[U-Boot] [PATCH v2] arm, imx6: add support for aristainetos2 board
add support for imx6dl based aristainetos2 board
U-Boot 2015.04-rc5-00066-g60f6ed4 (Apr 10 2015 - 08:46:27)
CPU: Freescale i.MX6DL rev1.1 at 792 MHz Reset cause: WDOG Board: aristaitenos2 Watchdog enabled I2C: ready DRAM: 1 GiB NAND: 1024 MiB MMC: FSL_SDHC: 0 SF: Detected N25Q128A with page size 256 Bytes, erase size 64 KiB, total 16 MiB Display: lg4573 (480x800) In: serial Out: serial Err: serial Net: FEC [PRIME] Hit any key to stop autoboot: 0 =>
Signed-off-by: Heiko Schocher hs@denx.de
Changes in v2: - add comment from Stefano Babic: - adapt for i2c fixes suggested by Stefano Babic - remove lgdisplay var - remove CONFIG_PHY_MICREL_KSZ9031 - rename enable_spi to enable_spi_display - rotate logo remains in board code
arch/arm/Kconfig | 5 + board/aristainetos2/Kconfig | 12 + board/aristainetos2/MAINTAINERS | 6 + board/aristainetos2/Makefile | 12 + board/aristainetos2/aristainetos2.c | 922 ++++++++++++++++++++++++++++++++++ board/aristainetos2/aristainetos2.cfg | 34 ++ board/aristainetos2/axi.cfg | 22 + board/aristainetos2/clocks.cfg | 24 + board/aristainetos2/ddr-setup.cfg | 59 +++ board/aristainetos2/nt5cc256m16cp.cfg | 60 +++ configs/aristainetos2_defconfig | 3 + include/configs/aristainetos2.h | 352 +++++++++++++ 12 files changed, 1511 insertions(+) create mode 100644 board/aristainetos2/Kconfig create mode 100644 board/aristainetos2/MAINTAINERS create mode 100644 board/aristainetos2/Makefile create mode 100644 board/aristainetos2/aristainetos2.c create mode 100644 board/aristainetos2/aristainetos2.cfg create mode 100644 board/aristainetos2/axi.cfg create mode 100644 board/aristainetos2/clocks.cfg create mode 100644 board/aristainetos2/ddr-setup.cfg create mode 100644 board/aristainetos2/nt5cc256m16cp.cfg create mode 100644 configs/aristainetos2_defconfig create mode 100644 include/configs/aristainetos2.h
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 49bcad1..287a9ff 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -523,6 +523,10 @@ config TARGET_ARISTAINETOS bool "Support aristainetos" select CPU_V7
+config TARGET_ARISTAINETOS2 + bool "Support aristainetos2" + select CPU_V7 + config TARGET_MX6QARM2 bool "Support mx6qarm2" select CPU_V7 @@ -856,6 +860,7 @@ source "arch/arm/cpu/armv8/Kconfig" source "arch/arm/imx-common/Kconfig"
source "board/aristainetos/Kconfig" +source "board/aristainetos2/Kconfig" source "board/BuR/kwb/Kconfig" source "board/BuR/tseries/Kconfig" source "board/CarMediaLab/flea3/Kconfig" diff --git a/board/aristainetos2/Kconfig b/board/aristainetos2/Kconfig new file mode 100644 index 0000000..2cf13e4 --- /dev/null +++ b/board/aristainetos2/Kconfig @@ -0,0 +1,12 @@ +if TARGET_ARISTAINETOS2 + +config SYS_BOARD + default "aristainetos2" + +config SYS_SOC + default "mx6" + +config SYS_CONFIG_NAME + default "aristainetos2" + +endif diff --git a/board/aristainetos2/MAINTAINERS b/board/aristainetos2/MAINTAINERS new file mode 100644 index 0000000..d155f86 --- /dev/null +++ b/board/aristainetos2/MAINTAINERS @@ -0,0 +1,6 @@ +ARISTAINETOS BOARD +M: Heiko Schocher hs@denx.de +S: Maintained +F: board/aristainetos2/ +F: include/configs/aristainetos2.h +F: configs/aristainetos2_defconfig diff --git a/board/aristainetos2/Makefile b/board/aristainetos2/Makefile new file mode 100644 index 0000000..2513744 --- /dev/null +++ b/board/aristainetos2/Makefile @@ -0,0 +1,12 @@ +# +# (C) Copyright 2015 +# Heiko Schocher, DENX Software Engineering, hs@denx.de. +# +# Copyright (C) 2007, Guennadi Liakhovetski lg@denx.de +# +# (C) Copyright 2011 Freescale Semiconductor, Inc. +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y := aristainetos2.o diff --git a/board/aristainetos2/aristainetos2.c b/board/aristainetos2/aristainetos2.c new file mode 100644 index 0000000..3a7aac0 --- /dev/null +++ b/board/aristainetos2/aristainetos2.c @@ -0,0 +1,922 @@ +/* + * (C) Copyright 2015 + * Heiko Schocher, DENX Software Engineering, hs@denx.de. + * + * Based on: + * Copyright (C) 2012 Freescale Semiconductor, Inc. + * + * Author: Fabio Estevam fabio.estevam@freescale.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <asm/arch/clock.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/iomux.h> +#include <asm/arch/mx6-pins.h> +#include <asm/errno.h> +#include <asm/gpio.h> +#include <asm/imx-common/iomux-v3.h> +#include <asm/imx-common/boot_mode.h> +#include <asm/imx-common/mxc_i2c.h> +#include <asm/imx-common/video.h> +#include <mmc.h> +#include <fsl_esdhc.h> +#include <micrel.h> +#include <miiphy.h> +#include <netdev.h> +#include <asm/arch/mxc_hdmi.h> +#include <asm/arch/crm_regs.h> +#include <linux/fb.h> +#include <ipu_pixfmt.h> +#include <asm/io.h> +#include <asm/arch/sys_proto.h> +#include <pwm.h> +#include <spi.h> +#include <video.h> +#include <../drivers/video/ipu.h> +#if defined(CONFIG_VIDEO_BMP_LOGO) + #include <bmp_logo.h> +#endif +DECLARE_GLOBAL_DATA_PTR; + +#define UART_PAD_CTRL (PAD_CTL_PUS_100K_UP | \ + PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | \ + PAD_CTL_SRE_FAST | PAD_CTL_HYS) + +#define USDHC_PAD_CTRL (PAD_CTL_PUS_47K_UP | \ + PAD_CTL_SPEED_LOW | PAD_CTL_DSE_80ohm | \ + PAD_CTL_SRE_FAST | PAD_CTL_HYS) + +#define USDHC2_PAD_CTRL (PAD_CTL_SPEED_LOW | \ + PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST) + +#define ENET_PAD_CTRL (PAD_CTL_PUS_100K_UP | \ + PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | PAD_CTL_HYS) + +#define SPI_PAD_CTRL (PAD_CTL_HYS | PAD_CTL_SPEED_MED | \ + PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST) + +#define I2C_PAD_CTRL (PAD_CTL_PUS_100K_UP | \ + PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | PAD_CTL_HYS | \ + PAD_CTL_ODE | PAD_CTL_SRE_FAST) + +#define PC MUX_PAD_CTRL(I2C_PAD_CTRL) + +#define DISP_PAD_CTRL (0x10) + +#define ECSPI1_CS0 IMX_GPIO_NR(4, 9) /* 4.3 display controller */ +#define ECSPI4_CS0 IMX_GPIO_NR(3, 29) +#define ECSPI4_CS1 IMX_GPIO_NR(5, 2) /* NOR boot flash */ + +#define SOFT_RESET_GPIO IMX_GPIO_NR(7, 13) +#define SD2_DRIVER_ENABLE IMX_GPIO_NR(7, 8) + + +struct i2c_pads_info i2c_pad_info1 = { + .scl = { + .i2c_mode = MX6_PAD_CSI0_DAT9__I2C1_SCL | PC, + .gpio_mode = MX6_PAD_CSI0_DAT9__GPIO5_IO27 | PC, + .gp = IMX_GPIO_NR(5, 27) + }, + .sda = { + .i2c_mode = MX6_PAD_CSI0_DAT8__I2C1_SDA | PC, + .gpio_mode = MX6_PAD_CSI0_DAT8__GPIO5_IO26 | PC, + .gp = IMX_GPIO_NR(5, 26) + } +}; + +struct i2c_pads_info i2c_pad_info2 = { + .scl = { + .i2c_mode = MX6_PAD_KEY_COL3__I2C2_SCL | PC, + .gpio_mode = MX6_PAD_KEY_COL3__GPIO4_IO12 | PC, + .gp = IMX_GPIO_NR(4, 12) + }, + .sda = { + .i2c_mode = MX6_PAD_KEY_ROW3__I2C2_SDA | PC, + .gpio_mode = MX6_PAD_KEY_ROW3__GPIO4_IO13 | PC, + .gp = IMX_GPIO_NR(4, 13) + } +}; + +struct i2c_pads_info i2c_pad_info3 = { + .scl = { + .i2c_mode = MX6_PAD_GPIO_5__I2C3_SCL | PC, + .gpio_mode = MX6_PAD_GPIO_5__GPIO1_IO05 | PC, + .gp = IMX_GPIO_NR(1, 5) + }, + .sda = { + .i2c_mode = MX6_PAD_GPIO_6__I2C3_SDA | PC, + .gpio_mode = MX6_PAD_GPIO_6__GPIO1_IO06 | PC, + .gp = IMX_GPIO_NR(1, 6) + } +}; + +struct i2c_pads_info i2c_pad_info4 = { + .scl = { + .i2c_mode = MX6_PAD_GPIO_7__I2C4_SCL | PC, + .gpio_mode = MX6_PAD_GPIO_7__GPIO1_IO07 | PC, + .gp = IMX_GPIO_NR(1, 7) + }, + .sda = { + .i2c_mode = MX6_PAD_GPIO_8__I2C4_SDA | PC, + .gpio_mode = MX6_PAD_GPIO_8__GPIO1_IO08 | PC, + .gp = IMX_GPIO_NR(1, 8) + } +}; + +int dram_init(void) +{ + gd->ram_size = get_ram_size((void *)PHYS_SDRAM, PHYS_SDRAM_SIZE); + + return 0; +} + +iomux_v3_cfg_t const uart1_pads[] = { + MX6_PAD_CSI0_DAT10__UART1_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_CSI0_DAT11__UART1_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_EIM_D19__UART1_CTS_B | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_EIM_D20__UART1_RTS_B | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + +iomux_v3_cfg_t const uart2_pads[] = { + MX6_PAD_EIM_D26__UART2_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_EIM_D27__UART2_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + +iomux_v3_cfg_t const uart3_pads[] = { + MX6_PAD_EIM_D24__UART3_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_EIM_D25__UART3_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_EIM_D31__UART3_RTS_B | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_EIM_D23__UART3_CTS_B | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + +iomux_v3_cfg_t const uart4_pads[] = { + MX6_PAD_KEY_COL0__UART4_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_KEY_ROW0__UART4_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + +iomux_v3_cfg_t const gpio_pads[] = { + /* LED enable*/ + MX6_PAD_ENET_CRS_DV__GPIO1_IO25 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* LED yellow */ + MX6_PAD_NANDF_CS3__GPIO6_IO16 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* LED red */ + MX6_PAD_EIM_EB0__GPIO2_IO28 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* LED green */ + MX6_PAD_EIM_A24__GPIO5_IO04 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* LED blue */ + MX6_PAD_EIM_EB1__GPIO2_IO29 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* spi flash WP protect */ + MX6_PAD_SD4_DAT7__GPIO2_IO15 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* spi CS 0 */ + MX6_PAD_EIM_D29__GPIO3_IO29 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* spi bus #2 SS driver enable */ + MX6_PAD_EIM_A23__GPIO6_IO06 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* RST_LOC# PHY reset input (has pull-down!)