[U-Boot] [PATCH 0/2] sunxi: update Pine64 device tree
When the Pine64 support was merged into U-Boot, there was no official Pine64 .dts in the Linux tree. Since this has changed now and the meanwhile merged Linux DT differs quite a lot from the (preliminary) .dts we used in U-Boot so far, let's update U-Boot's DT to match the Linux version. Beside the effect of using a single instance of the DT we gain the huge advantage of not (necessarily) needing to load a .dtb to boot Linux. Instead just specifying $fdtcontroladdr does the trick, which is used by the UEFI boot scheme already. This has the potential of relieving distributions from the burden of supplying .dtb files for each and every "supported" board.
Following Chen-Yu's suggestion on the last post, the first patch is a 1:1 copy of the Linux version (as of 4.12-rc1), the second one (re-)adds the DT nodes for the Ethernet MAC, which is both not-yet-upstream in Linux and also differening from the proposed Linux driver bindings. But let's fix that later once the Linux driver gets merged.
Given that U-Boot itself does not use the DT much (at least at the moment), there is little risk of breakage, so I'd be grateful if this could be still merged into the next release.
Cheers, Andre.
Andre Przywara (2): arm64: A64/Pine64: update device tree from Linux sunxi: A64: (re-)add sun8i emac DT nodes
arch/arm/dts/sun50i-a64-pine64-common.dtsi | 93 ----- arch/arm/dts/sun50i-a64-pine64-plus.dts | 16 +- arch/arm/dts/sun50i-a64-pine64.dts | 60 ++- arch/arm/dts/sun50i-a64.dtsi | 634 ++++++++++------------------- include/dt-bindings/clock/sun50i-a64-ccu.h | 134 ++++++ include/dt-bindings/reset/sun50i-a64-ccu.h | 98 +++++ 6 files changed, 496 insertions(+), 539 deletions(-) delete mode 100644 arch/arm/dts/sun50i-a64-pine64-common.dtsi create mode 100644 include/dt-bindings/clock/sun50i-a64-ccu.h create mode 100644 include/dt-bindings/reset/sun50i-a64-ccu.h
The Linux device tree for the Allwinner A64 SoC has changed a lot since the U-Boot version was merged. Let's replace the current DT with a exact copy of the Linux one as of: commit c6778ff813d2ca3e3c8733c87dc8b6831a64578b Merge: 0ff4c01 3c0e3abd Author: Linus Torvalds torvalds@linux-foundation.org Date: Tue May 9 10:07:33 2017 -0700
For this patch this makes U-Boot lose the (not yet upstream) Ethernet node, but the next patch will fix this up.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- arch/arm/dts/sun50i-a64-pine64-common.dtsi | 93 ----- arch/arm/dts/sun50i-a64-pine64-plus.dts | 26 +- arch/arm/dts/sun50i-a64-pine64.dts | 59 ++- arch/arm/dts/sun50i-a64.dtsi | 639 +++++++++-------------------- include/dt-bindings/clock/sun50i-a64-ccu.h | 134 ++++++ include/dt-bindings/reset/sun50i-a64-ccu.h | 98 +++++ 6 files changed, 480 insertions(+), 569 deletions(-) delete mode 100644 arch/arm/dts/sun50i-a64-pine64-common.dtsi create mode 100644 include/dt-bindings/clock/sun50i-a64-ccu.h create mode 100644 include/dt-bindings/reset/sun50i-a64-ccu.h
diff --git a/arch/arm/dts/sun50i-a64-pine64-common.dtsi b/arch/arm/dts/sun50i-a64-pine64-common.dtsi deleted file mode 100644 index 9ec81c6..0000000 --- a/arch/arm/dts/sun50i-a64-pine64-common.dtsi +++ /dev/null @@ -1,93 +0,0 @@ -/* - * Copyright (c) 2016 ARM Ltd. - * - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This library is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This library is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * Or, alternatively, - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use, - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, - * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. - */ - -#include "sun50i-a64.dtsi" - -/ { - - aliases { - serial0 = &uart0; - ethernet0 = &emac; - }; - - soc { - reg_vcc3v3: vcc3v3 { - compatible = "regulator-fixed"; - regulator-name = "vcc3v3"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - }; - }; -}; - -&mmc0 { - pinctrl-names = "default"; - pinctrl-0 = <&mmc0_pins>, <&mmc0_default_cd_pin>; - vmmc-supply = <®_vcc3v3>; - cd-gpios = <&pio 5 6 0>; - cd-inverted; - status = "okay"; -}; - -&uart0 { - pinctrl-names = "default"; - pinctrl-0 = <&uart0_pins_a>; - status = "okay"; -}; - -&i2c1 { - pinctrl-names = "default"; - pinctrl-0 = <&i2c1_pins>; - status = "okay"; -}; - -&usbphy { - status = "okay"; -}; - -&ohci1 { - status = "okay"; -}; - -&ehci1 { - status = "okay"; -}; diff --git a/arch/arm/dts/sun50i-a64-pine64-plus.dts b/arch/arm/dts/sun50i-a64-pine64-plus.dts index 389c609..790d14d 100644 --- a/arch/arm/dts/sun50i-a64-pine64-plus.dts +++ b/arch/arm/dts/sun50i-a64-pine64-plus.dts @@ -40,33 +40,11 @@ * OTHER DEALINGS IN THE SOFTWARE. */
