[U-Boot] [PATCH] core: ofnode: Have ofnode_read_u32_default return a u32
It was returning an int, which doesn't work if the u32 it is reading, or the default value, will overflow a signed int.
While it could be made to work, when using a C standard/compiler where casting negative signed values to unsigned has a defined behavior, combined with careful casting, it seems obvious one is meant to use ofnode_read_s32_default() with signed values.
Cc: Simon Glass sjg@chromium.org Signed-off-by: Trent Piepho tpiepho@impinj.com --- drivers/core/ofnode.c | 2 +- include/dm/ofnode.h | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/core/ofnode.c b/drivers/core/ofnode.c index cc0c031e0d..0185f83399 100644 --- a/drivers/core/ofnode.c +++ b/drivers/core/ofnode.c @@ -39,7 +39,7 @@ int ofnode_read_u32(ofnode node, const char *propname, u32 *outp) return 0; }
-int ofnode_read_u32_default(ofnode node, const char *propname, u32 def) +u32 ofnode_read_u32_default(ofnode node, const char *propname, u32 def) { assert(ofnode_valid(node)); ofnode_read_u32(node, propname, &def); diff --git a/include/dm/ofnode.h b/include/dm/ofnode.h index d206ee2caa..dcda22b31b 100644 --- a/include/dm/ofnode.h +++ b/include/dm/ofnode.h @@ -224,7 +224,7 @@ static inline int ofnode_read_s32(ofnode node, const char *propname, * @def: default value to return if the property has no value * @return property value, or @def if not found */ -int ofnode_read_u32_default(ofnode ref, const char *propname, u32 def); +u32 ofnode_read_u32_default(ofnode ref, const char *propname, u32 def);
/** * ofnode_read_s32_default() - Read a 32-bit integer from a property
Applied to u-boot-dm, thanks!
Trent Piepho
