[U-Boot] [PATCH][Re-submission] AFEB9260 network fix
AFEB9260 uses PA10, PA11 for ETX2 and ETX3. Also, due to extarnal pull-up on IRQ line, Micrel PHY ID is 1 after reset sequence, not 0.
Signed-off-by: Sergey Lapin slapin@ossfans.org --- board/afeb9260/afeb9260.c | 2 +- cpu/arm926ejs/at91/at91sam9260_macb.c | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/board/afeb9260/afeb9260.c b/board/afeb9260/afeb9260.c index 024db2b..a247663 100644 --- a/board/afeb9260/afeb9260.c +++ b/board/afeb9260/afeb9260.c @@ -177,7 +177,7 @@ int board_eth_init(bd_t *bis) { int rc = 0; #ifdef CONFIG_MACB - rc = macb_eth_initialize(0, (void *)AT91SAM9260_BASE_EMAC, 0x00); + rc = macb_eth_initialize(0, (void *)AT91SAM9260_BASE_EMAC, 0x01); #endif return rc; } diff --git a/cpu/arm926ejs/at91/at91sam9260_macb.c b/cpu/arm926ejs/at91/at91sam9260_macb.c index ab60fb7..ea5e767 100644 --- a/cpu/arm926ejs/at91/at91sam9260_macb.c +++ b/cpu/arm926ejs/at91/at91sam9260_macb.c @@ -47,7 +47,7 @@ void at91_macb_hw_init(void) at91_set_B_periph(AT91_PIN_PA25, 0); /* ERX2 */ at91_set_B_periph(AT91_PIN_PA26, 0); /* ERX3 */ at91_set_B_periph(AT91_PIN_PA27, 0); /* ERXCK */ -#if defined(CONFIG_AT91SAM9260EK) +#if defined(CONFIG_AT91SAM9260EK) || defined(CONFIG_AFEB9260) /* * use PA10, PA11 for ETX2, ETX3. * PA23 and PA24 are for TWI EEPROM
Applied to arm
Best Regards, J.
On Wed, May 13, 2009 at 01:16:51AM +0200, Jean-Christophe PLAGNIOL-VILLARD wrote:
Applied to arm
Thanks a lot!
Sergey Lapin
