[U-Boot] [GIT PULL] Xilinx changes
Hi Tom,
I am sending bunch of patches I have collected around Xilinx changes. USB Kconfig was discussed with Marek and I have got his ACK via IRC. Kconfig change CONFIG_SYS_NO_FLASH we discussed together (I have run some builds for others arm stuff) CLK changes was also discussed with Stephen and Simon.
Thanks, Michal
The following changes since commit 95d52733036af7438a5285d729d53844ec48c63e:
Revert "stm32: Change USART port to USART6 for stm32f746 discovery board" (2016-07-21 15:38:13 -0400)
git://www.denx.de/git/u-boot-microblaze.git master
for you to fetch changes up to 766d2609dd7fbad0faa89c7dff26edc108afa890:
zynq: defconfig: Remove unnecessary board specific config files (2016-07-22 15:16:43 +0200)
---------------------------------------------------------------- Alexander Graf (1): ARM64: zynqmp: Enable AHCI on EP platform
Michal Simek (9): ARM: zynq/zynqmp: Use the default CONFIG_BOOTDELAY=2 api: Disable api_net when DM is used spl: Fix compilation warnings for arm64 ARM64: zynqmp: Enable CLK and SPL_CLK by default ARM64: zynqmp: Enable SPL for all zynqmp boards serial: zynq: Read information about clock from DT ARM64: zynqmp: Remove get_uart_clk() dm: clk: Remove simple version of clk_get_by_index/name() microblaze: Remove empty ifdef around caches
Siva Durga Prasad Paladugu (6): mmc: sdhci: Disable internal clock enable bit usb: Kconfig: Add Kconfigs entry USB_EHCI_ZYNQ usb: zynq: Define config USB_STORAGE through defconfig Kconfig: Move option CONFIG_SYS_NO_FLASH to Kconfig zynq: config: Enable CONFIG_SYS_NO_FLASH through defconfig zynq: defconfig: Remove unnecessary board specific config files
api/api_net.c | 2 +- arch/arm/Kconfig | 2 ++ arch/arm/cpu/armv8/zynqmp/clk.c | 16 ---------------- arch/arm/include/asm/arch-zynqmp/clk.h | 1 - arch/arm/lib/spl.c | 2 +- common/Kconfig | 6 ++++++ common/spl/spl_fat.c | 3 ++- configs/xilinx_zynqmp_ep_defconfig | 8 +++++--- configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig | 8 +++++--- configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig | 8 +++++--- configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig | 8 +++++--- configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig | 8 +++++--- configs/xilinx_zynqmp_zcu102_defconfig | 8 +++++--- configs/xilinx_zynqmp_zcu102_revB_defconfig | 8 +++++--- configs/zynq_microzed_defconfig | 7 +++++-- configs/zynq_picozed_defconfig | 7 +++++-- configs/zynq_zc702_defconfig | 5 ++++- configs/zynq_zc706_defconfig | 5 ++++- configs/zynq_zc770_xm010_defconfig | 4 ++-- configs/zynq_zc770_xm011_defconfig | 4 ++-- configs/zynq_zc770_xm012_defconfig | 3 +-- configs/zynq_zc770_xm013_defconfig | 4 ++-- configs/zynq_zed_defconfig | 7 +++++-- configs/zynq_zybo_defconfig | 5 ++++- drivers/clk/clk-uclass.c | 28 +--------------------------- drivers/mmc/sdhci.c | 2 +- drivers/serial/serial_zynq.c | 28 +++++++++++++++++++++++++++- drivers/usb/host/Kconfig | 7 +++++++ include/configs/microblaze-generic.h | 4 ---- include/configs/xilinx_zynqmp_ep.h | 1 + include/configs/zynq-common.h | 5 +---- include/configs/zynq_microzed.h | 19 ------------------- include/configs/zynq_picozed.h | 19 ------------------- include/configs/zynq_zc70x.h | 3 --- include/configs/zynq_zc770.h | 22 ---------------------- include/configs/zynq_zed.h | 19 ------------------- include/configs/zynq_zybo.h | 3 --- 37 files changed, 119 insertions(+), 180 deletions(-) delete mode 100644 include/configs/zynq_microzed.h delete mode 100644 include/configs/zynq_picozed.h delete mode 100644 include/configs/zynq_zc770.h delete mode 100644 include/configs/zynq_zed.h
On Fri, Jul 22, 2016 at 03:17:51PM +0200, Michal Simek wrote:
Hi Tom,
Thanks, Michal
Michal Simek
