[U-Boot] [PATCH] schmoogie: fix build error due to removal of forceenv()
commit 6d014adf dropped support for the forceenv() function, but failed to remove references to it from board/davinci/schmoogie/schmoogie.c
Replace forceenv() by setenv() and set CONFIG_ENV_OVERWRITE instead in the board config file to allow overwriting the serial number.
Signed-off-by: Wolfgang Denk wd@denx.de Cc: Sergey Kubushyn ksi@koi8.net --- board/davinci/schmoogie/schmoogie.c | 8 ++++---- include/configs/davinci-schmoogie.h | 1 + 2 files changed, 5 insertions(+), 4 deletions(-)
diff --git a/board/davinci/schmoogie/schmoogie.c b/board/davinci/schmoogie/schmoogie.c index 19c9580..80a0f9f 100644 --- a/board/davinci/schmoogie/schmoogie.c +++ b/board/davinci/schmoogie/schmoogie.c @@ -107,12 +107,12 @@ int misc_init_r(void) /* Set serial number from UID chip */ if (i2c_read(CONFIG_SYS_UID_ADDR, 0, 1, buf, 8)) { printf("\nUID @ 0x%02x read FAILED!!!\n", CONFIG_SYS_UID_ADDR); - forceenv("serial#", "FAILED"); + setenv("serial#", "FAILED"); } else { if (buf[0] != 0x70) { /* Device Family Code */ printf("\nUID @ 0x%02x read FAILED!!!\n", CONFIG_SYS_UID_ADDR); - forceenv("serial#", "FAILED"); + setenv("serial#", "FAILED"); } } /* Now check CRC */ @@ -122,12 +122,12 @@ int misc_init_r(void)
if (tmp[0] != 0) { printf("\nUID @ 0x%02x - BAD CRC!!!\n", CONFIG_SYS_UID_ADDR); - forceenv("serial#", "FAILED"); + setenv("serial#", "FAILED"); } else { /* CRC OK, set "serial" env variable */ sprintf((char *)&tmp[0], "%02x%02x%02x%02x%02x%02x", buf[6], buf[5], buf[4], buf[3], buf[2], buf[1]); - forceenv("serial#", (char *)&tmp[0]); + setenv("serial#", (char *)&tmp[0]); }
return(0); diff --git a/include/configs/davinci-schmoogie.h b/include/configs/davinci-schmoogie.h index 04cdc21..5b140fc 100644 --- a/include/configs/davinci-schmoogie.h +++ b/include/configs/davinci-schmoogie.h @@ -83,6 +83,7 @@ /*=====================*/ #undef CONFIG_ENV_IS_IN_FLASH #define CONFIG_SYS_NO_FLASH +#define CONFIG_ENV_OVERWRITE /* instead if obsoleted forceenv() */ #define CONFIG_NAND_DAVINCI #define CONFIG_SYS_NAND_CS 2 #define CONFIG_ENV_IS_IN_NAND /* U-Boot env in NAND Flash */
On Tue, 5 Oct 2010, Wolfgang Denk wrote:
Ack-by: Sergey Kubushyn ksi@koi8.net ---
} else { if (buf[0] != 0x70) { /* Device Family Code */ printf("\nUID @ 0x%02x read FAILED!!!\n", CONFIG_SYS_UID_ADDR);setenv("serial#", "FAILED");
} } /* Now check CRC */setenv("serial#", "FAILED");
} else { /* CRC OK, set "serial" env variable */ sprintf((char *)&tmp[0], "%02x%02x%02x%02x%02x%02x", buf[6], buf[5], buf[4], buf[3], buf[2], buf[1]);setenv("serial#", "FAILED");
return(0);
1.7.2.3
--- ****************************************************************** * KSI@home KOI8 Net < > The impossible we do immediately. * * Las Vegas NV, USA < > Miracles require 24-hour notice. * ******************************************************************
Thanks
I'll add it to u-boot-ti
Sandeep
Applied.
Sandeep, I hope this is OK with you. Thanks.
Paulraj, Sandeep
Sergey Kubushyn
