[U-Boot] [PATCH 0/3]: arm:Kirkwood network driver fixes
Hi!
Three patches to fix various network driver issues on kirkwood. Patch 3 is a repost of the patch sent earlier today which is rebased on top of the other two.
// Simon
Signed-off-by: Simon Kagstrom simon.kagstrom@netinsight.net --- drivers/net/kirkwood_egiga.c | 14 ++++++++++---- 1 files changed, 10 insertions(+), 4 deletions(-)
diff --git a/drivers/net/kirkwood_egiga.c b/drivers/net/kirkwood_egiga.c index f31fefc..065e335 100644 --- a/drivers/net/kirkwood_egiga.c +++ b/drivers/net/kirkwood_egiga.c @@ -38,6 +38,8 @@ #include <asm/arch/kirkwood.h> #include "kirkwood_egiga.h"
+#define KIRKWOOD_PHY_ADR_REQUEST 0xee + /* * smi_reg_read - miiphy_read callback function. * @@ -52,7 +54,8 @@ static int smi_reg_read(char *devname, u8 phy_adr, u8 reg_ofs, u16 * data) u32 timeout;
/* Phyadr read request */ - if (phy_adr == 0xEE && reg_ofs == 0xEE) { + if (phy_adr == KIRKWOOD_PHY_ADR_REQUEST && + reg_ofs == KIRKWOOD_PHY_ADR_REQUEST) { /* */ *data = (u16) (KWGBEREG_RD(regs->phyadr) & PHYADR_MASK); return 0; @@ -127,7 +130,8 @@ static int smi_reg_write(char *devname, u8 phy_adr, u8 reg_ofs, u16 data) u32 timeout;
/* Phyadr write request*/ - if (phy_adr == 0xEE && reg_ofs == 0xEE) { + if (phy_adr == KIRKWOOD_PHY_ADR_REQUEST && + reg_ofs == KIRKWOOD_PHY_ADR_REQUEST) { KWGBEREG_WR(regs->phyadr, data); return 0; } @@ -444,7 +448,8 @@ static int kwgbe_init(struct eth_device *dev) #if (defined (CONFIG_MII) || defined (CONFIG_CMD_MII)) \ && defined (CONFIG_SYS_FAULT_ECHO_LINK_DOWN) u16 phyadr; - miiphy_read(dev->name, 0xEE, 0xEE, &phyadr); + miiphy_read(dev->name, KIRKWOOD_PHY_ADR_REQUEST, + KIRKWOOD_PHY_ADR_REQUEST, &phyadr); if (!miiphy_link(dev->name, phyadr)) { printf("%s: No link on %s\n", __FUNCTION__, dev->name); return -1; @@ -670,7 +675,8 @@ int kirkwood_egiga_initialize(bd_t * bis) #if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) miiphy_register(dev->name, smi_reg_read, smi_reg_write); /* Set phy address of the port */ - miiphy_write(dev->name, 0xEE, 0xEE, PHY_BASE_ADR + devnum); + miiphy_write(dev->name, KIRKWOOD_PHY_ADR_REQUEST, + KIRKWOOD_PHY_ADR_REQUEST, PHY_BASE_ADR + devnum); #endif } return 0;
-----Original Message----- From: u-boot-bounces@lists.denx.de [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Simon Kagstrom Sent: Thursday, August 20, 2009 1:42 PM Cc: U-Boot ML Subject: [U-Boot] [PATCH 1/3]: arm:kirkwood Define kirkwood phy address magic number
define this in header file
Basically this is needed in drivers/net/phy/mv88e61xx.c for multi chip support in this case we need to define this in include/miiphy.h. which conflicts with other phy address definition, that's why not done earlier
It makes more sense to add APIs miiphy_read/write_phyadr to miiutils
Regards.. Prafulla . .
