case ONENAND_CMD_ERASE: case ONENAND_CMD_BUFFERRAM: - block = (int)(addr >> this->erase_shift); + block = onenand_block(this, addr); page = -1; break;
+ case FLEXONENAND_CMD_READ_PI: + cmd = ONENAND_CMD_READ; + block = addr * this->density_mask; + page = 0; + break; + default: - block = (int)(addr >> this->erase_shift); - page = (int)(addr >> this->page_shift); + block = onenand_block(this, addr); + page = (int) (addr + - onenand_addr(this, block)) >> this->page_shift; page &= this->page_mask; break; } @@ -240,8 +361,11 @@ static int onenand_command(struct mtd_info *mtd, int cmd, loff_t addr, this->write_word(value, this->base + ONENAND_REG_START_ADDRESS2);
- /* Switch to the next data buffer */ - ONENAND_SET_NEXT_BUFFERRAM(this); + if (ONENAND_IS_MLC(this)) + ONENAND_SET_BUFFERRAM0(this); + else + /* Switch to the next data buffer */ + ONENAND_SET_NEXT_BUFFERRAM(this);
return 0; } @@ -252,7 +376,7 @@ static int onenand_command(struct mtd_info *mtd, int cmd, loff_t addr, this->write_word(value, this->base + ONENAND_REG_START_ADDRESS1);
- /* Write 'DFS, FBA' of Flash */ + /* Select DataRAM for DDP */ value = onenand_bufferram_address(this, block); this->write_word(value, this->base + ONENAND_REG_START_ADDRESS2); @@ -262,10 +386,14 @@ static int onenand_command(struct mtd_info *mtd, int cmd, loff_t addr, int dataram;
switch (cmd) { + case FLEXONENAND_CMD_RECOVER_LSB: case ONENAND_CMD_READ: case ONENAND_CMD_READOOB: - dataram = ONENAND_SET_NEXT_BUFFERRAM(this); - readcmd = 1; + if (ONENAND_IS_MLC(this)) + dataram = ONENAND_SET_BUFFERRAM0(this); + else + dataram = ONENAND_SET_NEXT_BUFFERRAM(this); + break;
default: @@ -292,6 +420,29 @@ static int onenand_command(struct mtd_info *mtd, int cmd, loff_t addr, }
/** + * onenand_read_ecc - return ecc status + * @param this onenand chip structure + */ +static inline int onenand_read_ecc(struct onenand_chip *this) +{ + int ecc, i; + + if (!FLEXONENAND(this)) + return this->read_word(this->base + ONENAND_REG_ECC_STATUS); + + for (i = 0; i < 4; i++) { + ecc = this->read_word(this->base + + ((ONENAND_REG_ECC_STATUS + i) << 1)); + if (likely(!ecc)) + continue; + if (ecc & FLEXONENAND_UNCORRECTABLE_ERROR) + return ONENAND_ECC_2BIT_ALL; + } + + return 0; +} + +/** * onenand_wait - [DEFAULT] wait until the command is done * @param mtd MTD device structure * @param state state to select the max. timeout value @@ -305,7 +456,7 @@ static int onenand_wait(struct mtd_info *mtd, int state) struct onenand_chip *this = mtd->priv; unsigned int flags = ONENAND_INT_MASTER; unsigned int interrupt = 0; - unsigned int ctrl, ecc; + unsigned int ctrl;
while (1) { interrupt = this->read_word(this->base + ONENAND_REG_INTERRUPT); @@ -315,6 +466,14 @@ static int onenand_wait(struct mtd_info *mtd, int state)
ctrl = this->read_word(this->base + ONENAND_REG_CTRL_STATUS);
+ if (interrupt & ONENAND_INT_READ) { + int ecc = onenand_read_ecc(this); + if (ecc & ONENAND_ECC_2BIT_ALL) { + printk("onenand_wait: ECC error = 0x%04x\n", ecc); + return -EBADMSG; + } + } + if (ctrl & ONENAND_CTRL_ERROR) { printk("onenand_wait: controller error = 0x%04x\n", ctrl); if (ctrl & ONENAND_CTRL_LOCK) @@ -324,14 +483,6 @@ static int onenand_wait(struct mtd_info *mtd, int state) return -EIO; }
- if (interrupt & ONENAND_INT_READ) { - ecc = this->read_word(this->base + ONENAND_REG_ECC_STATUS); - if (ecc & ONENAND_ECC_2BIT_ALL) { - MTDDEBUG (MTD_DEBUG_LEVEL0, - "onenand_wait: ECC error = 0x%04x\n", ecc); - return -EBADMSG; - } - }
return 0; } @@ -499,7 +650,7 @@ static int onenand_check_bufferram(struct mtd_info *mtd, loff_t addr)
if (found && ONENAND_IS_DDP(this)) { /* Select DataRAM for DDP */ - int block = (int) (addr >> this->erase_shift); + int block = onenand_block(this, addr); int value = onenand_bufferram_address(this, block); this->write_word(value, this->base + ONENAND_REG_START_ADDRESS2); } @@ -632,6 +783,45 @@ static int onenand_transfer_auto_oob(struct mtd_info *mtd, uint8_t *buf, }
/** + * onenand_recover_lsb - [Flex-OneNAND] Recover LSB page data + * @param mtd MTD device structure + * @param addr address to recover + * @param status return value from onenand_wait + * + * MLC NAND Flash cell has paired pages - LSB page and MSB page. LSB page has + * lower page address and MSB page has higher page address in paired pages. + * If power off occurs during MSB page program, the paired LSB page data can + * become corrupt. LSB page recovery read is a way to read LSB page though page + * data are corrupted. When uncorrectable error occurs as a result of LSB page + * read after power up, issue LSB page recovery read. + */ +static int onenand_recover_lsb(struct mtd_info *mtd, loff_t addr, int status) +{ + struct onenand_chip *this = mtd->priv; + int i; + + /* Recovery is only for Flex-OneNAND */ + if (!FLEXONENAND(this)) + return status; + + /* check if we failed due to uncorrectable error */ + if (status != -EBADMSG && status != ONENAND_BBT_READ_ECC_ERROR) + return status; + + /* check if address lies in MLC region */ + i = flexonenand_region(mtd, addr); + if (mtd->eraseregions[i].erasesize < (1 << this->erase_shift)) + return status; + + printk("onenand_recover_lsb:" + "Attempting to recover from uncorrectable read\n"); + + /* Issue the LSB page recovery command */ + this->command(mtd, FLEXONENAND_CMD_RECOVER_LSB, addr, this->writesize); + return this->wait(mtd, FL_READING); +} + +/** * onenand_read_ops_nolock - [OneNAND Interface] OneNAND read main and/or out-of-band * @param mtd MTD device structure * @param from offset to read from @@ -673,6 +863,7 @@ static int onenand_read_ops_nolock(struct mtd_info *mtd, loff_t from, stats = mtd->ecc_stats;
/* Read-while-load method */ + /* Note: We can't use this feature in MLC */
/* Do first load to bufferRAM */ if (read < len) { @@ -680,6 +871,8 @@ static int onenand_read_ops_nolock(struct mtd_info *mtd, loff_t from, this->main_buf = buf; this->command(mtd, ONENAND_CMD_READ, from, writesize); ret = this->wait(mtd, FL_READING); + if (unlikely(ret)) + ret = onenand_recover_lsb(mtd, from, ret); onenand_update_bufferram(mtd, from, !ret); if (ret == -EBADMSG) ret = 0; @@ -694,7 +887,7 @@ static int onenand_read_ops_nolock(struct mtd_info *mtd, loff_t from, while (!ret) { /* If there is more to load then start next load */ from += thislen; - if (read + thislen < len) { + if (!ONENAND_IS_MLC(this) && read + thislen < len) { this->main_buf = buf + thislen; this->command(mtd, ONENAND_CMD_READ, from, writesize); /* @@ -728,6 +921,16 @@ static int onenand_read_ops_nolock(struct mtd_info *mtd, loff_t from, oobcolumn = 0; }
+ if (ONENAND_IS_MLC(this) && (read + thislen < len)) { + this->command(mtd, ONENAND_CMD_READ, from, writesize); + ret = this->wait(mtd, FL_READING); + if (unlikely(ret)) + ret = onenand_recover_lsb(mtd, from, ret); + onenand_update_bufferram(mtd, from, !ret); + if (ret == -EBADMSG) + ret = 0; + } + /* See if we are done */ read += thislen; if (read == len) @@ -735,16 +938,19 @@ static int onenand_read_ops_nolock(struct mtd_info *mtd, loff_t from, /* Set up for next read from bufferRAM */ if (unlikely(boundary)) this->write_word(ONENAND_DDP_CHIP1, this->base + ONENAND_REG_START_ADDRESS2); - ONENAND_SET_NEXT_BUFFERRAM(this); + if (!ONENAND_IS_MLC(this)) + ONENAND_SET_NEXT_BUFFERRAM(this); buf += thislen; thislen = min_t(int, writesize, len - read); column = 0;
- /* Now wait for load */ - ret = this->wait(mtd, FL_READING); - onenand_update_bufferram(mtd, from, !ret); - if (ret == -EBADMSG) - ret = 0; + if (!ONENAND_IS_MLC(this)) { + /* Now wait for load */ + ret = this->wait(mtd, FL_READING); + onenand_update_bufferram(mtd, from, !ret); + if (ret == -EBADMSG) + ret = 0; + } }
/* @@ -781,7 +987,7 @@ static int onenand_read_oob_nolock(struct mtd_info *mtd, loff_t from, size_t len = ops->ooblen; mtd_oob_mode_t mode = ops->mode; u_char *buf = ops->oobbuf; - int ret = 0; + int ret = 0, readcmd;
from += ops->ooboffs;
@@ -812,16 +1018,21 @@ static int onenand_read_oob_nolock(struct mtd_info *mtd, loff_t from,
+ readcmd = ONENAND_IS_MLC(this) ? ONENAND_CMD_READ : ONENAND_CMD_READOOB; + while (read < len) { thislen = oobsize - column; thislen = min_t(int, thislen, len);
this->spare_buf = buf; - this->command(mtd, ONENAND_CMD_READOOB, from, mtd->oobsize); + this->command(mtd, readcmd, from, mtd->oobsize);
onenand_update_bufferram(mtd, from, 0);
ret = this->wait(mtd, FL_READING); + if (unlikely(ret)) + ret = onenand_recover_lsb(mtd, from, ret); + if (ret && ret != -EBADMSG) { printk(KERN_ERR "onenand_read_oob_nolock: read failed = 0x%x\n", ret); break; @@ -945,9 +1156,12 @@ static int onenand_bbt_wait(struct mtd_info *mtd, int state) ctrl = this->read_word(this->base + ONENAND_REG_CTRL_STATUS);
if (interrupt & ONENAND_INT_READ) { - int ecc = this->read_word(this->base + ONENAND_REG_ECC_STATUS); - if (ecc & ONENAND_ECC_2BIT_ALL) + int ecc = onenand_read_ecc(this); + if (ecc & ONENAND_ECC_2BIT_ALL) { + printk(KERN_INFO "onenand_bbt_wait: ecc error = 0x%04x" + ", controller = 0x%04x\n", ecc, ctrl); return ONENAND_BBT_READ_ERROR; + } } else { printk(KERN_ERR "onenand_bbt_wait: read timeout!" "ctrl=0x%04x intr=0x%04x\n", ctrl, interrupt); @@ -976,12 +1190,14 @@ int onenand_bbt_read_oob(struct mtd_info *mtd, loff_t from, { struct onenand_chip *this = mtd->priv; int read = 0, thislen, column; - int ret = 0; + int ret = 0, readcmd; size_t len = ops->ooblen; u_char *buf = ops->oobbuf;
