[U-Boot] [PATCH v7 1/1] MX53: support for freescale MX53LOCO board
This patch add initial support for freescale MX53LOCO board. Network(FEC),SD/MMC,UART have been supported by this patch
Signed-off-by: Jason Liu jason.hui@linaro.org --- Changes since v6: - move the pmic support out from this patchset Changes since v5: - merge the "Add power init support" patch changes since v4: - remove the boot reset cause from board support changes since v3: - include other two small patch into this commit, mx53loco: set mmc env to MMC slot1 MX5: Enable flat-device-tree support on mx53 loco board changes since V2: -factor out the boot cause function to common code, -fix gd->ram_size with full memory size -remove the '1' from all #defines that just enable features -correct memory test end address value --- MAINTAINERS | 1 + board/freescale/mx53loco/Makefile | 47 +++++ board/freescale/mx53loco/imximage.cfg | 96 +++++++++++ board/freescale/mx53loco/mx53loco.c | 302 +++++++++++++++++++++++++++++++++ boards.cfg | 1 + include/configs/mx53loco.h | 186 ++++++++++++++++++++ 6 files changed, 633 insertions(+), 0 deletions(-)
diff --git a/MAINTAINERS b/MAINTAINERS index e2a4ba9..42c5048 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -574,6 +574,7 @@ Stefano Babic sbabic@denx.de Jason Liu r64343@freescale.com
mx53evk i.MX53 + mx53loco i.MX53
Enric Balletbo i Serra eballetbo@iseebcn.com
diff --git a/board/freescale/mx53loco/Makefile b/board/freescale/mx53loco/Makefile new file mode 100644 index 0000000..2088a48 --- /dev/null +++ b/board/freescale/mx53loco/Makefile @@ -0,0 +1,47 @@ +# +# (C) Copyright 2011 Freescale Semiconductor, Inc. +# Jason Liu r64343@freescale.com +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +COBJS := mx53loco.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(call cmd_link_o_target, $(OBJS) $(SOBJS)) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak .depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/freescale/mx53loco/imximage.cfg b/board/freescale/mx53loco/imximage.cfg new file mode 100644 index 0000000..ce9c8fc --- /dev/null +++ b/board/freescale/mx53loco/imximage.cfg @@ -0,0 +1,96 @@ +# Copyright (C) 2011 Freescale Semiconductor, Inc. +# Jason Liu r64343@freescale.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not write to the Free Software +# Foundation Inc. 51 Franklin Street Fifth Floor Boston, +# MA 02110-1301 USA +# +# Refer docs/README.imxmage for more details about how-to configure +# and create imximage boot image +# +# The syntax is taken as close as possible with the kwbimage + +# image version + +IMAGE_VERSION 2 + +# Boot Device : one of +# spi, sd (the board has no nand neither onenand) + +BOOT_FROM sd + +# Device Configuration Data (DCD) +# +# Each entry must have the format: +# Addr-type Address Value +# +# where: +# Addr-type register length (1,2 or 4 bytes) +# Address absolute address of the register +# value value to be stored in the register + +DATA 4 0x53fa8554 0x00300000 +DATA 4 0x53fa8558 0x00300040 +DATA 4 0x53fa8560 0x00300000 +DATA 