[U-Boot] [PATCH 0/6] [U-boot] SMDK5420: Add support for FIMD and DP
This patchset adds support for FIMD and DP on SMDK5420.
This patchset has dependency on Rajeshwari's base patchset: [V4] EXYNOS5420: Add SMDK5420 board support http://comments.gmane.org/gmane.comp.boot-loaders.u-boot/170582
Also, for testing we need Naveen's i2c patchset aswell: i2c: improve s3c24x0 with High-speed and new SYS_I2C framework support http://www.mail-archive.com/u-boot@lists.denx.de/msg122679.html
Ajay Kumar (6): [PATCH 1/6] exynos_fb: Remove usage of static defines [PATCH 2/6] arm: exynos: Add RPLL for Exynos5420 [PATCH 3/6] arm: exynos: Add get_lcd_clk and set_lcd_clk callbacks for Exynos5420 [PATCH 4/6] video: exynos_fimd: Add framework to disable FIMD sysmmu [PATCH 5/6] smdk5420: Implement callbacks needed by exynos_fb driver [PATCH 6/6] CONFIG: SMDK5420: Enable FIMD and DP
arch/arm/cpu/armv7/exynos/clock.c | 74 +++++++++++++++- arch/arm/cpu/armv7/exynos/clock_init.h | 3 + arch/arm/cpu/armv7/exynos/clock_init_exynos5.c | 13 +++ arch/arm/cpu/armv7/exynos/exynos5_setup.h | 2 +- arch/arm/dts/exynos5420.dtsi | 5 ++ arch/arm/include/asm/arch-exynos/clk.h | 1 + arch/arm/include/asm/arch-exynos/system.h | 1 + board/samsung/common/board.c | 15 ++++ board/samsung/smdk5420/smdk5420.c | 118 +++++++------------------ doc/device-tree-bindings/video/exynos-fb.txt | 2 + drivers/video/exynos_fb.c | 20 ++--- drivers/video/exynos_fimd.c | 12 +++ include/configs/exynos5250-dt.h | 2 - include/configs/smdk5420.h | 8 ++ 14 files changed, 172 insertions(+), 104 deletions(-)
Previously, we used to statically assign values for vl_col, vl_row and vl_bpix using #defines like LCD_XRES, LCD_YRES and LCD_COLOR16.
Introducing the function exynos_lcd_early_init() would take care of this assignment on the fly by parsing FIMD DT properties, thereby allowing us to remove LCD_XRES and LCD_YRES from the main config file.
Signed-off-by: Ajay Kumar ajaykumar.rs@samsung.com --- arch/arm/include/asm/arch-exynos/system.h | 1 + board/samsung/common/board.c | 15 +++++++++++++++ drivers/video/exynos_fb.c | 20 ++++++-------------- include/configs/exynos5250-dt.h | 2 -- 4 files changed, 22 insertions(+), 16 deletions(-)
diff --git a/arch/arm/include/asm/arch-exynos/system.h b/arch/arm/include/asm/arch-exynos/system.h index 7e2057c..4968d3d 100644 --- a/arch/arm/include/asm/arch-exynos/system.h +++ b/arch/arm/include/asm/arch-exynos/system.h @@ -39,5 +39,6 @@ struct exynos5_sysreg {
void set_usbhost_mode(unsigned int mode); void set_system_display_ctrl(void); +int exynos_lcd_early_init(const void *blob);
#endif /* _EXYNOS4_SYSTEM_H */ diff --git a/board/samsung/common/board.c b/board/samsung/common/board.c index ce85ddb..ae89c94 100644 --- a/board/samsung/common/board.c +++ b/board/samsung/common/board.c @@ -17,6 +17,7 @@ #include <asm/arch/gpio.h> #include <asm/arch/pinmux.h> #include <asm/arch/power.h> +#include <asm/arch/system.h> #include <power/pmic.h> #include <power/max77686_pmic.h>