MTDDEBUG(MTD_DEBUG_LEVEL3, "onenand_bbt_read_oob: from = 0x%08x, len = %zi\n", (unsigned int) from, len);
+ readcmd = ONENAND_IS_MLC(this) ? ONENAND_CMD_READ : ONENAND_CMD_READOOB; + /* Initialize return value */ ops->oobretlen = 0;
@@ -1002,11 +1218,14 @@ int onenand_bbt_read_oob(struct mtd_info *mtd, loff_t from, thislen = min_t(int, thislen, len);
ret = this->bbt_wait(mtd, FL_READING); + if (unlikely(ret)) + ret = onenand_recover_lsb(mtd, from, ret); + if (ret) break;
@@ -1044,9 +1263,11 @@ static int onenand_verify_oob(struct mtd_info *mtd, const u_char *buf, loff_t to { struct onenand_chip *this = mtd->priv; u_char *oob_buf = this->oob_buf; - int status, i; + int status, i, readcmd; + + readcmd = ONENAND_IS_MLC(this) ? ONENAND_CMD_READ : ONENAND_CMD_READOOB;
- this->command(mtd, ONENAND_CMD_READOOB, to, mtd->oobsize); + this->command(mtd, readcmd, to, mtd->oobsize); onenand_update_bufferram(mtd, to, 0); status = this->wait(mtd, FL_READING); if (status) @@ -1291,7 +1512,7 @@ static int onenand_write_oob_nolock(struct mtd_info *mtd, loff_t to, { struct onenand_chip *this = mtd->priv; int column, ret = 0, oobsize; - int written = 0; + int written = 0, oobcmd; u_char *oobbuf; size_t len = ops->ooblen; const u_char *buf = ops->oobbuf; @@ -1333,6 +1554,8 @@ static int onenand_write_oob_nolock(struct mtd_info *mtd, loff_t to,
oobbuf = this->oob_buf;
+ oobcmd = ONENAND_IS_MLC(this) ? ONENAND_CMD_PROG : ONENAND_CMD_PROGOOB; + /* Loop until all data write */ while (written < len) { int thislen = min_t(int, oobsize, len - written); @@ -1348,7 +1571,14 @@ static int onenand_write_oob_nolock(struct mtd_info *mtd, loff_t to, memcpy(oobbuf + column, buf, thislen); this->write_bufferram(mtd, 0, ONENAND_SPARERAM, oobbuf, 0, mtd->oobsize);
- this->command(mtd, ONENAND_CMD_PROGOOB, to, mtd->oobsize); + if (ONENAND_IS_MLC(this)) { + /* Set main area of DataRAM to 0xff*/ + memset(this->page_buf, 0xff, mtd->writesize); + this->write_bufferram(mtd, 0, ONENAND_DATARAM, + this->page_buf, 0, mtd->writesize); + } + + this->command(mtd, oobcmd, to, mtd->oobsize);
onenand_update_bufferram(mtd, to, 0); if (ONENAND_IS_2PLANE(this)) { @@ -1475,34 +1705,54 @@ int onenand_erase(struct mtd_info *mtd, struct erase_info *instr) { struct onenand_chip *this = mtd->priv; unsigned int block_size; - loff_t addr; - int len; - int ret = 0; + loff_t addr = instr->addr; + unsigned int len = instr->len; + int ret = 0, i; + struct mtd_erase_region_info *region = NULL; + unsigned int region_end = 0;
- MTDDEBUG (MTD_DEBUG_LEVEL3, - "onenand_erase: start = 0x%08x, len = %i\n", - (unsigned int)instr->addr, (unsigned int)instr->len); + MTDDEBUG(MTD_DEBUG_LEVEL3, "onenand_erase: start = 0x%08x, len = %i\n", + (unsigned int) addr, len);
- block_size = (1 << this->erase_shift); - - /* Start address must align on block boundary */ - if (unlikely(instr->addr & (block_size - 1))) { - MTDDEBUG (MTD_DEBUG_LEVEL0, - "onenand_erase: Unaligned address\n"); + /* Do not allow erase past end of device */ + if (unlikely((len + addr) > mtd->size)) { + MTDDEBUG(MTD_DEBUG_LEVEL0, "onenand_erase:" + "Erase past end of device\n"); return -EINVAL; }
- /* Length must align on block boundary */ - if (unlikely(instr->len & (block_size - 1))) { - MTDDEBUG (MTD_DEBUG_LEVEL0, - "onenand_erase: Length not block aligned\n"); - return -EINVAL; + if (FLEXONENAND(this)) { + /* Find the eraseregion of this address */ + i = flexonenand_region(mtd, addr); + region = &mtd->eraseregions[i]; + + block_size = region->erasesize; + region_end = region->offset + + region->erasesize * region->numblocks; + + /* Start address within region must align on block boundary. + * Erase region's start offset is always block start address. + */ + if (unlikely((addr - region->offset) & (block_size - 1))) { + MTDDEBUG(MTD_DEBUG_LEVEL0, "onenand_erase:" + "Unaligned address\n"); + return -EINVAL; + } + } else { + block_size = 1 << this->erase_shift; + + /* Start address must align on block boundary */ + if (unlikely(addr & (block_size - 1))) { + MTDDEBUG(MTD_DEBUG_LEVEL0, "onenand_erase:" + "Unaligned address\n"); + return -EINVAL; + } }
- /* Do not allow erase past end of device */ - if (unlikely((instr->len + instr->addr) > mtd->size)) { + /* Length must align on block boundary */ + if (unlikely(len & (block_size - 1))) { MTDDEBUG (MTD_DEBUG_LEVEL0, - "onenand_erase: Erase past end of device\n"); + "onenand_erase: Length not block aligned\n"); return -EINVAL; }
@@ -1512,9 +1762,6 @@ int onenand_erase(struct mtd_info *mtd, struct erase_info *instr) onenand_get_device(mtd, FL_ERASING);
/* Loop throught the pages */ - len = instr->len; - addr = instr->addr; - instr->state = MTD_ERASING;
while (len) { @@ -1541,14 +1788,7 @@ int onenand_erase(struct mtd_info *mtd, struct erase_info *instr) else MTDDEBUG (MTD_DEBUG_LEVEL0, "onenand_erase: " "Failed erase, block %d\n", - (unsigned)(addr >> this->erase_shift)); - if (ret == -EPERM) - printk("onenand_erase: " - "Device is write protected!!!\n"); - else - printk("onenand_erase: " - "Failed erase, block %d\n", - (unsigned)(addr >> this->erase_shift)); + onenand_block(this, addr)); instr->state = MTD_ERASE_FAILED; instr->fail_addr = addr;
@@ -1557,6 +1797,24 @@ int onenand_erase(struct mtd_info *mtd, struct erase_info *instr)
len -= block_size; addr += block_size; + + if (addr == region_end) { + if (!len) + break; + region++; + + block_size = region->erasesize; + region_end = region->offset + + region->erasesize * region->numblocks; + + if (len & (block_size - 1)) { + /* This has been checked + * at MTD partitioning level. */ + + printk("onenand_erase: Unaligned address\n"); + goto erase_exit; + } + } }
instr->state = MTD_ERASE_DONE; @@ -1634,7 +1892,7 @@ static int onenand_default_block_markbad(struct mtd_info *mtd, loff_t ofs) int block;
/* Get block number */ - block = ((int) ofs) >> bbm->bbt_erase_shift; + block = onenand_block(this, ofs); if (bbm->bbt) bbm->bbt[block >> 2] |= 0x01 << ((block & 0x03) << 1);
@@ -1682,8 +1940,8 @@ static int onenand_do_lock_cmd(struct mtd_info *mtd, loff_t ofs, size_t len, int int start, end, block, value, status; int wp_status_mask;
- start = ofs >> this->erase_shift; - end = len >> this->erase_shift; + start = onenand_block(this, ofs); + end = onenand_block(this, ofs + len);
if (cmd == ONENAND_CMD_LOCK) wp_status_mask = ONENAND_WP_LS; @@ -1718,7 +1976,7 @@ static int onenand_do_lock_cmd(struct mtd_info *mtd, loff_t ofs, size_t len, int }
/* Block lock scheme */ - for (block = start; block < start + end; block++) { + for (block = start; block < end; block++) { /* Set block address */ value = onenand_block_address(this, block); this->write_word(value, this->base + ONENAND_REG_START_ADDRESS1); @@ -1831,7 +2089,7 @@ static void onenand_unlock_all(struct mtd_info *mtd) { struct onenand_chip *this = mtd->priv; loff_t ofs = 0; - size_t len = this->chipsize; + size_t len = mtd->size;
if (this->options & ONENAND_HAS_UNLOCK_ALL) { /* Set start block address */ @@ -1847,14 +2105,12 @@ static void onenand_unlock_all(struct mtd_info *mtd) & ONENAND_CTRL_ONGO) continue;
- return; - /* Check lock status */ if (onenand_check_lock_status(this)) return;
/* Workaround for all block unlock in DDP */ - if (ONENAND_IS_DDP(this)) { + if (ONENAND_IS_DDP(this) && !FLEXONENAND(this)) { /* All blocks on another chip */ ofs = this->chipsize >> 1; len = this->chipsize >> 1; @@ -1906,6 +2162,14 @@ static void onenand_check_features(struct mtd_info *mtd) break; }
+ if (ONENAND_IS_MLC(this)) + this->options &= ~ONENAND_HAS_2PLANE; + + if (FLEXONENAND(this)) { + this->options &= ~ONENAND_HAS_CONT_LOCK; + this->options |= ONENAND_HAS_UNLOCK_ALL; + } + if (this->options & ONENAND_HAS_CONT_LOCK) printk(KERN_DEBUG "Lock scheme is Continuous Lock\n"); if (this->options & ONENAND_HAS_UNLOCK_ALL) @@ -1922,16 +2186,18 @@ static void onenand_check_features(struct mtd_info *mtd) */ char *onenand_print_device_info(int device, int version) { - int vcc, demuxed, ddp, density; + int vcc, demuxed, ddp, density, flexonenand; char *dev_info = malloc(80); char *p = dev_info;
vcc = device & ONENAND_DEVICE_VCC_MASK; demuxed = device & ONENAND_DEVICE_IS_DEMUX; ddp = device & ONENAND_DEVICE_IS_DDP; - density = device >> ONENAND_DEVICE_DENSITY_SHIFT; - p += sprintf(dev_info, "%sOneNAND%s %dMB %sV 16-bit (0x%02x)", + density = onenand_get_density(device); + flexonenand = device & DEVICE_IS_FLEXONENAND; + p += sprintf(dev_info, "%s%sOneNAND%s %dMB %sV 16-bit (0x%02x)", demuxed ? "" : "Muxed ", + flexonenand ? "Flex-" : "", ddp ? "(DDP)" : "", (16 << density), vcc ? "2.65/3.3" : "1.8", device);
@@ -1957,7 +2223,7 @@ static int onenand_check_maf(int manuf) char *name; int i;
- for (i = 0; size; i++) + for (i = 0; i < size; i++) if (manuf == onenand_manuf_ids[i].id) break;
@@ -1974,6 +2240,263 @@ static int onenand_check_maf(int manuf) }
