[PATCH v1 0/2] Fix kmeter1 support
Fix kmeter1 support after testing next branch on board.
I try to add this board to my daily u-boot mainline tests with tbot:
http://xeidos.ddns.net/ubtestresults/home
Changes only in kmeter1_defconfig needed.
Patches are based against next branch, commit * 0ac83d080a - Merge branch 'next' of https://gitlab.denx.de/u-boot/custodians/u-boot-x86 into next
If needed, I can do a rebase to master...
Heiko Schocher (2): mpc83xx: kmeter1_defconfig add missing BAT4 config mpc83xx: kmeter1: increase malloc_f space
configs/kmeter1_defconfig | 7 +++++++ 1 file changed, 7 insertions(+)
BAT4 setup missed in defconfig, add it.
Signed-off-by: Heiko Schocher hs@denx.de ---
configs/kmeter1_defconfig | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/configs/kmeter1_defconfig b/configs/kmeter1_defconfig index f24b7aafc0..05967e11b1 100644 --- a/configs/kmeter1_defconfig +++ b/configs/kmeter1_defconfig @@ -60,6 +60,12 @@ CONFIG_BAT3_DCACHE_INHIBITED=y CONFIG_BAT3_DCACHE_GUARDED=y CONFIG_BAT3_USER_MODE_VALID=y CONFIG_BAT3_SUPERVISOR_MODE_VALID=y +CONFIG_BAT4=y +CONFIG_BAT4_NAME="STACK_IN_DCACHE" +CONFIG_BAT4_BASE=0xE6000000 +CONFIG_BAT4_ACCESS_RW=y +CONFIG_BAT4_USER_MODE_VALID=y +CONFIG_BAT4_SUPERVISOR_MODE_VALID=y CONFIG_BAT5=y CONFIG_BAT5_NAME="PAXE" CONFIG_BAT5_BASE=0xA0000000
make malloc space before relocation bigger, set
CONFIG_SYS_MALLOC_F_LEN=0x800
configs/kmeter1_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/kmeter1_defconfig b/configs/kmeter1_defconfig index 05967e11b1..5bddf0e28d 100644 --- a/configs/kmeter1_defconfig +++ b/configs/kmeter1_defconfig @@ -1,5 +1,6 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xF0000000 +CONFIG_SYS_MALLOC_F_LEN=0x800 CONFIG_KM_DEF_NETDEV="eth2" CONFIG_ENV_SIZE=0x4000 CONFIG_ENV_SECT_SIZE=0x20000
Heiko Schocher