-/dts-v1/; - -#include "sun50i-a64-pine64-common.dtsi" +#include "sun50i-a64-pine64.dts"
/ { model = "Pine64+"; compatible = "pine64,pine64-plus", "allwinner,sun50i-a64";
- chosen { - stdout-path = "serial0:115200n8"; - }; - - /* There is a model with 2GB of DRAM, but U-Boot fixes this for us. */ - memory { - reg = <0x40000000 0x40000000>; - }; -}; - -&emac { - pinctrl-names = "default"; - pinctrl-0 = <&rgmii_pins>; - phy-mode = "rgmii"; - phy = <&phy1>; - status = "okay"; - - phy1: ethernet-phy@1 { - reg = <1>; - }; + /* TODO: Camera, Ethernet PHY, touchscreen, etc. */ }; - diff --git a/arch/arm/dts/sun50i-a64-pine64.dts b/arch/arm/dts/sun50i-a64-pine64.dts index ebe029e..c680ed3 100644 --- a/arch/arm/dts/sun50i-a64-pine64.dts +++ b/arch/arm/dts/sun50i-a64-pine64.dts @@ -42,17 +42,70 @@
/dts-v1/;
-#include "sun50i-a64-pine64-common.dtsi" +#include "sun50i-a64.dtsi" + +#include <dt-bindings/gpio/gpio.h>
/ { model = "Pine64"; compatible = "pine64,pine64", "allwinner,sun50i-a64";
+ aliases { + serial0 = &uart0; + }; + chosen { stdout-path = "serial0:115200n8"; };
- memory { - reg = <0x40000000 0x20000000>; + reg_vcc3v3: vcc3v3 { + compatible = "regulator-fixed"; + regulator-name = "vcc3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; }; }; + +&ehci1 { + status = "okay"; +}; + +&i2c1 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c1_pins>; + status = "okay"; +}; + +&i2c1_pins { + bias-pull-up; +}; + +&mmc0 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc0_pins>; + vmmc-supply = <®_vcc3v3>; + cd-gpios = <&pio 5 6 GPIO_ACTIVE_HIGH>; + cd-inverted; + disable-wp; + bus-width = <4>; + status = "okay"; +}; + +&ohci1 { + status = "okay"; +}; + +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_pins_a>; + status = "okay"; +}; + +&usb_otg { + dr_mode = "host"; + status = "okay"; +}; + +&usbphy { + status = "okay"; +}; diff --git a/arch/arm/dts/sun50i-a64.dtsi b/arch/arm/dts/sun50i-a64.dtsi index bef0d00..c7f669f 100644 --- a/arch/arm/dts/sun50i-a64.dtsi +++ b/arch/arm/dts/sun50i-a64.dtsi @@ -42,8 +42,9 @@ * OTHER DEALINGS IN THE SOFTWARE. */
+#include <dt-bindings/clock/sun50i-a64-ccu.h> #include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/pinctrl/sun4i-a10.h> +#include <dt-bindings/reset/sun50i-a64-ccu.h>
/ { interrupt-parent = <&gic>; @@ -54,28 +55,28 @@ #address-cells = <1>; #size-cells = <0>;
- cpu@0 { + cpu0: cpu@0 { compatible = "arm,cortex-a53", "arm,armv8"; device_type = "cpu"; reg = <0>; enable-method = "psci"; };
- cpu@1 { + cpu1: cpu@1 { compatible = "arm,cortex-a53", "arm,armv8"; device_type = "cpu"; reg = <1>; enable-method = "psci"; };
- cpu@2 { + cpu2: cpu@2 { compatible = "arm,cortex-a53", "arm,armv8"; device_type = "cpu"; reg = <2>; enable-method = "psci"; };
- cpu@3 { + cpu3: cpu@3 { compatible = "arm,cortex-a53", "arm,armv8"; device_type = "cpu"; reg = <3>; @@ -83,28 +84,31 @@ }; };
- psci { - compatible = "arm,psci-0.2"; - method = "smc"; + osc24M: osc24M_clk { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <24000000>; + clock-output-names = "osc24M"; + }; + + osc32k: osc32k_clk { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <32768>; + clock-output-names = "osc32k"; };
- memory { - device_type = "memory"; - reg = <0x40000000 0>; + iosc: internal-osc-clk { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <16000000>; + clock-accuracy = <300000000>; + clock-output-names = "iosc"; };
- gic: interrupt-controller@1c81000 { - compatible = "arm,gic-400"; - interrupt-controller; - #interrupt-cells = <3>; - #address-cells = <0>; - - reg = <0x01c81000 0x1000>, - <0x01c82000 0x2000>, - <0x01c84000 0x2000>, - <0x01c86000 0x2000>; - interrupts = <GIC_PPI 9 - (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>; + psci { + compatible = "arm,psci-0.2"; + method = "smc"; };
timer { @@ -119,199 +123,6 @@ (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>; };