/** +* flexonenand_get_boundary - Reads the SLC boundary +* @param onenand_info - onenand info structure +* +* Fill up boundary[] field in onenand_chip +**/ +static int flexonenand_get_boundary(struct mtd_info *mtd) +{ + struct onenand_chip *this = mtd->priv; + unsigned int die, bdry; + int ret, syscfg, locked; + + /* Disable ECC */ + syscfg = this->read_word(this->base + ONENAND_REG_SYS_CFG1); + this->write_word((syscfg | 0x0100), this->base + ONENAND_REG_SYS_CFG1); + + for (die = 0; die < this->dies; die++) { + this->command(mtd, FLEXONENAND_CMD_PI_ACCESS, die, 0); + this->wait(mtd, FL_SYNCING); + + this->command(mtd, FLEXONENAND_CMD_READ_PI, die, 0); + ret = this->wait(mtd, FL_READING); + + bdry = this->read_word(this->base + ONENAND_DATARAM); + if ((bdry >> FLEXONENAND_PI_UNLOCK_SHIFT) == 3) + locked = 0; + else + locked = 1; + this->boundary[die] = bdry & FLEXONENAND_PI_MASK; + + this->command(mtd, ONENAND_CMD_RESET, 0, 0); + ret = this->wait(mtd, FL_RESETING); + + printk(KERN_INFO "Die %d boundary: %d%s\n", die, + this->boundary[die], locked ? "(Locked)" : "(Unlocked)"); + } + + /* Enable ECC */ + this->write_word(syscfg, this->base + ONENAND_REG_SYS_CFG1); + return 0; +} + +/** + * flexonenand_get_size - Fill up fields in onenand_chip and mtd_info + * boundary[], diesize[], mtd->size, mtd->erasesize, + * mtd->eraseregions + * @param mtd - MTD device structure + */ +static void flexonenand_get_size(struct mtd_info *mtd) +{ + struct onenand_chip *this = mtd->priv; + int die, ofs, i, eraseshift, density; + int blksperdie, maxbdry; + + density = onenand_get_density(this->device_id); + blksperdie = ((16 << density) << 20) >> (this->erase_shift); + blksperdie >>= ONENAND_IS_DDP(this) ? 1 : 0; + maxbdry = blksperdie - 1; + eraseshift = this->erase_shift - 1; + + mtd->numeraseregions = this->dies << 1; + + /* This fills up the device boundary */ + flexonenand_get_boundary(mtd); + die = ofs = 0; + i = -1; + for (; die < this->dies; die++) { + if (!die || this->boundary[die-1] != maxbdry) { + i++; + mtd->eraseregions[i].offset = ofs; + mtd->eraseregions[i].erasesize = 1 << eraseshift; + mtd->eraseregions[i].numblocks = + this->boundary[die] + 1; + ofs += mtd->eraseregions[i].numblocks << eraseshift; + eraseshift++; + } else { + mtd->numeraseregions -= 1; + mtd->eraseregions[i].numblocks += + this->boundary[die] + 1; + ofs += (this->boundary[die] + 1) << (eraseshift - 1); + } + if (this->boundary[die] != maxbdry) { + i++; + mtd->eraseregions[i].offset = ofs; + mtd->eraseregions[i].erasesize = 1 << eraseshift; + mtd->eraseregions[i].numblocks = maxbdry ^ + this->boundary[die]; + ofs += mtd->eraseregions[i].numblocks << eraseshift; + eraseshift--; + } else + mtd->numeraseregions -= 1; + } + + /* Expose MLC erase size except when all blocks are SLC */ + mtd->erasesize = 1 << this->erase_shift; + if (mtd->numeraseregions == 1) + mtd->erasesize >>= 1; + + printk(KERN_INFO "Device has %d eraseregions\n", mtd->numeraseregions); + for (i = 0; i < mtd->numeraseregions; i++) + printk(KERN_INFO "[offset: 0x%08x, erasesize: 0x%05x," + " numblocks: %04u]\n", mtd->eraseregions[i].offset, + mtd->eraseregions[i].erasesize, + mtd->eraseregions[i].numblocks); + + for (die = 0, mtd->size = 0; die < this->dies; die++) { + this->diesize[die] = (blksperdie << this->erase_shift); + this->diesize[die] -= (this->boundary[die] + 1) + << (this->erase_shift - 1); + mtd->size += this->diesize[die]; + } +} + +/** + * flexonenand_check_blocks_erased - Check if blocks are erased + * @param mtd_info - mtd info structure + * @param start - first erase block to check + * @param end - last erase block to check + * + * Converting an unerased block from MLC to SLC + * causes byte values to change. Since both data and its ECC + * have changed, reads on the block give uncorrectable error. + * This might lead to the block being detected as bad. + * + * Avoid this by ensuring that the block to be converted is + * erased. + */ +static int flexonenand_check_blocks_erased(struct mtd_info *mtd, + int start, int end) +{ + struct onenand_chip *this = mtd->priv; + int i, ret; + int block; + struct mtd_oob_ops ops = { + .mode = MTD_OOB_PLACE, + .ooboffs = 0, + .ooblen = mtd->oobsize, + .datbuf = NULL, + .oobbuf = this->oob_buf, + }; + loff_t addr; + + printk(KERN_DEBUG "Check blocks from %d to %d\n", start, end); + + for (block = start; block <= end; block++) { + addr = flexonenand_addr(this, block); + if (onenand_block_isbad_nolock(mtd, addr, 0)) + continue; + + /* + * Since main area write results in ECC write to spare, + * it is sufficient to check only ECC bytes for change. + */ + ret = onenand_read_oob_nolock(mtd, addr, &ops); + if (ret) + return ret; + + for (i = 0; i < mtd->oobsize; i++) + if (this->oob_buf[i] != 0xff) + break; + + if (i != mtd->oobsize) { + printk(KERN_WARNING "Block %d not erased.\n", block); + return 1; + } + } + + return 0; +} + +/** + * flexonenand_set_boundary - Writes the SLC boundary + * @param mtd - mtd info structure + */ +int flexonenand_set_boundary(struct mtd_info *mtd, int die, + int boundary, int lock) +{ + struct onenand_chip *this = mtd->priv; + int ret, density, blksperdie, old, new, thisboundary; + loff_t addr; + + if (die >= this->dies) + return -EINVAL; + + if (boundary == this->boundary[die]) + return 0; + + density = onenand_get_density(this->device_id); + blksperdie = ((16 << density) << 20) >> this->erase_shift; + blksperdie >>= ONENAND_IS_DDP(this) ? 1 : 0; + + if (boundary >= blksperdie) { + printk("flexonenand_set_boundary:" + "Invalid boundary value. " + "Boundary not changed.\n"); + return -EINVAL; + } + + /* Check if converting blocks are erased */ + old = this->boundary[die] + (die * this->density_mask); + new = boundary + (die * this->density_mask); + ret = flexonenand_check_blocks_erased(mtd, min(old, new) + + 1, max(old, new)); + if (ret) { + printk(KERN_ERR "flexonenand_set_boundary: Please erase blocks before boundary change\n"); + return ret; + } + + this->command(mtd, FLEXONENAND_CMD_PI_ACCESS, die, 0); + this->wait(mtd, FL_SYNCING); + + /* Check is boundary is locked */ + this->command(mtd, FLEXONENAND_CMD_READ_PI, die, 0); + ret = this->wait(mtd, FL_READING); + + thisboundary = this->read_word(this->base + ONENAND_DATARAM); + if ((thisboundary >> FLEXONENAND_PI_UNLOCK_SHIFT) != 3) { + printk(KERN_ERR "flexonenand_set_boundary: boundary locked\n"); + goto out; + } + + printk(KERN_INFO "flexonenand_set_boundary: Changing die %d boundary: %d%s\n", + die, boundary, lock ? "(Locked)" : "(Unlocked)"); + + boundary &= FLEXONENAND_PI_MASK; + boundary |= lock ? 0 : (3 << FLEXONENAND_PI_UNLOCK_SHIFT); + + addr = die ? this->diesize[0] : 0; + this->command(mtd, ONENAND_CMD_ERASE, addr, 0); + ret = this->wait(mtd, FL_ERASING); + if (ret) { + printk("flexonenand_set_boundary:" + "Failed PI erase for Die %d\n", die); + goto out; + } + + this->write_word(boundary, this->base + ONENAND_DATARAM); + this->command(mtd, ONENAND_CMD_PROG, addr, 0); + ret = this->wait(mtd, FL_WRITING); + if (ret) { + printk("flexonenand_set_boundary:" + "Failed PI write for Die %d\n", die); + goto out; + } + + this->command(mtd, FLEXONENAND_CMD_PI_UPDATE, die, 0); + ret = this->wait(mtd, FL_WRITING); +out: + this->write_word(ONENAND_CMD_RESET, this->base + ONENAND_REG_COMMAND); + this->wait(mtd, FL_RESETING); + if (!ret) + /* Recalculate device size on boundary change*/ + flexonenand_get_size(mtd); + + return ret; +} + +/** * onenand_probe - [OneNAND Interface] Probe the OneNAND device * @param mtd MTD device structure * @@ -2016,48 +2539,69 @@ static int onenand_probe(struct mtd_info *mtd) maf_id = this->read_word(this->base + ONENAND_REG_MANUFACTURER_ID); dev_id = this->read_word(this->base + ONENAND_REG_DEVICE_ID); ver_id = this->read_word(this->base + ONENAND_REG_VERSION_ID); + this->technology = this->read_word(this->base + ONENAND_REG_TECHNOLOGY);
/* Check OneNAND device */ if (maf_id != bram_maf_id || dev_id != bram_dev_id) return -ENXIO;
- /* FIXME : Current OneNAND MTD doesn't support Flex-OneNAND */ - if (dev_id & (1 << 9)) { - printk("Not yet support Flex-OneNAND\n"); - return -ENXIO; - } - /* Flash device information */ mtd->name = onenand_print_device_info(dev_id, ver_id); this->device_id = dev_id; this->version_id = ver_id;
density = onenand_get_density(dev_id); + if (FLEXONENAND(this)) { + this->dies = ONENAND_IS_DDP(this) ? 2 : 1; + /* Maximum possible erase regions */ + mtd->numeraseregions = this->dies << 1; + mtd->eraseregions = malloc(sizeof(struct mtd_erase_region_info) + * (this->dies << 1)); + if (!mtd->eraseregions) + return -ENOMEM; + } + + /* + * For Flex-OneNAND, chipsize represents maximum possible device size. + * mtd->size represents the actual device size. + */ this->chipsize = (16 << density) << 20; - /* Set density mask. it is used for DDP */ - if (ONENAND_IS_DDP(this)) - this->density_mask = (1 << (density + 6)); - else - this->density_mask = 0;
/* OneNAND page size & block size */ /* The data buffer size is equal to page size */ mtd->writesize = this->read_word(this->base + ONENAND_REG_DATA_BUFFER_SIZE); + /* We use the full BufferRAM */ + if (ONENAND_IS_MLC(this)) + mtd->writesize <<= 1; + mtd->oobsize = mtd->writesize >> 5; /* Pagers per block is always 64 in OneNAND */ mtd->erasesize = mtd->writesize << 6; + /* + * Flex-OneNAND SLC area has 64 pages per block. + * Flex-OneNAND MLC area has 128 pages per block. + * Expose MLC erase size to find erase_shift and page_mask. + */ + if (FLEXONENAND(this)) + mtd->erasesize <<= 1;
