[PATCH v2] riscv: cancel the limitation that NR_CPUS is less than or equal to 32
Various specifications of riscv allow the number of hart to be greater than 32. The limit of 32 is determined by gd->arch.available_harts. We can eliminate this limitation through bitmaps. Currently, the number of hart is limited to 4095, and 4095 is the limit of the RISC-V Advanced Core Local Interruptor Specification.
Test on sifive unmatched.
Signed-off-by: Xiang W wxjstz@126.com --- Changes since v1:
* When NR_CPUS is very large, the value of GD_AVAILABLE_HARTS will overflow the immediate range of ld/lw. This patch fixes this problem
arch/riscv/Kconfig | 4 ++-- arch/riscv/cpu/start.S | 21 ++++++++++++++++----- arch/riscv/include/asm/global_data.h | 4 +++- arch/riscv/lib/smp.c | 2 +- 4 files changed, 22 insertions(+), 9 deletions(-)
diff --git a/arch/riscv/Kconfig b/arch/riscv/Kconfig index ba29e70acf..7b9c7f5bca 100644 --- a/arch/riscv/Kconfig +++ b/arch/riscv/Kconfig @@ -220,8 +220,8 @@ config SPL_SMP all, single processor machines.
config NR_CPUS - int "Maximum number of CPUs (2-32)" - range 2 32 + int "Maximum number of CPUs (2-4095)" + range 2 4095 depends on SMP || SPL_SMP default 8 help diff --git a/arch/riscv/cpu/start.S b/arch/riscv/cpu/start.S index 76850ec9be..92f3b78f29 100644 --- a/arch/riscv/cpu/start.S +++ b/arch/riscv/cpu/start.S @@ -166,11 +166,22 @@ wait_for_gd_init: mv gp, s0
/* register available harts in the available_harts mask */ - li t1, 1 - sll t1, t1, tp - LREG t2, GD_AVAILABLE_HARTS(gp) - or t2, t2, t1 - SREG t2, GD_AVAILABLE_HARTS(gp) + li t1, GD_AVAILABLE_HARTS + add t1, t1, gp + LREG t1, 0(t1) +#if defined(CONFIG_ARCH_RV64I) + srli t2, tp, 6 + slli t2, t2, 3 +#elif defined(CONFIG_ARCH_RV32I) + srli t2, tp, 5 + slli t2, t2, 2 +#endif + add t1, t1, t2 + LREG t2, 0(t1) + li t3, 1 + sll t3, t3, tp + or t2, t2, t3 + SREG t2, 0(t1)
amoswap.w.rl zero, zero, 0(t0)
diff --git a/arch/riscv/include/asm/global_data.h b/arch/riscv/include/asm/global_data.h index 095484a635..6de2ee0b25 100644 --- a/arch/riscv/include/asm/global_data.h +++ b/arch/riscv/include/asm/global_data.h @@ -10,9 +10,11 @@ #ifndef __ASM_GBL_DATA_H #define __ASM_GBL_DATA_H
+#include <config.h> #include <asm/smp.h> #include <asm/u-boot.h> #include <compiler.h> +#include <linux/bitops.h>
/* Architecture-specific global data */ struct arch_global_data { @@ -28,7 +30,7 @@ struct arch_global_data { struct ipi_data ipi[CONFIG_NR_CPUS]; #endif #ifndef CONFIG_XIP - ulong available_harts; + ulong available_harts[BITS_TO_LONGS(CONFIG_NR_CPUS)]; #endif };
diff --git a/arch/riscv/lib/smp.c b/arch/riscv/lib/smp.c index ba992100ad..e8e391fd41 100644 --- a/arch/riscv/lib/smp.c +++ b/arch/riscv/lib/smp.c @@ -47,7 +47,7 @@ static int send_ipi_many(struct ipi_data *ipi, int wait)
#ifndef CONFIG_XIP /* skip if hart is not available */ - if (!(gd->arch.available_harts & (1 << reg))) + if (!test_bit(reg, gd->arch.available_harts)) continue; #endif
Changes since v1:
- When NR_CPUS is very large, the value of GD_AVAILABLE_HARTS will overflow the immediate range of ld/lw. This patch fixes this problem
- li t1, 1
- sll t1, t1, tp
- or t2, t2, t1
- li t1, GD_AVAILABLE_HARTS
- add t1, t1, gp
- LREG t1, 0(t1)
- srli t2, tp, 6
- slli t2, t2, 3
- srli t2, tp, 5
- slli t2, t2, 2
- add t1, t1, t2
- LREG t2, 0(t1)
- li t3, 1
- sll t3, t3, tp
This seems incorrect. Shouldn't we have "$tp % sizeof(ulong)" instead of "$tp / sizeof(ulong)" ?
or t2, t2, t3
SREG t2, 0(t1)
Best regards, Leo
在 2021-12-29星期三的 17:23 +0800,Leo Liang写道:
Changes since v1:
diff --git a/arch/riscv/cpu/start.S b/arch/riscv/cpu/start.S index 76850ec9be..92f3b78f29 100644 --- a/arch/riscv/cpu/start.S +++ b/arch/riscv/cpu/start.S @@ -166,11 +166,22 @@ wait_for_gd_init: mv gp, s0 /* register available harts in the available_harts mask */ - li t1, 1 - sll t1, t1, tp - LREG t2, GD_AVAILABLE_HARTS(gp) - or t2, t2, t1 - SREG t2, GD_AVAILABLE_HARTS(gp) + li t1, GD_AVAILABLE_HARTS + add t1, t1, gp + LREG t1, 0(t1) +#if defined(CONFIG_ARCH_RV64I) + srli t2, tp, 6 + slli t2, t2, 3 +#elif defined(CONFIG_ARCH_RV32I) + srli t2, tp, 5 + slli t2, t2, 2 +#endif + add t1, t1, t2 + LREG t2, 0(t1) + li t3, 1 + sll t3, t3, tp
Do you meening: "$tp % sizeof(ulong)" instead of "$tp" ?