- clocks { - #address-cells = <1>; - #size-cells = <1>; - ranges; - - osc24M: osc24M_clk { - #clock-cells = <0>; - compatible = "fixed-clock"; - clock-frequency = <24000000>; - clock-output-names = "osc24M"; - }; - - osc32k: osc32k_clk { - #clock-cells = <0>; - compatible = "fixed-clock"; - clock-frequency = <32768>; - clock-output-names = "osc32k"; - }; - - pll1: pll1_clk@1c20000 { - #clock-cells = <0>; - compatible = "allwinner,sun8i-a23-pll1-clk"; - reg = <0x01c20000 0x4>; - clocks = <&osc24M>; - clock-output-names = "pll1"; - }; - - pll6: pll6_clk@1c20028 { - #clock-cells = <1>; - compatible = "allwinner,sun6i-a31-pll6-clk"; - reg = <0x01c20028 0x4>; - clocks = <&osc24M>; - clock-output-names = "pll6", "pll6x2"; - }; - - pll6d2: pll6d2_clk { - #clock-cells = <0>; - compatible = "fixed-factor-clock"; - clock-div = <2>; - clock-mult = <1>; - clocks = <&pll6 0>; - clock-output-names = "pll6d2"; - }; - - pll7: pll7_clk@1c2002c { - #clock-cells = <1>; - compatible = "allwinner,sun6i-a31-pll6-clk"; - reg = <0x01c2002c 0x4>; - clocks = <&osc24M>; - clock-output-names = "pll7", "pll7x2"; - }; - - cpu: cpu_clk@1c20050 { - #clock-cells = <0>; - compatible = "allwinner,sun4i-a10-cpu-clk"; - reg = <0x01c20050 0x4>; - clocks = <&osc32k>, <&osc24M>, <&pll1>, <&pll1>; - clock-output-names = "cpu"; - critical-clocks = <0>; - }; - - axi: axi_clk@1c20050 { - #clock-cells = <0>; - compatible = "allwinner,sun4i-a10-axi-clk"; - reg = <0x01c20050 0x4>; - clocks = <&cpu>; - clock-output-names = "axi"; - }; - - ahb1: ahb1_clk@1c20054 { - #clock-cells = <0>; - compatible = "allwinner,sun6i-a31-ahb1-clk"; - reg = <0x01c20054 0x4>; - clocks = <&osc32k>, <&osc24M>, <&axi>, <&pll6 0>; - clock-output-names = "ahb1"; - }; - - ahb2: ahb2_clk@1c2005c { - #clock-cells = <0>; - compatible = "allwinner,sun8i-h3-ahb2-clk"; - reg = <0x01c2005c 0x4>; - clocks = <&ahb1>, <&pll6d2>; - clock-output-names = "ahb2"; - }; - - apb1: apb1_clk@1c20054 { - #clock-cells = <0>; - compatible = "allwinner,sun4i-a10-apb0-clk"; - reg = <0x01c20054 0x4>; - clocks = <&ahb1>; - clock-output-names = "apb1"; - }; - - apb2: apb2_clk@1c20058 { - #clock-cells = <0>; - compatible = "allwinner,sun4i-a10-apb1-clk"; - reg = <0x01c20058 0x4>; - clocks = <&osc32k>, <&osc24M>, <&pll6 1>, <&pll6 1>; - clock-output-names = "apb2"; - }; - - bus_gates: bus_gates_clk@1c20060 { - #clock-cells = <1>; - compatible = "allwinner,sun50i-a64-bus-gates-clk", - "allwinner,sunxi-multi-bus-gates-clk"; - reg = <0x01c20060 0x14>; - ahb1_parent { - clocks = <&ahb1>; - clock-indices = <1>, <5>, - <6>, <8>, - <9>, <10>, - <13>, <14>, - <18>, <19>, - <20>, <21>, - <23>, <24>, - <25>, <28>, - <32>, <35>, - <36>, <37>, - <40>, <43>, - <44>, <52>, - <53>, <54>, - <135>; - clock-output-names = "bus_mipidsi", "bus_ce", - "bus_dma", "bus_mmc0", - "bus_mmc1", "bus_mmc2", - "bus_nand", "bus_sdram", - "bus_ts", "bus_hstimer", - "bus_spi0", "bus_spi1", - "bus_otg", "bus_otg_ehci0", - "bus_ehci0", "bus_otg_ohci0", - "bus_ve", "bus_lcd0", - "bus_lcd1", "bus_deint", - "bus_csi", "bus_hdmi", - "bus_de", "bus_gpu", - "bus_msgbox", "bus_spinlock", - "bus_dbg"; - }; - ahb2_parent { - clocks = <&ahb2>; - clock-indices = <17>, <29>; - clock-output-names = "bus_gmac", "bus_ohci0"; - }; - apb1_parent { - clocks = <&apb1>; - clock-indices = <64>, <65>, - <69>, <72>, - <76>, <77>, - <78>; - clock-output-names = "bus_codec", "bus_spdif", - "bus_pio", "bus_ths", - "bus_i2s0", "bus_i2s1", - "bus_i2s2"; - }; - abp2_parent { - clocks = <&apb2>; - clock-indices = <96>, <97>, - <98>, <101>, - <112>, <113>, - <114>, <115>, - <116>; - clock-output-names = "bus_i2c0", "bus_i2c1", - "bus_i2c2", "bus_scr", - "bus_uart0", "bus_uart1", - "bus_uart2", "bus_uart3", - "bus_uart4"; - }; - }; - - mmc0_clk: mmc0_clk@1c20088 { - #clock-cells = <0>; - compatible = "allwinner,sun4i-a10-mod0-clk"; - reg = <0x01c20088 0x4>; - clocks = <&osc24M>, <&pll6 1>, <&pll7 1>; - clock-output-names = "mmc0"; - }; - - mmc1_clk: mmc1_clk@1c2008c { - #clock-cells = <0>; - compatible = "allwinner,sun4i-a10-mod0-clk"; - reg = <0x01c2008c 0x4>; - clocks = <&osc24M>, <&pll6 1>, <&pll7 1>; - clock-output-names = "mmc1"; - }; - - mmc2_clk: mmc2_clk@1c20090 { - #clock-cells = <0>; - compatible = "allwinner,sun4i-a10-mod0-clk"; - reg = <0x01c20090 0x4>; - clocks = <&osc24M>, <&pll6 1>, <&pll7 1>; - clock-output-names = "mmc2"; - }; - }; - soc { compatible = "simple-bus"; #address-cells = <1>; @@ -319,240 +130,181 @@ ranges;
