[GIT PULL] TI changes for v2020.04-rc4
Hi Tom,
Please find the pull request for v2020.04-rc4 containing TI specific changes.
Travis-CI build: https://travis-ci.org/lokeshvutla/u-boot/builds/655346045
Thanks and regards, Lokesh
The following changes since commit 548ce227d3d852455c6395c0cec30af0cda77b09:
Prepare v2020.04-rc3 (2020-02-26 07:53:20 -0500)
https://gitlab.denx.de/u-boot/custodians/u-boot-ti.git tags/ti-v2020.04-rc4
for you to fetch changes up to 8bef0597e46db229220de3a9c76bf448b290db62:
defconfig: k2x_hs: Remove DTB_RESELECT to fix DHCP issue (2020-02-26 18:35:29 +0530)
---------------------------------------------------------------- Below are the changes in this PR:
- Minor fix in AVS class 0 driver - DHCP fixes in Keystone2 HS platforms.
---------------------------------------------------------------- Madan Srinivas (1): defconfig: k2x_hs: Remove DTB_RESELECT to fix DHCP issue
Vignesh Raghavendra (1): misc: k3_avs: Fix possible NULL pointer deference
configs/k2e_evm_defconfig | 2 -- configs/k2e_hs_evm_defconfig | 2 -- configs/k2hk_evm_defconfig | 2 -- configs/k2hk_hs_evm_defconfig | 2 -- configs/k2l_evm_defconfig | 2 -- drivers/misc/k3_avs.c | 4 ++++ 6 files changed, 4 insertions(+), 10 deletions(-)
On Thu, Feb 27, 2020 at 08:48:53AM +0530, Lokesh Vutla wrote:
Hi Tom,
Lokesh Vutla