this->erase_shift = ffs(mtd->erasesize) - 1; this->page_shift = ffs(mtd->writesize) - 1; this->ppb_shift = (this->erase_shift - this->page_shift); this->page_mask = (mtd->erasesize / mtd->writesize) - 1; + /* Set density mask. it is used for DDP */ + if (ONENAND_IS_DDP(this)) + this->density_mask = this->chipsize >> (this->erase_shift + 1); /* It's real page size */ this->writesize = mtd->writesize;
/* REVIST: Multichip handling */
- mtd->size = this->chipsize; + if (FLEXONENAND(this)) + flexonenand_get_size(mtd); + else + mtd->size = this->chipsize;
/* Check OneNAND features */ onenand_check_features(mtd); @@ -2149,6 +2693,11 @@ int onenand_scan(struct mtd_info *mtd, int maxchips) * Allow subpage writes up to oobsize. */ switch (mtd->oobsize) { + case 128: + this->ecclayout = &onenand_oob_128; + mtd->subpage_sft = 0; + break; + case 64: this->ecclayout = &onenand_oob_64; mtd->subpage_sft = 2; diff --git a/drivers/mtd/onenand/onenand_bbt.c b/drivers/mtd/onenand/onenand_bbt.c index d538f95..1354877 100644 --- a/drivers/mtd/onenand/onenand_bbt.c +++ b/drivers/mtd/onenand/onenand_bbt.c @@ -69,6 +69,7 @@ static int create_bbt(struct mtd_info *mtd, uint8_t * buf, loff_t from; size_t readlen, ooblen; struct mtd_oob_ops ops; + int rgn;
printk(KERN_INFO "Scanning device for bad blocks\n");
@@ -82,7 +83,7 @@ static int create_bbt(struct mtd_info *mtd, uint8_t * buf, /* Note that numblocks is 2 * (real numblocks) here; * see i += 2 below as it makses shifting and masking less painful */ - numblocks = mtd->size >> (bbm->bbt_erase_shift - 1); + numblocks = this->chipsize >> (bbm->bbt_erase_shift - 1); startblock = 0; from = 0;
@@ -115,7 +116,12 @@ static int create_bbt(struct mtd_info *mtd, uint8_t * buf, } } i += 2; - from += (1 << bbm->bbt_erase_shift); + + if (FLEXONENAND(this)) { + rgn = flexonenand_region(mtd, from); + from += mtd->eraseregions[rgn].erasesize; + } else + from += (1 << bbm->bbt_erase_shift); }
return 0; @@ -152,7 +158,7 @@ static int onenand_isbad_bbt(struct mtd_info *mtd, loff_t offs, int allowbbt) uint8_t res;
/* Get block number * 2 */ - block = (int)(offs >> (bbm->bbt_erase_shift - 1)); + block = (int) (onenand_block(this, offs) << 1); res = (bbm->bbt[block >> 3] >> (block & 0x06)) & 0x03;
MTDDEBUG (MTD_DEBUG_LEVEL2, @@ -191,7 +197,7 @@ int onenand_scan_bbt(struct mtd_info *mtd, struct nand_bbt_descr *bd) struct bbm_info *bbm = this->bbm; int len, ret = 0;
- len = mtd->size >> (this->erase_shift + 2); + len = this->chipsize >> (this->erase_shift + 2); /* Allocate memory (2bit per block) */ bbm->bbt = malloc(len); if (!bbm->bbt) { diff --git a/drivers/mtd/onenand/onenand_uboot.c b/drivers/mtd/onenand/onenand_uboot.c index 9823b5b..c642016 100644 --- a/drivers/mtd/onenand/onenand_uboot.c +++ b/drivers/mtd/onenand/onenand_uboot.c @@ -40,8 +40,10 @@ void onenand_init(void)
onenand_scan(&onenand_mtd, 1);
+ if (onenand_chip.device_id & DEVICE_IS_FLEXONENAND) + puts("Flex-"); puts("OneNAND: "); - print_size(onenand_mtd.size, "\n"); + print_size(onenand_chip.chipsize, "\n");
#ifdef CONFIG_MTD_DEVICE /* diff --git a/include/linux/mtd/onenand.h b/include/linux/mtd/onenand.h index 06f7baf..0bfbec0 100644 --- a/include/linux/mtd/onenand.h +++ b/include/linux/mtd/onenand.h @@ -20,8 +20,9 @@ #include <linux/mtd/compat.h> #include <linux/mtd/bbm.h>
+#define MAX_DIES 2 #define MAX_BUFFERRAM 2 -#define MAX_ONENAND_PAGESIZE (2048 + 64) +#define MAX_ONENAND_PAGESIZE (4096 + 128)
/* Scan and identify a OneNAND device */ extern int onenand_scan (struct mtd_info *mtd, int max_chips); @@ -39,9 +40,14 @@ struct onenand_bufferram { /** * struct onenand_chip - OneNAND Private Flash Chip Data * @param base [BOARDSPECIFIC] address to access OneNAND + * @dies: [INTERN][FLEXONENAND] number of dies on chip + * @boundary: [INTERN][FLEXONENAND] Boundary of the dies + * @diesize: [INTERN][FLEXONENAND] Size of the dies * @param chipsize [INTERN] the size of one chip for multichip arrays * @param device_id [INTERN] device ID * @param verstion_id [INTERN] version ID + * @technology [INTERN] describes the internal NAND array technology such as SLC or MLC. + * @density_mask: [INTERN] chip density, used for DDP devices * @param options [BOARDSPECIFIC] various chip options. They can partly be set to inform onenand_scan about * @param erase_shift [INTERN] number of address bits in a block * @param page_shift [INTERN] number of address bits in a page @@ -64,9 +70,13 @@ struct onenand_bufferram { */ struct onenand_chip { void __iomem *base; + unsigned int dies; + unsigned int boundary[MAX_DIES]; + unsigned int diesize[MAX_DIES]; unsigned int chipsize; unsigned int device_id; unsigned int version_id; + unsigned int technology; unsigned int density_mask; unsigned int options;
@@ -124,6 +134,8 @@ struct onenand_chip { #define ONENAND_SET_BUFFERRAM0(this) (this->bufferram_index = 0) #define ONENAND_SET_BUFFERRAM1(this) (this->bufferram_index = 1)
+#define FLEXONENAND(this) (this->device_id & DEVICE_IS_FLEXONENAND) +#define ONENAND_IS_MLC(this) (this->technology & ONENAND_TECHNOLOGY_IS_MLC) #define ONENAND_IS_DDP(this) \ (this->device_id & ONENAND_DEVICE_IS_DDP)
@@ -156,4 +168,6 @@ struct onenand_manufacturers { int onenand_bbt_read_oob(struct mtd_info *mtd, loff_t from, struct mtd_oob_ops *ops);
+unsigned int onenand_block(struct onenand_chip *this, loff_t addr); +int flexonenand_region(struct mtd_info *mtd, loff_t addr); #endif /* __LINUX_MTD_ONENAND_H */ diff --git a/include/linux/mtd/onenand_regs.h b/include/linux/mtd/onenand_regs.h index fc63380..bc2bb4a 100644 --- a/include/linux/mtd/onenand_regs.h +++ b/include/linux/mtd/onenand_regs.h @@ -67,6 +67,9 @@ /* * Device ID Register F001h (R) */ +#define DEVICE_IS_FLEXONENAND (1 << 9) +#define FLEXONENAND_PI_MASK (0x3ff) +#define FLEXONENAND_PI_UNLOCK_SHIFT (14) #define ONENAND_DEVICE_DENSITY_MASK (0xf) #define ONENAND_DEVICE_DENSITY_SHIFT (4) #define ONENAND_DEVICE_IS_DDP (1 << 3) @@ -84,6 +87,11 @@ #define ONENAND_VERSION_PROCESS_SHIFT (8)
/* + * Technology Register F006h (R) + */ +#define ONENAND_TECHNOLOGY_IS_MLC (1 << 0) + +/* * Start Address 1 F100h (R/W) */ #define ONENAND_DDP_SHIFT (15) @@ -93,7 +101,7 @@ /* * Start Address 8 F107h (R/W) */ -#define ONENAND_FPA_MASK (0x3f) +#define ONENAND_FPA_MASK (0x7f) #define ONENAND_FPA_SHIFT (2) #define ONENAND_FSA_MASK (0x03)
@@ -105,7 +113,7 @@ #define ONENAND_BSA_BOOTRAM (0 << 2) #define ONENAND_BSA_DATARAM0 (2 << 2) #define ONENAND_BSA_DATARAM1 (3 << 2) -#define ONENAND_BSC_MASK (0x03) +#define ONENAND_BSC_MASK (0x07)
/* * Command Register F220h (R/W) @@ -123,9 +131,14 @@ #define ONENAND_CMD_ERASE (0x94) #define ONENAND_CMD_RESET (0xF0) #define ONENAND_CMD_READID (0x90) +#define FLEXONENAND_CMD_RESET (0xF3) +#define FLEXONENAND_CMD_PI_UPDATE (0x05) +#define FLEXONENAND_CMD_PI_ACCESS (0x66) +#define FLEXONENAND_CMD_RECOVER_LSB (0x05)
/* NOTE: Those are not *REAL* commands */ #define ONENAND_CMD_BUFFERRAM (0x1978) +#define FLEXONENAND_CMD_READ_PI (0x1985)
/* * System Configuration 1 Register F221h (R, R/W) @@ -186,5 +199,6 @@ #define ONENAND_ECC_1BIT (1 << 0) #define ONENAND_ECC_2BIT (1 << 1) #define ONENAND_ECC_2BIT_ALL (0xAAAA) +#define FLEXONENAND_UNCORRECTABLE_ERROR (0x1010)
#endif /* __ONENAND_REG_H */ diff --git a/include/onenand_uboot.h b/include/onenand_uboot.h index 49da9d0..92279d5 100644 --- a/include/onenand_uboot.h +++ b/include/onenand_uboot.h @@ -23,6 +23,7 @@ struct erase_info; struct onenand_chip;
extern struct mtd_info onenand_mtd; +extern struct onenand_chip onenand_chip;
/* board */ extern void onenand_board_init(struct mtd_info *); @@ -38,6 +39,15 @@ extern int onenand_erase(struct mtd_info *mtd, struct erase_info *instr);
extern char *onenand_print_device_info(int device, int version);
+extern unsigned onenand_block(struct onenand_chip *this, loff_t addr); + +extern loff_t onenand_addr(struct onenand_chip *this, int block); + +extern int flexonenand_region(struct mtd_info *mtd, loff_t addr); + +extern int flexonenand_set_boundary(struct mtd_info *mtd, int die, + int boundary, int lock); + /* S3C64xx */ extern void s3c64xx_onenand_init(struct mtd_info *); extern void s3c64xx_set_width_regs(struct onenand_chip *);
- loff_t ofs = 0;
- int die = 0, boundary;
- if (ONENAND_IS_DDP(this) && block >= this->density_mask) {
die = 1;
- boundary = this->boundary[die];
- ofs += block << (this->erase_shift - 1);
- if (block > (boundary + 1))
- return ofs;
You're missing some (loff_t) casts that are in Linux, here and elsewhere.
This is not a header file; let GCC decide when to inline. Note that this function is not specified as inline in Linux.
There are some other fairly significant differences with Linux later in the patch -- is this due to missing functionality that u-boot doesn't need, or something else?
-Scott
Hi Scott,
- loff_t ofs = 0;
- block -= this->density_mask;
- die = 1;
- ofs = this->diesize[0];
- ofs += (block - boundary - 1) << (this->erase_shift - 1);
- return ofs;
Accepted and corrected
Yes, there are certain functionalities that OneNAND doesn't need in U-Boot. Sending the updated patches.
Regards, Amul Kumar Saha
H Scott,
If you you don't mind, I'm okay to this patch. Can you merge it?
Thank you, Kyungmin Park
On Wed, Nov 4, 2009 at 2:00 PM, Amul Kumar Saha amul.saha@samsung.com wrote:
Hi Scott,
- loff_t ofs = 0;
- die = 1;
- return ofs;
This is not a header file; let GCC decide when to inline. Â Note that this function is not specified as inline in Linux.