mmc0: mmc@1c0f000 { - compatible = "allwinner,sun50i-a64-mmc", - "allwinner,sun5i-a13-mmc"; + compatible = "allwinner,sun50i-a64-mmc"; reg = <0x01c0f000 0x1000>; - clocks = <&bus_gates 8>, <&mmc0_clk>, - <&mmc0_clk>, <&mmc0_clk>; - clock-names = "ahb", "mmc", - "output", "sample"; - resets = <&ahb_rst 8>; + clocks = <&ccu CLK_BUS_MMC0>, <&ccu CLK_MMC0>; + clock-names = "ahb", "mmc"; + resets = <&ccu RST_BUS_MMC0>; reset-names = "ahb"; interrupts = <GIC_SPI 60 IRQ_TYPE_LEVEL_HIGH>; + max-frequency = <150000000>; status = "disabled"; #address-cells = <1>; #size-cells = <0>; };
mmc1: mmc@1c10000 { - compatible = "allwinner,sun50i-a64-mmc", - "allwinner,sun5i-a13-mmc"; + compatible = "allwinner,sun50i-a64-mmc"; reg = <0x01c10000 0x1000>; - clocks = <&bus_gates 9>, <&mmc1_clk>, - <&mmc1_clk>, <&mmc1_clk>; - clock-names = "ahb", "mmc", - "output", "sample"; - resets = <&ahb_rst 9>; + clocks = <&ccu CLK_BUS_MMC1>, <&ccu CLK_MMC1>; + clock-names = "ahb", "mmc"; + resets = <&ccu RST_BUS_MMC1>; reset-names = "ahb"; interrupts = <GIC_SPI 61 IRQ_TYPE_LEVEL_HIGH>; + max-frequency = <150000000>; status = "disabled"; #address-cells = <1>; #size-cells = <0>; };
mmc2: mmc@1c11000 { - compatible = "allwinner,sun50i-a64-mmc", - "allwinner,sun5i-a13-mmc"; + compatible = "allwinner,sun50i-a64-emmc"; reg = <0x01c11000 0x1000>; - clocks = <&bus_gates 10>, <&mmc2_clk>, - <&mmc2_clk>, <&mmc2_clk>; - clock-names = "ahb", "mmc", - "output", "sample"; - resets = <&ahb_rst 10>; + clocks = <&ccu CLK_BUS_MMC2>, <&ccu CLK_MMC2>; + clock-names = "ahb", "mmc"; + resets = <&ccu RST_BUS_MMC2>; reset-names = "ahb"; interrupts = <GIC_SPI 62 IRQ_TYPE_LEVEL_HIGH>; + max-frequency = <200000000>; status = "disabled"; #address-cells = <1>; #size-cells = <0>; };
+ usb_otg: usb@01c19000 { + compatible = "allwinner,sun8i-a33-musb"; + reg = <0x01c19000 0x0400>; + clocks = <&ccu CLK_BUS_OTG>; + resets = <&ccu RST_BUS_OTG>; + interrupts = <GIC_SPI 71 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "mc"; + phys = <&usbphy 0>; + phy-names = "usb"; + extcon = <&usbphy 0>; + status = "disabled"; + }; + + usbphy: phy@01c19400 { + compatible = "allwinner,sun50i-a64-usb-phy"; + reg = <0x01c19400 0x14>, + <0x01c1a800 0x4>, + <0x01c1b800 0x4>; + reg-names = "phy_ctrl", + "pmu0", + "pmu1"; + clocks = <&ccu CLK_USB_PHY0>, + <&ccu CLK_USB_PHY1>; + clock-names = "usb0_phy", + "usb1_phy"; + resets = <&ccu RST_USB_PHY0>, + <&ccu RST_USB_PHY1>; + reset-names = "usb0_reset", + "usb1_reset"; + status = "disabled"; + #phy-cells = <1>; + }; + + ehci1: usb@01c1b000 { + compatible = "allwinner,sun50i-a64-ehci", "generic-ehci"; + reg = <0x01c1b000 0x100>; + interrupts = <GIC_SPI 74 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_OHCI1>, + <&ccu CLK_BUS_EHCI1>, + <&ccu CLK_USB_OHCI1>; + resets = <&ccu RST_BUS_OHCI1>, + <&ccu RST_BUS_EHCI1>; + phys = <&usbphy 1>; + phy-names = "usb"; + status = "disabled"; + }; + + ohci1: usb@01c1b400 { + compatible = "allwinner,sun50i-a64-ohci", "generic-ohci"; + reg = <0x01c1b400 0x100>; + interrupts = <GIC_SPI 75 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_OHCI1>, + <&ccu CLK_USB_OHCI1>; + resets = <&ccu RST_BUS_OHCI1>; + phys = <&usbphy 1>; + phy-names = "usb"; + status = "disabled"; + }; + + ccu: clock@01c20000 { + compatible = "allwinner,sun50i-a64-ccu"; + reg = <0x01c20000 0x400>; + clocks = <&osc24M>, <&osc32k>; + clock-names = "hosc", "losc"; + #clock-cells = <1>; + #reset-cells = <1>; + }; + pio: pinctrl@1c20800 { compatible = "allwinner,sun50i-a64-pinctrl"; reg = <0x01c20800 0x400>; interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 21 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&bus_gates 69>; + clocks = <&ccu 58>; gpio-controller; #gpio-cells = <3>; interrupt-controller; - #interrupt-cells = <2>; - - uart0_pins_a: uart0@0 { - allwinner,pins = "PB8", "PB9"; - allwinner,function = "uart0"; - allwinner,drive = <SUN4I_PINCTRL_10_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; - }; - - uart0_pins_b: uart0@1 { - allwinner,pins = "PF2", "PF3"; - allwinner,function = "uart0"; - allwinner,drive = <SUN4I_PINCTRL_10_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; - }; - - uart1_2pins: uart1_2@0 { - allwinner,pins = "PG6", "PG7"; - allwinner,function = "uart1"; - allwinner,drive = <SUN4I_PINCTRL_10_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; - }; - - uart1_4pins: uart1_4@0 { - allwinner,pins = "PG6", "PG7", "PG8", "PG9"; - allwinner,function = "uart1"; - allwinner,drive = <SUN4I_PINCTRL_10_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; - }; - - uart2_2pins: uart2_2@0 { - allwinner,pins = "PB0", "PB1"; - allwinner,function = "uart2"; - allwinner,drive = <SUN4I_PINCTRL_10_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; - }; - - uart2_4pins: uart2_4@0 { - allwinner,pins = "PB0", "PB1", "PB2", "PB3"; - allwinner,function = "uart2"; - allwinner,drive = <SUN4I_PINCTRL_10_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; - }; - - uart3_pins_a: uart3@0 { - allwinner,pins = "PD0", "PD1"; - allwinner,function = "uart3"; - allwinner,drive = <SUN4I_PINCTRL_10_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; - }; - - uart3_2pins_b: uart3_2@1 { - allwinner,pins = "PH4", "PH5"; - allwinner,function = "uart3"; - allwinner,drive = <SUN4I_PINCTRL_10_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; - }; + #interrupt-cells = <3>;
- uart3_4pins_b: uart3_4@1 { - allwinner,pins = "PH4", "PH5", "PH6", "PH7"; - allwinner,function = "uart3"; - allwinner,drive = <SUN4I_PINCTRL_10_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; - }; - - uart4_2pins: uart4_2@0 { - allwinner,pins = "PD2", "PD3"; - allwinner,function = "uart4"; - allwinner,drive = <SUN4I_PINCTRL_10_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; - }; - - uart4_4pins: uart4_4@0 { - allwinner,pins = "PD2", "PD3", "PD4", "PD5"; - allwinner,function = "uart4"; - allwinner,drive = <SUN4I_PINCTRL_10_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; - }; - - mmc0_pins: mmc0@0 { - allwinner,pins = "PF0", "PF1", "PF2", "PF3", - "PF4", "PF5"; - allwinner,function = "mmc0"; - allwinner,drive = <SUN4I_PINCTRL_30_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; - }; - - mmc0_default_cd_pin: mmc0_cd_pin@0 { - allwinner,pins = "PF6"; - allwinner,function = "gpio_in"; - allwinner,drive = <SUN4I_PINCTRL_10_MA>; - allwinner,pull = <SUN4I_PINCTRL_PULL_UP>; - }; - - mmc1_pins: mmc1@0 { - allwinner,pins = "PG0", "PG1", "PG2", "PG3", - "PG4", "PG5"; - allwinner,function = "mmc1"; - allwinner,drive = <SUN4I_PINCTRL_30_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + i2c1_pins: i2c1_pins { + pins = "PH2", "PH3"; + function = "i2c1"; };
- mmc2_pins: mmc2@0 { - allwinner,pins = "PC1", "PC5", "PC6", "PC8", - "PC9", "PC10"; - allwinner,function = "mmc2"; - allwinner,drive = <SUN4I_PINCTRL_30_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + mmc0_pins: mmc0-pins { + pins = "PF0", "PF1", "PF2", "PF3", + "PF4", "PF5"; + function = "mmc0"; + drive-strength = <30>; + bias-pull-up; };
- i2c0_pins: i2c0_pins { - allwinner,pins = "PH0", "PH1"; - allwinner,function = "i2c0"; - allwinner,drive = <SUN4I_PINCTRL_10_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + mmc1_pins: mmc1-pins { + pins = "PG0", "PG1", "PG2", "PG3", + "PG4", "PG5"; + function = "mmc1"; + drive-strength = <30>; + bias-pull-up; };
- i2c1_pins: i2c1_pins { - allwinner,pins = "PH2", "PH3"; - allwinner,function = "i2c1"; - allwinner,drive = <SUN4I_PINCTRL_10_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + mmc2_pins: mmc2-pins { + pins = "PC1", "PC5", "PC6", "PC8", "PC9", + "PC10","PC11", "PC12", "PC13", + "PC14", "PC15", "PC16"; + function = "mmc2"; + drive-strength = <30>; + bias-pull-up; };
- i2c2_pins: i2c2_pins { - allwinner,pins = "PE14", "PE15"; - allwinner,function = "i2c2"; - allwinner,drive = <SUN4I_PINCTRL_10_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + uart0_pins_a: uart0@0 { + pins = "PB8", "PB9"; + function = "uart0"; };
- rmii_pins: rmii_pins { - allwinner,pins = "PD10", "PD11", "PD13", "PD14", - "PD17", "PD18", "PD19", "PD20", - "PD22", "PD23"; - allwinner,function = "emac"; - allwinner,drive = <SUN4I_PINCTRL_40_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + uart1_pins: uart1_pins { + pins = "PG6", "PG7"; + function = "uart1"; };
- rgmii_pins: rgmii_pins { - allwinner,pins = "PD8", "PD9", "PD10", "PD11", - "PD12", "PD13", "PD15", - "PD16", "PD17", "PD18", "PD19", - "PD20", "PD21", "PD22", "PD23"; - allwinner,function = "emac"; - allwinner,drive = <SUN4I_PINCTRL_40_MA>; - allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + uart1_rts_cts_pins: uart1_rts_cts_pins { + pins = "PG8", "PG9"; + function = "uart1"; }; };
