[U-Boot] [PATCH] sunxi: fix sid base address macro name for H6
In the current H6 CPU memory space code, the SUNXI in the macro name of the SID address base is wrongly spelled as SNUXI, which leads to SID readout not working.
Fix this macro name.
Fixes: 55f6b1c351c9 ("sunxi: add basic memory map definitions of H6 SoC") Signed-off-by: Icenowy Zheng icenowy@aosc.io --- arch/arm/include/asm/arch-sunxi/cpu_sun50i_h6.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/include/asm/arch-sunxi/cpu_sun50i_h6.h b/arch/arm/include/asm/arch-sunxi/cpu_sun50i_h6.h index f568def8b4..41a9b0fc47 100644 --- a/arch/arm/include/asm/arch-sunxi/cpu_sun50i_h6.h +++ b/arch/arm/include/asm/arch-sunxi/cpu_sun50i_h6.h @@ -20,7 +20,7 @@ #define SUNXI_DMA_BASE 0x03002000 /* SID address space starts at 0x03006000, but e-fuse is at offset 0x200 */ #define SUNXI_SIDC_BASE 0x03006000 -#define SNUXI_SID_BASE 0x03006200 +#define SUNXI_SID_BASE 0x03006200 #define SUNXI_TIMER_BASE 0x03009000 #define SUNXI_PIO_BASE 0x0300B000 #define SUNXI_PSI_BASE 0x0300C000
Applied to u-boot-sunxi/master
Icenowy Zheng
Jagan Teki
