[U-Boot] [PATCH 0/4] OMAP3 pandora: pin mux updates
This patch series clean up and update pin mux for pandora. The update is needed for rev3 or later boards to work properly, but older boards still work after this.
Grazvydas Ignotas (4): OMAP3 pandora: pin mux cleanup OMAP3 pandora: setup pin mux for pins used on rev3 boards OMAP3 pandora: setup pulls for various GPIOs OMAP3 pandora: Fix CKE1 MUX setting to allow self-refresh
board/omap3/pandora/pandora.h | 86 +++++++++++++++++------------------------ 1 files changed, 35 insertions(+), 51 deletions(-)
Remove configuration of not unused pins, effectively leaving them in safe mode. --- board/omap3/pandora/pandora.h | 25 ------------------------- 1 files changed, 0 insertions(+), 25 deletions(-)
diff --git a/board/omap3/pandora/pandora.h b/board/omap3/pandora/pandora.h index 8f0838c..3d04b2a 100644 --- a/board/omap3/pandora/pandora.h +++ b/board/omap3/pandora/pandora.h @@ -107,15 +107,6 @@ const omap3_sysinfo sysinfo = { MUX_VAL(CP(GPMC_D15), (IEN | PTD | DIS | M0)) /*GPMC_D15*/\ MUX_VAL(CP(GPMC_NCS0), (IDIS | PTU | EN | M0)) /*GPMC_nCS0*/\ MUX_VAL(CP(GPMC_NCS1), (IDIS | PTU | EN | M0)) /*GPMC_nCS1*/\ - MUX_VAL(CP(GPMC_NCS2), (IDIS | PTU | EN | M0)) /*GPMC_nCS2*/\ - MUX_VAL(CP(GPMC_NCS3), (IDIS | PTU | EN | M0)) /*GPMC_nCS3*/\ - MUX_VAL(CP(GPMC_NCS4), (IDIS | PTU | EN | M0))\ - MUX_VAL(CP(GPMC_NCS5), (IDIS | PTD | DIS | M0))\ - MUX_VAL(CP(GPMC_NCS6), (IEN | PTD | DIS | M1))\ - MUX_VAL(CP(GPMC_NCS7), (IEN | PTU | EN | M1))\ - MUX_VAL(CP(GPMC_NBE1), (IEN | PTD | DIS | M0))\ - MUX_VAL(CP(GPMC_WAIT2), (IEN | PTU | EN | M0))\ - MUX_VAL(CP(GPMC_WAIT3), (IEN | PTU | EN | M0))\ MUX_VAL(CP(GPMC_CLK), (IDIS | PTD | DIS | M0)) /*GPMC_CLK*/\ MUX_VAL(CP(GPMC_NADV_ALE), (IDIS | PTD | DIS | M0)) /*GPMC_nADV_ALE*/\ MUX_VAL(CP(GPMC_NOE), (IDIS | PTD | DIS | M0)) /*GPMC_nOE*/\ @@ -254,16 +245,10 @@ const omap3_sysinfo sysinfo = { MUX_VAL(CP(CAM_WEN), (IEN | PTU | DIS | M4)) /*GPIO_167*/\ /* - nIRQ_NUB2*/\ /*Various other stuff*/\ - MUX_VAL(CP(CAM_VS), (IEN | PTU | DIS | M4)) /*GPIO_95*/\ - /* - nTOUCH_BUSY*/\ MUX_VAL(CP(UART3_CTS_RCTX), (IEN | PTD | DIS | M4)) /*GPIO_163*/\ /* - nOC_USB5*/\ - MUX_VAL(CP(MCBSP1_CLKX), (IDIS | PTD | DIS | M4)) /*GPIO_162*/\ - /* - START_ADC*/\ MUX_VAL(CP(ETK_D8_ES2), (IEN | PTD | DIS | M4)) /*GPIO_22*/\ /* - MSECURE*/\ - MUX_VAL(CP(CAM_STROBE), (IEN | PTU | DIS | M4)) /*GPIO_126*/\ - /* - HP_DETECT*/\ /*External Resets and Enables*/\ MUX_VAL(CP(ETK_D0_ES2), (IDIS | PTD | DIS | M4)) /*GPIO_14*/\ /* - nHDPHN_SHUTDOWN*/\ @@ -277,14 +262,6 @@ const omap3_sysinfo sysinfo = { /* - RESET_NUBS*/\ MUX_VAL(CP(UART3_RTS_SD), (IDIS | PTU | EN | M4)) /*GPIO_164*/\ /* - EN_USB_5V*/\ - /*Unused*/\ - MUX_VAL(CP(HDQ_SIO), (IEN | PTU | EN | M0)) /*HDQ_SIO - NC*/\ - MUX_VAL(CP(CSI2_DX0), (IEN | PTD | DIS | M0)) /*CSI2_DX0 - NC*/\ - MUX_VAL(CP(CSI2_DY0), (IEN | PTD | DIS | M0)) /*CSI2_DY0 - NC*/\ - MUX_VAL(CP(CSI2_DX1), (IEN | PTD | DIS | M0)) /*CSI2_DX1 - NC*/\ - MUX_VAL(CP(CSI2_DY1), (IEN | PTD | DIS | M0)) /*CSI2_DY1 - NC*/\ - MUX_VAL(CP(I2C2_SCL), (IEN | PTU | EN | M0)) /*I2C2_SCL - NC*/\ - MUX_VAL(CP(I2C2_SDA), (IEN | PTU | EN | M0)) /*I2C2_SDA - NC*/\ /*HS USB OTG Port (connects to HSUSB0)*/\ MUX_VAL(CP(HSUSB0_CLK), (IEN | PTD | DIS | M0)) /*HSUSB0_CLK*/\ MUX_VAL(CP(HSUSB0_STP), (IDIS | PTU | EN | M0)) /*HSUSB0_STP*/\ @@ -338,8 +315,6 @@ const omap3_sysinfo sysinfo = { MUX_VAL(CP(SYS_BOOT5), (IEN | PTD | DIS | M4)) /*GPIO_7*/\ MUX_VAL(CP(SYS_BOOT6), (IEN | PTD | DIS | M4)) /*GPIO_8*/\ MUX_VAL(CP(SYS_OFF_MODE), (IEN | PTD | DIS | M0)) /*SYS_OFF_MODE*/\ - MUX_VAL(CP(SYS_CLKOUT1), (IEN | PTD | DIS | M4)) /*SYS_CLKOUT1 - NC*/\ - MUX_VAL(CP(SYS_CLKOUT2), (IEN | PTD | DIS | M4)) /*SYS_CLKOUT2 - NC*/\ /*JTAG*/\ MUX_VAL(CP(JTAG_nTRST), (IEN | PTD | DIS | M0)) /*JTAG_nTRST*/\ MUX_VAL(CP(JTAG_TCK), (IEN | PTD | DIS | M0)) /*JTAG_TCK*/\
Setup pin mux for GPIO pins connected on rev3 or later boards. Also change NUB2 IRQ pin. This should not affect older boards because they don't have any nubs (analog controllers) attached to them. --- board/omap3/pandora/pandora.h | 11 ++++++++++- 1 files changed, 10 insertions(+), 1 deletions(-)
diff --git a/board/omap3/pandora/pandora.h b/board/omap3/pandora/pandora.h index 3d04b2a..1bd3d30 100644 --- a/board/omap3/pandora/pandora.h +++ b/board/omap3/pandora/pandora.h @@ -242,13 +242,15 @@ const omap3_sysinfo sysinfo = { /* - WIFI_IRQ*/\ MUX_VAL(CP(MCBSP1_FSX), (IEN | PTD | DIS | M4)) /*GPIO_161*/\ /* - nIRQ_NUB1*/\ - MUX_VAL(CP(CAM_WEN), (IEN | PTU | DIS | M4)) /*GPIO_167*/\ + MUX_VAL(CP(MCBSP1_CLKX), (IEN | PTU | DIS | M4)) /*GPIO_162*/\ /* - nIRQ_NUB2*/\ /*Various other stuff*/\ MUX_VAL(CP(UART3_CTS_RCTX), (IEN | PTD | DIS | M4)) /*GPIO_163*/\ /* - nOC_USB5*/\ MUX_VAL(CP(ETK_D8_ES2), (IEN | PTD | DIS | M4)) /*GPIO_22*/\ /* - MSECURE*/\ + MUX_VAL(CP(CSI2_DY1), (IEN | PTD | DIS | M4)) /*GPIO_115*/\ + /* - POP_OVERHEAT*/\ /*External Resets and Enables*/\ MUX_VAL(CP(ETK_D0_ES2), (IDIS | PTD | DIS | M4)) /*GPIO_14*/\ /* - nHDPHN_SHUTDOWN*/\ @@ -262,6 +264,13 @@ const omap3_sysinfo sysinfo = { /* - RESET_NUBS*/\ MUX_VAL(CP(UART3_RTS_SD), (IDIS | PTU | EN | M4)) /*GPIO_164*/\ /* - EN_USB_5V*/\ + /*Spare GPIOs*/\ + MUX_VAL(CP(GPMC_NCS7), (IEN | PTD | EN | M4)) /*GPIO_58*/\ + MUX_VAL(CP(GPMC_WAIT2), (IEN | PTD | EN | M4)) /*GPIO_64*/\ + MUX_VAL(CP(GPMC_WAIT3), (IEN | PTD | EN | M4)) /*GPIO_65*/\ + MUX_VAL(CP(CAM_VS), (IEN | PTU | EN | M4)) /*GPIO_95*/\ + MUX_VAL(CP(CAM_WEN), (IEN | PTD | EN | M4)) /*GPIO_167*/\ + MUX_VAL(CP(HDQ_SIO), (IEN | PTD | EN | M4)) /*GPIO_170*/\ /*HS USB OTG Port (connects to HSUSB0)*/\ MUX_VAL(CP(HSUSB0_CLK), (IEN | PTD | DIS | M0)) /*HSUSB0_CLK*/\ MUX_VAL(CP(HSUSB0_STP), (IDIS | PTU | EN | M0)) /*HSUSB0_STP*/\
Set pullups or pulldowns for GPIOs which need them. Disable them for others, which have external pulls. Also make disabled pull setting consistent (some pins had type set to "up" even if pull type selection was disabled). --- board/omap3/pandora/pandora.h | 50 ++++++++++++++++++++-------------------- 1 files changed, 25 insertions(+), 25 deletions(-)
diff --git a/board/omap3/pandora/pandora.h b/board/omap3/pandora/pandora.h index 1bd3d30..dfaf32f 100644 --- a/board/omap3/pandora/pandora.h +++ b/board/omap3/pandora/pandora.h @@ -145,26 +145,26 @@ const omap3_sysinfo sysinfo = { MUX_VAL(CP(DSS_DATA22), (IDIS | PTD | DIS | M0)) /*DSS_DATA22*/\ MUX_VAL(CP(DSS_DATA23), (IDIS | PTD | DIS | M0)) /*DSS_DATA23*/\ /*GPIO based game buttons*/\ - MUX_VAL(CP(CAM_XCLKA), (IEN | PTU | DIS | M4)) /*GPIO_96 - LEFT*/\ - MUX_VAL(CP(CAM_PCLK), (IEN | PTU | DIS | M4)) /*GPIO_97 - L2*/\ - MUX_VAL(CP(CAM_FLD), (IEN | PTU | DIS | M4)) /*GPIO_98 - RIGHT*/\ - MUX_VAL(CP(CAM_D0), (IEN | PTU | DIS | M4)) /*GPIO_99 - MENU*/\ - MUX_VAL(CP(CAM_D1), (IEN | PTU | DIS | M4)) /*GPIO_100 - START*/\ - MUX_VAL(CP(CAM_D2), (IEN | PTU | DIS | M4)) /*GPIO_101 - Y*/\ - MUX_VAL(CP(CAM_D3), (IEN | PTU | DIS | M4)) /*GPIO_102 - L1*/\ - MUX_VAL(CP(CAM_D4), (IEN | PTU | DIS | M4)) /*GPIO_103 - DOWN*/\ - MUX_VAL(CP(CAM_D5), (IEN | PTU | DIS | M4)) /*GPIO_104 - SELECT*/\ - MUX_VAL(CP(CAM_D6), (IEN | PTU | DIS | M4)) /*GPIO_105 - R1*/\ - MUX_VAL(CP(CAM_D7), (IEN | PTU | DIS | M4)) /*GPIO_106 - B*/\ - MUX_VAL(CP(CAM_D8), (IEN | PTU | DIS | M4)) /*GPIO_107 - R2*/\ - MUX_VAL(CP(CAM_D10), (IEN | PTU | DIS | M4)) /*GPIO_109 - X*/\ - MUX_VAL(CP(CAM_D11), (IEN | PTU | DIS | M4)) /*GPIO_110 - UP*/\ - MUX_VAL(CP(CAM_XCLKB), (IEN | PTU | DIS | M4)) /*GPIO_111 - A*/\ + MUX_VAL(CP(CAM_XCLKA), (IEN | PTD | DIS | M4)) /*GPIO_96 - LEFT*/\ + MUX_VAL(CP(CAM_PCLK), (IEN | PTD | DIS | M4)) /*GPIO_97 - L2*/\ + MUX_VAL(CP(CAM_FLD), (IEN | PTD | DIS | M4)) /*GPIO_98 - RIGHT*/\ + MUX_VAL(CP(CAM_D0), (IEN | PTD | DIS | M4)) /*GPIO_99 - MENU*/\ + MUX_VAL(CP(CAM_D1), (IEN | PTD | DIS | M4)) /*GPIO_100 - START*/\ + MUX_VAL(CP(CAM_D2), (IEN | PTD | DIS | M4)) /*GPIO_101 - Y*/\ + MUX_VAL(CP(CAM_D3), (IEN | PTD | DIS | M4)) /*GPIO_102 - L1*/\ + MUX_VAL(CP(CAM_D4), (IEN | PTD | DIS | M4)) /*GPIO_103 - DOWN*/\ + MUX_VAL(CP(CAM_D5), (IEN | PTD | DIS | M4)) /*GPIO_104 - SELECT*/\ + MUX_VAL(CP(CAM_D6), (IEN | PTD | DIS | M4)) /*GPIO_105 - R1*/\ + MUX_VAL(CP(CAM_D7), (IEN | PTD | DIS | M4)) /*GPIO_106 - B*/\ + MUX_VAL(CP(CAM_D8), (IEN | PTD | DIS | M4)) /*GPIO_107 - R2*/\ + MUX_VAL(CP(CAM_D10), (IEN | PTD | DIS | M4)) /*GPIO_109 - X*/\ + MUX_VAL(CP(CAM_D11), (IEN | PTD | DIS | M4)) /*GPIO_110 - UP*/\ + MUX_VAL(CP(CAM_XCLKB), (IEN | PTD | DIS | M4)) /*GPIO_111 - A*/\ /*Audio Interface To External DAC (Headphone, Speakers)*/\ MUX_VAL(CP(MCBSP2_FSX), (IDIS | PTD | DIS | M0)) /*McBSP2_FSX*/\ MUX_VAL(CP(MCBSP2_CLKX), (IDIS | PTD | DIS | M0)) /*McBSP2_CLKX*/\ MUX_VAL(CP(MCBSP2_DX), (IDIS | PTD | DIS | M0)) /*McBSP2_DX*/\ - MUX_VAL(CP(MCBSP_CLKS), (IEN | PTU | DIS | M0)) /*McBSP_CLKS*/\ + MUX_VAL(CP(MCBSP_CLKS), (IEN | PTD | DIS | M0)) /*McBSP_CLKS*/\ MUX_VAL(CP(MCBSP2_DR), (IDIS | PTD | DIS | M4)) /*GPIO_118*/\ /* - nPOWERDOWN_DAC*/\ /*Expansion card 1*/\ @@ -210,13 +210,13 @@ const omap3_sysinfo sysinfo = { MUX_VAL(CP(MCBSP4_DX), (IDIS | PTD | DIS | M0)) /*McBSP4_DX*/\ MUX_VAL(CP(MCBSP4_FSX), (IEN | PTD | DIS | M0)) /*McBSP4_FSX*/\ /*GPIO definitions for muxed pins on AV connector*/\ - MUX_VAL(CP(UART2_CTS), (IEN | PTU | EN | M4)) /*GPIO_144,*/\ + MUX_VAL(CP(UART2_CTS), (IEN | PTD | EN | M4)) /*GPIO_144,*/\ /*UART2_CTS*/\ - MUX_VAL(CP(UART2_RTS), (IEN | PTU | DIS | M4)) /*GPIO_145,*/\ + MUX_VAL(CP(UART2_RTS), (IEN | PTD | EN | M4)) /*GPIO_145,*/\ /*UART2_RTS*/\ - MUX_VAL(CP(UART2_TX), (IEN | PTU | EN | M4)) /*GPIO_146,*/\ + MUX_VAL(CP(UART2_TX), (IEN | PTD | EN | M4)) /*GPIO_146,*/\ /*UART2_TX*/\ - MUX_VAL(CP(UART2_RX), (IEN | PTD | DIS | M4)) /*GPIO_147,*/\ + MUX_VAL(CP(UART2_RX), (IEN | PTD | EN | M4)) /*GPIO_147,*/\ /*UART2_RX*/\ /*Serial Interface (Peripheral boot, Linux console, on AV connector)*/\ MUX_VAL(CP(UART3_RX_IRRX), (IEN | PTD | DIS | M0)) /*UART3_RX*/\ @@ -231,18 +231,18 @@ const omap3_sysinfo sysinfo = { MUX_VAL(CP(MCBSP1_DR), (IDIS | PTD | DIS | M4)) /*GPIO_159*/\ /* - LED_WIFI*/\ /*Switches*/\ - MUX_VAL(CP(MCSPI1_CS2), (IEN | PTU | DIS | M4)) /*GPIO_176*/\ + MUX_VAL(CP(MCSPI1_CS2), (IEN | PTD | DIS | M4)) /*GPIO_176*/\ /* - nHOLD_SWITCH*/\ - MUX_VAL(CP(CAM_D9), (IEN | PTU | DIS | M4)) /*GPIO_108*/\ + MUX_VAL(CP(CAM_D9), (IEN | PTD | DIS | M4)) /*GPIO_108*/\ /* - nLID_SWITCH*/\ /*External IRQs*/\ - MUX_VAL(CP(CAM_HS), (IEN | PTU | DIS | M4)) /*GPIO_94*/\ + MUX_VAL(CP(CAM_HS), (IEN | PTD | DIS | M4)) /*GPIO_94*/\ /* - nTOUCH_IRQ*/\ MUX_VAL(CP(ETK_D7_ES2), (IEN | PTD | DIS | M4)) /*GPIO_21*/\ /* - WIFI_IRQ*/\ MUX_VAL(CP(MCBSP1_FSX), (IEN | PTD | DIS | M4)) /*GPIO_161*/\ /* - nIRQ_NUB1*/\ - MUX_VAL(CP(MCBSP1_CLKX), (IEN | PTU | DIS | M4)) /*GPIO_162*/\ + MUX_VAL(CP(MCBSP1_CLKX), (IEN | PTD | DIS | M4)) /*GPIO_162*/\ /* - nIRQ_NUB2*/\ /*Various other stuff*/\ MUX_VAL(CP(UART3_CTS_RCTX), (IEN | PTD | DIS | M4)) /*GPIO_163*/\ @@ -262,7 +262,7 @@ const omap3_sysinfo sysinfo = { /* - nLCD_RESET*/\ MUX_VAL(CP(MCBSP1_CLKR), (IDIS | PTD | DIS | M4)) /*GPIO_156*/\ /* - RESET_NUBS*/\ - MUX_VAL(CP(UART3_RTS_SD), (IDIS | PTU | EN | M4)) /*GPIO_164*/\ + MUX_VAL(CP(UART3_RTS_SD), (IDIS | PTD | DIS | M4)) /*GPIO_164*/\ /* - EN_USB_5V*/\ /*Spare GPIOs*/\ MUX_VAL(CP(GPMC_NCS7), (IEN | PTD | EN | M4)) /*GPIO_58*/\
Pandora is using both SDRC CSes. The MUX setting is needed for the second CS clock signal to allow the 2 RAM parts to be put in self-refresh correctly.
Based on similar patch for beagle and overo by Jean Pihet and Steve Sakoman. --- board/omap3/pandora/pandora.h | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/board/omap3/pandora/pandora.h b/board/omap3/pandora/pandora.h index dfaf32f..f06ee5b 100644 --- a/board/omap3/pandora/pandora.h +++ b/board/omap3/pandora/pandora.h @@ -396,6 +396,6 @@ const omap3_sysinfo sysinfo = { MUX_VAL(CP(D2D_MBUSFLAG), (IEN | PTD | DIS | M0)) /*d2d_mbusflag*/\ MUX_VAL(CP(D2D_SBUSFLAG), (IEN | PTD | DIS | M0)) /*d2d_sbusflag*/\ MUX_VAL(CP(SDRC_CKE0), (IDIS | PTU | EN | M0)) /*sdrc_cke0*/\ - MUX_VAL(CP(SDRC_CKE1), (IDIS | PTD | DIS | M7)) /*sdrc_cke1*/ + MUX_VAL(CP(SDRC_CKE1), (IDIS | PTU | EN | M0)) /*sdrc_cke1*/
#endif
what is the status of the precedent rev at the end of the patch series?
Best Regards, J.
On Thu, Jul 9, 2009 at 1:44 AM, Jean-Christophe PLAGNIOL-VILLARDplagnioj@jcrosoft.com wrote:
Works fine except one analog controller, but I have the only rev2 board with them and don't mind about that. All other boards with analog controllers are rev3 and need these patches to work.
Grazvydas Ignotas
