[U-Boot] [PATCH 1/6] S5PC100: Samsung S5PC100 SoC support
S5PC100 processor is ARM Cortex A8 Processor SoC and SMDKC100 Board use this. So, this patch tested on SMDKC100 Board.
I'll send 6 patch for working on SMDKC100 Board including this. But, this patch make the change to ARM Cortex A8 specific code like a cpu/arm_cortexa8/cpu.c, start.S.
So, I wanna be reviewed to know how to contribute this whole patch.
CC: Dirk Behme <dirk.behme at googlemail.com> Signed-off-by: HeungJun, Kim riverful.kim@samsung.com
It includes the following :
- Samsung S5PC100 SoC specific source codes - Samsung S5PC100 SoC specific header files - modify ARM Cortex A8 cpu.c, start.S
cpu/arm_cortexa8/cpu.c | 80 +--- cpu/arm_cortexa8/s5pc100/Makefile | 48 +++ cpu/arm_cortexa8/s5pc100/config.mk | 36 ++ cpu/arm_cortexa8/s5pc100/speed.c | 186 +++++++++ cpu/arm_cortexa8/s5pc100/timer.c | 223 ++++++++++ cpu/arm_cortexa8/start.S | 23 + include/asm-arm/arch-s5pc100/clock-others.h | 33 ++ include/asm-arm/arch-s5pc100/cpu.h | 379 +++++++++++++++++ include/asm-arm/arch-s5pc100/gpio.h | 580 +++++++++++++++++++++++++++ include/asm-arm/arch-s5pc100/hardware.h | 63 +++ include/asm-arm/arch-s5pc100/map-base.h | 19 + include/asm-arm/arch-s5pc100/sys_proto.h | 30 ++ include/asm-arm/arch-s5pc100/uart.h | 68 ++++ include/asm-arm/arch-s5pc100/watchdog.h | 16 + include/s5pc1xx-onenand.h | 105 +++++ 15 files changed, 1828 insertions(+), 61 deletions(-) create mode 100644 cpu/arm_cortexa8/s5pc100/Makefile create mode 100644 cpu/arm_cortexa8/s5pc100/config.mk create mode 100644 cpu/arm_cortexa8/s5pc100/speed.c create mode 100644 cpu/arm_cortexa8/s5pc100/timer.c create mode 100644 include/asm-arm/arch-s5pc100/clock-others.h create mode 100644 include/asm-arm/arch-s5pc100/cpu.h create mode 100644 include/asm-arm/arch-s5pc100/gpio.h create mode 100644 include/asm-arm/arch-s5pc100/hardware.h create mode 100644 include/asm-arm/arch-s5pc100/map-base.h create mode 100644 include/asm-arm/arch-s5pc100/sys_proto.h create mode 100644 include/asm-arm/arch-s5pc100/uart.h create mode 100644 include/asm-arm/arch-s5pc100/watchdog.h create mode 100644 include/s5pc1xx-onenand.h
diff --git a/cpu/arm_cortexa8/cpu.c b/cpu/arm_cortexa8/cpu.c index 6fd07d0..95e8523 100644 --- a/cpu/arm_cortexa8/cpu.c +++ b/cpu/arm_cortexa8/cpu.c @@ -37,11 +37,28 @@ #include <asm/system.h>
#ifndef CONFIG_L2_OFF -void l2cache_disable(void); +void l2_cache_disable(void); +#endif + +#ifdef CONFIG_USE_IRQ +DECLARE_GLOBAL_DATA_PTR; #endif
static void cache_flush(void);
+int cpu_init(void) +{ + /* + * setup up stacks if necessary + */ +#ifdef CONFIG_USE_IRQ + IRQ_STACK_START = + _armboot_start - CONFIG_SYS_MALLOC_LEN - CONFIG_SYS_GBL_DATA_SIZE - 4; + FIQ_STACK_START = IRQ_STACK_START - CONFIG_STACKSIZE_IRQ; +#endif + return 0; +} + int cleanup_before_linux(void) { unsigned int i; @@ -63,7 +80,7 @@ int cleanup_before_linux(void)
#ifndef CONFIG_L2_OFF /* turn off L2 cache */ - l2cache_disable(); + l2_cache_disable(); /* invalidate L2 cache also */ v7_flush_dcache_all(get_device_type()); #endif @@ -78,65 +95,6 @@ int cleanup_before_linux(void) return 0; }
-void l2cache_enable() -{ - unsigned long i; - volatile unsigned int j; - - /* ES2 onwards we can disable/enable L2 ourselves */ - if (get_cpu_rev() >= CPU_3XX_ES20) { - __asm__ __volatile__("mrc p15, 0, %0, c1, c0, 1":"=r"(i)); - __asm__ __volatile__("orr %0, %0, #0x2":"=r"(i)); - __asm__ __volatile__("mcr p15, 0, %0, c1, c0, 1":"=r"(i)); - } else { - /* Save r0, r12 and restore them after usage */ - __asm__ __volatile__("mov %0, r12":"=r"(j)); - __asm__ __volatile__("mov %0, r0":"=r"(i)); - - /* - * GP Device ROM code API usage here - * r12 = AUXCR Write function and r0 value - */ - __asm__ __volatile__("mov r12, #0x3"); - __asm__ __volatile__("mrc p15, 0, r0, c1, c0, 1"); - __asm__ __volatile__("orr r0, r0, #0x2"); - /* SMI instruction to call ROM Code API */ - __asm__ __volatile__(".word 0xE1600070"); - __asm__ __volatile__("mov r0, %0":"=r"(i)); - __asm__ __volatile__("mov r12, %0":"=r"(j)); - } - -} - -void l2cache_disable() -{ - unsigned long i; - volatile unsigned int j; - - /* ES2 onwards we can disable/enable L2 ourselves */ - if (get_cpu_rev() >= CPU_3XX_ES20) { - __asm__ __volatile__("mrc p15, 0, %0, c1, c0, 1":"=r"(i)); - __asm__ __volatile__("bic %0, %0, #0x2":"=r"(i)); - __asm__ __volatile__("mcr p15, 0, %0, c1, c0, 1":"=r"(i)); - } else { - /* Save r0, r12 and restore them after usage */ - __asm__ __volatile__("mov %0, r12":"=r"(j)); - __asm__ __volatile__("mov %0, r0":"=r"(i)); - - /* - * GP Device ROM code API usage here - * r12 = AUXCR Write function and r0 value - */ - __asm__ __volatile__("mov r12, #0x3"); - __asm__ __volatile__("mrc p15, 0, r0, c1, c0, 1"); - __asm__ __volatile__("bic r0, r0, #0x2"); - /* SMI instruction to call ROM Code API */ - __asm__ __volatile__(".word 0xE1600070"); - __asm__ __volatile__("mov r0, %0":"=r"(i)); - __asm__ __volatile__("mov r12, %0":"=r"(j)); - } -} - static void cache_flush(void) { asm ("mcr p15, 0, %0, c7, c5, 0": :"r" (0)); diff --git a/cpu/arm_cortexa8/s5pc100/Makefile b/cpu/arm_cortexa8/s5pc100/Makefile new file mode 100644 index 0000000..511a8dc --- /dev/null +++ b/cpu/arm_cortexa8/s5pc100/Makefile @@ -0,0 +1,48 @@ +# +# (C) Copyright 2000-2003 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# (C) Copyright 2008 +# Guennadi Liakhovetki, DENX Software Engineering, lg@denx.de +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(SOC).a + +COBJS-y = timer.o +COBJS-$(CONFIG_S5PC100) += speed.o + +OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS-y)) + +all: $(obj).depend $(LIB) + +$(LIB): $(OBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/cpu/arm_cortexa8/s5pc100/config.mk b/cpu/arm_cortexa8/s5pc100/config.mk new file mode 100644 index 0000000..e05d7ae --- /dev/null +++ b/cpu/arm_cortexa8/s5pc100/config.mk @@ -0,0 +1,36 @@ +# +# (C) Copyright 2002 +# Gary Jennejohn, DENX Software Engineering, gj@denx.de +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# +PLATFORM_RELFLAGS += -fno-strict-aliasing -fno-common -ffixed-r8 \ + -msoft-float + +# Make ARMv5 to allow more compilers to work, even though its v6. +PLATFORM_CPPFLAGS += -march=armv5t +# ========================================================================= +# +# Supply options according to compiler version +# +# ========================================================================= +PLATFORM_CPPFLAGS +=$(call cc-option) +PLATFORM_CPPFLAGS +=$(call cc-option,-mno-thumb-interwork,) +PLATFORM_RELFLAGS +=$(call cc-option,-mshort-load-bytes,\ + $(call cc-option,-malignment-traps,)) diff --git a/cpu/arm_cortexa8/s5pc100/speed.c b/cpu/arm_cortexa8/s5pc100/speed.c new file mode 100644 index 0000000..c5768f8 --- /dev/null +++ b/cpu/arm_cortexa8/s5pc100/speed.c @@ -0,0 +1,186 @@ +/* + * (C) Copyright 2009 + * Inki Dae, SAMSUNG Electronics, inki.dae@samsung.com + * Heungjun Kim, SAMSUNG Electronics, riverful.kim@samsung.com + * Minkyu Kang, SAMSUNG Electronics, mk7.kang@samsung.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * This code should work for both the S3C2400 and the S3C2410 + * as they seem to have the same PLL and clock machinery inside. + * The different address mapping is handled by the s3c24xx.h files below. + */ + +#include <common.h> + +#define APLL 0 +#define MPLL 1 +#define EPLL 2 +#define HPLL 3 + +/* ------------------------------------------------------------------------- */ +/* + * NOTE: This describes the proper use of this file. + * + * CONFIG_SYS_CLK_FREQ should be defined as the input frequency of the PLL. + * + * get_FCLK(), get_HCLK(), get_PCLK() and get_UCLK() return the clock of + * the specified bus in HZ. + */ +/* ------------------------------------------------------------------------- */ + +static ulong get_PLLCLK(int pllreg) +{ + ulong r, m, p, s, mask; + + switch (pllreg) { + case APLL: + r = S5P_APLL_CON_REG; + break; + case MPLL: + r = S5P_MPLL_CON_REG; + break; + case EPLL: + r = S5P_EPLL_CON_REG; + break; + case HPLL: + r = S5P_HPLL_CON_REG; + break; + default: + hang(); + } + + if (pllreg == APLL) + mask = 0x3ff; + else + mask = 0x0ff; + + m = (r >> 16) & mask; + p = (r >> 8) & 0x3f; + s = r & 0x7; + + return m * (CONFIG_SYS_CLK_FREQ / (p * (1 << s))); +} + +/* return ARMCORE frequency */ +ulong get_ARMCLK(void) +{ + ulong div; + unsigned long dout_apll, armclk; + unsigned int apll_ratio, arm_ratio;; + + div = S5P_CLK_DIV0_REG; + /* ARM_RATIO: [6:4] */ + arm_ratio = (div >> 4) & 0x7; + /* APLL_RATIO: [0] */ + apll_ratio = div & 0x1; + + dout_apll = get_PLLCLK(APLL) / (apll_ratio + 1); + armclk = dout_apll / (arm_ratio + 1); + + return armclk; +} + +/* return FCLK frequency */ +ulong get_FCLK(void) +{ + return get_PLLCLK(APLL); +} + +/* return MCLK frequency */ +ulong get_MCLK(void) +{ + return get_PLLCLK(MPLL); +} + +/* return HCLKD0 frequency */ +ulong get_HCLK(void) +{ + ulong hclkd0; + uint div, d0_bus_ratio; + + div = S5P_CLK_DIV0_REG; + /* D0_BUS_RATIO: [10:8] */ + d0_bus_ratio = (div >> 8) & 0x7; + + hclkd0 = get_ARMCLK() / (d0_bus_ratio + 1); + + return hclkd0; +} + +/* return PCLKD0 frequency */ +ulong get_PCLKD0(void) +{ + ulong pclkd0; + uint div, pclkd0_ratio; + + div = S5P_CLK_DIV0_REG; + /* PCLKD0_RATIO: [14:12] */ + pclkd0_ratio = (div >> 12) & 0x7; + + pclkd0 = get_HCLK() / (pclkd0_ratio + 1); + + return pclkd0; +} + +/* return PCLKD1 frequency */ +ulong get_PCLK(void) +{ + ulong d1_bus, pclkd1; + uint div, d1_bus_ratio, pclkd1_ratio; + + div = S5P_CLK_DIV1_REG; + /* D1_BUS_RATIO: [14:12] */ + d1_bus_ratio = (div >> 12) & 0x7; + /* PCLKD1_RATIO: [18:16] */ + pclkd1_ratio = (div >> 16) & 0x7; + + /* ASYNC Mode */ + d1_bus = get_PLLCLK(MPLL) / (d1_bus_ratio + 1); + pclkd1 = d1_bus / (pclkd1_ratio + 1); + + return pclkd1; +} + +/* return UCLK frequency */ +ulong get_UCLK(void) +{ + return get_PLLCLK(EPLL); +} + +#ifdef CONFIG_DISPLAY_CPUINFO +int print_cpuinfo(void) +{ + unsigned int pid = __REG(S5P_PRO_ID); + + pid >>= 12; + pid &= 0x00fff; + + printf("CPU:\tS5PC%x@%luMHz\n", pid, get_ARMCLK() / 1000000); + printf("\tFclk = %luMHz, HclkD0 = %luMHz, PclkD0 = %luMHz," + " PclkD1 = %luMHz\n", + get_FCLK() / 1000000, get_HCLK() / 1000000, + get_PCLKD0() / 1000000, get_PCLK() / 1000000); + + return 0; +} +#endif + diff --git a/cpu/arm_cortexa8/s5pc100/timer.c b/cpu/arm_cortexa8/s5pc100/timer.c new file mode 100644 index 0000000..0864600 --- /dev/null +++ b/cpu/arm_cortexa8/s5pc100/timer.c @@ -0,0 +1,223 @@ +/* + * (C) Copyright 2003 + * Texas Instruments <www.ti.com> + * + * (C) Copyright 2002 + * Sysgo Real-Time Solutions, GmbH <www.elinos.com> + * Marius Groeger mgroeger@sysgo.de + * + * (C) Copyright 2002 + * Sysgo Real-Time Solutions, GmbH <www.elinos.com> + * Alex Zuepke azu@sysgo.de + * + * (C) Copyright 2002-2004 + * Gary Jennejohn, DENX Software Engineering, gj@denx.de + * + * (C) Copyright 2004 + * Philippe Robin, ARM Ltd. philippe.robin@arm.com + * + * (C) Copyright 2008 + * Guennadi Liakhovetki, DENX Software Engineering, lg@denx.de + * + * (C) Copyright 2009 + * Heungjun Kim, SAMSUNG Electronics, riverful.kim@samsung.com + * Inki Dae, SAMSUNG Electronics, inki.dae@samsung.com + * Minkyu Kang, SAMSUNG Electronics, mk7.kang@samsung.