*/ + MX6_PAD_GPIO_18__GPIO7_IO13 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* SD 2 level shifter output enable */ + MX6_PAD_SD3_RST__GPIO7_IO08 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* SD1 card detect input */ + MX6_PAD_ENET_RXD0__GPIO1_IO27 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* SD1 write protect input */ + MX6_PAD_DI0_PIN4__GPIO4_IO20 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* SD2 card detect input */ + MX6_PAD_GPIO_19__GPIO4_IO05 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* SD2 write protect input */ + MX6_PAD_SD4_DAT2__GPIO2_IO10 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* Touchscreen IRQ */ + MX6_PAD_SD4_DAT1__GPIO2_IO09 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +static iomux_v3_cfg_t const misc_pads[] = { + /* USB_OTG_ID = GPIO1_24*/ + MX6_PAD_ENET_RX_ER__USB_OTG_ID | MUX_PAD_CTRL(NO_PAD_CTRL), + /* H1 Power enable = GPIO1_0*/ + MX6_PAD_GPIO_0__USB_H1_PWR | MUX_PAD_CTRL(NO_PAD_CTRL), + /* OTG Power enable = GPIO4_15*/ + MX6_PAD_KEY_ROW4__USB_OTG_PWR | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +iomux_v3_cfg_t const enet_pads[] = { + MX6_PAD_ENET_MDIO__ENET_MDIO | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET_MDC__ENET_MDC | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TXC__RGMII_TXC | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TD0__RGMII_TD0 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TD1__RGMII_TD1 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TD2__RGMII_TD2 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TD3__RGMII_TD3 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_TX_CTL__RGMII_TX_CTL | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_ENET_REF_CLK__ENET_TX_CLK | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_RXC__RGMII_RXC | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_RD0__RGMII_RD0 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_RD1__RGMII_RD1 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_RD2__RGMII_RD2 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_RD3__RGMII_RD3 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6_PAD_RGMII_RX_CTL__RGMII_RX_CTL | MUX_PAD_CTRL(ENET_PAD_CTRL), +}; + +static void setup_iomux_enet(void) +{ + imx_iomux_v3_setup_multiple_pads(enet_pads, ARRAY_SIZE(enet_pads)); +} + +iomux_v3_cfg_t const usdhc1_pads[] = { + MX6_PAD_SD1_CLK__SD1_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD1_CMD__SD1_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD1_DAT0__SD1_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD1_DAT1__SD1_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD1_DAT2__SD1_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD1_DAT3__SD1_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), +}; + +iomux_v3_cfg_t const usdhc2_pads[] = { + MX6_PAD_SD2_CLK__SD2_CLK | MUX_PAD_CTRL(USDHC2_PAD_CTRL), + MX6_PAD_SD2_CMD__SD2_CMD | MUX_PAD_CTRL(USDHC2_PAD_CTRL), + MX6_PAD_SD2_DAT0__SD2_DATA0 | MUX_PAD_CTRL(USDHC2_PAD_CTRL), + MX6_PAD_SD2_DAT1__SD2_DATA1 | MUX_PAD_CTRL(USDHC2_PAD_CTRL), + MX6_PAD_SD2_DAT2__SD2_DATA2 | MUX_PAD_CTRL(USDHC2_PAD_CTRL), + MX6_PAD_SD2_DAT3__SD2_DATA3 | MUX_PAD_CTRL(USDHC2_PAD_CTRL), + MX6_PAD_SD3_RST__SD3_RESET | MUX_PAD_CTRL(USDHC_PAD_CTRL), +}; + +static iomux_v3_cfg_t const ecspi1_pads[] = { + MX6_PAD_EIM_D16__ECSPI1_SCLK | MUX_PAD_CTRL(SPI_PAD_CTRL), + MX6_PAD_EIM_D17__ECSPI1_MISO | MUX_PAD_CTRL(SPI_PAD_CTRL), + MX6_PAD_EIM_D18__ECSPI1_MOSI | MUX_PAD_CTRL(SPI_PAD_CTRL), + MX6_PAD_KEY_ROW1__GPIO4_IO09 | MUX_PAD_CTRL(SPI_PAD_CTRL), +}; + +iomux_v3_cfg_t const ecspi4_pads[] = { + MX6_PAD_EIM_D21__ECSPI4_SCLK | MUX_PAD_CTRL(SPI_PAD_CTRL), + MX6_PAD_EIM_D22__ECSPI4_MISO | MUX_PAD_CTRL(SPI_PAD_CTRL), + MX6_PAD_EIM_D28__ECSPI4_MOSI | MUX_PAD_CTRL(SPI_PAD_CTRL), + MX6_PAD_EIM_A25__GPIO5_IO02 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_EIM_D29__GPIO3_IO29 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +/* only used for 4.3" display */ +static iomux_v3_cfg_t const display_pads[] = { + MX6_PAD_DI0_DISP_CLK__IPU1_DI0_DISP_CLK | MUX_PAD_CTRL(DISP_PAD_CTRL), + MX6_PAD_DI0_PIN15__IPU1_DI0_PIN15, + MX6_PAD_DI0_PIN2__IPU1_DI0_PIN02, + MX6_PAD_DI0_PIN3__IPU1_DI0_PIN03, + MX6_PAD_DISP0_DAT0__IPU1_DISP0_DATA00, + MX6_PAD_DISP0_DAT1__IPU1_DISP0_DATA01, + MX6_PAD_DISP0_DAT2__IPU1_DISP0_DATA02, + MX6_PAD_DISP0_DAT3__IPU1_DISP0_DATA03, + MX6_PAD_DISP0_DAT4__IPU1_DISP0_DATA04, + MX6_PAD_DISP0_DAT5__IPU1_DISP0_DATA05, + MX6_PAD_DISP0_DAT6__IPU1_DISP0_DATA06, + MX6_PAD_DISP0_DAT7__IPU1_DISP0_DATA07, + MX6_PAD_DISP0_DAT8__IPU1_DISP0_DATA08, + MX6_PAD_DISP0_DAT9__IPU1_DISP0_DATA09, + MX6_PAD_DISP0_DAT10__IPU1_DISP0_DATA10, + MX6_PAD_DISP0_DAT11__IPU1_DISP0_DATA11, + MX6_PAD_DISP0_DAT12__IPU1_DISP0_DATA12, + MX6_PAD_DISP0_DAT13__IPU1_DISP0_DATA13, + MX6_PAD_DISP0_DAT14__IPU1_DISP0_DATA14, + MX6_PAD_DISP0_DAT15__IPU1_DISP0_DATA15, + MX6_PAD_DISP0_DAT16__IPU1_DISP0_DATA16, + MX6_PAD_DISP0_DAT17__IPU1_DISP0_DATA17, + MX6_PAD_DISP0_DAT18__IPU1_DISP0_DATA18, + MX6_PAD_DISP0_DAT19__IPU1_DISP0_DATA19, + MX6_PAD_DISP0_DAT20__IPU1_DISP0_DATA20, + MX6_PAD_DISP0_DAT21__IPU1_DISP0_DATA21, + MX6_PAD_DISP0_DAT22__IPU1_DISP0_DATA22, + MX6_PAD_DISP0_DAT23__IPU1_DISP0_DATA23, +}; + +static iomux_v3_cfg_t const backlight_pads[] = { + /* backlight PWM brightness control */ + MX6_PAD_GPIO_9__PWM1_OUT | MUX_PAD_CTRL(NO_PAD_CTRL), + /* backlight enable */ + MX6_PAD_EIM_BCLK__GPIO6_IO31 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* LCD power enable */ + MX6_PAD_NANDF_CS2__GPIO6_IO15 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +int board_spi_cs_gpio(unsigned bus, unsigned cs) +{ + if (bus == CONFIG_SF_DEFAULT_BUS && cs == CONFIG_SF_DEFAULT_CS) + return IMX_GPIO_NR(5, 2); + + if (bus == 0 && cs == 0) + return IMX_GPIO_NR(4, 9); + + return -1; +} + +static void setup_spi(void) +{ + int i; + + imx_iomux_v3_setup_multiple_pads(ecspi1_pads, ARRAY_SIZE(ecspi1_pads)); + imx_iomux_v3_setup_multiple_pads(ecspi4_pads, ARRAY_SIZE(ecspi4_pads)); + for (i = 0; i < 4; i++) + enable_spi_clk(true, i); + + gpio_direction_output(ECSPI1_CS0, 1); + gpio_direction_output(ECSPI4_CS1, 0); + + /* set cs0 to high (second device on spi bus #4) */ + gpio_direction_output(ECSPI4_CS0, 1); +} + +static void setup_iomux_gpio(void) +{ + imx_iomux_v3_setup_multiple_pads(gpio_pads, ARRAY_SIZE(gpio_pads)); +} + +static void setup_iomux_uart(void) +{ + switch (CONFIG_MXC_UART_BASE) { + case UART1_BASE: + imx_iomux_v3_setup_multiple_pads(uart1_pads, + ARRAY_SIZE(uart1_pads)); + break; + case UART2_BASE: + imx_iomux_v3_setup_multiple_pads(uart2_pads, + ARRAY_SIZE(uart2_pads)); + break; + case UART3_BASE: + imx_iomux_v3_setup_multiple_pads(uart3_pads, + ARRAY_SIZE(uart3_pads)); + break; + case UART4_BASE: + imx_iomux_v3_setup_multiple_pads(uart4_pads, + ARRAY_SIZE(uart4_pads)); + break; + } +} + +#ifdef CONFIG_FSL_ESDHC +struct fsl_esdhc_cfg usdhc_cfg[2] = { + {USDHC1_BASE_ADDR}, + {USDHC2_BASE_ADDR}, +}; + +int board_mmc_getcd(struct mmc *mmc) +{ + return 1; +} + +int board_mmc_init(bd_t *bis) +{ + usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC_CLK); + imx_iomux_v3_setup_multiple_pads(usdhc1_pads, ARRAY_SIZE(usdhc1_pads)); + +#if defined(CONFIG_USE_SDHC2) + usdhc_cfg[1].sdhc_clk = mxc_get_clock(MXC_ESDHC2_CLK); + imx_iomux_v3_setup_multiple_pads(usdhc2_pads, ARRAY_SIZE(usdhc2_pads)); + + return fsl_esdhc_initialize(bis, &usdhc_cfg[0]) | + fsl_esdhc_initialize(bis, &usdhc_cfg[1]); +#else + /* + * usdhc2 has a levelshifter on the carrier board Rev. DV1, + * that will automatically detect the driving direction. + * During initialisation this isn't working correctly, + * which causes DAT3 to be driven low towards the SD-card. + * This causes a SD-card enetring the SPI-Mode + * and therefore getting inaccessible until next power cycle. + * As workaround we drive the DAT3 line as GPIO and set it high. + * This makes usdhc2 unusable in u-boot, but works for the + * initialisation in Linux + */ + imx_iomux_v3_setup_pad(MX6_PAD_SD2_DAT3__GPIO1_IO12 | + MUX_PAD_CTRL(NO_PAD_CTRL)); + gpio_direction_output(IMX_GPIO_NR(1, 12) , 1); + + return fsl_esdhc_initialize(bis, &usdhc_cfg[0]); +#endif +} +#endif + +/* + * Do not overwrite the console + * Use always serial for U-Boot console + */ +int overwrite_console(void) +{ + return 1; +} + +int board_phy_config(struct phy_device *phydev) +{ + /* control data pad skew - devaddr = 