@@ -130,6 +131,20 @@ int board_early_init_f(void) #ifdef CONFIG_SYS_I2C_INIT_BOARD board_i2c_init(gd->fdt_blob); #endif + +#if defined(CONFIG_OF_CONTROL) && defined(CONFIG_EXYNOS_FB) +/* + * board_init_f(arch/arm/lib/board.c) calls lcd_setmem() which needs + * panel_info.vl_col, panel_info.vl_row and panel_info.vl_bpix, to reserve + * FB memory at a very early stage. So, we need to fill panel_info.vl_col, + * panel_info.vl_row and panel_info.vl_bpix before lcd_setmem() is called. + */ + err = exynos_lcd_early_init(gd->fdt_blob); + if (err) { + debug("LCD early init failed\n"); + return err; + } +#endif return err; } #endif diff --git a/drivers/video/exynos_fb.c b/drivers/video/exynos_fb.c index 5c7ec91..686870f 100644 --- a/drivers/video/exynos_fb.c +++ b/drivers/video/exynos_fb.c @@ -27,17 +27,12 @@ DECLARE_GLOBAL_DATA_PTR;
static unsigned int panel_width, panel_height;
-/* - * board_init_f(arch/arm/lib/board.c) calls lcd_setmem() which needs - * panel_info.vl_col, panel_info.vl_row and panel_info.vl_bpix to reserve - * FB memory at a very early stage, i.e even before exynos_fimd_parse_dt() - * is called. So, we are forced to statically assign it. - */ #ifdef CONFIG_OF_CONTROL vidinfo_t panel_info = { - .vl_col = LCD_XRES, - .vl_row = LCD_YRES, - .vl_bpix = LCD_COLOR16, + /* Insert a value here so that we don't end up in the BSS + * Reference: drivers/video/tegra.c + */ + .vl_col = -1, }; #endif
@@ -159,7 +154,7 @@ static void lcd_panel_on(vidinfo_t *vid) }
#ifdef CONFIG_OF_CONTROL -int exynos_fimd_parse_dt(const void *blob) +int exynos_lcd_early_init(const void *blob) { unsigned int node; node = fdtdec_next_compatible(blob, 0, COMPAT_SAMSUNG_EXYNOS_FIMD); @@ -303,10 +298,7 @@ void lcd_ctrl_init(void *lcdbase) set_system_display_ctrl(); set_lcd_clk();
-#ifdef CONFIG_OF_CONTROL - if (exynos_fimd_parse_dt(gd->fdt_blob)) - debug("Can't get proper panel info\n"); -#else +#ifndef CONFIG_OF_CONTROL /* initialize parameters which is specific to panel. */ init_panel_info(&panel_info); #endif diff --git a/include/configs/exynos5250-dt.h b/include/configs/exynos5250-dt.h index 689919d..508962c 100644 --- a/include/configs/exynos5250-dt.h +++ b/include/configs/exynos5250-dt.h @@ -50,8 +50,6 @@ #ifdef CONFIG_LCD #define CONFIG_EXYNOS_FB #define CONFIG_EXYNOS_DP -#define LCD_XRES 2560 -#define LCD_YRES 1600 #define LCD_BPP LCD_COLOR16 #endif #endif /* __CONFIG_5250_H */
ping.
- board_init_f(arch/arm/lib/board.c) calls lcd_setmem() which needs
- panel_info.vl_col, panel_info.vl_row and panel_info.vl_bpix, to reserve
- FB memory at a very early stage. So, we need to fill panel_info.vl_col,
- panel_info.vl_row and panel_info.vl_bpix before lcd_setmem() is called.
if (err) {
return err;
- panel_info.vl_col, panel_info.vl_row and panel_info.vl_bpix to reserve
- FB memory at a very early stage, i.e even before exynos_fimd_parse_dt()
- is called. So, we are forced to statically assign it.
.vl_col = LCD_XRES,
.vl_row = LCD_YRES,
.vl_col = -1,
}; #endif
1.7.12.4
Hi Ajay,
[once more from the right address]
I can't test this on Pit at present - any chance of a series at some point to enable that?
I pushed my branch to u-boot-x86.git branch try-5420b.
As a general comment, it would be nice to follow up with a series to fully enable device tree for the GPIOs also. At the moment these are hard-coded.
RPLL is needed to drive the LCD panel on Exynos5420 based boards.
