[PATCH] common: blk: fix comment about blkcache_read return value
The blkcache_read() routine returns 1 (true) to indicate that a block was found in the cache and returned, or 0 if not.
Signed-off-by: Eric Nelson eric@nelint.com --- include/blk.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/blk.h b/include/blk.h index 65db69f5d9..6f541bb2ba 100644 --- a/include/blk.h +++ b/include/blk.h @@ -129,7 +129,7 @@ int blkcache_init(void); * @param blksz - size in bytes of each block * @param buf - buffer to contain cached data * - * @return - '1' if block returned from cache, '0' otherwise. + * @return - 1 if block returned from cache, 0 otherwise. */ int blkcache_read(int iftype, int dev, lbaint_t start, lbaint_t blkcnt,
Eric Nelson