0x02, register = 0x04 */ + ksz9031_phy_extended_write(phydev, 0x02, + MII_KSZ9031_EXT_RGMII_CTRL_SIG_SKEW, + MII_KSZ9031_MOD_DATA_NO_POST_INC, 0x0000); + /* rx data pad skew - devaddr = 0x02, register = 0x05 */ + ksz9031_phy_extended_write(phydev, 0x02, + MII_KSZ9031_EXT_RGMII_RX_DATA_SKEW, + MII_KSZ9031_MOD_DATA_NO_POST_INC, 0x0000); + /* tx data pad skew - devaddr = 0x02, register = 0x06 */ + ksz9031_phy_extended_write(phydev, 0x02, + MII_KSZ9031_EXT_RGMII_TX_DATA_SKEW, + MII_KSZ9031_MOD_DATA_NO_POST_INC, 0x0000); + /* gtx and rx clock pad skew - devaddr = 0x02, register = 0x08 */ + ksz9031_phy_extended_write(phydev, 0x02, + MII_KSZ9031_EXT_RGMII_CLOCK_SKEW, + MII_KSZ9031_MOD_DATA_NO_POST_INC, 0x03FF); + + if (phydev->drv->config) + phydev->drv->config(phydev); + + + + return 0; +} + +int board_eth_init(bd_t *bis) +{ + setup_iomux_enet(); + return cpu_eth_init(bis); +} + +#if defined(CONFIG_VIDEO_IPUV3) + +#if defined(CONFIG_VIDEO_BMP_LOGO) +static int rotate_logo_one(unsigned char *out, unsigned char *in) +{ + int i, j; + + for (i = 0; i < BMP_LOGO_WIDTH; i++) + for (j = 0; j < BMP_LOGO_HEIGHT; j++) + out[j * BMP_LOGO_WIDTH + BMP_LOGO_HEIGHT - 1 - i] = + in[i * BMP_LOGO_WIDTH + j]; + return 0; +} + +/* + * Rotate the BMP_LOGO (only) + * Will only work, if the logo is square, as + * BMP_LOGO_HEIGHT and BMP_LOGO_WIDTH are defines, not variables + */ +void rotate_logo(int rotations) +{ + unsigned char out_logo[BMP_LOGO_WIDTH * BMP_LOGO_HEIGHT]; + unsigned char *in_logo; + int i, j; + + if (BMP_LOGO_WIDTH != BMP_LOGO_HEIGHT) + return; + + in_logo = bmp_logo_bitmap; + + /* one 90 degree rotation */ + if (rotations == 1 || rotations == 2 || rotations == 3) + rotate_logo_one(out_logo, in_logo); + + /* second 90 degree rotation */ + if (rotations == 2 || rotations == 3) + rotate_logo_one(in_logo, out_logo); + + /* third 90 degree rotation */ + if (rotations == 3) + rotate_logo_one(out_logo, in_logo); + + /* copy result back to original array */ + if (rotations == 1 || rotations == 3) + for (i = 0; i < BMP_LOGO_WIDTH; i++) + for (j = 0; j < BMP_LOGO_HEIGHT; j++) + in_logo[i * BMP_LOGO_WIDTH + j] = + out_logo[i * BMP_LOGO_WIDTH + j]; +} +#endif + +static void enable_display_power(void) +{ + imx_iomux_v3_setup_multiple_pads(backlight_pads, + ARRAY_SIZE(backlight_pads)); + + /* backlight enable */ + gpio_direction_output(IMX_GPIO_NR(6, 31), 1); + /* LCD power enable */ + gpio_direction_output(IMX_GPIO_NR(6, 15), 1); + + /* enable backlight PWM 1 */ + if (pwm_init(0, 0, 0)) + goto error; + /* duty cycle 500ns, period: 3000ns */ + if (pwm_config(0, 50000, 300000)) + goto error; + if (pwm_enable(0)) + goto error; + return; + +error: + puts("error init pwm for backlight\n"); + return; +} + +static void enable_lvds(struct display_info_t const *dev) +{ + struct iomuxc *iomux = (struct iomuxc *)IOMUXC_BASE_ADDR; + struct mxc_ccm_reg *ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; + int reg; + s32 timeout = 100000; + + /* set PLL5 clock */ + reg = readl(&ccm->analog_pll_video); + reg |= BM_ANADIG_PLL_VIDEO_POWERDOWN; + writel(reg, &ccm->analog_pll_video); + + /* set PLL5 to 232720000Hz */ + reg &= ~BM_ANADIG_PLL_VIDEO_DIV_SELECT; + reg |= BF_ANADIG_PLL_VIDEO_DIV_SELECT(0x26); + reg &= ~BM_ANADIG_PLL_VIDEO_POST_DIV_SELECT; + reg |= BF_ANADIG_PLL_VIDEO_POST_DIV_SELECT(0); + writel(reg, &ccm->analog_pll_video); + + writel(BF_ANADIG_PLL_VIDEO_NUM_A(0xC0238), + &ccm->analog_pll_video_num); + writel(BF_ANADIG_PLL_VIDEO_DENOM_B(0xF4240), + &ccm->analog_pll_video_denom); + + reg &= ~BM_ANADIG_PLL_VIDEO_POWERDOWN; + writel(reg, &ccm->analog_pll_video); + + while (timeout--) + if (readl(&ccm->analog_pll_video) & BM_ANADIG_PLL_VIDEO_LOCK) + break; + if (timeout < 0) + printf("Warning: video pll lock timeout!\n"); + + reg = readl(&ccm->analog_pll_video); + reg |= BM_ANADIG_PLL_VIDEO_ENABLE; + reg &= ~BM_ANADIG_PLL_VIDEO_BYPASS; + writel(reg, &ccm->analog_pll_video); + + /* set LDB0, LDB1 clk select to 000/000 (PLL5 clock) */ + reg = readl(&ccm->cs2cdr); + reg &= ~(MXC_CCM_CS2CDR_LDB_DI0_CLK_SEL_MASK + | MXC_CCM_CS2CDR_LDB_DI1_CLK_SEL_MASK); + reg |= (0 << MXC_CCM_CS2CDR_LDB_DI0_CLK_SEL_OFFSET) + | (0 << MXC_CCM_CS2CDR_LDB_DI1_CLK_SEL_OFFSET); + writel(reg, &ccm->cs2cdr); + + reg = readl(&ccm->cscmr2); + reg |= MXC_CCM_CSCMR2_LDB_DI0_IPU_DIV; + writel(reg, &ccm->cscmr2); + + reg = readl(&ccm->chsccdr); + reg |= (CHSCCDR_CLK_SEL_LDB_DI0 + << MXC_CCM_CHSCCDR_IPU1_DI0_CLK_SEL_OFFSET); + writel(reg, &ccm->chsccdr); + + reg = IOMUXC_GPR2_BGREF_RRMODE_EXTERNAL_RES + | IOMUXC_GPR2_DI1_VS_POLARITY_ACTIVE_HIGH + | IOMUXC_GPR2_DI0_VS_POLARITY_ACTIVE_HIGH + | IOMUXC_GPR2_BIT_MAPPING_CH0_SPWG + | IOMUXC_GPR2_DATA_WIDTH_CH0_24BIT + | IOMUXC_GPR2_LVDS_CH1_MODE_DISABLED + | IOMUXC_GPR2_LVDS_CH0_MODE_ENABLED_DI0; + writel(reg, &iomux->gpr[2]); + + reg = readl(&iomux->gpr[3]); + reg = (reg & ~IOMUXC_GPR3_LVDS0_MUX_CTL_MASK) + | (IOMUXC_GPR3_MUX_SRC_IPU1_DI0 + << IOMUXC_GPR3_LVDS0_MUX_CTL_OFFSET); + writel(reg, &iomux->gpr[3]); + + return; +} + +static void enable_spi_display(struct display_info_t const *dev) +{ + struct iomuxc *iomux = (struct iomuxc *)IOMUXC_BASE_ADDR; + struct mxc_ccm_reg *ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; + int reg; + s32 timeout = 100000; + +#if defined(CONFIG_VIDEO_BMP_LOGO) + rotate_logo(3); /* portrait display in landscape mode */ +#endif + + /* + * set ldb clock to 28341000 Hz calculated through the formula: + * (XRES + LEFT_M + RIGHT_M + HSYNC_LEN) * + * (YRES + UPPER_M + LOWER_M + VSYNC_LEN) * REFRESH) + * see: + * https://community.freescale.com/thread/308170 + */ + ipu_set_ldb_clock(28341000); + + reg = readl(&ccm->cs2cdr); + + /* select pll 5 clock */ + reg &= ~(MXC_CCM_CS2CDR_LDB_DI0_CLK_SEL_MASK + | MXC_CCM_CS2CDR_LDB_DI1_CLK_SEL_MASK); + writel(reg, &ccm->cs2cdr); + + /* set PLL5 to 197994996Hz */ + reg &= ~BM_ANADIG_PLL_VIDEO_DIV_SELECT; + reg |= BF_ANADIG_PLL_VIDEO_DIV_SELECT(0x21); + reg &= ~BM_ANADIG_PLL_VIDEO_POST_DIV_SELECT; + reg |= BF_ANADIG_PLL_VIDEO_POST_DIV_SELECT(0); + writel(reg, &ccm->analog_pll_video); + + writel(BF_ANADIG_PLL_VIDEO_NUM_A(0xfbf4), + &ccm->analog_pll_video_num); + writel(BF_ANADIG_PLL_VIDEO_DENOM_B(0xf4240), + &ccm->analog_pll_video_denom); + + reg &= ~BM_ANADIG_PLL_VIDEO_POWERDOWN; + writel(reg, &ccm->analog_pll_video); + + while (timeout--) + if (readl(&ccm->analog_pll_video) & BM_ANADIG_PLL_VIDEO_LOCK) + break; + if (timeout < 0) + printf("Warning: video pll lock timeout!\n"); + + reg = readl(&ccm->analog_pll_video); + reg |= BM_ANADIG_PLL_VIDEO_ENABLE; + reg &= ~BM_ANADIG_PLL_VIDEO_BYPASS; + writel(reg, &ccm->analog_pll_video); + + /* set LDB0, LDB1 clk select to 000/000 (PLL5 clock) */ + reg = readl(&ccm->cs2cdr); + reg &= ~(MXC_CCM_CS2CDR_LDB_DI0_CLK_SEL_MASK + | MXC_CCM_CS2CDR_LDB_DI1_CLK_SEL_MASK); + reg |= (0 << MXC_CCM_CS2CDR_LDB_DI0_CLK_SEL_OFFSET) + | (0 << MXC_CCM_CS2CDR_LDB_DI1_CLK_SEL_OFFSET); + writel(reg, &ccm->cs2cdr); + + reg = readl(&ccm->cscmr2); + reg |= MXC_CCM_CSCMR2_LDB_DI0_IPU_DIV; + writel(reg, &ccm->cscmr2); + + reg = readl(&ccm->chsccdr); + reg |= (CHSCCDR_CLK_SEL_LDB_DI0 + << MXC_CCM_CHSCCDR_IPU1_DI0_CLK_SEL_OFFSET); + reg &= ~MXC_CCM_CHSCCDR_IPU1_DI0_PODF_MASK; + reg |= (2 << MXC_CCM_CHSCCDR_IPU1_DI0_PODF_OFFSET); + reg &= ~MXC_CCM_CHSCCDR_IPU1_DI0_PRE_CLK_SEL_MASK; + reg |= (2 << MXC_CCM_CHSCCDR_IPU1_DI0_PRE_CLK_SEL_OFFSET); + writel(reg, &ccm->chsccdr); + + reg = IOMUXC_GPR2_BGREF_RRMODE_EXTERNAL_RES + | IOMUXC_GPR2_DI1_VS_POLARITY_ACTIVE_HIGH + | IOMUXC_GPR2_DI0_VS_POLARITY_ACTIVE_HIGH + | IOMUXC_GPR2_BIT_MAPPING_CH0_SPWG + | IOMUXC_GPR2_DATA_WIDTH_CH0_24BIT + | IOMUXC_GPR2_LVDS_CH1_MODE_DISABLED + | IOMUXC_GPR2_LVDS_CH0_MODE_ENABLED_DI0; + writel(reg, &iomux->gpr[2]); + + reg = readl(&iomux->gpr[3]); + reg = (reg & ~IOMUXC_GPR3_LVDS0_MUX_CTL_MASK) + | (IOMUXC_GPR3_MUX_SRC_IPU1_DI0 + << IOMUXC_GPR3_LVDS0_MUX_CTL_OFFSET); + writel(reg, &iomux->gpr[3]); + + imx_iomux_v3_setup_multiple_pads( + display_pads, + ARRAY_SIZE(display_pads)); + + return; +} + +struct display_info_t const displays[] = {{ + .bus = -1, + .addr = 0, + .pixfmt = IPU_PIX_FMT_RGB24, + .detect = NULL, + .enable = enable_lvds, + .mode = { + .name = "lb07wv8", + .refresh = 60, + .xres = 800, + .yres = 480, + .pixclock = 30066, + .left_margin = 88, + .right_margin = 88, + .upper_margin = 20, + .lower_margin = 20, + .hsync_len = 80, + .vsync_len = 5, + .sync = FB_SYNC_EXT, + .vmode = FB_VMODE_NONINTERLACED +} }, { + .bus = -1, + .addr = 0, + .pixfmt = IPU_PIX_FMT_RGB24, + .detect = NULL, + .enable = enable_spi_display, + .mode = { + .name = "lg4573", + .refresh = 60, + .xres = 480, + .yres = 800, + .pixclock = 37037, + .left_margin = 59, + .right_margin = 10, + .upper_margin = 15, + .lower_margin = 15, + .hsync_len = 10, + .vsync_len = 15, + .sync = FB_SYNC_EXT | FB_SYNC_HOR_HIGH_ACT | + FB_SYNC_VERT_HIGH_ACT, + .vmode = FB_VMODE_NONINTERLACED +} } }; +size_t display_count = ARRAY_SIZE(displays); + +static void setup_display(void) +{ + enable_ipu_clock(); + enable_display_power(); +} + +/* no console on this board */ +int board_cfb_skip(void) +{ + return 1; +} +#endif + +int board_early_init_f(void) +{ + setup_iomux_uart(); + setup_iomux_gpio(); + + gpio_direction_output(SOFT_RESET_GPIO, 1); + gpio_direction_output(SD2_DRIVER_ENABLE, 1); + +#if defined(CONFIG_VIDEO_IPUV3) + setup_display(); +#endif + return 0; +} + +iomux_v3_cfg_t nfc_pads[] = { + MX6_PAD_NANDF_CLE__NAND_CLE | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_ALE__NAND_ALE | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_WP_B__NAND_WP_B | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_RB0__NAND_READY_B | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_CS0__NAND_CE0_B | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_CS1__NAND_CE1_B | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_SD4_CMD__NAND_RE_B | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_SD4_CLK__NAND_WE_B | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_D0__NAND_DATA00 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_D1__NAND_DATA01 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_D2__NAND_DATA02 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_D3__NAND_DATA03 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_D4__NAND_DATA04 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_D5__NAND_DATA05 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_D6__NAND_DATA06 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_D7__NAND_DATA07 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_SD4_DAT0__NAND_DQS | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +static void setup_gpmi_nand(void) +{ + struct mxc_ccm_reg *mxc_ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; + + /* config gpmi nand iomux */ + imx_iomux_v3_setup_multiple_pads(nfc_pads, + ARRAY_SIZE(nfc_pads)); + + /* gate ENFC_CLK_ROOT clock first,before clk source switch */ + clrbits_le32(&mxc_ccm->CCGR2, MXC_CCM_CCGR2_IOMUX_IPT_CLK_IO_MASK); + + /* config gpmi and bch clock to 100 MHz */ + clrsetbits_le32(&mxc_ccm->cs2cdr, + MXC_CCM_CS2CDR_ENFC_CLK_PODF_MASK | + MXC_CCM_CS2CDR_ENFC_CLK_PRED_MASK | + MXC_CCM_CS2CDR_ENFC_CLK_SEL_MASK, + MXC_CCM_CS2CDR_ENFC_CLK_PODF(0) | + MXC_CCM_CS2CDR_ENFC_CLK_PRED(3) | + MXC_CCM_CS2CDR_ENFC_CLK_SEL(3)); + + /* enable ENFC_CLK_ROOT clock */ + setbits_le32(&mxc_ccm->CCGR2, MXC_CCM_CCGR2_IOMUX_IPT_CLK_IO_MASK); + + /* enable gpmi and bch clock gating */ + setbits_le32(&mxc_ccm->CCGR4, + MXC_CCM_CCGR4_RAWNAND_U_BCH_INPUT_APB_MASK | + MXC_CCM_CCGR4_RAWNAND_U_GPMI_BCH_INPUT_BCH_MASK | + MXC_CCM_CCGR4_RAWNAND_U_GPMI_BCH_INPUT_GPMI_IO_MASK | + MXC_CCM_CCGR4_RAWNAND_U_GPMI_INPUT_APB_MASK | + MXC_CCM_CCGR4_PL301_MX6QPER1_BCH_OFFSET); + + /* enable apbh clock gating */ + setbits_le32(&mxc_ccm->CCGR0, MXC_CCM_CCGR0_APBHDMA_MASK); +} + +int board_init(void) +{ + struct iomuxc *iomux = (struct iomuxc *)IOMUXC_BASE_ADDR; + + /* address of boot parameters */ + gd->bd->bi_boot_params = PHYS_SDRAM + 0x100; + + setup_spi(); + + setup_i2c(0, CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE, + &i2c_pad_info1); + setup_i2c(1, CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE, + &i2c_pad_info2); + setup_i2c(2, CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE, + &i2c_pad_info3); + setup_i2c(3, CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE, + &i2c_pad_info4); + + /* SPI NOR Flash read only */ + gpio_request(CONFIG_GPIO_ENABLE_SPI_FLASH, "ena_spi_nor"); + gpio_direction_output(CONFIG_GPIO_ENABLE_SPI_FLASH, 0); + gpio_free(CONFIG_GPIO_ENABLE_SPI_FLASH); + + /* enable all LEDs */ + gpio_request(IMX_GPIO_NR(2, 13), "LED ena"); /* 25 */ + gpio_direction_output(IMX_GPIO_NR(1, 25), 0); + + /* switch off Status LEDs */ + gpio_request(IMX_GPIO_NR(6, 16), "LED yellow"); /* 176 */ + gpio_direction_output(IMX_GPIO_NR(6, 16), 1); + gpio_request(IMX_GPIO_NR(2, 28), "LED red"); /* 60 */ + gpio_direction_output(IMX_GPIO_NR(2, 28), 1); + gpio_request(IMX_GPIO_NR(5, 4), "LED green"); /* 132 */ + gpio_direction_output(IMX_GPIO_NR(5, 4), 1); + gpio_request(IMX_GPIO_NR(2, 29), "LED blue"); /* 61 */ + gpio_direction_output(IMX_GPIO_NR(2, 29), 1); + + setup_gpmi_nand(); + + /* ENET_RX_ER for USB_OTG_ID */ + clrsetbits_le32(&iomux->gpr[1], IOMUXC_GPR1_USB_OTG_ID_SEL_MASK, 0); + imx_iomux_v3_setup_multiple_pads(misc_pads, ARRAY_SIZE(misc_pads)); + + /* enable spi bus #2 SS drivers */ + gpio_direction_output(IMX_GPIO_NR(6, 6), 1); + + return 0; +} + +int board_late_init(void) +{ + char *my_bootdelay; + char bootmode = 0; + char const *panel = getenv("panel"); + + /* + * Check the boot-source. If booting from NOR Flash, + * disable bootdelay + */ + gpio_request(IMX_GPIO_NR(7, 6), "bootsel0"); + gpio_direction_input(IMX_GPIO_NR(7, 6)); + gpio_request(IMX_GPIO_NR(7, 7), "bootsel1"); + gpio_direction_input(IMX_GPIO_NR(7, 7)); + gpio_request(IMX_GPIO_NR(7, 1), "bootsel2"); + gpio_direction_input(IMX_GPIO_NR(7, 1)); + bootmode |= (gpio_get_value(IMX_GPIO_NR(7, 6)) ? 1 : 0) << 0; + bootmode |= (gpio_get_value(IMX_GPIO_NR(7, 7)) ? 1 : 0) << 1; + bootmode |= (gpio_get_value(IMX_GPIO_NR(7, 1)) ? 1 : 0) << 2; + + if (bootmode == 7) { + my_bootdelay = getenv("nor_bootdelay"); + if (my_bootdelay != NULL) + setenv("bootdelay", my_bootdelay); + else + setenv("bootdelay", "-2"); + } + + /* if we have the lg panel, we can initialze it now */ + if (panel) + if (!strcmp(panel, displays[1].mode.name)) + lg4573_spi_startup(0, 0, 10000000, SPI_MODE_0); + + return 0; +} + +int checkboard(void) +{ + puts("Board: aristaitenos2\n"); + return 0; +} + +#ifdef CONFIG_USB_EHCI_MX6 +int board_ehci_hcd_init(int port) +{ + int ret; + + ret = gpio_request(ARISTAINETOS2_USB_H1_PWR, "usb-h1-pwr"); + if (!ret) + gpio_direction_output(ARISTAINETOS2_USB_H1_PWR, 1); + ret = gpio_request(ARISTAINETOS2_USB_OTG_PWR, "usb-OTG-pwr"); + if (!ret) + gpio_direction_output(ARISTAINETOS2_USB_OTG_PWR, 1); + return 0; +} + +int board_ehci_power(int port, int on) +{ + if (port) + gpio_set_value(ARISTAINETOS2_USB_OTG_PWR, on); + else + gpio_set_value(ARISTAINETOS2_USB_H1_PWR, on); + return 0; +} +#endif diff --git a/board/aristainetos2/aristainetos2.cfg b/board/aristainetos2/aristainetos2.cfg new file mode 100644 index 0000000..a66bc1c --- /dev/null +++ b/board/aristainetos2/aristainetos2.cfg @@ -0,0 +1,34 @@ +/* + * (C) Copyright 2014 + * Heiko Schocher, DENX Software Engineering, hs@denx.de. + * + * Based on: + * Copyright (C) 2013 Boundary Devices + * + * SPDX-License-Identifier: GPL-2.0+ + * + * Refer doc/README.imximage for more details about how-to configure + * and create imximage boot image + * + * The syntax is taken as close as possible with the kwbimage + */ + +/* image version */ +IMAGE_VERSION 2 + +/* + * Boot Device : one of + * spi, sd + */ +BOOT_FROM spi + +#define __ASSEMBLY__ +#include <config.h> +#include "asm/arch/mx6-ddr.h" +#include "asm/arch/iomux.h" +#include "asm/arch/crm_regs.h" + +#include "ddr-setup.cfg" +#include "nt5cc256m16cp.cfg" +#include "clocks.cfg" +#include "axi.cfg" diff --git a/board/aristainetos2/axi.cfg b/board/aristainetos2/axi.cfg new file mode 100644 index 0000000..0bb816c --- /dev/null +++ b/board/aristainetos2/axi.cfg @@ -0,0 +1,22 @@ +/* + * Copyright (C) 2013 Boundary Devices + * + * SPDX-License-Identifier: GPL-2.0+ + * + * Device Configuration Data (DCD) + * + * Each entry must have the format: + * Addr-type Address Value + * + * where: + * Addr-type register length (1,2 or 4 bytes) + * Address absolute address of the register + * value value to be stored in the register + */ + +/* enable AXI cache for VDOA/VPU/IPU */ +DATA 4, MX6_IOMUXC_GPR4, 0xF00000CF + +/* set IPU AXI-id0 Qos=0xf(bypass) AXI-id1 Qos=0x7 */ +DATA 4, MX6_IOMUXC_GPR6, 0x007F007F +DATA 4, MX6_IOMUXC_GPR7, 0x007F007F diff --git a/board/aristainetos2/clocks.cfg b/board/aristainetos2/clocks.cfg new file mode 100644 index 0000000..987d9a4 --- /dev/null +++ b/board/aristainetos2/clocks.cfg @@ -0,0 +1,24 @@ +/* + * Copyright (C) 2013 Boundary Devices + * + * SPDX-License-Identifier: GPL-2.0+ + * + * Device Configuration Data (DCD) + * + * Each entry must have the format: + * Addr-type Address Value + * + * where: + * Addr-type register length (1,2 or 4 bytes) + * Address absolute address of the register + * value value to be stored in the register + */ + +/* set the default clock gate to save power */ +DATA 4, CCM_CCGR0, 0x00c03f3f +DATA 4, CCM_CCGR1, 0x0030fcff +DATA 4, CCM_CCGR2, 0x0fffcfc0 +DATA 4, CCM_CCGR3, 0x3ff0300f +DATA 4, CCM_CCGR4, 0xfffff300 +DATA 4, CCM_CCGR5, 0x0f0000c3 +DATA 4, CCM_CCGR6, 0x00000fff diff --git a/board/aristainetos2/ddr-setup.cfg b/board/aristainetos2/ddr-setup.cfg new file mode 100644 index 0000000..3d5d894 --- /dev/null +++ b/board/aristainetos2/ddr-setup.cfg @@ -0,0 +1,59 @@ +/* + * Copyright (C) 2013 Boundary Devices + * + * SPDX-License-Identifier: GPL-2.0+ + * + * Device Configuration Data (DCD) + * + * Each entry must have the format: + * Addr-type Address Value + * + * where: + * Addr-type register length (1,2 or 4 bytes) + * Address absolute address of the register + * value value to be stored in the register + */ + +/* DDR IO TYPE */ +DATA 4, MX6_IOM_GRP_DDR_TYPE, 0x000C0000 +DATA 4, MX6_IOM_GRP_DDRPKE, 0x00000000 +/* Clock */ +DATA 4, MX6_IOM_DRAM_SDCLK_0, 0x00000030 +DATA 4, MX6_IOM_DRAM_SDCLK_1, 0x00000030 +/* Address */ +DATA 4, MX6_IOM_DRAM_CAS, 0x00000030 +DATA 4, MX6_IOM_DRAM_RAS, 0x00000030 +DATA 4, MX6_IOM_GRP_ADDDS, 0x00000030 +/* Control */ +DATA 4, MX6_IOM_DRAM_RESET, 0x00000030 +DATA 4, MX6_IOM_DRAM_SDBA2, 0x00000000 +DATA 4, MX6_IOM_DRAM_SDODT0, 0x00000030 +DATA 4, MX6_IOM_DRAM_SDODT1, 0x00000030 +DATA 4, MX6_IOM_GRP_CTLDS, 0x00000030 +/* Data Strobe */ +DATA 4, MX6_IOM_DDRMODE_CTL, 0x00020000 +DATA 4, MX6_IOM_DRAM_SDQS0, 0x00000028 +DATA 4, MX6_IOM_DRAM_SDQS1, 0x00000028 +DATA 4, MX6_IOM_DRAM_SDQS2, 0x00000028 +DATA 4, MX6_IOM_DRAM_SDQS3, 0x00000028 +DATA 4, MX6_IOM_DRAM_SDQS4, 0x00000028 +DATA 4, MX6_IOM_DRAM_SDQS5, 0x00000028 +DATA 4, MX6_IOM_DRAM_SDQS6, 0x00000028 +DATA 4, MX6_IOM_DRAM_SDQS7, 0x00000028 +DATA 4, MX6_IOM_GRP_DDRMODE, 0x00020000 +DATA 4, MX6_IOM_GRP_B0DS, 0x00000028 +DATA 4, MX6_IOM_GRP_B1DS, 0x00000028 +DATA 4, MX6_IOM_GRP_B2DS, 0x00000028 +DATA 4, MX6_IOM_GRP_B3DS, 0x00000028 +DATA 4, MX6_IOM_GRP_B4DS, 0x00000028 +DATA 4, MX6_IOM_GRP_B5DS, 0x00000028 +DATA 4, MX6_IOM_GRP_B6DS, 0x00000028 +DATA 4, MX6_IOM_GRP_B7DS, 0x00000028 +DATA 4, MX6_IOM_DRAM_DQM0, 0x00000028 +DATA 4, MX6_IOM_DRAM_DQM1, 0x00000028 +DATA 4, MX6_IOM_DRAM_DQM2, 0x00000028 +DATA 4, MX6_IOM_DRAM_DQM3, 0x00000028 +DATA 4, MX6_IOM_DRAM_DQM4, 0x00000028 +DATA 4, MX6_IOM_DRAM_DQM5, 0x00000028 +DATA 4, MX6_IOM_DRAM_DQM6, 0x00000028 +DATA 4, MX6_IOM_DRAM_DQM7, 0x00000028 diff --git a/board/aristainetos2/nt5cc256m16cp.cfg b/board/aristainetos2/nt5cc256m16cp.cfg new file mode 100644 index 0000000..2ff41e9 --- /dev/null +++ b/board/aristainetos2/nt5cc256m16cp.cfg @@ -0,0 +1,60 @@ +/* + * Copyright (C) 2013 Boundary Devices + * + * SPDX-License-Identifier: GPL-2.0+ + */ +/* ZQ Calibration */ +DATA 4, MX6_MMDC_P0_MPZQHWCTRL, 0xa1390003 +DATA 4, MX6_MMDC_P0_MPWLDECTRL0, 0x001F001F +DATA 4, MX6_MMDC_P0_MPWLDECTRL1, 0x001F001F +DATA 4, MX6_MMDC_P1_MPWLDECTRL0, 0x001F001F +DATA 4, MX6_MMDC_P1_MPWLDECTRL1, 0x001F001F +/* + * DQS gating, read delay, write delay calibration values + */ +DATA 4, MX6_MMDC_P0_MPDGCTRL0, 0x42190217 +DATA 4, MX6_MMDC_P0_MPDGCTRL1, 0x017B017B +DATA 4, MX6_MMDC_P1_MPDGCTRL0, 0x4176017B +DATA 4, MX6_MMDC_P1_MPDGCTRL1, 0x015F016C +DATA 4, MX6_MMDC_P0_MPRDDLCTL, 0x4C4C4D4C +DATA 4, MX6_MMDC_P1_MPRDDLCTL, 0x4A4D4C48 +DATA 4, MX6_MMDC_P0_MPWRDLCTL, 0x3F3F3F40 +DATA 4, MX6_MMDC_P1_MPWRDLCTL, 0x3538382E +/* read data bit delay */ +DATA 4, MX6_MMDC_P0_MPRDDQBY0DL, 0x33333333 +DATA 4, MX6_MMDC_P0_MPRDDQBY1DL, 0x33333333 +DATA 4, MX6_MMDC_P0_MPRDDQBY2DL, 0x33333333 +DATA 4, MX6_MMDC_P0_MPRDDQBY3DL, 0x33333333 +DATA 4, MX6_MMDC_P1_MPRDDQBY0DL, 0x33333333 +DATA 4, MX6_MMDC_P1_MPRDDQBY1DL, 0x33333333 +DATA 4, MX6_MMDC_P1_MPRDDQBY2DL, 0x33333333 +DATA 4, MX6_MMDC_P1_MPRDDQBY3DL, 0x33333333 +/* Complete calibration by forced measurment */ +DATA 4, MX6_MMDC_P0_MPMUR0, 0x00000800 +DATA 4, MX6_MMDC_P1_MPMUR0, 0x00000800 +/* in DDR3, 64-bit mode, only MMDC0 is initiated */ +DATA 4, MX6_MMDC_P0_MDPDC, 0x00020025 +DATA 4, MX6_MMDC_P0_MDOTC, 0x00333030 +DATA 4, MX6_MMDC_P0_MDCFG0, 0x676B5313 +DATA 4, MX6_MMDC_P0_MDCFG1, 0xB66E8B63 +DATA 4, MX6_MMDC_P0_MDCFG2, 0x01FF00DB +DATA 4, MX6_MMDC_P0_MDMISC, 0x00001740 +DATA 4, MX6_MMDC_P0_MDSCR, 0x00008000 +DATA 4, MX6_MMDC_P0_MDRWD, 0x000026d2 +DATA 4, MX6_MMDC_P0_MDOR, 0x006B1023 +DATA 4, MX6_MMDC_P0_MDASP, 0x00000027 +DATA 4, MX6_MMDC_P0_MDCTL, 0x84190000 + +DATA 4, MX6_MMDC_P0_MDSCR, 0x04008032 +DATA 4, MX6_MMDC_P0_MDSCR, 0x00008033 +DATA 4, MX6_MMDC_P0_MDSCR, 0x00048031 +DATA 4, MX6_MMDC_P0_MDSCR, 0x05208030 +DATA 4, MX6_MMDC_P0_MDSCR, 0x04008040 + +/* final ddr setup */ +DATA 4, MX6_MMDC_P0_MDREF, 0x00005800 +DATA 4, MX6_MMDC_P0_MPODTCTRL, 0x00011117 +DATA 4, MX6_MMDC_P1_MPODTCTRL, 0x00011117 +DATA 4, MX6_MMDC_P0_MDPDC, 0x00025565 +DATA 4, MX6_MMDC_P0_MAPSR, 0x00011006 +DATA 4, MX6_MMDC_P0_MDSCR, 0x00000000 diff --git a/configs/aristainetos2_defconfig b/configs/aristainetos2_defconfig new file mode 100644 index 0000000..26292fd --- /dev/null +++ b/configs/aristainetos2_defconfig @@ -0,0 +1,3 @@ +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/aristainetos2/aristainetos2.cfg,MX6DL" +CONFIG_ARM=y +CONFIG_TARGET_ARISTAINETOS2=y diff --git a/include/configs/aristainetos2.h b/include/configs/aristainetos2.h new file mode 100644 index 0000000..3c1203b --- /dev/null +++ b/include/configs/aristainetos2.h @@ -0,0 +1,352 @@ +/* + * (C) Copyright 2015 + * Heiko Schocher, DENX Software Engineering, hs@denx.de. + * + * Based on: + * Copyright (C) 2012 Freescale Semiconductor, Inc. + * + * Configuration settings for the Freescale i.MX6DL aristainetos2 board. + * + * SPDX-License-Identifier: GPL-2.0+ + */ +#ifndef __ARISTAINETOS2_CONFIG_H +#define __ARISTAINETOS2_CONFIG_H + +#define CONFIG_MX6 + +#include "mx6_common.h" +#include <linux/sizes.h> + +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DISPLAY_BOARDINFO + +#include <asm/arch/imx-regs.h> +#include <asm/imx-common/gpio.h> + +#define CONFIG_MACH_TYPE 4501 +#define CONFIG_MMCROOT "/dev/mmcblk0p1" +#define CONFIG_HOSTNAME aristainetos2 +#define PHYS_SDRAM_SIZE (1u * 1024 * 1024 * 1024) + +#define CONFIG_SYS_GENERIC_BOARD + +/* Size of malloc() pool */ +#define CONFIG_SYS_MALLOC_LEN (64 * SZ_1M) + +#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_BOARD_LATE_INIT +#define CONFIG_MXC_GPIO + +#define CONFIG_MXC_UART +#define CONFIG_MXC_UART_BASE UART2_BASE +#define CONFIG_CONSOLE_DEV "ttymxc1" + +#define CONFIG_CMD_FUSE +#define CONFIG_MXC_OCOTP + +/* MMC Configs */ +#define CONFIG_FSL_ESDHC +#define CONFIG_FSL_USDHC +#define CONFIG_SYS_FSL_ESDHC_ADDR 0 + +#define CONFIG_MMC +#define CONFIG_CMD_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_BOUNCE_BUFFER +#define CONFIG_CMD_EXT2 +#define CONFIG_CMD_FAT +#define CONFIG_DOS_PARTITION + +#define CONFIG_CMD_PING +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_MII +#define CONFIG_CMD_NET +#define CONFIG_FEC_MXC +#define CONFIG_MII +#define IMX_FEC_BASE ENET_BASE_ADDR +#define CONFIG_FEC_XCV_TYPE RGMII +#define CONFIG_ETHPRIME "FEC" +#define CONFIG_FEC_MXC_PHYADDR 0 +#define CONFIG_PHYLIB +#define CONFIG_PHY_MICREL +#define CONFIG_PHY_MICREL_KSZ9031 + +#define CONFIG_CMD_SF +#define CONFIG_SPI_FLASH +#define CONFIG_SPI_FLASH_MTD +#define CONFIG_SPI_FLASH_STMICRO +#define CONFIG_MXC_SPI +#define CONFIG_SF_DEFAULT_BUS 3 +#define CONFIG_SF_DEFAULT_CS 1 +#define CONFIG_SF_DEFAULT_SPEED 20000000 +#define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 +#define CONFIG_SYS_SPI_ST_ENABLE_WP_PIN + +/* allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE +#define CONFIG_CONS_INDEX 1 +#define CONFIG_BAUDRATE 115200 + +/* Command definition */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_BMODE +#define CONFIG_CMD_BOOTZ +#define CONFIG_CMD_SETEXPR +#undef CONFIG_CMD_IMLS + +#define CONFIG_BOOTDELAY 3 + +#define CONFIG_LOADADDR 0x12000000 +#define CONFIG_SYS_TEXT_BASE 0x17800000 + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "script=u-boot.scr\0" \ + "fit_file=/boot/system.itb\0" \ + "loadaddr=0x12000000\0" \ + "fit_addr_r=0x14000000\0" \ + "uboot=/boot/u-boot.imx\0" \ + "uboot_sz=d0000\0" \ + "rescue_sys_addr=f0000\0" \ + "rescue_sys_length=f10000\0" \ + "board_type=aristainetos2_7@1\0" \ + "panel=lb07wv8\0" \ + "splashpos=m,m\0" \ + "console=" CONFIG_CONSOLE_DEV "\0" \ + "nor_bootdelay=-2\0" \ + "fdt_high=0xffffffff\0" \ + "initrd_high=0xffffffff\0" \ + "mtdids=nand0=gpmi-nand,nor0=spi3.1\0" \ + "mtdparts=mtdparts=spi3.1:832k(u-boot),64k(env),64k(env-red)," \ + "-(rescue-system);gpmi-nand:-(ubi)\0" \ + "addmisc=setenv bootargs ${bootargs} net.ifnames=0 consoleblank=0\0" \ + "addmtd=setenv bootargs ${bootargs} ${mtdparts}\0" \ + "set_fit_default=fdt addr ${fit_addr_r};fdt set /configurations " \ + "default ${board_type}\0" \ + "get_env=mw ${loadaddr} 0 0x20000;" \ + "mmc rescan;" \ + "ext2load mmc ${mmcdev}:${mmcpart} ${loadaddr} env.txt;" \ + "env import -t ${loadaddr}\0" \ + "default_env=mw ${loadaddr} 0 0x20000;" \ + "env export -t ${loadaddr} serial# ethaddr eth1addr " \ + "board_type panel;" \ + "env default -a;" \ + "env import -t ${loadaddr}\0" \ + "loadbootscript=" \ + "ext2load mmc ${mmcdev}:${mmcpart} ${loadaddr} ${script};\0" \ + "bootscript=echo Running bootscript from mmc ...; " \ + "source\0" \ + "mmcpart=1\0" \ + "mmcdev=0\0" \ + "mmcroot=" CONFIG_MMCROOT " rootwait rw\0" \ + "mmcargs=setenv bootargs console=${console},${baudrate} " \ + "root=${mmcroot}\0" \ + "mmcboot=echo Booting from