4 0x53fa8564 0x00300040 +DATA 4 0x53fa8568 0x00300040 +DATA 4 0x53fa8570 0x00300000 +DATA 4 0x53fa8574 0x00300000 +DATA 4 0x53fa8578 0x00300000 +DATA 4 0x53fa857c 0x00300040 +DATA 4 0x53fa8580 0x00300040 +DATA 4 0x53fa8584 0x00300000 +DATA 4 0x53fa8588 0x00300000 +DATA 4 0x53fa8590 0x00300040 +DATA 4 0x53fa8594 0x00300000 +DATA 4 0x53fa86f0 0x00300000 +DATA 4 0x53fa86f4 0x00000000 +DATA 4 0x53fa86fc 0x00000000 +DATA 4 0x53fa8714 0x00000000 +DATA 4 0x53fa8718 0x00300000 +DATA 4 0x53fa871c 0x00300000 +DATA 4 0x53fa8720 0x00300000 +DATA 4 0x53fa8724 0x04000000 +DATA 4 0x53fa8728 0x00300000 +DATA 4 0x53fa872c 0x00300000 +DATA 4 0x63fd9088 0x35343535 +DATA 4 0x63fd9090 0x4d444c44 +DATA 4 0x63fd907c 0x01370138 +DATA 4 0x63fd9080 0x013b013c +DATA 4 0x63fd9018 0x00011740 +DATA 4 0x63fd9000 0xc3190000 +DATA 4 0x63fd900c 0x9f5152e3 +DATA 4 0x63fd9010 0xb68e8a63 +DATA 4 0x63fd9014 0x01ff00db +DATA 4 0x63fd902c 0x000026d2 +DATA 4 0x63fd9030 0x009f0e21 +DATA 4 0x63fd9008 0x12273030 +DATA 4 0x63fd9004 0x0002002d +DATA 4 0x63fd901c 0x00008032 +DATA 4 0x63fd901c 0x00008033 +DATA 4 0x63fd901c 0x00028031 +DATA 4 0x63fd901c 0x092080b0 +DATA 4 0x63fd901c 0x04008040 +DATA 4 0x63fd901c 0x0000803a +DATA 4 0x63fd901c 0x0000803b +DATA 4 0x63fd901c 0x00028039 +DATA 4 0x63fd901c 0x09208138 +DATA 4 0x63fd901c 0x04008048 +DATA 4 0x63fd9020 0x00001800 +DATA 4 0x63fd9040 0x04b80003 +DATA 4 0x63fd9058 0x00022227 +DATA 4 0x63fd901c 0x00000000 diff --git a/board/freescale/mx53loco/mx53loco.c b/board/freescale/mx53loco/mx53loco.c new file mode 100644 index 0000000..d032428 --- /dev/null +++ b/board/freescale/mx53loco/mx53loco.c @@ -0,0 +1,302 @@ +/* + * Copyright (C) 2011 Freescale Semiconductor, Inc. + * Jason Liu r64343@freescale.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/mx5x_pins.h> +#include <asm/arch/sys_proto.h> +#include <asm/arch/crm_regs.h> +#include <asm/arch/iomux.h> +#include <asm/arch/clock.h> +#include <asm/errno.h> +#include <netdev.h> +#include <i2c.h> +#include <mmc.h> +#include <fsl_esdhc.h> +#include <mxc_gpio.h> + +DECLARE_GLOBAL_DATA_PTR; + +u32 get_board_rev(void) +{ + return get_cpu_rev(); +} + +int dram_init(void) +{ + u32 size1, size2; + + size1 = get_ram_size((volatile void *)PHYS_SDRAM_1, PHYS_SDRAM_1_SIZE); + size2 = get_ram_size((volatile void *)PHYS_SDRAM_2, PHYS_SDRAM_2_SIZE); + + gd->ram_size = size1 + size2; + + return 0; +} +void dram_init_banksize(void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM_1; + gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; + + gd->bd->bi_dram[1].start = PHYS_SDRAM_2; + gd->bd->bi_dram[1].size = PHYS_SDRAM_2_SIZE; +} + +static void setup_iomux_uart(void) +{ + /* UART1 RXD */ + mxc_request_iomux(MX53_PIN_CSI0_D11, IOMUX_CONFIG_ALT2); + mxc_iomux_set_pad(MX53_PIN_CSI0_D11, + PAD_CTL_HYS_ENABLE | PAD_CTL_DRV_HIGH | + PAD_CTL_PUE_PULL | PAD_CTL_PKE_ENABLE | + PAD_CTL_HYS_ENABLE | PAD_CTL_100K_PU | + PAD_CTL_ODE_OPENDRAIN_ENABLE); + mxc_iomux_set_input(MX53_UART1_IPP_UART_RXD_MUX_SELECT_INPUT, 0x1); + + /* UART1 TXD */ + mxc_request_iomux(MX53_PIN_CSI0_D10, IOMUX_CONFIG_ALT2); + mxc_iomux_set_pad(MX53_PIN_CSI0_D10, + PAD_CTL_HYS_ENABLE | PAD_CTL_DRV_HIGH | + PAD_CTL_PUE_PULL | PAD_CTL_PKE_ENABLE | + PAD_CTL_HYS_ENABLE | PAD_CTL_100K_PU | + PAD_CTL_ODE_OPENDRAIN_ENABLE); +} + +static void setup_iomux_fec(void) +{ + /*FEC_MDIO*/ + mxc_request_iomux(MX53_PIN_FEC_MDIO, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX53_PIN_FEC_MDIO, + PAD_CTL_HYS_ENABLE | PAD_CTL_DRV_HIGH | + PAD_CTL_PUE_PULL | PAD_CTL_PKE_ENABLE | + PAD_CTL_22K_PU | PAD_CTL_ODE_OPENDRAIN_ENABLE); + mxc_iomux_set_input(MX53_FEC_FEC_MDI_SELECT_INPUT, 0x1); + + /*FEC_MDC*/ + mxc_request_iomux(MX53_PIN_FEC_MDC, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX53_PIN_FEC_MDC, PAD_CTL_DRV_HIGH); + + /* FEC RXD1 */ + mxc_request_iomux(MX53_PIN_FEC_RXD1, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX53_PIN_FEC_RXD1, + PAD_CTL_HYS_ENABLE | PAD_CTL_PKE_ENABLE); + + /* FEC RXD0 */ + mxc_request_iomux(MX53_PIN_FEC_RXD0, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX53_PIN_FEC_RXD0, + PAD_CTL_HYS_ENABLE | PAD_CTL_PKE_ENABLE); + + /* FEC TXD1 */ + mxc_request_iomux(MX53_PIN_FEC_TXD1, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX53_PIN_FEC_TXD1, PAD_CTL_DRV_HIGH); + + /* FEC TXD0 */ + mxc_request_iomux(MX53_PIN_FEC_TXD0, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX53_PIN_FEC_TXD0, PAD_CTL_DRV_HIGH); + + /* FEC TX_EN */ + mxc_request_iomux(MX53_PIN_FEC_TX_EN, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX53_PIN_FEC_TX_EN, PAD_CTL_DRV_HIGH); + + /* FEC TX_CLK */ + mxc_request_iomux(MX53_PIN_FEC_REF_CLK, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX53_PIN_FEC_REF_CLK, + PAD_CTL_HYS_ENABLE | PAD_CTL_PKE_ENABLE); + + /* FEC RX_ER */ + mxc_request_iomux(MX53_PIN_FEC_RX_ER, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX53_PIN_FEC_RX_ER, + PAD_CTL_HYS_ENABLE | PAD_CTL_PKE_ENABLE); + + /* FEC CRS */ + mxc_request_iomux(MX53_PIN_FEC_CRS_DV, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX53_PIN_FEC_CRS_DV, + PAD_CTL_HYS_ENABLE | PAD_CTL_PKE_ENABLE); +} + +#ifdef CONFIG_FSL_ESDHC +struct fsl_esdhc_cfg esdhc_cfg[2] = { + {MMC_SDHC1_BASE_ADDR, 1}, + {MMC_SDHC3_BASE_ADDR, 1}, +}; + +int board_mmc_getcd(u8 *cd, struct mmc *mmc) +{ + struct fsl_esdhc_cfg *cfg = (struct fsl_esdhc_cfg *)mmc->priv; + + if (cfg->esdhc_base == MMC_SDHC1_BASE_ADDR) + *cd = mxc_gpio_get(77); /*GPIO3_13*/ + else + *cd = mxc_gpio_get(75); /*GPIO3_11*/ + + return 0; +} + +int board_mmc_init(bd_t *bis) +{ + u32 index; + s32 status = 0; + + for (index = 0; index < CONFIG_SYS_FSL_ESDHC_NUM; index++) { + switch (index) { + case 0: + mxc_request_iomux(MX53_PIN_SD1_CMD, IOMUX_CONFIG_ALT0); + mxc_request_iomux(MX53_PIN_SD1_CLK, IOMUX_CONFIG_ALT0); + mxc_request_iomux(MX53_PIN_SD1_DATA0, + IOMUX_CONFIG_ALT0); + mxc_request_iomux(MX53_PIN_SD1_DATA1, + IOMUX_CONFIG_ALT0); + mxc_request_iomux(MX53_PIN_SD1_DATA2, + IOMUX_CONFIG_ALT0); + mxc_request_iomux(MX53_PIN_SD1_DATA3, + IOMUX_CONFIG_ALT0); + mxc_request_iomux(MX53_PIN_EIM_DA13, + IOMUX_CONFIG_ALT1); + + mxc_iomux_set_pad(MX53_PIN_SD1_CMD, + PAD_CTL_HYS_ENABLE | PAD_CTL_DRV_HIGH | + PAD_CTL_PUE_PULL | PAD_CTL_PKE_ENABLE | + PAD_CTL_HYS_ENABLE | PAD_CTL_100K_PU); + mxc_iomux_set_pad(MX53_PIN_SD1_CLK, + PAD_CTL_PUE_PULL | PAD_CTL_PKE_ENABLE | + PAD_CTL_HYS_ENABLE | PAD_CTL_47K_PU | + PAD_CTL_DRV_HIGH); + mxc_iomux_set_pad(MX53_PIN_SD1_DATA0, + PAD_CTL_HYS_ENABLE | PAD_CTL_DRV_HIGH | + PAD_CTL_PUE_PULL | PAD_CTL_PKE_ENABLE | + PAD_CTL_HYS_ENABLE | PAD_CTL_47K_PU); + mxc_iomux_set_pad(MX53_PIN_SD1_DATA1, + PAD_CTL_HYS_ENABLE | PAD_CTL_DRV_HIGH | + PAD_CTL_PUE_PULL | PAD_CTL_PKE_ENABLE | + PAD_CTL_HYS_ENABLE | PAD_CTL_47K_PU); + mxc_iomux_set_pad(MX53_PIN_SD1_DATA2, + PAD_CTL_HYS_ENABLE | PAD_CTL_DRV_HIGH | + PAD_CTL_PUE_PULL | PAD_CTL_PKE_ENABLE | + PAD_CTL_HYS_ENABLE | PAD_CTL_47K_PU); + mxc_iomux_set_pad(MX53_PIN_SD1_DATA3, + PAD_CTL_HYS_ENABLE | PAD_CTL_DRV_HIGH | + PAD_CTL_PUE_PULL | PAD_CTL_PKE_ENABLE | + PAD_CTL_HYS_ENABLE | PAD_CTL_47K_PU); + break; + case 1: + mxc_request_iomux(MX53_PIN_ATA_RESET_B, + IOMUX_CONFIG_ALT2); + mxc_request_iomux(MX53_PIN_ATA_IORDY, + IOMUX_CONFIG_ALT2); + mxc_request_iomux(MX53_PIN_ATA_DATA8, + IOMUX_CONFIG_ALT4); + mxc_request_iomux(MX53_PIN_ATA_DATA9, + IOMUX_CONFIG_ALT4); + mxc_request_iomux(MX53_PIN_ATA_DATA10, + IOMUX_CONFIG_ALT4); + mxc_request_iomux(MX53_PIN_ATA_DATA11, + IOMUX_CONFIG_ALT4); + mxc_request_iomux(MX53_PIN_ATA_DATA0, + IOMUX_CONFIG_ALT4); + mxc_request_iomux(MX53_PIN_ATA_DATA1, + IOMUX_CONFIG_ALT4); + mxc_request_iomux(MX53_PIN_ATA_DATA2, + IOMUX_CONFIG_ALT4); + mxc_request_iomux(MX53_PIN_ATA_DATA3, + IOMUX_CONFIG_ALT4); + mxc_request_iomux(MX53_PIN_EIM_DA11, + IOMUX_CONFIG_ALT1); + + mxc_iomux_set_pad(MX53_PIN_ATA_RESET_B, + PAD_CTL_HYS_ENABLE | PAD_CTL_DRV_HIGH | + PAD_CTL_PUE_PULL | PAD_CTL_PKE_ENABLE | + PAD_CTL_HYS_ENABLE | PAD_CTL_100K_PU); + mxc_iomux_set_pad(MX53_PIN_ATA_IORDY, + PAD_CTL_PUE_PULL | PAD_CTL_PKE_ENABLE | + PAD_CTL_HYS_ENABLE | PAD_CTL_47K_PU | + PAD_CTL_DRV_HIGH); + mxc_iomux_set_pad(MX53_PIN_ATA_DATA8, + PAD_CTL_HYS_ENABLE | PAD_CTL_DRV_HIGH | + PAD_CTL_PUE_PULL | PAD_CTL_PKE_ENABLE | + PAD_CTL_HYS_ENABLE | PAD_CTL_47K_PU); + mxc_iomux_set_pad(MX53_PIN_ATA_DATA9, + PAD_CTL_HYS_ENABLE | PAD_CTL_DRV_HIGH | + PAD_CTL_PUE_PULL | PAD_CTL_PKE_ENABLE | + PAD_CTL_HYS_ENABLE | PAD_CTL_47K_PU); + mxc_iomux_set_pad(MX53_PIN_ATA_DATA10, + PAD_CTL_HYS_ENABLE | PAD_CTL_DRV_HIGH | + PAD_CTL_PUE_PULL | PAD_CTL_PKE_ENABLE | + PAD_CTL_HYS_ENABLE | PAD_CTL_47K_PU); + mxc_iomux_set_pad(MX53_PIN_ATA_DATA11, + PAD_CTL_HYS_ENABLE | PAD_CTL_DRV_HIGH | + PAD_CTL_PUE_PULL | PAD_CTL_PKE_ENABLE | + PAD_CTL_HYS_ENABLE | PAD_CTL_47K_PU); + mxc_iomux_set_pad(MX53_PIN_ATA_DATA0, + PAD_CTL_HYS_ENABLE | PAD_CTL_DRV_HIGH | + PAD_CTL_PUE_PULL | PAD_CTL_PKE_ENABLE | + PAD_CTL_HYS_ENABLE | PAD_CTL_47K_PU); + mxc_iomux_set_pad(MX53_PIN_ATA_DATA1, + PAD_CTL_HYS_ENABLE | PAD_CTL_DRV_HIGH | + PAD_CTL_PUE_PULL | PAD_CTL_PKE_ENABLE | + PAD_CTL_HYS_ENABLE | PAD_CTL_47K_PU); + mxc_iomux_set_pad(MX53_PIN_ATA_DATA2, + PAD_CTL_HYS_ENABLE | PAD_CTL_DRV_HIGH | + PAD_CTL_PUE_PULL | PAD_CTL_PKE_ENABLE | + PAD_CTL_HYS_ENABLE | PAD_CTL_47K_PU); + mxc_iomux_set_pad(MX53_PIN_ATA_DATA3, + PAD_CTL_HYS_ENABLE | PAD_CTL_DRV_HIGH | + PAD_CTL_PUE_PULL | PAD_CTL_PKE_ENABLE | + PAD_CTL_HYS_ENABLE | PAD_CTL_47K_PU); + + break; + default: + printf("Warning: you configured more ESDHC controller" + "(%d) as supported by the board(2)\n", + CONFIG_SYS_FSL_ESDHC_NUM); + return status; + } + status |= fsl_esdhc_initialize(bis, &esdhc_cfg[index]); + } + + return status; +} +#endif + +int board_early_init_f(void) +{ + setup_iomux_uart(); + setup_iomux_fec(); + + return 0; +} + +int board_init(void) +{ + gd->bd->bi_arch_number = MACH_TYPE_MX53_LOCO; + gd->bd->bi_boot_params = PHYS_SDRAM_1 + 0x100; + + return 0; +} + +int checkboard(void) +{ + puts("Board: MX53 LOCO\n"); + + return 0; +} diff --git a/boards.cfg b/boards.cfg index 2b0900a..67fd163 100644 --- a/boards.cfg +++ b/boards.cfg @@ -124,6 +124,7 @@ ca9x4_ct_vxp arm armv7 vexpress armltd efikamx arm armv7 efikamx - mx5 mx51evk arm armv7 mx51evk freescale mx5 mx51evk:IMX_CONFIG=board/freescale/mx51evk/imximage.cfg mx53evk arm armv7 mx53evk freescale mx5 mx53evk:IMX_CONFIG=board/freescale/mx53evk/imximage.cfg +mx53loco arm armv7 mx53loco freescale mx5 mx53loco:IMX_CONFIG=board/freescale/mx53loco/imximage.cfg vision2 arm armv7 vision2 ttcontrol mx5 cm_t35 arm armv7 cm_t35 - omap3 omap3_overo arm armv7 overo - omap3 diff --git a/include/configs/mx53loco.h b/include/configs/mx53loco.h new file mode 100644 index 0000000..60dc2be --- /dev/null +++ b/include/configs/mx53loco.h @@ -0,0 +1,186 @@ +/* + * Copyright (C) 2011 Freescale Semiconductor, Inc. + * Jason Liu r64343@freescale.com + * + * Configuration settings for Freescale MX53 low cost board. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#define CONFIG_MX53 + +#define CONFIG_SYS_MX5_HCLK 24000000 +#define CONFIG_SYS_MX5_CLK32 32768 +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DISPLAY_BOARDINFO + +#define CONFIG_L2_OFF + +#include <asm/arch/imx-regs.h> + +#define CONFIG_CMDLINE_TAG +#define CONFIG_REVISION_TAG +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_INITRD_TAG + +/* Size of malloc() pool */ +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 2 * 1024 * 1024) + +#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_MXC_GPIO + +#define CONFIG_MXC_UART +#define CONFIG_SYS_MX53_UART1 + +/* MMC Configs */ +#define CONFIG_FSL_ESDHC +#define CONFIG_SYS_FSL_ESDHC_ADDR 0 +#define CONFIG_SYS_FSL_ESDHC_NUM 2 + +#define CONFIG_MMC +#define CONFIG_CMD_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_CMD_FAT +#define CONFIG_DOS_PARTITION + +/* Eth Configs */ +#define CONFIG_HAS_ETH1 +#define CONFIG_NET_MULTI +#define CONFIG_MII +#define CONFIG_DISCOVER_PHY + +#define CONFIG_FEC_MXC +#define IMX_FEC_BASE FEC_BASE_ADDR +#define CONFIG_FEC_MXC_PHYADDR 0x1F + +#define CONFIG_CMD_PING +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_MII +#define CONFIG_CMD_NET + +/* allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE +#define