Signed-off-by: Rohit Hagargundgi h.rohit@samsung.com Signed-off-by: Amul Kumar Saha amul.saha@samsung.com --- drivers/mtd/onenand/onenand_base.c | 740 +++++++++++++++++++++++++++++++----- drivers/mtd/onenand/onenand_bbt.c | 14 drivers/mtd/onenand/onenand_uboot.c | 4 include/linux/mtd/onenand.h | 16 include/linux/mtd/onenand_regs.h | 18 include/onenand_uboot.h | 10 6 files changed, 701 insertions(+), 101 deletions(-)
diff --git a/drivers/mtd/onenand/onenand_base.c b/drivers/mtd/onenand/onenand_base.c index 368fa6e..16814e7 100644 --- a/drivers/mtd/onenand/onenand_base.c +++ b/drivers/mtd/onenand/onenand_base.c @@ -9,6 +9,11 @@ * auto-placement support, read-while load support, various fixes * Copyright (C) Nokia Corporation, 2007 * + * Rohit Hagargundgi <h.rohit at samsung.com>, + * Amul Kumar Saha amul.saha@samsung.com: + * Flex-OneNAND support + * Copyright (C) Samsung Electronics, 2009 + * * This program is free software; you can redistribute it and/or modify * it under the terms of the GNU General Public License version 2 as * published by the Free Software Foundation. @@ -24,7 +29,7 @@ #include <malloc.h>
/* It should access 16-bit instead of 8-bit */ -static inline void *memcpy_16(void *dst, const void *src, unsigned int len) +static void *memcpy_16(void *dst, const void *src, unsigned int len) { void *ret = dst; short *d = dst; @@ -37,6 +42,27 @@ static inline void *memcpy_16(void *dst, const void *src, unsigned int len) }
/** + * onenand_oob_128 - oob info for Flex-Onenand with 4KB page + * For now, we expose only 64 out of 80 ecc bytes + */ +static struct nand_ecclayout onenand_oob_128 = { + .eccbytes = 64, + .eccpos = { + 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, + 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, + 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, + 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, + 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, + 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, + 102, 103, 104, 105 + }, + .oobfree = { + {2, 4}, {18, 4}, {34, 4}, {50, 4}, + {66, 4}, {82, 4}, {98, 4}, {114, 4} + } +}; + +/** * onenand_oob_64 - oob info for large (2KB) page */ static struct nand_ecclayout onenand_oob_64 = { @@ -74,6 +100,14 @@ static const unsigned char ffchars[] = { 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* 48 */ 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* 64 */ + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* 80 */ + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* 96 */ + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* 112 */ + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* 128 */ };
/** @@ -180,6 +214,85 @@ static int onenand_buffer_address(int dataram1, int sectors, int count) }
/** + * flexonenand_block - Return block number for flash address + * @param this - OneNAND device structure + * @param addr - Address for which block number is needed + */ +static unsigned int flexonenand_block(struct onenand_chip *this, loff_t addr) +{ + unsigned int boundary, blk, die = 0; + + if (ONENAND_IS_DDP(this) && addr >= this->diesize[0]) { + die = 1; + addr -= this->diesize[0]; + } + + boundary = this->boundary[die]; + + blk = addr >> (this->erase_shift - 1); + if (blk > boundary) + blk = (blk + boundary + 1) >> 1; + + blk += die ? this->density_mask : 0; + return blk; +} + +unsigned int onenand_block(struct onenand_chip *this, loff_t addr) +{ + if (!FLEXONENAND(this)) + return addr >> this->erase_shift; + return flexonenand_block(this, addr); +} + +/** + * flexonenand_addr - Return address of the block + * @this: OneNAND device structure + * @block: Block number on Flex-OneNAND + * + * Return address of the block + */ +static loff_t flexonenand_addr(struct onenand_chip *this, int block) +{ + loff_t ofs = 0; + int die = 0, boundary; + + if (ONENAND_IS_DDP(this) && block >= this->density_mask) { + block -= this->density_mask; + die = 1; + ofs = this->diesize[0]; + } + + boundary = this->boundary[die]; + ofs += (loff_t) block << (this->erase_shift - 1); + if (block > (boundary + 1)) + ofs += (loff_t) (block - boundary - 1) + << (this->erase_shift - 1); + return ofs; +} + +loff_t onenand_addr(struct onenand_chip *this, int block) +{ + if (!FLEXONENAND(this)) + return (loff_t) block << this->erase_shift; + return flexonenand_addr(this, block); +} + +/** + * flexonenand_region - [Flex-OneNAND] Return erase region of addr + * @param mtd MTD device structure + * @param addr address whose erase region needs to be identified + */ +int flexonenand_region(struct mtd_info *mtd, loff_t addr) +{ + int i; + + for (i = 0; i < mtd->numeraseregions; i++) + if (addr < mtd->eraseregions[i].offset) + break; + return i - 1; +} + +/** * onenand_get_density - [DEFAULT] Get OneNAND density * @param dev_id OneNAND device ID * @@ -205,10 +318,11 @@ static int onenand_command(struct mtd_info *mtd, int cmd, loff_t addr, size_t len) { struct onenand_chip *this = mtd->priv; - int value, readcmd = 0; + int value; int block, page; + /* Now we use page size operation */ - int sectors = 4, count = 4; + int sectors = 0, count = 0;
/* Address translation */ switch (cmd) { @@ -220,15 +334,28 @@ static int onenand_command(struct mtd_info *mtd, int cmd, loff_t addr, page = -1; break;
+ case FLEXONENAND_CMD_READ_PI: + cmd = ONENAND_CMD_READ; + block = addr * this->density_mask; + page = 0; + break; + default: - block = (int)(addr >> this->erase_shift); - page = (int)(addr >> this->page_shift); + block = onenand_block(this, addr); + page = (int) (addr + - onenand_addr(this, block)) >> this->page_shift; page &= this->page_mask; break; } @@ -240,8 +367,11 @@ static int onenand_command(struct mtd_info *mtd, int cmd, loff_t addr, this->write_word(value, this->base + ONENAND_REG_START_ADDRESS2);
return 0; } @@ -252,7 +382,7 @@ static int onenand_command(struct mtd_info *mtd, int cmd, loff_t addr, this->write_word(value, this->base + ONENAND_REG_START_ADDRESS1);
- /* Write 'DFS, FBA' of Flash */ + /* Select DataRAM for DDP */ value = onenand_bufferram_address(this, block); this->write_word(value, this->base + ONENAND_REG_START_ADDRESS2); @@ -262,10 +392,14 @@ static int onenand_command(struct mtd_info *mtd, int cmd, loff_t addr, int dataram;
default: @@ -292,6 +426,29 @@ static int onenand_command(struct mtd_info *mtd, int cmd, loff_t addr, }
/** + * onenand_read_ecc - return ecc status + * @param this onenand chip structure + */ +static int onenand_read_ecc(struct onenand_chip *this) +{ + int ecc, i; + + if (!FLEXONENAND(this)) + return this->read_word(this->base + ONENAND_REG_ECC_STATUS); + + for (i = 0; i < 4; i++) { + ecc = this->read_word(this->base + + ((ONENAND_REG_ECC_STATUS + i) << 1)); + if (likely(!ecc)) + continue; + if (ecc & FLEXONENAND_UNCORRECTABLE_ERROR) + return ONENAND_ECC_2BIT_ALL; + } + + return 0; +} + +/** * onenand_wait - [DEFAULT] wait until the command is done * @param mtd MTD device structure * @param state state to select the max. timeout value @@ -305,7 +462,7 @@ static int onenand_wait(struct mtd_info *mtd, int state) struct onenand_chip *this = mtd->priv; unsigned int flags = ONENAND_INT_MASTER; unsigned int interrupt = 0; - unsigned int ctrl, ecc; + unsigned int ctrl;
while (1) { interrupt = this->read_word(this->base + ONENAND_REG_INTERRUPT); @@ -315,6 +472,14 @@ static int onenand_wait(struct mtd_info *mtd, int state)
+ if (interrupt & ONENAND_INT_READ) { + int ecc = onenand_read_ecc(this); + if (ecc & ONENAND_ECC_2BIT_ALL) { + printk("onenand_wait: ECC error = 0x%04x\n", ecc); + return -EBADMSG; + } + } + if (ctrl & ONENAND_CTRL_ERROR) { printk("onenand_wait: controller error = 0x%04x\n", ctrl); if (ctrl & ONENAND_CTRL_LOCK) @@ -324,14 +489,6 @@ static int onenand_wait(struct mtd_info *mtd, int state) return -EIO; }
return 0; } @@ -499,7 +656,7 @@ static int onenand_check_bufferram(struct mtd_info *mtd, loff_t addr)
if (found && ONENAND_IS_DDP(this)) { /* Select DataRAM for DDP */ - int block = (int) (addr >> this->erase_shift); + int block = onenand_block(this, addr); int value = onenand_bufferram_address(this, block); this->write_word(value, this->base + ONENAND_REG_START_ADDRESS2); } @@ -632,6 +789,45 @@ static int onenand_transfer_auto_oob(struct mtd_info *mtd, uint8_t *buf, }
/** + * onenand_recover_lsb - [Flex-OneNAND] Recover LSB page data + * @param mtd MTD device structure + * @param addr address to recover + * @param status return value from onenand_wait + * + * MLC NAND Flash cell has paired pages - LSB page and MSB page. LSB page has + * lower page address and MSB page has higher page address in paired pages. + * If power off occurs during MSB page program, the paired LSB page data can + * become corrupt. LSB page recovery read is a way to read LSB page though page + * data are corrupted. When uncorrectable error occurs as a result of LSB page + * read after power up, issue LSB page recovery read. + */ +static int onenand_recover_lsb(struct mtd_info *mtd, loff_t addr, int status) +{ + struct onenand_chip *this = mtd->priv; + int i; + + /* Recovery is only for Flex-OneNAND */ + if (!FLEXONENAND(this)) + return status; + + /* check if we failed due to uncorrectable error */ + if (status != -EBADMSG && status != ONENAND_BBT_READ_ECC_ERROR) + return status; + + /* check if address lies in MLC region */ + i = flexonenand_region(mtd, addr); + if (mtd->eraseregions[i].erasesize < (1 << this->erase_shift)) + return status; + + printk("onenand_recover_lsb:" + "Attempting to recover from uncorrectable read\n"); + + /* Issue the LSB page recovery command */ + this->command(mtd, FLEXONENAND_CMD_RECOVER_LSB, addr, this->writesize); + return this->wait(mtd, FL_READING); +} + +/** * onenand_read_ops_nolock - [OneNAND Interface] OneNAND read main and/or out-of-band * @param mtd MTD device structure * @param from offset to read from @@ -673,6 +869,7 @@ static int onenand_read_ops_nolock(struct mtd_info *mtd, loff_t from, stats = mtd->ecc_stats;