Signed-off-by: Ajay Kumar ajaykumar.rs@samsung.com --- arch/arm/cpu/armv7/exynos/clock_init.h | 3 +++ arch/arm/cpu/armv7/exynos/clock_init_exynos5.c | 13 +++++++++++++ 2 files changed, 16 insertions(+)
diff --git a/arch/arm/cpu/armv7/exynos/clock_init.h b/arch/arm/cpu/armv7/exynos/clock_init.h index a875d0b..fce502f 100644 --- a/arch/arm/cpu/armv7/exynos/clock_init.h +++ b/arch/arm/cpu/armv7/exynos/clock_init.h @@ -75,6 +75,9 @@ struct mem_timings { unsigned spll_mdiv; unsigned spll_pdiv; unsigned spll_sdiv; + unsigned rpll_mdiv; + unsigned rpll_pdiv; + unsigned rpll_sdiv; unsigned pclk_cdrex_ratio; unsigned direct_cmd_msr[MEM_TIMINGS_MSR_COUNT];
diff --git a/arch/arm/cpu/armv7/exynos/clock_init_exynos5.c b/arch/arm/cpu/armv7/exynos/clock_init_exynos5.c index e7f1496..c91c4a1 100644 --- a/arch/arm/cpu/armv7/exynos/clock_init_exynos5.c +++ b/arch/arm/cpu/armv7/exynos/clock_init_exynos5.c @@ -179,6 +179,10 @@ struct mem_timings mem_timings[] = { .spll_mdiv = 0xc8, .spll_pdiv = 0x3, .spll_sdiv = 0x2, + /* RPLL @266MHz */ + .rpll_mdiv = 0x10A, + .rpll_pdiv = 0x3, + .rpll_sdiv = 0x3,
.direct_cmd_msr = { 0x00020018, 0x00030000, 0x00010046, 0x00000d70, @@ -800,6 +804,7 @@ static void exynos5420_system_clock_init(void) writel(mem->ipll_pdiv * PLL_LOCK_FACTOR, &clk->ipll_lock); writel(mem->spll_pdiv * PLL_LOCK_FACTOR, &clk->spll_lock); writel(mem->kpll_pdiv * PLL_LOCK_FACTOR, &clk->kpll_lock); + writel(mem->rpll_pdiv * PLL_X_LOCK_FACTOR, &clk->rpll_lock);
setbits_le32(&clk->src_cpu, MUX_HPM_SEL_MASK);
@@ -898,6 +903,14 @@ static void exynos5420_system_clock_init(void) while ((readl(&clk->spll_con0) & PLL_LOCKED) == 0) ;
+ /* Set RPLL */ + writel(RPLL_CON2_VAL, &clk->rpll_con2); + writel(RPLL_CON1_VAL, &clk->rpll_con1); + val = set_pll(mem->rpll_mdiv, mem->rpll_pdiv, mem->rpll_sdiv); + writel(val, &clk->rpll_con0); + while ((readl(&clk->rpll_con0) & PLL_LOCKED) == 0) + ; + writel(CLK_DIV_CDREX0_VAL, &clk->div_cdrex0); writel(CLK_DIV_CDREX1_VAL, &clk->div_cdrex1);
ping.
unsigned rpll_mdiv;
unsigned rpll_pdiv;
/* RPLL @266MHz */
.rpll_mdiv = 0x10A,
.rpll_pdiv = 0x3,
.rpll_sdiv = 0x3, .direct_cmd_msr = { 0x00020018, 0x00030000, 0x00010046, 0x00000d70,
writel(mem->rpll_pdiv * PLL_X_LOCK_FACTOR, &clk->rpll_lock); setbits_le32(&clk->src_cpu, MUX_HPM_SEL_MASK);
/* Set RPLL */
-- 1.7.12.4
Add get_lcd_clk and set_lcd_clk callbacks for Exynos5420 needed by exynos video driver. Also, configure ACLK_400_DISP1 as the parent for MUX_ACLK_400_DISP1_SUB_SEL.
