[U-Boot] [PATCH] usb: dwc3: Handle case where setup_phy is not needed
If CONFIG_PHY is not enabled then the dwc3_setup_phy() returns ENOTSUPP which can be still valid and intentional so modify error check to handle this -ENOTSUPP.
Signed-off-by: Siva Durga Prasad Paladugu siva.durga.paladugu@xilinx.com --- drivers/usb/dwc3/dwc3-generic.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/usb/dwc3/dwc3-generic.c b/drivers/usb/dwc3/dwc3-generic.c index 3e6c494..a261d8d 100644 --- a/drivers/usb/dwc3/dwc3-generic.c +++ b/drivers/usb/dwc3/dwc3-generic.c @@ -47,7 +47,7 @@ static int dwc3_generic_peripheral_probe(struct udevice *dev) struct dwc3 *dwc3 = &priv->dwc3;
rc = dwc3_setup_phy(dev, &priv->phys, &priv->num_phys); - if (rc) + if (rc && rc != -ENOTSUPP) return rc;
dwc3->regs = map_physmem(priv->base, DWC3_OTG_REGS_END, MAP_NOCACHE);
Hi Siva Durga Prasad Paladugu,
^^^^^^^^^^^^^^^^^^^^^^^^^^^ - could you elaborate on this a bit more?
What is the use case when -ENOTSUPP is valid and intentional ?
- if (rc)
MAP_NOCACHE);
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-59 Fax: (+49)-8142-66989-80 Email: lukma@denx.de
Hi Lukasz,
-----Original Message----- From: Lukasz Majewski [mailto:lukma@denx.de] Sent: Monday, April 01, 2019 1:03 PM To: Siva Durga Prasad Paladugu sivadur@xilinx.com Cc: u-boot@lists.denx.de; marex@denx.de; jjhiblot@ti.com; sjg@chromium.org; patrick.delaunay@st.com; Michal Simek michals@xilinx.com Subject: Re: [PATCH] usb: dwc3: Handle case where setup_phy is not needed
In the cases where phy will be setup by First stage boot loader itself and don't want to do it again at u-boot.
Thanks, Siva
- if (rc)
MAP_NOCACHE);
Lukasz Majewski
On Mon, 1 Apr 2019 10:23:42 +0000 Siva Durga Prasad Paladugu sivadur@xilinx.com wrote:
Hi Lukasz,
I think that I saw some time ago similar patch for uart - on IMX IIRC (it was also setup by BootROM on SoC).
Maybe we would need some kind of switch in Kconfig to indicate this use case?
Another option would be to mark this in DTS as TI specific property?
My point is that we shall not proceed with the flow when we do receive -ENOTSUPP
Thanks, Siva
- if (rc)
MAP_NOCACHE);
Lukasz Majewski
Lukasz Majewski
Hi Lukasz,
-----Original Message----- From: Lukasz Majewski [mailto:lukma@denx.de] Sent: Monday, April 01, 2019 4:04 PM To: Siva Durga Prasad Paladugu sivadur@xilinx.com Cc: u-boot@lists.denx.de; marex@denx.de; jjhiblot@ti.com; sjg@chromium.org; patrick.delaunay@st.com; Michal Simek michals@xilinx.com Subject: Re: [PATCH] usb: dwc3: Handle case where setup_phy is not needed
Hi Lukasz,
My point is that we shall not proceed with the flow when we do receive - ENOTSUPP
TBH, I feel we should not call dwc3_setup_phy() if CONFIG_PHY is not enabled. If we look at dwc3_setup_phy() definition, it is under CONFIG_PHY.
Thanks, Siva
Thanks, Siva
- if (rc)
MAP_NOCACHE);
Lukasz Majewski
Email:
lukma@denx.de
Lukasz Majewski
On 01. 04. 19 12:38, Siva Durga Prasad Paladugu wrote:
Hi Lukasz,
Hi Lukasz,
CONFIG_PHY.
+1 on this.
M
-----Original Message----- From: Michal Simek [mailto:michal.simek@xilinx.com] Sent: Monday, April 1, 2019 4:10 PM To: Siva Durga Prasad Paladugu sivadur@xilinx.com; Lukasz Majewski lukma@denx.de Cc: u-boot@lists.denx.de; marex@denx.de; jjhiblot@ti.com; sjg@chromium.org; patrick.delaunay@st.com Subject: Re: [PATCH] usb: dwc3: Handle case where setup_phy is not needed
Hi Lukasz,
Hi Lukasz,
CONFIG_PHY.
+1 on this.
Any update on this patch?
Thanks, Siva
M
-----Original Message----- From: Siva Durga Prasad Paladugu Sent: Tuesday, May 28, 2019 3:36 PM To: Michal Simek michal.simek@xilinx.com; Lukasz Majewski lukma@denx.de Cc: u-boot@lists.denx.de; marex@denx.de; jjhiblot@ti.com; sjg@chromium.org; patrick.delaunay@st.com Subject: RE: [PATCH] usb: dwc3: Handle case where setup_phy is not needed
Hi Lukasz,
Hi Lukasz,
> If CONFIG_PHY is not enabled then the dwc3_setup_phy() returns > ENOTSUPP which can be still valid and intentional ^^^^^^^^^^^^^^^^^^^^^^^^^^^ - could you elaborate on this a bit more?
CONFIG_PHY.
+1 on this.
This is how its already being handled in drivers/usb/host/xhci-dwc3.c at line 127 in routine xhci_dwc3_probe() (snippet below)
ret = dwc3_setup_phy(dev, &plat->usb_phys, &plat->num_phys); if (ret && (ret != -ENOTSUPP)) return ret;
We have two options either treat -ENOTSUPP as valid as above patch which I sent or don’t invoke dwc3_setup_phy() if CONFIG_PHY is not enabled.
Thanks, Siva
Thanks, Siva
M
Lukasz Majewski
Michal Simek