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> + +#define PRESCALER_1 (16 - 1) /* prescaler of timer 2, 3, 4 */ +#define MUX_DIV_2 (1) /* 1/2 period */ +#define MUX_DIV_4 (2) /* 1/4 period */ +#define MUX_DIV_8 (3) /* 1/8 period */ +#define MUX_DIV_16 (4) /* 1/16 period */ +#define MUX4_DIV_SHIFT 16 + +#define TCON_TIMER4_SHIFT 20 + +static ulong count_value; + +/* Internal tick units */ +static unsigned long long timestamp; /* Monotonic incrementing timer */ +static unsigned long lastdec; /* Last decremneter snapshot */ + +/* macro to read the 16 bit timer */ +static inline ulong READ_TIMER(void) +{ + const s5pc1xx_timers_t *timers = (s5pc1xx_timers_t *) S5P_TIMER_BASE; + + return timers->TCNTO4; +} + +int timer_init(void) +{ + s5pc1xx_timers_t *timers = (s5pc1xx_timers_t *) S5P_TIMER_BASE; + + /* + * @ PWM Timer 4 + * Timer Freq(HZ) = + * PCLK / { (prescaler_value + 1) * (divider_value) } + */ + + /* set prescaler : 16 */ + /* set divider : 2 */ + timers->TCFG0 = (PRESCALER_1 & 0xff) << 8; + timers->TCFG1 = (MUX_DIV_2 & 0xf) << MUX4_DIV_SHIFT; + + if (count_value == 0) { + + /* reset initial value */ + /* count_value = 2085937.5(HZ) (per 1 sec)*/ + count_value = get_PCLK() / ((PRESCALER_1 + 1) * + (MUX_DIV_2 + 1)); + + /* count_value / 100 = 20859.375(HZ) (per 10 msec) */ + count_value = count_value / 100; + } + + /* set count value */ + timers->TCNTB4 = count_value; + lastdec = count_value; + + /* auto reload & manual update */ + timers->TCON = (timers->TCON & ~(0x07 << TCON_TIMER4_SHIFT)) | + S5P_TCON4_AUTO_RELOAD | S5P_TCON4_UPDATE; + + /* start PWM timer 4 */ + timers->TCON = (timers->TCON & ~(0x07 << TCON_TIMER4_SHIFT)) | + S5P_TCON4_AUTO_RELOAD | S5P_TCON4_ON; + + timestamp = 0; + + return 0; +} + + +/* + * timer without interrupts + */ +void reset_timer(void) +{ + reset_timer_masked(); +} + +ulong get_timer(ulong base) +{ + return get_timer_masked() - base; +} + +void set_timer(ulong t) +{ + timestamp = t; +} + +/* delay x useconds */ +void udelay(unsigned long usec) +{ + ulong tmo, tmp; + + if (usec >= 1000) { + /* + * if "big" number, spread normalization + * to seconds + * 1. start to normalize for usec to ticks per sec + * 2. find number of "ticks" to wait to achieve target + * 3. finish normalize. + */ + tmo = usec / 1000; + tmo *= CONFIG_SYS_HZ; + tmo /= 1000; + } else { + /* else small number, don't kill it prior to HZ multiply */ + tmo = usec * CONFIG_SYS_HZ; + tmo /= (1000 * 1000); + } + + /* get current timestamp */ + tmp = get_timer(0); + + /* if setting this fordward will roll time stamp */ + /* reset "advancing" timestamp to 0, set lastdec value */ + /* else, set advancing stamp wake up time */ + if ((tmo + tmp + 1) < tmp) + reset_timer_masked(); + else + tmo += tmp; + + /* loop till event */ + while (get_timer_masked() < tmo) + ; /* nop */ +} + +void reset_timer_masked(void) +{ + /* reset time */ + lastdec = READ_TIMER(); + timestamp = 0; +} + +ulong get_timer_masked(void) +{ + /* current tick value */ + ulong now = READ_TIMER(); + + if (lastdec >= now) + timestamp += lastdec - now; + else + timestamp += lastdec + count_value - now; + + lastdec = now; + + return timestamp; +} + +/* + * This function is derived from PowerPC code (read timebase as long long). + * On ARM it just returns the timer value. + */ +unsigned long long get_ticks(void) +{ + return get_timer(0); +} + +/* + * This function is derived from PowerPC code (timebase clock frequency). + * On ARM it returns the number of timer ticks per second. + */ +ulong get_tbclk(void) +{ + /* We overrun in 100s */ + return CONFIG_SYS_HZ * 100; +} + +void reset_cpu(ulong ignored) +{ + unsigned int pid = __REG(S5P_PRO_ID); + + pid >>= 12; + pid &= 0x00fff; + pid |= (0xC << 12); + + __REG(S5P_SW_RST) = pid; + + while (1) ; +} diff --git a/cpu/arm_cortexa8/start.S b/cpu/arm_cortexa8/start.S index 66b4820..da6eed7 100644 --- a/cpu/arm_cortexa8/start.S +++ b/cpu/arm_cortexa8/start.S @@ -34,6 +34,7 @@
.globl _start _start: b reset +#ifndef CONFIG_ONENAND_IPL ldr pc, _undefined_instruction ldr pc, _software_interrupt ldr pc, _prefetch_abort @@ -50,6 +51,9 @@ _not_used: .word not_used _irq: .word irq _fiq: .word fiq _pad: .word 0x12345678 /* now 16*4=64 */ +#else + . = _start + 64 +#endif .global _end_vect _end_vect:
@@ -108,6 +112,7 @@ reset: orr r0, r0, #0xd3 msr cpsr,r0
+#ifndef CONFIG_ONENAND_IPL #if (CONFIG_OMAP34XX) /* Copy vectors to mask ROM indirect addr */ adr r0, _start @ r0 <- current position of code @@ -131,11 +136,13 @@ next: bl cpy_clk_code @ put dpll adjust code behind vectors #endif /* NAND Boot */ #endif +#endif /* CONFIG_ONENAND_IPL */ /* the mask ROM code should have PLL and others stable */ #ifndef CONFIG_SKIP_LOWLEVEL_INIT bl cpu_init_crit #endif
+#ifndef CONFIG_ONENAND_IPL #ifndef CONFIG_SKIP_RELOCATE_UBOOT relocate: @ relocate U-Boot to RAM adr r0, _start @ r0 <- current position of code @@ -154,18 +161,24 @@ copy_loop: @ copy 32 bytes at a time cmp r0, r2 @ until source end addreee [r2] ble copy_loop #endif /* CONFIG_SKIP_RELOCATE_UBOOT */ +#endif /* CONFIG_ONENAND_IPL */
/* Set up the stack */ stack_setup: ldr r0, _TEXT_BASE @ upper 128 KiB: relocated uboot +#ifdef CONFIG_ONENAND_IPL + sub sp, r0, #128 @ leave 32 words for abort-stack +#else sub r0, r0, #CONFIG_SYS_MALLOC_LEN @ malloc area sub r0, r0, #CONFIG_SYS_GBL_DATA_SIZE @ bdinfo #ifdef CONFIG_USE_IRQ sub r0, r0, #(CONFIG_STACKSIZE_IRQ + CONFIG_STACKSIZE_FIQ) #endif sub sp, r0, #12 @ leave 3 words for abort-stack +#endif /* CONFIG_ONENAND_IPL */ and sp, sp, #~7 @ 8 byte alinged for (ldr/str)d
+#ifndef CONFIG_ONENAND_IPL /* Clear BSS (if any). Is below tx (watch load addr - need space) */ clear_bss: ldr r0, _bss_start @ find start of bss segment @@ -176,10 +189,15 @@ clbss_l: cmp r0, r1 @ are we at the end yet add r0, r0, #4 @ increment clear index pointer bne clbss_l @ keep clearing till at end +#endif /* CONFIG_ONENAND_IPL */
ldr pc, _start_armboot @ jump to C code
+#ifdef CONFIG_ONENAND_IPL +_start_armboot: .word start_oneboot +#else _start_armboot: .word start_armboot +#endif
/************************************************************************* @@ -218,6 +236,8 @@ cpu_init_crit: bl lowlevel_init @ go setup pll,mux,memory mov lr, ip @ restore link mov pc, lr @ back to my caller + +#ifndef CONFIG_ONENAND_IPL /* ************************************************************************* * @@ -502,6 +522,7 @@ finished_inval: ldmfd r13!, {r0 - r5, r7, r9 - r12, pc}
+#if (CONFIG_OMAP34XX) .align 5 .global reset_cpu reset_cpu: @@ -514,3 +535,5 @@ _loop_forever: b _loop_forever rstctl: .word PRM_RSTCTRL +#endif +#endif /* CONFIG_ONENAND_IPL */ diff --git a/include/asm-arm/arch-s5pc100/clock-others.h b/include/asm-arm/arch-s5pc100/clock-others.h new file mode 100644 index 0000000..35f1686 --- /dev/null +++ b/include/asm-arm/arch-s5pc100/clock-others.h @@ -0,0 +1,33 @@ + +/* + * Clock control - Others + */ +#define S5P_OTHERS_REG_BASE(x) (S5P_PA_CLK_OTHERS + (x)) +#define S5P_OTHERS_BASE S5P_OTHERS_REG_BASE(0x0) +#define S5P_SW_RST S5P_OTHERS_REG_BASE(0x0) +#define S5P_ONENAND_RST S5P_OTHERS_REG_BASE(0x8) +#define S5P_GENERAL_CTRL S5P_OTHERS_REG_BASE(0x100) +#define S5P_GENERAL_STATUS S5P_OTHERS_REG_BASE(0x104) +#define S5P_MEM_SYS_CFG S5P_OTHERS_REG_BASE(0x200) +#define S5P_CAM_MUX_SEL S5P_OTHERS_REG_BASE(0x300) +#define S5P_MIXER_OUT_SEL S5P_OTHERS_REG_BASE(0x304) +#define S5P_LPMP3_MODE_SEL S5P_OTHERS_REG_BASE(0x308) +#define S5P_MIPI_PHY_CON0 S5P_OTHERS_REG_BASE(0x400) +#define S5P_MIPI_PHY_CON1 S5P_OTHERS_REG_BASE(0x414) +#define S5P_HDMI_PHY_CON0 S5P_OTHERS_REG_BASE(0x420) + +#ifndef __ASSEMBLY__ +#define S5P_OTHERS_BASE_REG __REG(S5P_OTHERS_BASE) +#define S5P_SW_RST_REG __REG(S5P_SW_RST) +#define S5P_ONENAND_RST_REG __REG(S5P_ONENAND_RST) +#define S5P_GENERAL_CTRL_REG __REG(S5P_GENERAL_CTRL) +#define S5P_GENERAL_STATUS_REG __REG(S5P_GENERAL_STATUS) +#define S5P_MEM_SYS_CFG_REG __REG(S5P_MEM_SYS_CFG) +#define S5P_CAM_MUX_SEL_REG __REG(S5P_CAM_MUX_SEL) +#define S5P_MIXER_OUT_SEL_REG __REG(S5P_MIXER_OUT_SEL) +#define S5P_LPMP3_MODE_SEL_REG __REG(S5P_LPMP3_MODE_SEL) +#define S5P_MIPI_PHY_CON0_REG __REG(S5P_MIPI_PHY_CON0) +#define S5P_MIPI_PHY_CON1_REG __REG(S5P_MIPI_PHY_CON1) +#define S5P_HDMI_PHY_CON0_REG __REG(S5P_HDMI_PHY_CON0) +#endif /* __ASSENBLY__ */ + diff --git a/include/asm-arm/arch-s5pc100/cpu.h b/include/asm-arm/arch-s5pc100/cpu.h new file mode 100644 index 0000000..6ec8656 --- /dev/null +++ b/include/asm-arm/arch-s5pc100/cpu.h @@ -0,0 +1,379 @@ +/* + * (C) Copyright 2009 + * Samsung Electronics, <www.samsung.com/sec> + * Heungjun Kim riverful.kim@samsung.com + * Minkyu Kang mk7.kang@samsung.