Signed-off-by: Ajay Kumar ajaykumar.rs@samsung.com --- arch/arm/cpu/armv7/exynos/clock.c | 74 +++++++++++++++++++++++++++++-- arch/arm/cpu/armv7/exynos/exynos5_setup.h | 2 +- arch/arm/include/asm/arch-exynos/clk.h | 1 + 3 files changed, 73 insertions(+), 4 deletions(-)
diff --git a/arch/arm/cpu/armv7/exynos/clock.c b/arch/arm/cpu/armv7/exynos/clock.c index bc06995..e953ddc 100644 --- a/arch/arm/cpu/armv7/exynos/clock.c +++ b/arch/arm/cpu/armv7/exynos/clock.c @@ -82,7 +82,8 @@ static int exynos_get_pll_clk(int pllreg, unsigned int r, unsigned int k) * VPLL_CON: MIDV [24:16] * BPLL_CON: MIDV [25:16]: Exynos5 */ - if (pllreg == APLL || pllreg == MPLL || pllreg == BPLL) + if (pllreg == APLL || pllreg == MPLL || + pllreg == BPLL || pllreg == SPLL) mask = 0x3ff; else mask = 0x1ff; @@ -388,6 +389,9 @@ static unsigned long exynos5420_get_pll_clk(int pllreg) r = readl(&clk->rpll_con0); k = readl(&clk->rpll_con1); break; + case SPLL: + r = readl(&clk->spll_con0); + break; default: printf("Unsupported PLL (%d)\n", pllreg); return 0; @@ -1035,6 +1039,40 @@ static unsigned long exynos5_get_lcd_clk(void) return pclk; }
+static unsigned long exynos5420_get_lcd_clk(void) +{ + struct exynos5420_clock *clk = + (struct exynos5420_clock *)samsung_get_base_clock(); + unsigned long pclk, sclk; + unsigned int sel; + unsigned int ratio; + + /* + * CLK_SRC_DISP10 + * FIMD1_SEL [4] + * 0: SCLK_RPLL + * 1: SCLK_SPLL + */ + sel = readl(&clk->src_disp10); + sel &= (1 << 4); + + if (sel) + sclk = get_pll_clk(SPLL); + else + sclk = get_pll_clk(RPLL); + + /* + * CLK_DIV_DISP10 + * FIMD1_RATIO [3:0] + */ + ratio = readl(&clk->div_disp10); + ratio = ratio & 0xf; + + pclk = sclk / (ratio + 1); + + return pclk; +} + void exynos4_set_lcd_clk(void) { struct exynos4_clock *clk = @@ -1159,6 +1197,33 @@ void exynos5_set_lcd_clk(void) writel(cfg, &clk->div_disp1_0); }
+void exynos5420_set_lcd_clk(void) +{ + struct exynos5420_clock *clk = + (struct exynos5420_clock *)samsung_get_base_clock(); + unsigned int cfg; + + /* + * CLK_SRC_DISP10 + * FIMD1_SEL [4] + * 0: SCLK_RPLL + * 1: SCLK_SPLL + */ + cfg = readl(&clk->src_disp10); + cfg &= ~(0x1 << 4); + cfg |= (0 << 4); + writel(cfg, &clk->src_disp10); + + /* + * CLK_DIV_DISP10 + * FIMD1_RATIO [3:0] + */ + cfg = readl(&clk->div_disp10); + cfg &= ~(0xf << 0); + cfg |= (0 << 0); + writel(cfg, &clk->div_disp10); +} + void exynos4_set_mipi_clk(void) { struct exynos4_clock *clk = @@ -1628,14 +1693,17 @@ unsigned long get_lcd_clk(void) { if (cpu_is_exynos4()) return exynos4_get_lcd_clk(); - else - return exynos5_get_lcd_clk(); + else if (proid_is_exynos5420()) + return exynos5420_get_lcd_clk(); + return exynos5_get_lcd_clk(); }
void set_lcd_clk(void) { if (cpu_is_exynos4()) exynos4_set_lcd_clk(); + else if (proid_is_exynos5420()) + exynos5420_set_lcd_clk(); else exynos5_set_lcd_clk(); } diff --git a/arch/arm/cpu/armv7/exynos/exynos5_setup.h b/arch/arm/cpu/armv7/exynos/exynos5_setup.h index 8e05a00..70b1c04 100644 --- a/arch/arm/cpu/armv7/exynos/exynos5_setup.h +++ b/arch/arm/cpu/armv7/exynos/exynos5_setup.h @@ -780,7 +780,7 @@ #define CLK_SRC_TOP2_VAL 0x11101000 #define CLK_SRC_TOP3_VAL 0x11111111 #define CLK_SRC_TOP4_VAL 0x11110111 -#define CLK_SRC_TOP5_VAL 0x11111100 +#define CLK_SRC_TOP5_VAL 0x11111101 #define CLK_SRC_TOP6_VAL 0x11110111 #define CLK_SRC_TOP7_VAL 0x00022200
diff --git a/arch/arm/include/asm/arch-exynos/clk.h b/arch/arm/include/asm/arch-exynos/clk.h index abce246..f0b4d70 100644 --- a/arch/arm/include/asm/arch-exynos/clk.h +++ b/arch/arm/include/asm/arch-exynos/clk.h @@ -15,6 +15,7 @@ #define VPLL 4 #define BPLL 5 #define RPLL 6 +#define SPLL 7
enum pll_src_bit { EXYNOS_SRC_MPLL = 6,
ping.