- ahb_rst: reset@1c202c0 { - #reset-cells = <1>; - compatible = "allwinner,sun6i-a31-clock-reset"; - reg = <0x01c202c0 0xc>; - }; - - apb1_rst: reset@1c202d0 { - #reset-cells = <1>; - compatible = "allwinner,sun6i-a31-clock-reset"; - reg = <0x01c202d0 0x4>; - }; - - apb2_rst: reset@1c202d8 { - #reset-cells = <1>; - compatible = "allwinner,sun6i-a31-clock-reset"; - reg = <0x01c202d8 0x4>; - }; - uart0: serial@1c28000 { compatible = "snps,dw-apb-uart"; reg = <0x01c28000 0x400>; interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>; reg-shift = <2>; reg-io-width = <4>; - clocks = <&bus_gates 112>; - resets = <&apb2_rst 16>; + clocks = <&ccu 67>; + resets = <&ccu 46>; status = "disabled"; };
@@ -562,8 +314,8 @@ interrupts = <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>; reg-shift = <2>; reg-io-width = <4>; - clocks = <&bus_gates 113>; - resets = <&apb2_rst 17>; + clocks = <&ccu 68>; + resets = <&ccu 47>; status = "disabled"; };
@@ -573,8 +325,8 @@ interrupts = <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>; reg-shift = <2>; reg-io-width = <4>; - clocks = <&bus_gates 114>; - resets = <&apb2_rst 18>; + clocks = <&ccu 69>; + resets = <&ccu 48>; status = "disabled"; };
@@ -584,8 +336,8 @@ interrupts = <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>; reg-shift = <2>; reg-io-width = <4>; - clocks = <&bus_gates 115>; - resets = <&apb2_rst 19>; + clocks = <&ccu 70>; + resets = <&ccu 49>; status = "disabled"; };
@@ -595,24 +347,17 @@ interrupts = <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>; reg-shift = <2>; reg-io-width = <4>; - clocks = <&bus_gates 116>; - resets = <&apb2_rst 20>; + clocks = <&ccu 71>; + resets = <&ccu 50>; status = "disabled"; };
- rtc: rtc@1f00000 { - compatible = "allwinner,sun6i-a31-rtc"; - reg = <0x01f00000 0x54>; - interrupts = <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>; - }; - i2c0: i2c@1c2ac00 { compatible = "allwinner,sun6i-a31-i2c"; reg = <0x01c2ac00 0x400>; interrupts = <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&bus_gates 96>; - resets = <&apb2_rst 0>; + clocks = <&ccu 63>; + resets = <&ccu 42>; status = "disabled"; #address-cells = <1>; #size-cells = <0>; @@ -622,8 +367,8 @@ compatible = "allwinner,sun6i-a31-i2c"; reg = <0x01c2b000 0x400>; interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&bus_gates 97>; - resets = <&apb2_rst 1>; + clocks = <&ccu 64>; + resets = <&ccu 43>; status = "disabled"; #address-cells = <1>; #size-cells = <0>; @@ -633,54 +378,50 @@ compatible = "allwinner,sun6i-a31-i2c"; reg = <0x01c2b400 0x400>; interrupts = <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&bus_gates 98>; - resets = <&apb2_rst 2>; + clocks = <&ccu 65>; + resets = <&ccu 44>; status = "disabled"; #address-cells = <1>; #size-cells = <0>; };
- emac: ethernet@01c30000 { - compatible = "allwinner,sun50i-a64-emac"; - reg = <0x01c30000 0x2000>, <0x01c00030 0x4>; - reg-names = "emac", "syscon"; - interrupts = <GIC_SPI 82 IRQ_TYPE_LEVEL_HIGH>; - resets = <&ahb_rst 17>; - reset-names = "ahb"; - clocks = <&bus_gates 17>; - clock-names = "ahb"; - status = "disabled"; - #address-cells = <1>; - #size-cells = <0>; + gic: interrupt-controller@1c81000 { + compatible = "arm,gic-400"; + reg = <0x01c81000 0x1000>, + <0x01c82000 0x2000>, + <0x01c84000 0x2000>, + <0x01c86000 0x2000>; + interrupts = <GIC_PPI 9 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>; + interrupt-controller; + #interrupt-cells = <3>; };
- usbphy: phy@1c1b810 { - compatible = "allwinner,sun50i-a64-usb-phy", - "allwinner,sun8i-a33-usb-phy"; - reg = <0x01c1b810 0x14>, <0x01c1b800 0x4>; - reg-names = "phy_ctrl", "pmu1"; - status = "disabled"; - #phy-cells = <1>; + rtc: rtc@1f00000 { + compatible = "allwinner,sun6i-a31-rtc"; + reg = <0x01f00000 0x54>; + interrupts = <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>; };
- ehci1: usb@01c1b000 { - compatible = "allwinner,sun50i-a64-ehci", - "generic-ehci"; - reg = <0x01c1b000 0x100>; - interrupts = <GIC_SPI 74 IRQ_TYPE_LEVEL_HIGH>; - phys = <&usbphy 1>; - phy-names = "usb"; - status = "disabled"; + r_ccu: clock@1f01400 { + compatible = "allwinner,sun50i-a64-r-ccu"; + reg = <0x01f01400 0x100>; + clocks = <&osc24M>, <&osc32k>, <&iosc>; + clock-names = "hosc", "losc", "iosc"; + #clock-cells = <1>; + #reset-cells = <1>; };