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + */ + +#ifndef _CPU_H +#define _CPU_H + +#include <asm/hardware.h> + +#ifndef __S5PC100_H__ +#define __S5PC100_H__ + +#define S5P_ADDR_BASE 0xe0000000 +#define S5P_ADDR(x) (S5P_ADDR_BASE + (x)) + +#define S5P_PA_ID S5P_ADDR(0x00000000) /* Chip ID Base */ +#define S5P_PA_CLK S5P_ADDR(0x00100000) /* Clock Base */ +#define S5P_PA_PWR S5P_ADDR(0x00108000) /* Power Base */ +#define S5P_PA_CLK_OTHERS S5P_ADDR(0x00200000) /* Clock Others Base */ +#define S5P_PA_GPIO S5P_ADDR(0x00300000) /* GPIO Base */ +#define S5P_PA_VIC0 S5P_ADDR(0x04000000) /* Vector Interrupt Controller 0 */ +#define S5P_PA_VIC1 S5P_ADDR(0x04100000) /* Vector Interrupt Controller 1 */ +#define S5P_PA_VIC2 S5P_ADDR(0x04200000) /* Vector Interrupt Controller 2 */ +#define S5P_PA_DMC S5P_ADDR(0x06000000) /* Dram Memory Controller */ +#define S5P_PA_SROMC S5P_ADDR(0x07000000) /* SROM Controller */ +#define S5P_PA_WATCHDOG S5P_ADDR(0x0a200000) /* Watchdog Timer */ +#define S5P_PA_PWMTIMER S5P_ADDR(0x0a000000) /* PWM Timer */ + +/* + * Chip ID + */ +#define S5P_ID(x) (S5P_PA_ID + (x)) + +#define S5P_PRO_ID S5P_ID(0) +#define S5P_OMR S5P_ID(4) + +/* + * Clock control + */ +#define S5P_CLKREG(x) (S5P_PA_CLK + (x)) + +/* Clock Register */ +#define S5P_APLL_LOCK S5P_CLKREG(0x0) +#define S5P_MPLL_LOCK S5P_CLKREG(0x4) +#define S5P_EPLL_LOCK S5P_CLKREG(0x8) +#define S5P_HPLL_LOCK S5P_CLKREG(0xc) + +#define S5P_APLL_CON S5P_CLKREG(0x100) +#define S5P_MPLL_CON S5P_CLKREG(0x104) +#define S5P_EPLL_CON S5P_CLKREG(0x108) +#define S5P_HPLL_CON S5P_CLKREG(0x10c) + +#define S5P_CLK_SRC0 S5P_CLKREG(0x200) +#define S5P_CLK_SRC1 S5P_CLKREG(0x204) +#define S5P_CLK_SRC2 S5P_CLKREG(0x208) +#define S5P_CLK_SRC3 S5P_CLKREG(0x20c) + +#define S5P_CLK_DIV0 S5P_CLKREG(0x300) +#define S5P_CLK_DIV1 S5P_CLKREG(0x304) +#define S5P_CLK_DIV2 S5P_CLKREG(0x308) +#define S5P_CLK_DIV3 S5P_CLKREG(0x30c) +#define S5P_CLK_DIV4 S5P_CLKREG(0x310) + +#define S5P_CLK_OUT S5P_CLKREG(0x400) + +#define S5P_CLK_GATE_D00 S5P_CLKREG(0x500) +#define S5P_CLK_GATE_D01 S5P_CLKREG(0x504) +#define S5P_CLK_GATE_D02 S5P_CLKREG(0x508) + +#define S5P_CLK_GATE_D10 S5P_CLKREG(0x520) +#define S5P_CLK_GATE_D11 S5P_CLKREG(0x524) +#define S5P_CLK_GATE_D12 S5P_CLKREG(0x528) +#define S5P_CLK_GATE_D13 S5P_CLKREG(0x530) +#define S5P_CLK_GATE_D14 S5P_CLKREG(0x534) + +#define S5P_CLK_GATE_D20 S5P_CLKREG(0x540) + +#define S5P_CLK_GATE_SCLK0 S5P_CLKREG(0x560) +#define S5P_CLK_GATE_SCLK1 S5P_CLKREG(0x564) + +#ifndef __ASSEMBLY__ +/* Clock Address */ +#define S5P_APLL_LOCK_REG __REG(S5P_APLL_LOCK) +#define S5P_MPLL_LOCK_REG __REG(S5P_MPLL_LOCK) +#define S5P_EPLL_LOCK_REG __REG(S5P_EPLL_LOCK) +#define S5P_HPLL_LOCK_REG __REG(S5P_HPLL_LOCK) + +#define S5P_APLL_CON_REG __REG(S5P_APLL_CON) +#define S5P_MPLL_CON_REG __REG(S5P_MPLL_CON) +#define S5P_EPLL_CON_REG __REG(S5P_EPLL_CON) +#define S5P_HPLL_CON_REG __REG(S5P_HPLL_CON) + +#define S5P_CLK_SRC0_REG __REG(S5P_CLK_SRC0) +#define S5P_CLK_SRC1_REG __REG(S5P_CLK_SRC1) +#define S5P_CLK_SRC2_REG __REG(S5P_CLK_SRC2) +#define S5P_CLK_SRC3_REG __REG(S5P_CLK_SRC3) + +#define S5P_CLK_DIV0_REG __REG(S5P_CLK_DIV0) +#define S5P_CLK_DIV1_REG __REG(S5P_CLK_DIV1) +#define S5P_CLK_DIV2_REG __REG(S5P_CLK_DIV2) +#define S5P_CLK_DIV3_REG __REG(S5P_CLK_DIV3) +#define S5P_CLK_DIV4_REG __REG(S5P_CLK_DIV4) + +#define S5P_CLK_OUT_REG __REG(S5P_CLK_OUT) + +#define S5P_CLK_GATE_D00_REG __REG(S5P_CLK_GATE_D00) +#define S5P_CLK_GATE_D01_REG __REG(S5P_CLK_GATE_D01) +#define S5P_CLK_GATE_D02_REG __REG(S5P_CLK_GATE_D02) + +#define S5P_CLK_GATE_D10_REG __REG(S5P_CLK_GATE_D10) +#define S5P_CLK_GATE_D11_REG __REG(S5P_CLK_GATE_D11) +#define S5P_CLK_GATE_D12_REG __REG(S5P_CLK_GATE_D12) +#define S5P_CLK_GATE_D13_REG __REG(S5P_CLK_GATE_D13) +#define S5P_CLK_GATE_D14_REG __REG(S5P_CLK_GATE_D14) + +#define S5P_CLK_GATE_D20_REG __REG(S5P_CLK_GATE_D20) + +#define S5P_CLK_GATE_SCLK0_REG __REG(S5P_CLK_GATE_SCLK0) +#define S5P_CLK_GATE_SCLK1_REG __REG(S5P_CLK_GATE_SCLK1) +#endif /* __ASSENBLY__ */ + + +/* + * Power control + */ +#define S5P_PWRREG(x) (S5P_PA_PWR + (x)) + +#define S5P_PWR_CFG S5P_PWRREG(0x0) +#define S5P_EINT_WAKEUP_MASK S5P_PWRREG(0x04) +#define S5P_NORMAL_CFG S5P_PWRREG(0x10) +#define S5P_STOP_CFG S5P_PWRREG(0x14) +#define S5P_SLEEP_CFG S5P_PWRREG(0x18) +#define S5P_STOP_MEM_CFG S5P_PWRREG(0x1c) +#define S5P_OSC_FREQ S5P_PWRREG(0x100) +#define S5P_OSC_STABLE S5P_PWRREG(0x104) +#define S5P_PWR_STABLE S5P_PWRREG(0x108) +#define S5P_INTERNAL_PWR_STABLE S5P_PWRREG(0x110) +#define S5P_CLAMP_STABLE S5P_PWRREG(0x114) +#define S5P_OTHERS S5P_PWRREG(0x200) +#define S5P_RST_STAT S5P_PWRREG(0x300) +#define S5P_WAKEUP_STAT S5P_PWRREG(0x304) +#define S5P_BLK_PWR_STAT S5P_PWRREG(0x308) +#define S5P_INFORM0 S5P_PWRREG(0x400) +#define S5P_INFORM1 S5P_PWRREG(0x404) +#define S5P_INFORM2 S5P_PWRREG(0x408) +#define S5P_INFORM3 S5P_PWRREG(0x40c) +#define S5P_INFORM4 S5P_PWRREG(0x410) +#define S5P_INFORM5 S5P_PWRREG(0x414) +#define S5P_INFORM6 S5P_PWRREG(0x418) +#define S5P_INFORM7 S5P_PWRREG(0x41c) +#define S5P_DCGIDX_MAP0 S5P_PWRREG(0x500) +#define S5P_DCGIDX_MAP1 S5P_PWRREG(0x504) +#define S5P_DCGIDX_MAP2 S5P_PWRREG(0x508) +#define S5P_DCGPERF_MAP0 S5P_PWRREG(0x50c) +#define S5P_DCGPERF_MAP1 S5P_PWRREG(0x510) +#define S5P_DVCIDX_MAP S5P_PWRREG(0x514) +#define S5P_FREQ_CPU S5P_PWRREG(0x518) +#define S5P_FREQ_DPM S5P_PWRREG(0x51c) +#define S5P_DVSEMCLK_EN S5P_PWRREG(0x520) +#define S5P_APLL_CON_L8 S5P_PWRREG(0x600) +#define S5P_APLL_CON_L7 S5P_PWRREG(0x604) +#define S5P_APLL_CON_L6 S5P_PWRREG(0x608) +#define S5P_APLL_CON_L5 S5P_PWRREG(0x60c) +#define S5P_APLL_CON_L4 S5P_PWRREG(0x610) +#define S5P_APLL_CON_L3 S5P_PWRREG(0x614) +#define S5P_APLL_CON_L2 S5P_PWRREG(0x618) +#define S5P_APLL_CON_L1 S5P_PWRREG(0x61c) +#define S5P_EM_CONTROL S5P_PWRREG(0x620) + +#define S5P_CLKDIV_IEM_L8 S5P_PWRREG(0x700) +#define S5P_CLKDIV_IEM_L7 S5P_PWRREG(0x704) +#define S5P_CLKDIV_IEM_L6 S5P_PWRREG(0x708) +#define S5P_CLKDIV_IEM_L5 S5P_PWRREG(0x70c) +#define S5P_CLKDIV_IEM_L4 S5P_PWRREG(0x710) +#define S5P_CLKDIV_IEM_L3 S5P_PWRREG(0x714) +#define S5P_CLKDIV_IEM_L2 S5P_PWRREG(0x718) +#define S5P_CLKDIV_IEM_L1 S5P_PWRREG(0x71c) + +#define S5P_IEM_HPMCLK_DIV S5P_PWRREG(0x724) + + +/* + * Vector Interrupt Controller + * : VIC0, VIC1, VIC2 + */ +/* VIC0 */ +#define S5P_VIC0_BASE(x) (S5P_PA_VIC0 + (x)) +#define S5P_VIC1_BASE(x) (S5P_PA_VIC1 + (x)) +#define S5P_VIC2_BASE(x) (S5P_PA_VIC2 + (x)) + +/* Vector Interrupt Offset */ +#define VIC_IRQSTATUS_OFFSET 0x0 /* IRQ Status Register */ +#define VIC_FIQSTATUS_OFFSET 0x4 /* FIQ Status Register */ +#define VIC_RAWINTR_OFFSET 0x8 /* Raw Interrupt Status Register */ +#define VIC_INTSELECT_OFFSET 0xc /* Interrupt Select Register */ +#define VIC_INTENABLE_OFFSET 0x10 /* Interrupt Enable Register */ +#define VIC_INTENCLEAR_OFFSET 0x14 /* Interrupt Enable Clear Register */ +#define VIC_SOFTINT_OFFSET 0x18 /* Software Interrupt Register */ +#define VIC_SOFTINTCLEAR_OFFSET 0x1c /* Software Interrupt Clear Register */ +#define VIC_PROTECTION_OFFSET 0x20 /* Protection Enable Register */ +#define VIC_SWPRIORITYMASK_OFFSET 0x24 /* Software Priority Mask Register */ +#define VIC_PRIORITYDAISY_OFFSET 0x28 /* Vector Priority Register for Daisy Chain */ +#define VIC_INTADDRESS_OFFSET 0xf00 /* Vector Priority Register for Daisy Chain */ + + +/* + * SROMC Controller + */ +/* DRAM Memory Controller */ +#define S5P_DMC_BASE(x) (S5P_PA_DMC + (x)) +/* SROMC Base */ +#define S5P_SROMC_BASE(x) (S5P_PA_SROMC + (x)) +/* SROMC offset */ +#define CONCONTROL_OFFSET 0x0 /* Controller Control Register */ +#define MEMCONTROL_OFFSET 0x04 /* Memory Control Register */ +#define MEMCONFIG0_OFFSET 0x08 /* Memory Chip0 Configuration Register */ +#define MEMCONFIG1_OFFSET 0x0c /* Memory Chip1 Configuration Register */ +#define DIRECTCMD_OFFSET 0x10 /* Memory Direct Command Register */ +#define PRECHCONFIG_OFFSET 0x14 /* Precharge Policy Configuration Register */ +#define PHYCONTROL0_OFFSET 0x18 /* PHY Control0 Register */ +#define PHYCONTROL1_OFFSET 0x1c /* PHY Control1 Register */ +#define PHYCONTROL2_OFFSET 0x20 /* PHY Control2 Register */ +#define PWRDNCONFIG_OFFSET 0x28 /* Dynamic Power Down Configuration Register */ +#define TIMINGAREF_OFFSET 0x30 /* AC Timing Register for SDRAM Auto Refresh */ +#define TIMINGROW_OFFSET 0x34 /* AC Timing Register for SDRAM Row */ +#define TIMINGDATA_OFFSET 0x38 /* AC Timing Register for SDRAM Data */ +#define TIMINGPOWER_OFFSET 0x3c /* AC Timing Register for Power Mode of SDRAM */ +#define PHYSTATUS0_OFFSET 0x40 /* PHY Status Register 0 */ +#define PHYSTATUS1_OFFSET 0x44 /* PHY Status Register 1 */ +#define CHIP0STATUS_OFFSET 0x48 /* Memory Chip0 Status Register */ +#define CHIP1STATUS_OFFSET 0x4c /* Memory Chip1 Status Register */ +#define AREFSTATUS_OFFSET 0x50 /* Counter status Register for Auto Refresh */ +#define MRSTATUS_OFFSET 0x54 /* Memory Mode Registers Status Register */ +#define PHYTEST0_OFFSET 0x58 /* PHY Test Register 0 */ +#define PHYTEST1_OFFSET 0x5c /* PHY Test Register 1 */ + +#define S5P_CONCONTROL S5P_DMC_BASE(CONCONTROL_OFFSET) +#define S5P_MEMCONTROL S5P_DMC_BASE(MEMCONTROL_OFFSET) +#define S5P_MEMCONFIG0 S5P_DMC_BASE(MEMCONFIG0_OFFSET) +#define S5P_MEMCONFIG1 S5P_DMC_BASE(MEMCONFIG1_OFFSET) +#define S5P_DIRECTCMD S5P_DMC_BASE(DIRECTCMD_OFFSET) +#define S5P_PRECHCONFIG S5P_DMC_BASE(PRECHCONFIG_OFFSET) +#define S5P_PHYCONTROL0 S5P_DMC_BASE(PHYCONTROL0_OFFSET) +#define S5P_PHYCONTROL1 S5P_DMC_BASE(PHYCONTROL1_OFFSET) +#define S5P_PHYCONTROL2 S5P_DMC_BASE(PHYCONTROL2_OFFSET) +#define S5P_PWRDNCONFIG S5P_DMC_BASE(PWRDNCONFIG_OFFSET) +#define S5P_TIMINGAREF S5P_DMC_BASE(TIMINGAREF_OFFSET) +#define S5P_TIMINGROW S5P_DMC_BASE(TIMINGROW_OFFSET) +#define S5P_TIMINGDATA S5P_DMC_BASE(TIMINGDATA_OFFSET) +#define S5P_TIMINGPOWER S5P_DMC_BASE(TIMINGPOWER_OFFSET) +#define S5P_PHYSTATUS0 S5P_DMC_BASE(PHYSTATUS0_OFFSET) +#define S5P_PHYSTATUS1 S5P_DMC_BASE(PHYSTATUS1_OFFSET) +#define S5P_CHIP0STATUS S5P_DMC_BASE(CHIP0STATUS_OFFSET) +#define S5P_CHIP1STATUS S5P_DMC_BASE(CHIP1STATUS_OFFSET) +#define S5P_AREFSTATUS S5P_DMC_BASE(AREFSTATUS_OFFSET) +#define S5P_MRSTATUS S5P_DMC_BASE(MRSTATUS_OFFSET) +#define S5P_PHYTEST0 S5P_DMC_BASE(PHYTEST0_OFFSET) +#define S5P_PHYTEST1 S5P_DMC_BASE(PHYTEST1_OFFSET) + + +/* + * PWM Timer + */ +#define S5P_PWMTIMER_BASE(x) (S5P_PA_PWMTIMER + (x)) + +/* PWM timer offset */ +#define PWM_TCFG0_OFFSET 0x0 +#define PWM_TCFG1_OFFSET 0x04 +#define PWM_TCON_OFFSET 0x08 +#define PWM_TCNTB0_OFFSET 0x0c +#define PWM_TCMPB0_OFFSET 0x10 +#define PWM_TCNTO0_OFFSET 0x14 +#define PWM_TCNTB1_OFFSET 0x18 +#define PWM_TCMPB1_OFFSET 0x1c +#define PWM_TCNTO1_OFFSET 0x20 +#define PWM_TCNTB2_OFFSET 0x24 +#define PWM_TCMPB2_OFFSET 0x28 +#define PWM_TCNTO2_OFFSET 0x2c +#define PWM_TCNTB3_OFFSET 0x30 +#define PWM_TCNTO3_OFFSET 0x38 +#define PWM_TCNTB4_OFFSET 0x3c +#define PWM_TCNTO4_OFFSET 0x40 +#define PWM_TINT_CSTAT_OFFSET 0x44 + +/* PWM timer register */ +#define S5P_PWM_TCFG0 S5P_PWMTIMER_BASE(PWM_TCFG0_OFFSET) +#define S5P_PWM_TCFG1 S5P_PWMTIMER_BASE(PWM_TCFG1_OFFSET) +#define S5P_PWM_TCON S5P_PWMTIMER_BASE(PWM_TCON_OFFSET) +#define S5P_PWM_TCNTB0 S5P_PWMTIMER_BASE(PWM_TCNTB0_OFFSET) +#define S5P_PWM_TCMPB0 S5P_PWMTIMER_BASE(PWM_TCMPB0_OFFSET) +#define S5P_PWM_TCNTO0 S5P_PWMTIMER_BASE(PWM_TCNTO0_OFFSET) +#define S5P_PWM_TCNTB1 S5P_PWMTIMER_BASE(PWM_TCNTB1_OFFSET) +#define S5P_PWM_TCMPB1 S5P_PWMTIMER_BASE(PWM_TCMPB1_OFFSET) +#define S5P_PWM_TCNTO1 S5P_PWMTIMER_BASE(PWM_TCNTO1_OFFSET) +#define S5P_PWM_TCNTB2 S5P_PWMTIMER_BASE(PWM_TCNTB2_OFFSET) +#define S5P_PWM_TCMPB2 S5P_PWMTIMER_BASE(PWM_TCMPB2_OFFSET) +#define S5P_PWM_TCNTO2 S5P_PWMTIMER_BASE(PWM_TCNTO2_OFFSET) +#define S5P_PWM_TCNTB3 S5P_PWMTIMER_BASE(PWM_TCNTB3_OFFSET) +#define S5P_PWM_TCNTO3 S5P_PWMTIMER_BASE(PWM_TCNTO3_OFFSET) +#define S5P_PWM_TCNTB4 S5P_PWMTIMER_BASE(PWM_TCNTB4_OFFSET) +#define S5P_PWM_TCNTO4 S5P_PWMTIMER_BASE(PWM_TCNTO4_OFFSET) +#define S5P_PWM_TINT_CSTAT S5P_PWMTIMER_BASE(PWM_TINT_CSTAT_OFFSET) + +/* PWM timer addressing */ +#define S5P_TIMER_BASE S5P_PWMTIMER_BASE(0x0) +#define S5P_PWMTIMER_BASE_REG __REG(S5P_PWMTIMER_BASE(0x0)) +#define S5P_PWM_TCFG0_REG __REG(S5P_PWM_TCFG0) +#define S5P_PWM_TCFG1_REG __REG(S5P_PWM_TCFG1) +#define S5P_PWM_TCON_REG __REG(S5P_PWM_TCON) +#define S5P_PWM_TCNTB0_REG __REG(S5P_PWM_TCNTB0) +#define S5P_PWM_TCMPB0_REG __REG(S5P_PWM_TCMPB0) +#define S5P_PWM_TCNTO0_REG __REG(S5P_PWM_TCNTO0) +#define S5P_PWM_TCNTB1_REG __REG(S5P_PWM_TCNTB1) +#define S5P_PWM_TCMPB1_REG __REG(S5P_PWM_TCMPB1) +#define S5P_PWM_TCNTO1_REG __REG(S5P_PWM_TCNTO1) +#define S5P_PWM_TCNTB2_REG __REG(S5P_PWM_TCNTB2) +#define S5P_PWM_TCMPB2_REG __REG(S5P_PWM_TCMPB2) +#define S5P_PWM_TCNTO2_REG __REG(S5P_PWM_TCNTO2) +#define S5P_PWM_TCNTB3_REG __REG(S5P_PWM_TCNTB3) +#define S5P_PWM_TCNTO3_REG __REG(S5P_PWM_TCNTO3) +#define S5P_PWM_TCNTB4_REG __REG(S5P_PWM_TCNTB4) +#define S5P_PWM_TCNTO4_REG __REG(S5P_PWM_TCNTO4) +#define S5P_PWM_TINT_CSTAT_REG __REG(S5P_PWM_TINT_CSTAT) + +/* PWM timer value */ +#define S5P_TCON4_AUTO_RELOAD (1 << 22) /* Interval mode(Auto Reload) of PWM Timer 4 */ +#define S5P_TCON4_UPDATE (1 << 21) /* Update TCNTB4 */ +#define S5P_TCON4_ON (1 << 20) /* start bit of PWM Timer 4 */ + +#ifndef __ASSEMBLY__ +typedef struct s5pc1xx_timer { + volatile unsigned long TCFG0; + volatile unsigned long TCFG1; + volatile unsigned long TCON; + volatile unsigned long TCNTB0; + volatile unsigned long TCMPB0; + volatile unsigned long TCNTO0; + volatile unsigned long TCNTB1; + volatile unsigned long TCMPB1; + volatile unsigned long TCNTO1; + volatile unsigned long TCNTB2; + volatile unsigned long TCMPB2; + volatile unsigned long TCNTO2; + volatile unsigned long TCNTB3; + volatile unsigned long res1; + volatile unsigned long TCNTO3; + volatile unsigned long TCNTB4; + volatile unsigned long TCNTO4; + volatile unsigned long TINTCSTAT; +} s5pc1xx_timers_t; +#endif /* __ASSEMBLY__ */ + +#include <asm/arch/uart.h> +#include <asm/arch/watchdog.h> +#include <asm/arch/gpio.h> +#include <asm/arch/clock-others.h> + +#endif /* __S5PC100_H__ */ + +#endif /* _CPU_H */ diff --git a/include/asm-arm/arch-s5pc100/gpio.h b/include/asm-arm/arch-s5pc100/gpio.h new file mode 100644 index 0000000..bd49aaa --- /dev/null +++ b/include/asm-arm/arch-s5pc100/gpio.h @@ -0,0 +1,580 @@ +/* + * (C) Copyright 2009 SAMSUNG Electronics + * Heungjun Kim riverful.kim@samsung.com + * Minkyu Kang mk7.kang@samsung.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * GPIO + */ + +/* GPIO Bank Base */ +#define S5P_GPIO_BASE(x) (S5P_PA_GPIO + (x)) + +#define S5P_GPIO_A_REG(x) (S5P_GPIO_BASE(0x0) + (x)) +#define S5P_GPIO_B_REG(x) (S5P_GPIO_BASE(0x40) + (x)) +#define S5P_GPIO_C_REG(x) (S5P_GPIO_BASE(0x60) + (x)) +#define S5P_GPIO_D_REG(x) (S5P_GPIO_BASE(0x80) + (x)) +#define S5P_GPIO_E_REG(x) (S5P_GPIO_BASE(0xa0) + (x)) +#define S5P_GPIO_F_REG(x) (S5P_GPIO_BASE(0xe0) + (x)) +#define S5P_GPIO_G_REG(x) (S5P_GPIO_BASE(0x160) + (x)) +#define S5P_GPIO_I_REG(x) (S5P_GPIO_BASE(0x1e0) + (x)) +#define S5P_GPIO_J_REG(x) (S5P_GPIO_BASE(0x200) + (x)) +#define S5P_GPIO_K_REG(x) (S5P_GPIO_BASE(0x2a0) + (x)) +#define S5P_GPIO_L_REG(x) (S5P_GPIO_BASE(0x320) + (x)) + +#define S5P_MP_REG(x) (S5P_GPIO_BASE(0x3c0) + (x)) +#define S5P_ETC_REG(x) (S5P_GPIO_BASE(0x4e0) + (x)) + +#define S5P_GPIO_INT_CON_REG(x) (S5P_GPIO_BASE(0x700) + (x)) +#define S5P_GPIO_INT_FLTCON_REG(x) (S5P_GPIO_BASE(0x800) + (x)) +#define S5P_GPIO_INT_MASK_REG(x) (S5P_GPIO_BASE(0x900) + (x)) +#define S5P_GPIO_INT_PEND_REG(x) (S5P_GPIO_BASE(0xa00) + (x)) +#define S5P_GPIO_INT_PRIO_REG(x) (S5P_GPIO_BASE(0xb00) + (x)) + +#define S5P_GPIO_H_REG(x) (S5P_GPIO_BASE(0xc00) + (x)) + +#define S5P_WAKEUP_INT_CON(x) (S5P_GPIO_BASE(0xe00) + (x)) +#define S5P_WAKEUP_FLTINT_CON(x) (S5P_GPIO_BASE(0xe80) + (x)) +#define S5P_WAKEUP_INT_MASK(x) (S5P_GPIO_BASE(0xf00) + (x)) +#define S5P_WAKEUP_INT_PEND(x) (S5P_GPIO_BASE(0xf40) + (x)) + + +/* GPIO Offset */ +#define CON_OFFSET 0x0 +#define DAT_OFFSET 0x4 +#define PULL_OFFSET 0x8 +#define DRV_OFFSET 0xc +#define PDNCON_OFFSET 0x10 +#define PDNPULL_OFFSET 0x14 + + +/* GPIO A Bank Base */ +#define S5P_GPIO_A0_BASE(x) (S5P_GPIO_A_REG(0x0) + (x)) +#define S5P_GPIO_A1_BASE(x) (S5P_GPIO_A_REG(0x20) + (x)) + +#define S5P_GPIO_A0_CON S5P_GPIO_A0_BASE(CON_OFFSET) +#define S5P_GPIO_A0_DAT S5P_GPIO_A0_BASE(DAT_OFFSET) +#define S5P_GPIO_A0_PULL S5P_GPIO_A0_BASE(PULL_OFFSET) +#define S5P_GPIO_A0_DRV S5P_GPIO_A0_BASE(DRV_OFFSET) +#define S5P_GPIO_A0_PDNCON S5P_GPIO_A0_BASE(PDNCON_OFFSET) +#define S5P_GPIO_A0_PDNPUL S5P_GPIO_A0_BASE(PDNPULL_OFFSET) + +#define S5P_GPIO_A1_CON S5P_GPIO_A1_BASE(CON_OFFSET) +#define S5P_GPIO_A1_DAT S5P_GPIO_A1_BASE(DAT_OFFSET) +#define S5P_GPIO_A1_PULL S5P_GPIO_A1_BASE(PULL_OFFSET) +#define S5P_GPIO_A1_DRV S5P_GPIO_A1_BASE(DRV_OFFSET) +#define S5P_GPIO_A1_PDNCON S5P_GPIO_A1_BASE(PDNCON_OFFSET) +#define S5P_GPIO_A1_PDNPUL S5P_GPIO_A1_BASE(PDNPULL_OFFSET) + +/* GPIO B Bank Base */ +#define S5P_GPIO_B_BASE(x) (S5P_GPIO_B_REG(0x0) + (x)) + +#define S5P_GPIO_B_CON S5P_GPIO_B_BASE(CON_OFFSET) +#define S5P_GPIO_B_DAT S5P_GPIO_B_BASE(DAT_OFFSET) +#define S5P_GPIO_B_PULL S5P_GPIO_B_BASE(PULL_OFFSET) +#define S5P_GPIO_B_DRV S5P_GPIO_B_BASE(DRV_OFFSET) +#define S5P_GPIO_B_PDNCON S5P_GPIO_B_BASE(PDNCON_OFFSET) +#define S5P_GPIO_B_PDNPUL S5P_GPIO_B_BASE(PDNPULL_OFFSET) + +/* GPIO C Bank Base */ +#define S5P_GPIO_C_BASE(x) (S5P_GPIO_C_REG(0x0) + (x)) + +#define S5P_GPIO_C_CON S5P_GPIO_C_BASE(CON_OFFSET) +#define S5P_GPIO_C_DAT S5P_GPIO_C_BASE(DAT_OFFSET) +#define S5P_GPIO_C_PULL S5P_GPIO_C_BASE(PULL_OFFSET) +#define S5P_GPIO_C_DRV S5P_GPIO_C_BASE(DRV_OFFSET) +#define S5P_GPIO_C_PDNCON S5P_GPIO_C_BASE(PDNCON_OFFSET) +#define S5P_GPIO_C_PDNPUL S5P_GPIO_C_BASE(PDNPULL_OFFSET) + +/* GPIO D Bank Base */ +#define S5P_GPIO_D_BASE(x) (S5P_GPIO_D_REG(0x0) + (x)) + +#define S5P_GPIO_D_CON S5P_GPIO_D_BASE(CON_OFFSET) +#define S5P_GPIO_D_DAT S5P_GPIO_D_BASE(DAT_OFFSET) +#define S5P_GPIO_D_PULL S5P_GPIO_D_BASE(PULL_OFFSET) +#define S5P_GPIO_D_DRV S5P_GPIO_D_BASE(DRV_OFFSET) +#define S5P_GPIO_D_PDNCON S5P_GPIO_D_BASE(PDNCON_OFFSET) +#define S5P_GPIO_D_PDNPUL S5P_GPIO_D_BASE(PDNPULL_OFFSET) + +/* GPIO E Bank Base */ +#define S5P_GPIO_E0_BASE(x) (S5P_GPIO_E_REG(0x0) + (x)) +#define S5P_GPIO_E1_BASE(x) (S5P_GPIO_E_REG(0x20) + (x)) + +#define S5P_GPIO_E0_CON S5P_GPIO_E0_BASE(CON_OFFSET) +#define S5P_GPIO_E0_DAT S5P_GPIO_E0_BASE(DAT_OFFSET) +#define S5P_GPIO_E0_PULL S5P_GPIO_E0_BASE(PULL_OFFSET) +#define S5P_GPIO_E0_DRV S5P_GPIO_E0_BASE(DRV_OFFSET) +#define S5P_GPIO_E0_PDNCON S5P_GPIO_E0_BASE(PDNCON_OFFSET) +#define S5P_GPIO_E0_PDNPUL S5P_GPIO_E0_BASE(PDNPULL_OFFSET) + +#define S5P_GPIO_E1_CON S5P_GPIO_E1_BASE(CON_OFFSET) +#define S5P_GPIO_E1_DAT S5P_GPIO_E1_BASE(DAT_OFFSET) +#define S5P_GPIO_E1_PULL S5P_GPIO_E1_BASE(PULL_OFFSET) +#define S5P_GPIO_E1_DRV S5P_GPIO_E1_BASE(DRV_OFFSET) +#define S5P_GPIO_E1_PDNCON S5P_GPIO_E1_BASE(PDNCON_OFFSET) +#define S5P_GPIO_E1_PDNPUL S5P_GPIO_E1_BASE(PDNPULL_OFFSET) + +/* GPIO F Bank Base */ +#define S5P_GPIO_F0_BASE(x) (S5P_GPIO_F_REG(0x0) + (x)) +#define S5P_GPIO_F1_BASE(x) (S5P_GPIO_F_REG(0x20) + (x)) +#define S5P_GPIO_F2_BASE(x) (S5P_GPIO_F_REG(0x40) + (x)) +#define S5P_GPIO_F3_BASE(x) (S5P_GPIO_F_REG(0x60) + (x)) + +#define S5P_GPIO_F0_CON S5P_GPIO_F0_BASE(CON_OFFSET) +#define S5P_GPIO_F0_DAT S5P_GPIO_F0_BASE(DAT_OFFSET) +#define S5P_GPIO_F0_PULL S5P_GPIO_F0_BASE(PULL_OFFSET) +#define S5P_GPIO_F0_DRV S5P_GPIO_F0_BASE(DRV_OFFSET) +#define S5P_GPIO_F0_PDNCON S5P_GPIO_F0_BASE(PDNCON_OFFSET) +#define S5P_GPIO_F0_PDNPUL S5P_GPIO_F0_BASE(PDNPULL_OFFSET) + +#define S5P_GPIO_F1_CON S5P_GPIO_F1_BASE(CON_OFFSET) +#define S5P_GPIO_F1_DAT S5P_GPIO_F1_BASE(DAT_OFFSET) +#define S5P_GPIO_F1_PULL S5P_GPIO_F1_BASE(PULL_OFFSET) +#define S5P_GPIO_F1_DRV S5P_GPIO_F1_BASE(DRV_OFFSET) +#define S5P_GPIO_F1_PDNCON S5P_GPIO_F1_BASE(PDNCON_OFFSET) +#define S5P_GPIO_F1_PDNPUL S5P_GPIO_F1_BASE(PDNPULL_OFFSET) + +#define S5P_GPIO_F2_CON S5P_GPIO_F2_BASE(CON_OFFSET) +#define S5P_GPIO_F2_DAT S5P_GPIO_F2_BASE(DAT_OFFSET) +#define S5P_GPIO_F2_PULL S5P_GPIO_F2_BASE(PULL_OFFSET) +#define S5P_GPIO_F2_DRV S5P_GPIO_F2_BASE(DRV_OFFSET) +#define S5P_GPIO_F2_PDNCON S5P_GPIO_F2_BASE(PDNCON_OFFSET) +#define S5P_GPIO_F2_PDNPUL S5P_GPIO_F2_BASE(PDNPULL_OFFSET) + +#define S5P_GPIO_F3_CON S5P_GPIO_F3_BASE(CON_OFFSET) +#define S5P_GPIO_F3_DAT S5P_GPIO_F3_BASE(DAT_OFFSET) +#define S5P_GPIO_F3_PULL S5P_GPIO_F3_BASE(PULL_OFFSET) +#define S5P_GPIO_F3_DRV S5P_GPIO_F3_BASE(DRV_OFFSET) +#define S5P_GPIO_F3_PDNCON S5P_GPIO_F3_BASE(PDNCON_OFFSET) +#define S5P_GPIO_F3_PDNPUL S5P_GPIO_F3_BASE(PDNPULL_OFFSET) + +/* GPIO G Bank Base */ +#define S5P_GPIO_G0_BASE(x) (S5P_GPIO_G_REG(0x0) + (x)) +#define S5P_GPIO_G1_BASE(x) (S5P_GPIO_G_REG(0x20) + (x)) +#define