case SPLL:
unsigned int sel;
unsigned int ratio;
* CLK_SRC_DISP10
* FIMD1_SEL [4]
* 0: SCLK_RPLL
* 1: SCLK_SPLL
sel &= (1 << 4);
if (sel)
else
* CLK_DIV_DISP10
* FIMD1_RATIO [3:0]
return pclk;
unsigned int cfg;
* CLK_SRC_DISP10
* FIMD1_SEL [4]
* 0: SCLK_RPLL
* 1: SCLK_SPLL
cfg &= ~(0x1 << 4);
cfg |= (0 << 4);
* CLK_DIV_DISP10
* FIMD1_RATIO [3:0]
cfg &= ~(0xf << 0);
cfg |= (0 << 0);
else
enum pll_src_bit { EXYNOS_SRC_MPLL = 6, -- 1.7.12.4
On Exynos5420, the FIMD sysmmus are in "on state" by default. We have to disable them in order to make FIMD DMA work. This patch adds the required framework to exynos_fimd driver to disable FIMD sysmmu on Exynos5420.
Signed-off-by: Ajay Kumar ajaykumar.rs@samsung.com --- arch/arm/dts/exynos5420.dtsi | 5 +++++ doc/device-tree-bindings/video/exynos-fb.txt | 2 ++ drivers/video/exynos_fimd.c | 12 ++++++++++++ 3 files changed, 19 insertions(+)
diff --git a/arch/arm/dts/exynos5420.dtsi b/arch/arm/dts/exynos5420.dtsi index ca6c605..2d64df8 100644 --- a/arch/arm/dts/exynos5420.dtsi +++ b/arch/arm/dts/exynos5420.dtsi @@ -71,4 +71,9 @@ reg = <0x12E20000 0x100>; interrupts = <0 203 0>; }; + + fimd@14400000 { + /* sysmmu is not used in U-Boot */ + samsung,disable-sysmmu; + }; }; diff --git a/doc/device-tree-bindings/video/exynos-fb.txt b/doc/device-tree-bindings/video/exynos-fb.txt index bb7441c..cddb505 100644 --- a/doc/device-tree-bindings/video/exynos-fb.txt +++ b/doc/device-tree-bindings/video/exynos-fb.txt @@ -55,6 +55,8 @@ Board(panel specific): samsung,pclk-name: parent clock identifier: 1(MPLL), 2(EPLL), 3(VPLL) samsung,sclk-div: parent_clock/source_clock ratio samsung,dual-lcd-enabled: 1 if you support two LCD, else 0 + samsung,disable-sysmmu: present if you want to disable the sysmmu + (needed for Exynos5420)
Example: SOC specific part: diff --git a/drivers/video/exynos_fimd.c b/drivers/video/exynos_fimd.c index 8c2de4e..410fff1 100644 --- a/drivers/video/exynos_fimd.c +++ b/drivers/video/exynos_fimd.c @@ -267,6 +267,18 @@ void exynos_fimd_lcd_init(vidinfo_t *vid) node, "reg"); if (fimd_ctrl == NULL) debug("Can't get the FIMD base address\n"); + + if (fdtdec_get_bool(gd->fdt_blob, node, "samsung,disable-sysmmu")) { + /* + * The reset value for FIMD SYSMMU registers + * MMU_CTRL:0x14640000 and MMU_CTRL:0x14680000 is 3. + * This means FIMD SYSMMU is on by default on Exynos5420. + * Since in u-boot we don't use SYSMMU, we are disabling + * FIMD SYSMMU. + */ + writel(0x0, 0x14640000); + writel(0x0, 0x14680000); + } #else fimd_ctrl = (struct exynos_fb *)samsung_get_base_fimd(); #endif
ping.