/* Do first load to bufferRAM */ if (read < len) { @@ -680,6 +877,8 @@ static int onenand_read_ops_nolock(struct mtd_info *mtd, loff_t from, this->main_buf = buf; this->command(mtd, ONENAND_CMD_READ, from, writesize); ret = this->wait(mtd, FL_READING); + if (unlikely(ret)) + ret = onenand_recover_lsb(mtd, from, ret); onenand_update_bufferram(mtd, from, !ret); if (ret == -EBADMSG) ret = 0; @@ -694,7 +893,7 @@ static int onenand_read_ops_nolock(struct mtd_info *mtd, loff_t from, while (!ret) { /* If there is more to load then start next load */ from += thislen; - if (read + thislen < len) { + if (!ONENAND_IS_MLC(this) && read + thislen < len) { this->main_buf = buf + thislen; this->command(mtd, ONENAND_CMD_READ, from, writesize); /* @@ -728,6 +927,16 @@ static int onenand_read_ops_nolock(struct mtd_info *mtd, loff_t from, oobcolumn = 0; }
+ if (ONENAND_IS_MLC(this) && (read + thislen < len)) { + this->command(mtd, ONENAND_CMD_READ, from, writesize); + ret = this->wait(mtd, FL_READING); + if (unlikely(ret)) + ret = onenand_recover_lsb(mtd, from, ret); + onenand_update_bufferram(mtd, from, !ret); + if (ret == -EBADMSG) + ret = 0; + } + /* See if we are done */ read += thislen; if (read == len) @@ -735,16 +944,19 @@ static int onenand_read_ops_nolock(struct mtd_info *mtd, loff_t from, /* Set up for next read from bufferRAM */ if (unlikely(boundary)) this->write_word(ONENAND_DDP_CHIP1, this->base + ONENAND_REG_START_ADDRESS2); - ONENAND_SET_NEXT_BUFFERRAM(this); + if (!ONENAND_IS_MLC(this)) + ONENAND_SET_NEXT_BUFFERRAM(this); buf += thislen; thislen = min_t(int, writesize, len - read); column = 0;
/* @@ -781,7 +993,7 @@ static int onenand_read_oob_nolock(struct mtd_info *mtd, loff_t from, size_t len = ops->ooblen; mtd_oob_mode_t mode = ops->mode; u_char *buf = ops->oobbuf; - int ret = 0; + int ret = 0, readcmd;
@@ -812,16 +1024,21 @@ static int onenand_read_oob_nolock(struct mtd_info *mtd, loff_t from,
ret = this->wait(mtd, FL_READING); + if (unlikely(ret)) + ret = onenand_recover_lsb(mtd, from, ret); + if (ret && ret != -EBADMSG) { printk(KERN_ERR "onenand_read_oob_nolock: read failed = 0x%x\n", ret); break; @@ -945,9 +1162,12 @@ static int onenand_bbt_wait(struct mtd_info *mtd, int state) ctrl = this->read_word(this->base + ONENAND_REG_CTRL_STATUS);
if (interrupt & ONENAND_INT_READ) { - int ecc = this->read_word(this->base + ONENAND_REG_ECC_STATUS); - if (ecc & ONENAND_ECC_2BIT_ALL) + int ecc = onenand_read_ecc(this); + if (ecc & ONENAND_ECC_2BIT_ALL) { + printk(KERN_INFO "onenand_bbt_wait: ecc error = 0x%04x" + ", controller = 0x%04x\n", ecc, ctrl); return ONENAND_BBT_READ_ERROR; + } } else { printk(KERN_ERR "onenand_bbt_wait: read timeout!" "ctrl=0x%04x intr=0x%04x\n", ctrl, interrupt); @@ -976,12 +1196,14 @@ int onenand_bbt_read_oob(struct mtd_info *mtd, loff_t from, { struct onenand_chip *this = mtd->priv; int read = 0, thislen, column; - int ret = 0; + int ret = 0, readcmd; size_t len = ops->ooblen; u_char *buf = ops->oobbuf;
@@ -1002,11 +1224,14 @@ int onenand_bbt_read_oob(struct mtd_info *mtd, loff_t from, thislen = min_t(int, thislen, len);
@@ -1044,9 +1269,11 @@ static int onenand_verify_oob(struct mtd_info *mtd, const u_char *buf, loff_t to { struct onenand_chip *this = mtd->priv; u_char *oob_buf = this->oob_buf; - int status, i; + int status, i, readcmd;
- this->command(mtd, ONENAND_CMD_READOOB, to, mtd->oobsize); + readcmd = ONENAND_IS_MLC(this) ? ONENAND_CMD_READ : ONENAND_CMD_READOOB; + + this->command(mtd, readcmd, to, mtd->oobsize); onenand_update_bufferram(mtd, to, 0); status = this->wait(mtd, FL_READING); if (status) @@ -1291,7 +1518,7 @@ static int onenand_write_oob_nolock(struct mtd_info *mtd, loff_t to, { struct onenand_chip *this = mtd->priv; int column, ret = 0, oobsize; - int written = 0; + int written = 0, oobcmd; u_char *oobbuf; size_t len = ops->ooblen; const u_char *buf = ops->oobbuf; @@ -1333,6 +1560,8 @@ static int onenand_write_oob_nolock(struct mtd_info *mtd, loff_t to,
+ oobcmd = ONENAND_IS_MLC(this) ? ONENAND_CMD_PROG : ONENAND_CMD_PROGOOB; + /* Loop until all data write */ while (written < len) { int thislen = min_t(int, oobsize, len - written); @@ -1348,7 +1577,14 @@ static int onenand_write_oob_nolock(struct mtd_info *mtd, loff_t to, memcpy(oobbuf + column, buf, thislen); this->write_bufferram(mtd, 0, ONENAND_SPARERAM, oobbuf, 0, mtd->oobsize);
onenand_update_bufferram(mtd, to, 0); if (ONENAND_IS_2PLANE(this)) { @@ -1475,34 +1711,54 @@ int onenand_erase(struct mtd_info *mtd, struct erase_info *instr) { struct onenand_chip *this = mtd->priv; unsigned int block_size; - loff_t addr; - int len; - int ret = 0; - - MTDDEBUG (MTD_DEBUG_LEVEL3, - "onenand_erase: start = 0x%08x, len = %i\n", - (unsigned int)instr->addr, (unsigned int)instr->len); + loff_t addr = instr->addr; + unsigned int len = instr->len; + int ret = 0, i; + struct mtd_erase_region_info *region = NULL; + unsigned int region_end = 0;
- block_size = (1 << this->erase_shift); + MTDDEBUG(MTD_DEBUG_LEVEL3, "onenand_erase: start = 0x%08x, len = %i\n", + (unsigned int) addr, len);
- /* Length must align on block boundary */ - if (unlikely(instr->len & (block_size - 1))) { - MTDDEBUG (MTD_DEBUG_LEVEL0, - "onenand_erase: Length not block aligned\n"); - return -EINVAL; + if (FLEXONENAND(this)) { + /* Find the eraseregion of this address */ + i = flexonenand_region(mtd, addr); + region = &mtd->eraseregions[i]; + + block_size = region->erasesize; + region_end = region->offset + + region->erasesize * region->numblocks; + + /* Start address within region must align on block boundary. + * Erase region's start offset is always block start address. + */ + if (unlikely((addr - region->offset) & (block_size - 1))) { + MTDDEBUG(MTD_DEBUG_LEVEL0, "onenand_erase:" + " Unaligned address\n"); + return -EINVAL; + } + } else { + block_size = 1 << this->erase_shift; + + /* Start address must align on block boundary */ + if (unlikely(addr & (block_size - 1))) { + MTDDEBUG(MTD_DEBUG_LEVEL0, "onenand_erase:" + "Unaligned address\n"); + return -EINVAL; + } }
@@ -1512,9 +1768,6 @@ int onenand_erase(struct mtd_info *mtd, struct erase_info *instr) onenand_get_device(mtd, FL_ERASING);
while (len) { @@ -1541,14 +1794,7 @@ int onenand_erase(struct mtd_info *mtd, struct erase_info *instr) else MTDDEBUG (MTD_DEBUG_LEVEL0, "onenand_erase: " "Failed erase, block %d\n", - (unsigned)(addr >> this->erase_shift)); - if (ret == -EPERM) - printk("onenand_erase: " - "Device is write protected!!!\n"); - else - printk("onenand_erase: " - "Failed erase, block %d\n", - (unsigned)(addr >> this->erase_shift)); + onenand_block(this, addr)); instr->state = MTD_ERASE_FAILED; instr->fail_addr = addr;
@@ -1557,6 +1803,23 @@ int onenand_erase(struct mtd_info *mtd, struct erase_info *instr)
len -= block_size; addr += block_size; + + if (addr == region_end) { + if (!len) + break; + region++; + + block_size = region->erasesize; + region_end = region->offset + + region->erasesize * region->numblocks; + + if (len & (block_size - 1)) { + /* This has been checked at MTD + * partitioning level. */ + printk("onenand_erase: Unaligned address\n"); + goto erase_exit; + } + } }
instr->state = MTD_ERASE_DONE; @@ -1634,7 +1897,7 @@ static int onenand_default_block_markbad(struct mtd_info *mtd, loff_t ofs) int block;
@@ -1682,8 +1945,8 @@ static int onenand_do_lock_cmd(struct mtd_info *mtd, loff_t ofs, size_t len, int int start, end, block, value, status; int wp_status_mask;
if (cmd == ONENAND_CMD_LOCK) wp_status_mask = ONENAND_WP_LS; @@ -1718,7 +1981,7 @@ static int onenand_do_lock_cmd(struct mtd_info *mtd, loff_t ofs, size_t len, int }
/* Block lock scheme */ - for (block = start; block < start + end; block++) { + for (block = start; block < end; block++) { /* Set block address */ value = onenand_block_address(this, block); this->write_word(value, this->base + ONENAND_REG_START_ADDRESS1); @@ -1831,7 +2094,7 @@ static void onenand_unlock_all(struct mtd_info *mtd) { struct onenand_chip *this = mtd->priv; loff_t ofs = 0; - size_t len = this->chipsize; + size_t len = mtd->size;
if (this->options & ONENAND_HAS_UNLOCK_ALL) { /* Set start block address */ @@ -1847,14 +2110,12 @@ static void onenand_unlock_all(struct mtd_info *mtd) & ONENAND_CTRL_ONGO) continue;
/* Workaround for all block unlock in DDP */ - if (ONENAND_IS_DDP(this)) { + if (ONENAND_IS_DDP(this) && !FLEXONENAND(this)) { /* All blocks on another chip */ ofs = this->chipsize >> 1; len = this->chipsize >> 1; @@ -1906,6 +2167,14 @@ static void onenand_check_features(struct mtd_info *mtd) break; }
+ if (ONENAND_IS_MLC(this)) + this->options &= ~ONENAND_HAS_2PLANE; + + if (FLEXONENAND(this)) { + this->options &= ~ONENAND_HAS_CONT_LOCK; + this->options |= ONENAND_HAS_UNLOCK_ALL; + } + if (this->options & ONENAND_HAS_CONT_LOCK) printk(KERN_DEBUG "Lock scheme is Continuous Lock\n"); if (this->options & ONENAND_HAS_UNLOCK_ALL) @@ -1922,16 +2191,18 @@ static void onenand_check_features(struct mtd_info *mtd) */ char *onenand_print_device_info(int device, int version) { - int vcc, demuxed, ddp, density; + int vcc, demuxed, ddp, density, flexonenand; char *dev_info = malloc(80); char *p = dev_info;
@@ -1957,7 +2228,7 @@ static int onenand_check_maf(int manuf) char *name; int i;
@@ -1974,6 +2245,263 @@ static int onenand_check_maf(int manuf) }