S5P_GPIO_G2_BASE(x) (S5P_GPIO_G_REG(0x40) + (x)) +#define S5P_GPIO_G3_BASE(x) (S5P_GPIO_G_REG(0x60) + (x)) + +#define S5P_GPIO_G0_CON S5P_GPIO_G0_BASE(CON_OFFSET) +#define S5P_GPIO_G0_DAT S5P_GPIO_G0_BASE(DAT_OFFSET) +#define S5P_GPIO_G0_PULL S5P_GPIO_G0_BASE(PULL_OFFSET) +#define S5P_GPIO_G0_DRV S5P_GPIO_G0_BASE(DRV_OFFSET) +#define S5P_GPIO_G0_PDNCON S5P_GPIO_G0_BASE(PDNCON_OFFSET) +#define S5P_GPIO_G0_PDNPUL S5P_GPIO_G0_BASE(PDNPULL_OFFSET) + +#define S5P_GPIO_G1_CON S5P_GPIO_G1_BASE(CON_OFFSET) +#define S5P_GPIO_G1_DAT S5P_GPIO_G1_BASE(DAT_OFFSET) +#define S5P_GPIO_G1_PULL S5P_GPIO_G1_BASE(PULL_OFFSET) +#define S5P_GPIO_G1_DRV S5P_GPIO_G1_BASE(DRV_OFFSET) +#define S5P_GPIO_G1_PDNCON S5P_GPIO_G1_BASE(PDNCON_OFFSET) +#define S5P_GPIO_G1_PDNPUL S5P_GPIO_G1_BASE(PDNPULL_OFFSET) + +#define S5P_GPIO_G2_CON S5P_GPIO_G2_BASE(CON_OFFSET) +#define S5P_GPIO_G2_DAT S5P_GPIO_G2_BASE(DAT_OFFSET) +#define S5P_GPIO_G2_PULL S5P_GPIO_G2_BASE(PULL_OFFSET) +#define S5P_GPIO_G2_DRV S5P_GPIO_G2_BASE(DRV_OFFSET) +#define S5P_GPIO_G2_PDNCON S5P_GPIO_G2_BASE(PDNCON_OFFSET) +#define S5P_GPIO_G2_PDNPUL S5P_GPIO_G2_BASE(PDNPULL_OFFSET) + +#define S5P_GPIO_G3_CON S5P_GPIO_G3_BASE(CON_OFFSET) +#define S5P_GPIO_G3_DAT S5P_GPIO_G3_BASE(DAT_OFFSET) +#define S5P_GPIO_G3_PULL S5P_GPIO_G3_BASE(PULL_OFFSET) +#define S5P_GPIO_G3_DRV S5P_GPIO_G3_BASE(DRV_OFFSET) +#define S5P_GPIO_G3_PDNCON S5P_GPIO_G3_BASE(PDNCON_OFFSET) +#define S5P_GPIO_G3_PDNPUL S5P_GPIO_G3_BASE(PDNPULL_OFFSET) + +/* GPIO I Bank Base */ +#define S5P_GPIO_I_BASE(x) (S5P_GPIO_I_REG(0x0) + (x)) + +#define S5P_GPIO_I_CON S5P_GPIO_I_BASE(CON_OFFSET) +#define S5P_GPIO_I_DAT S5P_GPIO_I_BASE(DAT_OFFSET) +#define S5P_GPIO_I_PULL S5P_GPIO_I_BASE(PULL_OFFSET) +#define S5P_GPIO_I_DRV S5P_GPIO_I_BASE(DRV_OFFSET) +#define S5P_GPIO_I_PDNCON S5P_GPIO_I_BASE(PDNCON_OFFSET) +#define S5P_GPIO_I_PDNPUL S5P_GPIO_I_BASE(PDNPULL_OFFSET) + +/* GPIO J Bank Base */ +#define S5P_GPIO_J0_BASE(x) (S5P_GPIO_J_REG(0x0) + (x)) +#define S5P_GPIO_J1_BASE(x) (S5P_GPIO_J_REG(0x20) + (x)) +#define S5P_GPIO_J2_BASE(x) (S5P_GPIO_J_REG(0x40) + (x)) +#define S5P_GPIO_J3_BASE(x) (S5P_GPIO_J_REG(0x60) + (x)) +#define S5P_GPIO_J4_BASE(x) (S5P_GPIO_J_REG(0x80) + (x)) + +#define S5P_GPIO_J0_CON S5P_GPIO_J0_BASE(CON_OFFSET) +#define S5P_GPIO_J0_DAT S5P_GPIO_J0_BASE(DAT_OFFSET) +#define S5P_GPIO_J0_PULL S5P_GPIO_J0_BASE(PULL_OFFSET) +#define S5P_GPIO_J0_DRV S5P_GPIO_J0_BASE(DRV_OFFSET) +#define S5P_GPIO_J0_PDNCON S5P_GPIO_J0_BASE(PDNCON_OFFSET) +#define S5P_GPIO_J0_PDNPUL S5P_GPIO_J0_BASE(PDNPULL_OFFSET) + +#define S5P_GPIO_J1_CON S5P_GPIO_J1_BASE(CON_OFFSET) +#define S5P_GPIO_J1_DAT S5P_GPIO_J1_BASE(DAT_OFFSET) +#define S5P_GPIO_J1_PULL S5P_GPIO_J1_BASE(PULL_OFFSET) +#define S5P_GPIO_J1_DRV S5P_GPIO_J1_BASE(DRV_OFFSET) +#define S5P_GPIO_J1_PDNCON S5P_GPIO_J1_BASE(PDNCON_OFFSET) +#define S5P_GPIO_J1_PDNPUL S5P_GPIO_J1_BASE(PDNPULL_OFFSET) + +#define S5P_GPIO_J2_CON S5P_GPIO_J2_BASE(CON_OFFSET) +#define S5P_GPIO_J2_DAT S5P_GPIO_J2_BASE(DAT_OFFSET) +#define S5P_GPIO_J2_PULL S5P_GPIO_J2_BASE(PULL_OFFSET) +#define S5P_GPIO_J2_DRV S5P_GPIO_J2_BASE(DRV_OFFSET) +#define S5P_GPIO_J2_PDNCON S5P_GPIO_J2_BASE(PDNCON_OFFSET) +#define S5P_GPIO_J2_PDNPUL S5P_GPIO_J2_BASE(PDNPULL_OFFSET) + +#define S5P_GPIO_J3_CON S5P_GPIO_J3_BASE(CON_OFFSET) +#define S5P_GPIO_J3_DAT S5P_GPIO_J3_BASE(DAT_OFFSET) +#define S5P_GPIO_J3_PULL S5P_GPIO_J3_BASE(PULL_OFFSET) +#define S5P_GPIO_J3_DRV S5P_GPIO_J3_BASE(DRV_OFFSET) +#define S5P_GPIO_J3_PDNCON S5P_GPIO_J3_BASE(PDNCON_OFFSET) +#define S5P_GPIO_J3_PDNPUL S5P_GPIO_J3_BASE(PDNPULL_OFFSET) + +#define S5P_GPIO_J4_CON S5P_GPIO_J4_BASE(CON_OFFSET) +#define S5P_GPIO_J4_DAT S5P_GPIO_J4_BASE(DAT_OFFSET) +#define S5P_GPIO_J4_PULL S5P_GPIO_J4_BASE(PULL_OFFSET) +#define S5P_GPIO_J4_DRV S5P_GPIO_J4_BASE(DRV_OFFSET) +#define S5P_GPIO_J4_PDNCON S5P_GPIO_J4_BASE(PDNCON_OFFSET) +#define S5P_GPIO_J4_PDNPUL S5P_GPIO_J4_BASE(PDNPULL_OFFSET) + +/* GPIO K Bank Base */ +#define S5P_GPIO_K0_BASE(x) (S5P_GPIO_K_REG(0x0) + (x)) +#define S5P_GPIO_K1_BASE(x) (S5P_GPIO_K_REG(0x20) + (x)) +#define S5P_GPIO_K2_BASE(x) (S5P_GPIO_K_REG(0x40) + (x)) +#define S5P_GPIO_K3_BASE(x) (S5P_GPIO_K_REG(0x60) + (x)) + +#define S5P_GPIO_K0_CON S5P_GPIO_K0_BASE(CON_OFFSET) +#define S5P_GPIO_K0_DAT S5P_GPIO_K0_BASE(DAT_OFFSET) +#define S5P_GPIO_K0_PULL S5P_GPIO_K0_BASE(PULL_OFFSET) +#define S5P_GPIO_K0_DRV S5P_GPIO_K0_BASE(DRV_OFFSET) +#define S5P_GPIO_K0_PDNCON S5P_GPIO_K0_BASE(PDNCON_OFFSET) +#define S5P_GPIO_K0_PDNPUL S5P_GPIO_K0_BASE(PDNPULL_OFFSET) + +#define S5P_GPIO_K1_CON S5P_GPIO_K1_BASE(CON_OFFSET) +#define S5P_GPIO_K1_DAT S5P_GPIO_K1_BASE(DAT_OFFSET) +#define S5P_GPIO_K1_PULL S5P_GPIO_K1_BASE(PULL_OFFSET) +#define S5P_GPIO_K1_DRV S5P_GPIO_K1_BASE(DRV_OFFSET) +#define S5P_GPIO_K1_PDNCON S5P_GPIO_K1_BASE(PDNCON_OFFSET) +#define S5P_GPIO_K1_PDNPUL S5P_GPIO_K1_BASE(PDNPULL_OFFSET) + +#define S5P_GPIO_K2_CON S5P_GPIO_K2_BASE(CON_OFFSET) +#define S5P_GPIO_K2_DAT S5P_GPIO_K2_BASE(DAT_OFFSET) +#define S5P_GPIO_K2_PULL S5P_GPIO_K2_BASE(PULL_OFFSET) +#define S5P_GPIO_K2_DRV S5P_GPIO_K2_BASE(DRV_OFFSET) +#define S5P_GPIO_K2_PDNCON S5P_GPIO_K2_BASE(PDNCON_OFFSET) +#define S5P_GPIO_K2_PDNPUL S5P_GPIO_K2_BASE(PDNPULL_OFFSET) + +#define S5P_GPIO_K3_CON S5P_GPIO_K3_BASE(CON_OFFSET) +#define S5P_GPIO_K3_DAT S5P_GPIO_K3_BASE(DAT_OFFSET) +#define S5P_GPIO_K3_PULL S5P_GPIO_K3_BASE(PULL_OFFSET) +#define S5P_GPIO_K3_DRV S5P_GPIO_K3_BASE(DRV_OFFSET) +#define S5P_GPIO_K3_PDNCON S5P_GPIO_K3_BASE(PDNCON_OFFSET) +#define S5P_GPIO_K3_PDNPUL S5P_GPIO_K3_BASE(PDNPULL_OFFSET) + +/* GPIO L Bank */ +#define S5P_GPIO_L0_BASE(x) (S5P_GPIO_L_REG(0x0) + (x)) +#define S5P_GPIO_L1_BASE(x) (S5P_GPIO_L_REG(0x20) + (x)) +#define S5P_GPIO_L2_BASE(x) (S5P_GPIO_L_REG(0x40) + (x)) +#define S5P_GPIO_L3_BASE(x) (S5P_GPIO_L_REG(0x60) + (x)) +#define S5P_GPIO_L4_BASE(x) (S5P_GPIO_L_REG(0x80) + (x)) + +#define S5P_GPIO_L0_CON S5P_GPIO_L0_BASE(CON_OFFSET) +#define S5P_GPIO_L0_DAT S5P_GPIO_L0_BASE(DAT_OFFSET) +#define S5P_GPIO_L0_PULL S5P_GPIO_L0_BASE(PULL_OFFSET) +#define S5P_GPIO_L0_DRV S5P_GPIO_L0_BASE(DRV_OFFSET) +#define S5P_GPIO_L0_PDNCON S5P_GPIO_L0_BASE(PDNCON_OFFSET) +#define S5P_GPIO_L0_PDNPUL S5P_GPIO_L0_BASE(PDNPULL_OFFSET) + +#define S5P_GPIO_L1_CON S5P_GPIO_L1_BASE(CON_OFFSET) +#define S5P_GPIO_L1_DAT S5P_GPIO_L1_BASE(DAT_OFFSET) +#define S5P_GPIO_L1_PULL S5P_GPIO_L1_BASE(PULL_OFFSET) +#define S5P_GPIO_L1_DRV S5P_GPIO_L1_BASE(DRV_OFFSET) +#define S5P_GPIO_L1_PDNCON S5P_GPIO_L1_BASE(PDNCON_OFFSET) +#define S5P_GPIO_L1_PDNPUL S5P_GPIO_L1_BASE(PDNPULL_OFFSET) + +#define S5P_GPIO_L2_CON S5P_GPIO_L2_BASE(CON_OFFSET) +#define S5P_GPIO_L2_DAT S5P_GPIO_L2_BASE(DAT_OFFSET) +#define S5P_GPIO_L2_PULL S5P_GPIO_L2_BASE(PULL_OFFSET) +#define S5P_GPIO_L2_DRV S5P_GPIO_L2_BASE(DRV_OFFSET) +#define S5P_GPIO_L2_PDNCON S5P_GPIO_L2_BASE(PDNCON_OFFSET) +#define S5P_GPIO_L2_PDNPUL S5P_GPIO_L2_BASE(PDNPULL_OFFSET) + +#define S5P_GPIO_L3_CON S5P_GPIO_L3_BASE(CON_OFFSET) +#define S5P_GPIO_L3_DAT S5P_GPIO_L3_BASE(DAT_OFFSET) +#define S5P_GPIO_L3_PULL S5P_GPIO_L3_BASE(PULL_OFFSET) +#define S5P_GPIO_L3_DRV S5P_GPIO_L3_BASE(DRV_OFFSET) +#define S5P_GPIO_L3_PDNCON S5P_GPIO_L3_BASE(PDNCON_OFFSET) +#define S5P_GPIO_L3_PDNPUL S5P_GPIO_L3_BASE(PDNPULL_OFFSET) + +#define S5P_GPIO_L4_CON S5P_GPIO_L4_BASE(CON_OFFSET) +#define S5P_GPIO_L4_DAT S5P_GPIO_L4_BASE(DAT_OFFSET) +#define S5P_GPIO_L4_PULL S5P_GPIO_L4_BASE(PULL_OFFSET) +#define S5P_GPIO_L4_DRV S5P_GPIO_L4_BASE(DRV_OFFSET) +#define S5P_GPIO_L4_PDNCON S5P_GPIO_L4_BASE(PDNCON_OFFSET) +#define S5P_GPIO_L4_PDNPUL S5P_GPIO_L4_BASE(PDNPULL_OFFSET) + +/* GPIO MP Bank */ +#define S5P_MP_0_OFFSET 0x0 +#define S5P_MP_1_OFFSET 0x20 +#define S5P_MP_2_OFFSET 0x40 +#define S5P_MP_3_OFFSET 0x60 +#define S5P_MP_4_OFFSET 0x80 +#define S5P_MP_5_OFFSET 0xa0 +#define S5P_MP_6_OFFSET 0xc0 +#define S5P_MP_7_OFFSET 0xe0 + +#define S5P_MP_0_BASE(x) (S5P_MP_REG(S5P_MP_0_OFFSET) + (x)) +#define S5P_MP_1_BASE(x) (S5P_MP_REG(S5P_MP_1_OFFSET) + (x)) +#define S5P_MP_2_BASE(x) (S5P_MP_REG(S5P_MP_2_OFFSET) + (x)) +#define S5P_MP_3_BASE(x) (S5P_MP_REG(S5P_MP_3_OFFSET) + (x)) +#define S5P_MP_4_BASE(x) (S5P_MP_REG(S5P_MP_4_OFFSET) + (x)) +#define S5P_MP_5_BASE(x) (S5P_MP_REG(S5P_MP_5_OFFSET) + (x)) +#define S5P_MP_6_BASE(x) (S5P_MP_REG(S5P_MP_6_OFFSET) + (x)) +#define S5P_MP_7_BASE(x) (S5P_MP_REG(S5P_MP_7_OFFSET) + (x)) + +#define S5P_MP_0PULL S5P_MP_0_BASE(PULL_OFFSET) +#define S5P_MP_0DRV S5P_MP_0_BASE(DRV_OFFSET) +#define S5P_MP_0PDNPULL S5P_MP_0_BASE(PDNPULL_OFFSET) + +#define S5P_MP_1PULL S5P_MP_1_BASE(PULL_OFFSET) +#define S5P_MP_1DRV S5P_MP_1_BASE(DRV_OFFSET) +#define S5P_MP_1PDNPULL S5P_MP_1_BASE(PDNPULL_OFFSET) + +#define S5P_MP_2PULL S5P_MP_2_BASE(PULL_OFFSET) +#define S5P_MP_2DRV S5P_MP_2_BASE(DRV_OFFSET) +#define S5P_MP_2PDNPULL S5P_MP_2_BASE(PDNPULL_OFFSET) + +#define S5P_MP_3DRV S5P_MP_3_BASE(DRV_OFFSET) +#define S5P_MP_4DRV S5P_MP_4_BASE(DRV_OFFSET) +#define S5P_MP_5DRV S5P_MP_5_BASE(DRV_OFFSET) +#define S5P_MP_6DRV S5P_MP_6_BASE(DRV_OFFSET) +#define S5P_MP_7DRV S5P_MP_7_BASE(DRV_OFFSET) +#define S5P_MP_8DRV S5P_MP_8_BASE(DRV_OFFSET) + +/* GPIO ETC Bank */ +#define S5P_ETC0_BASE(x) (S5P_ETC_REG(0x0) + (x)) +#define S5P_ETC1_BASE(x) (S5P_ETC_REG(0x20) + (x)) +#define S5P_ETC2_BASE(x) (S5P_ETC_REG(0x40) + (x)) +#define S5P_ETC3_BASE(x) (S5P_ETC_REG(0x60) + (x)) +#define S5P_ETC4_BASE(x) (S5P_ETC_REG(0x80) + (x)) + +#define S5P_ETC0PULL S5P_ETC0_BASE(PULL_OFFSET) +#define S5P_ETC0DRV S5P_ETC0_BASE(DRV_OFFSET) +#define S5P_ETC1PULL S5P_ETC1_BASE(PULL_OFFSET) +#define S5P_ETC1DRV S5P_ETC1_BASE(DRV_OFFSET) +#define S5P_ETC2PULL S5P_ETC2_BASE(PULL_OFFSET) +#define S5P_ETC2DRV S5P_ETC2_BASE(DRV_OFFSET) +#define S5P_ETC3PULL S5P_ETC3_BASE(PULL_OFFSET) +#define S5P_ETC3DRV S5P_ETC3_BASE(DRV_OFFSET) +#define S5P_ETC4DRV S5P_ETC4_BASE(DRV_OFFSET) + +/* GPIO External Interrupt */ +#define S5P_GPIO_INT0_CON S5P_GPIO_INT_CON_REG(0x0) +#define S5P_GPIO_INT1_CON S5P_GPIO_INT_CON_REG(0x4) +#define S5P_GPIO_INT2_CON S5P_GPIO_INT_CON_REG(0x8) +#define S5P_GPIO_INT3_CON S5P_GPIO_INT_CON_REG(0xc) +#define S5P_GPIO_INT4_CON S5P_GPIO_INT_CON_REG(0x10) +#define S5P_GPIO_INT5_CON