fimd@14400000 {
* FIMD SYSMMU.
#endif
1.7.12.4
Add callbacks to set up DP-HPD, backlight and LCD power on SMDK5420.
Signed-off-by: Ajay Kumar ajaykumar.rs@samsung.com --- board/samsung/smdk5420/smdk5420.c | 118 +++++++++++--------------------------- 1 file changed, 34 insertions(+), 84 deletions(-)
diff --git a/board/samsung/smdk5420/smdk5420.c b/board/samsung/smdk5420/smdk5420.c index cf76455..3f29ce0 100644 --- a/board/samsung/smdk5420/smdk5420.c +++ b/board/samsung/smdk5420/smdk5420.c @@ -137,98 +137,48 @@ int board_mmc_init(bd_t *bis) #endif
#ifdef CONFIG_LCD -void cfg_lcd_gpio(void) +void exynos_cfg_lcd_gpio(void) { - struct exynos5_gpio_part1 *gpio1 = - (struct exynos5_gpio_part1 *)samsung_get_base_gpio_part1(); + struct exynos5420_gpio_part2 *gpio2 = + (struct exynos5420_gpio_part2 *)samsung_get_base_gpio_part2();
- /* For Backlight */ + /* Set Hotplug detect for DP */ + s5p_gpio_cfg_pin(&gpio2->x0, 7, GPIO_FUNC(0x3)); +} + +void exynos_backlight_on(unsigned int onoff) +{ + struct exynos5420_gpio_part1 *gpio1 = + (struct exynos5420_gpio_part1 *)samsung_get_base_gpio_part1(); + + struct exynos5420_gpio_part2 *gpio2 = + (struct exynos5420_gpio_part2 *)samsung_get_base_gpio_part2(); + + /* For PWM */ s5p_gpio_cfg_pin(&gpio1->b2, 0, GPIO_OUTPUT); s5p_gpio_set_value(&gpio1->b2, 0, 1);
- /* LCD power on */ - s5p_gpio_cfg_pin(&gpio1->x1, 5, GPIO_OUTPUT); - s5p_gpio_set_value(&gpio1->x1, 5, 1); - - /* Set Hotplug detect for DP */ - s5p_gpio_cfg_pin(&gpio1->x0, 7, GPIO_FUNC(0x3)); + /* BL_EN */ + s5p_gpio_cfg_pin(&gpio2->x1, 5, GPIO_OUTPUT); + s5p_gpio_set_value(&gpio2->x1, 5, 1); }
-vidinfo_t panel_info = { - .vl_freq = 60, - .vl_col = 2560, - .vl_row = 1600, - .vl_width = 2560, - .vl_height = 1600, - .vl_clkp = CONFIG_SYS_LOW, - .vl_hsp = CONFIG_SYS_LOW, - .vl_vsp = CONFIG_SYS_LOW, - .vl_dp = CONFIG_SYS_LOW, - .vl_bpix = 4, /* LCD_BPP = 2^4, for output conosle on LCD */ - - /* wDP panel timing infomation */ - .vl_hspw = 32, - .vl_hbpd = 80, - .vl_hfpd = 48, - - .vl_vspw = 6, - .vl_vbpd = 37, - .vl_vfpd = 3, - .vl_cmd_allow_len = 0xf, - - .win_id = 3, - .cfg_gpio = cfg_lcd_gpio, - .backlight_on = NULL, - .lcd_power_on = NULL, - .reset_lcd = NULL, - .dual_lcd_enabled = 0, - - .init_delay = 0, - .power_on_delay = 0, - .reset_delay = 0, - .interface_mode = FIMD_RGB_INTERFACE, - .dp_enabled = 1, -}; - -static struct edp_device_info edp_info = { - .disp_info = { - .h_res = 2560, - .h_sync_width = 32, - .h_back_porch = 80, - .h_front_porch = 48, - .v_res = 1600, - .v_sync_width = 