[PATCH] mmc: tmio: Use IS_ENABLED() to check for CONFIG_ option
Use IS_ENABLED() instead of CONFIG_IS_ENABLED() to check for CONFIG_ option which is identical across all of U-Boot and xPL builds.
Fixes: 2769ddc99fd ("mmc: tmio: Replace ifdeffery with IS_ENABLED/CONFIG_IS_ENABLED macros") Signed-off-by: Marek Vasut marek.vasut+renesas@mailbox.org --- Cc: Jaehoon Chung jh80.chung@samsung.com Cc: Peng Fan peng.fan@nxp.com Cc: Tom Rini trini@konsulko.com --- drivers/mmc/tmio-common.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/mmc/tmio-common.c b/drivers/mmc/tmio-common.c index 8d7ee481d64..d1e26815996 100644 --- a/drivers/mmc/tmio-common.c +++ b/drivers/mmc/tmio-common.c @@ -378,7 +378,7 @@ static bool tmio_sd_addr_is_dmaable(struct mmc_data *data) }
#ifdef CONFIG_SPL_BUILD - if (IS_ENABLED(CONFIG_ARCH_UNIPHIER) && !CONFIG_IS_ENABLED(CONFIG_ARM64)) { + if (IS_ENABLED(CONFIG_ARCH_UNIPHIER) && !IS_ENABLED(CONFIG_ARM64)) { /* * For UniPhier ARMv7 SoCs, the stack is allocated in locked * ways of L2, which is unreachable from the DMA engine.
