[PATCH] fw_env: rename variables holding env data content
Rename "addr0" and "addr1" to "buf0" and "buf1" accordingly. Name "addr" suggests that variable contains a numeric value being some kind of address. Name "buf" is de facto a standard name for pointer to allocated memory for reading data to.
While at it drop redundant checks for NULL before calling free().
Signed-off-by: Rafał Miłecki rafal@milecki.pl --- tools/env/fw_env.c | 39 ++++++++++++++++++--------------------- 1 file changed, 18 insertions(+), 21 deletions(-)
diff --git a/tools/env/fw_env.c b/tools/env/fw_env.c index bf8b7ba304..0347e9d15a 100644 --- a/tools/env/fw_env.c +++ b/tools/env/fw_env.c @@ -1416,11 +1416,11 @@ int fw_env_open(struct env_opts *opts) { int crc0, crc0_ok; unsigned char flag0; - void *addr0 = NULL; + void *buf0 = NULL;
int crc1, crc1_ok; unsigned char flag1; - void *addr1 = NULL; + void *buf1 = NULL;
int ret;
@@ -1430,8 +1430,8 @@ int fw_env_open(struct env_opts *opts) if (parse_config(opts)) /* should fill envdevices */ return -EINVAL;
- addr0 = calloc(1, CUR_ENVSIZE); - if (addr0 == NULL) { + buf0 = calloc(1, CUR_ENVSIZE); + if (buf0 == NULL) { fprintf(stderr, "Not enough memory for environment (%ld bytes)\n", CUR_ENVSIZE); @@ -1440,13 +1440,13 @@ int fw_env_open(struct env_opts *opts) }
dev_current = 0; - if (flash_io(O_RDONLY, addr0, CUR_ENVSIZE)) { + if (flash_io(O_RDONLY, buf0, CUR_ENVSIZE)) { ret = -EIO; goto open_cleanup; }
if (!have_redund_env) { - struct env_image_single *single = addr0; + struct env_image_single *single = buf0;
crc0 = crc32(0, (uint8_t *)single->data, ENV_SIZE); crc0_ok = (crc0 == single->crc); @@ -1458,12 +1458,12 @@ int fw_env_open(struct env_opts *opts) environment.dirty = 1; }
- environment.image = addr0; + environment.image = buf0; environment.crc = &single->crc; environment.flags = NULL; environment.data = single->data; } else { - struct env_image_redundant *redundant0 = addr0; + struct env_image_redundant *redundant0 = buf0; struct env_image_redundant *redundant1;
crc0 = crc32(0, (uint8_t *)redundant0->data, ENV_SIZE); @@ -1472,17 +1472,17 @@ int fw_env_open(struct env_opts *opts) flag0 = redundant0->flags;
dev_current = 1; - addr1 = calloc(1, CUR_ENVSIZE); - if (addr1 == NULL) { + buf1 = calloc(1, CUR_ENVSIZE); + if (buf1 == NULL) { fprintf(stderr, "Not enough memory for environment (%ld bytes)\n", CUR_ENVSIZE); ret = -ENOMEM; goto open_cleanup; } - redundant1 = addr1; + redundant1 = buf1;
- if (flash_io(O_RDONLY, addr1, CUR_ENVSIZE)) { + if (flash_io(O_RDONLY, buf1, CUR_ENVSIZE)) { ret = -EIO; goto open_cleanup; } @@ -1571,17 +1571,17 @@ int fw_env_open(struct env_opts *opts) * flags before writing out */ if (dev_current) { - environment.image = addr1; + environment.image = buf1; environment.crc = &redundant1->crc; environment.flags = &redundant1->flags; environment.data = redundant1->data; - free(addr0); + free(buf0); } else { - environment.image = addr0; + environment.image = buf0; environment.crc = &redundant0->crc; environment.flags = &redundant0->flags; environment.data = redundant0->data; - free(addr1); + free(buf1); } #ifdef DEBUG fprintf(stderr, "Selected env in %s\n", DEVNAME(dev_current)); @@ -1590,11 +1590,8 @@ int fw_env_open(struct env_opts *opts) return 0;
open_cleanup: - if (addr0) - free(addr0); - - if (addr1) - free(addr1); + free(buf0); + free(buf1);
return ret; }
Rafał Miłecki