6, - .v_back_porch = 37, - .v_front_porch = 3, - .v_sync_rate = 60, - }, - .lt_info = { - .lt_status = DP_LT_NONE, - }, - .video_info = { - .master_mode = 0, - .bist_mode = DP_DISABLE, - .bist_pattern = NO_PATTERN, - .h_sync_polarity = 0, - .v_sync_polarity = 0, - .interlaced = 0, - .color_space = COLOR_RGB, - .dynamic_range = VESA, - .ycbcr_coeff = COLOR_YCBCR601, - .color_depth = COLOR_8, - }, -}; - -static struct exynos_dp_platform_data dp_platform_data = { - .phy_enable = set_dp_phy_ctrl, - .edp_dev_info = &edp_info, -}; - -void init_panel_info(vidinfo_t *vid) +void exynos_lcd_power_on(void) { - vid->rgb_mode = MODE_RGB_P, - - exynos_set_dp_platform_data(&dp_platform_data); + int pmic_bus, pmic_i2caddr, ldo38_reg, old_bus; + u8 value; + + /* enable VDD_28IO_DP: LDO38 should be at 2.8V */ + pmic_bus = 4; + pmic_i2caddr = 0x66; + ldo38_reg = 0x62; + value = 0x78; + + old_bus = i2c_get_bus_num(); + i2c_set_bus_num(pmic_bus); + if (i2c_write(pmic_i2caddr, ldo38_reg, 1, &value, 1)) + printf("i2c write fail. Failed to enable VDD_28IO_DP\n"); + i2c_set_bus_num(old_bus); } #endif
ping.
/* For Backlight */
/* LCD power on */
/* BL_EN */
.vl_freq = 60,
.vl_col = 2560,
.vl_row = 1600,
.vl_width = 2560,
.vl_height = 1600,
LCD */
.vl_hspw = 32,
.vl_hbpd = 80,
.vl_hfpd = 48,
.vl_vspw = 6,
.vl_vbpd = 37,
.vl_vfpd = 3,
.win_id = 3,
.reset_lcd = NULL,
.init_delay = 0,
.reset_delay = 0,
.dp_enabled = 1,
.disp_info = {
.h_res = 2560,
.h_sync_width = 32,
.h_back_porch = 80,
.v_res = 1600,
.v_sync_width = 6,
.v_back_porch = 37,
.v_front_porch = 3,
.v_sync_rate = 60,
.lt_info = {
.video_info = {
.master_mode = 0,
.interlaced = 0,
u8 value;
pmic_bus = 4;
ldo38_reg = 0x62;
value = 0x78;
} #endif
-- 1.7.12.4
Enable FIMD and DP drivers on SMDK5420 so that we get to see the LCD console on eDP panel.
Signed-off-by: Ajay Kumar ajaykumar.rs@samsung.com --- include/configs/smdk5420.h | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/include/configs/smdk5420.h b/include/configs/smdk5420.h index 447f8e5..cc9c424 100644 --- a/include/configs/smdk5420.h +++ b/include/configs/smdk5420.h @@ -53,4 +53,12 @@
#define CONFIG_MAX_I2C_NUM 11
+/* Display */ +#define CONFIG_LCD +#ifdef CONFIG_LCD +#define CONFIG_EXYNOS_FB +#define CONFIG_EXYNOS_DP +#define LCD_BPP LCD_COLOR16 +#endif + #endif /* __CONFIG_5420_H */
ping.
1.7.12.4
This all seems good to me, builds without errors.
+Simon
-- 1.7.12.4
ping.
On Fri, Oct 11, 2013 at 9:57 AM, Ajay kumar ajaynumb@gmail.com wrote:
+Simon
-- 1.7.12.4
Ajay Kumar
Ajay kumar