mmc ...; " \ + "run mmcargs addmtd addmisc set_fit_default;" \ + "bootm ${fit_addr_r}\0" \ + "mmc_load_fit=ext2load mmc ${mmcdev}:${mmcpart} ${fit_addr_r} " \ + "${fit_file}\0" \ + "mmc_load_uboot=ext2load mmc ${mmcdev}:${mmcpart} ${loadaddr} " \ + "${uboot}\0" \ + "mmc_upd_uboot=mw.b ${loadaddr} 0xff ${uboot_sz};" \ + "setexpr cmp_buf ${loadaddr} + ${uboot_sz};" \ + "setexpr uboot_maxsize ${uboot_sz} - 400;" \ + "mw.b ${cmp_buf} 0x00 ${uboot_sz};" \ + "run mmc_load_uboot;sf probe;sf erase 0 ${uboot_sz};" \ + "sf write ${loadaddr} 400 ${filesize};" \ + "sf read ${cmp_buf} 400 ${uboot_sz};" \ + "cmp.b ${loadaddr} ${cmp_buf} ${uboot_maxsize}\0" \ + "ubiargs=setenv bootargs console=${console},${baudrate} " \ + "ubi.mtd=0,4096 root=ubi0:rootfs rootfstype=ubifs\0 " \ + "ubiboot=echo Booting from ubi ...; " \ + "run ubiargs addmtd addmisc set_fit_default;" \ + "bootm ${fit_addr_r}\0" \ + "ubifs_load_fit=sf probe;ubi part ubi 4096;ubifsmount ubi:rootfs;" \ + "ubifsload ${fit_addr_r} /boot/system.itb; " \ + "imi ${fit_addr_r}\0 " \ + "rescueargs=setenv bootargs console=${console},${baudrate} " \ + "root=/dev/ram rw\0 " \ + "rescueboot=echo Booting rescue system from NOR ...; " \ + "run rescueargs addmtd addmisc set_fit_default;" \ + "bootm ${fit_addr_r}\0" \ + "rescue_load_fit=sf probe;sf read ${fit_addr_r} ${rescue_sys_addr} " \ + "${rescue_sys_length}; imi ${fit_addr_r}\0 " + + +#define CONFIG_BOOTCOMMAND \ + "mmc dev ${mmcdev};" \ + "if mmc rescan; then " \ + "if run loadbootscript; then " \ + "run bootscript; " \ + "else " \ + "if run mmc_load_fit; then " \ + "run mmcboot; " \ + "else " \ + "if run ubifs_load_fit; then " \ + "run ubiboot; " \ + "else " \ + "if run rescue_load_fit; then " \ + "run rescueboot; " \ + "else " \ + "echo RESCUE SYSTEM BOOT " \ + "FAILURE;" \ + "fi; " \ + "fi; " \ + "fi; " \ + "fi; " \ + "else " \ + "if run ubifs_load_fit; then " \ + "run ubiboot; " \ + "else " \ + "if run rescue_load_fit; then " \ + "run rescueboot; " \ + "else " \ + "echo RESCUE SYSTEM BOOT FAILURE;" \ + "fi; " \ + "fi; " \ + "fi" + +#define CONFIG_ARP_TIMEOUT 200UL + +/* Miscellaneous configurable options */ +#define CONFIG_SYS_LONGHELP +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " +#define CONFIG_AUTO_COMPLETE +#define CONFIG_SYS_CBSIZE 256 + +/* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE + +#define CONFIG_SYS_MEMTEST_START PHYS_SDRAM +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + 0x100000) +#define CONFIG_SYS_MEMTEST_SCRATCH 0x10800000 + +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR + +#define CONFIG_CMDLINE_EDITING +#define CONFIG_STACKSIZE (128 * 1024) + +/* Physical Memory Map */ +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM MMDC0_ARB_BASE_ADDR + +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM +#define CONFIG_SYS_INIT_RAM_ADDR IRAM_BASE_ADDR +#define CONFIG_SYS_INIT_RAM_SIZE IRAM_SIZE + +#define CONFIG_SYS_INIT_SP_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) + +/* FLASH and environment organization */ +#define CONFIG_SYS_NO_FLASH + +#define CONFIG_ENV_SIZE (12 * 1024) +#define CONFIG_ENV_IS_IN_SPI_FLASH +#define CONFIG_SYS_REDUNDAND_ENVIRONMENT +#define CONFIG_ENV_SPI_BUS CONFIG_SF_DEFAULT_BUS +#define CONFIG_ENV_SPI_CS CONFIG_SF_DEFAULT_CS +#define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED +#define CONFIG_ENV_SPI_MODE CONFIG_SF_DEFAULT_MODE +#define CONFIG_ENV_SECT_SIZE (0x010000) +#define CONFIG_ENV_OFFSET (0x0d0000) +#define CONFIG_ENV_OFFSET_REDUND (0x0e0000) + +#define CONFIG_OF_LIBFDT + +#define CONFIG_CMD_CACHE + +#define CONFIG_SYS_FSL_USDHC_NUM 2 + +#define CONFIG_CMD_I2C +#define CONFIG_SYS_I2C +#define CONFIG_SYS_I2C_MXC +#define CONFIG_SYS_I2C_MXC_I2C3 /* enable I2C bus 3 */ +#define CONFIG_SYS_I2C_MXC_I2C4 /* enable I2C bus 4 */ +#define CONFIG_SYS_I2C_SPEED 100000 +#define CONFIG_SYS_I2C_SLAVE 0x7f +#define CONFIG_SYS_I2C_NOPROBES { {0, 0x00} } + +#define CONFIG_CMD_GPIO +#define CONFIG_GPIO_ENABLE_SPI_FLASH IMX_GPIO_NR(2, 15) + +/* NAND stuff */ +#define CONFIG_CMD_NAND +#define CONFIG_CMD_NAND_TRIMFFS +#define CONFIG_NAND_MXS +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_SYS_NAND_BASE 0x40000000 +#define CONFIG_SYS_NAND_5_ADDR_CYCLE +#define CONFIG_SYS_NAND_ONFI_DETECTION + +/* DMA stuff, needed for GPMI/MXS NAND support */ +#define CONFIG_APBH_DMA +#define CONFIG_APBH_DMA_BURST +#define CONFIG_APBH_DMA_BURST8 + +/* RTC */ +#define CONFIG_SYS_I2C_RTC_ADDR 0x68 +#define CONFIG_SYS_RTC_BUS_NUM 2 +#define CONFIG_RTC_M41T11 +#define CONFIG_CMD_DATE + +/* USB Configs */ +#define CONFIG_CMD_USB +#define CONFIG_CMD_FAT +#define CONFIG_USB_EHCI +#define CONFIG_USB_EHCI_MX6 +#define CONFIG_USB_STORAGE +#define CONFIG_USB_MAX_CONTROLLER_COUNT 2 +#define CONFIG_EHCI_HCD_INIT_AFTER_RESET /* For OTG port */ +#define CONFIG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) +#define CONFIG_MXC_USB_FLAGS 0 + +#define ARISTAINETOS2_USB_OTG_PWR IMX_GPIO_NR(4, 15) +#define ARISTAINETOS2_USB_H1_PWR IMX_GPIO_NR(1, 0) + +/* UBI support */ +#define CONFIG_CMD_MTDPARTS +#define CONFIG_MTD_PARTITIONS +#define CONFIG_MTD_DEVICE +#define CONFIG_RBTREE +#define CONFIG_LZO +#define CONFIG_CMD_UBI +#define CONFIG_CMD_UBIFS + +#define CONFIG_MTD_UBI_FASTMAP +#define CONFIG_MTD_UBI_FASTMAP_AUTOCONVERT 1 + +#define CONFIG_HW_WATCHDOG +#define CONFIG_IMX_WATCHDOG + +#define CONFIG_FIT + +/* Framebuffer */ +#define CONFIG_VIDEO +#define CONFIG_VIDEO_IPUV3 +/* check this console not needed, after test remove it */ +#define CONFIG_CFB_CONSOLE +#define CONFIG_VGA_AS_SINGLE_DEVICE +#define CONFIG_SYS_CONSOLE_IS_IN_ENV +#define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE +#define CONFIG_VIDEO_BMP_RLE8 +#define CONFIG_SPLASH_SCREEN +#define CONFIG_SPLASH_SCREEN_ALIGN +#define CONFIG_BMP_16BPP +#define CONFIG_VIDEO_LOGO +#define CONFIG_VIDEO_BMP_LOGO +#define CONFIG_IPUV3_CLK 198000000 +#define CONFIG_IMX_VIDEO_SKIP +#define CONFIG_SYS_LDB_CLOCK 33246000 +#define CONFIG_LG4573 + +#define CONFIG_CMD_BMP + +#define CONFIG_PWM_IMX +#define CONFIG_IMX6_PWM_PER_CLK 66000000 + +#endif /* __ARISTAINETOS2_CONFIG_H */
Hi Heiko,
I am looking into the aristainetos board and I am figuring out how the DL version can be integrated. I dislike that a lot of code is duplicated.
Currently, we are able to detect the cpu at run time with the accessor is_cpu_type(). They can be used to switch between different sets of pinmuxes - even having a common binary for both boards is possible. Take a look for example at the gw_ventana board.
Changes in v2:
- bool "Support aristainetos2"
- select CPU_V7
+config SYS_BOARD
- default "aristainetos2"
+config SYS_SOC
- default "mx6"
- (C) Copyright 2015
- Heiko Schocher, DENX Software Engineering, hs@denx.de.
- Based on:
- Copyright (C) 2012 Freescale Semiconductor, Inc.
- Author: Fabio Estevam fabio.estevam@freescale.com
- #include <bmp_logo.h>
- PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | \
- PAD_CTL_SRE_FAST | PAD_CTL_HYS)
- PAD_CTL_SPEED_LOW | PAD_CTL_DSE_80ohm | \
- PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST)
- PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | PAD_CTL_HYS)
- PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | PAD_CTL_HYS | \
- PAD_CTL_ODE | PAD_CTL_SRE_FAST)
- .scl = {
- .sda = {
This is in common with aristaneitos, as most of other setup. I know that offsets for imx6Q and imx6DL are different. I prefer the solution having two sets of them (MX6Q_PAD_CSI0_DAT9__I2C1_SCL against MX6DL_PAD_CSI0_DAT9__I2C1_SC), and detecting at runtim the cpu, the correct one is chosen and applied.
- .scl = {
- .sda = {
- .scl = {
- .sda = {
- .scl = {
- .sda = {
- gd->ram_size = get_ram_size((void *)PHYS_SDRAM, PHYS_SDRAM_SIZE);
- MX6_PAD_CSI0_DAT10__UART1_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL),
- MX6_PAD_CSI0_DAT11__UART1_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL),
- MX6_PAD_EIM_D19__UART1_CTS_B | MUX_PAD_CTRL(UART_PAD_CTRL),
- MX6_PAD_EIM_D20__UART1_RTS_B | MUX_PAD_CTRL(UART_PAD_CTRL),
For most pins except I2C, the solution is to use the IOMUX_PADS() macro. This works for both imx6q and imx6dl. You should have:
iomux_v3_cfg_t const uart1_pads[] = { IOMUX_PADS(PAD_CSI0_DAT10__UART1_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL)), ......
- MX6_PAD_EIM_D26__UART2_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL),
- MX6_PAD_EIM_D27__UART2_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL),
- MX6_PAD_EIM_D24__UART3_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL),
- MX6_PAD_EIM_D25__UART3_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL),
- MX6_PAD_EIM_D31__UART3_RTS_B | MUX_PAD_CTRL(UART_PAD_CTRL),
- MX6_PAD_EIM_D23__UART3_CTS_B | MUX_PAD_CTRL(UART_PAD_CTRL),
- MX6_PAD_KEY_COL0__UART4_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL),
- MX6_PAD_KEY_ROW0__UART4_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL),
The same here.
