[PATCH 1/1] efi_loader: avoid #ifdef in efi_setup.c
We prefer `if` over `#ifdef` in our code.
Eliminate #ifdef statements in efi_setup.c.
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- lib/efi_loader/efi_setup.c | 25 ++++++++++--------------- 1 file changed, 10 insertions(+), 15 deletions(-)
diff --git a/lib/efi_loader/efi_setup.c b/lib/efi_loader/efi_setup.c index a610e032d2f..aa59bc7779d 100644 --- a/lib/efi_loader/efi_setup.c +++ b/lib/efi_loader/efi_setup.c @@ -86,7 +86,6 @@ out: return ret; }
-#ifdef CONFIG_EFI_SECURE_BOOT /** * efi_init_secure_boot - initialize secure boot state * @@ -112,12 +111,6 @@ static efi_status_t efi_init_secure_boot(void)
return ret; } -#else -static efi_status_t efi_init_secure_boot(void) -{ - return EFI_SUCCESS; -} -#endif /* CONFIG_EFI_SECURE_BOOT */
/** * efi_init_capsule - initialize capsule update state @@ -302,9 +295,11 @@ efi_status_t efi_init_obj_list(void) }
/* Secure boot */ - ret = efi_init_secure_boot(); - if (ret != EFI_SUCCESS) - goto out; + if (IS_ENABLED(CONFIG_EFI_SECURE_BOOT)) { + ret = efi_init_secure_boot(); + if (ret != EFI_SUCCESS) + goto out; + }
/* Indicate supported runtime services */ ret = efi_init_runtime_supported(); @@ -322,11 +317,11 @@ efi_status_t efi_init_obj_list(void) if (ret != EFI_SUCCESS) goto out; } -#ifdef CONFIG_NETDEVICES - ret = efi_net_register(); - if (ret != EFI_SUCCESS) - goto out; -#endif + if (IS_ENABLED(CONFIG_NETDEVICES)) { + ret = efi_net_register(); + if (ret != EFI_SUCCESS) + goto out; + } if (IS_ENABLED(CONFIG_ACPI)) { ret = efi_acpi_register(); if (ret != EFI_SUCCESS)
On Wed, 16 Oct 2024 at 13:17, Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote:
- efi_init_secure_boot - initialize secure boot state
return ret;
return EFI_SUCCESS;
- efi_init_capsule - initialize capsule update state
/* Secure boot */
goto out;
goto out;
} /* Indicate supported runtime services */ ret = efi_init_runtime_supported();
goto out;
-#endif
goto out;
-- 2.45.2
Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org
Ilias Apalodimas
