[U-Boot] Fw: Aw: Re: [PATCH v4 0/7] Fix CVE-2018-18440 and CVE-2018-18439
Gesendet: Sonntag, 02. Dezember 2018 um 16:48 Uhr Von: "Frank Wunderlich" frank-w@public-files.de An: "Simon Goldschmidt" simon.k.r.goldschmidt@gmail.com Betreff: Aw: Re: [U-Boot] [PATCH v4 0/7] Fix CVE-2018-18440 and CVE-2018-18439
lmb_init: base: 0x80000000, size: 0x80000000
https://github.com/frank-w/u-boot/commit/e0763252a8e135f00b996fbda7bb1067a19...
Regards Frank
Gesendet: Sonntag, 02. Dezember 2018 um 10:24 Uhr Von: "Simon Goldschmidt" simon.k.r.goldschmidt@gmail.com An: "Frank Wunderlich" frank-w@public-files.de Cc: u-boot@lists.denx.de Betreff: Re: [U-Boot] [PATCH v4 0/7] Fix CVE-2018-18440 and CVE-2018-18439
Am 01.12.2018 um 12:07 schrieb Frank Wunderlich:
forgot error-message and detailed command:
fatload ${device} ${partition} ${scriptaddr} ${bpi}/${board}/${service}/${bootenv} ** Reading file would overwrite reserved memory ** echo ${device} ${partition} ${scriptaddr} ${bpi}/${board}/${service}/${bootenv} mmc 1:1 0x83000000 bananapi/bpi-r2/linux/uEnv.txt
file exists i checked with test, but fatload failed, after reverting the Patches same command works
Hmm, ok. With your configuration, I thought 'gd->bd->bi_dram[0].start' and 'gd->bd->bi_dram[0].size' should be populated and correctly describe your DRAM.
Could you try adding this printf code to the function 'lmb_init_and_reserve':
printf("lmb_init: base: 0x%x, size: 0x%x\n", base, size);
and check if this correctly describes your memory?
Thanks, Simon
regards Frank
Gesendet: Samstag, 01. Dezember 2018 um 10:46 Uhr Von: "Frank Wunderlich" frank-w@public-files.de An: "Simon Goldschmidt" simon.k.r.goldschmidt@gmail.com Cc: u-boot@lists.denx.de Betreff: Re: [U-Boot] [PATCH v4 0/7] Fix CVE-2018-18440 and CVE-2018-18439
Hi Simon
#define CONFIG_SYS_SDRAM_BASE 0x80000000
https://github.com/frank-w/u-boot/blob/a6d0c3f8e992a2e428f05443647fe9f5b13f8...
CONFIG_ARM=y CONFIG_NR_DRAM_BANKS=1 https://github.com/frank-w/u-boot/blob/a6d0c3f8e992a2e428f05443647fe9f5b13f8...
i applied the patch-series on top of my 2018-11 final (currently removed from github)
https://github.com/frank-w/u-boot/tree/bpi-r2_v5
tried ${scriptaddr}=0x83000000
here the fatload-command:
https://github.com/frank-w/u-boot/blob/60bc4075c7744e36058fcba76cd6e6c3a4002...
working before, 0x81000000 and some higher values
HTH
regards Frank
Gesendet: Samstag, 01. Dezember 2018 um 10:25 Uhr Von: "Simon Goldschmidt" simon.k.r.goldschmidt@gmail.com An: "Frank Wunderlich" frank-w@public-files.de Cc: "U-Boot Mailing List" u-boot@lists.denx.de Betreff: Re: [U-Boot] [PATCH v4 0/7] Fix CVE-2018-18440 and CVE-2018-18439
On Fri, Nov 30, 2018 at 6:51 PM Frank Wunderlich frank-w@public-files.de wrote:
Hi Simon,
after applying these Patch-series i cannot load to any address (fatload). Do i need any additional Patch ("fdt: parse "reserved-memory" for memory reservation" sounds like that). Maybe there should be a fallback if no reservation is defined.
No, you should not need additional patches. The code makes use of "lmb" memory allocation just like the "bootm" code does. The "memory reservation" patch you cited only ensures that memory which is marked as reserved in the fdt cannot be overwritten by load.
If it doesn't work for you at all, the available memory is probably not described correctly. Could you check the values of the following defines (or if they are defined at all):
- CONFIG_SYS_SDRAM_BASE
- CONFIG_ARM
- CONFIG_NR_DRAM_BANKS
I might need to improve the DRAM detection code in v5 (which is still pending as I am working on lmb tests).
regards Frank
> Gesendet: Samstag, 24. November 2018 um 15:11 Uhr > Von: "Simon Goldschmidt" simon.k.r.goldschmidt@gmail.com > An: "Tom Rini" trini@konsulko.com, u-boot@lists.denx.de, "Joe Hershberger" joe.hershberger@ni.com > Cc: "Alexey Brodkin" Alexey.Brodkin@synopsys.com, "Heinrich Schuchardt" xypron.glpk@gmx.de, "Michal Simek" michal.simek@xilinx.com, "Alexander Graf" agraf@suse.de, "Andrea Barisani" andrea.barisani@f-secure.com > Betreff: [U-Boot] [PATCH v4 0/7] Fix CVE-2018-18440 and CVE-2018-18439 > > This series fixes CVE-2018-18440 ("insufficient boundary checks in > filesystem image load") by adding restrictions to the 'load' > command and fixes CVE-2018-18439 ("insufficient boundary checks in > network image boot") by adding restrictions to the tftp code. > The functions from lmb.c are used to setup regions of allowed and > reserved memory. Then, the file size to load is checked against these > addresses and loading the file is aborted if it would overwrite > reserved memory. > > The memory reservation code is reused from bootm/image. > > Changes in v4: > - fixed invalid 'if' statement without braces in boot_fdt_reserve_region > - removed patch 7 ("net: remove CONFIG_MCAST_TFTP), adapted patch 8 > > Changes in v3: > - No patch changes, but needed to resend since patman added too many cc > addresses that gmail seemed to detect as spam :-( > > Changes in v2: > - added code to reserve devicetree reserved-memory in lmb > - added tftp fixes (patches 7 and 8) > - fixed a bug in new function lmb_alloc_addr > > Simon Goldschmidt (7): > lib: lmb: reserving overlapping regions should fail > fdt: parse "reserved-memory" for memory reservation > lib: lmb: extend lmb for checks at load time > fs: prevent overwriting reserved memory > bootm: use new common function lmb_init_and_reserve > lmb: remove unused extern declaration > tftp: prevent overwriting reserved memory > > common/bootm.c | 8 ++---- > common/image-fdt.c | 53 +++++++++++++++++++++++++++++------ > fs/fs.c | 56 +++++++++++++++++++++++++++++++++++-- > include/lmb.h | 7 +++-- > lib/lmb.c | 69 ++++++++++++++++++++++++++++++++++++++++++++++ > net/tftp.c | 66 ++++++++++++++++++++++++++++++++++++++------ > 6 files changed, 231 insertions(+), 28 deletions(-) > > -- > 2.17.1 > > _______________________________________________ > U-Boot mailing list > U-Boot@lists.denx.de > https://lists.denx.de/listinfo/u-boot >
Frank Wunderlich
