[U-Boot] [PATCH v3 1/2] armv8: fsl-lsch3: Add SD boot support for LS1088ARDB
Signed-off-by: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com Signed-off-by: Ashish Kumar Ashish.Kumar@nxp.com Signed-off-by: Raghav Dogra raghav.dogra@nxp.com --- v3: Depends upon http://patchwork.ozlabs.org/patch/794217/
Rebase to top commit "8b3cec7 mtdparts: Fix uninitialized scalar usage" Enable PPA New memory map
arch/arm/Kconfig | 1 + board/freescale/ls1088a/MAINTAINERS | 1 + board/freescale/ls1088a/ddr.c | 4 ++++ configs/ls1088ardb_sdcard_qspi_defconfig | 33 ++++++++++++++++++++++++++++++ include/configs/ls1088a_common.h | 35 ++++++++++++++++++++++++++++++++ include/configs/ls1088ardb.h | 30 +++++++++++++++++++++++++-- 6 files changed, 102 insertions(+), 2 deletions(-) create mode 100644 configs/ls1088ardb_sdcard_qspi_defconfig
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 5cad0d3..6243710 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -926,6 +926,7 @@ config TARGET_LS1088ARDB select ARMV8_MULTIENTRY select ARCH_MISC_INIT select BOARD_LATE_INIT + select SUPPORT_SPL help Support for NXP LS1088ARDB platform. The LS1088A Reference design board (RDB) is a high-performance diff --git a/board/freescale/ls1088a/MAINTAINERS b/board/freescale/ls1088a/MAINTAINERS index e1e6d4b..68f23d6 100644 --- a/board/freescale/ls1088a/MAINTAINERS +++ b/board/freescale/ls1088a/MAINTAINERS @@ -5,6 +5,7 @@ S: Maintained F: board/freescale/ls1088a/ F: include/configs/ls1088ardb.h F: configs/ls1088ardb_qspi_defconfig +F: configs/ls1088ardb_sdcard_qspi_defconfig
LS1088AQDS BOARD M: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com diff --git a/board/freescale/ls1088a/ddr.c b/board/freescale/ls1088a/ddr.c index 0ecfd65..bbab3a8 100644 --- a/board/freescale/ls1088a/ddr.c +++ b/board/freescale/ls1088a/ddr.c @@ -96,7 +96,11 @@ int fsl_initdram(void) { puts("Initializing DDR....using SPD\n");
+#if defined(CONFIG_SPL) && !defined(CONFIG_SPL_BUILD) + gd->ram_size = fsl_ddr_sdram_size(); +#else gd->ram_size = fsl_ddr_sdram(); +#endif
return 0; } diff --git a/configs/ls1088ardb_sdcard_qspi_defconfig b/configs/ls1088ardb_sdcard_qspi_defconfig new file mode 100644 index 0000000..c226bc1 --- /dev/null +++ b/configs/ls1088ardb_sdcard_qspi_defconfig @@ -0,0 +1,33 @@ +CONFIG_ARM=y +CONFIG_TARGET_LS1088ARDB=y +# CONFIG_SYS_MALLOC_F is not set +CONFIG_DM_SPI=y +CONFIG_DM_SPI_FLASH=y +CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1088a-rdb" +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_SYS_EXTRA_OPTIONS="SD_BOOT_QSPI" +CONFIG_SD_BOOT=y +CONFIG_SPL=y +CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_OF_CONTROL=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_DM=y +CONFIG_SPI_FLASH=y +CONFIG_NETDEVICES=y +CONFIG_E1000=y +CONFIG_SYS_NS16550=y +CONFIG_FSL_DSPI=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x8b0 +CONFIG_FSL_LS_PPA=y +CONFIG_SPL_BUILD=y +CONFIG_PARTITIONS=y +# CONFIG_DISPLAY_BOARDINFO is not set diff --git a/include/configs/ls1088a_common.h b/include/configs/ls1088a_common.h index c78ba5d..b79db5a 100644 --- a/include/configs/ls1088a_common.h +++ b/include/configs/ls1088a_common.h @@ -20,18 +20,24 @@ #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_FSL_OCRAM_BASE + 0xfff0)