/** +* flexonenand_get_boundary - Reads the SLC boundary +* @param onenand_info - onenand info structure +* +* Fill up boundary[] field in onenand_chip +**/ +static int flexonenand_get_boundary(struct mtd_info *mtd) +{ + struct onenand_chip *this = mtd->priv; + unsigned int die, bdry; + int ret, syscfg, locked; + + /* Disable ECC */ + syscfg = this->read_word(this->base + ONENAND_REG_SYS_CFG1); + this->write_word((syscfg | 0x0100), this->base + ONENAND_REG_SYS_CFG1); + + for (die = 0; die < this->dies; die++) { + this->command(mtd, FLEXONENAND_CMD_PI_ACCESS, die, 0); + this->wait(mtd, FL_SYNCING); + + this->command(mtd, FLEXONENAND_CMD_READ_PI, die, 0); + ret = this->wait(mtd, FL_READING); + + bdry = this->read_word(this->base + ONENAND_DATARAM); + if ((bdry >> FLEXONENAND_PI_UNLOCK_SHIFT) == 3) + locked = 0; + else + locked = 1; + this->boundary[die] = bdry & FLEXONENAND_PI_MASK; + + this->command(mtd, ONENAND_CMD_RESET, 0, 0); + ret = this->wait(mtd, FL_RESETING); + + printk(KERN_INFO "Die %d boundary: %d%s\n", die, + this->boundary[die], locked ? "(Locked)" : "(Unlocked)"); + } + + /* Enable ECC */ + this->write_word(syscfg, this->base + ONENAND_REG_SYS_CFG1); + return 0; +} + +/** + * flexonenand_get_size - Fill up fields in onenand_chip and mtd_info + * boundary[], diesize[], mtd->size, mtd->erasesize, + * mtd->eraseregions + * @param mtd - MTD device structure + */ +static void flexonenand_get_size(struct mtd_info *mtd) +{ + struct onenand_chip *this = mtd->priv; + int die, ofs, i, eraseshift, density; + int blksperdie, maxbdry; + + density = onenand_get_density(this->device_id); + blksperdie = ((loff_t)(16 << density) << 20) >> (this->erase_shift); + blksperdie >>= ONENAND_IS_DDP(this) ? 1 : 0; + maxbdry = blksperdie - 1; + eraseshift = this->erase_shift - 1; + + mtd->numeraseregions = this->dies << 1; + + /* This fills up the device boundary */ + flexonenand_get_boundary(mtd); + die = ofs = 0; + i = -1; + for (; die < this->dies; die++) { + if (!die || this->boundary[die-1] != maxbdry) { + i++; + mtd->eraseregions[i].offset = ofs; + mtd->eraseregions[i].erasesize = 1 << eraseshift; + mtd->eraseregions[i].numblocks = + this->boundary[die] + 1; + ofs += mtd->eraseregions[i].numblocks << eraseshift; + eraseshift++; + } else { + mtd->numeraseregions -= 1; + mtd->eraseregions[i].numblocks += + this->boundary[die] + 1; + ofs += (this->boundary[die] + 1) << (eraseshift - 1); + } + if (this->boundary[die] != maxbdry) { + i++; + mtd->eraseregions[i].offset = ofs; + mtd->eraseregions[i].erasesize = 1 << eraseshift; + mtd->eraseregions[i].numblocks = maxbdry ^ + this->boundary[die]; + ofs += mtd->eraseregions[i].numblocks << eraseshift; + eraseshift--; + } else + mtd->numeraseregions -= 1; + } + + /* Expose MLC erase size except when all blocks are SLC */ + mtd->erasesize = 1 << this->erase_shift; + if (mtd->numeraseregions == 1) + mtd->erasesize >>= 1; + + printk(KERN_INFO "Device has %d eraseregions\n", mtd->numeraseregions); + for (i = 0; i < mtd->numeraseregions; i++) + printk(KERN_INFO "[offset: 0x%08x, erasesize: 0x%05x," + " numblocks: %04u]\n", mtd->eraseregions[i].offset, + mtd->eraseregions[i].erasesize, + mtd->eraseregions[i].numblocks); + + for (die = 0, mtd->size = 0; die < this->dies; die++) { + this->diesize[die] = (loff_t) (blksperdie << this->erase_shift); + this->diesize[die] -= (loff_t) (this->boundary[die] + 1) + << (this->erase_shift - 1); + mtd->size += this->diesize[die]; + } +} + +/** + * flexonenand_check_blocks_erased - Check if blocks are erased + * @param mtd_info - mtd info structure + * @param start - first erase block to check + * @param end - last erase block to check + * + * Converting an unerased block from MLC to SLC + * causes byte values to change. Since both data and its ECC + * have changed, reads on the block give uncorrectable error. + * This might lead to the block being detected as bad. + * + * Avoid this by ensuring that the block to be converted is + * erased. + */ +static int flexonenand_check_blocks_erased(struct mtd_info *mtd, + int start, int end) +{ + struct onenand_chip *this = mtd->priv; + int i, ret; + int block; + struct mtd_oob_ops ops = { + .mode = MTD_OOB_PLACE, + .ooboffs = 0, + .ooblen = mtd->oobsize, + .datbuf = NULL, + .oobbuf = this->oob_buf, + }; + loff_t addr; + + printk(KERN_DEBUG "Check blocks from %d to %d\n", start, end); + + for (block = start; block <= end; block++) { + addr = flexonenand_addr(this, block); + if (onenand_block_isbad_nolock(mtd, addr, 0)) + continue; + + /* + * Since main area write results in ECC write to spare, + * it is sufficient to check only ECC bytes for change. + */ + ret = onenand_read_oob_nolock(mtd, addr, &ops); + if (ret) + return ret; + + for (i = 0; i < mtd->oobsize; i++) + if (this->oob_buf[i] != 0xff) + break; + + if (i != mtd->oobsize) { + printk(KERN_WARNING "Block %d not erased.\n", block); + return 1; + } + } + + return 0; +} + +/** + * flexonenand_set_boundary - Writes the SLC boundary + * @param mtd - mtd info structure + */ +int flexonenand_set_boundary(struct mtd_info *mtd, int die, + int boundary, int lock) +{ + struct onenand_chip *this = mtd->priv; + int ret, density, blksperdie, old, new, thisboundary; + loff_t addr; + + if (die >= this->dies) + return -EINVAL; + + if (boundary == this->boundary[die]) + return 0; + + density = onenand_get_density(this->device_id); + blksperdie = ((16 << density) << 20) >> this->erase_shift; + blksperdie >>= ONENAND_IS_DDP(this) ? 1 : 0; + + if (boundary >= blksperdie) { + printk("flexonenand_set_boundary:" + "Invalid boundary value. " + "Boundary not changed.\n"); + return -EINVAL; + } + + /* Check if converting blocks are erased */ + old = this->boundary[die] + (die * this->density_mask); + new = boundary + (die * this->density_mask); + ret = flexonenand_check_blocks_erased(mtd, min(old, new) + + 1, max(old, new)); + if (ret) { + printk(KERN_ERR "flexonenand_set_boundary: Please erase blocks before boundary change\n"); + return ret; + } + + this->command(mtd, FLEXONENAND_CMD_PI_ACCESS, die, 0); + this->wait(mtd, FL_SYNCING); + + /* Check is boundary is locked */ + this->command(mtd, FLEXONENAND_CMD_READ_PI, die, 0); + ret = this->wait(mtd, FL_READING); + + thisboundary = this->read_word(this->base + ONENAND_DATARAM); + if ((thisboundary >> FLEXONENAND_PI_UNLOCK_SHIFT) != 3) { + printk(KERN_ERR "flexonenand_set_boundary: boundary locked\n"); + goto out; + } + + printk(KERN_INFO "flexonenand_set_boundary: Changing die %d boundary: %d%s\n", + die, boundary, lock ? "(Locked)" : "(Unlocked)"); + + boundary &= FLEXONENAND_PI_MASK; + boundary |= lock ? 0 : (3 << FLEXONENAND_PI_UNLOCK_SHIFT); + + addr = die ? this->diesize[0] : 0; + this->command(mtd, ONENAND_CMD_ERASE, addr, 0); + ret = this->wait(mtd, FL_ERASING); + if (ret) { + printk("flexonenand_set_boundary:" + "Failed PI erase for Die %d\n", die); + goto out; + } + + this->write_word(boundary, this->base + ONENAND_DATARAM); + this->command(mtd, ONENAND_CMD_PROG, addr, 0); + ret = this->wait(mtd, FL_WRITING); + if (ret) { + printk("flexonenand_set_boundary:" + "Failed PI write for Die %d\n", die); + goto out; + } + + this->command(mtd, FLEXONENAND_CMD_PI_UPDATE, die, 0); + ret = this->wait(mtd, FL_WRITING); +out: + this->write_word(ONENAND_CMD_RESET, this->base + ONENAND_REG_COMMAND); + this->wait(mtd, FL_RESETING); + if (!ret) + /* Recalculate device size on boundary change*/ + flexonenand_get_size(mtd); + + return ret; +} + +/** * onenand_probe - [OneNAND Interface] Probe the OneNAND device * @param mtd MTD device structure * @@ -2016,48 +2544,69 @@ static int onenand_probe(struct mtd_info *mtd) maf_id = this->read_word(this->base + ONENAND_REG_MANUFACTURER_ID); dev_id = this->read_word(this->base + ONENAND_REG_DEVICE_ID); ver_id = this->read_word(this->base + ONENAND_REG_VERSION_ID); + this->technology = this->read_word(this->base + ONENAND_REG_TECHNOLOGY);
/* Check OneNAND features */ onenand_check_features(mtd); @@ -2149,6 +2698,11 @@ int onenand_scan(struct mtd_info *mtd, int maxchips) * Allow subpage writes up to oobsize. */ switch (mtd->oobsize) { + case 128: + this->ecclayout = &onenand_oob_128; + mtd->subpage_sft = 0; + break; + case 64: this->ecclayout = &onenand_oob_64; mtd->subpage_sft = 2; diff --git a/drivers/mtd/onenand/onenand_bbt.c b/drivers/mtd/onenand/onenand_bbt.c index d538f95..1354877 100644 --- a/drivers/mtd/onenand/onenand_bbt.c +++ b/drivers/mtd/onenand/onenand_bbt.c @@ -69,6 +69,7 @@ static int create_bbt(struct mtd_info *mtd, uint8_t * buf, loff_t from; size_t readlen, ooblen; struct mtd_oob_ops ops; + int rgn;
#ifdef CONFIG_MTD_DEVICE /* diff --git a/include/linux/mtd/onenand.h b/include/linux/mtd/onenand.h index 9a6f317..68e174e 100644 --- a/include/linux/mtd/onenand.h +++ b/include/linux/mtd/onenand.h @@ -20,8 +20,9 @@ #include <linux/mtd/compat.h> #include <linux/mtd/bbm.h>
@@ -157,4 +169,6 @@ struct onenand_manufacturers { int onenand_bbt_read_oob(struct mtd_info *mtd, loff_t from, struct mtd_oob_ops *ops);
+unsigned int onenand_block(struct onenand_chip *this, loff_t addr); +int flexonenand_region(struct mtd_info *mtd, loff_t addr); #endif /* __LINUX_MTD_ONENAND_H */ diff --git a/include/linux/mtd/onenand_regs.h b/include/linux/mtd/onenand_regs.h index 07fed1c..8449a3c 100644 --- a/include/linux/mtd/onenand_regs.h +++ b/include/linux/mtd/onenand_regs.h @@ -67,6 +67,9 @@ /* * Device ID Register F001h (R) */ +#define DEVICE_IS_FLEXONENAND (1 << 9) +#define FLEXONENAND_PI_MASK (0x3ff) +#define FLEXONENAND_PI_UNLOCK_SHIFT (14) #define ONENAND_DEVICE_DENSITY_MASK (0xf) #define ONENAND_DEVICE_DENSITY_SHIFT (4) #define ONENAND_DEVICE_IS_DDP (1 << 3) @@ -84,6 +87,11 @@ #define ONENAND_VERSION_PROCESS_SHIFT (8)
/* * Command Register F220h (R/W) @@ -125,9 +133,14 @@ #define ONENAND_CMD_ERASE_VERIFY (0x71) #define ONENAND_CMD_RESET (0xF0) #define ONENAND_CMD_READID (0x90) +#define FLEXONENAND_CMD_RESET (0xF3) +#define FLEXONENAND_CMD_PI_UPDATE (0x05) +#define FLEXONENAND_CMD_PI_ACCESS (0x66) +#define FLEXONENAND_CMD_RECOVER_LSB (0x05)
/* * System Configuration 1 Register F221h (R, R/W) @@ -190,5 +203,6 @@ #define ONENAND_ECC_2BIT (1 << 1) #define ONENAND_ECC_2BIT_ALL (0xAAAA) #define ONENAND_ECC_4BIT_UNCORRECTABLE (0x1010) +#define FLEXONENAND_UNCORRECTABLE_ERROR (0x1010)
On Wed, Nov 04, 2009 at 10:37:17AM +0530, Amul Kumar Saha wrote:
This patch adds support for Flex-OneNAND devices.
A couple 64-bit offset nits...
- struct onenand_chip *this = mtd->priv;
- int die, ofs, i, eraseshift, density;
[snip]
- for (; die < this->dies; die++) {
i++;
"ofs" should be loff_t.
- printk(KERN_INFO "Device has %d eraseregions\n", mtd->numeraseregions);
- for (i = 0; i < mtd->numeraseregions; i++)
offset is uint64_t, so use %08llx. This gives a warning...
If you want, I can just fix these up -- but give it a retest afterward.
-Scott
Hi Scott,
[snip]
- if (!die || this->boundary[die-1] != maxbdry) {
- i++;
- mtd->eraseregions[i].offset = ofs;
- mtd->eraseregions[i].erasesize = 1 << eraseshift;
- mtd->eraseregions[i].numblocks =
- this->boundary[die] + 1;
- ofs += mtd->eraseregions[i].numblocks << eraseshift;
Accepted and Corrected.
- printk(KERN_INFO "[offset: 0x%08x, erasesize: 0x%05x,"
- " numblocks: %04u]\n", mtd->eraseregions[i].offset,
- mtd->eraseregions[i].erasesize,
- mtd->eraseregions[i].numblocks);
Thanks for considering fixing these yourself. I'll send the updated patches anyway.