S5P_GPIO_INT_CON_REG(0x14) +#define S5P_GPIO_INT6_CON S5P_GPIO_INT_CON_REG(0x18) +#define S5P_GPIO_INT7_CON S5P_GPIO_INT_CON_REG(0x1c) +#define S5P_GPIO_INT8_CON S5P_GPIO_INT_CON_REG(0x20) +#define S5P_GPIO_INT9_CON S5P_GPIO_INT_CON_REG(0x24) +#define S5P_GPIO_INT10_CON S5P_GPIO_INT_CON_REG(0x28) +#define S5P_GPIO_INT11_CON S5P_GPIO_INT_CON_REG(0x2c) +#define S5P_GPIO_INT12_CON S5P_GPIO_INT_CON_REG(0x30) +#define S5P_GPIO_INT13_CON S5P_GPIO_INT_CON_REG(0x34) +#define S5P_GPIO_INT14_CON S5P_GPIO_INT_CON_REG(0x38) +#define S5P_GPIO_INT15_CON S5P_GPIO_INT_CON_REG(0x3c) +#define S5P_GPIO_INT16_CON S5P_GPIO_INT_CON_REG(0x40) +#define S5P_GPIO_INT17_CON S5P_GPIO_INT_CON_REG(0x44) +#define S5P_GPIO_INT18_CON S5P_GPIO_INT_CON_REG(0x48) +#define S5P_GPIO_INT19_CON S5P_GPIO_INT_CON_REG(0x4c) +#define S5P_GPIO_INT20_CON S5P_GPIO_INT_CON_REG(0x50) + +#define S5P_GPIO_INT0_FLTCON0 S5P_GPIO_INT_CON_REG(0x0) +#define S5P_GPIO_INT0_FLTCON1 S5P_GPIO_INT_CON_REG(0x4) +#define S5P_GPIO_INT1_FLTCON0 S5P_GPIO_INT_CON_REG(0x8) +#define S5P_GPIO_INT1_FLTCON1 S5P_GPIO_INT_CON_REG(0xc) +#define S5P_GPIO_INT2_FLTCON0 S5P_GPIO_INT_CON_REG(0x10) +#define S5P_GPIO_INT2_FLTCON1 S5P_GPIO_INT_CON_REG(0x14) +#define S5P_GPIO_INT3_FLTCON0 S5P_GPIO_INT_CON_REG(0x18) +#define S5P_GPIO_INT3_FLTCON1 S5P_GPIO_INT_CON_REG(0x1c) +#define S5P_GPIO_INT4_FLTCON0 S5P_GPIO_INT_CON_REG(0x20) +#define S5P_GPIO_INT4_FLTCON1 S5P_GPIO_INT_CON_REG(0x24) +#define S5P_GPIO_INT5_FLTCON0 S5P_GPIO_INT_CON_REG(0x28) +#define S5P_GPIO_INT5_FLTCON1 S5P_GPIO_INT_CON_REG(0x2c) +#define S5P_GPIO_INT6_FLTCON0 S5P_GPIO_INT_CON_REG(0x30) +#define S5P_GPIO_INT6_FLTCON1 S5P_GPIO_INT_CON_REG(0x34) +#define S5P_GPIO_INT7_FLTCON0 S5P_GPIO_INT_CON_REG(0x38) +#define S5P_GPIO_INT7_FLTCON1 S5P_GPIO_INT_CON_REG(0x3c) +#define S5P_GPIO_INT8_FLTCON0 S5P_GPIO_INT_CON_REG(0x40) +#define S5P_GPIO_INT8_FLTCON1 S5P_GPIO_INT_CON_REG(0x44) +#define S5P_GPIO_INT9_FLTCON0 S5P_GPIO_INT_CON_REG(0x48) +#define S5P_GPIO_INT9_FLTCON1 S5P_GPIO_INT_CON_REG(0x4c) +#define S5P_GPIO_INT10_FLTCON0 S5P_GPIO_INT_CON_REG(0x50) +#define S5P_GPIO_INT11_FLTCON0 S5P_GPIO_INT_CON_REG(0x58) +#define S5P_GPIO_INT11_FLTCON1 S5P_GPIO_INT_CON_REG(0x5c) +#define S5P_GPIO_INT12_FLTCON0 S5P_GPIO_INT_CON_REG(0x60) +#define S5P_GPIO_INT13_FLTCON0 S5P_GPIO_INT_CON_REG(0x68) +#define S5P_GPIO_INT13_FLTCON1 S5P_GPIO_INT_CON_REG(0x6c) +#define S5P_GPIO_INT14_FLTCON0 S5P_GPIO_INT_CON_REG(0x70) +#define S5P_GPIO_INT14_FLTCON1 S5P_GPIO_INT_CON_REG(0x74) +#define S5P_GPIO_INT15_FLTCON0 S5P_GPIO_INT_CON_REG(0x78) +#define S5P_GPIO_INT15_FLTCON1 S5P_GPIO_INT_CON_REG(0x7c) +#define S5P_GPIO_INT16_FLTCON0 S5P_GPIO_INT_CON_REG(0x80) +#define S5P_GPIO_INT16_FLTCON1 S5P_GPIO_INT_CON_REG(0x84) +#define S5P_GPIO_INT17_FLTCON0 S5P_GPIO_INT_CON_REG(0x88) +#define S5P_GPIO_INT17_FLTCON1 S5P_GPIO_INT_CON_REG(0x8c) +#define S5P_GPIO_INT18_FLTCON0 S5P_GPIO_INT_CON_REG(0x90) +#define S5P_GPIO_INT18_FLTCON1 S5P_GPIO_INT_CON_REG(0x94) +#define S5P_GPIO_INT19_FLTCON0 S5P_GPIO_INT_CON_REG(0x98) +#define S5P_GPIO_INT19_FLTCON1 S5P_GPIO_INT_CON_REG(0x9c) +#define S5P_GPIO_INT20_FLTCON0 S5P_GPIO_INT_CON_REG(0xa0) + +#define S5P_GPIO_INT0_MASK S5P_GPIO_INT_MASK_REG(0x00) +#define S5P_GPIO_INT1_MASK S5P_GPIO_INT_MASK_REG(0x04) +#define S5P_GPIO_INT2_MASK S5P_GPIO_INT_MASK_REG(0x08) +#define S5P_GPIO_INT3_MASK S5P_GPIO_INT_MASK_REG(0x0c) +#define S5P_GPIO_INT4_MASK S5P_GPIO_INT_MASK_REG(0x10) +#define S5P_GPIO_INT5_MASK S5P_GPIO_INT_MASK_REG(0x14) +#define S5P_GPIO_INT6_MASK S5P_GPIO_INT_MASK_REG(0x18) +#define S5P_GPIO_INT7_MASK S5P_GPIO_INT_MASK_REG(0x1c) +#define S5P_GPIO_INT8_MASK S5P_GPIO_INT_MASK_REG(0x20) +#define S5P_GPIO_INT9_MASK S5P_GPIO_INT_MASK_REG(0x24) +#define S5P_GPIO_INT10_MASK S5P_GPIO_INT_MASK_REG(0x28) +#define S5P_GPIO_INT11_MASK S5P_GPIO_INT_MASK_REG(0x2c) +#define S5P_GPIO_INT12_MASK S5P_GPIO_INT_MASK_REG(0x30) +#define S5P_GPIO_INT13_MASK S5P_GPIO_INT_MASK_REG(0x34) +#define S5P_GPIO_INT14_MASK S5P_GPIO_INT_MASK_REG(0x38) +#define S5P_GPIO_INT15_MASK S5P_GPIO_INT_MASK_REG(0x3c) +#define S5P_GPIO_INT16_MASK S5P_GPIO_INT_MASK_REG(0x40) +#define S5P_GPIO_INT17_MASK S5P_GPIO_INT_MASK_REG(0x44) +#define S5P_GPIO_INT18_MASK S5P_GPIO_INT_MASK_REG(0x48) +#define S5P_GPIO_INT19_MASK S5P_GPIO_INT_MASK_REG(0x4c) +#define S5P_GPIO_INT20_MASK S5P_GPIO_INT_MASK_REG(0x50) + +#define S5P_GPIO_INT0_PEND S5P_GPIO_INT_PEND_REG(0x00) +#define S5P_GPIO_INT1_PEND S5P_GPIO_INT_PEND_REG(0x04) +#define S5P_GPIO_INT2_PEND S5P_GPIO_INT_PEND_REG(0x08) +#define S5P_GPIO_INT3_PEND S5P_GPIO_INT_PEND_REG(0x0c) +#define S5P_GPIO_INT4_PEND S5P_GPIO_INT_PEND_REG(0x10) +#define S5P_GPIO_INT5_PEND S5P_GPIO_INT_PEND_REG(0x14) +#define S5P_GPIO_INT6_PEND S5P_GPIO_INT_PEND_REG(0x18) +#define S5P_GPIO_INT7_PEND S5P_GPIO_INT_PEND_REG(0x1c) +#define S5P_GPIO_INT8_PEND S5P_GPIO_INT_PEND_REG(0x20) +#define S5P_GPIO_INT9_PEND S5P_GPIO_INT_PEND_REG(0x24) +#define S5P_GPIO_INT10_PEND S5P_GPIO_INT_PEND_REG(0x28) +#define S5P_GPIO_INT11_PEND S5P_GPIO_INT_PEND_REG(0x2c) +#define S5P_GPIO_INT12_PEND S5P_GPIO_INT_PEND_REG(0x30) +#define S5P_GPIO_INT13_PEND S5P_GPIO_INT_PEND_REG(0x34) +#define S5P_GPIO_INT14_PEND S5P_GPIO_INT_PEND_REG(0x38) +#define S5P_GPIO_INT15_PEND S5P_GPIO_INT_PEND_REG(0x3c) +#define S5P_GPIO_INT16_PEND S5P_GPIO_INT_PEND_REG(0x40) +#define S5P_GPIO_INT17_PEND S5P_GPIO_INT_PEND_REG(0x44) +#define S5P_GPIO_INT18_PEND S5P_GPIO_INT_PEND_REG(0x48) +#define S5P_GPIO_INT19_PEND S5P_GPIO_INT_PEND_REG(0x4c) +#define S5P_GPIO_INT20_PEND S5P_GPIO_INT_PEND_REG(0x50) + +#define S5P_GPIO_INT_GRPPRI S5P_GPIO_INT_PRIO_REG(0x00) +#define S5P_GPIO_INT_PRIORITY S5P_GPIO_INT_PRIO_REG(0x04) +#define S5P_GPIO_INT_SERVICE S5P_GPIO_INT_PRIO_REG(0x08) +#define S5P_GPIO_INT_SERVICE_PEND S5P_GPIO_INT_PRIO_REG(0x0c) +#define S5P_GPIO_INT_GRPFIXPRI S5P_GPIO_INT_PRIO_REG(0x10) + +#define S5P_GPIO_INT0_FIXPRI S5P_GPIO_INT_PRIO_REG(0x14) +#define S5P_GPIO_INT1_FIXPRI S5P_GPIO_INT_PRIO_REG(0x18) +#define S5P_GPIO_INT2_FIXPRI S5P_GPIO_INT_PRIO_REG(0x1c) +#define S5P_GPIO_INT3_FIXPRI S5P_GPIO_INT_PRIO_REG(0x20) +#define S5P_GPIO_INT4_FIXPRI S5P_GPIO_INT_PRIO_REG(0x24) +#define S5P_GPIO_INT5_FIXPRI S5P_GPIO_INT_PRIO_REG(0x28) +#define S5P_GPIO_INT6_FIXPRI S5P_GPIO_INT_PRIO_REG(0x2c) +#define S5P_GPIO_INT7_FIXPRI S5P_GPIO_INT_PRIO_REG(0x30) +#define S5P_GPIO_INT8_FIXPRI S5P_GPIO_INT_PRIO_REG(0x34) +#define S5P_GPIO_INT9_FIXPRI S5P_GPIO_INT_PRIO_REG(0x38) +#define S5P_GPIO_INT10_FIXPRI S5P_GPIO_INT_PRIO_REG(0x3c) +#define S5P_GPIO_INT11_FIXPRI S5P_GPIO_INT_PRIO_REG(0x40) +#define S5P_GPIO_INT12_FIXPRI S5P_GPIO_INT_PRIO_REG(0x44) +#define S5P_GPIO_INT13_FIXPRI S5P_GPIO_INT_PRIO_REG(0x48) +#define S5P_GPIO_INT14_FIXPRI S5P_GPIO_INT_PRIO_REG(0x4c) +#define S5P_GPIO_INT15_FIXPRI S5P_GPIO_INT_PRIO_REG(0x50) +#define S5P_GPIO_INT16_FIXPRI S5P_GPIO_INT_PRIO_REG(0x54) +#define S5P_GPIO_INT17_FIXPRI S5P_GPIO_INT_PRIO_REG(0x58) +#define S5P_GPIO_INT18_FIXPRI S5P_GPIO_INT_PRIO_REG(0x5c) +#define S5P_GPIO_INT19_FIXPRI S5P_GPIO_INT_PRIO_REG(0x60) +#define S5P_GPIO_INT20_FIXPRI S5P_GPIO_INT_PRIO_REG(0x64) + +/* GPIO H Bank Base */ +#define S5P_GPIO_H0_BASE(x) (S5P_GPIO_H_REG(0x0) + (x)) +#define S5P_GPIO_H1_BASE(x) (S5P_GPIO_H_REG(0x20) + (x)) +#define S5P_GPIO_H2_BASE(x) (S5P_GPIO_H_REG(0x40) + (x)) +#define S5P_GPIO_H3_BASE(x) (S5P_GPIO_H_REG(0x60) + (x)) + +#define S5P_GPIO_H0_CON S5P_GPIO_H0_BASE(CON_OFFSET) +#define S5P_GPIO_H0_DAT S5P_GPIO_H0_BASE(DAT_OFFSET) +#define S5P_GPIO_H0_PULL S5P_GPIO_H0_BASE(PULL_OFFSET) +#define S5P_GPIO_H0_DRV S5P_GPIO_H0_BASE(DRV_OFFSET) +#define S5P_GPIO_H0_PDNCON S5P_GPIO_H0_BASE(PDNCON_OFFSET) +#define S5P_GPIO_H0_PDNPUL S5P_GPIO_H0_BASE(PDNPULL_OFFSET) + +#define S5P_GPIO_H1_CON S5P_GPIO_H1_BASE(CON_OFFSET) +#define S5P_GPIO_H1_DAT S5P_GPIO_H1_BASE(DAT_OFFSET) +#define S5P_GPIO_H1_PULL S5P_GPIO_H1_BASE(PULL_OFFSET) +#define S5P_GPIO_H1_DRV S5P_GPIO_H1_BASE(DRV_OFFSET) +#define S5P_GPIO_H1_PDNCON S5P_GPIO_H1_BASE(PDNCON_OFFSET) +#define S5P_GPIO_H1_PDNPUL S5P_GPIO_H1_BASE(PDNPULL_OFFSET) + +#define S5P_GPIO_H2_CON S5P_GPIO_H2_BASE(CON_OFFSET) +#define S5P_GPIO_H2_DAT S5P_GPIO_H2_BASE(DAT_OFFSET) +#define S5P_GPIO_H2_PULL S5P_GPIO_H2_BASE(PULL_OFFSET) +#define S5P_GPIO_H2_DRV S5P_GPIO_H2_BASE(DRV_OFFSET) +#define S5P_GPIO_H2_PDNCON S5P_GPIO_H2_BASE(PDNCON_OFFSET) +#define S5P_GPIO_H2_PDNPUL S5P_GPIO_H2_BASE(PDNPULL_OFFSET) + +#define S5P_GPIO_H3_CON S5P_GPIO_H3_BASE(CON_OFFSET) +#define S5P_GPIO_H3_DAT S5P_GPIO_H3_BASE(DAT_OFFSET) +#define S5P_GPIO_H3_PULL S5P_GPIO_H3_BASE(PULL_OFFSET) +#define S5P_GPIO_H3_DRV S5P_GPIO_H3_BASE(DRV_OFFSET) +#define S5P_GPIO_H3_PDNCON S5P_GPIO_H3_BASE(PDNCON_OFFSET) +#define S5P_GPIO_H3_PDNPUL S5P_GPIO_H3_BASE(PDNPULL_OFFSET) + +/* GPIO Wakeup Interrupt Configuration */ +#define S5P_GPIO_WAKEUP_INT0_CON S5P_WAKEUP_INT_CON(0x00) +#define S5P_GPIO_WAKEUP_INT1_CON S5P_WAKEUP_INT_CON(0x04) +#define S5P_GPIO_WAKEUP_INT2_CON S5P_WAKEUP_INT_CON(0x08) +#define S5P_GPIO_WAKEUP_INT3_CON S5P_WAKEUP_INT_CON(0x0c) + +/* GPIO Wakeup Interrupt Filter Configuration */ +#define S5P_GPIO_WAKEUP_FLTINT0_CON0 S5P_WAKEUP_FLTINT_CON(0x00) +#define S5P_GPIO_WAKEUP_FLTINT0_CON1 S5P_WAKEUP_FLTINT_CON(0x04) +#define S5P_GPIO_WAKEUP_FLTINT1_CON0 S5P_WAKEUP_FLTINT_CON(0x08) +#define S5P_GPIO_WAKEUP_FLTINT1_CON1 S5P_WAKEUP_FLTINT_CON(0x0c) +#define S5P_GPIO_WAKEUP_FLTINT2_CON0 S5P_WAKEUP_FLTINT_CON(0x10) +#define S5P_GPIO_WAKEUP_FLTINT2_CON1 S5P_WAKEUP_FLTINT_CON(0x14) +#define S5P_GPIO_WAKEUP_FLTINT3_CON0 S5P_WAKEUP_FLTINT_CON(0x18) +#define S5P_GPIO_WAKEUP_FLTINT3_CON1 S5P_WAKEUP_FLTINT_CON(0x1c) + +/* GPIO Wakeup Interrupt Mask */ +#define S5P_GPIO_WAKEUP_INT0_MASK S5P_WAKEUP_INT_MASK(0x00) +#define S5P_GPIO_WAKEUP_INT1_MASK S5P_WAKEUP_INT_MASK(0x04) +#define S5P_GPIO_WAKEUP_INT2_MASK S5P_WAKEUP_INT_MASK(0x08) +#define S5P_GPIO_WAKEUP_INT3_MASK S5P_WAKEUP_INT_MASK(0x0c) + +/* GPIO Wakeup Interrupt Pend */ +#define S5P_GPIO_WAKEUP_INT0_PEND S5P_WAKEUP_INT_PEND(0x00) +#define S5P_GPIO_WAKEUP_INT1_PEND S5P_WAKEUP_INT_PEND(0x04) +#define S5P_GPIO_WAKEUP_INT2_PEND S5P_WAKEUP_INT_PEND(0x08) +#define S5P_GPIO_WAKEUP_INT3_PEND S5P_WAKEUP_INT_PEND(0x0c) + diff --git a/include/asm-arm/arch-s5pc100/hardware.h