There is such a description in the riscv specification:
SLL, SRL, and SRA perform logical left, logical right, and arithmetic right shifts on the value in register rs1 by the shift amount held in the lower 5 bits of register rs2.
SLL, SRL, and SRA perform logical left, logical right, and arithmetic right shifts on the value in register rs1 by the shift amount held in register rs2. In RV64I, only the low 6 bits of rs2 are considered for the shift amount.
So we don’t need to perform the remainder operation.
regards, Xiang W
+ or t2, t2, t3 + SREG t2, 0(t1) amoswap.w.rl zero, zero, 0(t0)
Best regards, Leo
Changes since v1:
Got it! Thanks for the explanation.
LGTM, Reviewed-by: Leo Yu-Chi Liang ycliang@andestech.com
Best regards, Leo
regards, Xiang W
Best regards, Leo
Changes since v1:
li t1, 1
sll t1, t1, tp
or t2, t2, t1
add t1, t1, gp
LREG t1, 0(t1)
srli t2, tp, 6
slli t2, t2, 3
srli t2, tp, 5
slli t2, t2, 2
add t1, t1, t2
LREG t2, 0(t1)
li t3, 1
sll t3, t3, tp
I noticed that this has never landed in U-Boot. Was this forgotten or dropped for some reason (couldn't find anything)?
The current limit on the Linux kernel side is 512. The default on 64-bit (riscv64) is 64.
david
Best regards, Leo
regards, Xiang W
or t2, t2, t3
Best regards, Leo
Hi David, On Fri, Feb 03, 2023 at 03:24:37PM +0100, David Abdurachmanov wrote:
Sorry, This patch is forgotten. I will make sure this gets applied as soon as possible if there is no other error or concerns.
Thanks for the reminder!
Best regards, Leo
david
Hi Xiang,
Changes since v1:
david
The patch seems to cause some CI error (timeout on QEMU). (https://source.denx.de/u-boot/custodians/u-boot-riscv/-/pipelines/15076) Could you take a look at it if you have time?
Best regards, Leo
在 2023-02-10星期五的 07:25 +0000,Leo Liang写道:
Hi Xiang,
Changes since v1:
david
Best regards, Leo
sorry! I missing a bug. There is an error in calculating the starting address of available_harts. The patch for start.S needs to be updated.
/* register available harts in the available_harts mask */ - li t1, 1 - sll t1, t1, tp - LREG t2, GD_AVAILABLE_HARTS(gp) - or t2, t2, t1 - SREG t2, GD_AVAILABLE_HARTS(gp) + li t1, GD_AVAILABLE_HARTS + add t1, t1, gp +#if defined(CONFIG_ARCH_RV64I) + srli t2, tp, 6 + slli t2, t2, 3 +#elif defined(CONFIG_ARCH_RV32I) + srli t2, tp, 5 + slli t2, t2, 2 +#endif + add t1, t1, t2 + LREG t2, 0(t1) + li t3, 1 + sll t3, t3, tp + or t2, t2, t3 + SREG t2, 0(t1)
The mailing list cannot receive my mail, please help to update
Hi Xiang,
Hi Xiang,
Hi Xiang, On Wed, Dec 22, 2021 at 07:32:53AM +0800, Xiang W wrote: > Various specifications of riscv allow the number of hart to be > greater than 32. The limit of 32 is determined by > gd->arch.available_harts. We can eliminate this limitation through > bitmaps. Currently, the number of hart is limited to 4095, and 4095 > is the limit of the RISC-V Advanced Core Local Interruptor > Specification. > > Test on sifive unmatched. > > Signed-off-by: Xiang W wxjstz@126.com > --- > Changes since v1: > > * When NR_CPUS is very large, the value of GD_AVAILABLE_HARTS will > overflow the immediate range of ld/lw. This patch fixes this > problem > > arch/riscv/Kconfig | 4 ++-- > arch/riscv/cpu/start.S | 21 ++++++++++++++++----- > arch/riscv/include/asm/global_data.h | 4 +++- > arch/riscv/lib/smp.c | 2 +- > 4 files changed, 22 insertions(+), 9 deletions(-) >
david
Best regards, Leo
- li t1, 1
- sll t1, t1, tp
- or t2, t2, t1
- add t1, t1, gp
- srli t2, tp, 6
- slli t2, t2, 3
- srli t2, tp, 5
- slli t2, t2, 2
add t1, t1, t2
LREG t2, 0(t1)
li t3, 1
sll t3, t3, tp
or t2, t2, t3
SREG t2, 0(t1)
I have updated the patch. (https://patchwork.ozlabs.org/project/uboot/patch/20230213084313.10419-1-ycli...) Could you take a look to see if there is any issue?
Best regards, Leo
David Abdurachmanov
Leo Liang
Xiang W
