[U-Boot] [PATCH v2] spi: soft_spi: Fix for soft_spi
This patch series, fix a null ptr inside soft_spi.
This version address comments from Jagan Teki jagan@amarulasolutions.com
v2 changes: - update soft_spi_platdata inside .set_mode.
Horatiu Vultur (1): spi: soft_spi: Fix null ptr when probing soft_spi.
drivers/spi/soft_spi.c | 15 ++++++++------- 1 file changed, 8 insertions(+), 7 deletions(-)
When probing soft_spi the result of dev_get_parent_priv(dev) in probe function is null ptr because the spi is on the ahb bus which has per_child_auto_alloc_size set to 0. Therefore it would generate an Ooops messages when accessing spi_slave structure.
The fix consist of updating the soft_spi_platdata flags inside the .set_mode.
Signed-off-by: Horatiu Vultur horatiu.vultur@microchip.com --- drivers/spi/soft_spi.c | 15 ++++++++------- 1 file changed, 8 insertions(+), 7 deletions(-)
diff --git a/drivers/spi/soft_spi.c b/drivers/spi/soft_spi.c index b06883f..2c47577 100644 --- a/drivers/spi/soft_spi.c +++ b/drivers/spi/soft_spi.c @@ -183,9 +183,15 @@ static int soft_spi_set_speed(struct udevice *dev, unsigned int speed) static int soft_spi_set_mode(struct udevice *dev, unsigned int mode) { struct soft_spi_priv *priv = dev_get_priv(dev); + struct soft_spi_platdata *plat = dev->platdata;
priv->mode = mode;
+ if (!(mode & SPI_CS_HIGH)) + plat->cs.flags |= GPIOD_ACTIVE_LOW; + if (mode & SPI_CPOL) + plat->sclk.flags |= GPIOD_ACTIVE_LOW; + return 0; }
@@ -210,18 +216,13 @@ static int soft_spi_ofdata_to_platdata(struct udevice *dev)
static int soft_spi_probe(struct udevice *dev) { - struct spi_slave *slave = dev_get_parent_priv(dev); struct soft_spi_platdata *plat = dev->platdata; - int cs_flags, clk_flags; int ret;
- cs_flags = (slave->mode & SPI_CS_HIGH) ? 0 : GPIOD_ACTIVE_LOW; - clk_flags = (slave->mode & SPI_CPOL) ? GPIOD_ACTIVE_LOW : 0; - if (gpio_request_by_name(dev, "cs-gpios", 0, &plat->cs, - GPIOD_IS_OUT | cs_flags) || + GPIOD_IS_OUT) || gpio_request_by_name(dev, "gpio-sck", 0, &plat->sclk, - GPIOD_IS_OUT | clk_flags)) + GPIOD_IS_OUT)) return -EINVAL;
ret = gpio_request_by_name(dev, "gpio-mosi", 0, &plat->mosi,
Am 07.01.19 um 09:20 schrieb Horatiu Vultur:
is this patch still required with https://patchwork.ozlabs.org/cover/1021335/ ?
priv->mode = mode;
don't you need to manually set the initial state of CS and CLK now? This was previously done by gpio_request_by_name(). That's why the driver needed to know the low-active bits early.
return 0; }
gpio_request_by_name(dev, "gpio-sck", 0, &plat->sclk,GPIOD_IS_OUT) ||
GPIOD_IS_OUT))
return -EINVAL;
This patch is not required if you will take in https://patchwork.ozlabs.org/cover/1021335.
priv->mode = mode;
No, because it is still using gpio_request_by_name() and that one will set the initial values for CS and CLK. And now in the .set_mode() we just update the CS and CLK, which is called before probing the spi.
return 0; }
GPIOD_IS_OUT))
return -EINVAL;
- Daniel
Daniel Schwierzeck
Horatiu Vultur