b/include/asm-arm/arch-s5pc100/hardware.h new file mode 100644 index 0000000..84d24c9 --- /dev/null +++ b/include/asm-arm/arch-s5pc100/hardware.h @@ -0,0 +1,63 @@ +/* + * Originates from Samsung's u-boot 1.1.6 port to S3C6400 / SMDK6400 + * + * (C) Copyright 2008 + * Guennadi Liakhovetki, DENX Software Engineering, lg@denx.de + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef _ARCH_HARDWARE_H_ +#define _ARCH_HARDWARE_H_ + +#include <asm/sizes.h> + +#ifndef __ASSEMBLY__ +#define UData(Data) ((unsigned long) (Data)) + +#define __REG(x) (*(vu_long *)(x)) +#define __REGl(x) (*(vu_long *)(x)) +#define __REGw(x) (*(vu_short *)(x)) +#define __REGb(x) (*(vu_char *)(x)) +#define __REG2(x, y) (*(vu_long *)((x) + (y))) +#else +#define UData(Data) (Data) + +#define __REG(x) (x) +#define __REGl(x) (x) +#define __REGw(x) (x) +#define __REGb(x) (x) +#define __REG2(x, y) ((x) + (y)) +#endif + +#define Fld(Size, Shft) (((Size) << 16) + (Shft)) + +#define FSize(Field) ((Field) >> 16) +#define FShft(Field) ((Field) & 0x0000FFFF) +#define FMsk(Field) (((UData (1) << FSize (Field)) - 1) << FShft (Field)) +#define FAlnMsk(Field) ((UData (1) << FSize (Field)) - 1) +#define F1stBit(Field) (UData (1) << FShft (Field)) + +#define FClrBit(Data, Bit) (Data = (Data & ~(Bit))) +#define FClrFld(Data, Field) (Data = (Data & ~FMsk(Field))) + +#define FInsrt(Value, Field) \ + (UData (Value) << FShft (Field)) + +#define FExtr(Data, Field) \ + ((UData (Data) >> FShft (Field)) & FAlnMsk (Field)) + +#endif /* _ARCH_HARDWARE_H_ */ diff --git a/include/asm-arm/arch-s5pc100/map-base.h b/include/asm-arm/arch-s5pc100/map-base.h new file mode 100644 index 0000000..37cc9ba --- /dev/null +++ b/include/asm-arm/arch-s5pc100/map-base.h @@ -0,0 +1,19 @@ +/* include/asm/arch/map-base.h + * + * Author: InKi Dae inki.dae@samsung.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. +*/ + +#ifndef ___ASM_ARCH_MAP_BASE_H +#define ___ASM_ARCH_MAP_BASE_H + +#define S5P_ADDR_BASE 0xE1F00000 + +#define S5P_ADDR(x) (S5P_ADDR_BASE + (x)) + +#define S5P_LCD_BASE S5P_ADDR(0xC100000) /* Display Controller */ + +#endif diff --git a/include/asm-arm/arch-s5pc100/sys_proto.h b/include/asm-arm/arch-s5pc100/sys_proto.h new file mode 100644 index 0000000..b601547 --- /dev/null +++ b/include/asm-arm/arch-s5pc100/sys_proto.h @@ -0,0 +1,30 @@ +/* + * (C) Copyright 2009 + * Samsung Electronics, <www.samsung.com/sec> + * + * (C) Copyright 2004-2008 + * Texas Instruments, <www.ti.com> + * Richard Woodruff r-woodruff2@ti.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR /PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#ifndef _SYS_PROTO_H_ +#define _SYS_PROTO_H_ + +ulong get_PCLK(void); +static inline s5pc1xx_uart_t *s5pc1xx_get_base_uart(enum s5pc1xx_uarts_nr nr); + +#endif diff --git a/include/asm-arm/arch-s5pc100/uart.h b/include/asm-arm/arch-s5pc100/uart.h new file mode 100644 index 0000000..4d2482a --- /dev/null +++ b/include/asm-arm/arch-s5pc100/uart.h @@ -0,0 +1,68 @@ + +/* + * UART + */ +/* uart base address */ +#define S5P_PA_UART S5P_ADDR(0x0c000000) /* UART */ +#define UARTx_OFFSET(x) (S5P_PA_UART + x * 0x400) +#define S5P_UART_BASE (S5P_PA_UART) +/* uart offset */ +#define ULCON_OFFSET 0x00 +#define UCON_OFFSET 0x04 +#define UFCON_OFFSET 0x08 +#define UMCON_OFFSET 0x0C +#define UTRSTAT_OFFSET 0x10 +#define UERSTAT_OFFSET 0x14 +#define UFSTAT_OFFSET 0x18 +#define UMSTAT_OFFSET 0x1C +#define UTXH_OFFSET 0x20 +#define URXH_OFFSET 0x24 +#define UBRDIV_OFFSET 0x28 +#define UDIVSLOT_OFFSET 0x2C +#define UINTP_OFFSET 0x30 +#define UINTSP_OFFSET 0x34 +#define UINTM_OFFSET 0x38 + +#define UTRSTAT_TX_EMPTY (1 << 2) +#define UTRSTAT_RX_READY (1 << 0) +#define UART_ERR_MASK 0xF + +#ifndef __ASSEMBLY__ +typedef struct s5pc1xx_uart { + volatile unsigned long ULCON; + volatile unsigned long UCON; + volatile unsigned long UFCON; + volatile unsigned long UMCON; + volatile unsigned long UTRSTAT; + volatile unsigned long UERSTAT; + volatile unsigned long UFSTAT; + volatile unsigned long UMSTAT; +#ifdef __BIG_ENDIAN + volatile unsigned char res1[3]; + volatile unsigned char UTXH; + volatile unsigned char res2[3]; + volatile unsigned char URXH; +#else /* Little Endian */ + volatile unsigned char UTXH; + volatile unsigned char res1[3]; + volatile unsigned char URXH; + volatile unsigned char res2[3]; +#endif + volatile unsigned long UBRDIV; +#ifdef __BIG_ENDIAN + volatile unsigned char res3[2]; + volatile unsigned short UDIVSLOT; +#else + volatile unsigned short UDIVSLOT; + volatile unsigned char res3[2]; +#endif +} s5pc1xx_uart_t; + +enum s5pc1xx_uarts_nr { + S5PC1XX_UART0, + S5PC1XX_UART1, + S5PC1XX_UART2, + S5PC1XX_UART3, +}; +#endif /* __ASSEMBLY__ */ + diff --git a/include/asm-arm/arch-s5pc100/watchdog.h b/include/asm-arm/arch-s5pc100/watchdog.h new file mode 100644 index 0000000..668bb09 --- /dev/null +++ b/include/asm-arm/arch-s5pc100/watchdog.h @@ -0,0 +1,16 @@ + +/* + * Watchdog + */ +#define S5P_WATCHDOG_BASE(x) (S5P_PA_WATCHDOG + (x)) + +#define WTCON_OFFSET 0x0 +#define WTDAT_OFFSET 0x4 +#define WTCNT_OFFSET 0x8 +#define WTCLRINT_OFFSET 0xc + +#define S5P_WTCON S5P_WATCHDOG_BASE(WTCON_OFFSET) +#define S5P_WTDAT S5P_WATCHDOG_BASE(WTDAT_OFFSET) +#define S5P_WTCNT S5P_WATCHDOG_BASE(WTCNT_OFFSET) +#define S5P_WTCLRINT S5P_WATCHDOG_BASE(WTCLRINT_OFFSET) + diff --git a/include/s5pc1xx-onenand.h b/include/s5pc1xx-onenand.h new file mode 100644 index 0000000..5244536 --- /dev/null +++ b/include/s5pc1xx-onenand.h @@ -0,0 +1,105 @@ +#ifndef __S5PC1XX_ONENAND_H__ +#define __S5PC1XX_ONENAND_H__ + +#include <asm/hardware.h> + +/* + * OneNAND Controller + */ +#define S5P_ONENAND_BASE 0xE7100000 + +#define MEM_CFG_OFFSET 0x0000 +#define BURST_LEN_OFFSET 0x0010 +#define MEM_RESET_OFFSET 0x0020 +#define INT_ERR_STAT_OFFSET 0x0030 +#define INT_ERR_MASK_OFFSET 0x0040 +#define INT_ERR_ACK_OFFSET 0x0050 +#define ECC_ERR_STAT_OFFSET 0x0060 +#define ECC_ERR_STAT_1_OFFSET 0x0060 +#define MANUFACT_ID_OFFSET 0x0070 +#define DEVICE_ID_OFFSET 0x0080 +#define DATA_BUF_SIZE_OFFSET 0x0090 +#define BOOT_BUF_SIZE_OFFSET 0x00A0 +#define BUF_AMOUNT_OFFSET 0x00B0 +#define TECH_OFFSET 0x00C0 +#define FBA_WIDTH_OFFSET 0x00D0 +#define FPA_WIDTH_OFFSET 0x00E0 +#define FSA_WIDTH_OFFSET 0x00F0 +#define SYNC_MODE_OFFSET 0x0130 +#define TRANS_SPARE_OFFSET 0x0140 +#define ERR_PAGE_ADDR_OFFSET 0x0180 +#define INT_PIN_ENABLE_OFFSET 0x01A0 +#define ACC_CLOCK_OFFSET 0x01C0 +#define ERR_BLK_ADDR_OFFSET 0x01E0 +#define FLASH_VER_ID_OFFSET 0x01F0 +#define WATCHDOG_CNT_LOW_OFFSET 0x0260 +#define WATCHDOG_CNT_HI_OFFSET 0x0270 +#define SYNC_WRITE_OFFSET 0x0280 +#define COLD_RESET_DELAY_OFFSET 0x02A0 +#define DDP_DEVICE_OFFSET 0x02B0 +#define MULTI_PLANE_OFFSET 0x02C0 +#define TRANS_MODE_OFFSET 0x02E0 +#define ECC_ERR_STAT_2_OFFSET 0x0300 +#define ECC_ERR_STAT_3_OFFSET 0x0310 +#define ECC_ERR_STAT_4_OFFSET 0x0320 +#define DEV_PAGE_SIZE_OFFSET 0x0340 +#define INT_MON_STATUS_OFFSET 0x0390 + +#define MEM_CFG0_REG __REG(S5P_ONENAND_BASE + MEM_CFG_OFFSET) +#define BURST_LEN0_REG __REG(S5P_ONENAND_BASE + BURST_LEN_OFFSET) +#define MEM_RESET0_REG __REG(S5P_ONENAND_BASE + MEM_RESET_OFFSET) +#define INT_ERR_STAT0_REG __REG(S5P_ONENAND_BASE + INT_ERR_STAT_OFFSET) +#define INT_ERR_MASK0_REG __REG(S5P_ONENAND_BASE + INT_ERR_MASK_OFFSET) +#define INT_ERR_ACK0_REG __REG(S5P_ONENAND_BASE + INT_ERR_ACK_OFFSET) +#define ECC_ERR_STAT0_REG __REG(S5P_ONENAND_BASE + ECC_ERR_STAT_OFFSET) +#define ECC_ERR_STAT_1_REG __REG(S5P_ONENAND_BASE + ECC_ERR_STAT_1_OFFSET) +#define MANUFACT_ID0_REG __REG(S5P_ONENAND_BASE + MANUFACT_ID_OFFSET) +#define DEVICE_ID0_REG __REG(S5P_ONENAND_BASE + DEVICE_ID_OFFSET) +#define DATA_BUF_SIZE0_REG __REG(S5P_ONENAND_BASE + DATA_BUF_SIZE_OFFSET) +#define BOOT_BUF_SIZE0_REG __REG(S5P_ONENAND_BASE + BOOT_BUF_SIZE_OFFSET) +#define FBA_WIDTH0_REG __REG(S5P_ONENAND_BASE + FBA_WIDTH_OFFSET) +#define FPA_WIDTH0_REG __REG(S5P_ONENAND_BASE + FPA_WIDTH_OFFSET) +#define FSA_WIDTH0_REG __REG(S5P_ONENAND_BASE + FSA_WIDTH_OFFSET) +#define SYNC_MODE_REG __REG(S5P_ONENAND_BASE + SYNC_MODE_OFFSET) +#define TRANS_SPARE0_REG __REG(S5P_ONENAND_BASE + TRANS_SPARE_OFFSET) +#define ERR_PAGE_ADDR_REG __REG(S5P_ONENAND_BASE + ERR_PAGE_ADDR_OFFSET) +#define DBS_DFS_WIDTH0_REG __REG(S5P_ONENAND_BASE + DBS_DFS_WIDTH_OFFSET) +#define INT_PIN_ENABLE0_REG __REG(S5P_ONENAND_BASE + INT_PIN_ENABLE_OFFSET) +#define ACC_CLOCK0_REG __REG(S5P_ONENAND_BASE + ACC_CLOCK_OFFSET) +#define ERR_BLK_ADDR_REG __REG(S5P_ONENAND_BASE + ERR_BLK_ADDR_OFFSET) +#define FLASH_VER_ID0_REG __REG(S5P_ONENAND_BASE + FLASH_VER_ID_OFFSET) +#define WATCHDOG_CNT_LOW_REG __REG(S5P_ONENAND_BASE + WATCHDOG_CNT_LOW_OFFSET) +#define WATCHDOG_CNT_HI_REG __REG(S5P_ONENAND_BASE + WATCHDOG_CNT_HI_OFFSET) +#define SYNC_WRITE_REG __REG(S5P_ONENAND_BASE + SYNC_WRITE_OFFSET) +#define COLD_RESET_DELAY_REG __REG(S5P_ONENAND_BASE + COLD_RESET_DELAY_OFFSET) +#define TRANS_MODE_REG __REG(S5P_ONENAND_BASE + TRANS_MODE_OFFSET) +#define DDP_DEVICE_REG __REG(S5P_ONENAND_BASE + DDP_DEVICE_OFFSET) +#define MULTI_PLANE_REG __REG(S5P_ONENAND_BASE + MULTI_PLANE_OFFSET) +#define ECC_ERR_STAT_2_REG __REG(S5P_ONENAND_BASE + ECC_ERR_STAT_2_OFFSET) +#define ECC_ERR_STAT_3_REG __REG(S5P_ONENAND_BASE + ECC_ERR_STAT_3_OFFSET) +#define ECC_ERR_STAT_4_REG __REG(S5P_ONENAND_BASE + ECC_ERR_STAT_4_OFFSET) +#define DEV_PAGE_SIZE_REG __REG(S5P_ONENAND_BASE + DEV_PAGE_SIZE_OFFSET) +#define INT_MON_STATUS_REG __REG(S5P_ONENAND_BASE + INT_MON_STATUS_OFFSET) + +#define ONENAND_MEM_RESET_HOT 0x3 +#define ONENAND_MEM_RESET_COLD 0x2 +#define ONENAND_MEM_RESET_WARM 0x1 + +#define CACHE_OP_ERR (1 << 13) +#define RST_CMP (1 << 12) +#define RDY_ACT (1 << 11) +#define INT_ACT (1 << 10) +#define UNSUP_CMD (1 << 9) +#define LOCKED_BLK (1 << 8) +#define BLK_RW_CMP (1 << 7) +#define ERS_CMP (1 << 6) +#define PGM_CMP (1 << 5) +#define LOAD_CMP (1 << 4) +#define ERS_FAIL (1 << 3) +#define PGM_FAIL (1 << 2) +#define INT_TO (1 << 1) +#define LD_FAIL_ECC_ERR (1 << 0) + +#define TSRF (1 << 0) + +#endif
On 17:05 Thu 25 Jun , HeungJun Kim wrote:
S5PC100 processor is ARM Cortex A8 Processor SoC and SMDKC100 Board use this. So, this patch tested on SMDKC100 Board.