/* Link Definitions */ +#ifdef CONFIG_SPL +#define CONFIG_SYS_TEXT_BASE 0x80400000 +#else #ifdef CONFIG_QSPI_BOOT #define CONFIG_SYS_TEXT_BASE 0x20100000 #else #define CONFIG_SYS_TEXT_BASE 0x30100000 #endif +#endif
#define CONFIG_SUPPORT_RAW_INITRD
#define CONFIG_SKIP_LOWLEVEL_INIT
+#if !defined(CONFIG_SD_BOOT) #define CONFIG_FSL_DDR_INTERACTIVE /* Interactive debugging */ +#endif
#define CONFIG_VERY_BIG_RAM #define CONFIG_SYS_DDR_SDRAM_BASE 0x80000000UL @@ -177,6 +183,11 @@ unsigned long long get_qixis_addr(void); " fsl_mc apply dpl 0x80200000 &&" \ " sf read $kernel_load $kernel_start" \ " $kernel_size && bootm $kernel_load" +#elif defined(CONFIG_SD_BOOT) +#define CONFIG_BOOTCOMMAND "mmcinfo;mmc read 0x80200000 0x6800 0x800;"\ + " fsl_mc apply dpl 0x80200000 &&" \ + " mmc read $kernel_load $kernel_start" \ + " $kernel_size && bootm $kernel_load" #else /* NOR BOOT*/ #define CONFIG_BOOTCOMMAND "fsl_mc apply dpl 0x580d00000 &&" \ " cp.b $kernel_start $kernel_load" \ @@ -196,6 +207,30 @@ unsigned long long get_qixis_addr(void);
#define CONFIG_PANIC_HANG /* do not reset board on panic */
+#ifdef CONFIG_SPL +#define CONFIG_SPL_BSS_START_ADDR 0x80100000 +#define CONFIG_SPL_BSS_MAX_SIZE 0x00100000 +#define CONFIG_SPL_DRIVERS_MISC_SUPPORT +#define CONFIG_SPL_ENV_SUPPORT +#define CONFIG_SPL_FRAMEWORK +#define CONFIG_SPL_I2C_SUPPORT +#define CONFIG_SPL_LDSCRIPT "arch/arm/cpu/armv8/u-boot-spl.lds" +#define CONFIG_SPL_LIBCOMMON_SUPPORT +#define CONFIG_SPL_LIBGENERIC_SUPPORT +#define CONFIG_SPL_MAX_SIZE 0x16000 +#define CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT +#define CONFIG_SPL_SERIAL_SUPPORT +#define CONFIG_SPL_STACK (CONFIG_SYS_FSL_OCRAM_BASE + 0x9ff0) +#define CONFIG_SPL_TARGET "u-boot-with-spl.bin" +#define CONFIG_SPL_TEXT_BASE 0x1800a000 +#ifdef CONFIG_SD_BOOT +#define CONFIG_SPL_MMC_SUPPORT +#endif + +#define CONFIG_SYS_SPL_MALLOC_SIZE 0x00100000 +#define CONFIG_SYS_SPL_MALLOC_START 0x80200000 +#define CONFIG_SYS_MONITOR_LEN (512 * 1024) +#endif #define CONFIG_SYS_BOOTM_LEN (64 << 20) /* Increase max gunzip size */
#endif /* __LS1088_COMMON_H */ diff --git a/include/configs/ls1088ardb.h b/include/configs/ls1088ardb.h index bab83b1..d0bdc10 100644 --- a/include/configs/ls1088ardb.h +++ b/include/configs/ls1088ardb.h @@ -16,6 +16,11 @@ #define CONFIG_ENV_SIZE 0x2000 /* 8KB */ #define CONFIG_ENV_OFFSET 0x300000 /* 3MB */ #define CONFIG_ENV_SECT_SIZE 0x40000 +#elif defined(CONFIG_SD_BOOT) +#define CONFIG_ENV_OFFSET (3 * 1024 * 1024) +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_SYS_MMC_ENV_DEV 0 +#define CONFIG_ENV_SIZE 0x2000 #else #define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x300000) @@ -23,7 +28,7 @@ #define CONFIG_ENV_SIZE 0x20000 #endif
-#if defined(CONFIG_QSPI_BOOT) +#if defined(CONFIG_QSPI_BOOT) || defined(CONFIG_SD_BOOT_QSPI) #define CONFIG_QIXIS_I2C_ACCESS #define SYS_NO_FLASH #undef CONFIG_CMD_IMLS @@ -236,7 +241,7 @@ #define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 5