On Thu, 20 Aug 2009 02:40:48 -0700 Prafulla Wadaskar prafulla@marvell.com wrote:
But is this really general functionality? miiphy.h is something I suppose should be generic between phys and not contain device-specific things like this.
Perhaps we should revive the patches that move out the phy initialization from sheevaplug.c and place the define and some implementation there?
// Simon
-----Original Message----- From: Simon Kagstrom [mailto:simon.kagstrom@netinsight.net] Sent: Thursday, August 20, 2009 5:17 PM To: Prafulla Wadaskar Cc: U-Boot ML; Ashish Karkare; Prabhanjan Sarnaik Subject: Re: [U-Boot] [PATCH 1/3]: arm:kirkwood Define kirkwood phy address magic number
multi chip support
Agreed, Current PHY support need to be re-architected to support switches in generic ways This is old pending issue, may be we should re-trigger it again after scheduled release
Sure the code can be abstracted from sheevaplug as well as rd6281a for MV88E1116 initialization. In the beginning I had posted my first patch as separate driver for MV88E1116, but again this is gated due to above rework to be done
// Simon
On Thu, 20 Aug 2009 20:20:08 -0700 Prafulla Wadaskar prafulla@marvell.com wrote:
multi chip support
Right. But for now, perhaps it's OK to merge the patch as-is and then correct the location of the define when the restructuring is done?
In the same way, I guess we should postspone moving out PHY initialization from sheevaplug and keep it duplicated until it's clear what to do there?
// Simon
Patches 1-3 applied to net repo.
thanks, Ben
This patch makes the device wait for up to 5 seconds for the link to come up, similar to what many of the other network drivers do. This avoids confusing situations where, e.g., a tftp fails when initiated early after U-boot has started (before the link has come up).
v2: Remove function name from printout
Signed-off-by: Simon Kagstrom simon.kagstrom@netinsight.net --- drivers/net/kirkwood_egiga.c | 20 ++++++++++++++------ 1 files changed, 14 insertions(+), 6 deletions(-)
diff --git a/drivers/net/kirkwood_egiga.c b/drivers/net/kirkwood_egiga.c index 065e335..9f36633 100644 --- a/drivers/net/kirkwood_egiga.c +++ b/drivers/net/kirkwood_egiga.c @@ -400,6 +400,7 @@ static int kwgbe_init(struct eth_device *dev) { struct kwgbe_device *dkwgbe = to_dkwgbe(dev); struct kwgbe_registers *regs = dkwgbe->regs; + int i;
/* setup RX rings */ kwgbe_init_rx_desc_ring(dkwgbe); @@ -447,13 +448,20 @@ static int kwgbe_init(struct eth_device *dev)
#if (defined (CONFIG_MII) || defined (CONFIG_CMD_MII)) \ && defined (CONFIG_SYS_FAULT_ECHO_LINK_DOWN) - u16 phyadr; - miiphy_read(dev->name, KIRKWOOD_PHY_ADR_REQUEST, - KIRKWOOD_PHY_ADR_REQUEST, &phyadr); - if (!miiphy_link(dev->name, phyadr)) { - printf("%s: No link on %s\n", __FUNCTION__, dev->name); - return -1; + /* Wait up to 5s for the link status */ + for (i = 0; i < 5; i++) { + u16 phyadr; + + miiphy_read(dev->name, KIRKWOOD_PHY_ADR_REQUEST, + KIRKWOOD_PHY_ADR_REQUEST, &phyadr); + /* Return if we get link up */ + if (miiphy_link(dev->name, phyadr)) + return 0; + udelay(1000000); } + + printf("No link on %s\n", dev->name); + return -1; #endif return 0; }
U-boot might use non-8-byte-aligned addresses for sending data, which the kwgbe_send doesn't accept (bootp does this for me). This patch copies the data to be sent to a malloced temporary buffer if it is non-aligned.