- ohci1: usb@01c1b400 { - compatible = "allwinner,sun50i-a64-ohci", - "generic-ohci"; - reg = <0x01c1b400 0x100>; - interrupts = <GIC_SPI 75 IRQ_TYPE_LEVEL_HIGH>; - phys = <&usbphy 1>; - phy-names = "usb"; - status = "enabled"; + r_pio: pinctrl@01f02c00 { + compatible = "allwinner,sun50i-a64-r-pinctrl"; + reg = <0x01f02c00 0x400>; + interrupts = <GIC_SPI 45 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&r_ccu 3>, <&osc24M>, <&osc32k>; + clock-names = "apb", "hosc", "losc"; + gpio-controller; + #gpio-cells = <3>; + interrupt-controller; + #interrupt-cells = <3>; }; }; }; diff --git a/include/dt-bindings/clock/sun50i-a64-ccu.h b/include/dt-bindings/clock/sun50i-a64-ccu.h new file mode 100644 index 0000000..370c0a0 --- /dev/null +++ b/include/dt-bindings/clock/sun50i-a64-ccu.h @@ -0,0 +1,134 @@ +/* + * Copyright (C) 2016 Maxime Ripard maxime.ripard@free-electrons.com + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +#ifndef _DT_BINDINGS_CLK_SUN50I_A64_H_ +#define _DT_BINDINGS_CLK_SUN50I_A64_H_ + +#define CLK_BUS_MIPI_DSI 28 +#define CLK_BUS_CE 29 +#define CLK_BUS_DMA 30 +#define CLK_BUS_MMC0 31 +#define CLK_BUS_MMC1 32 +#define CLK_BUS_MMC2 33 +#define CLK_BUS_NAND 34 +#define CLK_BUS_DRAM 35 +#define CLK_BUS_EMAC 36 +#define CLK_BUS_TS 37 +#define CLK_BUS_HSTIMER 38 +#define CLK_BUS_SPI0 39 +#define CLK_BUS_SPI1 40 +#define CLK_BUS_OTG 41 +#define CLK_BUS_EHCI0 42 +#define CLK_BUS_EHCI1 43 +#define CLK_BUS_OHCI0 44 +#define CLK_BUS_OHCI1 45 +#define CLK_BUS_VE 46 +#define CLK_BUS_TCON0 47 +#define CLK_BUS_TCON1 48 +#define CLK_BUS_DEINTERLACE 49 +#define CLK_BUS_CSI 50 +#define CLK_BUS_HDMI 51 +#define CLK_BUS_DE 52 +#define CLK_BUS_GPU 53 +#define CLK_BUS_MSGBOX 54 +#define CLK_BUS_SPINLOCK 55 +#define CLK_BUS_CODEC 56 +#define CLK_BUS_SPDIF 57 +#define CLK_BUS_PIO 58 +#define CLK_BUS_THS 59 +#define CLK_BUS_I2S0 60 +#define CLK_BUS_I2S1 61 +#define CLK_BUS_I2S2 62 +#define CLK_BUS_I2C0 63 +#define CLK_BUS_I2C1 64 +#define CLK_BUS_I2C2 65 +#define CLK_BUS_SCR 66 +#define CLK_BUS_UART0 67 +#define CLK_BUS_UART1 68 +#define CLK_BUS_UART2 69 +#define CLK_BUS_UART3 70 +#define CLK_BUS_UART4 71 +#define CLK_BUS_DBG 72 +#define CLK_THS 73 +#define CLK_NAND 74 +#define CLK_MMC0 75 +#define CLK_MMC1 76 +#define CLK_MMC2 77 +#define CLK_TS 78 +#define CLK_CE 79 +#define CLK_SPI0 80 +#define CLK_SPI1 81 +#define CLK_I2S0 82 +#define CLK_I2S1 83 +#define CLK_I2S2 84 +#define CLK_SPDIF 85 +#define CLK_USB_PHY0 86 +#define CLK_USB_PHY1 87 +#define CLK_USB_HSIC 88 +#define CLK_USB_HSIC_12M 89 + +#define CLK_USB_OHCI0 91 + +#define CLK_USB_OHCI1 93 + +#define CLK_DRAM_VE 95 +#define CLK_DRAM_CSI 96 +#define CLK_DRAM_DEINTERLACE 97 +#define CLK_DRAM_TS 98 +#define CLK_DE 99 +#define CLK_TCON0 100 +#define CLK_TCON1 101 +#define CLK_DEINTERLACE 102 +#define CLK_CSI_MISC 103 +#define CLK_CSI_SCLK 104 +#define CLK_CSI_MCLK 105 +#define CLK_VE 106 +#define CLK_AC_DIG 107 +#define CLK_AC_DIG_4X 108 +#define CLK_AVS 109 +#define CLK_HDMI 110 +#define CLK_HDMI_DDC 111 + +#define CLK_DSI_DPHY 113 +#define CLK_GPU 114 + +#endif /* _DT_BINDINGS_CLK_SUN50I_H_ */ diff --git a/include/dt-bindings/reset/sun50i-a64-ccu.h b/include/dt-bindings/reset/sun50i-a64-ccu.h new file mode 100644 index 0000000..db60b29 --- /dev/null +++ b/include/dt-bindings/reset/sun50i-a64-ccu.h @@ -0,0 +1,98 @@ +/* + * Copyright (C) 2016 Maxime Ripard maxime.ripard@free-electrons.com + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +#ifndef _DT_BINDINGS_RST_SUN50I_A64_H_ +#define _DT_BINDINGS_RST_SUN50I_A64_H_ + +#define RST_USB_PHY0 0 +#define RST_USB_PHY1 1 +#define RST_USB_HSIC 2 +#define RST_DRAM 3 +#define RST_MBUS 4 +#define RST_BUS_MIPI_DSI 5 +#define RST_BUS_CE 6 +#define RST_BUS_DMA 7 +#define RST_BUS_MMC0 8 +#define RST_BUS_MMC1 9 +#define RST_BUS_MMC2 10 +#define RST_BUS_NAND 11 +#define RST_BUS_DRAM 12 +#define RST_BUS_EMAC 13 +#define RST_BUS_TS 14 +#define RST_BUS_HSTIMER 15 +#define RST_BUS_SPI0 16 +#define RST_BUS_SPI1 17 +#define RST_BUS_OTG 18 +#define RST_BUS_EHCI0 19 +#define RST_BUS_EHCI1 20 +#define RST_BUS_OHCI0 21 +#define RST_BUS_OHCI1 22 +#define RST_BUS_VE 23 +#define RST_BUS_TCON0 24 +#define RST_BUS_TCON1 25 +#define RST_BUS_DEINTERLACE 26 +#define RST_BUS_CSI 27 +#define RST_BUS_HDMI0 28 +#define RST_BUS_HDMI1 29 +#define RST_BUS_DE 30 +#define RST_BUS_GPU 31 +#define RST_BUS_MSGBOX 32 +#define RST_BUS_SPINLOCK 33 +#define RST_BUS_DBG 34 +#define RST_BUS_LVDS 35 +#define RST_BUS_CODEC 36 +#define RST_BUS_SPDIF 37 +#define RST_BUS_THS 38 +#define RST_BUS_I2S0 39 +#define RST_BUS_I2S1 40 +#define RST_BUS_I2S2 41 +#define RST_BUS_I2C0 42 +#define RST_BUS_I2C1 43 +#define RST_BUS_I2C2 44 +#define RST_BUS_SCR 45 +#define RST_BUS_UART0 46 +#define RST_BUS_UART1 47 +#define RST_BUS_UART2 48 +#define RST_BUS_UART3 49 +#define RST_BUS_UART4 50 + +#endif /* _DT_BINDINGS_RST_SUN50I_A64_H_ */