Regards, Amul
Signed-off-by: Rohit Hagargundgi h.rohit@samsung.com Signed-off-by: Amul Kumar Saha amul.saha@samsung.com --- drivers/mtd/onenand/onenand_base.c | 742 +++++++++++++++++++++++++++++++----- drivers/mtd/onenand/onenand_bbt.c | 14 drivers/mtd/onenand/onenand_uboot.c | 4 include/linux/mtd/onenand.h | 16 include/linux/mtd/onenand_regs.h | 18 include/onenand_uboot.h | 10 6 files changed, 703 insertions(+), 101 deletions(-)
diff --git a/drivers/mtd/onenand/onenand_base.c b/drivers/mtd/onenand/onenand_base.c index 368fa6e..f9273ab 100644 --- a/drivers/mtd/onenand/onenand_base.c +++ b/drivers/mtd/onenand/onenand_base.c @@ -9,6 +9,11 @@ * auto-placement support, read-while load support, various fixes * Copyright (C) Nokia Corporation, 2007 * + * Rohit Hagargundgi <h.rohit at samsung.com>, + * Amul Kumar Saha amul.saha@samsung.com: + * Flex-OneNAND support + * Copyright (C) Samsung Electronics, 2009 + * * This program is free software; you can redistribute it and/or modify * it under the terms of the GNU General Public License version 2 as * published by the Free Software Foundation. @@ -24,7 +29,7 @@ #include <malloc.h>
+ case FLEXONENAND_CMD_PI_ACCESS: + /* addr contains die index */ + block = addr * this->density_mask; + page = -1; + break; + case ONENAND_CMD_ERASE: case ONENAND_CMD_BUFFERRAM: - block = (int)(addr >> this->erase_shift); + block = onenand_block(this, addr); page = -1; break;
- /* Switch to the next data buffer */ - ONENAND_SET_NEXT_BUFFERRAM(this); + if (ONENAND_IS_MLC(this)) + ONENAND_SET_BUFFERRAM0(this); + else + /* Switch to the next data buffer */ + ONENAND_SET_NEXT_BUFFERRAM(this);
switch (cmd) { + case FLEXONENAND_CMD_RECOVER_LSB: case ONENAND_CMD_READ: case ONENAND_CMD_READOOB: - dataram = ONENAND_SET_NEXT_BUFFERRAM(this); - readcmd = 1; + if (ONENAND_IS_MLC(this)) + dataram = ONENAND_SET_BUFFERRAM0(this); + else + dataram = ONENAND_SET_NEXT_BUFFERRAM(this); + break;
- if (interrupt & ONENAND_INT_READ) { - ecc = this->read_word(this->base + ONENAND_REG_ECC_STATUS); - if (ecc & ONENAND_ECC_2BIT_ALL) { - MTDDEBUG (MTD_DEBUG_LEVEL0, - "onenand_wait: ECC error = 0x%04x\n", ecc); - return -EBADMSG; - } - }
/* Read-while-load method */ + /* Note: We can't use this feature in MLC */
- /* Now wait for load */ - ret = this->wait(mtd, FL_READING); - onenand_update_bufferram(mtd, from, !ret); - if (ret == -EBADMSG) - ret = 0; + if (!ONENAND_IS_MLC(this)) { + /* Now wait for load */ + ret = this->wait(mtd, FL_READING); + onenand_update_bufferram(mtd, from, !ret); + if (ret == -EBADMSG) + ret = 0; + } }
from += ops->ooboffs;
+ readcmd = ONENAND_IS_MLC(this) ? ONENAND_CMD_READ : ONENAND_CMD_READOOB; + while (read < len) { thislen = oobsize - column; thislen = min_t(int, thislen, len);
this->spare_buf = buf; - this->command(mtd, ONENAND_CMD_READOOB, from, mtd->oobsize); + this->command(mtd, readcmd, from, mtd->oobsize);
onenand_update_bufferram(mtd, from, 0);
MTDDEBUG(MTD_DEBUG_LEVEL3, "onenand_bbt_read_oob: from = 0x%08x, len = %zi\n", (unsigned int) from, len);
+ readcmd = ONENAND_IS_MLC(this) ? ONENAND_CMD_READ : ONENAND_CMD_READOOB; + /* Initialize return value */ ops->oobretlen = 0;
ret = this->bbt_wait(mtd, FL_READING); + if (unlikely(ret)) + ret = onenand_recover_lsb(mtd, from, ret); + if (ret) break;
oobbuf = this->oob_buf;
- this->command(mtd, ONENAND_CMD_PROGOOB, to, mtd->oobsize); + if (ONENAND_IS_MLC(this)) { + /* Set main area of DataRAM to 0xff*/ + memset(this->page_buf, 0xff, mtd->writesize); + this->write_bufferram(mtd, 0, ONENAND_DATARAM, + this->page_buf, 0, mtd->writesize); + } + + this->command(mtd, oobcmd, to, mtd->oobsize);
@@ -1974,6 +2245,265 @@ static int onenand_check_maf(int manuf) }
/** +* flexonenand_get_boundary - Reads the SLC boundary +* @param onenand_info - onenand info structure +* +* Fill up boundary[] field in onenand_chip +**/ +static int flexonenand_get_boundary(struct mtd_info *mtd) +{ + struct onenand_chip *this = mtd->priv; + unsigned int die, bdry; + int ret, syscfg, locked; + + /* Disable ECC */ + syscfg = this->read_word(this->base + ONENAND_REG_SYS_CFG1); + this->write_word((syscfg | 0x0100), this->base + ONENAND_REG_SYS_CFG1); + + for (die = 0; die < this->dies; die++) { + this->command(mtd, FLEXONENAND_CMD_PI_ACCESS, die, 0); + this->wait(mtd, FL_SYNCING); + + this->command(mtd, FLEXONENAND_CMD_READ_PI, die, 0); + ret = this->wait(mtd, FL_READING); + + bdry = this->read_word(this->base + ONENAND_DATARAM); + if ((bdry >> FLEXONENAND_PI_UNLOCK_SHIFT) == 3) + locked = 0; + else + locked = 1; + this->boundary[die] = bdry & FLEXONENAND_PI_MASK; + + this->command(mtd, ONENAND_CMD_RESET, 0, 0); + ret = this->wait(mtd, FL_RESETING); + + printk(KERN_INFO "Die %d boundary: %d%s\n", die, + this->boundary[die], locked ? "(Locked)" : "(Unlocked)"); + } + + /* Enable ECC */ + this->write_word(syscfg, this->base + ONENAND_REG_SYS_CFG1); + return 0; +} + +/** + * flexonenand_get_size - Fill up fields in onenand_chip and mtd_info + * boundary[], diesize[], mtd->size, mtd->erasesize, + * mtd->eraseregions + * @param mtd - MTD device structure + */ +static void flexonenand_get_size(struct mtd_info *mtd) +{ + struct onenand_chip *this = mtd->priv; + int die, i, eraseshift, density; + int blksperdie, maxbdry; + loff_t ofs; + + density = onenand_get_density(this->device_id); + blksperdie = ((loff_t)(16 << density) << 20) >> (this->erase_shift); + blksperdie >>= ONENAND_IS_DDP(this) ? 1 : 0; + maxbdry = blksperdie - 1; + eraseshift = this->erase_shift - 1; + + mtd->numeraseregions = this->dies << 1; + + /* This fills up the device boundary */ + flexonenand_get_boundary(mtd); + die = 0; + ofs = 0; + i = -1; + for (; die < this->dies; die++) { + if (!die || this->boundary[die-1] != maxbdry) { + i++; + mtd->eraseregions[i].offset = ofs; + mtd->eraseregions[i].erasesize = 1 << eraseshift; + mtd->eraseregions[i].numblocks = + this->boundary[die] + 1; + ofs += mtd->eraseregions[i].numblocks << eraseshift; + eraseshift++; + } else { + mtd->numeraseregions -= 1; + mtd->eraseregions[i].numblocks += + this->boundary[die] + 1; + ofs += (this->boundary[die] + 1) << (eraseshift - 1); + } + if (this->boundary[die] != maxbdry) { + i++; + mtd->eraseregions[i].offset = ofs; + mtd->eraseregions[i].erasesize = 1 << eraseshift; + mtd->eraseregions[i].numblocks = maxbdry ^ + this->boundary[die]; + ofs += mtd->eraseregions[i].numblocks << eraseshift; + eraseshift--; + } else + mtd->numeraseregions -= 1; + } + + /* Expose MLC erase size except when all blocks are SLC */ + mtd->erasesize = 1 << this->erase_shift; + if (mtd->numeraseregions == 1) + mtd->erasesize >>= 1; + + printk(KERN_INFO "Device has %d eraseregions\n", mtd->numeraseregions); + for (i = 0; i < mtd->numeraseregions; i++) + printk(KERN_INFO "[offset: 0x%08llx, erasesize: 0x%05x," + " numblocks: %04u]\n", mtd->eraseregions[i].offset, + mtd->eraseregions[i].erasesize, + mtd->eraseregions[i].numblocks); + + for (die = 0, mtd->size = 0; die < this->dies; die++) { + this->diesize[die] = (loff_t) (blksperdie << this->erase_shift); + this->diesize[die] -= (loff_t) (this->boundary[die] + 1) + << (this->erase_shift - 1); + mtd->size += this->diesize[die]; + } +} + +/** + * flexonenand_check_blocks_erased - Check if blocks are erased + * @param mtd_info - mtd info structure + * @param start - first erase block to check + * @param end - last erase block to check + * + * Converting an unerased block from MLC to SLC + * causes byte values to change. Since both data and its ECC + * have changed, reads on the block give uncorrectable error. + * This might lead to the block being detected as bad. + * + * Avoid this by ensuring that the block to be converted is + * erased. + */ +static int flexonenand_check_blocks_erased(struct mtd_info *mtd, + int start, int end) +{ + struct onenand_chip *this = mtd->priv; + int i, ret; + int block; + struct mtd_oob_ops ops = { + .mode = MTD_OOB_PLACE, + .ooboffs = 0, + .ooblen = mtd->oobsize, + .datbuf = NULL, + .oobbuf = this->oob_buf, + }; + loff_t addr; + + printk(KERN_DEBUG "Check blocks from %d to %d\n", start, end); + + for (block = start; block <= end; block++) { + addr = flexonenand_addr(this, block); + if (onenand_block_isbad_nolock(mtd, addr, 0)) + continue; + + /* + * Since main area write results in ECC write to spare, + * it is sufficient to check only ECC bytes for change. + */ + ret = onenand_read_oob_nolock(mtd, addr, &ops); + if (ret) + return ret; + + for (i = 0; i < mtd->oobsize; i++) + if (this->oob_buf[i] != 0xff) + break; + + if (i != mtd->oobsize) { + printk(KERN_WARNING "Block %d not erased.\n", block); + return 1; + } + } + + return 0; +} + +/** + * flexonenand_set_boundary - Writes the SLC boundary + * @param mtd - mtd info structure + */ +int flexonenand_set_boundary(struct mtd_info *mtd, int die, + int boundary, int lock) +{ + struct onenand_chip *this = mtd->priv; + int ret, density, blksperdie, old, new, thisboundary; + loff_t addr; + + if (die >= this->dies) + return -EINVAL; + + if (boundary == this->boundary[die]) + return 0; + + density = onenand_get_density(this->device_id); + blksperdie = ((16 << density) << 20) >> this->erase_shift; + blksperdie >>= ONENAND_IS_DDP(this) ? 1 : 0; + + if (boundary >= blksperdie) { + printk("flexonenand_set_boundary:" + "Invalid boundary value. " + "Boundary not changed.\n"); + return -EINVAL; + } + + /* Check if converting blocks are erased */ + old = this->boundary[die] + (die * this->density_mask); + new = boundary + (die * this->density_mask); + ret = flexonenand_check_blocks_erased(mtd, min(old, new) + + 1, max(old, new)); + if (ret) { + printk(KERN_ERR "flexonenand_set_boundary: Please erase blocks before boundary change\n"); + return ret; + } + + this->command(mtd, FLEXONENAND_CMD_PI_ACCESS, die, 0); + this->wait(mtd, FL_SYNCING); + + /* Check is boundary is locked */ + this->command(mtd, FLEXONENAND_CMD_READ_PI, die, 0); + ret = this->wait(mtd, FL_READING); + + thisboundary = this->read_word(this->base + ONENAND_DATARAM); + if ((thisboundary >> FLEXONENAND_PI_UNLOCK_SHIFT) != 3) { + printk(KERN_ERR "flexonenand_set_boundary: boundary locked\n"); + goto out; + } + + printk(KERN_INFO "flexonenand_set_boundary: Changing die %d boundary: %d%s\n", + die, boundary, lock ? "(Locked)" : "(Unlocked)"); + + boundary &= FLEXONENAND_PI_MASK; + boundary |= lock ? 0 : (3 << FLEXONENAND_PI_UNLOCK_SHIFT); + + addr = die ? this->diesize[0] : 0; + this->command(mtd, ONENAND_CMD_ERASE, addr, 0); + ret = this->wait(mtd, FL_ERASING); + if (ret) { + printk("flexonenand_set_boundary:" + "Failed PI erase for Die %d\n", die); + goto out; + } + + this->write_word(boundary, this->base + ONENAND_DATARAM); + this->command(mtd, ONENAND_CMD_PROG, addr, 0); + ret = this->wait(mtd, FL_WRITING); + if (ret) { + printk("flexonenand_set_boundary:" + "Failed PI write for Die %d\n", die); + goto out; + } + + this->command(mtd, FLEXONENAND_CMD_PI_UPDATE, die, 0); + ret = this->wait(mtd, FL_WRITING); +out: + this->write_word(ONENAND_CMD_RESET, this->base + ONENAND_REG_COMMAND); + this->wait(mtd, FL_RESETING); + if (!ret) + /* Recalculate device size on boundary change*/ + flexonenand_get_size(mtd); + + return ret; +} + +/** * onenand_probe - [OneNAND Interface] Probe the OneNAND device * @param mtd MTD device structure * @@ -2016,48 +2546,69 @@ static int onenand_probe(struct mtd_info *mtd) maf_id = this->read_word(this->base + ONENAND_REG_MANUFACTURER_ID); dev_id = this->read_word(this->base + ONENAND_REG_DEVICE_ID); ver_id = this->read_word(this->base + ONENAND_REG_VERSION_ID); + this->technology = this->read_word(this->base + ONENAND_REG_TECHNOLOGY);
/* Check OneNAND features */ onenand_check_features(mtd); @@ -2149,6 +2700,11 @@ int onenand_scan(struct mtd_info *mtd, int maxchips) * Allow subpage writes up to oobsize. */ switch (mtd->oobsize) { + case 128: + this->ecclayout = &onenand_oob_128; + mtd->subpage_sft = 0; + break; + case 64: this->ecclayout = &onenand_oob_64; mtd->subpage_sft = 2; diff --git a/drivers/mtd/onenand/onenand_bbt.c b/drivers/mtd/onenand/onenand_bbt.c index d538f95..1354877 100644 --- a/drivers/mtd/onenand/onenand_bbt.c +++ b/drivers/mtd/onenand/onenand_bbt.c @@ -69,6 +69,7 @@ static int create_bbt(struct mtd_info *mtd, uint8_t * buf, loff_t from; size_t readlen, ooblen; struct mtd_oob_ops ops; + int rgn;
Applied patches 1 and 2 to next.
-Scott
Amul Kumar Saha
Kyungmin Park
Scott Wood