I'll send 6 patch for working on SMDKC100 Board including this. But, this patch make the change to ARM Cortex A8 specific code like a cpu/arm_cortexa8/cpu.c, start.S.
So, I wanna be reviewed to know how to contribute this whole patch.
this will go in a PATCH 0/X e-mail please fix the commit message
CC: Dirk Behme <dirk.behme at googlemail.com>
please @
Signed-off-by: HeungJun, Kim riverful.kim@samsung.com
please rebase your patch as it's does not apply against the u-boot-arm master, next or testing
It includes the following :
- Samsung S5PC100 SoC specific source codes
- Samsung S5PC100 SoC specific header files
- modify ARM Cortex A8 cpu.c, start.S
cpu/arm_cortexa8/cpu.c | 80 +--- cpu/arm_cortexa8/s5pc100/Makefile | 48 +++ cpu/arm_cortexa8/s5pc100/config.mk | 36 ++ cpu/arm_cortexa8/s5pc100/speed.c | 186 +++++++++ cpu/arm_cortexa8/s5pc100/timer.c | 223 ++++++++++ cpu/arm_cortexa8/start.S | 23 + include/asm-arm/arch-s5pc100/clock-others.h | 33 ++ include/asm-arm/arch-s5pc100/cpu.h | 379 +++++++++++++++++ include/asm-arm/arch-s5pc100/gpio.h | 580 +++++++++++++++++++++++++++ include/asm-arm/arch-s5pc100/hardware.h | 63 +++ include/asm-arm/arch-s5pc100/map-base.h | 19 + include/asm-arm/arch-s5pc100/sys_proto.h | 30 ++ include/asm-arm/arch-s5pc100/uart.h | 68 ++++ include/asm-arm/arch-s5pc100/watchdog.h | 16 + include/s5pc1xx-onenand.h | 105 +++++ 15 files changed, 1828 insertions(+), 61 deletions(-) create mode 100644 cpu/arm_cortexa8/s5pc100/Makefile create mode 100644 cpu/arm_cortexa8/s5pc100/config.mk create mode 100644 cpu/arm_cortexa8/s5pc100/speed.c create mode 100644 cpu/arm_cortexa8/s5pc100/timer.c create mode 100644 include/asm-arm/arch-s5pc100/clock-others.h create mode 100644 include/asm-arm/arch-s5pc100/cpu.h create mode 100644 include/asm-arm/arch-s5pc100/gpio.h create mode 100644 include/asm-arm/arch-s5pc100/hardware.h create mode 100644 include/asm-arm/arch-s5pc100/map-base.h create mode 100644 include/asm-arm/arch-s5pc100/sys_proto.h create mode 100644 include/asm-arm/arch-s5pc100/uart.h create mode 100644 include/asm-arm/arch-s5pc100/watchdog.h create mode 100644 include/s5pc1xx-onenand.h
diff --git a/cpu/arm_cortexa8/cpu.c b/cpu/arm_cortexa8/cpu.c index 6fd07d0..95e8523 100644 --- a/cpu/arm_cortexa8/cpu.c +++ b/cpu/arm_cortexa8/cpu.c @@ -37,11 +37,28 @@ #include <asm/system.h>
#ifndef CONFIG_L2_OFF -void l2cache_disable(void); +void l2_cache_disable(void); +#endif
+#ifdef CONFIG_USE_IRQ +DECLARE_GLOBAL_DATA_PTR; #endif
static void cache_flush(void);
+int cpu_init(void) +{
* setup up stacks if necessary
- IRQ_STACK_START =
_armboot_start - CONFIG_SYS_MALLOC_LEN - CONFIG_SYS_GBL_DATA_SIZE - 4;
- FIQ_STACK_START = IRQ_STACK_START - CONFIG_STACKSIZE_IRQ;
no need please remove
int cleanup_before_linux(void) { unsigned int i; @@ -63,7 +80,7 @@ int cleanup_before_linux(void)
#ifndef CONFIG_L2_OFF /* turn off L2 cache */
- l2cache_disable();
- l2_cache_disable(); /* invalidate L2 cache also */ v7_flush_dcache_all(get_device_type());
#endif @@ -78,65 +95,6 @@ int cleanup_before_linux(void) return 0; }
<snip>
diff --git a/cpu/arm_cortexa8/s5pc100/speed.c b/cpu/arm_cortexa8/s5pc100/speed.c new file mode 100644 index 0000000..c5768f8 --- /dev/null +++ b/cpu/arm_cortexa8/s5pc100/speed.c @@ -0,0 +1,186 @@ +/*
- (C) Copyright 2009
- Inki Dae, SAMSUNG Electronics, inki.dae@samsung.com
- Heungjun Kim, SAMSUNG Electronics, riverful.kim@samsung.com
- Minkyu Kang, SAMSUNG Electronics, mk7.kang@samsung.com
- project.
- MA 02111-1307 USA
- This code should work for both the S3C2400 and the S3C2410
- as they seem to have the same PLL and clock machinery inside.
- The different address mapping is handled by the s3c24xx.h files below.
+#include <common.h>
+#define APLL 0 +#define MPLL 1 +#define EPLL 2 +#define HPLL 3
- NOTE: This describes the proper use of this file.
- CONFIG_SYS_CLK_FREQ should be defined as the input frequency of the PLL.
- get_FCLK(), get_HCLK(), get_PCLK() and get_UCLK() return the clock of
- the specified bus in HZ.
+static ulong get_PLLCLK(int pllreg)
please use this convention get_xxx_clk_rate for all clock function and please rename the file clock.c and please create a clk.h file with this functions prototype
- ulong r, m, p, s, mask;
- switch (pllreg) {
- case APLL:
r = S5P_APLL_CON_REG;
break;
- case MPLL:
r = S5P_MPLL_CON_REG;
break;
- case EPLL:
r = S5P_EPLL_CON_REG;
break;
- case HPLL:
r = S5P_HPLL_CON_REG;
break;
- default:
hang();
- if (pllreg == APLL)
mask = 0x3ff;
- else
mask = 0x0ff;
- m = (r >> 16) & mask;
- p = (r >> 8) & 0x3f;
- s = r & 0x7;
- return m * (CONFIG_SYS_CLK_FREQ / (p * (1 << s)));
+/* return ARMCORE frequency */
<snip>
+#ifdef CONFIG_DISPLAY_CPUINFO +int print_cpuinfo(void) +{
- unsigned int pid = __REG(S5P_PRO_ID);
- pid >>= 12;
- pid &= 0x00fff;
- printf("CPU:\tS5PC%x@%luMHz\n", pid, get_ARMCLK() / 1000000);
- printf("\tFclk = %luMHz, HclkD0 = %luMHz, PclkD0 = %luMHz,"
" PclkD1 = %luMHz\n",
get_FCLK() / 1000000, get_HCLK() / 1000000,
get_PCLKD0() / 1000000, get_PCLK() / 1000000);
+} +#endif
please move this in cpu.c or cpu_info.c
diff --git a/cpu/arm_cortexa8/s5pc100/timer.c b/cpu/arm_cortexa8/s5pc100/timer.c new file mode 100644 index 0000000..0864600 --- /dev/null +++ b/cpu/arm_cortexa8/s5pc100/timer.c @@ -0,0 +1,223 @@ +/*
- (C) Copyright 2003
- Texas Instruments <www.ti.com>
- (C) Copyright 2002
- Sysgo Real-Time Solutions, GmbH <www.elinos.com>
- Marius Groeger mgroeger@sysgo.de
- Alex Zuepke azu@sysgo.de
- (C) Copyright 2002-2004
- Gary Jennejohn, DENX Software Engineering, gj@denx.de
- (C) Copyright 2004
- Philippe Robin, ARM Ltd. philippe.robin@arm.com
- (C) Copyright 2008
- Guennadi Liakhovetki, DENX Software Engineering, lg@denx.de
all there people write the code?
- project.
- MA 02111-1307 USA
+#define PRESCALER_1 (16 - 1) /* prescaler of timer 2, 3, 4 */ +#define MUX_DIV_2 (1) /* 1/2 period */ +#define MUX_DIV_4 (2) /* 1/4 period */ +#define MUX_DIV_8 (3) /* 1/8 period */ +#define MUX_DIV_16 (4) /* 1/16 period */ +#define MUX4_DIV_SHIFT 16
+#define TCON_TIMER4_SHIFT 20
+static ulong count_value;
+/* Internal tick units */ +static unsigned long long timestamp; /* Monotonic incrementing timer */ +static unsigned long lastdec; /* Last decremneter snapshot */
+/* macro to read the 16 bit timer */ +static inline ulong READ_TIMER(void) +{
- const s5pc1xx_timers_t *timers = (s5pc1xx_timers_t *) S5P_TIMER_BASE;
- return timers->TCNTO4;
+int timer_init(void) +{
- s5pc1xx_timers_t *timers = (s5pc1xx_timers_t *) S5P_TIMER_BASE;
* @ PWM Timer 4
* Timer Freq(HZ) =
* PCLK / { (prescaler_value + 1) * (divider_value) }
- /* set prescaler : 16 */
- /* set divider : 2 */
- timers->TCFG0 = (PRESCALER_1 & 0xff) << 8;
- timers->TCFG1 = (MUX_DIV_2 & 0xf) << MUX4_DIV_SHIFT;
- if (count_value == 0) {
/* reset initial value */
/* count_value = 2085937.5(HZ) (per 1 sec)*/
count_value = get_PCLK() / ((PRESCALER_1 + 1) *
(MUX_DIV_2 + 1));
/* count_value / 100 = 20859.375(HZ) (per 10 msec) */
count_value = count_value / 100;
- /* set count value */
- timers->TCNTB4 = count_value;
- lastdec = count_value;
- /* auto reload & manual update */
- timers->TCON = (timers->TCON & ~(0x07 << TCON_TIMER4_SHIFT)) |
S5P_TCON4_AUTO_RELOAD | S5P_TCON4_UPDATE;
- /* start PWM timer 4 */
S5P_TCON4_AUTO_RELOAD | S5P_TCON4_ON;
- timestamp = 0;
please remove one empty file
- timer without interrupts
<snip>
+void reset_cpu(ulong ignored)
please move this to reset.c or cpu.c it's not related to the timer
- pid >>= 12;
- pid &= 0x00fff;
- pid |= (0xC << 12);
- __REG(S5P_SW_RST) = pid;
- while (1) ;
+} diff --git a/cpu/arm_cortexa8/start.S b/cpu/arm_cortexa8/start.S index 66b4820..da6eed7 100644 --- a/cpu/arm_cortexa8/start.S +++ b/cpu/arm_cortexa8/start.S @@ -34,6 +34,7 @@
.globl _start _start: b reset +#ifndef CONFIG_ONENAND_IPL
please sync with arm1136/start.S I do want to have multiple start.S implementation anymore please also note the we introduce a CONFIG_PRELOADER
ldr pc, _undefined_instruction ldr pc, _software_interrupt ldr pc, _prefetch_abort @@ -50,6 +51,9 @@ _not_used: .word not_used _irq: .word irq _fiq: .word fiq _pad: .word 0x12345678 /* now 16*4=64 */ +#else
- . = _start + 64
+#endif .global _end_vect _end_vect:
@@ -108,6 +112,7 @@ reset: orr r0, r0, #0xd3 msr cpsr,r0
+#ifndef CONFIG_ONENAND_IPL #if (CONFIG_OMAP34XX) /* Copy vectors to mask ROM indirect addr */ adr r0, _start @ r0 <- current position of code @@ -131,11 +136,13 @@ next: bl cpy_clk_code @ put dpll adjust code behind vectors #endif /* NAND Boot */ #endif +#endif /* CONFIG_ONENAND_IPL */ /* the mask ROM code should have PLL and others stable */ #ifndef CONFIG_SKIP_LOWLEVEL_INIT bl cpu_init_crit #endif
<snip>
@@ -502,6 +522,7 @@ finished_inval: ldmfd r13!, {r0 - r5, r7, r9 - r12, pc}
+#if (CONFIG_OMAP34XX) .align 5 .global reset_cpu reset_cpu: @@ -514,3 +535,5 @@ _loop_forever: b _loop_forever rstctl: .word PRM_RSTCTRL +#endif
please move this reset_cpu to cortexA8/omap3/
+#endif /* CONFIG_ONENAND_IPL */ diff --git a/include/asm-arm/arch-s5pc100/clock-others.h b/include/asm-arm/arch-s5pc100/clock-others.h new file mode 100644 index 0000000..35f1686 --- /dev/null +++ b/include/asm-arm/arch-s5pc100/clock-others.h @@ -0,0 +1,33 @@
please add licence header
- Clock control - Others
<snip>
diff --git a/include/asm-arm/arch-s5pc100/cpu.h b/include/asm-arm/arch-s5pc100/cpu.h new file mode 100644 index 0000000..6ec8656 --- /dev/null +++ b/include/asm-arm/arch-s5pc100/cpu.h @@ -0,0 +1,379 @@ +/*
- Samsung Electronics, <www.samsung.com/sec>
- Heungjun Kim riverful.kim@samsung.com
- Minkyu Kang mk7.kang@samsung.com
- MA 02111-1307 USA
+#ifndef _CPU_H +#define _CPU_H
please split this file a few more as somethink like this clock.h pwm.h power.h etc.... please also not that you have whitespace and your patch is line wrapped
+#ifndef __S5PC100_H__ +#define __S5PC100_H__
+#define S5P_ADDR_BASE 0xe0000000 +#define S5P_ADDR(x) (S5P_ADDR_BASE + (x))
+#define S5P_PA_ID S5P_ADDR(0x00000000) /* Chip ID Base */ +#define S5P_PA_CLK S5P_ADDR(0x00100000) /* Clock Base */ +#define S5P_PA_PWR S5P_ADDR(0x00108000) /* Power Base */ +#define S5P_PA_CLK_OTHERS S5P_ADDR(0x00200000) /* Clock Others Base */ +#define S5P_PA_GPIO S5P_ADDR(0x00300000) /* GPIO Base */ +#define S5P_PA_VIC0 S5P_ADDR(0x04000000) /* Vector Interrupt Controller 0 */ +#define S5P_PA_VIC1 S5P_ADDR(0x04100000) /* Vector Interrupt Controller 1 */ +#define S5P_PA_VIC2 S5P_ADDR(0x04200000) /* Vector Interrupt Controller 2 */ +#define S5P_PA_DMC S5P_ADDR(0x06000000) /* Dram Memory Controller */ +#define S5P_PA_SROMC S5P_ADDR(0x07000000) /* SROM Controller */ +#define S5P_PA_WATCHDOG S5P_ADDR(0x0a200000) /* Watchdog Timer */ +#define S5P_PA_PWMTIMER S5P_ADDR(0x0a000000) /* PWM Timer */
- Chip ID
+#define S5P_ID(x) (S5P_PA_ID + (x))
+#define S5P_PRO_ID S5P_ID(0) +#define S5P_OMR S5P_ID(4)
<snip>
why do you include it?
<snip>
- Originates from Samsung's u-boot 1.1.6 port to S3C6400 / SMDK6400
- MA 02111-1307 USA
please use proper accessor in the file, so you do not need those macro
please use generic bits ops
Best Regards, J.
CC: Dirk Behme <dirk.behme at googlemail.com> Signed-off-by: HeungJun, Kim riverful.kim@samsung.com
do you plan to send a new version?
Best Regards, J.
Mr. Jean,
Yes. Definitely. To send the new version patch may be so late, cause of my busy days, not my laziness.
BTW, is there any issues or problem? If there is, can you tell me about that things for me to handle it? I hope your waiting a few days. sorry for that.
Best regards, riverful
2009/7/8, Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com:
Best Regards, J.
HeungJun Kim