CONFIG_CONS_INDEX 1 +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE {9600, 19200, 38400, 57600, 115200} + +/* Command definition */ +#include <config_cmd_default.h> + +#undef CONFIG_CMD_IMLS + +#define CONFIG_BOOTDELAY 3 + +#define CONFIG_PRIME "FEC0" + +#define CONFIG_LOADADDR 0x70800000 /* loadaddr env var */ +#define CONFIG_SYS_TEXT_BASE 0x77800000 + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "script=boot.scr\0" \ + "uimage=uImage\0" \ + "mmcdev=0\0" \ + "mmcpart=2\0" \ + "mmcroot=/dev/mmcblk0p3 rw\0" \ + "mmcrootfstype=ext3 rootwait\0" \ + "mmcargs=setenv bootargs console=ttymxc0,${baudrate} " \ + "root=${mmcroot} " \ + "rootfstype=${mmcrootfstype}\0" \ + "loadbootscript=" \ + "fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${script};\0" \ + "bootscript=echo Running bootscript from mmc ...; " \ + "source\0" \ + "loaduimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${uimage}\0" \ + "mmcboot=echo Booting from mmc ...; " \ + "run mmcargs; " \ + "bootm\0" \ + "netargs=setenv bootargs console=ttymxc0,${baudrate} " \ + "root=/dev/nfs " \ + "ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp\0" \ + "netboot=echo Booting from net ...; " \ + "run netargs; " \ + "dhcp ${uimage}; bootm\0" \ + +#define CONFIG_BOOTCOMMAND \ + "if mmc rescan ${mmcdev}; then " \ + "if run loadbootscript; then " \ + "run bootscript; " \ + "else " \ + "if run loaduimage; then " \ + "run mmcboot; " \ + "else run netboot; " \ + "fi; " \ + "fi; " \ + "else run netboot; fi" + +#define CONFIG_ARP_TIMEOUT 200UL + +/* Miscellaneous configurable options */ +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " +#define CONFIG_SYS_PROMPT "MX53LOCO U-Boot > " +#define CONFIG_AUTO_COMPLETE +#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ + +/* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ + +#define CONFIG_SYS_MEMTEST_START 0x70000000 +#define CONFIG_SYS_MEMTEST_END 0x70010000 + +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR + +#define CONFIG_SYS_HZ 1000 +#define CONFIG_CMDLINE_EDITING + +/* Stack sizes */ +#define CONFIG_STACKSIZE (128 * 1024) /* regular stack */ + +/* Physical Memory Map */ +#define CONFIG_NR_DRAM_BANKS 2 +#define PHYS_SDRAM_1 CSD0_BASE_ADDR +#define PHYS_SDRAM_1_SIZE (512 * 1024 * 1024) +#define PHYS_SDRAM_2 CSD1_BASE_ADDR +#define PHYS_SDRAM_2_SIZE (512 * 1024 * 1024) +#define PHYS_SDRAM_SIZE (PHYS_SDRAM_1_SIZE + PHYS_SDRAM_2_SIZE) + +#define CONFIG_SYS_SDRAM_BASE (PHYS_SDRAM_1) +#define CONFIG_SYS_INIT_RAM_ADDR (IRAM_BASE_ADDR) +#define CONFIG_SYS_INIT_RAM_SIZE (IRAM_SIZE) + +#define CONFIG_SYS_INIT_SP_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) + +/* FLASH and environment organization */ +#define CONFIG_SYS_NO_FLASH + +#define CONFIG_ENV_OFFSET (6 * 64 * 1024) +#define CONFIG_ENV_SIZE (8 * 1024) +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_SYS_MMC_ENV_DEV 0 + +#define CONFIG_OF_LIBFDT +#define CONFIG_SYS_BOOTMAPSZ 0x800000 + +#endif /* __CONFIG_H */
Applied to u-boot-imx, thanks.
Best regards, Stefano Babic
Jason Liu
Stefano Babic