- /* LED enable*/
- MX6_PAD_ENET_CRS_DV__GPIO1_IO25 | MUX_PAD_CTRL(NO_PAD_CTRL),
- /* LED yellow */
- MX6_PAD_NANDF_CS3__GPIO6_IO16 | MUX_PAD_CTRL(NO_PAD_CTRL),
- /* LED red */
- MX6_PAD_EIM_EB0__GPIO2_IO28 | MUX_PAD_CTRL(NO_PAD_CTRL),
- /* LED green */
- MX6_PAD_EIM_A24__GPIO5_IO04 | MUX_PAD_CTRL(NO_PAD_CTRL),
- /* LED blue */
- MX6_PAD_EIM_EB1__GPIO2_IO29 | MUX_PAD_CTRL(NO_PAD_CTRL),
- /* spi flash WP protect */
- MX6_PAD_SD4_DAT7__GPIO2_IO15 | MUX_PAD_CTRL(NO_PAD_CTRL),
- /* spi CS 0 */
- MX6_PAD_EIM_D29__GPIO3_IO29 | MUX_PAD_CTRL(NO_PAD_CTRL),
- /* spi bus #2 SS driver enable */
- MX6_PAD_EIM_A23__GPIO6_IO06 | MUX_PAD_CTRL(NO_PAD_CTRL),
- /* RST_LOC# PHY reset input (has pull-down!)*/
- MX6_PAD_GPIO_18__GPIO7_IO13 | MUX_PAD_CTRL(NO_PAD_CTRL),
- /* SD 2 level shifter output enable */
- MX6_PAD_SD3_RST__GPIO7_IO08 | MUX_PAD_CTRL(NO_PAD_CTRL),
- /* SD1 card detect input */
- MX6_PAD_ENET_RXD0__GPIO1_IO27 | MUX_PAD_CTRL(NO_PAD_CTRL),
- /* SD1 write protect input */
- MX6_PAD_DI0_PIN4__GPIO4_IO20 | MUX_PAD_CTRL(NO_PAD_CTRL),
- /* SD2 card detect input */
- MX6_PAD_GPIO_19__GPIO4_IO05 | MUX_PAD_CTRL(NO_PAD_CTRL),
- /* SD2 write protect input */
- MX6_PAD_SD4_DAT2__GPIO2_IO10 | MUX_PAD_CTRL(NO_PAD_CTRL),
- /* Touchscreen IRQ */
- MX6_PAD_SD4_DAT1__GPIO2_IO09 | MUX_PAD_CTRL(NO_PAD_CTRL),
- /* USB_OTG_ID = GPIO1_24*/
- MX6_PAD_ENET_RX_ER__USB_OTG_ID | MUX_PAD_CTRL(NO_PAD_CTRL),
- /* H1 Power enable = GPIO1_0*/
- MX6_PAD_GPIO_0__USB_H1_PWR | MUX_PAD_CTRL(NO_PAD_CTRL),
- /* OTG Power enable = GPIO4_15*/
- MX6_PAD_KEY_ROW4__USB_OTG_PWR | MUX_PAD_CTRL(NO_PAD_CTRL),
- MX6_PAD_ENET_MDIO__ENET_MDIO | MUX_PAD_CTRL(ENET_PAD_CTRL),
- MX6_PAD_ENET_MDC__ENET_MDC | MUX_PAD_CTRL(ENET_PAD_CTRL),
- MX6_PAD_RGMII_TXC__RGMII_TXC | MUX_PAD_CTRL(ENET_PAD_CTRL),
- MX6_PAD_RGMII_TD0__RGMII_TD0 | MUX_PAD_CTRL(ENET_PAD_CTRL),
- MX6_PAD_RGMII_TD1__RGMII_TD1 | MUX_PAD_CTRL(ENET_PAD_CTRL),
- MX6_PAD_RGMII_TD2__RGMII_TD2 | MUX_PAD_CTRL(ENET_PAD_CTRL),
- MX6_PAD_RGMII_TD3__RGMII_TD3 | MUX_PAD_CTRL(ENET_PAD_CTRL),
- MX6_PAD_RGMII_TX_CTL__RGMII_TX_CTL | MUX_PAD_CTRL(ENET_PAD_CTRL),
- MX6_PAD_ENET_REF_CLK__ENET_TX_CLK | MUX_PAD_CTRL(ENET_PAD_CTRL),
- MX6_PAD_RGMII_RXC__RGMII_RXC | MUX_PAD_CTRL(ENET_PAD_CTRL),
- MX6_PAD_RGMII_RD0__RGMII_RD0 | MUX_PAD_CTRL(ENET_PAD_CTRL),
- MX6_PAD_RGMII_RD1__RGMII_RD1 | MUX_PAD_CTRL(ENET_PAD_CTRL),
- MX6_PAD_RGMII_RD2__RGMII_RD2 | MUX_PAD_CTRL(ENET_PAD_CTRL),
- MX6_PAD_RGMII_RD3__RGMII_RD3 | MUX_PAD_CTRL(ENET_PAD_CTRL),
- MX6_PAD_RGMII_RX_CTL__RGMII_RX_CTL | MUX_PAD_CTRL(ENET_PAD_CTRL),
- imx_iomux_v3_setup_multiple_pads(enet_pads, ARRAY_SIZE(enet_pads));
- MX6_PAD_SD1_CLK__SD1_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL),
- MX6_PAD_SD1_CMD__SD1_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL),
- MX6_PAD_SD1_DAT0__SD1_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL),
- MX6_PAD_SD1_DAT1__SD1_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL),
- MX6_PAD_SD1_DAT2__SD1_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL),
- MX6_PAD_SD1_DAT3__SD1_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL),
- MX6_PAD_SD2_CLK__SD2_CLK | MUX_PAD_CTRL(USDHC2_PAD_CTRL),
- MX6_PAD_SD2_CMD__SD2_CMD | MUX_PAD_CTRL(USDHC2_PAD_CTRL),
- MX6_PAD_SD2_DAT0__SD2_DATA0 | MUX_PAD_CTRL(USDHC2_PAD_CTRL),
- MX6_PAD_SD2_DAT1__SD2_DATA1 | MUX_PAD_CTRL(USDHC2_PAD_CTRL),
- MX6_PAD_SD2_DAT2__SD2_DATA2 | MUX_PAD_CTRL(USDHC2_PAD_CTRL),
- MX6_PAD_SD2_DAT3__SD2_DATA3 | MUX_PAD_CTRL(USDHC2_PAD_CTRL),
- MX6_PAD_SD3_RST__SD3_RESET | MUX_PAD_CTRL(USDHC_PAD_CTRL),
- MX6_PAD_EIM_D16__ECSPI1_SCLK | MUX_PAD_CTRL(SPI_PAD_CTRL),
- MX6_PAD_EIM_D17__ECSPI1_MISO | MUX_PAD_CTRL(SPI_PAD_CTRL),
- MX6_PAD_EIM_D18__ECSPI1_MOSI | MUX_PAD_CTRL(SPI_PAD_CTRL),
- MX6_PAD_KEY_ROW1__GPIO4_IO09 | MUX_PAD_CTRL(SPI_PAD_CTRL),
- MX6_PAD_EIM_D21__ECSPI4_SCLK | MUX_PAD_CTRL(SPI_PAD_CTRL),
- MX6_PAD_EIM_D22__ECSPI4_MISO | MUX_PAD_CTRL(SPI_PAD_CTRL),
- MX6_PAD_EIM_D28__ECSPI4_MOSI | MUX_PAD_CTRL(SPI_PAD_CTRL),
- MX6_PAD_EIM_A25__GPIO5_IO02 | MUX_PAD_CTRL(NO_PAD_CTRL),
- MX6_PAD_DI0_DISP_CLK__IPU1_DI0_DISP_CLK | MUX_PAD_CTRL(DISP_PAD_CTRL),
- MX6_PAD_DI0_PIN15__IPU1_DI0_PIN15,
- MX6_PAD_DI0_PIN2__IPU1_DI0_PIN02,
- MX6_PAD_DI0_PIN3__IPU1_DI0_PIN03,
- MX6_PAD_DISP0_DAT0__IPU1_DISP0_DATA00,
- MX6_PAD_DISP0_DAT1__IPU1_DISP0_DATA01,
- MX6_PAD_DISP0_DAT2__IPU1_DISP0_DATA02,
- MX6_PAD_DISP0_DAT3__IPU1_DISP0_DATA03,
- MX6_PAD_DISP0_DAT4__IPU1_DISP0_DATA04,
- MX6_PAD_DISP0_DAT5__IPU1_DISP0_DATA05,
- MX6_PAD_DISP0_DAT6__IPU1_DISP0_DATA06,
- MX6_PAD_DISP0_DAT7__IPU1_DISP0_DATA07,
- MX6_PAD_DISP0_DAT8__IPU1_DISP0_DATA08,
- MX6_PAD_DISP0_DAT9__IPU1_DISP0_DATA09,
- MX6_PAD_DISP0_DAT10__IPU1_DISP0_DATA10,
- MX6_PAD_DISP0_DAT11__IPU1_DISP0_DATA11,
- MX6_PAD_DISP0_DAT12__IPU1_DISP0_DATA12,
- MX6_PAD_DISP0_DAT13__IPU1_DISP0_DATA13,
- MX6_PAD_DISP0_DAT14__IPU1_DISP0_DATA14,
- MX6_PAD_DISP0_DAT15__IPU1_DISP0_DATA15,
- MX6_PAD_DISP0_DAT16__IPU1_DISP0_DATA16,
- MX6_PAD_DISP0_DAT17__IPU1_DISP0_DATA17,
- MX6_PAD_DISP0_DAT18__IPU1_DISP0_DATA18,
- MX6_PAD_DISP0_DAT19__IPU1_DISP0_DATA19,
- MX6_PAD_DISP0_DAT20__IPU1_DISP0_DATA20,
- MX6_PAD_DISP0_DAT21__IPU1_DISP0_DATA21,
- MX6_PAD_DISP0_DAT22__IPU1_DISP0_DATA22,
- MX6_PAD_DISP0_DAT23__IPU1_DISP0_DATA23,
- /* backlight PWM brightness control */
- MX6_PAD_GPIO_9__PWM1_OUT | MUX_PAD_CTRL(NO_PAD_CTRL),
- /* backlight enable */
- MX6_PAD_EIM_BCLK__GPIO6_IO31 | MUX_PAD_CTRL(NO_PAD_CTRL),
- /* LCD power enable */
- MX6_PAD_NANDF_CS2__GPIO6_IO15 | MUX_PAD_CTRL(NO_PAD_CTRL),
- if (bus == CONFIG_SF_DEFAULT_BUS && cs == CONFIG_SF_DEFAULT_CS)
- if (bus == 0 && cs == 0)
- return -1;
- int i;
- imx_iomux_v3_setup_multiple_pads(ecspi1_pads, ARRAY_SIZE(ecspi1_pads));
- imx_iomux_v3_setup_multiple_pads(ecspi4_pads, ARRAY_SIZE(ecspi4_pads));
- for (i = 0; i < 4; i++)
- gpio_direction_output(ECSPI1_CS0, 1);
- gpio_direction_output(ECSPI4_CS1, 0);
- /* set cs0 to high (second device on spi bus #4) */
- gpio_direction_output(ECSPI4_CS0, 1);
- imx_iomux_v3_setup_multiple_pads(gpio_pads, ARRAY_SIZE(gpio_pads));
- switch (CONFIG_MXC_UART_BASE) {
- case UART1_BASE:
break;
- case UART2_BASE:
break;
- case UART3_BASE:
break;
- case UART4_BASE:
break;
- {USDHC1_BASE_ADDR},
- {USDHC2_BASE_ADDR},
- return 1;
- usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC_CLK);
- imx_iomux_v3_setup_multiple_pads(usdhc1_pads, ARRAY_SIZE(usdhc1_pads));
- usdhc_cfg[1].sdhc_clk = mxc_get_clock(MXC_ESDHC2_CLK);
- imx_iomux_v3_setup_multiple_pads(usdhc2_pads, ARRAY_SIZE(usdhc2_pads));
- return fsl_esdhc_initialize(bis, &usdhc_cfg[0]) |
+#else
- imx_iomux_v3_setup_pad(MX6_PAD_SD2_DAT3__GPIO1_IO12 |
- gpio_direction_output(IMX_GPIO_NR(1, 12) , 1);
- return fsl_esdhc_initialize(bis, &usdhc_cfg[0]);
+#endif +} +#endif
- Do not overwrite the console
- Use always serial for U-Boot console
- return 1;
- /* control data pad skew - devaddr = 0x02, register = 0x04 */
- ksz9031_phy_extended_write(phydev, 0x02,
- /* rx data pad skew - devaddr = 0x02, register = 0x05 */
- /* tx data pad skew - devaddr = 0x02, register = 0x06 */
- /* gtx and rx clock pad skew - devaddr = 0x02, register = 0x08 */
- if (phydev->drv->config)
- setup_iomux_enet();
- return cpu_eth_init(bis);
- int i, j;
- for (i = 0; i < BMP_LOGO_WIDTH; i++)
- Rotate the BMP_LOGO (only)
- Will only work, if the logo is square, as
- BMP_LOGO_HEIGHT and BMP_LOGO_WIDTH are defines, not variables
- unsigned char out_logo[BMP_LOGO_WIDTH * BMP_LOGO_HEIGHT];
- unsigned char *in_logo;
- int i, j;
- if (BMP_LOGO_WIDTH != BMP_LOGO_HEIGHT)
return;
- in_logo = bmp_logo_bitmap;
- /* one 90 degree rotation */
- if (rotations == 1 || rotations == 2 || rotations == 3)
- /* second 90 degree rotation */
- if (rotations == 2 || rotations == 3)
- /* third 90 degree rotation */
- if (rotations == 3)
- /* copy result back to original array */
- if (rotations == 1 || rotations == 3)
+} +#endif
- imx_iomux_v3_setup_multiple_pads(backlight_pads,
- gpio_direction_output(IMX_GPIO_NR(6, 31), 1);
- gpio_direction_output(IMX_GPIO_NR(6, 15), 1);
- /* enable backlight PWM 1 */
- if (pwm_init(0, 0, 0))
goto error;
- /* duty cycle 500ns, period: 3000ns */
- if (pwm_config(0, 50000, 300000))
goto error;
- if (pwm_enable(0))
goto error;
- return;
+error:
- puts("error init pwm for backlight\n");
- return;
- struct iomuxc *iomux = (struct iomuxc *)IOMUXC_BASE_ADDR;
- struct mxc_ccm_reg *ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR;
- int reg;
- s32 timeout = 100000;
- /* set PLL5 clock */
- reg = readl(&ccm->analog_pll_video);
- reg |= BM_ANADIG_PLL_VIDEO_POWERDOWN;
- writel(reg, &ccm->analog_pll_video);
- /* set PLL5 to 232720000Hz */
- reg &= ~BM_ANADIG_PLL_VIDEO_DIV_SELECT;
- reg |= BF_ANADIG_PLL_VIDEO_DIV_SELECT(0x26);
- reg &= ~BM_ANADIG_PLL_VIDEO_POST_DIV_SELECT;
- reg |= BF_ANADIG_PLL_VIDEO_POST_DIV_SELECT(0);
- writel(BF_ANADIG_PLL_VIDEO_NUM_A(0xC0238),
- writel(BF_ANADIG_PLL_VIDEO_DENOM_B(0xF4240),
- reg &= ~BM_ANADIG_PLL_VIDEO_POWERDOWN;
- while (timeout--)
break;
