[U-Boot] [PATCH v3 3/7] efi_loader: Move efi_allocate_pool implementation to efi_memory.c
Implementation essentially unchanged, but use EFI_PAGE_MASK/SHIFT instead of numeric constants.
Signed-off-by: Stefan Brüns stefan.bruens@rwth-aachen.de --- include/efi_loader.h | 3 +++ lib/efi_loader/efi_boottime.c | 11 +++++------ lib/efi_loader/efi_memory.c | 11 +++++++++++ 3 files changed, 19 insertions(+), 6 deletions(-)
diff --git a/include/efi_loader.h b/include/efi_loader.h index 9738835..40e7beb 100644 --- a/include/efi_loader.h +++ b/include/efi_loader.h @@ -119,6 +119,9 @@ efi_status_t efi_allocate_pages(int type, int memory_type, unsigned long pages, uint64_t *memory); /* EFI memory free function. Not implemented today */ efi_status_t efi_free_pages(uint64_t memory, unsigned long pages); +/* EFI memory allocator for small allocations, called by EFI payloads */ +efi_status_t efi_allocate_pool(int pool_type, unsigned long size, + void **buffer); /* Returns the EFI memory map */ efi_status_t efi_get_memory_map(unsigned long *memory_map_size, struct efi_mem_desc *memory_map, diff --git a/lib/efi_loader/efi_boottime.c b/lib/efi_loader/efi_boottime.c index 784891b..eb74cb0 100644 --- a/lib/efi_loader/efi_boottime.c +++ b/lib/efi_loader/efi_boottime.c @@ -130,15 +130,14 @@ efi_status_t EFIAPI efi_get_memory_map_ext(unsigned long *memory_map_size, return EFI_EXIT(r); }
-static efi_status_t EFIAPI efi_allocate_pool(int pool_type, unsigned long size, - void **buffer) +static efi_status_t EFIAPI efi_allocate_pool_ext(int pool_type, + unsigned long size, + void **buffer) { efi_status_t r; - efi_physical_addr_t t;
EFI_ENTRY("%d, %ld, %p", pool_type, size, buffer); - r = efi_allocate_pages(0, pool_type, (size + 0xfff) >> 12, &t); - *buffer = (void *)(uintptr_t)t; + r = efi_allocate_pool(pool_type, size, buffer); return EFI_EXIT(r); }
@@ -736,7 +735,7 @@ static const struct efi_boot_services efi_boot_services = { .allocate_pages = efi_allocate_pages_ext, .free_pages = efi_free_pages_ext, .get_memory_map = efi_get_memory_map_ext, - .allocate_pool = efi_allocate_pool, + .allocate_pool = efi_allocate_pool_ext, .free_pool = efi_free_pool, .create_event = efi_create_event, .set_timer = efi_set_timer, diff --git a/lib/efi_loader/efi_memory.c b/lib/efi_loader/efi_memory.c index 5d71fdf..045558d 100644 --- a/lib/efi_loader/efi_memory.c +++ b/lib/efi_loader/efi_memory.c @@ -327,6 +327,17 @@ efi_status_t efi_free_pages(uint64_t memory, unsigned long pages) return EFI_SUCCESS; }
+efi_status_t efi_allocate_pool(int pool_type, unsigned long size, + void **buffer) +{ + efi_status_t r; + efi_physical_addr_t t; + u64 num_pages = (size + EFI_PAGE_MASK) >> EFI_PAGE_SHIFT; + + r = efi_allocate_pages(0, pool_type, num_pages, &t); + return EFI_EXIT(r); +} + efi_status_t efi_get_memory_map(unsigned long *memory_map_size, struct efi_mem_desc *memory_map, unsigned long *map_key,
Sorry for being nitpicky about the commit message again. Imagine you're a distribution maintainer for U-Boot and you need to read the commit messages of all commits in the tree to figure out whether you need to cherry-pick a patch or not. Or you git bisect down to this commit and need to figure out what the original intention of this patch was.
How about something like
We currently handle efi_allocate_pool() inside of our boot time service file. In the following patch, pool allocation will receive additional internal semantics that we should preserve inside efi_memory.c instead.
As foundation for those changes, split the function into an externally facing helper efi_allocate_pool_ext() for use by payloads and an internal function efi_allocate_pool() in efi_memory.c that handles the actual allocation.
While at it, change the magic 0xfff / 12 constants to the more obvious EFI_PAGE_MASK/SHIFT defines.
Alex
The function that gets called by EFI payloads is actually the _ext one, as that's the one that swizzles the gd pointer as well. Just remove the last bit of the sentence.
void **buffer);
void **buffer)
unsigned long size,
void **buffer)
{ efi_status_t r;
- r = efi_allocate_pool(pool_type, size, buffer); return EFI_EXIT(r);
- .allocate_pool = efi_allocate_pool_ext, .free_pool = efi_free_pool, .create_event = efi_create_event, .set_timer = efi_set_timer,
void **buffer)
- efi_status_t r;
- u64 num_pages = (size + EFI_PAGE_MASK) >> EFI_PAGE_SHIFT;
- r = efi_allocate_pages(0, pool_type, num_pages, &t);
This is missing the *buffer update, no?
- return EFI_EXIT(r);
Double EFI_EXIT is fatal. Please just return r here.
Alex
Alexander Graf
Stefan Brüns