v2: Malloc send buffer v3: No need to use jumbo frames, use 1518 bytes buffer instead v4: Correct alignment passed to memalign (should be 8!), allocate buffer at initialization(), use PKTSIZE_ALIGN
Signed-off-by: Simon Kagstrom simon.kagstrom@netinsight.net --- drivers/net/kirkwood_egiga.c | 21 +++++++++++++++++---- drivers/net/kirkwood_egiga.h | 1 + 2 files changed, 18 insertions(+), 4 deletions(-)
diff --git a/drivers/net/kirkwood_egiga.c b/drivers/net/kirkwood_egiga.c index 9f36633..479035d 100644 --- a/drivers/net/kirkwood_egiga.c +++ b/drivers/net/kirkwood_egiga.c @@ -500,18 +500,26 @@ static int kwgbe_send(struct eth_device *dev, volatile void *dataptr, struct kwgbe_device *dkwgbe = to_dkwgbe(dev); struct kwgbe_registers *regs = dkwgbe->regs; struct kwgbe_txdesc *p_txdesc = dkwgbe->p_txdesc; + void *p = (void *)dataptr; u32 cmd_sts;
+ /* Copy buffer if it's misaligned */ if ((u32) dataptr & 0x07) { - printf("Err..(%s) xmit dataptr not 64bit aligned\n", - __FUNCTION__); - return -1; + if (datasize > PKTSIZE_ALIGN) { + printf("Non-aligned data too large (%d)\n", + datasize); + return -1; + } + + memcpy(dkwgbe->p_aligned_txbuf, p, datasize); + p = dkwgbe->p_aligned_txbuf; } + p_txdesc->cmd_sts = KWGBE_ZERO_PADDING | KWGBE_GEN_CRC; p_txdesc->cmd_sts |= KWGBE_TX_FIRST_DESC | KWGBE_TX_LAST_DESC; p_txdesc->cmd_sts |= KWGBE_BUFFER_OWNED_BY_DMA; p_txdesc->cmd_sts |= KWGBE_TX_EN_INTERRUPT; - p_txdesc->buf_ptr = (u8 *) dataptr; + p_txdesc->buf_ptr = (u8 *) p; p_txdesc->byte_cnt = datasize;
/* Apply send command using zeroth RXUQ */ @@ -628,8 +636,13 @@ int kirkwood_egiga_initialize(bd_t * bis) * PKTSIZE_ALIGN + 1))) goto error3;
+ if (!(dkwgbe->p_aligned_txbuf = memalign(8, PKTSIZE_ALIGN))) + goto error4; + if (!(dkwgbe->p_txdesc = (struct kwgbe_txdesc *) memalign(PKTALIGN, sizeof(struct kwgbe_txdesc) + 1))) { + free(dkwgbe->p_aligned_txbuf); + error4: free(dkwgbe->p_rxbuf); error3: free(dkwgbe->p_rxdesc); diff --git a/drivers/net/kirkwood_egiga.h b/drivers/net/kirkwood_egiga.h index 9c893d1..16d5214 100644 --- a/drivers/net/kirkwood_egiga.h +++ b/drivers/net/kirkwood_egiga.h @@ -499,6 +499,7 @@ struct kwgbe_device { struct kwgbe_rxdesc *p_rxdesc; struct kwgbe_rxdesc *p_rxdesc_curr; u8 *p_rxbuf; + u8 *p_aligned_txbuf; };
#endif /* __EGIGA_H__ */
-----Original Message----- From: u-boot-bounces@lists.denx.de [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Simon Kagstrom Sent: Thursday, August 20, 2009 1:44 PM To: U-Boot ML Subject: [U-Boot] [PATCH 3/3] [repost]: arm: kirkwood: See to it that sent data is 8-byte aligned
<snip...>
- u8 *p_aligned_txbuf;
1.6.0.4
Ack, Technically this patch is okay, Unless we all agree this to be done in low level drivers :-)
Ben Warren
Prafulla Wadaskar
Simon Kagstrom