Acked-by: Maxime Ripard maxime.ripard@free-electrons.com
Maxime
As the kernel DT does not have an Ethernet driver and bindings, lets (re-)add the DT bindings for U-Boot's sun8i EMAC Ethernet driver, which got lost when syncing the kernel DT to U-Boot. This slightly updates the DT nodes to adapt to the new DT (clock and reset nodes), but keeps the rest the same to let it work with the existing U-Boot driver.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- arch/arm/dts/sun50i-a64-pine64-plus.dts | 14 +++++++++++++- arch/arm/dts/sun50i-a64-pine64.dts | 1 + arch/arm/dts/sun50i-a64.dtsi | 33 +++++++++++++++++++++++++++++++++ 3 files changed, 47 insertions(+), 1 deletion(-)
diff --git a/arch/arm/dts/sun50i-a64-pine64-plus.dts b/arch/arm/dts/sun50i-a64-pine64-plus.dts index 790d14d..948cb19 100644 --- a/arch/arm/dts/sun50i-a64-pine64-plus.dts +++ b/arch/arm/dts/sun50i-a64-pine64-plus.dts @@ -46,5 +46,17 @@ model = "Pine64+"; compatible = "pine64,pine64-plus", "allwinner,sun50i-a64";
- /* TODO: Camera, Ethernet PHY, touchscreen, etc. */ + /* TODO: Camera, touchscreen, etc. */ +}; + +&emac { + pinctrl-names = "default"; + pinctrl-0 = <&rgmii_pins>; + phy-mode = "rgmii"; + phy = <&phy1>; + status = "okay"; + + phy1: ethernet-phy@1 { + reg = <1>; + }; }; diff --git a/arch/arm/dts/sun50i-a64-pine64.dts b/arch/arm/dts/sun50i-a64-pine64.dts index c680ed3..6c15040 100644 --- a/arch/arm/dts/sun50i-a64-pine64.dts +++ b/arch/arm/dts/sun50i-a64-pine64.dts @@ -52,6 +52,7 @@
aliases { serial0 = &uart0; + ethernet0 = &emac; };
chosen { diff --git a/arch/arm/dts/sun50i-a64.dtsi b/arch/arm/dts/sun50i-a64.dtsi index c7f669f..121e660 100644 --- a/arch/arm/dts/sun50i-a64.dtsi +++ b/arch/arm/dts/sun50i-a64.dtsi @@ -295,6 +295,25 @@ pins = "PG8", "PG9"; function = "uart1"; }; + + rmii_pins: rmii_pins { + allwinner,pins = "PD10", "PD11", "PD13", "PD14", + "PD17", "PD18", "PD19", "PD20", + "PD22", "PD23"; + allwinner,function = "emac"; + allwinner,drive = <3>; + allwinner,pull = <0>; + }; + + rgmii_pins: rgmii_pins { + allwinner,pins = "PD8", "PD9", "PD10", "PD11", + "PD12", "PD13", "PD15", + "PD16", "PD17", "PD18", "PD19", + "PD20", "PD21", "PD22", "PD23"; + allwinner,function = "emac"; + allwinner,drive = <3>; + allwinner,pull = <0>; + }; };
uart0: serial@1c28000 { @@ -423,5 +442,19 @@ interrupt-controller; #interrupt-cells = <3>; }; + + emac: ethernet@01c30000 { + compatible = "allwinner,sun50i-a64-emac"; + reg = <0x01c30000 0x2000>, <0x01c00030 0x4>; + reg-names = "emac", "syscon"; + interrupts = <GIC_SPI 82 IRQ_TYPE_LEVEL_HIGH>; + resets = <&ccu RST_BUS_EMAC>; + reset-names = "ahb"; + clocks = <&ccu CLK_BUS_EMAC>; + clock-names = "ahb"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <0>; + }; }; };
Maxime
NAK, please start making use of -u-boot.dtsi files for these so they won't keep getting lost.
Hi Tom,
Ah, thanks for the heads up, wasn't aware of that. I changed this patch, it looks quite neat now since this non-standard binding is now in a separate file and the original .dts files match exactly the Linux versions. Also it is expected that we will need to change these nodes anyway to match the upcoming Linux Ethernet bindings.
One thing I noticed is that the binman/ node got lost with this approach, is that because the -u-boot.dtsi scheme can only deal with one addon file and stops looking on the first hit (skipping sunxi-u-boot.dtsi)?
Cheers, Andre.
On Tue, May 23, 2017 at 10:32:06AM +0100, Andre Przywara wrote:
Hi Tom,
Ah, I think we've found another problem to fix then, yes. Today we only allow one -u-boot.dtsi, but really we should allow for N of them, and allow for more specific ones (ie board-u-boot.dtsi) to override less specific (ie soc-u-boot.dtsi) ones, just like regular DTS files, thanks!
Andre Przywara
Maxime Ripard
