[U-Boot] [PATCH] armv7m: Add SysTick timer driver
The SysTick is a 24-bit down counter that is found on all ARM Cortex M3, M4, M7 devices and is always located at a fixed address.
Signed-off-by: Phil Edworthy phil.edworthy@renesas.com --- Resend with Albert's new email address - get_maintainer.pl gave the old one. --- arch/arm/cpu/armv7m/Makefile | 2 + arch/arm/cpu/armv7m/systick-timer.c | 91 +++++++++++++++++++++++++++++++++++++ 2 files changed, 93 insertions(+) create mode 100644 arch/arm/cpu/armv7m/systick-timer.c
diff --git a/arch/arm/cpu/armv7m/Makefile b/arch/arm/cpu/armv7m/Makefile index aff60e8..e1a6c40 100644 --- a/arch/arm/cpu/armv7m/Makefile +++ b/arch/arm/cpu/armv7m/Makefile @@ -7,3 +7,5 @@
extra-y := start.o obj-y += cpu.o + +obj-$(CONFIG_SYS_ARCH_TIMER) += systick-timer.o diff --git a/arch/arm/cpu/armv7m/systick-timer.c b/arch/arm/cpu/armv7m/systick-timer.c new file mode 100644 index 0000000..6ccc2fb --- /dev/null +++ b/arch/arm/cpu/armv7m/systick-timer.c @@ -0,0 +1,91 @@ +/* + * ARM Cortex M3/M4/M7 SysTick timer driver + * (C) Copyright 2017 Renesas Electronics Europe Ltd + * + * Based on arch/arm/mach-stm32/stm32f1/timer.c + * (C) Copyright 2015 + * Kamil Lulko, kamil.lulko@gmail.com + * + * Copyright 2015 ATS Advanced Telematics Systems GmbH + * Copyright 2015 Konsulko Group, Matt Porter mporter@konsulko.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* SysTick Base Address - fixed for all Cortex M3, M4 and M7 devices */ +#define SYSTICK_BASE 0xE000E010 + +struct cm3_systick { + uint32_t ctrl; + uint32_t reload; + uint32_t val; + uint32_t calibration; +}; + +#define TIMER_LOAD_VAL 0x00FFFFFF +#define SYSTICK_CTRL_EN BIT(0) +/* Clock source: 0 = Ref clock, 1 = CPU clock */ +#define SYSTICK_CTRL_CPU_CLK BIT(2) + +/* read the 24-bit timer */ +static ulong read_timer(void) +{ + struct cm3_systick *systick = (struct cm3_systick *)SYSTICK_BASE; + + /* The timer counts down, therefore convert to an incrementing timer */ + return TIMER_LOAD_VAL - readl(&systick->val); +} + +int timer_init(void) +{ + struct cm3_systick *systick = (struct cm3_systick *)SYSTICK_BASE; + + writel(TIMER_LOAD_VAL, &systick->reload); + writel(TIMER_LOAD_VAL, &systick->val); + +#ifdef CONFIG_ARMCORTEXM3_SYSTICK_CPU + /* Use CPU clock, no interrupts */ + writel(SYSTICK_CTRL_EN | SYSTICK_CTRL_CPU_CLK, &systick->ctrl); +#else + /* Use external clock, no interrupts */ + writel(SYSTICK_CTRL_EN, &systick->ctrl); +#endif + + gd->arch.tbl = 0; + gd->arch.tbu = 0; + gd->arch.lastinc = read_timer(); + + return 0; +} + +/* return milli-seconds timer value */ +ulong get_timer(ulong base) +{ + unsigned long long t = get_ticks() * 1000; + + return (ulong)((t / CONFIG_SYS_HZ_CLOCK)) - base; +} + +unsigned long long get_ticks(void) +{ + u32 now = read_timer(); + + if (now >= gd->arch.lastinc) + gd->arch.tbl += (now - gd->arch.lastinc); + else + gd->arch.tbl += (TIMER_LOAD_VAL - gd->arch.lastinc) + now; + + gd->arch.lastinc = now; + + return gd->arch.tbl; +} + +ulong get_tbclk(void) +{ + return CONFIG_SYS_HZ_CLOCK; +}
Hi Phil,
Actually this is not my /new/ e-mail address, the u-boot one should work. I am in the process of fixing my access to it.
Le Fri, 3 Feb 2017 14:53:06 +0000, Phil Edworthy phil.edworthy@renesas.com a écrit :
Cordialement, Albert ARIBAUD 3ADEV
Albert ARIBAUD
Phil Edworthy
