[U-Boot] [Patch v2] lib/fdtdec: Fix fdt_addr_t and fdt_size_t typedef
fdt_addr_t is a physical address. It can be either 64-bit or 32-bit, depending on the architecture. It should be phys_addr_t instead of u64 or u32. Similarly, fdt_size_t is changed to phys_size_t.
Signed-off-by: York Sun yorksun@freescale.com CC: Simon Glass sjg@chromium.org --- Change log v2: Rebase code to latest master, add change to fsl_dspi.c.
drivers/spi/fsl_dspi.c | 4 ++-- include/fdtdec.h | 7 +++---- lib/fdtdec.c | 4 ++-- 3 files changed, 7 insertions(+), 8 deletions(-)
diff --git a/drivers/spi/fsl_dspi.c b/drivers/spi/fsl_dspi.c index 7928531..326f040 100644 --- a/drivers/spi/fsl_dspi.c +++ b/drivers/spi/fsl_dspi.c @@ -664,8 +664,8 @@ static int fsl_dspi_ofdata_to_platdata(struct udevice *bus) plat->speed_hz = fdtdec_get_int(blob, node, "spi-max-frequency", FSL_DSPI_DEFAULT_SCK_FREQ);
- debug("DSPI: regs=0x%llx, max-frequency=%d, endianess=%s, num-cs=%d\n", - (u64)plat->regs_addr, plat->speed_hz, + debug("DSPI: regs=0x%pa, max-frequency=%d, endianess=%s, num-cs=%d\n", + &plat->regs_addr, plat->speed_hz, plat->flags & DSPI_FLAG_REGMAP_ENDIAN_BIG ? "be" : "le", plat->num_chipselect);
diff --git a/include/fdtdec.h b/include/fdtdec.h index 2323603..c61734c 100644 --- a/include/fdtdec.h +++ b/include/fdtdec.h @@ -14,6 +14,7 @@ * changes to support FDT are minimized. */
+#include <linux/types.h> #include <libfdt.h> #include <pci.h>
@@ -21,15 +22,13 @@ * A typedef for a physical address. Note that fdt data is always big * endian even on a litle endian machine. */ +typedef phys_addr_t fdt_addr_t; +typedef phys_size_t fdt_size_t; #ifdef CONFIG_PHYS_64BIT -typedef u64 fdt_addr_t; -typedef u64 fdt_size_t; #define FDT_ADDR_T_NONE (-1ULL) #define fdt_addr_to_cpu(reg) be64_to_cpu(reg) #define fdt_size_to_cpu(reg) be64_to_cpu(reg) #else -typedef u32 fdt_addr_t; -typedef u32 fdt_size_t; #define FDT_ADDR_T_NONE (-1U) #define fdt_addr_to_cpu(reg) be32_to_cpu(reg) #define fdt_size_to_cpu(reg) be32_to_cpu(reg) diff --git a/lib/fdtdec.c b/lib/fdtdec.c index 9c6b361..3ff8b66 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -102,8 +102,8 @@ fdt_addr_t fdtdec_get_addr_size(const void *blob, int node, size = (fdt_size_t *)((char *)cell + sizeof(fdt_addr_t)); *sizep = fdt_size_to_cpu(*size); - debug("addr=%08lx, size=%llx\n", - (ulong)addr, (u64)*sizep); + debug("addr=%pa, size=%llx\n", + &addr, (u64)*sizep); } else { debug("%08lx\n", (ulong)addr); }
Hi York,
Can you please put that change into a different patch? For both:
- changes to support FDT are minimized.
@@ -21,15 +22,13 @@
- A typedef for a physical address. Note that fdt data is always big
- endian even on a litle endian machine.
-- 1.7.9.5
Sure. I have to rebase it anyway after this commit 5b34436.
York
On 08/02/2015 03:30 PM, Simon Glass wrote:
Hi York,
@@ -21,15 +22,13 @@
-- 1.7.9.5
York Sun