- if (timeout < 0)
- reg |= BM_ANADIG_PLL_VIDEO_ENABLE;
- reg &= ~BM_ANADIG_PLL_VIDEO_BYPASS;
- /* set LDB0, LDB1 clk select to 000/000 (PLL5 clock) */
- reg = readl(&ccm->cs2cdr);
- reg &= ~(MXC_CCM_CS2CDR_LDB_DI0_CLK_SEL_MASK
- reg |= (0 << MXC_CCM_CS2CDR_LDB_DI0_CLK_SEL_OFFSET)
- writel(reg, &ccm->cs2cdr);
- reg = readl(&ccm->cscmr2);
- reg |= MXC_CCM_CSCMR2_LDB_DI0_IPU_DIV;
- writel(reg, &ccm->cscmr2);
- reg = readl(&ccm->chsccdr);
- reg |= (CHSCCDR_CLK_SEL_LDB_DI0
- writel(reg, &ccm->chsccdr);
- reg = IOMUXC_GPR2_BGREF_RRMODE_EXTERNAL_RES
- writel(reg, &iomux->gpr[2]);
- reg = readl(&iomux->gpr[3]);
- reg = (reg & ~IOMUXC_GPR3_LVDS0_MUX_CTL_MASK)
- writel(reg, &iomux->gpr[3]);
- return;
- int reg;
- rotate_logo(3); /* portrait display in landscape mode */
* see:
- ipu_set_ldb_clock(28341000);
- /* select pll 5 clock */
- /* set PLL5 to 197994996Hz */
- reg |= BF_ANADIG_PLL_VIDEO_DIV_SELECT(0x21);
- writel(BF_ANADIG_PLL_VIDEO_NUM_A(0xfbf4),
- writel(BF_ANADIG_PLL_VIDEO_DENOM_B(0xf4240),
- while (timeout--)
break;
- if (timeout < 0)
- reg &= ~MXC_CCM_CHSCCDR_IPU1_DI0_PODF_MASK;
- reg |= (2 << MXC_CCM_CHSCCDR_IPU1_DI0_PODF_OFFSET);
- reg &= ~MXC_CCM_CHSCCDR_IPU1_DI0_PRE_CLK_SEL_MASK;
- reg |= (2 << MXC_CCM_CHSCCDR_IPU1_DI0_PRE_CLK_SEL_OFFSET);
display_pads,
- return;
- .bus = -1,
- .addr = 0,
- .pixfmt = IPU_PIX_FMT_RGB24,
- .detect = NULL,
- .enable = enable_lvds,
- .mode = {
.name = "lb07wv8",
.refresh = 60,
.xres = 800,
.yres = 480,
.pixclock = 30066,
.left_margin = 88,
.right_margin = 88,
.upper_margin = 20,
.lower_margin = 20,
.hsync_len = 80,
.vsync_len = 5,
- .bus = -1,
- .addr = 0,
- .detect = NULL,
- .enable = enable_spi_display,
- .mode = {
.name = "lg4573",
.refresh = 60,
.xres = 480,
.yres = 800,
.pixclock = 37037,
.left_margin = 59,
.right_margin = 10,
.upper_margin = 15,
.lower_margin = 15,
.hsync_len = 10,
.vsync_len = 15,
- enable_ipu_clock();
- enable_display_power();
- return 1;
+} +#endif
- setup_iomux_uart();
- setup_iomux_gpio();
- gpio_direction_output(SOFT_RESET_GPIO, 1);
- gpio_direction_output(SD2_DRIVER_ENABLE, 1);
- setup_display();
- MX6_PAD_NANDF_CLE__NAND_CLE | MUX_PAD_CTRL(NO_PAD_CTRL),
- MX6_PAD_NANDF_ALE__NAND_ALE | MUX_PAD_CTRL(NO_PAD_CTRL),
- MX6_PAD_NANDF_WP_B__NAND_WP_B | MUX_PAD_CTRL(NO_PAD_CTRL),
- MX6_PAD_NANDF_RB0__NAND_READY_B | MUX_PAD_CTRL(NO_PAD_CTRL),
- MX6_PAD_NANDF_CS0__NAND_CE0_B | MUX_PAD_CTRL(NO_PAD_CTRL),
- MX6_PAD_NANDF_CS1__NAND_CE1_B | MUX_PAD_CTRL(NO_PAD_CTRL),
- MX6_PAD_SD4_CMD__NAND_RE_B | MUX_PAD_CTRL(NO_PAD_CTRL),
- MX6_PAD_SD4_CLK__NAND_WE_B | MUX_PAD_CTRL(NO_PAD_CTRL),
- MX6_PAD_NANDF_D0__NAND_DATA00 | MUX_PAD_CTRL(NO_PAD_CTRL),
- MX6_PAD_NANDF_D1__NAND_DATA01 | MUX_PAD_CTRL(NO_PAD_CTRL),
- MX6_PAD_NANDF_D2__NAND_DATA02 | MUX_PAD_CTRL(NO_PAD_CTRL),
- MX6_PAD_NANDF_D3__NAND_DATA03 | MUX_PAD_CTRL(NO_PAD_CTRL),
- MX6_PAD_NANDF_D4__NAND_DATA04 | MUX_PAD_CTRL(NO_PAD_CTRL),
- MX6_PAD_NANDF_D5__NAND_DATA05 | MUX_PAD_CTRL(NO_PAD_CTRL),
- MX6_PAD_NANDF_D6__NAND_DATA06 | MUX_PAD_CTRL(NO_PAD_CTRL),
- MX6_PAD_NANDF_D7__NAND_DATA07 | MUX_PAD_CTRL(NO_PAD_CTRL),
- MX6_PAD_SD4_DAT0__NAND_DQS | MUX_PAD_CTRL(NO_PAD_CTRL),
- struct mxc_ccm_reg *mxc_ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR;
- /* config gpmi nand iomux */
- imx_iomux_v3_setup_multiple_pads(nfc_pads,
- /* gate ENFC_CLK_ROOT clock first,before clk source switch */
- clrbits_le32(&mxc_ccm->CCGR2, MXC_CCM_CCGR2_IOMUX_IPT_CLK_IO_MASK);
- /* config gpmi and bch clock to 100 MHz */
- clrsetbits_le32(&mxc_ccm->cs2cdr,
- /* enable ENFC_CLK_ROOT clock */
- setbits_le32(&mxc_ccm->CCGR2, MXC_CCM_CCGR2_IOMUX_IPT_CLK_IO_MASK);
- /* enable gpmi and bch clock gating */
- setbits_le32(&mxc_ccm->CCGR4,
- /* enable apbh clock gating */
- setbits_le32(&mxc_ccm->CCGR0, MXC_CCM_CCGR0_APBHDMA_MASK);
- /* address of boot parameters */
- gd->bd->bi_boot_params = PHYS_SDRAM + 0x100;
- setup_spi();
- setup_i2c(0, CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE,
&i2c_pad_info1);
- setup_i2c(1, CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE,
&i2c_pad_info2);
- setup_i2c(2, CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE,
&i2c_pad_info3);
- setup_i2c(3, CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE,
&i2c_pad_info4);
- /* SPI NOR Flash read only */
- gpio_request(CONFIG_GPIO_ENABLE_SPI_FLASH, "ena_spi_nor");
- gpio_direction_output(CONFIG_GPIO_ENABLE_SPI_FLASH, 0);
- gpio_free(CONFIG_GPIO_ENABLE_SPI_FLASH);
- /* enable all LEDs */
- gpio_request(IMX_GPIO_NR(2, 13), "LED ena"); /* 25 */
- gpio_direction_output(IMX_GPIO_NR(1, 25), 0);
- /* switch off Status LEDs */
- gpio_request(IMX_GPIO_NR(6, 16), "LED yellow"); /* 176 */
- gpio_direction_output(IMX_GPIO_NR(6, 16), 1);
- gpio_request(IMX_GPIO_NR(2, 28), "LED red"); /* 60 */
- gpio_direction_output(IMX_GPIO_NR(2, 28), 1);
- gpio_request(IMX_GPIO_NR(5, 4), "LED green"); /* 132 */
- gpio_direction_output(IMX_GPIO_NR(5, 4), 1);
- gpio_request(IMX_GPIO_NR(2, 29), "LED blue"); /* 61 */
- gpio_direction_output(IMX_GPIO_NR(2, 29), 1);
- setup_gpmi_nand();
- /* ENET_RX_ER for USB_OTG_ID */
- clrsetbits_le32(&iomux->gpr[1], IOMUXC_GPR1_USB_OTG_ID_SEL_MASK, 0);
- imx_iomux_v3_setup_multiple_pads(misc_pads, ARRAY_SIZE(misc_pads));
- /* enable spi bus #2 SS drivers */
- gpio_direction_output(IMX_GPIO_NR(6, 6), 1);
- char *my_bootdelay;
- char bootmode = 0;
- char const *panel = getenv("panel");
* disable bootdelay
- gpio_request(IMX_GPIO_NR(7, 6), "bootsel0");
- gpio_direction_input(IMX_GPIO_NR(7, 6));
- gpio_request(IMX_GPIO_NR(7, 7), "bootsel1");
- gpio_direction_input(IMX_GPIO_NR(7, 7));
- gpio_request(IMX_GPIO_NR(7, 1), "bootsel2");
- gpio_direction_input(IMX_GPIO_NR(7, 1));
- bootmode |= (gpio_get_value(IMX_GPIO_NR(7, 6)) ? 1 : 0) << 0;
- bootmode |= (gpio_get_value(IMX_GPIO_NR(7, 7)) ? 1 : 0) << 1;
- bootmode |= (gpio_get_value(IMX_GPIO_NR(7, 1)) ? 1 : 0) << 2;
- if (bootmode == 7) {
else
- /* if we have the lg panel, we can initialze it now */
- if (panel)
- puts("Board: aristaitenos2\n");
- int ret;
- ret = gpio_request(ARISTAINETOS2_USB_H1_PWR, "usb-h1-pwr");
- if (!ret)
- ret = gpio_request(ARISTAINETOS2_USB_OTG_PWR, "usb-OTG-pwr");
- if (!ret)
- if (port)
- else
- (C) Copyright 2014
- Based on:
- Copyright (C) 2013 Boundary Devices
- Refer doc/README.imximage for more details about how-to configure
- and create imximage boot image
- The syntax is taken as close as possible with the kwbimage
- Boot Device : one of
- spi, sd
+BOOT_FROM spi
- Device Configuration Data (DCD)
- Each entry must have the format:
- Addr-type Address Value
- where:
- where:
- where:
- DQS gating, read delay, write delay calibration values
- Based on:
- Configuration settings for the Freescale i.MX6DL aristainetos2 board.
+#define CONFIG_MX6
- "script=u-boot.scr\0" \
- "fit_file=/boot/system.itb\0" \
- "loadaddr=0x12000000\0" \
- "fit_addr_r=0x14000000\0" \
- "uboot=/boot/u-boot.imx\0" \
- "uboot_sz=d0000\0" \
- "rescue_sys_addr=f0000\0" \
- "rescue_sys_length=f10000\0" \
- "board_type=aristainetos2_7@1\0" \
- "panel=lb07wv8\0" \
- "splashpos=m,m\0" \
- "console=" CONFIG_CONSOLE_DEV "\0" \
- "nor_bootdelay=-2\0" \
- "fdt_high=0xffffffff\0" \
- "initrd_high=0xffffffff\0" \
- "mtdids=nand0=gpmi-nand,nor0=spi3.1\0" \
- "mtdparts=mtdparts=spi3.1:832k(u-boot),64k(env),64k(env-red)," \
- "addmisc=setenv bootargs ${bootargs} net.ifnames=0 consoleblank=0\0" \
- "addmtd=setenv bootargs ${bootargs} ${mtdparts}\0" \
- "set_fit_default=fdt addr ${fit_addr_r};fdt set /configurations " \
- "get_env=mw ${loadaddr} 0 0x20000;" \
"mmc rescan;" \
- "default_env=mw ${loadaddr} 0 0x20000;" \
"env default -a;" \
- "loadbootscript=" \
- "bootscript=echo Running bootscript from mmc ...; " \
"source\0" \
- "mmcpart=1\0" \
- "mmcdev=0\0" \
- "mmcroot=" CONFIG_MMCROOT " rootwait rw\0" \
- "mmcargs=setenv bootargs console=${console},${baudrate} " \
- "mmcboot=echo Booting from mmc ...; " \
- "mmc_load_fit=ext2load mmc ${mmcdev}:${mmcpart} ${fit_addr_r} " \
"${fit_file}\0" \
- "mmc_load_uboot=ext2load mmc ${mmcdev}:${mmcpart} ${loadaddr} " \
"${uboot}\0" \
- "mmc_upd_uboot=mw.b ${loadaddr} 0xff ${uboot_sz};" \
- "ubiargs=setenv bootargs console=${console},${baudrate} " \
- "ubiboot=echo Booting from ubi ...; " \
- "ubifs_load_fit=sf probe;ubi part ubi 4096;ubifsmount ubi:rootfs;" \
- "rescueargs=setenv bootargs console=${console},${baudrate} " \
- "rescueboot=echo Booting rescue system from NOR ...; " \
- "rescue_load_fit=sf probe;sf read ${fit_addr_r} ${rescue_sys_addr} " \
- "mmc dev ${mmcdev};" \
- "if mmc rescan; then " \
"else " \
"run mmcboot; " \
"else " \
"run ubiboot; " \
"else " \
"else " \
"FAILURE;" \
"fi; " \
"fi; " \
"fi; " \
"fi; " \
- "else " \
"run ubiboot; " \
"else " \
"else " \
"fi; " \
"fi; " \
- "fi"
- (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE)
- (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
+#define CONFIG_FIT
Best regards, Stefano Babic
Heiko Schocher
Stefano Babic