/* QSPI device */ -#if defined(CONFIG_QSPI_BOOT) +#if defined(CONFIG_QSPI_BOOT) || defined(CONFIG_SD_BOOT_QSPI) #define CONFIG_FSL_QSPI #define CONFIG_SPI_FLASH_SPANSION #define FSL_QSPI_FLASH_SIZE (1 << 26) @@ -248,7 +253,11 @@ #define CONFIG_SYS_MEMTEST_START 0x80000000 #define CONFIG_SYS_MEMTEST_END 0x9fffffff
+#ifdef CONFIG_SPL_BUILD +#define CONFIG_SYS_MONITOR_BASE CONFIG_SPL_TEXT_BASE +#else #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE +#endif
#define CONFIG_FSL_MEMAC
@@ -270,6 +279,23 @@ "sf read 0x80100000 0xE00000 0x100000;" \ "fsl_mc start mc 0x80000000 0x80100000\0" \ "mcmemsize=0x70000000 \0" +#elif defined(CONFIG_SD_BOOT) +#undef CONFIG_EXTRA_ENV_SETTINGS +#define CONFIG_EXTRA_ENV_SETTINGS \ + "hwconfig=fsl_ddr:bank_intlv=auto\0" \ + "loadaddr=0x90100000\0" \ + "kernel_addr=0x800\0" \ + "ramdisk_addr=0x800000\0" \ + "ramdisk_size=0x2000000\0" \ + "fdt_high=0xa0000000\0" \ + "initrd_high=0xffffffffffffffff\0" \ + "kernel_start=0x8000\0" \ + "kernel_load=0xa0000000\0" \ + "kernel_size=0x14000\0" \ + "mcinitcmd=mmcinfo;mmc read 0x80000000 0x5000 0x800;" \ + "mmc read 0x80100000 0x7000 0x800;" \ + "fsl_mc start mc 0x80000000 0x80100000\0" \ + "mcmemsize=0x70000000 \0"
#endif
Add support for SD boot for QDS for ls1088 paltform
Signed-off-by: Ashish Kumar Ashish.Kumar@nxp.com Signed-off-by: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com Signed-off-by: Raghav Dogra raghav.dogra@nxp.com --- v3: Depends upon http://patchwork.ozlabs.org/patch/794217/
arch/arm/Kconfig | 1 + board/freescale/ls1088a/MAINTAINERS | 1 + configs/ls1088aqds_sdcard_qspi_defconfig | 33 +++++++++++++++++++++++++++++++ include/configs/ls1088aqds.h | 34 ++++++++++++++++++++++++++++---- 4 files changed, 65 insertions(+), 4 deletions(-) create mode 100644 configs/ls1088aqds_sdcard_qspi_defconfig
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 6243710..8bce296 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -812,6 +812,7 @@ config TARGET_LS1088AQDS select ARMV8_MULTIENTRY select ARCH_MISC_INIT select BOARD_LATE_INIT + select SUPPORT_SPL help Support for NXP LS1088AQDS platform The LS1088A Development System (QDS) is a high-performance diff --git a/board/freescale/ls1088a/MAINTAINERS b/board/freescale/ls1088a/MAINTAINERS index 68f23d6..b3d5c38 100644 --- a/board/freescale/ls1088a/MAINTAINERS +++ b/board/freescale/ls1088a/MAINTAINERS @@ -14,3 +14,4 @@ S: Maintained F: board/freescale/ls1088a/ F: include/configs/ls1088aqds.h F: configs/ls1088aqds_qspi_defconfig +F: configs/ls1088aqds_sdcard_qspi_defconfig diff --git a/configs/ls1088aqds_sdcard_qspi_defconfig b/configs/ls1088aqds_sdcard_qspi_defconfig new file mode 100644 index 0000000..95d8627 --- /dev/null +++ b/configs/ls1088aqds_sdcard_qspi_defconfig @@ -0,0 +1,33 @@ +CONFIG_ARM=y +CONFIG_TARGET_LS1088AQDS=y +# CONFIG_SYS_MALLOC_F is not set +CONFIG_DM_SPI=y +CONFIG_DM_SPI_FLASH=y +CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1088a-qds" +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_SYS_EXTRA_OPTIONS="SD_BOOT_QSPI" +CONFIG_SD_BOOT=y +CONFIG_SPL=y +CONFIG_HUSH_PARSER=y +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_OF_CONTROL=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_DM=y +CONFIG_SPI_FLASH=y +CONFIG_NETDEVICES=y +CONFIG_E1000=y +CONFIG_SYS_NS16550=y +CONFIG_FSL_DSPI=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x8b0 +CONFIG_FSL_LS_PPA=y +CONFIG_SPL_BUILD=y +CONFIG_PARTITIONS=y +# CONFIG_DISPLAY_BOARDINFO is not set diff --git a/include/configs/ls1088aqds.h b/include/configs/ls1088aqds.h index 3547b0b..72c2d3c 100644 --- a/include/configs/ls1088aqds.h +++ b/include/configs/ls1088aqds.h @@ -24,6 +24,11 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_ENV_SIZE 0x2000 /* 8KB */ #define CONFIG_ENV_OFFSET 0x300000 /* 3MB */ #define CONFIG_ENV_SECT_SIZE 0x40000 +#elif defined(CONFIG_SD_BOOT) +#define CONFIG_ENV_OFFSET (3 * 1024 * 1024) +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_SYS_MMC_ENV_DEV 0 +#define CONFIG_ENV_SIZE 0x2000 #else #define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x300000) @@ -31,10 +36,10 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_ENV_SIZE 0x20000 #endif
-#if defined(CONFIG_QSPI_BOOT) +#if defined(CONFIG_QSPI_BOOT) || defined(CONFIG_SD_BOOT_QSPI) #define CONFIG_QIXIS_I2C_ACCESS #define SYS_NO_FLASH - +#define CONFIG_SYS_I2C_EARLY_INIT #undef CONFIG_CMD_IMLS #define CONFIG_SYS_CLK_FREQ 100000000 #define CONFIG_DDR_CLK_FREQ 100000000 @@ -192,7 +197,7 @@ unsigned long get_board_ddr_clk(void); | CSPR_V)
#define CONFIG_SYS_FPGA_AMASK IFC_AMASK(64*1024) -#if defined(CONFIG_QSPI_BOOT) +#if defined(CONFIG_QSPI_BOOT) || defined(CONFIG_SD_BOOT_QSPI) #define CONFIG_SYS_FPGA_CSOR CSOR_GPCM_ADM_SHIFT(0) #else #define CONFIG_SYS_FPGA_CSOR CSOR_GPCM_ADM_SHIFT(12) @@ -295,7 +300,7 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 5
/* QSPI device */ -#if defined(CONFIG_QSPI_BOOT) +#if defined(CONFIG_QSPI_BOOT) || defined(CONFIG_SD_BOOT_QSPI) #define CONFIG_FSL_QSPI #define CONFIG_SPI_FLASH_SPANSION #define FSL_QSPI_FLASH_SIZE (1 << 26) @@ -318,7 +323,11 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_MEMTEST_START 0x80000000 #define CONFIG_SYS_MEMTEST_END 0x9fffffff
@@ -346,6 +355,23 @@ unsigned long get_board_ddr_clk(void); "sf read 0x80100000 0xE00000 0x100000;" \ "fsl_mc start mc 0x80000000 0x80100000\0" \ "mcmemsize=0x70000000 \0" +#elif defined(CONFIG_SD_BOOT) +#undef CONFIG_EXTRA_ENV_SETTINGS +#define CONFIG_EXTRA_ENV_SETTINGS \ + "hwconfig=fsl_ddr:bank_intlv=auto\0" \ + "loadaddr=0x90100000\0" \ + "kernel_addr=0x800\0" \ + "ramdisk_addr=0x800000\0" \ + "ramdisk_size=0x2000000\0" \ + "fdt_high=0xa0000000\0" \ + "initrd_high=0xffffffffffffffff\0" \ + "kernel_start=0x8000\0" \ + "kernel_load=0xa0000000\0" \ + "kernel_size=0x14000\0" \ + "mcinitcmd=mmcinfo;mmc read 0x80000000 0x5000 0x800;" \ + "mmc read 0x80100000 0x7000 0x800;" \ + "fsl_mc start mc 0x80000000 0x80100000\0" \ + "mcmemsize=0x70000000 \0" #else /* NOR BOOT */ #undef CONFIG_EXTRA_ENV_SETTINGS #define CONFIG_EXTRA_ENV_SETTINGS \
You know your dependency is not going to be accepted. Why do you send this patch?
York
v3: Depends upon https://emea01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fpatchwork....
Ashish,
I don't see correct image is generated with SD boot. RCW is missing. How do you boot it?
York
Ashish Kumar
York Sun
